  4. Test Adapter Govee v0.0.x
    6.5k
313 Beiträge 49 Kommentatoren 88.5k Aufrufe 48 Beobachtet
  • M myssv
    Hier mal das große Log:
    govee.0	10482	2021-08-09 16:45:23.889	error	Error: Request failed with status code 500
    govee.0	10482	2021-08-09 16:45:23.493	info	Server Response: 200 (OK)
    govee.0	10482	2021-08-09 16:45:23.493	info	Request send: get device list
    govee.0	10482	2021-08-09 16:45:23.492	info	Function: get current device info by API
    govee.0	10482	2021-08-09 16:45:18.945	error	Error: Request failed with status code 500
    govee.0	10482	2021-08-09 16:45:18.566	info	Server Response: 200 (OK)
    govee.0	10482	2021-08-09 16:45:18.566	info	Request send: get device list
    govee.0	10482	2021-08-09 16:45:18.566	info	Function: get current device info by API
    govee.0	10482	2021-08-09 16:45:14.024	error	Error: Request failed with status code 500
    govee.0	10482	2021-08-09 16:45:13.673	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.retrievable" has to be type "string" but received type "boolean"
    govee.0	10482	2021-08-09 16:45:13.662	info	Govee Startup Routine finished
    govee.0	10482	2021-08-09 16:45:13.661	info	Device "******************A:59" was created.
    govee.0	10482	2021-08-09 16:45:13.661	error	H6159
    govee.0	10482	2021-08-09 16:45:13.661	warn	Device: ******************A:59 not supports cmd "colorTem"
    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.hex" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.value" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.660	info	object "color.saturation" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.hue" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.hsv" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.blue" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.659	info	object "color.green" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.658	info	object "color.red" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.658	info	object "color.rgb" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.658	info	object "color" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.657	info	Device: ******************A:59 supports cmd "color"
    govee.0	10482	2021-08-09 16:45:13.656	info	object "brightness" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.656	info	Device: ******************A:59 supports cmd "brightness"
    govee.0	10482	2021-08-09 16:45:13.656	info	object "powerState" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.656	info	Device: ******************A:59 supports cmd "powerState"
    govee.0	10482	2021-08-09 16:45:13.655	info	object "retrievable" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.654	info	object "model" for: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.653	info	Device: ******************A:59 created
    govee.0	10482	2021-08-09 16:45:13.652	info	Device: ******************A:59 is controllable
    govee.0	10482	2021-08-09 16:45:13.651	info	Select Device: ******************A:59
    govee.0	10482	2021-08-09 16:45:13.650	info	Found (1) Devices
    govee.0	10482	2021-08-09 16:45:13.650	info	Server Response: 200 (OK)
    govee.0	10482	2021-08-09 16:45:13.650	info	Request send: get device list
    govee.0	10482	2021-08-09 16:45:13.238	info	check group user admin group admin: false
    govee.0	10482	2021-08-09 16:45:13.234	info	check user admin pw iobroker: true,system.user.admin
    govee.0	10482	2021-08-09 16:45:13.106	info	Govee API Key: *******************************cf4f
    govee.0	10482	2021-08-09 16:45:13.105	info	Refresh interval set to: 5 seceonds
    govee.0	10482	2021-08-09 16:45:13.105	info	Private mode is enabled (senstive data will not shown in log output)
    govee.0	10482	2021-08-09 16:45:13.104	info	Expert log enabled
    govee.0	10482	2021-08-09 16:45:13.082	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.15
    nbuengerN Offline
    nbuengerN Offline
    nbuenger
    schrieb am zuletzt editiert von nbuenger
    @myssv @dirk1962
    Moin Leute, tut mir echt leid aber durch die Arbeit komme ich im Moment kaum dazu an den Rechner zu gehen. Was ich aber aus dem Log ungefähr ableiten kann ist das der Fehler 500 ein Internal Server Error Seitens Govee ist. Denn bei mir läuft alles nach wie vor. Habe eben nochmal getestet. Dieser Error 500 scheint erstmal nur ein kosmetisches Problem im Log zu sein. Die Funktion der Steuerung sollte nach wie vor gegeben sein. Ich kann es mir sonst nicht weiter erklären. leider müsst ihr warten bis ich dazu komme ein Patch fertig zu machen. Im Moment kann ich aber nicht sagen wann. Bin leider alleine an dem Projekt zu gange.
    • nbuengerN nbuenger
      @myssv @dirk1962
      myssv
      @nbuenger Bei mir ist der Fehler wieder verschwunden. Würde für Deine Theorie sprechen.
