  4. Test Adapter Govee v0.0.x
    5.2k
313 Beiträge 49 Kommentatoren 86.8k Aufrufe 48 Beobachtet
  • Z zgadgeter
    Hi, anbei der Log, aber ich werde daraus nicht schlau...
    govee.0
    2021-07-25 13:15:10.004	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    govee.0
    2021-07-25 13:15:10.004	info	terminating
    govee.0
    2021-07-25 13:15:10.002	error	Cannot read property 'status' of undefined
    govee.0
    2021-07-25 13:15:10.002	error	TypeError: Cannot read property 'status' of undefined at /opt/iobroker/node_modules/iobroker.govee/main.js:135:27 at processTicksAndRejections (internal/process/task_queues.js:97:5)
    govee.0
    2021-07-25 13:15:10.002	error	unhandled promise rejection: Cannot read property 'status' of undefined
    govee.0
    2021-07-25 13:15:10.001	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.IOBDebian104
    2021-07-25 13:15:10.099	debug	Incoming Host message getLogs
    host.IOBDebian104
    2021-07-25 13:15:10.092	debug	Incoming Host message getLogFiles
    govee.0
    govee.0
    govee.0
    govee.0
    govee.0
    govee.0
    govee.0
    2021-07-25 13:15:09.653	info	check group user admin group admin: false
    govee.0
    2021-07-25 13:15:09.651	info	check user admin pw iobroker: true,system.user.admin
    govee.0
    2021-07-25 13:15:09.541	info	Govee API Key:
    govee.0
    2021-07-25 13:15:09.540	warn	Private mode is disabled (senstive data will shown in log output)
    govee.0
    2021-07-25 13:15:09.540	warn	Expert log disabled
    govee.0
    2021-07-25 13:15:09.530	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.14```
    #41
    @zgadgeter expert log und private log bitte einschalten und dann nochmals posten.
    • Z zgadgeter
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      host.IOBDebian104
      host.IOBDebian104
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      govee.0
      nbuengerN Offline
      nbuengerN Offline
      nbuenger
      #42
      @zgadgeter Moin, freut mich das du dabei bist. Wie @ilovegym bereits geschrieben hat brauchen wir den expert log und in deine Privaten Infos zu schützen aktiviere doch auch bitte den private mode. Und noch eine kleine Info von dir. Welches Gerät von Govee hast du denn im Einsatz? Dein Problem bekommen wir auf jeden Fall gelöst. Außerdem hoffe ich das ich morgen das Update fertig bekomme.
      Beste Grüße Nick
      J 1 Antwort Letzte Antwort
      • nbuengerN nbuenger
        Beste Grüße Nick
        JayDee
        #43
        @nbuenger
        Hey ... ich würde den adapter auch gerne testen ... nur irgendwie kann ich ihn nicht installieren ... vermutlich mache ich was falsch ;-) ... ein tip?
        Fertig mit Fehler: host.IObrokerPI4 Cannot install https://github.com/nbuenger/ioBroker.govee/tarball/master: 1
        $ ./iobroker url "https://github.com/nbuenger/ioBroker.govee" --debug
        Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)
        NPM version: 6.14.4
        npm install https://github.com/nbuenger/ioBroker.govee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
        npm
         ERR! code E404
        npm
         ERR! 404 Not Found - GET https://codeload.github.com/nbuenger/ioBroker.govee/legacy.tar.gz/masternpm ERR! 404 npm ERR!
        404  'https://github.com/nbuenger/ioBroker.govee/tarball/master' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm
         ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-08-03T20_49_07_706Z-debug.log
        ERROR: host.IObrokerPI4 Cannot install https://github.com/nbuenger/ioBroker.govee/tarball/master: 1
        nbuengerN 1 Antwort Letzte Antwort
        • J JayDee
          @nbuenger
          NPM version: 6.14.4
          npm
           ERR! code E404
          npm
          nbuengerN Offline
          nbuengerN Offline
          nbuenger
          #44
          @jaydee hey freut mich. Bin mir jetzt nicht ganz sicher aber in dem Link von dem er sich den Adapter ziehen will steht am Ende „tarball“
          Kannst du das entfernen. Dann sollte er eigentlich laufen.
          Beste Grüße Nick
            Beste Grüße Nick
            JayDee
            schrieb am zuletzt editiert von JayDee
            #45
            @nbuenger
            das hat mich auch gewundert. wo das herkommt, keine ahnung ...
            den link nutze ich: "https://github.com/nbuenger/ioBroker.govee"
            kann es an der NPM version liegen?
