  4. Node-Red
  5. Payload String zerlegen
    6.4k
77 Beiträge 7 Kommentatoren 19.6k Aufrufe 7 Beobachtet
  • R rieders
    Hallo
    Ich versuche gerade mein Stromzähler String zu zerlegen.
    Eine Verbindung zum mqtt-Broker besteht, die Daten werden auch im Debug angezeigt.
    Ich habe schon einiges Versuch, ich bekomme einfach nicht die Werte einzeln angezeigt.
    Smartmeter_Garten/tele/SENSOR : msg.payload : string[643]
    "{"Time":"2023-01-13T12:54:35","SDM630":{"1":178,"Voltage_P1":231.88,"Voltage_P2":231.5,"Voltage_P3":232.49,"Current_P1":0,"Current_P2":0.1,"Current_P3":0,"Power_P1":0,"Power_P2":22.35,"Power_P3":0,"Frequenz":50.01,"Total":534.694,"phase_angle":-9.73,"Import_nres":186.145,"Export_nres":348.549,"Export_P1":13.568,"Export_P2":334.981,"Export_P3":0,"Import_P1":19.409,"Import_P2":131.003,"Import_P3":35.733,"L1_total_kwh":32.977,"L2_total_kwh":465.984,"L3_total_kwh":35.733,"Blindleistung_L1":0,"Blindleistung_L2":-7.734,"Blindleistung_L3":0,"Scheinleistung_L1":0,"Scheinleistung_L2":22.627,"Scheinleistung_L3":0,"VAh_since_last_reset":565.815}}"
    Ich hoffe jemand kann mir weiter helfen.
    "id": "553525487db580b5",
    "type": "mqtt in",
    "z": "eb71b4cddc9da37a",
    "name": "Smartmeter_Garten/tele/SENSOR",
    "topic": "Smartmeter_Garten/tele/SENSOR",
    "qos": "2",
    "datatype": "auto-detect",
    "broker": "e7e1e2255e66e588",
    "nl": false,
    "rap": true,
    "rh": "2",
    "inputs": 0,
    "x": 180,
    "y": 260,
    "wires": [
    "04a7ba72539a5cb1",
    "df378652670347e0"
    "id": "b0fcb45d6d8ab9f4",
    "type": "ui_gauge",
    "name": "Test",
    "group": "67140eec2a9994a9",
    "order": 0,
    "width": 0,
    "height": 0,
    "gtype": "gage",
    "title": "Voltage_P1",
    "label": "",
    "format": "{{Value}}",
    "min": "1",
    "max": "260",
    "colors": [
    "#b30000",
    "#e6e600",
    "#00b815"
    "seg1": "",
    "seg2": "",
    "x": 890,
    "y": 260,
    "wires": []
    "id": "9faaac80e56b9d83",
    "type": "ui_chart",
    "name": "",
    "order": 0,
    "width": 0,
    "height": 0,
    "label": "chart",
    "chartType": "line",
    "legend": "false",
    "xformat": "HH:mm:ss",
    "interpolate": "linear",
    "nodata": "",
    "dot": false,
    "ymin": "0",
    "ymax": "260",
    "removeOlder": 1,
    "removeOlderPoints": "",
    "removeOlderUnit": "3600",
    "cutout": 0,
    "useOneColor": false,
    "useUTC": false,
    "colors": [
    "#1f77b4",
    "#aec7e8",
    "#ff7f0e",
    "#2ca02c",
    "#98df8a",
    "#d62728",
    "#ff9896",
    "#9467bd",
    "#c5b0d5"
    "outputs": 1,
    "useDifferentColor": false,
    "x": 890,
    "y": 320,
    "wires": [
    "id": "04a7ba72539a5cb1",
    "type": "json",
    "name": "V1",
    "property": "payload",
    "action": "",
    "pretty": false,
    "x": 450,
    "y": 200,
    "wires": [
    "35354018b6c6c095",
    "639599639f78788c"
    "id": "6f72cb37f4aa2278",
    "type": "debug",
    "name": "debug 1",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "targetType": "msg",
    "statusVal": "",
    "statusType": "auto",
    "x": 900,
    "y": 200,
    "wires": []
    "id": "35354018b6c6c095",
    "type": "debug",
    "name": "debug 2",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "statusVal": "",
    "x": 620,
    "y": 120,
    "wires": []
    "id": "639599639f78788c",
    "type": "change",
    "name": "",
    "rules": [
    "t": "set",
    "p": "payload",
    "pt": "msg",
    "to": "payload["SDM630"].Voltage_P1",
    "tot": "msg"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 670,
    "y": 200,
    "wires": [
    "6f72cb37f4aa2278",
    "b0fcb45d6d8ab9f4",
    "9faaac80e56b9d83"
    "id": "a5192d83b6ce2f1c",
    "type": "mqtt out",
    "name": "V1",
    "topic": "Testzähler",
    "qos": "",
    "retain": "",
    "respTopic": "",
    "contentType": "",
    "userProps": "",
    "correl": "",
    "expiry": "",
    "broker": "d19896c9b4e98e28",
    "x": 750,
    "y": 340,
    "wires": []
    "id": "df378652670347e0",
    "type": "function",
    "name": "function 2",
    "func": "\nreturn msg;payload["SDM630"].Voltage_P1",
    "outputs": 1,
    "noerr": 0,
    "initialize": "",
    "finalize": "",
    "libs": [],
    "x": 560,
    "y": 340,
    "wires": [
    "a5192d83b6ce2f1c"
    "id": "e7e1e2255e66e588",
    "type": "mqtt-broker",
    "name": "mqtt-broker",
    "broker": "192.168.1.146",
    "port": "1885",
    "clientid": "",
    "autoConnect": true,
    "usetls": false,
    "protocolVersion": "4",
    "keepalive": "60",
    "cleansession": true,
    "birthTopic": "",
    "birthQos": "0",
    "birthPayload": "",
    "birthMsg": {},
    "closeTopic": "",
    "closeQos": "0",
    "closePayload": "",
    "closeMsg": {},
    "willTopic": "",
    "willQos": "0",
    "willPayload": "",
    "willMsg": {},
    "userProps": "",
    "sessionExpiry": ""
    "id": "67140eec2a9994a9",
    "type": "ui_group",
    "name": "Test",
    "tab": "71f6d060a354b8d9",
    "order": 1,
    "disp": true,
    "width": "6",
    "collapse": false
    "id": "d19896c9b4e98e28",
    "name": "Venus OS",
    "broker": "192.168.1.37",
    "port": "1883",
    "clientid": "test-client",
    "usetls": false,
    "keepalive": "60",
    "birthTopic": "",
    "birthQos": "0",
    "birthPayload": "",
    "birthMsg": {},
    "closeTopic": "",
    "closeQos": "0",
    "closePayload": "",
    "closeMsg": {},
    "willTopic": "",
    "willQos": "0",
    "willPayload": "",
    "willMsg": {},
    "userProps": "",
    "sessionExpiry": ""
    "id": "71f6d060a354b8d9",
    "type": "ui_tab",
    "name": "Home",
    "icon": "dashboard",
    "disabled": false,
    "hidden": false
    Grüße André
    mickymM Offline
    mickymM Offline
    mickym
    @rieders Am besten ist es aus dem Debugfenster einfach den Pfad kopieren. Sprich du schaust, was aus debug2 rauskommt und kopierst den Pfad, des Wertes den Du anzeigen willst.