      Dafür bekommem ich jetzt viele Warnungen:
      govee.0	10705	2021-08-10 07:40:17.864	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
      govee.0	10705	2021-08-10 07:40:13.078	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
      govee.0	10705	2021-08-10 07:40:07.905	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
      govee.0	10705	2021-08-10 07:40:02.777	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
      govee.0	10705	2021-08-10 07:39:58.337	warn	State "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has no existing object, this might lead to an error in future versions
        @jaydee ich werde das mal im laufe der Woche prüfen. Ich will ja immer noch ein Update raushauen. Aber ich bin gefühlt nur auf der Arbeit😅.
        JayDee
        @nbuenger kein problem :) ... gibt es denn schon erkenntnisse?
        • N Offline
          N Offline
          nick1290
          @nbuenger Ich finds super das es einen Adapter gibt, dann kann ich mir auch endlich mal Gedanken um den kauf von den Strips machen. Leider können die Wifi-Tero-/Hygrometer noch nicht über die App ausgelesen werden. Wollte damit meine Luftentfeuchter automatisieren :/ Aber gut evtl legt Govee da irgendwann mal nach :)
          Sobald ich aber Strips habe kannst du sicher sein das ich auch mit Teste :D
            JayDee
            schrieb am zuletzt editiert von JayDee
            @nbuenger
            @nbuenger said in Test Adapter Govee v0.0.x:
            Hey.
            zur Info. Ich hab mal meinen IOBroker geupdated.
            JS-controller 3.3.15
            Node.js v12.22.4
            Nun war die installation möglich. Vermutlich wäre es gut die abhängigkeiten bzw. voraussetzungen festzuhalten ...
            Jetzt gehts ans testen juhu .... =)
            L 1 Antwort Letzte Antwort
            • J JayDee
              @nbuenger
              Hey.
              Node.js v12.22.4
              Langer
              @nbuenger
              Als erstes vielen Dank für Deine Arbeit.
              Habe den Adapter installiert, bekomme auch alle Govee's angezeigt.
              Mit Deinem Tool bekomme ich folgende Ausgabe:
                "device": "FF:ED:A4:C1:38:93:49:51",
                "model": "H6199",
                "deviceName": "TV-Backlight",
                "controllable": true,
                "retrievable": true,
                "supportCmds": [
                  "turn",
                  "brightness",
                  "color",
                  "colorTem"
                "properties": {
                  "colorTem": {
                    "range": {
                      "min": 2000,
                      "max": 9000
                "device": "8E:AA:A4:C1:38:2E:0E:0B",
                "model": "H6159",
                "deviceName": "Terrasse",
                "supportCmds": [
                  "turn",
                  "brightness",
                  "color",
                  "colorTem"
                "properties": {
                  "colorTem": {
                    "range": {
                      "min": 2000,
                      "max": 9000
                "device": "DD:C5:A4:C1:38:43:44:86",
                "model": "H6159",
                "deviceName": "Sitze",
                "supportCmds": [
                  "turn",
                  "brightness",
                  "color",
                  "colorTem"
                "properties": {
                  "colorTem": {
                    "range": {
                      "min": 2000,
                      "max": 9000
              Aber ich kann keine Werte ändern, sprich nicht Einschalten, die Farbe nicht ändern usw.
              Jeder Wert den ich ändere wird kurz danach wieder zurück gesetzt.
              Und in Protokolle kommen folgende Fehler:
              govee.0
              2021-08-25 13:56:37.678	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
              govee.0
              2021-08-25 13:56:32.978	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
              govee.0
              2021-08-25 13:56:27.734	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
              govee.0
              2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTemMod"
              govee.0
              2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTem"
              govee.0
              2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTemMod"
              govee.0
              2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTem"
              Ich hoffe das es dafür eine Lösung gibt.
              Vielen Dank im voraus.
              MfG
              Wastl
              nbuengerN 1 Antwort Letzte Antwort
              • H Offline
                helfi9999
                Hi kurze Frage,
                habe mir den H6125 geholt bekomme ihn aber nicht angezeigt. Kann es sein das das Band nicht kompatibel ist mit dem Adapter oder ist der Adapter ausbaufähig.
                Würde den Strip gerne in IObroker einbinden.
