  4. Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...
adaptersecurity s2testz-wave 2
49 Beiträge 11 Kommentatoren 7.5k Aufrufe 14 Beobachtet
  • E Esmax666
    Hallo zusammen
    Ich habe das update durchgefürt und ich bekomme leider errors ? ist das normal ?
    ich habe dannach targevalue auf 90 gestetzt für die rollo, aber das werte bleibt leider auf 99
    $ iobroker upgrade zwave2@2.2.0
    Update zwave2 from @1.10.4 to @2.2.0
    NPM version: 6.14.15
    npm install iobroker.zwave2@2.2.0 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ../src/serialport.cpp: At global scope:../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { | ^
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { | ^
    In file included from ../node_modules/nan/nan.h:58, from ../src/./serialport.h:13, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 736 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ 770 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ 486 | NODE_MODULE(serialport, init); | ^~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] 176 | snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); | ^~In file included from /usr/include/stdio.h:866, from ../src/serialport.h:10, from ../src/serialport_unix.cpp:2:/usr/include/arm-linux-gnueabihf/bits/stdio2.h:71:35: note: ‘__builtin___snprintf_chk’ output 20 or more bytes (assuming 1043) into a destination of size 1024 71 | return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, | ~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 72 | __glibc_objsize (__s), __fmt, | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 73 | __va_arg_pack ()); | ~~~~~~~~~~~~~~~~~
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] 86 | snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); | ^~In file included from /usr/include/stdio.h:866, from ../src/serialport.h:10, from ../src/serialport_unix.cpp:2:/usr/include/arm-linux-gnueabihf/bits/stdio2.h:71:35: note: ‘__builtin___snprintf_chk’ output 22 or more bytes (assuming 1045) into a destination of size 1024 71 | return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, | ~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 72 | __glibc_objsize (__s), __fmt, | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 73 | __va_arg_pack ()); | ~~~~~~~~~~~~~~~~~
    ../src/linux/BluetoothSerialPort.cc:18:6: error: variable or field ‘InitAll’ declared void
    18 | void InitAll(Handle<Object> exports) { | ^~~~~~~
    ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope 18 | void InitAll(Handle<Object> exports) { | ^~~~~~../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token 18 | void InitAll(Handle<Object> exports) { | ^
    ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope 18 | void InitAll(Handle<Object> exports) { | ^~~~~~~
    In file included from ../src/linux/BluetoothSerialPort.cc:12:
    ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’ 736 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~~~~~
    make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.11.0-1019-raspigyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.22.7gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
    Update "system.adapter.zwave2.0"
    upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
    upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
    upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
    upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
    upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
    upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
    upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
    upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
    upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
    upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
    upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
    upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-UGEYJTWC.js.map build/chunk-UGEYJTWC.js.map application/json
    upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-UGEYJTWC.js build/chunk-UGEYJTWC.js application/javascript
    upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-M6QDE7JV.js.map build/chunk-M6QDE7JV.js.map application/json
    upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-M6QDE7JV.js build/chunk-M6QDE7JV.js application/javascript
    upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-4AZ3T2J6.js.map build/chunk-4AZ3T2J6.js.map application/json
    upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-4AZ3T2J6.js build/chunk-4AZ3T2J6.js application/javascript
    upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
    Adapter "zwave2" updated
    Process exited with code 0
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @esmax666 sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
    Was passiert dabei im Z-Wave Log (siehe neuer Tab)?
    Warum sudo böse ist: https://forum.iobroker.net/post/17109
    E 1 Antwort Letzte Antwort
      Wo hast du denn den Kernel her? Soweit ich weiß ist 5.10 für RaspberryOS aktuell.
      [Edit:] Scheint ein nixbuntu zu sein.
      Esmax666
      schrieb am zuletzt editiert von Esmax666
      @thomas-braun said in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
      genau ubuntu :)
      @alcalzone said in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
      Gibt nicht so infos:
      ich habe gerade noch ein befehl gemacht
      ich hab nur das als log, ist das normal ?
      Debug mod ist aktiv
      Subscribed to logs...
      2021-10-15T16:34:41.363Z SERIAL « 0x0109000400050380031463                                            (11 bytes)
      2021-10-15T16:34:41.372Z CNTRLR   [Node 005] [~] [Battery] level: 20 => 20                          [Endpoint 0]
      2021-10-15T16:34:41.376Z CNTRLR   [Node 005] [~] [Battery] isLow: false => false                    [Endpoint 0]
      2021-10-15T16:34:41.378Z SERIAL » [ACK]        (0x06)
      2021-10-15T16:34:41.381Z DRIVER « [Node 005] [REQ] [ApplicationCommand]
                                        └─[BatteryCCReport]
                                            level:  20
                                            is low: false
      und das ist die allgemein Log
      2021-10-15 18:01:00.287 - debug: zwave2.0 (24871) Node 2: metadata updated: airTemperature
      2021-10-15 18:01:00.290 - debug: zwave2.0 (24871) Node 2: value updated: airTemperature => 17.17
      2021-10-15 18:01:15.183 - debug: zwave2.0 (24871) Node 33: value updated: value_electric_kwh_consumed => 0.23
      2021-10-15 18:02:26.986 - debug: zwave2.0 (24871) Node 4: metadata updated: airTemperature
      2021-10-15 18:02:26.989 - debug: zwave2.0 (24871) Node 4: value updated: airTemperature => 17.17
      2021-10-15 18:05:00.012 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:05:00.013 - debug: shuttercontrol.0 (24492) Sun Azimut: 253.7°
      2021-10-15 18:05:00.014 - debug: shuttercontrol.0 (24492) Sun Elevation: 2.4°
      2021-10-15 18:07:08.214 - debug: zwave2.0 (24871) Node 30: value updated: value_electric_kwh_consumed => 0.23
      2021-10-15 18:10:00.016 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:10:00.017 - debug: shuttercontrol.0 (24492) Sun Azimut: 254.7°
      2021-10-15 18:10:00.017 - debug: shuttercontrol.0 (24492) Sun Elevation: 1.6°
      2021-10-15 18:14:48.286 - debug: zwave2.0 (24871) Node 29: value updated: value_electric_kwh_consumed => 0.24
      2021-10-15 18:15:00.015 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:15:00.016 - debug: shuttercontrol.0 (24492) Sun Azimut: 255.6°
      2021-10-15 18:15:00.016 - debug: shuttercontrol.0 (24492) Sun Elevation: 0.8°
      2021-10-15 18:17:06.124 - debug: zwave2.0 (24871) sendTo "getSerialPorts" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:17:36.900 - debug: zwave2.0 (24871) sendTo "getSerialPorts" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:20:00.018 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:20:00.019 - debug: shuttercontrol.0 (24492) Sun Azimut: 256.6°
      2021-10-15 18:20:00.019 - debug: shuttercontrol.0 (24492) Sun Elevation: 0°
      2021-10-15 18:24:12.135 - debug: zwave2.0 (24871) sendTo "getSerialPorts" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:24:27.470 - info: host.ubuntu Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2021-10-15 18:25:00.016 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:25:00.016 - debug: shuttercontrol.0 (24492) Sun Azimut: 257.5°
      2021-10-15 18:25:00.017 - debug: shuttercontrol.0 (24492) Sun Elevation: -0.8°
      2021-10-15 18:25:05.312 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.320 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.328 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.340 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.349 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.357 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.370 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.379 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.392 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.415 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.427 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.434 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.447 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.456 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.463 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.480 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.490 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.500 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.514 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.522 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.531 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.544 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.553 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.560 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.584 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.592 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.608 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.637 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.644 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.653 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.669 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.676 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.686 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.699 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.706 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.713 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.725 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.732 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.739 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.750 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.757 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.764 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.776 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.783 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.791 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.805 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.816 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.823 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.834 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.841 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:05.849 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.543 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.558 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.560 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.562 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.563 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.564 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.567 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.568 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.569 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.570 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.571 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.572 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.575 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.576 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.577 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.578 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.580 - debug: zwave2.0 (24871) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.582 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.592 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.595 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.601 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.605 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.611 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.616 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.619 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.621 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.623 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.625 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.628 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.632 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.635 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.639 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.641 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.643 - debug: zwave2.0 (24871) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.647 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.650 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.654 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.656 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.659 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.661 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.666 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.670 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.672 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.674 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.677 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.680 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.684 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.687 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.689 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.692 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:06.695 - debug: zwave2.0 (24871) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:38.754 - debug: zwave2.0 (24871) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:59.173 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:59.174 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:25:59.566 - debug: zwave2.0 (24871) sendTo "getNetworkMap" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:02.959 - debug: zwave2.0 (24871) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:15.334 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:15.357 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:15.374 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:15.393 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:15.410 - debug: zwave2.0 (24871) Node 31: value updated: value_electric_kwh_consumed => 0.26
      2021-10-15 18:26:15.419 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:47.648 - info: host.ubuntu "system.adapter.zwave2.0" disabled
      2021-10-15 18:26:47.654 - info: host.ubuntu stopInstance system.adapter.zwave2.0 (force=false, process=true)
      2021-10-15 18:26:47.694 - info: zwave2.0 (24871) Got terminate signal TERMINATE_YOURSELF
      2021-10-15 18:26:47.696 - info: host.ubuntu stopInstance system.adapter.zwave2.0 send kill signal
      2021-10-15 18:26:47.696 - info: zwave2.0 (24871) Shutting down driver...
      2021-10-15 18:26:47.698 - debug: zwave2.0 (24871) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:26:47.758 - info: zwave2.0 (24871) Resetting node status...
      2021-10-15 18:26:48.201 - info: zwave2.0 (24871) terminating
      2021-10-15 18:26:48.204 - info: zwave2.0 (24871) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-10-15 18:26:48.318 - info: zwave2.0 (24871) Cleaned everything up!
      2021-10-15 18:26:48.700 - info: host.ubuntu stopInstance system.adapter.zwave2.0 killing pid 24871
      2021-10-15 18:26:48.851 - info: host.ubuntu instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-10-15 18:26:54.351 - info: host.ubuntu "system.adapter.zwave2.0" enabled
      2021-10-15 18:26:54.506 - info: host.ubuntu instance system.adapter.zwave2.0 started with pid 25293
      2021-10-15 18:26:56.827 - debug: zwave2.0 (25293) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-10-15 18:26:56.863 - debug: zwave2.0 (25293) Objects client ready ... initialize now
      2021-10-15 18:26:56.866 - debug: zwave2.0 (25293) Objects create System PubSub Client
      2021-10-15 18:26:56.868 - debug: zwave2.0 (25293) Objects create User PubSub Client
      2021-10-15 18:26:56.869 - debug: zwave2.0 (25293) Objects client initialize lua scripts
      2021-10-15 18:26:56.884 - debug: zwave2.0 (25293) Objects connected to redis: 127.0.0.1:9001
      2021-10-15 18:26:56.962 - debug: zwave2.0 (25293) objectDB connected
      2021-10-15 18:26:56.964 - debug: zwave2.0 (25293) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-10-15 18:26:56.974 - debug: zwave2.0 (25293) States create System PubSub Client
      2021-10-15 18:26:56.975 - debug: zwave2.0 (25293) States create User PubSub Client
      2021-10-15 18:26:56.984 - debug: zwave2.0 (25293) States connected to redis: 127.0.0.1:9000
      2021-10-15 18:26:56.985 - debug: zwave2.0 (25293) statesDB connected
      2021-10-15 18:26:57.268 - info: zwave2.0 (25293) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.7, js-controller: 3.3.18
      2021-10-15 18:27:01.052 - info: zwave2.0 (25293) The driver is ready. Found 21 nodes.
