  4. SONOFF ZigBee 3.0 USB DONGLE PLUS
    5.6k
sonoff zigbee
435 Beiträge 50 Kommentatoren 154.4k Aufrufe 48 Beobachtet
  • hg6806H hg6806
    @thomas-braun sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
    iob logs --watch | uniq
    Was meinst du mit Kaltstart?
    Ich habe den Adapter gestoppt, Befehl ausgeführt und dann wieder Adapter gestartet. Hier das Ergebnis:
    pi@RPI4:~ $ iob logs --watch | uniq
    2023-04-21 22:06:21.270  - info: host.RPI4 "system.adapter.zigbee.0" disabled
    2023-04-21 22:06:21.275  - info: host.RPI4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2023-04-21 22:06:21.283  - info: zigbee.0 (1919) Got terminate signal TERMINATE_YOURSELF
    2023-04-21 22:06:21.285  - info: zigbee.0 (1919) cleaned everything up...
    2023-04-21 22:06:21.288  - info: zigbee.0 (1919) Zigbee: disabling joining new devices.
    2023-04-21 22:06:21.537  - info: host.RPI4 stopInstance system.adapter.zigbee.0 send kill signal
    2023-04-21 22:06:21.786  - info: zigbee.0 (1919) terminating
    2023-04-21 22:06:21.788  - debug: zigbee.0 (1919) Plugin sentry destroyed
    2023-04-21 22:06:21.789  - info: zigbee.0 (1919) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-21 22:06:22.469  - info: host.RPI4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-21 22:06:29.879  - info: host.RPI4 "system.adapter.zigbee.0" enabled
    2023-04-21 22:06:30.309  - info: host.RPI4 instance system.adapter.zigbee.0 started with pid 56240
    2023-04-21 22:06:34.252  - debug: zigbee.0 (56240) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-04-21 22:06:34.397  - debug: zigbee.0 (56240) Objects client ready ... initialize now
    2023-04-21 22:06:34.400  - debug: zigbee.0 (56240) Objects create System PubSub Client
    2023-04-21 22:06:34.403  - debug: zigbee.0 (56240) Objects create User PubSub Client
    2023-04-21 22:06:34.675  - debug: zigbee.0 (56240) Objects client initialize lua scripts
    2023-04-21 22:06:34.690  - debug: zigbee.0 (56240) Objects connected to redis: 127.0.0.1:9001
    2023-04-21 22:06:34.808  - debug: zigbee.0 (56240) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-04-21 22:06:34.907  - debug: zigbee.0 (56240) States create System PubSub Client
    2023-04-21 22:06:34.910  - debug: zigbee.0 (56240) States create User PubSub Client
    2023-04-21 22:06:35.130  - debug: zigbee.0 (56240) States connected to redis: 127.0.0.1:9000
    2023-04-21 22:06:35.732  - debug: zigbee.0 (56240) Plugin sentry Initialize Plugin (enabled=true)
    2023-04-21 22:06:36.307  - info: zigbee.0 (56240) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.0, js-controller: 4.0.24
    2023-04-21 22:06:36.359  - debug: zigbee.0 (56240) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channe       lList":[15],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-d       ata/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfigur       ation":false}}
    2023-04-21 22:06:36.461  - info: zigbee.0 (56240) Starting Zigbee  npm ...
    2023-04-21 22:06:36.463  - debug: zigbee.0 (56240) Starting zigbee-herdsman...
    2023-04-21 22:06:37.178  - info: zigbee.0 (56240) Installed Version: iobroker.zigbee@1.8.10
    2023-04-21 22:06:37.201  - debug: zigbee.0 (56240) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_04_21-22_06_36.tar.gz success
    2023-04-21 22:06:37.478  - debug: zigbee.0 (56240) zigbee-herdsman started
    2023-04-21 22:06:37.480  - info: zigbee.0 (56240) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintr       el":1,"revision":20221226}}
    2023-04-21 22:06:37.489  - debug: zigbee.0 (56240) Zigbee network parameters: panID=6754 channel=15 extendedPanID=8f54d126004b1200
    2023-04-21 22:06:37.491  - info: zigbee.0 (56240) Unable to disable LED, unsupported function.
    2023-04-21 22:06:37.513  - info: zigbee.0 (56240)   --> transmitPower : normal
    2023-04-21 22:06:37.523  - info: zigbee.0 (56240) Currently no devices.
