  4. Node-Red
  5. Payload String zerlegen
    6.4k
77 Beiträge 7 Kommentatoren 19.6k Aufrufe 7 Beobachtet
  • mickymM mickym
    @66er Du kannst auch jedes Switch Objekt nur auf die Objektebene herauslösen und dann die Eigenschaften eines Switches in einem 2. Schritt bearbeiten. Deiner Fantasie sind keine Grenzen gesetzt:
           "id": "f86a9994.9674a8",
           "type": "inject",
           "z": "169f5b00.a13415",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "{\"ble\":{},\"cloud\":{\"connected\":false},\"eth\":{\"ip\":null},\"input:0\":{\"id\":0,\"state\":false},\"input:1\":{\"id\":1,\"state\":false},\"input:2\":{\"id\":2,\"state\":false},\"input:3\":{\"id\":3,\"state\":false},\"mqtt\":{\"connected\":true},\"switch:0\":{\"id\": 0, \"source\": \"UI\", \"output\": false, \"apower\": 0.000, \"voltage\": 237.237,\"aenergy\": {\"total\":0.021,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:1\":{\"id\": 1, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 237.292,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:2\":{\"id\": 2, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 238.268,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:3\":{\"id\": 3, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 238.230,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241651},\"temperature\":{\"tC\":null, \"tF\":null}},\"sys\":{\"mac\":\"95CCA87E43AC\",\"restart_required\":false,\"time\":\"08:14\",\"unixtime\":1633241653,\"uptime\":741,\"ram_size\":236340,\"ram_free\":147172,\"fs_size\":474641,\"fs_free\":317515,\"available_updates\":{\"beta\":{\"version\":\"0.9.0-beta1\"}}},\"wifi\":{\"sta_ip\":\"192.168.1.182\",\"status\":\"got ip\",\"ssid\":\"IoT\",\"rssi\":-58}}",
           "payloadType": "str",
           "x": 330,
           "y": 1320,
           "wires": [
                   "6cd75bd9.78f334"
           "id": "6cd75bd9.78f334",
           "type": "json",
           "name": "",
           "property": "payload",
           "action": "",
           "pretty": false,
           "x": 500,
           "y": 1320,
           "wires": [
                   "d59ab49f.83adb8",
                   "e409ee82.60264",
                   "7e3fb303.82128c",
                   "efc2f40c.3bb7f8",
                   "b65c559e.7ae848"
           "id": "efc2f40c.3bb7f8",
           "type": "change",
           "name": "switch3",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload[\"switch:3\"]",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 700,
           "y": 1480,
           "wires": [
                   "666be515.af213c",
                   "9b305a05.dd89e8"
           "id": "7e3fb303.82128c",
           "type": "change",
           "name": "switch2",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload[\"switch:2\"]",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 700,
           "y": 1400,
           "wires": [
                   "1306fb28.2e72e5",
                   "ffe7aeed.e875e"
           "id": "e409ee82.60264",
           "type": "change",
           "name": "switch1",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload[\"switch:1\"]",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 700,
           "y": 1320,
           "wires": [
                   "1ab33829.4b2438",
                   "9a153f8f.51f3a"
           "id": "d59ab49f.83adb8",
           "type": "change",
           "name": "switch0",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload[\"switch:0\"]",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 700,
           "y": 1240,
           "wires": [
                   "10fa2b5a.1d3fd5",
                   "d9d71e77.faca5"
           "id": "b65c559e.7ae848",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "true",
           "targetType": "full",
           "statusVal": "",
           "statusType": "auto",
           "x": 480,
           "y": 1400,
           "wires": []
           "id": "10fa2b5a.1d3fd5",
           "type": "change",
           "name": "output",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.output",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1220,
           "wires": [
                   "21f577ba.3b76c8"
           "id": "d9d71e77.faca5",
           "type": "change",
           "name": "energy",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.aenergy.total",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1260,
           "wires": [
                   "f8d0d07f.86fff"
           "id": "1ab33829.4b2438",
           "type": "change",