      2021-10-15 18:27:01.402 - info: zwave2.0 (25293) Node 1: ready to use
      2021-10-15 18:27:01.439 - info: zwave2.0 (25293) Updating broadcast/multicast node states
      2021-10-15 18:27:02.518 - info: zwave2.0 (25293) Node 7: ready to use
      2021-10-15 18:27:02.563 - info: zwave2.0 (25293) Node 8: ready to use
      2021-10-15 18:27:02.598 - info: zwave2.0 (25293) Node 9: ready to use
      2021-10-15 18:27:02.669 - info: zwave2.0 (25293) Node 2: ready to use
      2021-10-15 18:27:02.698 - info: zwave2.0 (25293) Node 2 is alive
      2021-10-15 18:27:02.994 - info: zwave2.0 (25293) Node 25: ready to use
      2021-10-15 18:27:03.932 - info: zwave2.0 (25293) Node 3: ready to use
      2021-10-15 18:27:03.949 - info: zwave2.0 (25293) Node 3 is alive
      2021-10-15 18:27:05.378 - info: zwave2.0 (25293) Node 4: ready to use
      2021-10-15 18:27:05.413 - info: zwave2.0 (25293) Node 4 is alive
      2021-10-15 18:27:06.680 - info: zwave2.0 (25293) Node 5: ready to use
      2021-10-15 18:27:06.745 - info: zwave2.0 (25293) Node 5 is alive
      2021-10-15 18:27:08.327 - info: zwave2.0 (25293) Node 22: ready to use
      2021-10-15 18:27:08.345 - info: zwave2.0 (25293) Node 22 is alive
      2021-10-15 18:27:12.921 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:12.924 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:12.931 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:12.936 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:12.941 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:12.944 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:14.940 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:14.949 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:14.956 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:15.958 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:15.966 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:15.973 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:16.974 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:16.988 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:16.995 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:20.034 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:20.044 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:20.053 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:21.167 - info: zwave2.0 (25293) Node 26 is dead
      2021-10-15 18:27:21.277 - info: zwave2.0 (25293) Node 29: ready to use
      2021-10-15 18:27:21.305 - info: zwave2.0 (25293) Node 29 is alive
      2021-10-15 18:27:21.357 - info: zwave2.0 (25293) Node 30: ready to use
      2021-10-15 18:27:21.396 - info: zwave2.0 (25293) Node 31: ready to use
      2021-10-15 18:27:21.407 - info: zwave2.0 (25293) Node 30 is alive
      2021-10-15 18:27:21.437 - info: zwave2.0 (25293) Node 32: ready to use
      2021-10-15 18:27:21.447 - info: zwave2.0 (25293) Node 31 is alive
      2021-10-15 18:27:21.481 - info: zwave2.0 (25293) Node 33: ready to use
      2021-10-15 18:27:21.499 - info: zwave2.0 (25293) Node 32 is alive
      2021-10-15 18:27:21.520 - info: zwave2.0 (25293) Node 33 is alive
      2021-10-15 18:27:21.558 - info: zwave2.0 (25293) Node 34: ready to use
      2021-10-15 18:27:21.603 - info: zwave2.0 (25293) Node 35: ready to use
      2021-10-15 18:27:21.627 - info: zwave2.0 (25293) Node 34 is alive
      2021-10-15 18:27:21.664 - info: zwave2.0 (25293) Node 35 is alive
      2021-10-15 18:27:21.769 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_029.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:21.818 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_030.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:21.852 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_031.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:21.908 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_032.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:21.930 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_033.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:21.964 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_034.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:22.024 - warn: zwave2.0 (25293) Deleting orphaned state zwave2.0.Node_035.Meter.value_electric_kwh_consumed
      2021-10-15 18:27:22.055 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.062 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.070 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.936 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.959 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.970 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:22.979 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.003 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.014 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.016 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.035 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.038 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.041 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.052 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.060 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.062 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.089 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.094 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.098 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.103 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.105 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.107 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.111 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.123 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.126 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.129 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.131 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.134 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.139 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.144 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.146 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.150 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.152 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.154 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.156 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.158 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.159 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.199 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.201 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.203 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.205 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.206 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.207 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.209 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.210 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.211 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.213 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.240 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.242 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.244 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.246 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.248 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.252 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.300 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.303 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.306 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.308 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.312 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.315 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.318 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.321 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.324 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.329 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.332 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.334 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.336 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.339 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.347 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.349 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.352 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.353 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.355 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.359 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.360 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.362 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.364 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.365 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.368 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.371 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.373 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.376 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.378 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.381 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.393 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.396 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.398 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.401 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.404 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.407 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.410 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.420 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.429 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.436 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.438 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.444 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.449 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.452 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.454 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.458 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.461 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.465 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.467 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.469 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.471 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.479 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.484 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.488 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.490 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.492 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.494 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.497 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.499 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.504 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.508 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.511 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.514 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.516 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.518 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.521 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.524 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.532 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.542 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.544 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.546 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.548 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.549 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.553 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.554 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.556 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.558 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.559 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.563 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.565 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.608 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:23.611 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:34.873 - error: zwave2.0 (25293) Node 26 interview failed: The node is dead
      2021-10-15 18:27:39.593 - debug: zwave2.0 (25293) sendTo "getNetworkMap" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:39.689 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:27:49.449 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:28:12.301 - debug: shuttercontrol.0 (24492) Shutter state changed: Volet bureau Haut old value = 90 new value = 80
      2021-10-15 18:28:12.301 - debug: shuttercontrol.0 (24492) Volet bureau Haut drived manually to 80. Old value = 90. New value = 80
      2021-10-15 18:28:12.302 - debug: shuttercontrol.0 (24492) Volet bureau Haut Updated trigger action to Manu_Mode to prevent moving after window close
      2021-10-15 18:28:12.382 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:28:12.383 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:28:22.474 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 80
      2021-10-15 18:28:32.125 - debug: shuttercontrol.0 (24492) Shutter state changed: Volet chambre invité Haut old value = 99 new value = 1
      2021-10-15 18:28:32.126 - debug: shuttercontrol.0 (24492) Volet chambre invité Haut drived manually to 1. Old value = 99. New value = 1
      2021-10-15 18:28:32.127 - debug: shuttercontrol.0 (24492) Volet chambre invité Haut Updated trigger action to Manu_Mode to prevent moving after window close
      2021-10-15 18:30:00.015 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:30:00.016 - debug: shuttercontrol.0 (24492) Sun Azimut: 258.5°
      2021-10-15 18:30:00.016 - debug: shuttercontrol.0 (24492) Sun Elevation: -1.5°
      2021-10-15 18:30:00.870 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.879 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.886 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.898 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.908 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.917 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.930 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.937 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.944 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.956 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.963 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.970 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.981 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.987 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:00.995 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.006 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.013 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.021 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.033 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.040 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.047 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.057 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.063 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.070 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.086 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.093 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.101 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.126 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.134 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.141 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.157 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.164 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.171 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.182 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.187 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.194 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.204 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.210 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.220 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.237 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.244 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.251 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.262 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.269 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.277 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.287 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.293 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.300 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.310 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.317 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:01.324 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.059 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.062 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.066 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.068 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.071 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.073 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.074 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.076 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.078 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.079 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.085 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.088 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.090 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.091 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.093 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.095 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.096 - debug: zwave2.0 (25293) sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.101 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.107 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.111 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.112 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.114 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.119 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.121 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.124 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.126 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.130 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.141 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.144 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.147 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.150 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.152 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.155 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.158 - debug: zwave2.0 (25293) sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.161 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.164 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.167 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.170 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.173 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.176 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.183 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.187 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.189 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.190 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.194 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.196 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.197 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.200 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.201 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.203 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.236 - debug: zwave2.0 (25293) sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:30:02.861 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:34:41.364 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:34:41.365 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:34:41.373 - debug: zwave2.0 (25293) Node 5: value updated: level => 20
      2021-10-15 18:34:41.377 - debug: zwave2.0 (25293) Node 5: value updated: isLow => false
      2021-10-15 18:34:42.388 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:35:00.018 - debug: shuttercontrol.0 (24492) calculate astrodata ...
      2021-10-15 18:35:00.018 - debug: shuttercontrol.0 (24492) Sun Azimut: 259.4°
      2021-10-15 18:35:00.019 - debug: shuttercontrol.0 (24492) Sun Elevation: -2.3°
      2021-10-15 18:36:03.161 - debug: zwave2.0 (25293) sendTo "getSerialPorts" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:37:00.529 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
      2021-10-15 18:37:00.687 - debug: zwave2.0 (25293) Node 32: value updated: value_electric_kwh_consumed => 0.19
      • AlCalzoneA AlCalzone
        @esmax666 sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
        ich habe dannach targevalue auf 90 gestetzt für die rollo, aber das werte bleibt leider auf 99
        Was passiert dabei im Z-Wave Log (siehe neuer Tab)?
        Esmax666
        schrieb am zuletzt editiert von Esmax666
        @alcalzone said in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
        jetzt habe ich ein bisschen mehr:
        Subscribed to logs...