                Intel NUC mit Iobroker
                • L Langer
                  @nbuenger
                    "model": "H6199",
                    "supportCmds": [
                      "turn",
                      "brightness",
                      "color",
                      "colorTem"
                    "properties": {
                      "colorTem": {
                        "range": {
                          "min": 2000,
                          "max": 9000
                    "model": "H6159",
                    "supportCmds": [
                      "turn",
                      "brightness",
                      "color",
                      "colorTem"
                    "properties": {
                      "colorTem": {
                        "range": {
                          "min": 2000,
                          "max": 9000
                    "model": "H6159",
                    "supportCmds": [
                      "turn",
                      "brightness",
                      "color",
                      "colorTem"
                    "properties": {
                      "colorTem": {
                        "range": {
                          "min": 2000,
                          "max": 9000
                  govee.0
                  govee.0
                  govee.0
                  govee.0
                  govee.0
                  govee.0
                  govee.0
                  MfG
                  Wastl
                  nbuengerN Offline
                  nbuengerN Offline
                  nbuenger
                  @langer Moin,
                  wie versuchst du die Werte denn zu bearbeiten. Machst du das über die Objekt Übersicht oder benutzt du ViS oder eine andere Visualisierung. Der Fehler mit den falschen Types kommt seid dem Update vom IOBroker. Ich würde gerne ein Update für euch raushauen aber ich komme nicht dazu da ich nur am arbeiten bin. Tut mir leid. Möglicherweise schaffe ich ja etwas in meinem Urlaub.
                  • H helfi9999
                    Hi kurze Frage,
                    nbuengerN Offline
                    nbuengerN Offline
                    nbuenger
                    @helfi9999 Moin, du kannst das einfach prüfen indem du deinen Govee-API-Key in meinem Tool eingibst.
                    https://buenger-webdesign.de/api/
                    Den Output kannst du mir dann hier reinschicken oder privat wie du gerne möchtest. Dann sage ich dir ob der von der API vollständig unterstützt wird.
                    Die neue Version des Testing Tools ist auch bald fertig es fehlen noch ein ein paar kleine optische Anpassungen dann bekommt ihr den Zugang dazu.
                      siton23
                      Erstmal danke für die Arbeit, die bisher geleistet wurde. Ich würde auch gerne die Govee LED Stripes im iobroker einbinden und den Adapter testen.
                      Meine Frage wäre noch ob es bald auch möglich sein wird die verschiedene Modi zu ändern?
                      Also vor allem der Musik Modus würde mich interessieren. Dann wäre es auch schön ggf. die Szenen (nicht nur Musik Szenen) einstellen zu können.
                      Würde mich sehr über Infos freuen ob dies In bereits in Planung ist, da ich es dann auch sehr gerne nutzen würde.
                      • S siton23
                        nbuengerN Offline
                        nbuengerN Offline
                        nbuenger
                        @siton23 Hey,
                        ich danke dir. So gerne ich das in den Adapter integrieren würde wird das leider nicht möglich sein. Die Offizielle API von Govee unterstützt das Feature für den Modi Wechsel nicht. Ich hoffe das die da irgendwann nach ziehen. Sehe da bisher aber keine Hoffnung. Tut mir leid dir das sagen zu müssen.
                          siton23
                          @nbuenger ok das ist schade. Aber trotzdem danke für die Antwort. Ich werde den Adapter trotzdem nutzen.
                            myssv
                            Nachdem es jetzt wieder früher dunkel wird, wollte ich eben meinen LED Streifen einschalten und es geht nicht mehr ...
                            Der Power State wird auch nicht mehr korrekt erkannt. Der Streifen ist aktuell an
                              myssv
                              Habe gerade gesehen, dass ich auch massenhaft Fehlermeldungen erhalte:
                              • Z Offline
                                Z Offline
                                zgadgeter
                                der ADapter bei mir ist schon laegner Rot, und ich bekomme den nicht auf gruen. Die letzte Version ist installiert. Einen neuen API habe ich auch schon beantragt...aber er bleibt auf rot.
                                Funktioniert der Adapter noch?
                                • Z zgadgeter
                                  @zgadgeter
                                  Ja, hier läuft der mit 'grüner Ampel'.
                                  Z 1 Antwort Letzte Antwort
                                    @zgadgeter
                                    Z Offline
                                    Z Offline
                                    zgadgeter
                                    #66
                                    Komisch. Ich habe den Adapter mal entfernt, wieder installiert, immer noch Rot.
                                    Dann habe ich den gesamten Iobroker upgedated (sieh untern), aber immer noch Rot...
                                    • Z zgadgeter
                                      #67
                                      @zgadgeter
                                      Und was steht im LogFile dazu?
                                        @zgadgeter
                                        Z Offline
                                        Z Offline
                                        zgadgeter
                                        #68
                                        @thomas-braun Hi, ich habe den adapter neu gestartet, und hier ist der output.5b09225f-d99c-42f3-9831-70ef55186570-image.png
                                        Also ich erkenne nichts....
                                        • Z zgadgeter
                                          #69
                                          @zgadgeter
                                          Ich vermute, dass sollte sich mal der Maintainer von dem Adapter anschauen. Mach am besten ein Issue auf github dazu auf.