            • J JayDee
              @nbuenger
              nbuengerN Offline
              nbuengerN Offline
              nbuenger
              schrieb am zuletzt editiert von nbuenger
              #46
              @jaydee ich werde das mal im laufe der Woche prüfen. Ich will ja immer noch ein Update raushauen. Aber ich bin gefühlt nur auf der Arbeit😅.
              M J 3 Antworten Letzte Antwort
                myssv
                schrieb am zuletzt editiert von myssv
                #47
                @nbuenger Ich bekomme mit einem Mal folgende Meldungen
                govee.0	9118	2021-08-09 16:26:25.727	error	Error: Request failed with status code 500
                govee.0	9118	2021-08-09 16:26:20.930	error	Error: Request failed with status code 500
                govee.0	9118	2021-08-09 16:26:15.826	error	Error: Request failed with status code 500
                govee.0	9118	2021-08-09 16:26:10.867	error	Error: Request failed with status code 500
                govee.0	9118	2021-08-09 16:26:10.469	info	Govee Startup Routine finished
                govee.0	9118	2021-08-09 16:26:09.995	info	check group user admin group admin: false
                govee.0	9118	2021-08-09 16:26:09.991	info	check user admin pw iobroker: true,system.user.admin
                govee.0	9118	2021-08-09 16:26:09.861	info	Govee API Key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                govee.0	9118	2021-08-09 16:26:09.860	warn	Expert log disabled
                govee.0	9118	2021-08-09 16:26:09.543	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.15
                Auch eine komplette Neuinstallation hat nicht geholfen.
                dirk1962D M 2 Antworten Letzte Antwort
                • M myssv
                  dirk1962D Offline
                  dirk1962D Offline
                  dirk1962
                  #48
                  @myssv @nbuenger Ist bei mir seit gestern genauso.
                  NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                  • M myssv
                    myssv
                    #49
                    Hier mal das große Log:
                    govee.0	10482	2021-08-09 16:45:23.889	error	Error: Request failed with status code 500
                    govee.0	10482	2021-08-09 16:45:23.493	info	Server Response: 200 (OK)
                    govee.0	10482	2021-08-09 16:45:23.493	info	Request send: get device list
                    govee.0	10482	2021-08-09 16:45:23.492	info	Function: get current device info by API
                    govee.0	10482	2021-08-09 16:45:18.945	error	Error: Request failed with status code 500
                    govee.0	10482	2021-08-09 16:45:18.566	info	Server Response: 200 (OK)
                    govee.0	10482	2021-08-09 16:45:18.566	info	Request send: get device list
                    govee.0	10482	2021-08-09 16:45:18.566	info	Function: get current device info by API
                    govee.0	10482	2021-08-09 16:45:14.024	error	Error: Request failed with status code 500
                    govee.0	10482	2021-08-09 16:45:13.673	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.retrievable" has to be type "string" but received type "boolean"
                    govee.0	10482	2021-08-09 16:45:13.662	info	Govee Startup Routine finished
                    govee.0	10482	2021-08-09 16:45:13.661	info	Device "******************A:59" was created.
                    govee.0	10482	2021-08-09 16:45:13.661	error	H6159
                    govee.0	10482	2021-08-09 16:45:13.661	warn	Device: ******************A:59 not supports cmd "colorTem"
                    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.hex" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.value" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.saturation" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.hue" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.hsv" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.blue" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.green" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.658	info	object "color.red" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.658	info	object "color.rgb" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.658	info	object "color" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.657	info	Device: ******************A:59 supports cmd "color"
                    govee.0	10482	2021-08-09 16:45:13.656	info	object "brightness" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.656	info	Device: ******************A:59 supports cmd "brightness"
                    govee.0	10482	2021-08-09 16:45:13.656	info	object "powerState" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.656	info	Device: ******************A:59 supports cmd "powerState"
                    govee.0	10482	2021-08-09 16:45:13.655	info	object "retrievable" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.654	info	object "model" for: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.653	info	Device: ******************A:59 created
                    govee.0	10482	2021-08-09 16:45:13.652	info	Device: ******************A:59 is controllable
                    govee.0	10482	2021-08-09 16:45:13.651	info	Select Device: ******************A:59
                    govee.0	10482	2021-08-09 16:45:13.650	info	Found (1) Devices
                    govee.0	10482	2021-08-09 16:45:13.650	info	Server Response: 200 (OK)
                    govee.0	10482	2021-08-09 16:45:13.650	info	Request send: get device list
                    govee.0	10482	2021-08-09 16:45:13.238	info	check group user admin group admin: false
                    govee.0	10482	2021-08-09 16:45:13.234	info	check user admin pw iobroker: true,system.user.admin
                    govee.0	10482	2021-08-09 16:45:13.106	info	Govee API Key: *******************************cf4f
                    govee.0	10482	2021-08-09 16:45:13.105	info	Refresh interval set to: 5 seceonds
                    govee.0	10482	2021-08-09 16:45:13.105	info	Private mode is enabled (senstive data will not shown in log output)
                    govee.0	10482	2021-08-09 16:45:13.104	info	Expert log enabled
                    govee.0	10482	2021-08-09 16:45:13.082	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.15
                    • M myssv
                      nbuengerN Offline
                      nbuengerN Offline
                      nbuenger
                      #50
                      @myssv @dirk1962
                      Moin Leute, tut mir echt leid aber durch die Arbeit komme ich im Moment kaum dazu an den Rechner zu gehen. Was ich aber aus dem Log ungefähr ableiten kann ist das der Fehler 500 ein Internal Server Error Seitens Govee ist. Denn bei mir läuft alles nach wie vor. Habe eben nochmal getestet. Dieser Error 500 scheint erstmal nur ein kosmetisches Problem im Log zu sein. Die Funktion der Steuerung sollte nach wie vor gegeben sein. Ich kann es mir sonst nicht weiter erklären. leider müsst ihr warten bis ich dazu komme ein Patch fertig zu machen. Im Moment kann ich aber nicht sagen wann. Bin leider alleine an dem Projekt zu gange.