        2021-10-15T17:34:18.298Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:18.303Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:18.305Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                          └─[SecurityCCNonceGet]
        2021-10-15T17:34:18.317Z SERIAL » 0x011100131e0a9880a471ad18d34f543305345b                            (19 bytes)
        2021-10-15T17:34:18.317Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ transmit options: 0x05
                                          │ callback id:      52
                                          └─[SecurityCCNonceReport]
                                              nonce: 0xa471ad18d34f5433
        2021-10-15T17:34:18.320Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:18.326Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:18.327Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:18.328Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:18.442Z SERIAL « 0x010700133400000cd3                                                 (9 bytes)
        2021-10-15T17:34:18.443Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:18.445Z DRIVER « [REQ] [SendData]
                                            callback id:     52
                                            transmit status: OK
        2021-10-15T17:34:18.532Z SERIAL « 0x011f0004001e19988183be5ad26fafae1f936e04e405bca42b90425d8689a26a5 (33 bytes)
                                          d
        2021-10-15T17:34:18.534Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:18.537Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 99 => 90         [Endpoint 0]
        2021-10-15T17:34:18.540Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                          └─[SecurityCCCommandEncapsulation]
                                            │ sequenced: false
                                            └─[MultilevelSwitchCCReport]
                                                current value: 90
        2021-10-15T17:34:19.032Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:19.034Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.036Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:19.047Z SERIAL » 0x011100131e0a9880962809473548dad0053546                            (19 bytes)
        2021-10-15T17:34:19.048Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      53
                                              nonce: 0x962809473548dad0
        2021-10-15T17:34:19.051Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:19.056Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:19.057Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.058Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:19.173Z SERIAL « 0x010700133500000cd2                                                 (9 bytes)
        2021-10-15T17:34:19.174Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.176Z DRIVER « [REQ] [SendData]
                                            callback id:     53
                                            transmit status: OK
        2021-10-15T17:34:19.276Z SERIAL « 0x01290004001e239881e2aedc867cac0e147f47f51e60df06c76ef4a739b1e1d19 (43 bytes)
                                          e9611a88dedb21b3e9fdb
        2021-10-15T17:34:19.278Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.280Z CNTRLR   [Node 030] [~] [Meter] value[66049]: 112.9 => 114.2               [Endpoint 0]
        2021-10-15T17:34:19.284Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                            └─[MeterCCReport]
                                                type:       Electric
                                                scale:      W
                                                rate type:  Consumed
                                                value:      114.2
                                                time delta: 0 seconds
        2021-10-15T17:34:19.338Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:19.339Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.340Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:19.349Z SERIAL » 0x011100131e0a98803c9139a6d7d6bdf50536b9                            (19 bytes)
        2021-10-15T17:34:19.350Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      54
                                              nonce: 0x3c9139a6d7d6bdf5
        2021-10-15T17:34:19.352Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:19.359Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:19.359Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.360Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:19.490Z SERIAL « 0x010700133600000ed3                                                 (9 bytes)
        2021-10-15T17:34:19.491Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.493Z DRIVER « [REQ] [SendData]
                                            callback id:     54
                                            transmit status: OK
        2021-10-15T17:34:19.581Z SERIAL « 0x011f0004001e1998813e99657ac5db09be2c6b00b36f633cf58bd309f556a29c1 (33 bytes)
        2021-10-15T17:34:19.584Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:19.586Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 90 => 78         [Endpoint 0]
        2021-10-15T17:34:19.588Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 78
        2021-10-15T17:34:20.009Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:20.011Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.013Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:20.030Z SERIAL » 0x011100131e0a9880267aad68da242b400537cf                            (19 bytes)
        2021-10-15T17:34:20.030Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      55
                                              nonce: 0x267aad68da242b40
        2021-10-15T17:34:20.033Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:20.039Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:20.040Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.041Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:20.153Z SERIAL « 0x010700133700000cd0                                                 (9 bytes)
        2021-10-15T17:34:20.153Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.155Z DRIVER « [REQ] [SendData]
                                            callback id:     55
                                            transmit status: OK
        2021-10-15T17:34:20.241Z SERIAL « 0x011f0004001e19988141c7dad03ac585bd4fb803a71fcc26804aa28c9fa1a8aac (33 bytes)
                                          f
        2021-10-15T17:34:20.243Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.246Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 78 => 70         [Endpoint 0]
        2021-10-15T17:34:20.248Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 70
        2021-10-15T17:34:20.956Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:20.958Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.960Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:20.981Z SERIAL » 0x011100131e0a9880f16fb0a0bd52fa7a05382d                            (19 bytes)
        2021-10-15T17:34:20.981Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      56
                                              nonce: 0xf16fb0a0bd52fa7a
        2021-10-15T17:34:20.984Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:20.990Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:20.991Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:20.992Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:21.102Z SERIAL « 0x010700133800000cdf                                                 (9 bytes)
        2021-10-15T17:34:21.103Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:21.103Z DRIVER « [REQ] [SendData]
                                            callback id:     56
                                            transmit status: OK
        2021-10-15T17:34:21.191Z SERIAL « 0x011f0004001e199881e93540f62a7c4fcc0fb03a0d5601f1d91debe62474d3a88 (33 bytes)
        2021-10-15T17:34:21.193Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:21.196Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 70 => 60         [Endpoint 0]
        2021-10-15T17:34:21.198Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 60
        2021-10-15T17:34:21.988Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:21.990Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:21.991Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:22.003Z SERIAL » 0x011100131e0a988028532a62665f8638053979                            (19 bytes)
        2021-10-15T17:34:22.004Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      57
                                              nonce: 0x28532a62665f8638
        2021-10-15T17:34:22.006Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:22.012Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:22.013Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:22.014Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:22.133Z SERIAL « 0x010700133900000ddf                                                 (9 bytes)
        2021-10-15T17:34:22.134Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:22.135Z DRIVER « [REQ] [SendData]
                                            callback id:     57
                                            transmit status: OK
        2021-10-15T17:34:22.220Z SERIAL « 0x011f0004001e1998813e569c252c60d71109e6884a9f2f285e222659e05b0f9b3 (33 bytes)
        2021-10-15T17:34:22.222Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:22.225Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 60 => 50         [Endpoint 0]
        2021-10-15T17:34:22.229Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 50
        2021-10-15T17:34:23.127Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:23.128Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:23.130Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:23.152Z SERIAL » 0x011100131e0a9880a91b397f06067d5a053a1d                            (19 bytes)
        2021-10-15T17:34:23.153Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      58
                                              nonce: 0xa91b397f06067d5a
        2021-10-15T17:34:23.155Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:23.161Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:23.162Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:23.163Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:23.274Z SERIAL « 0x010700133a00000cdd                                                 (9 bytes)
        2021-10-15T17:34:23.275Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:23.276Z DRIVER « [REQ] [SendData]
                                            callback id:     58
                                            transmit status: OK
        2021-10-15T17:34:23.360Z SERIAL « 0x011f0004001e1998819854b7d485599dea26ee977c4e66a9ecca11c3a6ca0ffa3 (33 bytes)
        2021-10-15T17:34:23.362Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:23.365Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 50 => 40         [Endpoint 0]
        2021-10-15T17:34:23.367Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 40
        2021-10-15T17:34:24.418Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:24.419Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:24.420Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:24.432Z SERIAL » 0x011100131e0a988057f6bccbb456e9b0053ba2                            (19 bytes)
        2021-10-15T17:34:24.433Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      59
                                              nonce: 0x57f6bccbb456e9b0
        2021-10-15T17:34:24.435Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:24.441Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:24.441Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:24.442Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:24.562Z SERIAL « 0x010700133b00000ddd                                                 (9 bytes)
        2021-10-15T17:34:24.563Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:24.564Z DRIVER « [REQ] [SendData]
                                            callback id:     59
                                            transmit status: OK
        2021-10-15T17:34:24.652Z SERIAL « 0x011f0004001e199881821700ec7c2b62d51dd87b4b0d2157c95f340e82f430cec (33 bytes)
        2021-10-15T17:34:24.653Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:24.654Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 40 => 30         [Endpoint 0]
        2021-10-15T17:34:24.656Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 30
        2021-10-15T17:34:25.955Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:25.956Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:25.957Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:25.969Z SERIAL » 0x011100131e0a98807b312dbbf9efaad0053c78                            (19 bytes)
        2021-10-15T17:34:25.969Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      60
                                              nonce: 0x7b312dbbf9efaad0
        2021-10-15T17:34:25.972Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:25.981Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:25.982Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:25.983Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:26.103Z SERIAL « 0x010700133c00000dda                                                 (9 bytes)
        2021-10-15T17:34:26.104Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:26.105Z DRIVER « [REQ] [SendData]
                                            callback id:     60
                                            transmit status: OK
        2021-10-15T17:34:26.192Z SERIAL « 0x011f0004001e1998813b0433930a0be07f49f0799a60857b5bfc9f3a09f28abef (33 bytes)
        2021-10-15T17:34:26.194Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:26.196Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 30 => 20         [Endpoint 0]
        2021-10-15T17:34:26.198Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 20
        2021-10-15T17:34:27.960Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:27.963Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:27.965Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:27.976Z SERIAL » 0x011100131e0a98803ab4afd903c5e389053d9d                            (19 bytes)
        2021-10-15T17:34:27.977Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      61
                                              nonce: 0x3ab4afd903c5e389
        2021-10-15T17:34:27.980Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:27.985Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:27.986Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:27.987Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:28.102Z SERIAL « 0x010700133d00000cda                                                 (9 bytes)
        2021-10-15T17:34:28.103Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:28.104Z DRIVER « [REQ] [SendData]
                                            callback id:     61
                                            transmit status: OK
        2021-10-15T17:34:28.190Z SERIAL « 0x011f0004001e1998815e7ced9f8c987ac19157731586553afa087957b36689c70 (33 bytes)
                                          b
        2021-10-15T17:34:28.192Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:28.195Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 20 => 10         [Endpoint 0]
        2021-10-15T17:34:28.197Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 10
        2021-10-15T17:34:29.394Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:29.396Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:29.397Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:29.409Z SERIAL » 0x011100131d0a988087d6b9318183daf3053e3b                            (19 bytes)
        2021-10-15T17:34:29.410Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      62
                                              nonce: 0x87d6b9318183daf3
        2021-10-15T17:34:29.412Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:29.418Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:29.418Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:29.419Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:29.579Z SERIAL « 0x010700133e000011c4                                                 (9 bytes)
        2021-10-15T17:34:29.580Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:29.581Z DRIVER « [REQ] [SendData]
                                            callback id:     62
                                            transmit status: OK
        2021-10-15T17:34:29.669Z SERIAL « 0x011f0004001d199881d8c9331c35f6f5169a94416820c987abac2ecdde693b68a (33 bytes)
                                          e
        2021-10-15T17:34:29.671Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:29.673Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 99 => 90         [Endpoint 0]
        2021-10-15T17:34:29.675Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 90
        2021-10-15T17:34:30.235Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:30.237Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:30.238Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:30.250Z SERIAL » 0x011100131d0a9880a5a5a86c1259c2fe053f7b                            (19 bytes)
        2021-10-15T17:34:30.251Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      63
                                              nonce: 0xa5a5a86c1259c2fe
        2021-10-15T17:34:30.254Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:30.259Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:30.260Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:30.261Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:30.421Z SERIAL « 0x010700133f000011c5                                                 (9 bytes)
        2021-10-15T17:34:30.423Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:30.425Z DRIVER « [REQ] [SendData]
                                            callback id:     63
                                            transmit status: OK
        2021-10-15T17:34:30.512Z SERIAL « 0x011f0004001d199881b7148bdfc6faa78f2978e514ee5da5ea155fc3863e9a0fe (33 bytes)
        2021-10-15T17:34:30.513Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:30.516Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 90 => 80         [Endpoint 0]
        2021-10-15T17:34:30.518Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 80
        2021-10-15T17:34:31.135Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:31.137Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:31.138Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:31.150Z SERIAL » 0x011100131d0a9880dbc3892f683a4148054052                            (19 bytes)
        2021-10-15T17:34:31.151Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      64
                                              nonce: 0xdbc3892f683a4148
        2021-10-15T17:34:31.154Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:31.159Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:31.160Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:31.161Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:31.321Z SERIAL « 0x0107001340000011ba                                                 (9 bytes)
        2021-10-15T17:34:31.322Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:31.324Z DRIVER « [REQ] [SendData]
                                            callback id:     64
                                            transmit status: OK
        2021-10-15T17:34:31.411Z SERIAL « 0x011f0004001d199881748931173986b6575c248ccc7245db8b072dddb210bd498 (33 bytes)
        2021-10-15T17:34:31.413Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:31.415Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 80 => 70         [Endpoint 0]
        2021-10-15T17:34:31.419Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 70
        2021-10-15T17:34:32.095Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:32.096Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.098Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:32.108Z SERIAL » 0x011100131d0a98801c1179c0cea210a20541dc                            (19 bytes)