    2023-04-21 22:06:37.526  - info: zigbee.0 (56240) Zigbee started
    2023-04-21 22:06:37.553  - debug: zigbee.0 (56240) getGroups result: {}
    2023-04-21 22:07:04.780  - info: host.RPI4 "system.adapter.zigbee.0" disabled
    2023-04-21 22:07:04.781  - info: host.RPI4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2023-04-21 22:07:04.795  - info: zigbee.0 (56240) Got terminate signal TERMINATE_YOURSELF
    2023-04-21 22:07:04.799  - info: zigbee.0 (56240) cleaned everything up...
    2023-04-21 22:07:04.804  - info: zigbee.0 (56240) Zigbee: disabling joining new devices.
    2023-04-21 22:07:05.081  - info: host.RPI4 stopInstance system.adapter.zigbee.0 send kill signal
    2023-04-21 22:07:05.301  - info: zigbee.0 (56240) terminating
    2023-04-21 22:07:05.303  - debug: zigbee.0 (56240) Plugin sentry destroyed
    2023-04-21 22:07:05.303  - info: zigbee.0 (56240) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-21 22:07:06.031  - info: host.RPI4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-21 22:07:11.049  - info: host.RPI4 "system.adapter.zigbee.0" enabled
    2023-04-21 22:07:11.451  - info: host.RPI4 instance system.adapter.zigbee.0 started with pid 56270
    2023-04-21 22:07:15.174  - debug: zigbee.0 (56270) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-04-21 22:07:15.350  - debug: zigbee.0 (56270) Objects client ready ... initialize now
    2023-04-21 22:07:15.472  - debug: zigbee.0 (56270) Objects create System PubSub Client
    2023-04-21 22:07:15.476  - debug: zigbee.0 (56270) Objects create User PubSub Client
    2023-04-21 22:07:15.768  - debug: zigbee.0 (56270) Objects client initialize lua scripts
    2023-04-21 22:07:15.779  - debug: zigbee.0 (56270) Objects connected to redis: 127.0.0.1:9001
    2023-04-21 22:07:15.893  - debug: zigbee.0 (56270) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-04-21 22:07:15.985  - debug: zigbee.0 (56270) States create System PubSub Client
    2023-04-21 22:07:15.988  - debug: zigbee.0 (56270) States create User PubSub Client
    2023-04-21 22:07:16.214  - debug: zigbee.0 (56270) States connected to redis: 127.0.0.1:9000
    2023-04-21 22:07:16.825  - debug: zigbee.0 (56270) Plugin sentry Initialize Plugin (enabled=true)
    2023-04-21 22:07:17.386  - info: zigbee.0 (56270) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.0, js-controller: 4.0.24
    2023-04-21 22:07:17.438  - debug: zigbee.0 (56270) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channe       lList":[15],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-d       ata/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfigur       ation":false}}
    2023-04-21 22:07:17.525  - info: zigbee.0 (56270) Starting Zigbee  npm ...
    2023-04-21 22:07:17.527  - debug: zigbee.0 (56270) Starting zigbee-herdsman...
    2023-04-21 22:07:18.224  - info: zigbee.0 (56270) Installed Version: iobroker.zigbee@1.8.10
    2023-04-21 22:07:18.247  - debug: zigbee.0 (56270) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_04_21-22_07_17.tar.gz success
    2023-04-21 22:07:18.547  - debug: zigbee.0 (56270) zigbee-herdsman started
    2023-04-21 22:07:18.548  - info: zigbee.0 (56270) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintr       el":1,"revision":20221226}}
    2023-04-21 22:07:18.561  - debug: zigbee.0 (56270) Zigbee network parameters: panID=6754 channel=15 extendedPanID=8f54d126004b1200
    2023-04-21 22:07:18.563  - info: zigbee.0 (56270) Unable to disable LED, unsupported function.
    2023-04-21 22:07:18.599  - info: zigbee.0 (56270)   --> transmitPower : normal
    2023-04-21 22:07:18.634  - info: zigbee.0 (56270) Currently no devices.
    2023-04-21 22:07:18.638  - info: zigbee.0 (56270) Zigbee started
    2023-04-21 22:07:18.657  - debug: zigbee.0 (56270) getGroups result: {}
    #401
    @hg6806 sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
    Kann es sein, dass die extendedPanID falsch eingestellt ist?
    hg6806H 1 Antwort Letzte Antwort
      hg6806H Offline
      hg6806H Offline
      hg6806
      #402
      Habe ich nie was verändert:
      Ist da wirklich was falsch?