                        @myssv @dirk1962
                        myssv
                        #51
                        @nbuenger Bei mir ist der Fehler wieder verschwunden. Würde für Deine Theorie sprechen.
                        Dafür bekommem ich jetzt viele Warnungen:
                        govee.0	10705	2021-08-10 07:40:17.864	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
                        govee.0	10705	2021-08-10 07:40:13.078	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
                        govee.0	10705	2021-08-10 07:40:07.905	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
                        govee.0	10705	2021-08-10 07:40:02.777	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
                        govee.0	10705	2021-08-10 07:39:58.337	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
                          JayDee
                          #52
                          @nbuenger kein problem :) ... gibt es denn schon erkenntnisse?
                          • N Offline
                            N Offline
                            nick1290
                            #53
                            @nbuenger Ich finds super das es einen Adapter gibt, dann kann ich mir auch endlich mal Gedanken um den kauf von den Strips machen. Leider können die Wifi-Tero-/Hygrometer noch nicht über die App ausgelesen werden. Wollte damit meine Luftentfeuchter automatisieren :/ Aber gut evtl legt Govee da irgendwann mal nach :)
                            Sobald ich aber Strips habe kannst du sicher sein das ich auch mit Teste :D
                              JayDee
                              #54
                              @nbuenger
                              @nbuenger said in Test Adapter Govee v0.0.x:
                              Hey.
                              zur Info. Ich hab mal meinen IOBroker geupdated.
                              JS-controller 3.3.15
                              Node.js v12.22.4
                              Nun war die installation möglich. Vermutlich wäre es gut die abhängigkeiten bzw. voraussetzungen festzuhalten ...
                              Jetzt gehts ans testen juhu .... =)
                              L 1 Antwort Letzte Antwort
                              • J JayDee
                                @nbuenger
                                Hey.
                                Node.js v12.22.4
                                Langer
                                #55
                                @nbuenger
                                Als erstes vielen Dank für Deine Arbeit.
                                Habe den Adapter installiert, bekomme auch alle Govee's angezeigt.
                                Mit Deinem Tool bekomme ich folgende Ausgabe:
                                  "device": "FF:ED:A4:C1:38:93:49:51",
                                  "model": "H6199",
                                  "deviceName": "TV-Backlight",
                                  "controllable": true,
                                  "retrievable": true,
                                  "supportCmds": [
                                    "turn",
                                    "brightness",
                                    "color",
                                    "colorTem"
                                  "properties": {
                                    "colorTem": {
                                      "range": {
                                        "min": 2000,
                                        "max": 9000
                                  "device": "8E:AA:A4:C1:38:2E:0E:0B",
                                  "model": "H6159",
                                  "deviceName": "Terrasse",
                                  "supportCmds": [
                                    "turn",
                                    "brightness",
                                    "color",
                                    "colorTem"
                                  "properties": {
                                    "colorTem": {
                                      "range": {
                                        "min": 2000,
                                        "max": 9000
                                  "device": "DD:C5:A4:C1:38:43:44:86",
                                  "model": "H6159",
                                  "deviceName": "Sitze",
                                  "supportCmds": [
                                    "turn",
                                    "brightness",
                                    "color",
                                    "colorTem"
                                  "properties": {
                                    "colorTem": {
                                      "range": {
                                        "min": 2000,
                                        "max": 9000
                                Aber ich kann keine Werte ändern, sprich nicht Einschalten, die Farbe nicht ändern usw.