        2021-10-15T17:34:32.109Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      65
                                              nonce: 0x1c1179c0cea210a2
        2021-10-15T17:34:32.112Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:32.120Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:32.121Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.122Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:32.279Z SERIAL « 0x0107001341000011bb                                                 (9 bytes)
        2021-10-15T17:34:32.281Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.283Z DRIVER « [REQ] [SendData]
                                            callback id:     65
                                            transmit status: OK
        2021-10-15T17:34:32.370Z SERIAL « 0x011f0004001d1998811013ceeb4d7ef85ca005b22242f91c4ab2a159dd807b5da (33 bytes)
        2021-10-15T17:34:32.372Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.374Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 70 => 60         [Endpoint 0]
        2021-10-15T17:34:32.375Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 60
        2021-10-15T17:34:32.767Z SERIAL « 0x01080004001e02984037                                              (10 bytes)
        2021-10-15T17:34:32.768Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.770Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
        2021-10-15T17:34:32.782Z SERIAL » 0x011100131e0a9880f0b6aa062f3f36ce0542b4                            (19 bytes)
        2021-10-15T17:34:32.783Z DRIVER » [Node 030] [REQ] [SendData]
                                          │ callback id:      66
                                              nonce: 0xf0b6aa062f3f36ce
        2021-10-15T17:34:32.785Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:32.791Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:32.792Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.793Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:32.912Z SERIAL « 0x010700134200000da4                                                 (9 bytes)
        2021-10-15T17:34:32.913Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:32.914Z DRIVER « [REQ] [SendData]
                                            callback id:     66
                                            transmit status: OK
        2021-10-15T17:34:33.001Z SERIAL « 0x011f0004001e199881a7e0c436e88d722fe694a7efd6acf06dcb43c43638f3061 (33 bytes)
                                          d
        2021-10-15T17:34:33.003Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:33.006Z CNTRLR   [Node 030] [~] [Multilevel Switch] currentValue: 10 => 0          [Endpoint 0]
        2021-10-15T17:34:33.009Z DRIVER « [Node 030] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 0
        2021-10-15T17:34:33.148Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:33.149Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:33.150Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:33.160Z SERIAL » 0x011100131d0a9880ebf724cfbadb399a054381                            (19 bytes)
        2021-10-15T17:34:33.160Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      67
                                              nonce: 0xebf724cfbadb399a
        2021-10-15T17:34:33.173Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:33.175Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:33.176Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:33.178Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:33.341Z SERIAL « 0x0107001343000012ba                                                 (9 bytes)
        2021-10-15T17:34:33.342Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:33.344Z DRIVER « [REQ] [SendData]
                                            callback id:     67
                                            transmit status: OK
        2021-10-15T17:34:33.430Z SERIAL « 0x011f0004001d199881e89d77f601273a9b4118a9b31259eb97f06f29e146ccfcd (33 bytes)
                                          f
        2021-10-15T17:34:33.433Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:33.435Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 60 => 50         [Endpoint 0]
        2021-10-15T17:34:33.438Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 50
        2021-10-15T17:34:34.308Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:34.310Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:34.311Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:34.324Z SERIAL » 0x011100131d0a98807d970f37367c633605447e                            (19 bytes)
        2021-10-15T17:34:34.325Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      68
                                              nonce: 0x7d970f37367c6336
        2021-10-15T17:34:34.327Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:34.332Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:34.333Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:34.334Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:34.490Z SERIAL « 0x0107001344000010bf                                                 (9 bytes)
        2021-10-15T17:34:34.491Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:34.493Z DRIVER « [REQ] [SendData]
                                            callback id:     68
                                            transmit status: OK
        2021-10-15T17:34:34.579Z SERIAL « 0x011f0004001d19988122c962f81126dc33ed0c2e9ea7847d316b030c1dee42a61 (33 bytes)
                                          d
        2021-10-15T17:34:34.580Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:34.582Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 50 => 40         [Endpoint 0]
        2021-10-15T17:34:34.585Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 40
        2021-10-15T17:34:35.617Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:35.618Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:35.620Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:35.632Z SERIAL » 0x011100131d0a9880bb1f3f02aa38a1b10545a9                            (19 bytes)
        2021-10-15T17:34:35.632Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      69
                                              nonce: 0xbb1f3f02aa38a1b1
        2021-10-15T17:34:35.637Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:35.641Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:35.641Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:35.642Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:35.801Z SERIAL « 0x0107001345000011bf                                                 (9 bytes)
        2021-10-15T17:34:35.801Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:35.802Z DRIVER « [REQ] [SendData]
                                            callback id:     69
                                            transmit status: OK
        2021-10-15T17:34:35.891Z SERIAL « 0x011f0004001d199881863b1dfcc2462341cf193f944533bb23a4620c6b8556e84 (33 bytes)
                                          a
        2021-10-15T17:34:35.893Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:35.895Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 40 => 30         [Endpoint 0]
        2021-10-15T17:34:35.897Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 30
        2021-10-15T17:34:37.174Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:37.175Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:37.177Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:37.188Z SERIAL » 0x011100131d0a9880cec00f7b650d733f0546ef                            (19 bytes)
        2021-10-15T17:34:37.188Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      70
                                              nonce: 0xcec00f7b650d733f
        2021-10-15T17:34:37.191Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:37.197Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:37.198Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:37.199Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:37.360Z SERIAL « 0x0107001346000011bc                                                 (9 bytes)
        2021-10-15T17:34:37.361Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:37.362Z DRIVER « [REQ] [SendData]
                                            callback id:     70
                                            transmit status: OK
        2021-10-15T17:34:37.451Z SERIAL « 0x011f0004001d1998810af7e9ed96159cbf8ad6e6c2a344ce45a654bb9f1445d3e (33 bytes)
        2021-10-15T17:34:37.453Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:37.455Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 30 => 20         [Endpoint 0]
        2021-10-15T17:34:37.457Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 20
        2021-10-15T17:34:39.208Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:39.209Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.211Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:39.224Z SERIAL » 0x011100131d0a9880a9334b4a88dbb03f0547f7                            (19 bytes)
        2021-10-15T17:34:39.225Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      71
                                              nonce: 0xa9334b4a88dbb03f
        2021-10-15T17:34:39.227Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:39.233Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:39.233Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.234Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:39.389Z SERIAL « 0x0107001347000010bc                                                 (9 bytes)
        2021-10-15T17:34:39.390Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.392Z DRIVER « [REQ] [SendData]
                                            callback id:     71
                                            transmit status: OK
        2021-10-15T17:34:39.480Z SERIAL « 0x011f0004001d1998811b8175c268bec51f03d7824e4e2da99104a83e6e5f37212 (33 bytes)
                                          e
        2021-10-15T17:34:39.481Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.483Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 20 => 10         [Endpoint 0]
        2021-10-15T17:34:39.485Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 10
        2021-10-15T17:34:39.591Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:39.592Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.594Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:39.607Z SERIAL » 0x011100131d0a98805597cf235f3c9b7d054814                            (19 bytes)
        2021-10-15T17:34:39.607Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      72
                                              nonce: 0x5597cf235f3c9b7d
        2021-10-15T17:34:39.609Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:39.615Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:39.616Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.616Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:39.781Z SERIAL « 0x0107001348000011b2                                                 (9 bytes)
        2021-10-15T17:34:39.782Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.783Z DRIVER « [REQ] [SendData]
                                            callback id:     72
                                            transmit status: OK
        2021-10-15T17:34:39.876Z SERIAL « 0x01290004001d23988124c528ee2a40bb462d33c3db2e8285e21e4c581c93051d7 (43 bytes)
                                          f55c82edc9875e5c64388
        2021-10-15T17:34:39.877Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:39.880Z CNTRLR   [Node 029] [~] [Meter] value[66049]: 114.6 => 115.4               [Endpoint 0]
        2021-10-15T17:34:39.882Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                            └─[MeterCCReport]
                                                type:       Electric
                                                scale:      W
                                                rate type:  Consumed
                                                value:      115.4
        2021-10-15T17:34:44.072Z SERIAL « 0x01080004001d02984034                                              (10 bytes)
        2021-10-15T17:34:44.075Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:44.077Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
        2021-10-15T17:34:44.087Z SERIAL » 0x011100131d0a988029f40133e0de1e62054913                            (19 bytes)
        2021-10-15T17:34:44.087Z DRIVER » [Node 029] [REQ] [SendData]
                                          │ callback id:      73
                                              nonce: 0x29f40133e0de1e62
        2021-10-15T17:34:44.090Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:34:44.097Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:34:44.097Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:44.098Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:34:44.478Z SERIAL « 0x010700134900002785                                                 (9 bytes)
        2021-10-15T17:34:44.480Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:44.481Z DRIVER « [REQ] [SendData]
                                            callback id:     73
                                            transmit status: OK
        2021-10-15T17:34:44.748Z SERIAL « 0x011f0004001d1998811ca60eb59f5841b86df9d8cb5d0329ef5f3050196676cb2 (33 bytes)
        2021-10-15T17:34:44.750Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:34:44.753Z CNTRLR   [Node 029] [~] [Multilevel Switch] currentValue: 10 => 0          [Endpoint 0]
        2021-10-15T17:34:44.755Z DRIVER « [Node 029] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                                current value: 0
        2021-10-15T17:37:00.510Z SERIAL « 0x01080004002002984009                                              (10 bytes)
        2021-10-15T17:37:00.511Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:37:00.513Z DRIVER « [Node 032] [REQ] [ApplicationCommand]
        2021-10-15T17:37:00.523Z SERIAL » 0x01110013200a9880b93a7a63e439cc0f054a04                            (19 bytes)
        2021-10-15T17:37:00.524Z DRIVER » [Node 032] [REQ] [SendData]
                                          │ callback id:      74
                                              nonce: 0xb93a7a63e439cc0f
        2021-10-15T17:37:00.526Z SERIAL « [ACK]        (0x06)
        2021-10-15T17:37:00.532Z SERIAL « 0x0104011301e8                                                       (6 bytes)
        2021-10-15T17:37:00.533Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:37:00.533Z DRIVER « [RES] [SendData]
                                            was sent: true
        2021-10-15T17:37:00.549Z SERIAL « 0x010700134a000002a3                                                 (9 bytes)
        2021-10-15T17:37:00.550Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:37:00.550Z DRIVER « [REQ] [SendData]
                                            callback id:     74
                                            transmit status: OK
        2021-10-15T17:37:00.575Z SERIAL « 0x0129000400202398810b8a550de6e7741ed7736a929c5ca394621052e9857d5e7 (43 bytes)
                                          eb9ccffcde193bd23117a
        2021-10-15T17:37:00.577Z SERIAL » [ACK]        (0x06)
        2021-10-15T17:37:00.579Z CNTRLR   [Node 032] [~] [Meter] value[65537]: 0.19 => 0.19                 [Endpoint 0]
        2021-10-15T17:37:00.582Z DRIVER « [Node 032] [REQ] [ApplicationCommand]
                                            │ sequenced: false
                                            └─[MeterCCReport]
                                                type:       Electric
                                                scale:      kWh
                                                rate type:  Consumed
                                                value:      0.19
        ich habe direct die rollo vor ort zu gemacht und dann man die Value lesen, value empfang geht aber senden eher nicht. ( hab wieder um 20:30 ein setpoint zu senden)
        zwave2.0
        	2021-10-15 20:30:23.046	debug	sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:23.039	debug	sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:23.027	debug	sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:23.020	debug	sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:23.013	debug	sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:23.000	debug	sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:22.993	debug	sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:22.986	debug	sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:22.973	debug	sendTo "getAssociations" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:22.966	debug	sendTo "getAssociationGroups" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:30:22.957	debug	sendTo "getEndpointIndizes" to system.adapter.admin.0 from system.adapter.zwave2.0
        zwave2.0
        	2021-10-15 20:26:56.323	debug	Node 34: value updated: value_electric_w_consumed => 1.2
        zwave2.0
        	2021-10-15 20:26:55.562	debug	Node 34: value updated: currentValue => 0
        zwave2.0
        	2021-10-15 20:26:50.932	debug	Node 34: value updated: currentValue => 10
        zwave2.0
        	2021-10-15 20:26:49.005	debug	Node 34: value updated: currentValue => 20
        zwave2.0
        	2021-10-15 20:26:47.515	debug	Node 34: value updated: currentValue => 30
        zwave2.0
        	2021-10-15 20:26:46.264	debug	Node 34: value updated: currentValue => 40
        zwave2.0
        	2021-10-15 20:26:45.164	debug	Node 34: value updated: currentValue => 50
        zwave2.0
        	2021-10-15 20:26:44.172	debug	Node 34: value updated: currentValue => 60
        zwave2.0
        	2021-10-15 20:26:43.253	debug	Node 34: value updated: currentValue => 70
        zwave2.0
        	2021-10-15 20:26:42.403	debug	Node 34: value updated: currentValue => 80
        zwave2.0
        	2021-10-15 20:26:41.602	debug	Node 34: value updated: currentValue => 90
        zwave2.0
        	2021-10-15 20:26:15.969	debug	Node 31: value updated: value_electric_kwh_consumed => 0.27
        • E Esmax666
                                            │ callback id:      52
                                              was sent: true
                                              callback id:     52
                                              transmit status: OK
                                            d
                                              │ sequenced: false
                                                  current value: 90
                                            │ callback id:      53
                                              was sent: true
                                              callback id:     53
                                              transmit status: OK
                                              │ sequenced: false
                                              └─[MeterCCReport]
                                                  type:       Electric
                                                  scale:      W
                                                  rate type:  Consumed
                                                  value:      114.2
                                            │ callback id:      54
                                              was sent: true
                                              callback id:     54
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 78
                                            │ callback id:      55
                                              was sent: true
                                              callback id:     55
                                              transmit status: OK
                                            f
                                              │ sequenced: false
                                                  current value: 70
                                            │ callback id:      56
                                              was sent: true
                                              callback id:     56
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 60
                                            │ callback id:      57
                                              was sent: true