           "name": "output",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1300,
           "wires": [
                   "d763e07f.5c467"
           "id": "9a153f8f.51f3a",
           "type": "change",
           "name": "energy",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1340,
           "wires": [
                   "ae57bd4a.003a3"
           "id": "1306fb28.2e72e5",
           "type": "change",
           "name": "output",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1380,
           "wires": [
                   "63096a35.170df4"
           "id": "ffe7aeed.e875e",
           "type": "change",
           "name": "energy",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1420,
           "wires": [
                   "678ced56.3d2c44"
           "id": "666be515.af213c",
           "type": "change",
           "name": "output",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1460,
           "wires": [
                   "85150103.9bf37"
           "id": "9b305a05.dd89e8",
           "type": "change",
           "name": "energy",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 890,
           "y": 1500,
           "wires": [
                   "5dfb6b7f.67f114"
           "id": "21f577ba.3b76c8",
           "type": "debug",
           "name": "switch 0 output",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "x": 1080,
           "y": 1220,
           "wires": []
           "id": "f8d0d07f.86fff",
           "type": "debug",
           "name": "switch 0 energy",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1260,
           "wires": []
           "id": "d763e07f.5c467",
           "type": "debug",
           "name": "switch 1 output",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1300,
           "wires": []
           "id": "ae57bd4a.003a3",
           "type": "debug",
           "name": "switch 1 energy",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1340,
           "wires": []
           "id": "63096a35.170df4",
           "type": "debug",
           "name": "switch 2 output",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1380,
           "wires": []
           "id": "678ced56.3d2c44",
           "type": "debug",
           "name": "switch 2 energy",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1420,
           "wires": []
           "id": "85150103.9bf37",
           "type": "debug",
           "name": "switch 3 output",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1460,
           "wires": []
           "id": "5dfb6b7f.67f114",
           "type": "debug",
           "name": "switch 3 energy",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1080,
           "y": 1500,
           "wires": []
    66er6 Offline
    66er6 Offline
    66er
    @mickym
    Sieht ja fast aus, wie mein Ergebnis. 👍
    So bin ich zu Erfolg gekommen:
    LG
    Stefan
    • 66er6 66er
      @mickym
      mickymM Offline
      mickymM Offline
      mickym
      @66er Falls Du das nur in eigene DP wegschreiben willst, dann kannst Dir ja mal meinen Subflow anschauen:
      https://forum.iobroker.net/topic/43856/json-string-oder-java-object-in-iobroker-struktur
      Seit Admin 5 musst Du dann zwar noch etwas nacharbeiten, in dem Du mit einem Skript die fehlenden Objekte noch erzeugst. Aber falls Du ihn nutzen willst, bekommst Du so alles in DP zerlegt.
      IN meinen Augen ist das zwar nicht sinnvoll, aber ich sehe ja, dass Du mit Deinem Flow nichts anderes machst.
      Oder Du nimmst den mqtt-Adapter im iobroker - dann hast Du ebenfalls alles als einzelne Datenpunkte.
      66er6 1 Antwort Letzte Antwort
      • mickymM mickym
        66er6 Offline
        66er6 Offline
        66er
        schrieb am zuletzt editiert von 66er
        @mickym sagte in Payload String zerlegen:
        Schau mir den anderen Link natürlich noch an.
        Warum ist das nicht sinnvoll? (Ich lerne mich ja gerade erst ein und wenn ich hier was falsch mache, sollte ich verstehen warum.)
        Versuchsweise schreibe ich die Werte da rein und visualisiere sie dann.
        Leider geben die Geräte nur einen "Sammelstring" nach MQTT und keine einzelnen, direkt verwertbare Datenpunkte.
        LG
        Stefan
        • 66er6 66er
          mickymM Offline
          mickymM Offline
          mickym
          @66er OK zum Visualisieren hängt davon ab, was Du halt nutzt. Für VIS ja.
          Wenn Du das Node-Red Dashborad nutzt, dann fütterst Du ja den switch mit der payload und der Switch behält ja den Status.
          Aber Du hast Recht für VIS ist es sinnvoll.