    Wenn ich also Dein Objekt nehme (Dein Flow lässt sich nicht importieren, da Du keine CodeTags verwendest) und möchte den Total Wert in der Text Node anzeigen, gehe ich mit dem Cursor dahin und kopieren den Pfad:
    Dann kommt folgendes raus:
    payload.SDM630.Total
    Das kannst Du nun direkt in der text node verwenden oder die payload verändern um es dann in einer gauge anzuzeigen.
    In der Text-Node:
    Mit der Change-Node:
    Hier mal mein Flow richtig exportiert in CodeTags:
           "id": "79cb540f2a41c739",
           "type": "inject",
           "z": "289f539dcc33814e",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "{\"Time\":\"2023-01-13T12:54:35\",\"SDM630\":{\"1\":178,\"Voltage_P1\":231.88,\"Voltage_P2\":231.5,\"Voltage_P3\":232.49,\"Current_P1\":0,\"Current_P2\":0.1,\"Current_P3\":0,\"Power_P1\":0,\"Power_P2\":22.35,\"Power_P3\":0,\"Frequenz\":50.01,\"Total\":534.694,\"phase_angle\":-9.73,\"Import_nres\":186.145,\"Export_nres\":348.549,\"Export_P1\":13.568,\"Export_P2\":334.981,\"Export_P3\":0,\"Import_P1\":19.409,\"Import_P2\":131.003,\"Import_P3\":35.733,\"L1_total_kwh\":32.977,\"L2_total_kwh\":465.984,\"L3_total_kwh\":35.733,\"Blindleistung_L1\":0,\"Blindleistung_L2\":-7.734,\"Blindleistung_L3\":0,\"Scheinleistung_L1\":0,\"Scheinleistung_L2\":22.627,\"Scheinleistung_L3\":0,\"VAh_since_last_reset\":565.815}}",
           "payloadType": "json",
           "x": 230,
           "y": 4260,
           "wires": [
                   "479307770498d089",
                   "7e8331652d9d7389",
                   "ae5bde5b22da03b0"
           "id": "479307770498d089",
           "type": "debug",
           "name": "Objekt",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 390,
           "y": 4260,
           "wires": []
           "id": "c9e73544e1bfa520",
           "type": "ui_gauge",
           "name": "",
           "group": "57f13d6f733e5c9d",
           "order": 2,
           "width": 0,
           "height": 0,
           "gtype": "gage",
           "title": "Total",
           "label": "units",
           "format": "{{value}}",
           "min": 0,
           "max": "1000",
           "colors": [
               "#00b500",
               "#e6e600",
               "#ca3838"
           "seg1": "",
           "seg2": "",
           "className": "",
           "x": 630,
           "y": 4340,
           "wires": []
           "id": "7e8331652d9d7389",
           "type": "ui_text",
           "order": 3,
           "width": 0,
           "height": 0,
           "name": "",
           "label": "Total",
           "format": "{{msg.payload.SDM630.Total}}",
           "layout": "row-spread",
           "className": "",
           "x": 390,
           "y": 4300,
           "wires": []
           "id": "ae5bde5b22da03b0",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.SDM630.Total",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 430,
           "y": 4340,
           "wires": [
                   "c9e73544e1bfa520",
                   "680cd23566aafb30"
           "id": "680cd23566aafb30",
           "type": "debug",
           "name": "Total",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 630,
           "y": 4380,
           "wires": []
           "id": "57f13d6f733e5c9d",
           "type": "ui_group",
           "name": "Test",
           "tab": "20b3095113f94d70",
           "order": 2,
           "disp": true,
           "width": "6",
           "collapse": false,
           "className": ""
           "id": "20b3095113f94d70",
           "type": "ui_tab",
           "name": "Home",
           "order": 1,
           "disabled": false,
           "hidden": false
    R 1 Antwort Letzte Antwort
    • mickymM mickym
      In der Text-Node:
             "type": "inject",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "x": 230,
             "y": 4260,
             "wires": [
                     "479307770498d089",
                     "7e8331652d9d7389",
                     "ae5bde5b22da03b0"
             "type": "debug",
             "name": "Objekt",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 390,
             "y": 4260,
             "wires": []
             "type": "ui_gauge",
             "name": "",
             "order": 2,
             "width": 0,
             "height": 0,
             "gtype": "gage",
             "title": "Total",
             "label": "units",
             "min": 0,
             "max": "1000",
             "colors": [
                 "#00b500",
                 "#e6e600",
                 "#ca3838"
             "seg1": "",
             "seg2": "",
             "className": "",
             "x": 630,
             "y": 4340,
             "wires": []
             "type": "ui_text",
             "order": 3,
             "width": 0,
             "height": 0,
             "name": "",
             "label": "Total",
             "className": "",
             "x": 390,
             "y": 4300,
             "wires": []
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 430,
             "y": 4340,
             "wires": [
                     "c9e73544e1bfa520",
                     "680cd23566aafb30"
             "type": "debug",
             "name": "Total",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 630,
             "y": 4380,
             "wires": []
             "type": "ui_group",
             "name": "Test",
             "order": 2,
             "disp": true,
             "width": "6",
             "collapse": false,
             "className": ""
             "type": "ui_tab",
             "name": "Home",
             "order": 1,
             "disabled": false,
             "hidden": false
      rieders
      schrieb am zuletzt editiert von rieders
      Vielen Dank für die Hilfe.
      Das Auslesen funktioniert super.
      Ich weiß nur nicht wie du aus dem debug2 den Pfad ausgelesen hast, bei mir sieht das ganz anders aus.
      Jetzt kann ich die Daten an Venus OS übergeben und hoffentlich als virtualen Zähler sehen.
      • R rieders
        mickymM Offline
        mickymM Offline
        mickym
        @rieders Hab ich gar nicht, da ich deinen Flow ja nicht importieren konnte (nicht in CodeTags), aber Du hast ja die Daten zum Glück bzw. das Objekt gepostet und so habe ich es einfach in die Inject Node geschrieben. Du kannst übrigens direkt in ein Objekt wandeln lassen, dann kannst du das direkt nach der mqtt-In Node machen, in dem Du Dir ein analysiertes Objekt ausgeben lässt.
