  4. Test Adapter Govee v0.0.x
    6.5k
313 Beiträge 49 Kommentatoren 88.5k Aufrufe 48 Beobachtet
  • L Langer
    @nbuenger
    Als erstes vielen Dank für Deine Arbeit.
    Habe den Adapter installiert, bekomme auch alle Govee's angezeigt.
    Mit Deinem Tool bekomme ich folgende Ausgabe:
      "device": "FF:ED:A4:C1:38:93:49:51",
      "model": "H6199",
      "deviceName": "TV-Backlight",
      "controllable": true,
      "retrievable": true,
      "supportCmds": [
        "turn",
        "brightness",
        "color",
        "colorTem"
      "properties": {
        "colorTem": {
          "range": {
            "min": 2000,
            "max": 9000
      "device": "8E:AA:A4:C1:38:2E:0E:0B",
      "model": "H6159",
      "deviceName": "Terrasse",
      "supportCmds": [
        "turn",
        "brightness",
        "color",
        "colorTem"
      "properties": {
        "colorTem": {
          "range": {
            "min": 2000,
            "max": 9000
      "device": "DD:C5:A4:C1:38:43:44:86",
      "model": "H6159",
      "deviceName": "Sitze",
      "supportCmds": [
        "turn",
        "brightness",
        "color",
        "colorTem"
      "properties": {
        "colorTem": {
          "range": {
            "min": 2000,
            "max": 9000
    Aber ich kann keine Werte ändern, sprich nicht Einschalten, die Farbe nicht ändern usw.
    Jeder Wert den ich ändere wird kurz danach wieder zurück gesetzt.
    Und in Protokolle kommen folgende Fehler:
    govee.0
    2021-08-25 13:56:37.678	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
    govee.0
    2021-08-25 13:56:32.978	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
    govee.0
    2021-08-25 13:56:27.734	info	State value to set for "govee.0.8E:AA:A4:C1:38:2E:0E:0B.online" has to be type "boolean" but received type "string"
    govee.0
    2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTemMod"
    govee.0
    2021-08-25 13:54:58.046	info	undefined is not a valid state value for id "govee.0.8E:AA:A4:C1:38:2E:0E:0B.colorTem"
    govee.0
    2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTemMod"
    govee.0
    2021-08-25 13:54:58.044	info	undefined is not a valid state value for id "govee.0.DD:C5:A4:C1:38:43:44:86.colorTem"
    Ich hoffe das es dafür eine Lösung gibt.
    Vielen Dank im voraus.
    MfG
    Wastl
    nbuengerN Offline
    nbuengerN Offline
    nbuenger
    @langer Moin,
    wie versuchst du die Werte denn zu bearbeiten. Machst du das über die Objekt Übersicht oder benutzt du ViS oder eine andere Visualisierung. Der Fehler mit den falschen Types kommt seid dem Update vom IOBroker. Ich würde gerne ein Update für euch raushauen aber ich komme nicht dazu da ich nur am arbeiten bin. Tut mir leid. Möglicherweise schaffe ich ja etwas in meinem Urlaub.
    • H helfi9999
      Hi kurze Frage,
      habe mir den H6125 geholt bekomme ihn aber nicht angezeigt. Kann es sein das das Band nicht kompatibel ist mit dem Adapter oder ist der Adapter ausbaufähig.
      Würde den Strip gerne in IObroker einbinden.
      nbuengerN Offline
      nbuengerN Offline
      nbuenger
      @helfi9999 Moin, du kannst das einfach prüfen indem du deinen Govee-API-Key in meinem Tool eingibst.
      https://buenger-webdesign.de/api/
      Den Output kannst du mir dann hier reinschicken oder privat wie du gerne möchtest. Dann sage ich dir ob der von der API vollständig unterstützt wird.
      Die neue Version des Testing Tools ist auch bald fertig es fehlen noch ein ein paar kleine optische Anpassungen dann bekommt ihr den Zugang dazu.
        siton23
        Erstmal danke für die Arbeit, die bisher geleistet wurde. Ich würde auch gerne die Govee LED Stripes im iobroker einbinden und den Adapter testen.
        Meine Frage wäre noch ob es bald auch möglich sein wird die verschiedene Modi zu ändern?
        Also vor allem der Musik Modus würde mich interessieren. Dann wäre es auch schön ggf. die Szenen (nicht nur Musik Szenen) einstellen zu können.
        Würde mich sehr über Infos freuen ob dies In bereits in Planung ist, da ich es dann auch sehr gerne nutzen würde.
        nbuengerN 1 Antwort Letzte Antwort
        • S siton23
          nbuengerN Offline
          nbuengerN Offline
          nbuenger
          @siton23 Hey,
          ich danke dir. So gerne ich das in den Adapter integrieren würde wird das leider nicht möglich sein. Die Offizielle API von Govee unterstützt das Feature für den Modi Wechsel nicht. Ich hoffe das die da irgendwann nach ziehen. Sehe da bisher aber keine Hoffnung. Tut mir leid dir das sagen zu müssen.
            siton23
            @nbuenger ok das ist schade. Aber trotzdem danke für die Antwort. Ich werde den Adapter trotzdem nutzen.
              myssv
              Nachdem es jetzt wieder früher dunkel wird, wollte ich eben meinen LED Streifen einschalten und es geht nicht mehr ...
