  4. Test Adapter EnOcean v0.5.x
    6.4k
enoceanenocean adapter
90 Beiträge 13 Kommentatoren 15.8k Aufrufe 14 Beobachtet
  • Jey CeeJ Jey Cee
    @michif100 dann ist das Problem das der rebuild vom adapter nicht klappt.
    michif100M Offline
    michif100M Offline
    michif100
    #81
    @jey-cee Adapter löschen und neu installieren? Kann ich meine Geräte vorher exportieren, oder muss ich die wieder neu anlegen?
    • Jey CeeJ Jey Cee
      michif100M Offline
      michif100M Offline
      michif100
      #82
      @jey-cee Eben mal den Adapter komplett gelöscht und versucht neu zu installieren:
      $ iobroker url https://github.com/Jey-Cee/ioBroker.enocean --host ubuntu-20-lts-vm --debug
      install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149
      NPM version: 6.14.15
      npm install Jey-Cee/ioBroker.enocean#b8dd92c56002e1d2ef27e25c4e92c33149461149 --prefix "/opt/iobroker" (System call)
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.enocean@0.6.0updated 1 package in 8.065s
      45 packages are looking for funding run `npm fund` for details
      upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
      upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
      upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
      upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
      upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
      upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
      upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
      Process exited with code 0
      • michif100M michif100
        Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        #83
        @michif100 du kannst die Objekte exportieren und später wieder importieren, dann kannst du dir das neu anlernen Sparen.
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        michif100M 1 Antwort Letzte Antwort
        • Jey CeeJ Jey Cee
          michif100M Offline
          michif100M Offline
          michif100
          #84
          @jey-cee Habe ich gemacht, aber jetzt bekomme ich den Adapter gar nicht mehr installiert, weder 0.5.4 noch 0.6.0, siehe oben...
            Jey CeeJ Offline
            Jey CeeJ Offline
            Jey Cee
            #85
            @michif100 versteh ich nicht, die Installation zeigt keine Fehler.
            Hast du den auch eine Instanz hinzugefügt?
            • Jey CeeJ Jey Cee
              michif100M Offline
              michif100M Offline
              michif100
              #86
              @jey-cee Ähm doch, exited with code 0 ?
              Oder habe ich da etwa sfalsch verstanden. Über die Admin Oberfläche kann ich jedenfalls kein Instanz erstellen. Muss ich das über die Konsole machen?
                Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                #87
                Exit code 0 bedeutet keine Fehler.
                Im Adapter Tab siehst du den Adapter mit der Installierten Version. Dort kannst du mit dem + eine Instanz hinzufügen.
                • Jey CeeJ Jey Cee
                  #88
                  @jey-cee sagte in Test Adapter EnOcean v0.5.x:
                  @michif100
                  https://www.iobroker.net/de/tutorial/media/Instance_new.gif
                    @michif100
                    michif100M Offline
                    michif100M Offline
                    michif100
                    schrieb am zuletzt editiert von michif100
                    #89
                    @homoran said in Test Adapter EnOcean v0.5.x:
                    @michif100
                    So kannte ich das eigentlich auch, war aber nichts da. Nach nochmaligem Neustart war der Adapter nun zu sehen, ich konnte eine Instanz erstellen und nun funktioniert alles wieder!! Tausend Dank!
                    @Jey-Cee P.S.: Ich stelle dir gerne einen Afriso CO2 Sensor zur Verfügung, wenn du denn implementieren kannst.
                    Ich meine, dass der auch recht gut dokumentiert ist.
                    Bei Bedarf gerne PM.
                    • Jey CeeJ Offline
                      Jey CeeJ Offline
                      Jey Cee
                      #90
                      Ab sofort geht es Hier mit der version 0.6.1 weiter.