        Dann brauchst nach der mqtt-In auch nichts mehr konvertieren.
        frankthegreatF 1 Antwort Letzte Antwort
        • mickymM mickym
          frankthegreatF Offline
          frankthegreat
          @mickym
          Sorry, das ich mich hier mit ranhänge. Mein Problem ist denk mal ähnlich.
          Ich möchte relatives Dimmen von KNX auf Zigbee umsetzen.
          Dazu müßte wohl auch der Payload zerlegt werden 🤔
          Hier die Ausgaben vom KNX.
          Taster ist gedrückt und soll runterdimmen:
          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":1},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[1]},"previouspayload":{"decr_incr":0,"data":0},"_msgid":"34735868e6770bd1"}
          Taster losgelassen, dimmen soll stoppen:
          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":0},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[0]},"previouspayload":{"decr_incr":0,"data":1},"_msgid":"a4982ca3e5461702"}
          Taster ist gedrückt und soll hochdimmen:
          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":1,"data":1},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[9]},"previouspayload":{"decr_incr":0,"data":0},"_msgid":"12ada754ecbda05f"}
          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":0},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[0]},"previouspayload":{"decr_incr":1,"data":1},"_msgid":"dabb632a5c74b60d"}
          Änderungen sehe ich hier jeweils bei :
          {"decr_incr":x,"data":x}
          Die Befehle für die Zigbee Leuchtmittel hab ich getestet, bei direktem schicken auf den DP funktionieren die schonmal.
          z.B.
          hochdimmen={"brightness_move": 40}
          runterdimmen={"brightness_move": -40}
          stoppen={"brightness_move": 0}
          Hab schon etliche Stunden mit der "Change" Node rumprobiert, allerdings ohne Erfolg 😞
          Wie muß ich vorgehen, um die KNX Befehle auf Zigbee umzusetzen?
          • mickymM Offline
            mickymM Offline
            mickym
            @frankthegreat Na ja - da ist noch etwas mehr Logik im Spiel und das muss man sich trotz aller Flows genau überlegen. Ich hab ja mal einen softdimmer ähnlich mit einem vis Widget erstellt.
            das mit dem hoch und runter Dimmen - kann man grundsätzlich mit mehreren Arten machen wahrscheinlich gibts den brightness Datenpunkt im Zigbee auch als absolute Werte. Move geht auch und vereinfacht das Ganze wohl eher.
            Im Prinzip, wenn es sich so darstellt, dann wäre
            data: 1 immer gedrückt = dimmen
            data: 0 immer losgelassen = stoppen
            decr_incr: 1 bei data 1 = hochdimmen
            decr_incr: 0 bei data 1 = runterdimmen.
            Da wir immer stoppen egal wie gerade gedimmt wurde, ist uns egal welchen Zustand das Teil vorher hatte. Auf dieser Basis probieren wird das mal - kleinen Moment. ;)
            So müsste das jetzt mal quick & dirty funktionieren:
            Statt der Inject Node halt Deine KNX Nodes dran machen und hinten halt in den brightness_move Datenpunkt ausgeben.
                   "id": "65b061e782f70ac9",
                   "type": "inject",
                   "z": "f71771fc316ba18f",
                   "name": "dim down",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"decr_incr\":0,\"data\":1}",
                   "x": 340,
                   "y": 140,
                   "wires": [
                           "240e3279819f0eae"
                   "id": "2e68f247a519c9b3",
                   "type": "inject",
                   "name": "stop",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"decr_incr\":0,\"data\":0}",
                   "x": 350,
                   "y": 220,
                   "wires": [
                           "240e3279819f0eae"
                   "id": "7efd5166901d779b",
                   "type": "inject",
                   "name": "dim up",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"decr_incr\":1,\"data\":1}",
                   "x": 350,
                   "y": 180,
                   "wires": [
                           "240e3279819f0eae"
                   "id": "240e3279819f0eae",
                   "type": "switch",
                   "name": "",
                   "property": "payload.data",
                   "propertyType": "msg",
                   "rules": [
                           "t": "eq",
                           "v": "0",
                           "vt": "num"
                           "t": "eq",
                           "v": "1",
                           "vt": "num"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 530,
                   "y": 180,
                   "wires": [
                           "2e23dae4976566fd"
                           "2e5b171c27e7e26a"
                   "id": "2e23dae4976566fd",
                   "type": "change",
                   "name": "stop dimming",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "0",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 830,
                   "y": 160,
                   "wires": [
                           "26db997e0e9ac3b2"
                   "id": "2e5b171c27e7e26a",
                   "type": "switch",
                   "name": "",
                   "property": "payload.decr_incr",
                   "rules": [
                           "t": "eq",
                           "v": "0",
                           "vt": "num"
                           "t": "eq",
                           "v": "1",
                           "vt": "num"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 2,
                   "x": 670,
                   "y": 220,
                   "wires": [
                           "75612c32dc30ca8a"
                           "28f8664528857291"
                   "outputLabels": [
                       "dim down",
                       "dim up"
                   "id": "75612c32dc30ca8a",
                   "type": "change",
                   "name": "dim down",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "-40",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 840,
                   "y": 200,
                   "wires": [
                           "26db997e0e9ac3b2"
                   "id": "28f8664528857291",
                   "type": "change",
                   "name": "dim up",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "40",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 850,
                   "y": 240,
                   "wires": [
                           "26db997e0e9ac3b2"
                   "id": "26db997e0e9ac3b2",
                   "type": "debug",
                   "name": "brightness move",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1040,
                   "y": 200,
                   "wires": []
            Das geht auch mit einer switch Node - nur dann muss man halt JSONATA verwenden und bei der ersten Übereinstimmung stoppen - dafür schaut der Flow übersichtlicher aus.