              Der Power State wird auch nicht mehr korrekt erkannt. Der Streifen ist aktuell an
                myssv
                Habe gerade gesehen, dass ich auch massenhaft Fehlermeldungen erhalte:
                • Z Offline
                  Z Offline
                  zgadgeter
                  der ADapter bei mir ist schon laegner Rot, und ich bekomme den nicht auf gruen. Die letzte Version ist installiert. Einen neuen API habe ich auch schon beantragt...aber er bleibt auf rot.
                  Funktioniert der Adapter noch?
                  • Z zgadgeter
                    @zgadgeter
                    Ja, hier läuft der mit 'grüner Ampel'.
                    Z 1 Antwort Letzte Antwort
                      @zgadgeter
                      Z Offline
                      Z Offline
                      zgadgeter
                      #66
                      Komisch. Ich habe den Adapter mal entfernt, wieder installiert, immer noch Rot.
                      Dann habe ich den gesamten Iobroker upgedated (sieh untern), aber immer noch Rot...
                      • Z zgadgeter
                        #67
                        @zgadgeter
                        Und was steht im LogFile dazu?
                          @zgadgeter
                          Z Offline
                          Z Offline
                          zgadgeter
                          #68
                          @thomas-braun Hi, ich habe den adapter neu gestartet, und hier ist der output.5b09225f-d99c-42f3-9831-70ef55186570-image.png
                          Also ich erkenne nichts....
                          • Z zgadgeter
                            #69
                            @zgadgeter
                            Ich vermute, dass sollte sich mal der Maintainer von dem Adapter anschauen. Mach am besten ein Issue auf github dazu auf.
                            • nbuengerN Offline
                              nbuengerN Offline
                              nbuenger
                              #70
                              Hey Leute, es tut mir wahnsinnig leid das ich mich nicht gemeldet habe und ihr von mir nichts weiteres mit bekommen habt. Ich würde gerne aktiv am Adapter arbeiten. Nur leider bin ich berufstätig und daher habe ich nicht die Zeit die ich gerne aufbringen würde. Möglicherweise habe ich demnächst einen neuen Job da hätte ich dann auch wieder mehr Zeit. Ich werde die Fehler die aufgetreten sind beheben. Ich kann euch nur nicht versprechen wann. Wenn es jemanden in der Community gibt der ebenfalls Bock auf das Projekt hat kann sich diese/r jemand gerne bei mir melden und ich Weihe diese/n jemand gerne in das Projekt ein.
                              Es tut mir leid das ich keine besseren Nachrichten für euch habe. Ich hoffe das wir den Adapter bald wieder voran bringen können.
                                Alex975
                                #71
                                Trotzdem mal eine generelle Frage:
                                Die API gibt nur Stripes zurück oder wurden die gefiltert? Hintergrund ist, dass ich von Govee ein WIFI Thermometer habe was im Gewächshaus hängt. Über den Alexa Adapter bekomme ich zumindest die Temp, diese aktualisiert sich aber nicht wirklich.
                                VG Alex
                                • A Alex975
                                  VG Alex
                                  nbuengerN Offline
                                  nbuengerN Offline
                                  nbuenger
                                  #72
                                  Moin @alex975,
                                  die API seitens Govee ist sehr eingewchränkt.
                                  Hier hast du mal die API zum ansehen. Darin ist eine Liste aller unterstützten Geräte. Allerdings habe ich bei einigen Geräten festgestellt das die API nicht korrekt funktioniert. Der Sensoren zählen leider auch dazu.
                                  Und für alle anderen. Das Update ist in Gange aber es benötigt alles noch etwas mehr Zeit. Sobald ich ein Datum für den Release habe bekommt ihr eine Info.
                                  VG Nick
                                  • Martin SteinerM Offline
                                    Martin Steiner
                                    #73
                                    ich habe Probleme bei der Installation des Adpaters. Kann mir Jemand bitte hilfreiche Hinweise geben?
                                    meine Hardware/Software:
                                    Pi4 mit 4 GB
                                    ioBroker Version 5.1.25
                                    Nodejs 14.7.5 (empfohlen wird 12.22.7 aber keine Ahnung wie ich wieder runtersetzen soll, hab mehrfach was erfolglos probiert... gibt es gute Anleitung?)
                                    NPM 6.14.14
                                    der Adapter wird von Github bei mir nicht geladen, in den Instanzen taucht er nicht auf. Allerdings ist in den Objekten ein Ordner "Govee" angelegt und ein Unterordner Admin.