          Ansonsten ist zwar schön alles in eigene Datenpunkte zu schreiben, aber gibt Dir ja keinen Mehrwert, weil die Info letztlich in dem JSON String enthalten ist. Wie gesagt für VIS ist es sinnvoll.
          • mickymM mickym
            66er6 Offline
            66er6 Offline
            66er
            @mickym
            Ja, ich nutze VIS.
            Hier noch ein Screenshot von MQTT:
            Im RPC-String unter events steht alles drin.
            LG
            Stefan
            • 66er6 66er
              @mickym
              Ja, ich nutze VIS.
              mickymM Offline
              mickymM Offline
              mickym
              @66er Ja wie gesagt, wenn Du nur das wieder in DP speicherst, was Du visualisierst - passt das schon!!!
              • mickymM mickym
                66er6 Offline
                66er6 Offline
                66er
                @mickym
                Prima,
                und ja: alle anderen Datenpunkt bleiben im JSON ohne das ich die anpacke.
                Danke, wieder mein Wissen und Verständnis für MQTT erweitert.👍
                LG
                Stefan
                R 1 Antwort Letzte Antwort
                • 66er6 66er
                  @mickym
                  Prima,
                  rieders
                  schrieb am zuletzt editiert von rieders
                  Hallo
                  Ich versuche gerade mein Stromzähler String zu zerlegen.
                  Eine Verbindung zum mqtt-Broker besteht, die Daten werden auch im Debug angezeigt.
                  Ich habe schon einiges Versuch, ich bekomme einfach nicht die Werte einzeln angezeigt.
                  Smartmeter_Garten/tele/SENSOR : msg.payload : string[643]
                  "{"Time":"2023-01-13T12:54:35","SDM630":{"1":178,"Voltage_P1":231.88,"Voltage_P2":231.5,"Voltage_P3":232.49,"Current_P1":0,"Current_P2":0.1,"Current_P3":0,"Power_P1":0,"Power_P2":22.35,"Power_P3":0,"Frequenz":50.01,"Total":534.694,"phase_angle":-9.73,"Import_nres":186.145,"Export_nres":348.549,"Export_P1":13.568,"Export_P2":334.981,"Export_P3":0,"Import_P1":19.409,"Import_P2":131.003,"Import_P3":35.733,"L1_total_kwh":32.977,"L2_total_kwh":465.984,"L3_total_kwh":35.733,"Blindleistung_L1":0,"Blindleistung_L2":-7.734,"Blindleistung_L3":0,"Scheinleistung_L1":0,"Scheinleistung_L2":22.627,"Scheinleistung_L3":0,"VAh_since_last_reset":565.815}}"
                  Ich hoffe jemand kann mir weiter helfen.
                  "id": "553525487db580b5",
                  "type": "mqtt in",
                  "z": "eb71b4cddc9da37a",
                  "name": "Smartmeter_Garten/tele/SENSOR",
                  "topic": "Smartmeter_Garten/tele/SENSOR",
                  "qos": "2",
                  "datatype": "auto-detect",
                  "broker": "e7e1e2255e66e588",
                  "nl": false,
                  "rap": true,
                  "rh": "2",
                  "inputs": 0,
                  "x": 180,
                  "y": 260,
                  "wires": [
                  "04a7ba72539a5cb1",
                  "df378652670347e0"
                  "id": "b0fcb45d6d8ab9f4",
                  "type": "ui_gauge",
                  "name": "Test",
                  "group": "67140eec2a9994a9",
                  "order": 0,
                  "width": 0,
                  "height": 0,
                  "gtype": "gage",
                  "title": "Voltage_P1",
                  "label": "",
                  "format": "{{Value}}",
                  "min": "1",
                  "max": "260",
                  "colors": [
                  "#b30000",
                  "#e6e600",
                  "#00b815"
                  "seg1": "",
                  "seg2": "",
                  "x": 890,
                  "y": 260,
                  "wires": []
                  "id": "9faaac80e56b9d83",
                  "type": "ui_chart",
                  "name": "",
                  "order": 0,
                  "width": 0,
                  "height": 0,
                  "label": "chart",
                  "chartType": "line",
                  "legend": "false",
                  "xformat": "HH:mm:ss",
                  "interpolate": "linear",
                  "nodata": "",
                  "dot": false,
                  "ymin": "0",
                  "ymax": "260",
                  "removeOlder": 1,
                  "removeOlderPoints": "",
                  "removeOlderUnit": "3600",
                  "cutout": 0,
                  "useOneColor": false,
                  "useUTC": false,
                  "colors": [
                  "#1f77b4",
                  "#aec7e8",
                  "#ff7f0e",
                  "#2ca02c",
                  "#98df8a",
                  "#d62728",
                  "#ff9896",
                  "#9467bd",
                  "#c5b0d5"
                  "outputs": 1,
                  "useDifferentColor": false,
                  "x": 890,
                  "y": 320,
                  "wires": [
                  "id": "04a7ba72539a5cb1",