                   "id": "9c42920aa2d032db",
                   "type": "switch",
                   "name": "",
                   "rules": [
                           "t": "jsonata_exp",
                           "v": "payload.data = 0",
                           "vt": "jsonata"
                           "t": "jsonata_exp",
                           "v": "payload.decr_incr = 0",
                           "vt": "jsonata"
                           "t": "jsonata_exp",
                           "v": "payload.decr_incr = 1",
                           "vt": "jsonata"
                   "checkall": "false",
                   "repair": false,
                   "outputs": 3,
                   "x": 670,
                   "y": 380,
                   "wires": [
                           "9b040f37641b3023"
                           "af3bf63193955ef5"
                           "fa5c8b6c4663ba2f"
                   "id": "b20aff26a7c2e42c",
                   "type": "inject",
                   "name": "dim down",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 480,
                   "y": 340,
                   "wires": [
                           "9c42920aa2d032db"
                   "id": "00cc24ce0bd3bc46",
                   "type": "inject",
                   "name": "stop",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 490,
                   "y": 420,
                   "wires": [
                           "9c42920aa2d032db"
                   "id": "291666bfb387eb09",
                   "type": "inject",
                   "name": "dim up",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 490,
                   "y": 380,
                   "wires": [
                           "9c42920aa2d032db"
                   "id": "9b040f37641b3023",
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "0",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 830,
                   "y": 340,
                   "wires": [
                           "f3660815c7c7b3df"
                   "id": "af3bf63193955ef5",
                   "type": "change",
                   "name": "dim down",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "-40",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 840,
                   "y": 380,
                   "wires": [
                           "f3660815c7c7b3df"
                   "id": "fa5c8b6c4663ba2f",
                   "type": "change",
                   "name": "dim up",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "40",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 850,
                   "y": 420,
                   "wires": [
                           "f3660815c7c7b3df"
                   "id": "f3660815c7c7b3df",
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1040,
                   "y": 380,
                   "wires": []
            • mickymM mickym
                     "type": "inject",
                     "name": "dim down",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 340,
                     "y": 140,
                     "wires": [
                             "240e3279819f0eae"
                     "type": "inject",
                     "name": "stop",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 350,
                     "y": 220,
                     "wires": [
                             "240e3279819f0eae"
                     "type": "inject",
                     "name": "dim up",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 350,
                     "y": 180,
                     "wires": [
                             "240e3279819f0eae"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "eq",
                             "v": "0",
                             "vt": "num"
                             "t": "eq",
                             "v": "1",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 530,
                     "y": 180,
                     "wires": [
                             "2e23dae4976566fd"
                             "2e5b171c27e7e26a"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "0",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 160,
                     "wires": [
                             "26db997e0e9ac3b2"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "eq",
                             "v": "0",
                             "vt": "num"
                             "t": "eq",
                             "v": "1",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 670,
                     "y": 220,
                     "wires": [
                             "75612c32dc30ca8a"
                             "28f8664528857291"
                     "outputLabels": [
                         "dim down",
                         "dim up"
                     "type": "change",
                     "name": "dim down",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "-40",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 840,
                     "y": 200,
                     "wires": [
                             "26db997e0e9ac3b2"
                     "type": "change",
                     "name": "dim up",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "40",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 850,
                     "y": 240,
                     "wires": [
                             "26db997e0e9ac3b2"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1040,
                     "y": 200,
                     "wires": []
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "jsonata_exp",
                             "vt": "jsonata"
                             "t": "jsonata_exp",
                             "vt": "jsonata"
                             "t": "jsonata_exp",
                             "vt": "jsonata"
                     "repair": false,
                     "outputs": 3,
                     "x": 670,
                     "y": 380,
                     "wires": [
                             "9b040f37641b3023"
                             "af3bf63193955ef5"
                             "fa5c8b6c4663ba2f"
                     "type": "inject",
                     "name": "dim down",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 480,
                     "y": 340,
                     "wires": [
                             "9c42920aa2d032db"
                     "type": "inject",
                     "name": "stop",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 490,
                     "y": 420,
                     "wires": [
                             "9c42920aa2d032db"
                     "type": "inject",
                     "name": "dim up",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 490,
                     "y": 380,
                     "wires": [
                             "9c42920aa2d032db"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "0",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 340,
                     "wires": [
                             "f3660815c7c7b3df"
                     "type": "change",
                     "name": "dim down",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "-40",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 840,
                     "y": 380,
                     "wires": [
                             "f3660815c7c7b3df"
                     "type": "change",
                     "name": "dim up",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "40",
                             "tot": "num"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 850,
                     "y": 420,
                     "wires": [
                             "f3660815c7c7b3df"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1040,
                     "y": 380,
                     "wires": []
              frankthegreat
              @mickym
              Jepp...und läuft auf Anhieb 👏
              Supi, danke dir. Abend gerettet.
              Ich hatte hauptsächlich versucht in diesen DP zu schreiben. Da hatt's aber mit der Umwandlung nicht geklappt.
              Aber so geht's natürlich auch.
              Nochmal DANKE 👍
              • R rieders
                Hallo
                "type": "mqtt in",
                "qos": "2",
                "nl": false,
                "rap": true,
                "rh": "2",
                "inputs": 0,
                "x": 180,
                "y": 260,
                "wires": [
                "04a7ba72539a5cb1",
                "df378652670347e0"
                "type": "ui_gauge",
                "name": "Test",
                "order": 0,
                "width": 0,
                "height": 0,
                "gtype": "gage",
                "label": "",
                "min": "1",
                "max": "260",
                "colors": [
                "#b30000",
                "#e6e600",
                "#00b815"
                "seg1": "",
                "seg2": "",
                "x": 890,
                "y": 260,
                "wires": []
                "type": "ui_chart",
                "name": "",
                "order": 0,
                "width": 0,
                "height": 0,
                "label": "chart",
                "legend": "false",
                "nodata": "",
                "dot": false,
                "ymin": "0",
                "ymax": "260",
                "removeOlder": 1,
                "cutout": 0,
                "useUTC": false,
                "colors": [
                "#1f77b4",
                "#aec7e8",
                "#ff7f0e",
                "#2ca02c",
                "#98df8a",
                "#d62728",
                "#ff9896",
                "#9467bd",
                "#c5b0d5"
                "outputs": 1,
                "x": 890,
                "y": 320,
                "wires": [
                "type": "json",
                "name": "V1",
                "action": "",
                "pretty": false,
                "x": 450,
                "y": 200,
                "wires": [
                "35354018b6c6c095",
                "639599639f78788c"
                "type": "debug",
                "name": "debug 1",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 900,
                "y": 200,
                "wires": []
                "type": "debug",
                "name": "debug 2",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 620,
                "y": 120,
                "wires": []
                "type": "change",
                "name": "",
                "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 670,
                "y": 200,
                "wires": [
                "6f72cb37f4aa2278",
                "b0fcb45d6d8ab9f4",
                "9faaac80e56b9d83"
                "type": "mqtt out",
                "name": "V1",
                "qos": "",
                "retain": "",
                "respTopic": "",
                "contentType": "",
                "userProps": "",
                "correl": "",
                "expiry": "",
                "x": 750,
                "y": 340,
                "wires": []
                "type": "function",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 560,
                "y": 340,
                "wires": [
                "a5192d83b6ce2f1c"
                "port": "1885",
                "clientid": "",
                "usetls": false,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
                "type": "ui_group",
                "name": "Test",
                "order": 1,
                "disp": true,
                "width": "6",
                "collapse": false
                "name": "Venus OS",
                "port": "1883",
                "usetls": false,
                "keepalive": "60",
                "birthTopic": "",
                "birthQos": "0",
                "birthPayload": "",
                "birthMsg": {},
                "closeTopic": "",
                "closeQos": "0",
                "closePayload": "",
                "closeMsg": {},
                "willTopic": "",
                "willQos": "0",
                "willPayload": "",
                "willMsg": {},
                "userProps": "",
                "sessionExpiry": ""
                "type": "ui_tab",
                "name": "Home",
                "disabled": false,
                "hidden": false
                Grüße André
                1 Offline
                1 Offline
                1984chris
                @rieders @rieders Hallo Ich habe das gleiche Problem wie du
                ![0_1684256284880_ausgabe.jpg](Uploading 100%)
                konntest du das wie in Debug2 darstellen?