                                Jeder Wert den ich ändere wird kurz danach wieder zurück gesetzt.
                                Und in Protokolle kommen folgende Fehler:
                                govee.0
                                2021-08-25 13:56:37.678	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
                                govee.0
                                2021-08-25 13:56:32.978	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
                                govee.0
                                2021-08-25 13:56:27.734	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
                                govee.0
                                2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTemMod"
                                govee.0
                                2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTem"
                                govee.0
                                2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTemMod"
                                govee.0
                                2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTem"
                                Ich hoffe das es dafür eine Lösung gibt.
                                Vielen Dank im voraus.
                                MfG
                                Wastl
                                • H Offline
                                  helfi9999
                                  #56
                                  Hi kurze Frage,
                                  habe mir den H6125 geholt bekomme ihn aber nicht angezeigt. Kann es sein das das Band nicht kompatibel ist mit dem Adapter oder ist der Adapter ausbaufähig.
                                  Würde den Strip gerne in IObroker einbinden.
                                  Intel NUC mit Iobroker
                                  • L Langer
                                    @nbuenger
                                      "model": "H6199",
                                      "supportCmds": [
                                        "turn",
                                        "brightness",
                                        "color",
                                        "colorTem"
                                      "properties": {
                                        "colorTem": {
                                          "range": {
                                            "min": 2000,
                                            "max": 9000
                                      "model": "H6159",
                                      "supportCmds": [
                                        "turn",
                                        "brightness",
                                        "color",
                                        "colorTem"
                                      "properties": {
                                        "colorTem": {
                                          "range": {
                                            "min": 2000,
                                            "max": 9000
                                      "model": "H6159",
                                      "supportCmds": [
                                        "turn",
                                        "brightness",
                                        "color",
                                        "colorTem"
                                      "properties": {
                                        "colorTem": {
                                          "range": {
                                            "min": 2000,
                                            "max": 9000
                                    govee.0
                                    govee.0
                                    govee.0
                                    govee.0
                                    govee.0
                                    govee.0
                                    govee.0
                                    MfG
                                    Wastl
                                    nbuengerN Offline
                                    nbuengerN Offline
                                    nbuenger
                                    #57
                                    @langer Moin,
                                    wie versuchst du die Werte denn zu bearbeiten. Machst du das über die Objekt Übersicht oder benutzt du ViS oder eine andere Visualisierung. Der Fehler mit den falschen Types kommt seid dem Update vom IOBroker. Ich würde gerne ein Update für euch raushauen aber ich komme nicht dazu da ich nur am arbeiten bin. Tut mir leid. Möglicherweise schaffe ich ja etwas in meinem Urlaub.
                                    • H helfi9999
                                      Hi kurze Frage,
                                      nbuengerN Offline
                                      nbuengerN Offline
                                      nbuenger
                                      #58
                                      @helfi9999 Moin, du kannst das einfach prüfen indem du deinen Govee-API-Key in meinem Tool eingibst.
                                      https://buenger-webdesign.de/api/
                                      Den Output kannst du mir dann hier reinschicken oder privat wie du gerne möchtest. Dann sage ich dir ob der von der API vollständig unterstützt wird.
                                      Die neue Version des Testing Tools ist auch bald fertig es fehlen noch ein ein paar kleine optische Anpassungen dann bekommt ihr den Zugang dazu.
                                        siton23
                                        #59
                                        Erstmal danke für die Arbeit, die bisher geleistet wurde. Ich würde auch gerne die Govee LED Stripes im iobroker einbinden und den Adapter testen.
                                        Meine Frage wäre noch ob es bald auch möglich sein wird die verschiedene Modi zu ändern?
                                        Also vor allem der Musik Modus würde mich interessieren. Dann wäre es auch schön ggf. die Szenen (nicht nur Musik Szenen) einstellen zu können.
                                        Würde mich sehr über Infos freuen ob dies In bereits in Planung ist, da ich es dann auch sehr gerne nutzen würde.
                                        • S siton23
                                          nbuengerN Offline
                                          nbuengerN Offline
                                          nbuenger
                                          #60
                                          @siton23 Hey,
                                          ich danke dir. So gerne ich das in den Adapter integrieren würde wird das leider nicht möglich sein. Die Offizielle API von Govee unterstützt das Feature für den Modi Wechsel nicht. Ich hoffe das die da irgendwann nach ziehen. Sehe da bisher aber keine Hoffnung. Tut mir leid dir das sagen zu müssen.