                  "type": "json",
                  "name": "V1",
                  "action": "",
                  "pretty": false,
                  "x": 450,
                  "y": 200,
                  "wires": [
                  "35354018b6c6c095",
                  "639599639f78788c"
                  "id": "6f72cb37f4aa2278",
                  "type": "debug",
                  "name": "debug 1",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 900,
                  "y": 200,
                  "wires": []
                  "id": "35354018b6c6c095",
                  "type": "debug",
                  "name": "debug 2",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 620,
                  "y": 120,
                  "wires": []
                  "id": "639599639f78788c",
                  "type": "change",
                  "name": "",
                  "rules": [
                  "t": "set",
                  "p": "payload",
                  "pt": "msg",
                  "to": "payload["SDM630"].Voltage_P1",
                  "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 670,
                  "y": 200,
                  "wires": [
                  "6f72cb37f4aa2278",
                  "b0fcb45d6d8ab9f4",
                  "9faaac80e56b9d83"
                  "id": "a5192d83b6ce2f1c",
                  "type": "mqtt out",
                  "name": "V1",
                  "topic": "Testzähler",
                  "qos": "",
                  "retain": "",
                  "respTopic": "",
                  "contentType": "",
                  "userProps": "",
                  "correl": "",
                  "expiry": "",
                  "broker": "d19896c9b4e98e28",
                  "x": 750,
                  "y": 340,
                  "wires": []
                  "id": "df378652670347e0",
                  "type": "function",
                  "name": "function 2",
                  "func": "\nreturn msg;payload["SDM630"].Voltage_P1",
                  "outputs": 1,
                  "noerr": 0,
                  "initialize": "",
                  "finalize": "",
                  "libs": [],
                  "x": 560,
                  "y": 340,
                  "wires": [
                  "a5192d83b6ce2f1c"
                  "id": "e7e1e2255e66e588",
                  "type": "mqtt-broker",
                  "name": "mqtt-broker",
                  "broker": "192.168.1.146",
                  "port": "1885",
                  "clientid": "",
                  "autoConnect": true,
                  "usetls": false,
                  "protocolVersion": "4",
                  "keepalive": "60",
                  "cleansession": true,
                  "birthTopic": "",
                  "birthQos": "0",
                  "birthPayload": "",
                  "birthMsg": {},
                  "closeTopic": "",
                  "closeQos": "0",
                  "closePayload": "",
                  "closeMsg": {},
                  "willTopic": "",
                  "willQos": "0",
                  "willPayload": "",
                  "willMsg": {},
                  "userProps": "",
                  "sessionExpiry": ""
                  "id": "67140eec2a9994a9",
                  "type": "ui_group",
                  "name": "Test",
                  "tab": "71f6d060a354b8d9",
                  "order": 1,
                  "disp": true,
                  "width": "6",
                  "collapse": false
                  "id": "d19896c9b4e98e28",
                  "name": "Venus OS",
                  "broker": "192.168.1.37",
                  "port": "1883",
                  "clientid": "test-client",
                  "usetls": false,
                  "keepalive": "60",
                  "birthTopic": "",
                  "birthQos": "0",
                  "birthPayload": "",
                  "birthMsg": {},
                  "closeTopic": "",
                  "closeQos": "0",
                  "closePayload": "",
                  "closeMsg": {},
                  "willTopic": "",
                  "willQos": "0",
                  "willPayload": "",
                  "willMsg": {},
                  "userProps": "",
                  "sessionExpiry": ""
                  "id": "71f6d060a354b8d9",
                  "type": "ui_tab",
                  "name": "Home",
                  "icon": "dashboard",
                  "disabled": false,
                  "hidden": false
                  Grüße André
                  mickymM 1 2 Antworten Letzte Antwort
                  • R rieders
                    Hallo
                    "type": "mqtt in",
                    "qos": "2",
                    "nl": false,
                    "rap": true,
                    "rh": "2",
                    "inputs": 0,
                    "x": 180,
                    "y": 260,
                    "wires": [
                    "04a7ba72539a5cb1",
                    "df378652670347e0"
                    "type": "ui_gauge",
                    "name": "Test",