                DANKE im Voraus
                LG Christoph
                1 1 Antwort Letzte Antwort
                • 1 1984chris
                  DANKE im Voraus
                  LG Christoph
                  1 Offline
                  1 Offline
                  1984chris
                  1 mickymM 2 Antworten Letzte Antwort
                  • 1 1984chris
                    1 Offline
                    1 Offline
                    1984chris
                    @1984chris ich will die einzelnen Werte L1,L2,L3 Ströme A_L1,A_l2 usw an die influxDB übertragen
                    • 1 1984chris
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @1984chris Wenn ich Dir helfen soll, dann solltest Du den Wert in die Zwischenablage kopieren und hier in Codetags einbetten.
                      Dann woher hast Du das - kommt das aus einer iobroker IN Node oder aus einer mqtt Node?
                      Willst Du alle Werte in einzelne Datenpunkte zerlegen oder nur einzelne Werte extrahieren und weiter verarbeiten?
                      Einzelne Werte kopierst Du in die Zwischenablage in dem Du mit der Maul im Debug Fenster neben den Wert fährst.
                      Wenn Du es in der Zwischenablage hast, dann kopierst Du es bitte in Code-Tags wie hier dargestellt:
                      Und wie gesagt - wer es nett, wenn Du ein paar Zeilen dazu schreiben möchtest, was Du möchtest
                      • 1 1984chris
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @1984chris sagte in Payload String zerlegen:
                        Dann wäre es wohl sinnvoll einzelne Werte zu erstellen, dann empfehle ich Dir meinen Flow - der den ganzen JSON in einzelne Datenpunkte schreibt:
                        https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
                        Dann brauchst Du nur diesen Flow zu importieren.
                        Im 1. Post ist eigentlich alles beschrieben und welche Einstellungen Du machen willst. Falls Du noch Fragen hast, dann gerne. Also hängt davon ab, ob Du nur ein paar Werte haben willst oder alle Werte einzeln haben möchtest.
                        • mickymM mickym
                          1 Offline
                          1 Offline
                          1984chris
                          @mickym ```
                          {"Time":"2023-05-16T19:45:29","Tagstrom":{"V_L1":233,"V_L3":236,"V_L3":236,"A_L1":0.63,"A_L2":2.33,"A_L3":0.32,"W_IN":590,"W_OUT":0,"kWh_total_IN":19147.756,"kWh_total_OUT":776.383},"WäPu":{"V_L1":232,"V_L3":236,"V_L3":235,"A_L1":0.48,"A_L2":0.00,"A_L3":0.02,"W_IN":112,"W_OUT":0,"kWh_total_IN":21698.535,"kWh_total_OUT":0.000}}
                          die Daten kommen von einenm Nodred in mqtt ich bekomme das auf der Debugseite nicht so angezeigt wie du im Beispiel. Will die einzelnen Werte dan in eine influxDB und weiter mit GRAFANA....
                          • 1 1984chris
                            @mickym ```
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @1984chris Wie gesagt wenn Du alle Werte haben willst, hast Du meinen Flow importiert und das Erstellen von Objekten zugelassen?
                            • 1 1984chris
                              @mickym ```
                              mickymM Offline
                              mickymM Offline
                              mickym
                              In dem Tagstrom ist ein komisches Zeichen - hast Du den String über Wert kopieren reinkopiert oder mit der Maus?
                                  "Time": "2023-05-16T19:45:29",
                                  "Tagstrom": {
                                      "V_L1": 233,
                                      "V_L3": 236,
                                      "A_L1": 0.63,
                                      "A_L2": 2.33,
                                      "A_L3": 0.32,
                                      "W_IN": 590,
                                      "W_OUT": 0,
                                      "kWh_total_IN": 19147.756,
                                      "kWh_total_OUT": 776.383
                                  "WäPu": {
                                      "V_L1": 232,
                                      "V_L3": 235,
                                      "A_L1": 0.48,
                                      "A_L2": 0,
                                      "A_L3": 0.02,
                                      "W_IN": 112,
                                      "W_OUT": 0,
                                      "kWh_total_IN": 21698.535,
                                      "kWh_total_OUT": 0
                              So funktioniert es.
                              • mickymM mickym
                                    "Tagstrom": {
                                        "V_L1": 233,
                                        "V_L3": 236,
                                        "A_L1": 0.63,
                                        "A_L2": 2.33,
                                        "A_L3": 0.32,
                                        "W_IN": 590,
                                        "W_OUT": 0,
                                    "WäPu": {
                                        "V_L1": 232,
                                        "V_L3": 235,
                                        "A_L1": 0.48,
                                        "A_L2": 0,
                                        "A_L3": 0.02,
                                        "W_IN": 112,
                                        "W_OUT": 0,
                                        "kWh_total_OUT": 0
                                So funktioniert es.
                                1 Offline
                                1 Offline
                                1984chris
                                @mickym
                                Mit der Maus, wenn ich über Wert kopieren reinkopiere kommt
                                [123,34,84,105,109,101,34,58,34,50,48,50,51,45,48,53,45,49,54,84,49,57,58,52,53,58,50,57,34,44,34,84,97,103,115,116,114,111,109,1,34,58,123,34,86,95,76,49,34,58,50,51,51,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,54,44,34,65,95,76,49,34,58,48,46,54,51,44,34,65,95,76,50,34,58,50,46,51,51,44,34,65,95,76,51,34,58,48,46,51,50,44,34,87,95,73,78,34,58,53,57,48,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,49,57,49,52,55,46,55,53,54,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,55,55,54,46,51,56,51,125,44,34,87,195,164,80,117,34,58,123,34,86,95,76,49,34,58,50,51,50,44,34,86,95,76,51,34,58,50,51,54,44,34,86,95,76,51,34,58,50,51,53,44,34,65,95,76,49,34,58,48,46,52,56,44,34,65,95,76,50,34,58,48,46,48,48,44,34,65,95,76,51,34,58,48,46,48,50,44,34,87,95,73,78,34,58,49,49,50,44,34,87,95,79,85,84,34,58,48,44,34,107,87,104,95,116,111,116,97,108,95,73,78,34,58,50,49,54,57,56,46,53,51,53,44,34,107,87,104,95,116,111,116,97,108,95,79,85,84,34,58,48,46,48,48,48,125,125]
                                • 1 1984chris
                                  @mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @1984chris Na OK - ich weiss nicht was Du da genau gemacht hast.