                                              callback id:     57
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 50
                                            │ callback id:      58
                                              was sent: true
                                              callback id:     58
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 40
                                            │ callback id:      59
                                              was sent: true
                                              callback id:     59
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 30
                                            │ callback id:      60
                                              was sent: true
                                              callback id:     60
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 20
                                            │ callback id:      61
                                              was sent: true
                                              callback id:     61
                                              transmit status: OK
                                            b
                                              │ sequenced: false
                                                  current value: 10
                                            │ callback id:      62
                                              was sent: true
                                              callback id:     62
                                              transmit status: OK
                                            e
                                              │ sequenced: false
                                                  current value: 90
                                            │ callback id:      63
                                              was sent: true
                                              callback id:     63
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 80
                                            │ callback id:      64
                                              was sent: true
                                              callback id:     64
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 70
                                            │ callback id:      65
                                              was sent: true
                                              callback id:     65
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 60
                                            │ callback id:      66
                                              was sent: true
                                              callback id:     66
                                              transmit status: OK
                                            d
                                              │ sequenced: false
                                                  current value: 0
                                            │ callback id:      67
                                              was sent: true
                                              callback id:     67
                                              transmit status: OK
                                            f
                                              │ sequenced: false
                                                  current value: 50
                                            │ callback id:      68
                                              was sent: true
                                              callback id:     68
                                              transmit status: OK
                                            d
                                              │ sequenced: false
                                                  current value: 40
                                            │ callback id:      69
                                              was sent: true
                                              callback id:     69
                                              transmit status: OK
                                            a
                                              │ sequenced: false
                                                  current value: 30
                                            │ callback id:      70
                                              was sent: true
                                              callback id:     70
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 20
                                            │ callback id:      71
                                              was sent: true
                                              callback id:     71
                                              transmit status: OK
                                            e
                                              │ sequenced: false
                                                  current value: 10
                                            │ callback id:      72
                                              was sent: true
                                              callback id:     72
                                              transmit status: OK
                                              │ sequenced: false
                                              └─[MeterCCReport]
                                                  type:       Electric
                                                  scale:      W
                                                  rate type:  Consumed
                                                  value:      115.4
                                            │ callback id:      73
                                              was sent: true
                                              callback id:     73
                                              transmit status: OK
                                              │ sequenced: false
                                                  current value: 0
                                            │ callback id:      74
                                              was sent: true
                                              callback id:     74
                                              transmit status: OK
                                              │ sequenced: false
                                              └─[MeterCCReport]
                                                  type:       Electric
                                                  scale:      kWh
                                                  rate type:  Consumed
                                                  value:      0.19
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          zwave2.0
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          Hast du in diesem Ausschnitt versucht, das Gerät zu steuern? Ich seh es zumindest nicht. Das Log muss offen sein, während du das tusts - am besten in neuem Fenster öffnen.
          Warum sudo böse ist: https://forum.iobroker.net/post/17109
          E 1 Antwort Letzte Antwort
            Esmax666
            ok wuste ich nicht:
            1000 mal danke für dein hilfe :)
            also hier normal gemacht:
            ich habe 2 mal über "object probiert" und kein reaktion und dannach direkt vor Ort (mit rollo schalter) die rollo ein bisschen zu und wieder geöffnet
            2021-10-16T07:32:45.355Z SERIAL » 0x010e001322076c018a0326013c25736e                                  (16 bytes)
            2021-10-16T07:32:45.357Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ transmit options: 0x25
                                              │ callback id:      115
                                              └─[SupervisionCCGet]
                                                │ session id:      10
                                                │ request updates: true
                                                └─[MultilevelSwitchCCSet]
                                                    target value: 60
            2021-10-16T07:32:45.360Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:32:45.366Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:32:45.367Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:45.367Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:32:45.383Z SERIAL « 0x01070013730000029a                                                 (9 bytes)
            2021-10-16T07:32:45.383Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:45.384Z DRIVER « [REQ] [SendData]
                                                callback id:     115
                                                transmit status: OK
            2021-10-16T07:32:45.398Z SERIAL « 0x010b00040022056c020a0000b3                                        (13 bytes)
            2021-10-16T07:32:45.400Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:45.402Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                              └─[SupervisionCCReport]
                                                  session id:          10
                                                  more updates follow: false
                                                  status:              NoSupport
                                                  duration:            0s
            2021-10-16T07:32:59.444Z SERIAL » 0x010e001322076c018b03260146257412                                  (16 bytes)
            2021-10-16T07:32:59.445Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      116
                                                │ session id:      11
                                                    target value: 70
            2021-10-16T07:32:59.448Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:32:59.454Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:32:59.455Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:59.455Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:32:59.471Z SERIAL « 0x01070013740000029d                                                 (9 bytes)
            2021-10-16T07:32:59.471Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:59.472Z DRIVER « [REQ] [SendData]
                                                callback id:     116
                                                transmit status: OK
            2021-10-16T07:32:59.486Z SERIAL « 0x010b00040022056c020b0000b2                                        (13 bytes)
            2021-10-16T07:32:59.487Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:32:59.488Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                  session id:          11
                                                  status:              NoSupport
                                                  duration:            0s
            2021-10-16T07:33:44.455Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:33:44.458Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:44.460Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:33:44.471Z SERIAL » 0x01110013220a9880edbefa3f1e61dd6f0575e6                            (19 bytes)
            2021-10-16T07:33:44.471Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      117
                                                  nonce: 0xedbefa3f1e61dd6f
            2021-10-16T07:33:44.475Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:33:44.479Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:33:44.481Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:44.482Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:33:44.496Z SERIAL « 0x01070013750000029c                                                 (9 bytes)
            2021-10-16T07:33:44.497Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:44.497Z DRIVER « [REQ] [SendData]
                                                callback id:     117
                                                transmit status: OK
            2021-10-16T07:33:44.521Z SERIAL « 0x011f000400221998812a4a28233e10ef60b8b20f6b32efed5944e510f956035b4 (33 bytes)
                                              d
            2021-10-16T07:33:44.522Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:44.524Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 99 => 90         [Endpoint 0]
            2021-10-16T07:33:44.526Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 90
            2021-10-16T07:33:45.153Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:33:45.156Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:45.157Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:33:45.167Z SERIAL » 0x01110013220a9880ff37beadad3155600576cc                            (19 bytes)
            2021-10-16T07:33:45.167Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      118
                                                  nonce: 0xff37beadad315560
            2021-10-16T07:33:45.170Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:33:45.176Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:33:45.179Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:45.180Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:33:45.192Z SERIAL « 0x01070013760000029f                                                 (9 bytes)
            2021-10-16T07:33:45.192Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:45.193Z DRIVER « [REQ] [SendData]
                                                callback id:     118
                                                transmit status: OK
            2021-10-16T07:33:45.215Z SERIAL « 0x011f00040022199881105b19cb40b2dc5f3dc6402af20cffcd49fafb27d515a27 (33 bytes)
                                              e
            2021-10-16T07:33:45.217Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:45.219Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 90 => 82         [Endpoint 0]
            2021-10-16T07:33:45.221Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 82
            2021-10-16T07:33:47.473Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:33:47.476Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:47.478Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:33:47.487Z SERIAL » 0x01110013220a98805aeca0387e687bb305774f                            (19 bytes)
            2021-10-16T07:33:47.488Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      119
                                                  nonce: 0x5aeca0387e687bb3
            2021-10-16T07:33:47.492Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:33:47.496Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:33:47.497Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:47.498Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:33:47.514Z SERIAL « 0x01070013770000029e                                                 (9 bytes)
            2021-10-16T07:33:47.515Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:47.515Z DRIVER « [REQ] [SendData]
                                                callback id:     119
                                                transmit status: OK
            2021-10-16T07:33:47.538Z SERIAL « 0x011f00040022199881a2a4364a6c34c72de72602f405df5a807a242f1a7c8c1cb (33 bytes)
                                              e
            2021-10-16T07:33:47.539Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:47.541Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 82 => 90         [Endpoint 0]
            2021-10-16T07:33:47.543Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 90
            2021-10-16T07:33:48.390Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:33:48.393Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:48.395Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:33:48.409Z SERIAL » 0x01110013220a988070ecfb85043fe04a0578c3                            (19 bytes)
            2021-10-16T07:33:48.410Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      120
                                                  nonce: 0x70ecfb85043fe04a
            2021-10-16T07:33:48.413Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:33:48.419Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:33:48.420Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:48.421Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:33:48.435Z SERIAL « 0x010700137800000291                                                 (9 bytes)
            2021-10-16T07:33:48.436Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:48.436Z DRIVER « [REQ] [SendData]
                                                callback id:     120
                                                transmit status: OK
            2021-10-16T07:33:48.460Z SERIAL « 0x011f00040022199881903288c0101927ad382fb63cf3e57089f6c8aeff6b96a4e (33 bytes)
                                              b
            2021-10-16T07:33:48.461Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:33:48.463Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 90 => 99         [Endpoint 0]
            2021-10-16T07:33:48.465Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 99
            und hier normal ein getrennt versuch über Iobrocker
            2021-10-16T07:37:00.557Z SERIAL « 0x01080004002002984009                                              (10 bytes)
            2021-10-16T07:37:00.567Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:00.569Z DRIVER « [Node 032] [REQ] [ApplicationCommand]
            2021-10-16T07:37:00.576Z SERIAL » 0x01110013200a9880b16a905cfa5c415805791b                            (19 bytes)
            2021-10-16T07:37:00.576Z DRIVER » [Node 032] [REQ] [SendData]
                                              │ callback id:      121
                                                  nonce: 0xb16a905cfa5c4158
            2021-10-16T07:37:00.579Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:37:00.584Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:37:00.585Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:00.586Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:37:00.601Z SERIAL « 0x010700137900000290                                                 (9 bytes)
            2021-10-16T07:37:00.601Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:00.602Z DRIVER « [REQ] [SendData]
                                                callback id:     121
                                                transmit status: OK
            2021-10-16T07:37:00.627Z SERIAL « 0x012900040020239881d27b513994f033d3c17fb9f9758bd4dd5047a20b61cfc73 (43 bytes)
                                              0b1dddbf20acf953e6e26
            2021-10-16T07:37:00.629Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:00.631Z CNTRLR   [Node 032] [~] [Meter] value[65537]: 0.19 => 0.19                 [Endpoint 0]
            2021-10-16T07:37:00.634Z DRIVER « [Node 032] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                └─[MeterCCReport]
                                                    type:       Electric
                                                    scale:      kWh
                                                    rate type:  Consumed
                                                    value:      0.19
            2021-10-16T07:37:51.697Z SERIAL » 0x010e001322076c018c03260133257a6e                                  (16 bytes)
            2021-10-16T07:37:51.699Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      122
                                                │ session id:      12
                                                    target value: 51
            2021-10-16T07:37:51.701Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:37:51.708Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:37:51.708Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:51.709Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:37:51.724Z SERIAL « 0x010700137a00000293                                                 (9 bytes)
            2021-10-16T07:37:51.725Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:51.726Z DRIVER « [REQ] [SendData]
                                                callback id:     122
                                                transmit status: OK
            2021-10-16T07:37:51.740Z SERIAL « 0x010b00040022056c020c0000b5                                        (13 bytes)