                                    Hier der Installationscode, vielleicht lässt sich daraus bereits ablesen wo es klemmt
                                    $ iobroker url https://github.com/nbuenger/ioBroker.govee --host raspberrypi4-ioB --debug
                                    install nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606
                                    NPM version: 6.14.14npm install nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606 --prefix "/opt/iobroker" (System call)
                                    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam> node-gyp rebuild
                                    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                                    CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                                    In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
                                    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args); ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1024:46: note: declared here NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback( ^~~~~~~~~~~~
                                    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’ res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked()); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3717:43: note: candidate expects 2 arguments, 1 provided/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’ V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3720:43: note: candidate expects 2 arguments, 1 provided../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ username->WriteUtf8(m->username, sizeof(m->username) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’ password->WriteUtf8(m->password, sizeof(m->password) - 1); ^In file included from /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:67, from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/v8.h:3037:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                    ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) { ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) { ^~~~~~ rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) { ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) { ^~~~~~~In file included from ../../nan/nan.h:54, from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init); ^~~~/home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:36: note: in definition of macro ‘NODE_MODULE_X’ (node::addon_register_func) (regfunc), \ ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)
                                    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)gyp ERR! System Linux 5.10.60-v7l+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v14.17.5gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                    + iobroker.govee@0.0.5updated 1 package in 44.717s
                                    68 packages are looking for funding run `npm fund` for details
                                    upload [5] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/words.js words.js application/javascript
                                    upload [4] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/style.css style.css text/css
                                    upload [3] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/index_m.html index_m.html text/html
                                    upload [2] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/govee.png govee.png image/png
                                    upload [1] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/govee-old.png govee-old.png image/png
                                    upload [0] govee.admin /opt/iobroker/node_modules/iobroker.govee/admin/admin.d.ts admin.d.ts video/mp2t
                                    Process exited with code 0
                                    Lieben Dank für Eure Hinweise und Unterstützung!
                                    Pi4 mit 4 GB
                                    Nodejs 14.7.5 (empfohlen wird 12.22.7 aber keine Ahnung wie ich wieder runtersetzen soll)
                                    NPM 6.14.14
                                    • Martin SteinerM Martin Steiner
                                      Pi4 mit 4 GB
                                      NPM 6.14.14
                                      Pi4 mit 4 GB
                                      NPM 6.14.14
                                      #74
                                      @martin-steiner sagte in Test Adapter Govee v0.0.x:
                                      Schau in meiner Signatur. Da erkläre ich wie man in den Versionen lustig rauf und runterspringen kann.
                                      Zu pam:
                                      Ist libpam0g-dev installiert?
                                      apt policy libpam0g-dev
                                      Martin SteinerM 1 Antwort Letzte Antwort
                                        Zu pam:
                                        Martin Steiner
                                        #75
                                        @thomas-braun sagte in Test Adapter Govee v0.0.x:
                                        Vielen Dank für die schnelle Antwort Thomas.
                                        pi@raspberrypi4-ioB:/opt/iobroker $ apt policy libpam0g-dev
                                        libpam0g-dev:
                                          Installiert:           1.3.1-5+rpt2
                                          Installationskandidat: 1.3.1-5+rpt2
                                          Versionstabelle:
                                         *** 1.3.1-5+rpt2 500
                                                500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                                             1.3.1-5 500
                                        da scheint was da zu sein ja...
                                        ich schau mir das mal an mit dem Downgraden... hab den Link gerade aufgerufen
                                        Danke für Deine Hilfe
                                        Ich hatte bisher eine Webseitenanleitung befolgt
                                        https://www.shelly-support.eu/forum/index.php?thread/5457-upgrade-update-iobroker-auf-raspberry-pi/
                                        wo das Thema auch beschrieben ist allerdings wenn ich auf die version 12.22.7 in der Befehlszeile abstelle dann kommt eine Fehlermeldung
                                        pi@raspberrypi4-ioB:/opt/iobroker $ apt policy nodejs
                                        nodejs:
                                          Installiert:           14.17.6-deb-1nodesource1
                                          Installationskandidat: 14.17.6-deb-1nodesource1
                                          Versionstabelle:
                                         *** 14.17.6-deb-1nodesource1 100
                                             12.22.7-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                             10.24.1-1nodesource1 500
                                                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                             10.24.0~dfsg-1~deb10u1 500
                                        pi@raspberrypi4-ioB:/opt/iobroker $ sudo apt install nodejs=12.22.7-1nodesource1
                                        pi@raspberrypi4-ioB:/opt/iobroker $ pi@raspberrypi4-ioB:/opt/iobroker $ sudo apt install nodejs=12.22.7-1nodesource1
                                        -bash: pi@raspberrypi4-ioB:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
                                        kannst Du damit etwas anfangen?
                                        So und jetzt lese ich deine Anleitung! :-)
                                          libpam0g-dev:
                                            Versionstabelle:
                                               1.3.1-5 500
                                          nodejs:
                                            Versionstabelle:
                                          #76
                                          Die richtige Versionierung verwenden.
                                          Mit
                                          sudo apt install nodejs=12.22.7-deb-1nodesource1
                                          wir ein Schuh draus.
                                          Übrigens ist die verlinkte Anleitung leider mal wieder Murks. Gleich an mehreren Stellen. Nicht verwenden.