                                  Wie gesagt wenn Du meinen Flow importierst - habe ich gerade gemacht - dann erhälst Du folgende Struktur
                                  Wenn Du mein Flow hast - dann brauchst Du nur die neue Node und eine iobroker-Out Node:
                                  wie gesagt die Fremdobjekte erstellen zulassen und in der Node angeben unter welchem Datenpunkt die Datenpunkte angelegt werden sollen:
                                  Hier zum Import:
                                         "id": "6e802f1553b18149",
                                         "type": "subflow",
                                         "name": "JSON or Obj to IOBroker",
                                         "info": "# Creates an IOBroker tree\n\nThis node creates an IOBroker tree out of an Java-Object or JSON String.\n\nThe object tree will be created under 0_userdata.0\nIn addition to the JSON-String or Java Object as `msg.payload` it is necessary to specify a `msg.top` properity in addition to the msg-Object.\n\nThe object tree will be created under 0_userdata.0\n\nExisting `msg.topic` entries will be deleted.\nAn iobroker-out node has to be appended to this subflow node. It is not part of the subflow itself. No topic should be specified in the iobroker out node.\n\nIs `msg.top` property isn't defined, the `top` property of the subflow-node is used. \n\nIn the properties of the subflow node a new property `keepTopic` has been added. Default is _false_ to keep the current behaviour. If set to _true_ then the originial topic will be placed between the `top` property of the subflow node and the property of the analyzed JSON object.\n\n**Attention:**\nIf msg.top and top is empty, all msg.topics (msg.topic) will be directly prefixed with 0_userdata.0. . \n\n**Update 13.09.2022:**\nSpaces in topics of objects are no longer replaced with underscores in objects. No differences between all data types.\n\n# Erstellt einen Objektbaum im ioBroker\n\nDiese Node erstellt einen Objektbaum im ioBroker aus einem JAVA Objekt bzw. einem JSON String. \n\nDer Baum wird in jedem Fall unter 0_userdata.0 erstellt und zwar unter dem Topic der in` msg.top` mitgegeben wurde. In der `msg.payload` befindet sich dann der JSON String oder das entsprechende Objekt.\n\nExistierende `msg.topic `Einträge werden gelöscht.\nEin entsprechende iobroker-out Node muss an den Flow angehängt werden. Sie ist nicht Bestandteil des Subflows. In dieser iobroker-out Node darf kein Topic angegeben werden. \n\nFalls msg.top nicht definiert wurde, wird der `top`-Wert der Subflow-Node verwendet.\n\nIn den Eigenschaften der Subflow-Node wurde ein neuer Parameter `keepTopic` hinzugefügt. Standardwert ist _false_, um das bisherige Verhalten beizubehalten. Setzt man die Eigenschaft auf _true_, dann wird das originale Topic zwischen der `top` Eigenschaft der Subflow-Node und Eigenschaft des analysierten JSON Objektes eingefügt.\n\n**Achtung:**\nWenn top und msg.top leer ist, werden alle msg.topics (msg.topic) direkt unter dem Präfix 0_userdata.0., angelegt bzw. ausgegeben. \n\n**Update 13.09.2022:**\nLeerzeichen werden in Topics von Objekten nicht mehr durch Unterstriche ersetzt. Es gibt keine Unterschiede mehr zwischen den Datentypen.",
                                         "category": "",
                                         "in": [
                                                 "x": 60,
                                                 "y": 160,
                                                 "wires": [
                                                         "id": "554b8c663bcb46c2"
                                         "out": [
                                                 "x": 2620,
                                                 "y": 280,
                                                 "wires": [
                                                         "id": "0962842ebd23e0d7",
                                                         "port": 0
                                         "env": [
                                                 "name": "top",
                                                 "type": "str",
                                                 "value": "objRoot"
                                                 "name": "keepTopic",
                                                 "type": "bool",
                                                 "value": "false"
                                         "meta": {},
                                         "color": "#E2D96E",
                                         "icon": "node-red/batch.svg"
                                         "id": "3e11e8338f694832",
                                         "type": "split",
                                         "z": "6e802f1553b18149",
                                         "name": "split object",
                                         "splt": "\\n",
                                         "spltType": "str",
                                         "arraySplt": 1,
                                         "arraySpltType": "len",
                                         "stream": false,
                                         "addname": "key",
                                         "x": 1370,
                                         "y": 160,
                                         "wires": [
                                                 "0562a4249c8b856b"
                                         "id": "0562a4249c8b856b",
                                         "type": "change",
                                         "name": "add key to topic",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "stateName",
                                                 "pt": "msg",
                                                 "to": "key",
                                                 "tot": "msg"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "topic  & '.' & key",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 1560,
                                         "y": 160,
                                         "wires": [
                                                 "ddc90985bef0fafa"
                                         "id": "ddc90985bef0fafa",
                                         "type": "switch",
                                         "name": "is type?",
                                         "rules": [
                                                 "t": "istype",
                                                 "v": "array",
                                                 "vt": "array"
                                                 "t": "istype",
                                                 "v": "object",
                                                 "vt": "object"
                                                 "t": "else"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 3,
                                         "x": 1740,
                                         "y": 160,
                                         "wires": [
                                                 "bfce19b206660fbe"
                                                 "3e11e8338f694832"
                                                 "1a8c03d866b85b12"
                                         "id": "bfce19b206660fbe",
                                         "type": "split",
                                         "name": "split array",
                                         "splt": "\\n",
                                         "spltType": "str",
                                         "arraySplt": 1,
                                         "stream": false,
                                         "addname": "",
                                         "x": 780,
                                         "y": 280,
                                         "wires": [
                                                 "e89927810c6d75ec"
                                         "id": "e89927810c6d75ec",
                                         "type": "change",
                                         "name": "add index to topic",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "topic  & '.' & parts.index",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 970,
                                         "y": 280,
                                         "wires": [
                                                 "a4d1a5d04564dc77"
                                         "id": "f5d52c6a57d08904",
                                         "type": "change",
                                         "name": "finalize msg.topic",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "top",
                                                 "pt": "msg",
                                                 "to": "'0_userdata.0.' & top",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "top & '.' & topic",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2170,
                                         "y": 240,
                                         "wires": [
                                                 "0962842ebd23e0d7"
                                         "id": "1a8c03d866b85b12",
                                         "type": "switch",
                                         "name": "is msg.top != null",
                                         "property": "top",
                                         "rules": [
                                                 "t": "nnull"
                                                 "t": "null"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 2,
                                         "x": 1950,
                                         "y": 280,
                                         "wires": [
                                                 "f5d52c6a57d08904"
                                                 "74c895ce724750de"
                                         "id": "e023fe88445ce43e",
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "delete",
                                                 "p": "topic",
                                                 "pt": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 350,
                                         "y": 200,
                                         "wires": [
                                                 "3649300b4c233b10"
                                         "id": "3649300b4c233b10",
                                         "type": "switch",
                                         "name": "is type?",
                                         "rules": [
