  4. Test Adapter Meteoalarm v2.0.x
    5.8k
412 Beiträge 19 Kommentatoren 110.8k Aufrufe 19 Beobachtet
    @jackblackson
    Hi, gerade mal schnell am Tablett das Update gemacht, der Fehler ist jetzt anders:
    meteoalarm.0
    2022-09-15 20:15:02.667 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
    meteoalarm.0
    2022-09-15 20:15:02.666 debug Plugin sentry destroyed
    meteoalarm.0
    2022-09-15 20:15:02.665 info terminating
    meteoalarm.0
    2022-09-15 20:15:02.652 error Cannot read properties of null (reading 'val')
    meteoalarm.0
    2022-09-15 20:15:02.652 error TypeError: Cannot read properties of null (reading 'val') at saveAlarmsForLater (/opt/iobroker/node_modules/iobroker.meteoalarm/main.js:907:39) at getData (/opt/iobroker/node_modules/iobroker.meteoalarm/main.js:295:31)
    meteoalarm.0
    2022-09-15 20:15:02.645 error unhandled promise rejection: Cannot read properties of null (reading 'val')
    meteoalarm.0
    2022-09-15 20:15:02.644 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    meteoalarm.0
    2022-09-15 20:15:02.033 debug 0: Existing alarm objects at adapter start: 0
    meteoalarm.0
    2022-09-15 20:15:01.904 debug XML Language: de-DE
    meteoalarm.0
    2022-09-15 20:15:01.903 debug Sentry aktiv - Breadcrumb gesetzt
    meteoalarm.0
    2022-09-15 20:15:01.902 debug Setup found: country DE and region DE047 - Kreis Darmstadt-Dieburg und Stadt Darmstadt
    meteoalarm.0
    2022-09-15 20:15:01.901 debug Language: de
    meteoalarm.0
    2022-09-15 20:15:01.883 info starting. Version 2.3.0 (non-npm: jack-blackson/ioBroker.meteoalarm#8dfb718522b496c18249f8927edd9b6c535229b3) in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v16.17.0, js-controller: 4.0.23
    meteoalarm.0
    2022-09-15 20:15:01.616 debug Plugin sentry Initialize Plugin (enabled=true)
    jackblacksonJ Offline
    jackblackson
    #321
    @ilovegym Sorry, da hat sich noch ein Fehler eingeschlichen - kannst du bitte nochmals aktualisieren?
    ? 1 Antwort Letzte Antwort
    • jackblacksonJ jackblackson
      #322
      @jackblackson Hi,
      Jetzt läuft er, keine Fehler mehr, und hat auch die alten Alarme und Verzeichnisse gelöscht.
      Top!
      Vielen Dank!
        Aktuelle Test Version 2.0.0
        Veröffentlichungsdatum 03.07.2021
        Github Link https://github.com/jack-blackson/ioBroker.meteoalarm
        Dieser Adapter bietet euch Unwetterwarnungen für ganz Europa.
        Da die Website meteoalarm.eu sehr bald abgeschaltet wird, und durch die neue Website meteoalarm.org ersetzt wird, gab es einen sehr große Umbau im Adapter. Hier wurde einiges an der Schnittstelle angepasst.
        Wichtig: Nach der Installation müsst ihr im Setup euer Land und eure Region auswählen - der Link, der bisher genutzt wurde, ist nicht mehr notwendig/funktioniert nicht mehr.
        Es gibt einige große Unterschiede zur vorigen Version:
        • Es gibt keine Objekte mehr für "Today" und "Tomorrow". Dafür gibt es jetzt pro Warnung einen Ordner, wo die Details zu finden sind. Der Gedanke ist, das ihr das HTML Widget nutzt. Weiters gibt es nun level auf der höchsten Ebene - dies ist die höchste Warnstufe, für die es aktuell Alarme gibt. Dies könnt ihr nützen, falls ihr das Widget gerne nur ab einem bestimmten Warnlevel anzeigen möchtet. Das selbe gilt für die Farbe.
        • Alarme werden bis zum Ablaufdatum angezeigt
        • Es ist leider aktuell keine Wetterkarte mehr verfügbar, wird hoffentlich irgendwann wieder kommen
        • Die Länder Schweiz, Portugal und Bulgarien sind leider vorerst nicht mehr verfügbar, da es noch Fehler in der Datenstruktur gibt, welche hoffentlich bald behoben werden.
        Solltet ihr irgendwelche Frage oder Probleme haben, bitte meldet euch einfach. Danke schon jetzt für euer Feedback!
        #323
        @jackblackson
        Nach dem Update auf 2.31 ist der Fehler wieder da, in der GitHub Version vorher war er weg…
        jackblacksonJ 1 Antwort Letzte Antwort
          @jackblackson
          jackblackson
          #324
          @ilovegym Der letzte Fehler mit „cannot read..“?
          • ? Offline
            #325
            @jackblackson
            Hmm seit heute ist der Fehler wieder weg, kann das am Server gelegen haben?
            Hab weder n Update noch n reboot gemacht..
              @jackblackson
              jackblackson
              #326
              @ilovegym Ist sehr komisch, weil es eigentlich nur passieren konnte, wenn man noch alte Alarme hatte, die mit Version vor 2.3.0 erstellt wurden.
