  4. Test ViessmannAPI v2.0.0
  • Weihnachtsangebot 2025! 🎄
    1.9k
805 Beiträge 128 Kommentatoren 292.6k Aufrufe 125 Watching
  • U Unterstedter
    Hat jemand schon mal ein schedule geändert über dieses Adapter die Zirkulationspumpe? In welchen Datenpunkt das geschrieben werden muss ist mir klar, aber das json nicht.
    Es gibt auf github ja ein Beispiel für die Ventilation, aber ich kapier nicht welche weiteren Attribute außer Start und End bei der Zirkulationspumpe erforderlich sind :
    var standard = '{"mon":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"tue":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
    "wed":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"thu":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
    "fri":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],"sat":[{"start":"00:00","end":"24:00","mode":"standard","position":0}],
    "sun":[{"start":"00:00","end":"24:00","mode":"standard","position":0}]}'
    setState("viessmannapi.0.xxxxxxx.0.features.ventilation.schedule.commands.setSchedule.setValue", JSON.parse(standard));
    manrum1
    schrieb am zuletzt editiert von manrum1
    #201
    @unterstedter Schau dir mal folgendes Beispiel an:
    var standard = '{"mon":[{"start":"04:00","end":"05:00","mode":"on","position":0},{"start":"16:00","end":"18:00","mode":"on","position":1}],"tue":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"wed":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"thu":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"fri":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"sat":[{"start":"04:00","end":"08:00","mode":"on","position":0}],"sun":[{"start":"04:00","end":"08:00","mode":"on","position":0}]}'
    setState('viessmannapi.0.xxxx.0.features.heating.dhw.schedule.commands.setSchedule.setValue', JSON.parse(standard));
    Bei mir funktioniert das Setzen von Schedules in 4 von 5 Fällen. Leider stützt immer wieder mal der Adapter ohne Fehlermeldung ab. Deshalb setze ich keine Schedules mehr per Script, ist mir einfach zu unverlässlich.
    • B BlackTigga
      @tombox sagte in Test ViessmannAPI v2.0.0:
      Ich habe eingebaut das die virtuelle Geräte nicht aktualisiert werden nochmal neu installieren und testen ob das limit jetzt reicht
      Läuft seit heute morgen anstandslos durch :+1:
      viessmannapi.0 2021-08-12 16:22:25.665	debug	ignore type:virtual
      viessmannapi.0 2021-08-12 16:22:25.664	debug	ignore type:virtual
      viessmannapi.0 2021-08-12 16:22:25.650	debug	ignore type:gateway
      viessmannapi.0 2021-08-12 16:21:26.324	debug	https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data"
      BlackTigga
      #202
      @blacktigga sagte in Test ViessmannAPI v2.0.0:
      @tombox Seit zwei oder drei Tagen ist mein Tageslimit immer ca. um 11 Uhr aufgebraucht. Es scheint, dass die virtuellen Geräte (RoomControl-1 und HeatDemandControl) jetzt wieder mit aktualisiert werden:
      2021-09-23 07:15:31.047  - viessmannapi.0 (14905) ignore type:gateway
      2021-09-23 07:15:31.424  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
      2021-09-23 07:15:31.885  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
      2021-09-23 07:15:32.608  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
      2021-09-23 07:16:31.048  - viessmannapi.0 (14905) ignore type:gateway
      2021-09-23 07:16:31.412  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
      2021-09-23 07:16:31.812  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
      2021-09-23 07:16:33.924  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
      2021-09-23 07:17:31.055  - viessmannapi.0 (14905) ignore type:gateway
      2021-09-23 07:17:31.524  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features HeatDemandControl {"data":[]}
      2021-09-23 07:17:31.989  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features RoomControl-1 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.695Z","isEnabled":true,"isReady":true,"deviceId":"Ro
      2021-09-23 07:17:32.012  - viessmannapi.0 (14905) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features 0 {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features/device","gatewayId":"7637415019518205","feature":"device","timestamp":"2021-09-23T00:13:58.709Z","isEnabled":true,"isReady":true,"deviceId":"0"},{"properties":{},"commands":{},"co
      • B BlackTigga
        tombox
        schrieb am zuletzt editiert von tombox
        #203
        @blacktigga dann bräuchte ich dann wieder den kompletten debug log nach einem neustart des adapters wenn das rate limit wieder frei ist. einfach per mail senden.