                                                 "t": "istype",
                                                 "v": "json",
                                                 "vt": "json"
                                                 "t": "istype",
                                                 "v": "array",
                                                 "vt": "array"
                                                 "t": "istype",
                                                 "v": "object",
                                                 "vt": "object"
                                                 "t": "else"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 4,
                                         "x": 600,
                                         "y": 160,
                                         "wires": [
                                                 "fc7913a8524badb7"
                                                 "bfce19b206660fbe"
                                                 "3e11e8338f694832"
                                                 "9ac3cc3681e8b6c6"
                                         "id": "1b8480cd2df7ba3f",
                                         "type": "comment",
                                         "name": "Array",
                                         "info": "",
                                         "x": 600,
                                         "y": 280,
                                         "wires": []
                                         "id": "b3541807672be040",
                                         "type": "comment",
                                         "name": "object",
                                         "info": "",
                                         "x": 1340,
                                         "y": 100,
                                         "wires": []
                                         "id": "a4d1a5d04564dc77",
                                         "type": "switch",
                                         "name": "is type?",
                                         "rules": [
                                                 "t": "istype",
                                                 "v": "object",
                                                 "vt": "object"
                                                 "t": "istype",
                                                 "v": "array",
                                                 "vt": "array"
                                                 "t": "else"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 3,
                                         "x": 1160,
                                         "y": 280,
                                         "wires": [
                                                 "3e11e8338f694832"
                                                 "bfce19b206660fbe"
                                                 "a096a93bb82b7a93"
                                         "id": "74c895ce724750de",
                                         "type": "change",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "top",
                                                 "pt": "msg",
                                                 "to": "top",
                                                 "tot": "env"
                                                 "t": "set",
                                                 "p": "top",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2170,
                                         "y": 320,
                                         "wires": [
                                                 "0962842ebd23e0d7"
                                         "id": "554b8c663bcb46c2",
                                         "type": "switch",
                                         "name": "",
                                         "property": "keepTopic",
                                         "propertyType": "env",
                                         "rules": [
                                                 "t": "true"
                                                 "t": "false"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 2,
                                         "x": 170,
                                         "y": 160,
                                         "wires": [
                                                 "e30ba9f0483285e4"
                                                 "e023fe88445ce43e"
                                         "id": "e30ba9f0483285e4",
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "change",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "from": "/",
                                                 "fromt": "str",
                                                 "to": ".",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 350,
                                         "y": 120,
                                         "wires": [
                                                 "3649300b4c233b10"
                                         "type": "change",
                                         "name": "translate invalid chars in topic",
                                         "rules": [
                                                 "t": "change",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "from": "..",
                                                 "fromt": "str",
                                                 "to": ".",
                                                 "tot": "str"
                                                 "t": "change",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "from": "€",
                                                 "fromt": "str",
                                                 "to": "EUR",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2430,
                                         "y": 280,
                                         "wires": [
                                         "id": "9ac3cc3681e8b6c6",
                                         "type": "change",
                                         "name": "set topic, if empty",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "topic ? topic : $type(payload)\t",
                                                 "tot": "jsonata"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 950,
                                         "y": 200,
                                         "wires": [
                                                 "a096a93bb82b7a93"
                                         "id": "fc7913a8524badb7",
                                         "type": "json",
                                         "name": "",
                                         "action": "obj",
                                         "pretty": false,
                                         "x": 750,
                                         "y": 100,
                                         "wires": [
                                                 "d9e7bdd4c48a8aa1"
                                         "id": "d9e7bdd4c48a8aa1",
                                         "type": "switch",
                                         "name": "is type?",
                                         "rules": [
                                                 "t": "istype",
                                                 "v": "array",
                                                 "vt": "array"
                                                 "t": "istype",
                                                 "v": "object",
                                                 "vt": "object"
                                                 "t": "else"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 3,
                                         "x": 900,
                                         "y": 100,
                                         "wires": [
                                                 "1520be42bcc2145e"
                                                 "1520be42bcc2145e"
                                                 "9ac3cc3681e8b6c6"
                                         "id": "a096a93bb82b7a93",
                                         "type": "junction",
                                         "x": 1380,
                                         "y": 280,
                                         "wires": [
                                                 "1a8c03d866b85b12"
                                         "id": "1520be42bcc2145e",
                                         "type": "junction",
                                         "x": 480,
                                         "y": 20,
                                         "wires": [
                                                 "3649300b4c233b10"
                                         "id": "ef7643b826aed308",
                                         "type": "subflow:6e802f1553b18149",
                                         "z": "1983aa28392732ca",
                                         "name": "",
                                         "env": [
                                                 "name": "top",
                                                 "value": "Sensor_903788",
                                                 "type": "str"
                                         "x": 550,
                                         "y": 2960,
                                         "wires": [
                                                 "2b9df08b75d20726"
                                         "id": "2b9df08b75d20726",
                                         "type": "ioBroker out",
                                         "name": "",
                                         "topic": "",
                                         "ack": "true",
                                         "autoCreate": "true",
                                         "stateName": "",
                                         "role": "",
                                         "payloadType": "",
                                         "readonly": "true",
                                         "stateUnit": "",
                                         "stateMin": "",
                                         "stateMax": "",
                                         "x": 780,
                                         "y": 2960,
                                         "wires": []
                                  In der NodeRed Adapter konfig schauen, dass Fremdobjekte erstellt werden dürfen und die Konvertierung ausgeschaltet ist.