            2021-10-16T07:37:51.741Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:37:51.742Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                  session id:          12
                                                  status:              NoSupport
                                                  duration:            0s
            2021-10-16T07:38:01.916Z SERIAL » 0x010e001322076c018d03260134257b69                                  (16 bytes)
            2021-10-16T07:38:01.918Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      123
                                                │ session id:      13
                                                    target value: 52
            2021-10-16T07:38:01.920Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:38:01.927Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:38:01.927Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:38:01.928Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:38:01.943Z SERIAL « 0x010700137b00000292                                                 (9 bytes)
            2021-10-16T07:38:01.944Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:38:01.945Z DRIVER « [REQ] [SendData]
                                                callback id:     123
                                                transmit status: OK
            2021-10-16T07:38:01.958Z SERIAL « 0x010b00040022056c020d0000b4                                        (13 bytes)
            2021-10-16T07:38:01.959Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:38:01.960Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                  session id:          13
                                                  status:              NoSupport
                                                  duration:            0s
            Edit:
            hier habe ich noch ein extra log erstellt wenn ich direkt vor Ort die rollo Öffnen und schlissen
            2021-10-16T07:41:39.642Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:39.646Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:39.648Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:39.657Z SERIAL » 0x01110013220a98804241ef013040e956057c96                            (19 bytes)
            2021-10-16T07:41:39.657Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      124
                                                  nonce: 0x4241ef013040e956
            2021-10-16T07:41:39.660Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:39.665Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:39.666Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:39.667Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:39.682Z SERIAL « 0x010700137c00000295                                                 (9 bytes)
            2021-10-16T07:41:39.683Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:39.688Z DRIVER « [REQ] [SendData]
                                                callback id:     124
                                                transmit status: OK
            2021-10-16T07:41:39.707Z SERIAL « 0x011f00040022199881a2735f88f099c0fef582cf90f30642ce3921650a6f61eb5 (33 bytes)
            2021-10-16T07:41:39.708Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:39.710Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 99 => 90         [Endpoint 0]
            2021-10-16T07:41:39.711Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 90
            2021-10-16T07:41:40.431Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:40.434Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:40.436Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:40.447Z SERIAL » 0x01110013220a98805133c0dc97932398057d74                            (19 bytes)
            2021-10-16T07:41:40.447Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      125
                                                  nonce: 0x5133c0dc97932398
            2021-10-16T07:41:40.450Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:40.455Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:40.456Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:40.457Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:40.472Z SERIAL « 0x010700137d00000294                                                 (9 bytes)
            2021-10-16T07:41:40.473Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:40.473Z DRIVER « [REQ] [SendData]
                                                callback id:     125
                                                transmit status: OK
            2021-10-16T07:41:40.498Z SERIAL « 0x011f000400221998810d246856288fa71aaf265bb0516a51bfaf9d1cef5c5a4ff (33 bytes)
            2021-10-16T07:41:40.499Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:40.501Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 90 => 80         [Endpoint 0]
            2021-10-16T07:41:40.503Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 80
            2021-10-16T07:41:41.282Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:41.284Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.286Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:41.295Z SERIAL » 0x01110013220a9880df84c65bb49fcc8b057e1c                            (19 bytes)
            2021-10-16T07:41:41.296Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      126
                                                  nonce: 0xdf84c65bb49fcc8b
            2021-10-16T07:41:41.298Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:41.305Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:41.306Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.307Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:41.320Z SERIAL « 0x010700137e00000297                                                 (9 bytes)
            2021-10-16T07:41:41.321Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.321Z DRIVER « [REQ] [SendData]
                                                callback id:     126
                                                transmit status: OK
            2021-10-16T07:41:41.349Z SERIAL « 0x011f000400221998815c623635e32bd276b1e5e86c54e6df6fc863e33d4ddc2d8 (33 bytes)
                                              c
            2021-10-16T07:41:41.350Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.352Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 80 => 70         [Endpoint 0]
            2021-10-16T07:41:41.354Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 70
            2021-10-16T07:41:41.543Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:41.545Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.547Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:41.555Z SERIAL » 0x01110013220a988079ac7f087347811e057fbe                            (19 bytes)
            2021-10-16T07:41:41.556Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      127
                                                  nonce: 0x79ac7f087347811e
            2021-10-16T07:41:41.558Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:41.564Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:41.564Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.566Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:41.580Z SERIAL « 0x010700137f00000296                                                 (9 bytes)
            2021-10-16T07:41:41.581Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.582Z DRIVER « [REQ] [SendData]
                                                callback id:     127
                                                transmit status: OK
            2021-10-16T07:41:41.604Z SERIAL « 0x011f00040022199881563a2a925ee36c39c5c8bfaf594679b2840757ac83ad3f5 (33 bytes)
                                              a
            2021-10-16T07:41:41.605Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:41.607Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 70 => 68         [Endpoint 0]
            2021-10-16T07:41:41.609Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 68
            2021-10-16T07:41:43.145Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:43.147Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:43.149Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:43.159Z SERIAL » 0x01110013220a9880066563607e0def30058084                            (19 bytes)
            2021-10-16T07:41:43.160Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      128
                                                  nonce: 0x066563607e0def30
            2021-10-16T07:41:43.163Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:43.168Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:43.168Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:43.169Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:43.184Z SERIAL « 0x010700138000000269                                                 (9 bytes)
            2021-10-16T07:41:43.185Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:43.185Z DRIVER « [REQ] [SendData]
                                                callback id:     128
                                                transmit status: OK
            2021-10-16T07:41:43.209Z SERIAL « 0x011f00040022199881f3715a8f9b1db836ff794f94bc000655f54572b8bcd6013 (33 bytes)
                                              a
            2021-10-16T07:41:43.211Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:43.213Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 68 => 70         [Endpoint 0]
            2021-10-16T07:41:43.215Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 70
            2021-10-16T07:41:44.031Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:44.033Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.035Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:44.045Z SERIAL » 0x01110013220a988098eba6e7b832c71905812f                            (19 bytes)
            2021-10-16T07:41:44.045Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      129
                                                  nonce: 0x98eba6e7b832c719
            2021-10-16T07:41:44.048Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:44.053Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:44.054Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.055Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:44.070Z SERIAL « 0x010700138100000268                                                 (9 bytes)
            2021-10-16T07:41:44.070Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.071Z DRIVER « [REQ] [SendData]
                                                callback id:     129
                                                transmit status: OK
            2021-10-16T07:41:44.094Z SERIAL « 0x011f00040022199881629f814d2e9b446ffbc1c8bf6cba98c9314a8f419b97756 (33 bytes)
                                              f
            2021-10-16T07:41:44.096Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.097Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 70 => 80         [Endpoint 0]
            2021-10-16T07:41:44.099Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 80
            2021-10-16T07:41:44.865Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:44.868Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.870Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:44.879Z SERIAL » 0x01110013220a988043d3ed0d49fd03360582bb                            (19 bytes)
            2021-10-16T07:41:44.880Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      130
                                                  nonce: 0x43d3ed0d49fd0336
            2021-10-16T07:41:44.885Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:44.888Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:44.889Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.889Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:44.904Z SERIAL « 0x01070013820000026b                                                 (9 bytes)
            2021-10-16T07:41:44.905Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.905Z DRIVER « [REQ] [SendData]
                                                callback id:     130
                                                transmit status: OK
            2021-10-16T07:41:44.929Z SERIAL « 0x011f000400221998815b7f46e1548130cca77e35daeb77435c29350c3c8ac6ee5 (33 bytes)
            2021-10-16T07:41:44.931Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:44.932Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 80 => 90         [Endpoint 0]
            2021-10-16T07:41:44.934Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 90
            2021-10-16T07:41:45.779Z SERIAL « 0x0108000400220298400b                                              (10 bytes)
            2021-10-16T07:41:45.781Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:45.783Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
            2021-10-16T07:41:45.796Z SERIAL » 0x01110013220a98808650417bd3bcfac90583fb                            (19 bytes)
            2021-10-16T07:41:45.797Z DRIVER » [Node 034] [REQ] [SendData]
                                              │ callback id:      131
                                                  nonce: 0x8650417bd3bcfac9
            2021-10-16T07:41:45.804Z SERIAL « [ACK]        (0x06)
            2021-10-16T07:41:45.806Z SERIAL « 0x0104011301e8                                                       (6 bytes)
            2021-10-16T07:41:45.807Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:45.808Z DRIVER « [RES] [SendData]
                                                was sent: true
            2021-10-16T07:41:45.821Z SERIAL « 0x01070013830000026a                                                 (9 bytes)
            2021-10-16T07:41:45.822Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:45.822Z DRIVER « [REQ] [SendData]
                                                callback id:     131
                                                transmit status: OK
            2021-10-16T07:41:45.852Z SERIAL « 0x011f0004002219988124ea00187ed003250c90798e8be086f1c9244268f6822e7 (33 bytes)
            2021-10-16T07:41:45.853Z SERIAL » [ACK]        (0x06)
            2021-10-16T07:41:45.855Z CNTRLR   [Node 034] [~] [Multilevel Switch] currentValue: 90 => 99         [Endpoint 0]
            2021-10-16T07:41:45.857Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
                                                │ sequenced: false
                                                    current value: 99
            ud hier noch iobroker.current.log
            021-10-16 09:32:20.658 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:32:45.355 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:32:46.355 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:32:59.444 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:32:59.608 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:44.456 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:44.474 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:44.504 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:44.525 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 90
            2021-10-16 09:33:44.549 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:45.153 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:45.173 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:45.213 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:45.220 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 82
            2021-10-16 09:33:45.263 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:47.474 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:47.490 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:47.523 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:47.541 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 90
            2021-10-16 09:33:47.568 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:48.390 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:48.414 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:48.453 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:33:48.464 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 99
            2021-10-16 09:33:48.492 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:36:44.980 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:37:00.558 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:37:00.559 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:37:00.632 - debug: zwave2.0 (25293) Node 32: value updated: value_electric_kwh_consumed => 0.19
            2021-10-16 09:37:01.580 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:37:51.698 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:37:52.695 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:38:01.916 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:38:02.924 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:40:26.327 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:40:26.330 - debug: zwave2.0 (25293) Node 4: metadata updated: airTemperature
            2021-10-16 09:40:26.332 - debug: zwave2.0 (25293) Node 4: value updated: airTemperature => 15.06
            2021-10-16 09:40:27.353 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:33.183 - debug: zwave2.0 (25293) sendTo "subscribeLogs" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.642 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.644 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.659 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.676 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.693 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:39.710 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 90
            2021-10-16 09:41:39.715 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:40.432 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:40.449 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:40.464 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:40.495 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:40.502 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 80
            2021-10-16 09:41:40.523 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.282 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.304 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.344 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.353 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 70
            2021-10-16 09:41:41.392 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.544 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.562 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.597 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:41.608 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 68
            2021-10-16 09:41:41.638 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:43.145 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:43.161 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:43.193 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:43.213 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 70
            2021-10-16 09:41:43.237 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.031 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.047 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.082 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.098 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 80
            2021-10-16 09:41:44.128 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.865 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.882 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:44.933 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 90
            2021-10-16 09:41:44.939 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:45.779 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:45.798 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:45.829 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            2021-10-16 09:41:45.856 - debug: zwave2.0 (25293) Node 34: value updated: currentValue => 99
            2021-10-16 09:41:45.877 - debug: zwave2.0 (25293) sendTo "registerPushCallback" to system.adapter.admin.0 from system.adapter.zwave2.0
            • E Esmax666
              @alcalzone said in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
              ok wuste ich nicht:
              Subscribed to logs...