        B 1 Antwort Letzte Antwort
        • T tombox
          BlackTigga
          #204
          @tombox Email ist raus
          • B BlackTigga
            tombox
            #205
            @blacktigga Sollte behoben sein
            • T tombox
              @manrum1 temporäre viessmann probleme abwarten bis sie es behoben haben
              manrum1
              #206
              @tombox Zur Info: Heute und gestern wieder Ausfälle:
              viessmannapi.0
              	2021-09-24 12:31:02.316	error	Error: Request failed with status code 500
              viessmannapi.0
              	2021-09-24 12:31:02.305	error	https://api.viessmann.com/iot/v1/equipment/installations/xxx/gateways/xxx/devices/$id/features
              T J 2 Antworten Letzte Antwort
              • M manrum1
                viessmannapi.0
                viessmannapi.0
                tombox
                #207
                @manrum1 Hier gibt es dazu ein Beitrag
                https://www.viessmann-community.com/t5/The-Viessmann-API/Performance-and-availability-of-Viessmann-servers/td-p/187420
                • T tombox
                  muro82
                  #208
                  Hi bin neu hier und meine Frage wäre
                  funktioniert der Adapter mit einer Vidodens 200-W mit integriertem WLAN Modul?
                  Will das über einen Raspberry laufen lassen benötige ich dazu noch etwas
                  Danke im voraus
                  J 1 Antwort Letzte Antwort
                  • M muro82
                    Danke im voraus
                    jensemann
                    #209
                    @muro82
                    Also ich habe eine Vidodens 300-W (vor 2 Monaten installiert) mit integriertem WLAN Modul.
                    Der Adapter funktioniert wie gewünscht.
                    Der iobroker läuft auch auf dem Raspberry. Ich würde dann mindestens den 3B nehmen. Da hatte ich auch mal zum testen ein iobroker image drauf. Für 3-5 Module reicht da auch der eine GB RAM.
                    • M manrum1
                      viessmannapi.0
                      viessmannapi.0
                      jensemann
                      schrieb am zuletzt editiert von jensemann
                      #210
                      @manrum1
                      @tombox
                      Habt ihr seit ein paar tagen auch Probleme?
                      ich habe nichts an meinen Settings geändert.
                      Trotzdem kommt dauert der Fehler 429 und anscheinend erreiche ich sehr schnell die max Api Calls von 1450 ?
                      viessmannapi.0
                      2021-10-12 20:38:30.040 error Error: Request failed with status code 429
                      viessmannapi.0
                      2021-10-12 20:38:30.039 error Receiving Events
                      viessmannapi.0
                      2021-10-12 20:38:29.915 error Error: Request failed with status code 429
                      viessmannapi.0
                      2021-10-12 20:38:29.796 error {"viErrorId":"XXXX","statusCode":429,"errorType":"RATE_LIMIT_EXCEEDED","message":"API calls rate limit has been exceeded. Please wait until your limit will renew.","extendedPayload":{"name":"development portal "XXXXX" daily limit","requestCountLimit":1450,"clientId":"XXXXXXX","userId":"XXXX","limitReset":1634083204599}}
                      • J jensemann
                        @manrum1
                        @tombox
                        viessmannapi.0
                        viessmannapi.0
                        viessmannapi.0
                        viessmannapi.0
                        tombox
                        #211
                        @jensemann nutzt du die aktuelle version? wieviele geräte hast du im gateway und welche refresh zeit
                        • T tombox
                          jensemann
                          #212
                          @tombox said in Test ViessmannAPI v2.0.0:
                          @tombox
                          Version ist 2.0.1
                          Update device status in minutes= 1
                          Update gateway events in minutes= 300
                          Gerätei m Gateway? Was ist damit gemeint? Ich habe eine Heizung mit integriertem WLAN Modul .. wenn das gemeint ist
                          ahhhh. ich glaube ich habs: 0 Eingabeereignisse / 11 Ausgabeereignisse ...