                                  • mickymM mickym
                                    Hier zum Import:
                                           "type": "subflow",
                                           "category": "",
                                           "in": [
                                                   "x": 60,
                                                   "y": 160,
                                                   "wires": [
                                           "out": [
                                                   "x": 2620,
                                                   "y": 280,
                                                   "wires": [
                                                           "port": 0
                                           "env": [
                                                   "name": "top",
                                                   "type": "str",
                                                   "value": "objRoot"
                                                   "type": "bool",
                                                   "value": "false"
                                           "meta": {},
                                           "color": "#E2D96E",
                                           "type": "split",
                                           "splt": "\\n",
                                           "spltType": "str",
                                           "arraySplt": 1,
                                           "stream": false,
                                           "addname": "key",
                                           "x": 1370,
                                           "y": 160,
                                           "wires": [
                                                   "0562a4249c8b856b"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "stateName",
                                                   "pt": "msg",
                                                   "to": "key",
                                                   "tot": "msg"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1560,
                                           "y": 160,
                                           "wires": [
                                                   "ddc90985bef0fafa"
                                           "type": "switch",
                                           "name": "is type?",
                                           "rules": [
                                                   "t": "istype",
                                                   "v": "array",
                                                   "vt": "array"
                                                   "t": "istype",
                                                   "v": "object",
                                                   "vt": "object"
                                                   "t": "else"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 3,
                                           "x": 1740,
                                           "y": 160,
                                           "wires": [
                                                   "bfce19b206660fbe"
                                                   "3e11e8338f694832"
                                                   "1a8c03d866b85b12"
                                           "type": "split",
                                           "splt": "\\n",
                                           "spltType": "str",
                                           "arraySplt": 1,
                                           "stream": false,
                                           "addname": "",
                                           "x": 780,
                                           "y": 280,
                                           "wires": [
                                                   "e89927810c6d75ec"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 970,
                                           "y": 280,
                                           "wires": [
                                                   "a4d1a5d04564dc77"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "top",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2170,
                                           "y": 240,
                                           "wires": [
                                                   "0962842ebd23e0d7"
                                           "type": "switch",
                                           "property": "top",
                                           "rules": [
                                                   "t": "nnull"
                                                   "t": "null"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 2,
                                           "x": 1950,
                                           "y": 280,
                                           "wires": [
                                                   "f5d52c6a57d08904"
                                                   "74c895ce724750de"
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "delete",
                                                   "p": "topic",
                                                   "pt": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 350,
                                           "y": 200,
                                           "wires": [
                                                   "3649300b4c233b10"
                                           "type": "switch",
                                           "name": "is type?",
                                           "rules": [
                                                   "t": "istype",
                                                   "v": "json",
                                                   "vt": "json"
                                                   "t": "istype",
                                                   "v": "array",
                                                   "vt": "array"
                                                   "t": "istype",
                                                   "v": "object",
                                                   "vt": "object"
                                                   "t": "else"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 4,
                                           "x": 600,
                                           "y": 160,
                                           "wires": [
                                                   "fc7913a8524badb7"
                                                   "bfce19b206660fbe"
                                                   "3e11e8338f694832"
                                                   "9ac3cc3681e8b6c6"
                                           "type": "comment",
                                           "name": "Array",
                                           "info": "",
                                           "x": 600,
                                           "y": 280,
                                           "wires": []
                                           "type": "comment",
                                           "name": "object",
                                           "info": "",
                                           "x": 1340,
                                           "y": 100,
                                           "wires": []
                                           "type": "switch",
                                           "name": "is type?",
                                           "rules": [
                                                   "t": "istype",
                                                   "v": "object",
                                                   "vt": "object"
                                                   "t": "istype",
                                                   "v": "array",
                                                   "vt": "array"
                                                   "t": "else"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 3,
                                           "x": 1160,
                                           "y": 280,
                                           "wires": [
                                                   "3e11e8338f694832"
                                                   "bfce19b206660fbe"
                                                   "a096a93bb82b7a93"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "top",
                                                   "pt": "msg",
                                                   "to": "top",
                                                   "tot": "env"
                                                   "t": "set",
                                                   "p": "top",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2170,
                                           "y": 320,
                                           "wires": [
                                                   "0962842ebd23e0d7"
                                           "type": "switch",
                                           "name": "",
                                           "rules": [
                                                   "t": "true"
                                                   "t": "false"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 2,
                                           "x": 170,
                                           "y": 160,
                                           "wires": [
                                                   "e30ba9f0483285e4"
                                                   "e023fe88445ce43e"
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "from": "/",
                                                   "fromt": "str",
                                                   "to": ".",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 350,
                                           "y": 120,
                                           "wires": [
                                                   "3649300b4c233b10"
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "from": "..",
                                                   "fromt": "str",
                                                   "to": ".",
                                                   "tot": "str"
                                                   "t": "change",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "from": "€",
                                                   "fromt": "str",
                                                   "to": "EUR",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2430,
                                           "y": 280,
                                           "wires": [
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 950,
                                           "y": 200,
                                           "wires": [
                                                   "a096a93bb82b7a93"
                                           "type": "json",
                                           "name": "",
                                           "action": "obj",
                                           "pretty": false,
                                           "x": 750,
                                           "y": 100,
                                           "wires": [
                                                   "d9e7bdd4c48a8aa1"
                                           "type": "switch",
                                           "name": "is type?",
                                           "rules": [
                                                   "t": "istype",
                                                   "v": "array",
                                                   "vt": "array"
                                                   "t": "istype",
                                                   "v": "object",
                                                   "vt": "object"
                                                   "t": "else"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 3,
                                           "x": 900,
                                           "y": 100,
                                           "wires": [
                                                   "1520be42bcc2145e"
                                                   "1520be42bcc2145e"
                                                   "9ac3cc3681e8b6c6"
                                           "type": "junction",
                                           "x": 1380,
                                           "y": 280,
                                           "wires": [
                                                   "1a8c03d866b85b12"
                                           "type": "junction",
                                           "x": 480,
                                           "y": 20,
                                           "wires": [
                                                   "3649300b4c233b10"
                                           "name": "",
                                           "env": [
                                                   "name": "top",
                                                   "type": "str"
                                           "x": 550,
                                           "y": 2960,
                                           "wires": [
                                                   "2b9df08b75d20726"
                                           "name": "",
                                           "topic": "",
                                           "ack": "true",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "true",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 780,
                                           "y": 2960,
                                           "wires": []
                                    1 Offline
                                    1 Offline
                                    1984chris
                                    @mickym
                                    Bin blutiger Anfänger in NodeRed und habe keine Programierkenntnisse,hab mir gedacht das geht so einfach.
                                    • 1 1984chris
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @1984chris Geht dich auch einfach. Also Schritt für Schritt:
                                      1. Hast Du die Einstellungen in der Adapterkonfiguration gemacht?
                                      2. Weißt Du wie man einen Flow importiert?
                                      • mickymM mickym
                                        1 Offline
                                        1 Offline
                                        1984chris
                                        @mickym
                                        Ich habe noch kein iobrocker.
                                        habe via Docker MQTT NODERED InfluxDB und GRAFANA laufen
                                        • 1 1984chris
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @1984chris Ah OK - gut das ändert natürlich einiges. ;)
                                          Gut kannst Du mal einen Screenshot von Deinem Flow machen und dann stelle bitte in deinen mqtt-Nodes ein, dass das Objekt komplett analysiert werden soll.
                                          Dann solltest du nun in dem Debug Fenster keinen String sondern ein Objekt bekommen. Wenn Du das hast - dann mach da mal ein Screenshot von Deinem Debug Fenster.
                                          Welche Influx DB Version nutzt Du denn?