      • hg6806H hg6806
        #403
        Ja, setz da statt DDDDDDDDDDDDDDDD
        halt
        8f54d126004b1200
        hin. DDDDDDDDDDDDDDDD ist nur als Platzhalter zu verstehen.
        • hg6806H hg6806
          #404
          @hg6806
          Und statt /dev/ttyUSB0 setzt man besser den Link aus
          ls -la /dev/serial/by-id
          ein.
            @hg6806
            ein.
            hg6806H Offline
            hg6806H Offline
            hg6806
            #405
            Erweiterte PAN ID habe ich umgestellt, findet noch immer keine Geräte.
            Bei dem Link bekomme ich leider nur Pünktchen:
            pi@RPI4:~ $ ls -la /dev/serial/by-id
            total 0
            drwxr-xr-x 2 root root 60 Apr 21 00:27 .
            drwxr-xr-x 4 root root 80 Apr 21 00:27 ..
            lrwxrwxrwx 1 root root 13 Apr 21 00:27 usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 -> ../../ttyUSB0
            pi@RPI4:~ $
            FreunderNachtF Thomas BraunT 2 Antworten Letzte Antwort
            • hg6806H hg6806
              total 0
              pi@RPI4:~ $
              FreunderNachtF Offline
              FreunderNacht
              #406
              @hg6806
              Schau dir mal dieses Video von Matthias Kleine an:
              Ab Minute 3:55 kommt das Thema.
              Das ganze Video ist aber auch interessant.
              https://youtu.be/2zoZ0VSuIEA
              Intel NUC mit Proxmox
              IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
              Influx DB
              Grafana
              PiHole
              PiVPN
              • hg6806H hg6806
                total 0
                pi@RPI4:~ $
                #407
                @hg6806
                ? Wie Pünktchen? Hat nix mit Pünktchen und Anton zu tun...
                Der einzutragende Link ist
                /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                  @hg6806
                  hg6806H Offline
                  hg6806H Offline
                  hg6806
                  #408
                  Eingetragen, bringt auch keine Geräte nach dem Suchen.
                  @FreunderNacht Auch alles befolgt.
                  • hg6806H hg6806
                    #409
                    Log schaut jetzt wie aus?
                      hg6806H Offline
                      hg6806H Offline
                      hg6806
                      #410
                      admin
                      v6.4.3
                      Log-Größe: 674 B
                      zigbee.0
                      Zeit
                      debug
                      Nachricht
                      zigbee.0
                      2023-04-21 23:39:43.255	debug	getGroups result: {}
                      zigbee.0
                      2023-04-21 23:39:43.247	info	Zigbee started
                      zigbee.0
                      2023-04-21 23:39:43.246	info	Currently no devices.
                      zigbee.0
                      2023-04-21 23:39:43.238	info	--> transmitPower : normal
                      zigbee.0
                      2023-04-21 23:39:43.207	info	Unable to disable LED, unsupported function.
                      zigbee.0
                      2023-04-21 23:39:43.205	debug	Zigbee network parameters: panID=6754 channel=11 extendedPanID=8f54d126004b1200
                      zigbee.0
                      2023-04-21 23:39:43.199	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                      zigbee.0
                      2023-04-21 23:39:43.198	debug	zigbee-herdsman started
                      zigbee.0
                      2023-04-21 23:39:42.832	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_04_22-00_39_41.tar.gz success
                      zigbee.0
                      2023-04-21 23:39:42.807	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      2023-04-21 23:39:42.023	debug	Starting zigbee-herdsman...
                      zigbee.0
                      2023-04-21 23:39:42.022	info	Starting Zigbee npm ...
                      zigbee.0
                      2023-04-21 23:39:41.939	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                      zigbee.0
                      2023-04-21 23:39:41.886	info	starting. Version 1.8.11 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.0, js-controller: 4.0.24
                      zigbee.0
                      2023-04-21 23:39:41.364	debug	Plugin sentry Initialize Plugin (enabled=true)
                      • hg6806H Offline
                        hg6806H Offline
                        hg6806
                        schrieb am zuletzt editiert von hg6806
                        #411
                        So, habe die Geräte endlich reinbekommen.
                        Nach stundenlangen Versuchen hatte ich noch einen RPi3 neu aufgesetzt und einen einfachen CC2531 angesteckt.