                          • J jensemann
                            @tombox
                            Version ist 2.0.1
                            tombox
                            #213
                            @jensemann probier mal die 2.0.4
                            • T tombox
                              jensemann
                              #214
                              Danke,läuft ohne Fehler seit dem Update!
                              • J jensemann
                                Tucca
                                #215
                                Hallo
                                sorry, für die "dumme" Frage.
                                Wie kann ich den Adapter installieren? In iobroker-Admin wird mir leider nur die Version 1.3.4 angezeigt. Auch wenn ich über npm bzw. github installieren möchte, muss ich ja etwas auswählen und dann ist dann der alte Adapter zu sehen ...
                                Ich habe heute iobroker neu installiert, da ich den Raspberry wechseln möchte.
                                VIelen Dank
                                Tucca
                                • T Tucca
                                  Hallo
                                  VIelen Dank
                                  Tucca
                                  tombox
                                  #216
                                  @tucca entweder wie im Beitrag 1 beschrieben installieren oder in den ioBroker Einstellung das repo auf latest stellen
                                    Al Bundy
                                    #217
                                    Remote Befehle sind möglich unter
                                    viessmannapi.0.XXXXX.0.features.heating.dhw.temperature.main.commands.setTargetTemperature.setValue
                                    Danke für den Adapter.
                                    Daten empfangen geht problemlos.
                                    Bei mir hackt es beim Senden von Befehlen.
                                    Wie wird z.B. der Eco-Modus aktiviert?
                                    Zuvor ging das in einem Javascript so:
                                      sendTo('viessmannapi.0.113766.0.', 'action', {
                                    		feature: 'heating.circuits.0.operating.programs.comfort',
                                    		action: 'activate',
                                    		payload: {}
                                    Ich habe nun noch die 113766 dazugefügt, im Vergleich zur vorgängigen API.
                                    Mit diesem Befehlt passiert aber nichts. Nicht mal ein Log Eintrag, den ich posten könnte (Loglevel silly).
                                    Was mache ich falsch? Wie sieht der korrekte Befehl aus?
                                    System-Info:
                                    Heizung: Gas-Brennwert-Wandgerät Vitodens 300-W
                                    Raspi 4
                                    iobroker v5.1.25
                                    js-controller v3.3.18
                                    node.js v12.22.7
                                    viessmannapi v2.0.4 (Objekte alle nochmals gelöscht und durch Adapter Neustart wieder angelegt)
                                      tombox
                                      #218
                                      @al-bundy das sendto wird nicht mehr unterstützt. bitte den entsprechend setvalue suchen und setzen
                                      z.b.
                                      viessmannapi.0.113766.0.features.heating.circuits.1.operating.modes.active.commands.setMode.setValue
                                      Wenn es kein setValue gibt kann der Wert nicht gesetz werden
                                      A 1 Antwort Letzte Antwort
                                      • T tombox
                                        z.b.
                                        Al Bundy
                                        schrieb am zuletzt editiert von Al Bundy
                                        #219
                                        @tombox
                                        Danke für den Hinweis.
                                        Das war mir bislang nicht klar. Hat aber auf anhieb funktioniert :).
                                        Nun suche ich mal die entsprechenden Objekte raus und schreibe die Scripts um.
                                        Edit 18.10.2021:
                                        Habe nun bei meiner Heizung alle setValue Parameter rausgesucht die bei meinem Gas-Brennwert-Wandgerät Vitodens 300-W vorliegen (also änderbar sind). Ich fand das Portal wie auch die Zahlreichen Objekte etwas unübersichtlich. Evtl. hilft das auch jemandem:
                                        Leider ist der von mir zuvor genutzte Datenpunkt ....eco...activate... nicht ausführbar.
                                        Ich werde mir wohl über ...setMode... => forcedReduced aushelfen müssen. Dies ist dann aber der dauerhaft reduzierte Betrieb und muss am Abend oder in der Nacht wieder auf "dhwAndHeating" gestellt werden, um wieder im Normalbetrieb zu laufen.
                                        • A Al Bundy
                                          @tombox
                                          Edit 18.10.2021:
                                          tombox
                                          #220
                                          @al-bundy Wäre eine Frage für die Viessmann Community warum es werte mit isExecutable false gibt und wann die vielleicht aktiviert werden
                                          32.6k
                                          81.9k