                    "order": 0,
                    "width": 0,
                    "height": 0,
                    "gtype": "gage",
                    "label": "",
                    "min": "1",
                    "max": "260",
                    "colors": [
                    "#b30000",
                    "#e6e600",
                    "#00b815"
                    "seg1": "",
                    "seg2": "",
                    "x": 890,
                    "y": 260,
                    "wires": []
                    "type": "ui_chart",
                    "name": "",
                    "order": 0,
                    "width": 0,
                    "height": 0,
                    "label": "chart",
                    "legend": "false",
                    "nodata": "",
                    "dot": false,
                    "ymin": "0",
                    "ymax": "260",
                    "removeOlder": 1,
                    "cutout": 0,
                    "useUTC": false,
                    "colors": [
                    "#1f77b4",
                    "#aec7e8",
                    "#ff7f0e",
                    "#2ca02c",
                    "#98df8a",
                    "#d62728",
                    "#ff9896",
                    "#9467bd",
                    "#c5b0d5"
                    "outputs": 1,
                    "x": 890,
                    "y": 320,
                    "wires": [
                    "type": "json",
                    "name": "V1",
                    "action": "",
                    "pretty": false,
                    "x": 450,
                    "y": 200,
                    "wires": [
                    "35354018b6c6c095",
                    "639599639f78788c"
                    "type": "debug",
                    "name": "debug 1",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 900,
                    "y": 200,
                    "wires": []
                    "type": "debug",
                    "name": "debug 2",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 620,
                    "y": 120,
                    "wires": []
                    "type": "change",
                    "name": "",
                    "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 670,
                    "y": 200,
                    "wires": [
                    "6f72cb37f4aa2278",
                    "b0fcb45d6d8ab9f4",
                    "9faaac80e56b9d83"
                    "type": "mqtt out",
                    "name": "V1",
                    "qos": "",
                    "retain": "",
                    "respTopic": "",
                    "contentType": "",
                    "userProps": "",
                    "correl": "",
                    "expiry": "",
                    "x": 750,
                    "y": 340,
                    "wires": []
                    "type": "function",
                    "outputs": 1,
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 560,
                    "y": 340,
                    "wires": [
                    "a5192d83b6ce2f1c"
                    "port": "1885",
                    "clientid": "",
                    "usetls": false,
                    "keepalive": "60",
                    "birthTopic": "",
                    "birthQos": "0",
                    "birthPayload": "",
                    "birthMsg": {},
                    "closeTopic": "",
                    "closeQos": "0",
                    "closePayload": "",
                    "closeMsg": {},
                    "willTopic": "",
                    "willQos": "0",
                    "willPayload": "",
                    "willMsg": {},
                    "userProps": "",
                    "sessionExpiry": ""
                    "type": "ui_group",
                    "name": "Test",
                    "order": 1,
                    "disp": true,
                    "width": "6",
                    "collapse": false
                    "name": "Venus OS",
                    "port": "1883",
                    "usetls": false,
                    "keepalive": "60",
                    "birthTopic": "",
                    "birthQos": "0",
                    "birthPayload": "",
                    "birthMsg": {},
                    "closeTopic": "",
                    "closeQos": "0",
                    "closePayload": "",
                    "closeMsg": {},
                    "willTopic": "",
                    "willQos": "0",
                    "willPayload": "",
                    "willMsg": {},
                    "userProps": "",
                    "sessionExpiry": ""
                    "type": "ui_tab",
                    "name": "Home",
                    "disabled": false,
                    "hidden": false
                    Grüße André
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @rieders Am besten ist es aus dem Debugfenster einfach den Pfad kopieren. Sprich du schaust, was aus debug2 rauskommt und kopierst den Pfad, des Wertes den Du anzeigen willst.