                        Mit dem hatte ich die Geräte sofort gefunden und auf einmal waren sie auch auf dem anderen Pi dann eingefügt.
                        Keine Ahnung warum.
                        Ich bin mir nicht ganz sicher, aber ich gleich ich hatte bei dem anderen wo es nie funktioniert hatte, dann nicht einmal danach gesucht.
                        Kann das jemand erklären?
                        Ach ja, die Feldstärke übrigens ist richtig gut.
                        Zwischen 120 - 190!
                        EDIT:
                        Noch zwei Infos. Den "Hilfs-"Pi3 hatte ich dann wieder ausgemacht, den Sensoren blieben drin. Bis auf einen der hatte, wahrscheinlich die zu große Entfernung die Verbindung verloren. Den habe ich auch wieder nicht mehr reinbekommen. Erst wieder durch Einschalten des Pi3.
                        Der Pi4, wo es so schwerfällig funktioniert ist eingebaut hinter einer Wandverblendung. Das hat man hier in Spanien ganz gerne, und ist auch ganz praktisch. Allerdings hab e ich hier auch recht viel eingepackt. Ein SAT Multiswitch (unicable), ein 1GBit Eth Switch und der Pi4 mit einem Meanwell Netzteil. Vielleicht macht doch einer hier böse EMV, weil einfach zu dicht zusammengepackt. Funken tut aber nur der Pi auf BT und Zickbee. Wifi ist auch abgeschaltet.
                        J Thomas BraunT 2 Antworten Letzte Antwort
                        • hg6806H hg6806
                          Keine Ahnung warum.
                          Zwischen 120 - 190!
                          EDIT:
                          Jan1
                          #412
                          @hg6806
                          Der Dongle sollte auf alle Fälle mit ner kurzen Verlängerung angeschlossen werden, sonst gibts Probleme.
                          • hg6806H hg6806
                            Keine Ahnung warum.
                            Zwischen 120 - 190!
                            EDIT:
                            #413
                            Auf dem Pi kann man das nicht abschalten. Der funkt immer durch die Gegend. Auch wenn WiFi nicht konfiguriert ist.
                            • hg6806H Offline
                              hg6806H Offline
                              hg6806
                              #414
                              Die Zigbee Dongles sind immer direkt an USB gesteckt.
                              Was noch auffällt.
                              Am Problem-Pi4 bekomme ich seit über 12h keine Batterie-Daten rein. Der Hilfs-Pi3 hatte sie sofort.
                              Also irgendwas scheint beim Pi4 mit Anlernen nicht i.O. zu sein.
                              Thomas BraunT arteckA J 3 Antworten Letzte Antwort
                              • hg6806H hg6806
                                Was noch auffällt.
                                #415
                                Setze eine USB-Verlängerung ein.
                                • hg6806H hg6806
                                  Was noch auffällt.
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #416
                                  das ist der FEHLER.. pack bitte eine Verlängerung dazwischen.. egal welcher PI und obs mal funktioniert hat oder nicht
                                  und wenns geht NICHT an USB3
                                  • hg6806H hg6806
                                    Was noch auffällt.
                                    Jan1
                                    #417
                                    Das wird dann auch immer Probleme geben ;)
                                    Bekanntes Problem und auch immer mit ner kurzen Verlängerung gelöst. Hatte auch das Problem mit dem Anlernen und es lag am direkten Stecken des Dongle. Ist auch egal ob das ein Pi oder sonst was ist.
                                    • J Jan1
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #418
                                      @jan1 sagte in SONOFF ZigBee 3.0 USB DONGLE PLUS:
                                      nein ist nicht egal... am NUC ist es egal
                                      der PI und dessen WIFI ist NUR das Problem..
                                      usb3.0_pi.mp4
                                      J hg6806H 2 Antworten Letzte Antwort
                                      • Thomas BraunT Online
                                        #419
                                        @arteck
                                        Ich hatte so ein Verhalten auch schon mit USB-Dongles von Funkmäusen/Tastaturen an einem Mini-PC mit Windows. Direkt am Getät eingesteckt war die Maus nicht zu benutzen, mit Verlängerung ging es dann. Ist also kein exklusives Problem des Pi und Zigbee-Sticks.
                                        • arteckA arteck
                                          usb3.0_pi.mp4
                                          Jan1
                                          #420
                                          @arteck
                                          Ob der NUC da viel anders als mein Beelink ist? Der wollte es auch nur mit Verlängerung ;)