                                                │ callback id:      115
                                                  │ session id:      10
                                                      target value: 60
                                                  was sent: true
                                                  callback id:     115
                                                  transmit status: OK
                                                    session id:          10
                                                    status:              NoSupport
                                                    duration:            0s
                                                │ callback id:      116
                                                  │ session id:      11
                                                      target value: 70
                                                  was sent: true
                                                  callback id:     116
                                                  transmit status: OK
                                                    session id:          11
                                                    status:              NoSupport
                                                    duration:            0s
                                                └─[SecurityCCNonceGet]
                                                │ transmit options: 0x05
                                                │ callback id:      117
                                                └─[SecurityCCNonceReport]
                                                  was sent: true
                                                  callback id:     117
                                                  transmit status: OK
                                                d
                                                └─[SecurityCCCommandEncapsulation]
                                                  │ sequenced: false
                                                  └─[MultilevelSwitchCCReport]
                                                      current value: 90
                                                │ callback id:      118
                                                  was sent: true
                                                  callback id:     118
                                                  transmit status: OK
                                                e
                                                  │ sequenced: false
                                                      current value: 82
                                                │ callback id:      119
                                                  was sent: true
                                                  callback id:     119
                                                  transmit status: OK
                                                e
                                                  │ sequenced: false
                                                      current value: 90
                                                │ callback id:      120
                                                  was sent: true
                                                  callback id:     120
                                                  transmit status: OK
                                                b
                                                  │ sequenced: false
                                                      current value: 99
                                                │ callback id:      121
                                                  was sent: true
                                                  callback id:     121
                                                  transmit status: OK
                                                  │ sequenced: false
                                                  └─[MeterCCReport]
                                                      type:       Electric
                                                      scale:      kWh
                                                      rate type:  Consumed
                                                      value:      0.19
                                                      time delta: 0 seconds
                                                │ callback id:      122
                                                  │ session id:      12
                                                      target value: 51
                                                  was sent: true
                                                  callback id:     122
                                                  transmit status: OK
                                                    session id:          12
                                                    status:              NoSupport
                                                    duration:            0s
                                                │ callback id:      123
                                                  │ session id:      13
                                                      target value: 52
                                                  was sent: true
                                                  callback id:     123
                                                  transmit status: OK
                                                    session id:          13
                                                    status:              NoSupport
                                                    duration:            0s
              Edit:
                                                │ callback id:      124
                                                  was sent: true
                                                  callback id:     124
                                                  transmit status: OK
                                                  │ sequenced: false
                                                      current value: 90
                                                │ callback id:      125
                                                  was sent: true
                                                  callback id:     125
                                                  transmit status: OK
                                                  │ sequenced: false
                                                      current value: 80
                                                │ callback id:      126
                                                  was sent: true
                                                  callback id:     126
                                                  transmit status: OK
                                                c
                                                  │ sequenced: false
                                                      current value: 70
                                                │ callback id:      127
                                                  was sent: true
                                                  callback id:     127
                                                  transmit status: OK
                                                a
                                                  │ sequenced: false
                                                      current value: 68
                                                │ callback id:      128
                                                  was sent: true
                                                  callback id:     128
                                                  transmit status: OK
                                                a
                                                  │ sequenced: false
                                                      current value: 70
                                                │ callback id:      129
                                                  was sent: true
                                                  callback id:     129
                                                  transmit status: OK
                                                f
                                                  │ sequenced: false
                                                      current value: 80
                                                │ callback id:      130
                                                  was sent: true
                                                  callback id:     130
                                                  transmit status: OK
                                                  │ sequenced: false
                                                      current value: 90
                                                │ callback id:      131
                                                  was sent: true
                                                  callback id:     131
                                                  transmit status: OK
                                                  │ sequenced: false
                                                      current value: 99
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @esmax666 sagte in Test Adapter Z-Wave2 v2.2.x - Eine neue Ära beginnt...:
              NoSupport
              Da liegt das Problem. Welches Gerät ist das genau? Bitte bei Node 34 auf den Bleistift zum Bearbeiten klicken und diese Infos kopieren:
              • AlCalzoneA AlCalzone
                NoSupport
                Esmax666
                "id": 34,
                "manufacturerId": 665,
                "productType": 5,
                "productId": 6803,
                "type": {
                  "basic": "Routing Slave",
                  "generic": "Multilevel Switch",
                  "specific": "Motor Control Class B"
                Technisat Roller-shutter
                https://www.technisat.com/en_XX/Roller-shutter-flush-mount,-BJ/352-22704-22938/
                Früher hat das schon funktionniert, aber angeblich habe ich ein update gemacht und dann geht es nicht mehr seltsam :(
                • E Esmax666
                  "id": 34,
                  "productType": 5,
                  "productId": 6803,
                  "type": {
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  Danke, Issue ist erstellt: https://github.com/zwave-js/node-zwave-js/issues/3536
                  Sollte in den nächsten Tagen gelöst sein.
                    Esmax666
                    Danke :) sehr cool
                    Hinweis: Die z wave version früher hat funktionniert mit Technisat ( Z wave module war circa 1 jahr nicht mehr geupdatet) vielleicht kannst du etwas dort etwas finden :)
                    • E Esmax666
                      Danke :) sehr cool
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @esmax666 Ich weiß schon was es ist
                        Esmax666
                        Can ich zurück auf ein alte version gehen ? Wie genau ? danke :)
                        • E Esmax666
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          @esmax666 Wenn du dich noch bis morgen gedulden kannst, gibts einen Patch, der dein Problem lösen sollte.
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            Version 2.2.4 ist auf dem Weg und sollte dein Problem beheben @Esmax666
                              Esmax666
                              super danke Momentan sehe ich noch 2.2.2
                              • E Esmax666
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                @esmax666 Dann installier mal manuell:
                                  Esmax666
                                  schrieb am zuletzt editiert von Esmax666
                                  @alcalzone
                                  Ok gemacht, leider geht es nicht
                                  2021-10-22T11:50:49.553Z SERIAL « 0x01070013050000a54b                                                 (9 bytes)
                                  2021-10-22T11:50:49.565Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:49.569Z DRIVER « [REQ] [SendData]
        callback id:     5
        transmit status: OK
                                  2021-10-22T11:50:49.583Z SERIAL » 0x010800131a01002506dc                                              (10 bytes)
                                  2021-10-22T11:50:49.584Z DRIVER » [Node 026] [REQ] [SendData]
        │ callback id:      6
        └─[NoOperationCC]
                                  2021-10-22T11:50:49.586Z CNTRLR   [Node 022] The node is alive.
                                  2021-10-22T11:50:49.587Z CNTRLR   [Node 022] The node is ready to be used
                                  2021-10-22T11:50:49.588Z CNTRLR « [Node 022] ping successful
                                  2021-10-22T11:50:49.593Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:49.599Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:49.600Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:49.601Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:53.726Z SERIAL « 0x010700130601019e73                                                 (9 bytes)
                                  2021-10-22T11:50:53.730Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.732Z DRIVER « [REQ] [SendData]
        callback id:     6
        transmit status: NoAck
                                  2021-10-22T11:50:53.742Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
                                  2021-10-22T11:50:53.743Z CNTRLR   [Node 026] The node is dead.
                                  2021-10-22T11:50:53.748Z SERIAL » 0x010800131d01002507da                                              (10 bytes)
                                  2021-10-22T11:50:53.749Z DRIVER » [Node 029] [REQ] [SendData]
        │ callback id:      7
        └─[NoOperationCC]
                                  2021-10-22T11:50:53.750Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
        Ack) (ZW0020)
                                  2021-10-22T11:50:53.751Z CNTRLR » [Node 026] querying node info...
                                  2021-10-22T11:50:53.751Z CNTRLR » [Node 026] pinging the node...
                                  2021-10-22T11:50:53.757Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:53.760Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:53.761Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.763Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:53.819Z SERIAL « 0x0107001307000006ea                                                 (9 bytes)
                                  2021-10-22T11:50:53.821Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.822Z DRIVER « [REQ] [SendData]
        callback id:     7
        transmit status: OK
                                  2021-10-22T11:50:53.834Z SERIAL » 0x010800131e01002508d6                                              (10 bytes)
                                  2021-10-22T11:50:53.834Z DRIVER » [Node 030] [REQ] [SendData]
        │ callback id:      8
        └─[NoOperationCC]
                                  2021-10-22T11:50:53.837Z CNTRLR   [Node 029] The node is alive.
                                  2021-10-22T11:50:53.838Z CNTRLR   [Node 029] The node is ready to be used
                                  2021-10-22T11:50:53.839Z CNTRLR « [Node 029] ping successful
                                  2021-10-22T11:50:53.845Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:53.848Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:53.849Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.850Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:53.909Z SERIAL « 0x0107001308000006e5                                                 (9 bytes)
                                  2021-10-22T11:50:53.910Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.910Z DRIVER « [REQ] [SendData]
        callback id:     8
        transmit status: OK
                                  2021-10-22T11:50:53.925Z SERIAL » 0x010800131f01002509d6                                              (10 bytes)
                                  2021-10-22T11:50:53.926Z DRIVER » [Node 031] [REQ] [SendData]
        │ callback id:      9
        └─[NoOperationCC]
                                  2021-10-22T11:50:53.927Z CNTRLR   [Node 030] The node is alive.
                                  2021-10-22T11:50:53.928Z CNTRLR   [Node 030] The node is ready to be used
                                  2021-10-22T11:50:53.929Z CNTRLR « [Node 030] ping successful
                                  2021-10-22T11:50:53.932Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:53.949Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:53.950Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.954Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:53.961Z SERIAL « 0x0107001309000002e0                                                 (9 bytes)
                                  2021-10-22T11:50:53.963Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.964Z DRIVER « [REQ] [SendData]
        callback id:     9
        transmit status: OK
                                  2021-10-22T11:50:53.972Z SERIAL » 0x01080013200100250aea                                              (10 bytes)
                                  2021-10-22T11:50:53.972Z DRIVER » [Node 032] [REQ] [SendData]
        │ callback id:      10
        └─[NoOperationCC]
                                  2021-10-22T11:50:53.973Z CNTRLR   [Node 031] The node is alive.
                                  2021-10-22T11:50:53.974Z CNTRLR   [Node 031] The node is ready to be used
                                  2021-10-22T11:50:53.975Z CNTRLR « [Node 031] ping successful
                                  2021-10-22T11:50:53.979Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:53.985Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:53.986Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:53.989Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:54.002Z SERIAL « 0x010700130a000002e3                                                 (9 bytes)
                                  2021-10-22T11:50:54.003Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.005Z DRIVER « [REQ] [SendData]
        callback id:     10
        transmit status: OK
                                  2021-10-22T11:50:54.015Z SERIAL » 0x01080013210100250bea                                              (10 bytes)
                                  2021-10-22T11:50:54.016Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      11
        └─[NoOperationCC]
                                  2021-10-22T11:50:54.017Z CNTRLR   [Node 032] The node is alive.