                #327
                @jackblackson ja, ist auch seitdem nicht mehr aufgetreten. Version 2.3.1 laeuft!
                • N Offline
                  N Offline
                  neunteufels
                  #328
                  Hallo.
                  Seit zwei Tage habe ich folgenden Fehler im Log.
                  Der Fehler tritt für beide Instanzen auf.
                  Version: 2.3.3
                  Das ganze ist jetzt Wochen und Monate stabil gelaufen und jetzt plötzlich der Fehler.
                  Neustart von Instanz, IOBroker und des ganzen Systems hat nichts gebracht.
                  Aufgefallen ist es mir, weil aktuell eine Windwarnung sein sollte, aber nichts gekommen ist.
                  TypeError: Cannot read properties of undefined (reading 'indexOf') at /opt/iobroker/node_modules/iobroker.meteoalarm/main.js:420:76 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:513:28) at Parser.emit (node:domain:489:12) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31)
                  Was kann ich noch probieren? @jackblackson
                  Danke vorab.
                  lg
                  LatziL jackblacksonJ 2 Antworten Letzte Antwort
                  • N neunteufels
                    Hallo.
                    Version: 2.3.3
                    Danke vorab.
                    lg
                    LatziL Online
                    LatziL Online
                    Latzi
                    schrieb am zuletzt editiert von Latzi
                    #329
                    @neunteufels
                    versuch´s mit Version 2.3.4 (im latest Repo) - ich hatte ein ähnliches Problem am Wochenende.
                    Edit: aktuell gibt´s schon eine 2.3.5
                    • N neunteufels
                      Hallo.
                      Version: 2.3.3
                      Danke vorab.
                      lg
                      jackblackson
                      #330
                      @neunteufels Wie @neunteufels sagt, sollte dir das Upgrade auf 2.3.4 (bzw. inzwischen 2.3.5) helfen - dies sind bisher aber nur im Beta-Channel verfügbar. Ich vermute du bist auch aus Österreich. Aus meiner Sicht wurde hier gestern bzw. vorgestern eine Windwarnung herausgegeben, die nicht ganz dem bisher definierten Format entsprochen hat - daher ist der Adapter abgeschmiert. Mit der neuen Version sollte es aber keine Problem mehr geben. Ich werde die 2.3.5 dann in 2-3 Tagen auch für alle freigeben.
                      N 1 Antwort Letzte Antwort
                        N Offline
                        N Offline
                        neunteufels
                        #331
                        @jackblackson @Latzi
                        2.3.5 hat das Problem gelöst.
                        Danke.
                        • Chris76eC Online
                          Chris76eC Online
                          Chris76e
                          #332
                          Für meinen Landkreis in Deutschland werden keine Warnungen mehr angezeigt obwohl auf der Webseite von meteoalarm.org eine Warnung vorhanden ist. Das ist schon seit ein paar Tagen so. Nutze seit heute die Version 2.3.5.
                          • Chris76eC Chris76e
                            jackblackson
                            schrieb am zuletzt editiert von jackblackson
                            #333
                            @chris76e Welche Version hattest du davor? Und um welche Region handelt es sich?
                            Chris76eC 1 Antwort Letzte Antwort
                              Chris76eC Online
                              Chris76eC Online
                              Chris76e
                              #334
                              @jackblackson Funktioniert wieder, habe gestern um 18:20 Uhr wieder Warnungen bekommen.
                              Kann dir leider nicht sagen welche Version ich vorher hatte, bin aber im stabel unterwegs.
                              Region ist Kreis Heinsberg.
                              • N Offline
                                N Offline
                                neunteufels
                                #335
                                Hallo.
                                Mir ist gerade auf gefallen, dass keine Benachrichtigung via Telegram kommt, wenn keine Warnungen mehr anstehen.
                                Das hat doch schon mal funktioniert, oder?
                                "Keine Warnungen" senden ist angehakt.
                                Was kann ich machen damit ich die wieder bekomme?
                                lg
                                • N neunteufels
                                  Hallo.
                                  lg
                                  jackblackson
                                  #336
                                  @neunteufels Ja, sollte schon funktionieren. Könntest du bitte kurz ein Issue anlegen, dann schau ich es mir gleich an. Dann sehen es Andere auch, wenn sie das selbe Problem haben.
                                    N Offline
                                    N Offline
                                    neunteufels
                                    #337
                                    @jackblackson
                                    Issue habe ich vor einer Woche erstellt.
                                    Hattest du schon Zeit die Sache zu checken?
                                    Diese Woche war es wieder so, dass die Benachrichtigung NICHT gekommen ist. :(
                                    Danke!
                                    • rtwlR Online
                                      rtwlR Online
                                      rtwl
                                      #338
                                      @jackblackson ich kann bestätigen, dass ich auch keine "keine Wetterwarnung" Meldung mehr bekomme. (Österreich)
                                      -Peter
                                      • N neunteufels
                                        @jackblackson
                                        Danke!
                                        jackblackson
                                        #339
                                        @neunteufels Ich schaue es mir heute an.
                                        • da_WoodyD Online
                                          da_WoodyD Online
                                          da_Woody
                                          #340
                                          @rtwl seltsam, in iQontrol bekomm ich die dingens.
                                          gruß vom Woody