                                  2021-10-22T11:50:54.018Z CNTRLR   [Node 032] The node is ready to be used
                                  2021-10-22T11:50:54.019Z CNTRLR « [Node 032] ping successful
                                  2021-10-22T11:50:54.029Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:54.034Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:54.035Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.037Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:54.046Z SERIAL « 0x010700130b000002e2                                                 (9 bytes)
                                  2021-10-22T11:50:54.046Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.048Z DRIVER « [REQ] [SendData]
        callback id:     11
        transmit status: OK
                                  2021-10-22T11:50:54.059Z SERIAL » 0x01080013220100250cee                                              (10 bytes)
                                  2021-10-22T11:50:54.060Z DRIVER » [Node 034] [REQ] [SendData]
        │ callback id:      12
        └─[NoOperationCC]
                                  2021-10-22T11:50:54.061Z CNTRLR   [Node 033] The node is alive.
                                  2021-10-22T11:50:54.062Z CNTRLR   [Node 033] The node is ready to be used
                                  2021-10-22T11:50:54.063Z CNTRLR « [Node 033] ping successful
                                  2021-10-22T11:50:54.074Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:54.076Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:54.077Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.081Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:54.116Z SERIAL « 0x010700130c000005e2                                                 (9 bytes)
                                  2021-10-22T11:50:54.117Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.118Z DRIVER « [REQ] [SendData]
        callback id:     12
        transmit status: OK
                                  2021-10-22T11:50:54.125Z SERIAL » 0x01080013230100250dee                                              (10 bytes)
                                  2021-10-22T11:50:54.125Z DRIVER » [Node 035] [REQ] [SendData]
        │ callback id:      13
        └─[NoOperationCC]
                                  2021-10-22T11:50:54.127Z CNTRLR   [Node 034] The node is alive.
                                  2021-10-22T11:50:54.127Z CNTRLR   [Node 034] The node is ready to be used
                                  2021-10-22T11:50:54.128Z CNTRLR « [Node 034] ping successful
                                  2021-10-22T11:50:54.140Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:54.143Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:54.144Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.146Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:54.182Z SERIAL « 0x010700130d000004e2                                                 (9 bytes)
                                  2021-10-22T11:50:54.183Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.187Z DRIVER « [REQ] [SendData]
        callback id:     13
        transmit status: OK
                                  2021-10-22T11:50:54.194Z SERIAL » 0x010800131a0100250ed4                                              (10 bytes)
                                  2021-10-22T11:50:54.194Z DRIVER » [Node 026] [REQ] [SendData]
        │ callback id:      14
        └─[NoOperationCC]
                                  2021-10-22T11:50:54.197Z CNTRLR   [Node 035] The node is alive.
                                  2021-10-22T11:50:54.198Z CNTRLR   [Node 035] The node is ready to be used
                                  2021-10-22T11:50:54.199Z CNTRLR « [Node 035] ping successful
                                  2021-10-22T11:50:54.209Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:50:54.215Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:50:54.215Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:54.217Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:50:58.338Z SERIAL « 0x010700130e01019d78                                                 (9 bytes)
                                  2021-10-22T11:50:58.341Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:50:58.344Z DRIVER « [REQ] [SendData]
        callback id:     14
                                  2021-10-22T11:50:58.362Z CNTRLR   [Node 026] Node 26 did not respond after 1 attempts, it is presumed dead
                                  2021-10-22T11:50:58.365Z CNTRLR   [Node 026] ping failed: Failed to send the command after 1 attempts (Status No
        Ack) (ZW0020)
                                  2021-10-22T11:50:58.366Z CNTRLR   [Node 026] Interview attempt (1/5) failed, node is dead.
                                  2021-10-22T11:51:11.340Z SERIAL » 0x010e001322076c018103260132250f17                                  (16 bytes)
                                  2021-10-22T11:51:11.342Z DRIVER » [Node 034] [REQ] [SendData]
        │ callback id:      15
        │ session id:      1
        target value: 50
                                  2021-10-22T11:51:11.345Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:51:11.351Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:51:11.352Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:11.353Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:51:11.398Z SERIAL « 0x010700130f000005e1                                                 (9 bytes)
                                  2021-10-22T11:51:11.399Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:11.399Z DRIVER « [REQ] [SendData]
        callback id:     15
        transmit status: OK
                                  2021-10-22T11:51:11.472Z SERIAL « 0x010b00040022056c02010000b8                                        (13 bytes)
                                  2021-10-22T11:51:11.478Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:11.483Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
        session id:          1
        status:              NoSupport
        duration:            0s
                                  2021-10-22T11:51:17.565Z SERIAL » 0x010e001322076c01820326013725100e                                  (16 bytes)
                                  2021-10-22T11:51:17.567Z DRIVER » [Node 034] [REQ] [SendData]
        │ callback id:      16
        │ session id:      2
        target value: 55
                                  2021-10-22T11:51:17.572Z SERIAL « [ACK]        (0x06)
                                  2021-10-22T11:51:17.576Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                                  2021-10-22T11:51:17.577Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:17.578Z DRIVER « [RES] [SendData]
        was sent: true
                                  2021-10-22T11:51:17.621Z SERIAL « 0x0107001310000004ff                                                 (9 bytes)
                                  2021-10-22T11:51:17.622Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:17.623Z DRIVER « [REQ] [SendData]
        callback id:     16
        transmit status: OK
                                  2021-10-22T11:51:17.692Z SERIAL « 0x010b00040022056c02020000bb                                        (13 bytes)
                                  2021-10-22T11:51:17.693Z SERIAL » [ACK]        (0x06)
                                  2021-10-22T11:51:17.695Z DRIVER « [Node 034] [REQ] [ApplicationCommand]
        session id:          2
        status:              NoSupport
        duration:            0s
                                  InstallLog
                                  $ iobroker url iobroker.zwave2@2.2.4 --host ubuntu
                                  install iobroker.zwave2@2.2.4
                                  NPM version: 6.14.15
                                  npm install iobroker.zwave2@2.2.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                  ../src/linux/BluetoothSerialPort.cc:18:6: error: variable or field ‘InitAll’ declared void
                                  18 | void InitAll(Handle<Object> exports) { | ^~~~~~~
                                  ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope 18 | void InitAll(Handle<Object> exports) { | ^~~~~~../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token 18 | void InitAll(Handle<Object> exports) { | ^
                                  ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
                                  In file included from ../src/linux/BluetoothSerialPort.cc:12:
                                  ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~/home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’ 736 | (node::addon_register_func) (regfunc), \ | ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ 23 | NODE_MODULE(BluetoothSerialPort, InitAll) | ^~~~~~~~~~~
                                  make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
                                  gyp ERR! build error
                                  gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:314:20)
                                  gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
                                  gyp ERR! System Linux 5.11.0-1019-raspigyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.22.7gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                  upload [18] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/zwave2.svg zwave2.svg image/svg+xml
                                  upload [17] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/tab_m.html tab_m.html text/html
                                  upload [16] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/style.css style.css text/css
                                  upload [15] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/script/d3.min.js script/d3.min.js application/javascript
                                  upload [14] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/log_window.html log_window.html text/html
                                  upload [13] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/index_m.html index_m.html text/html
                                  upload [12] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js.map build/tab.js.map application/json
                                  upload [11] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/tab.js build/tab.js application/javascript
                                  upload [10] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js.map build/log.js.map application/json
                                  upload [9] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/log.js build/log.js application/javascript
                                  upload [8] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js.map build/index.js.map application/json
                                  upload [7] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/index.js build/index.js application/javascript
                                  upload [6] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-MTOBDWCR.js.map build/chunk-MTOBDWCR.js.map application/json
                                  upload [5] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-MTOBDWCR.js build/chunk-MTOBDWCR.js application/javascript
                                  upload [4] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-LGH3N725.js.map build/chunk-LGH3N725.js.map application/json
                                  upload [3] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-LGH3N725.js build/chunk-LGH3N725.js application/javascript
                                  upload [2] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-BZNVH3F4.js.map build/chunk-BZNVH3F4.js.map application/json
                                  upload [1] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/build/chunk-BZNVH3F4.js build/chunk-BZNVH3F4.js application/javascript
                                  upload [0] zwave2.admin /opt/iobroker/node_modules/iobroker.zwave2/admin/.eslintrc.js .eslintrc.js application/javascript
                                  Update "system.adapter.zwave2.0"
                                  • E Esmax666
                                    @alcalzone
        callback id:     5
        transmit status: OK
        │ callback id:      6
        └─[NoOperationCC]
        was sent: true
        callback id:     6
        │ callback id:      7
        └─[NoOperationCC]
        Ack) (ZW0020)
        was sent: true
        callback id:     7
        transmit status: OK
        │ callback id:      8
        └─[NoOperationCC]
        was sent: true
        callback id:     8
        transmit status: OK
        │ callback id:      9
        └─[NoOperationCC]
        was sent: true
        callback id:     9
        transmit status: OK
        │ callback id:      10
        └─[NoOperationCC]
        was sent: true
        callback id:     10
        transmit status: OK
        │ callback id:      11
        └─[NoOperationCC]
        was sent: true
        callback id:     11
        transmit status: OK
        │ callback id:      12
        └─[NoOperationCC]
        was sent: true
        callback id:     12
        transmit status: OK
        │ callback id:      13
        └─[NoOperationCC]
        was sent: true
        callback id:     13
        transmit status: OK
        │ callback id:      14
        └─[NoOperationCC]
        was sent: true
        callback id:     14
        Ack) (ZW0020)
        │ callback id:      15
        │ session id:      1
        target value: 50
        was sent: true
        callback id:     15
        transmit status: OK
        session id:          1
        status:              NoSupport
        duration:            0s
        │ callback id:      16
        │ session id:      2
        target value: 55
        was sent: true
        callback id:     16
        transmit status: OK
        session id:          2
        status:              NoSupport
        duration:            0s
                                    InstallLog
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    schrieb am zuletzt editiert von AlCalzone
                                    @esmax666 Bitte mal den Node neu interviewen:
                                    (ich seh grade, der Text neben dem Button ist falsch - bitte trotzdem draufklicken - halt bei Node 34)
                                      Esmax666
                                      @alcalzone
                                      YEs!!!!
                                      Rollo geht schon wieder :) nice !
                                      Das kann ich glaich mit alle rollo hier machen oder ?
                                      • E Esmax666
                                        @alcalzone
                                        YEs!!!!
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @esmax666 Ich würde es gezielt nur bei denen machen, die Probleme haben.
                                        • Christian WernerC Offline
                                          Christian Werner
                                          habe gerade das Update gemacht, danach aber vielleicht zu schnell auf "Interview All" - also noch bevor alle Nodes bei mir aktiv waren. Bin nun erstmal wieder zurück zur 1.10 (per Backup).
                                          Aber die Frage ist von der Version 1.10.4 kommend.
                                          1. Adapter Update dann ->
                                          • Setze ich die S2 Security Keys oder nicht ? (waren bei mir leer und ich hatte auf "Generate" geklickt. Der S0 Key war gesetzt)
                                          • Soll man dann ein Aktives Interview der Geräte machen oder passiert das von selbst?
                                            Ich hatte einen Versuch 8 von 5 im Log vielleicht lief hier auch was doppelt, weil ich mit drauf geklickt hatte?
                                              [Node 007] Interview attempt (8/5) failed, node is dead.
                                          Ich kann hier alles noch mal nachstellen oder testen - falls das was Hilft.
                                          Grüße und Danke