                    Wenn ich also Dein Objekt nehme (Dein Flow lässt sich nicht importieren, da Du keine CodeTags verwendest) und möchte den Total Wert in der Text Node anzeigen, gehe ich mit dem Cursor dahin und kopieren den Pfad:
                    Dann kommt folgendes raus:
                    payload.SDM630.Total
                    Das kannst Du nun direkt in der text node verwenden oder die payload verändern um es dann in einer gauge anzuzeigen.
                    In der Text-Node:
                    Mit der Change-Node:
                    Hier mal mein Flow richtig exportiert in CodeTags:
                           "id": "79cb540f2a41c739",
                           "type": "inject",
                           "z": "289f539dcc33814e",
                           "name": "",
                           "props": [
                                   "p": "payload"
                           "repeat": "",
                           "crontab": "",
                           "once": false,
                           "onceDelay": 0.1,
                           "topic": "",
                           "payload": "{\"Time\":\"2023-01-13T12:54:35\",\"SDM630\":{\"1\":178,\"Voltage_P1\":231.88,\"Voltage_P2\":231.5,\"Voltage_P3\":232.49,\"Current_P1\":0,\"Current_P2\":0.1,\"Current_P3\":0,\"Power_P1\":0,\"Power_P2\":22.35,\"Power_P3\":0,\"Frequenz\":50.01,\"Total\":534.694,\"phase_angle\":-9.73,\"Import_nres\":186.145,\"Export_nres\":348.549,\"Export_P1\":13.568,\"Export_P2\":334.981,\"Export_P3\":0,\"Import_P1\":19.409,\"Import_P2\":131.003,\"Import_P3\":35.733,\"L1_total_kwh\":32.977,\"L2_total_kwh\":465.984,\"L3_total_kwh\":35.733,\"Blindleistung_L1\":0,\"Blindleistung_L2\":-7.734,\"Blindleistung_L3\":0,\"Scheinleistung_L1\":0,\"Scheinleistung_L2\":22.627,\"Scheinleistung_L3\":0,\"VAh_since_last_reset\":565.815}}",
                           "payloadType": "json",
                           "x": 230,
                           "y": 4260,
                           "wires": [
                                   "479307770498d089",
                                   "7e8331652d9d7389",
                                   "ae5bde5b22da03b0"
                           "id": "479307770498d089",
                           "type": "debug",
                           "name": "Objekt",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 390,
                           "y": 4260,
                           "wires": []
                           "id": "c9e73544e1bfa520",
                           "type": "ui_gauge",
                           "name": "",
                           "group": "57f13d6f733e5c9d",
                           "order": 2,
                           "width": 0,
                           "height": 0,
                           "gtype": "gage",
                           "title": "Total",
                           "label": "units",
                           "format": "{{value}}",
                           "min": 0,
                           "max": "1000",
                           "colors": [
                               "#00b500",
                               "#e6e600",
                               "#ca3838"
                           "seg1": "",
                           "seg2": "",
                           "className": "",
                           "x": 630,
                           "y": 4340,
                           "wires": []
                           "id": "7e8331652d9d7389",
                           "type": "ui_text",
                           "order": 3,
                           "width": 0,
                           "height": 0,
                           "name": "",
                           "label": "Total",
                           "format": "{{msg.payload.SDM630.Total}}",
                           "layout": "row-spread",
                           "className": "",
                           "x": 390,
                           "y": 4300,
                           "wires": []
                           "id": "ae5bde5b22da03b0",
                           "type": "change",
                           "name": "",
                           "rules": [
                                   "t": "set",
                                   "p": "payload",
                                   "pt": "msg",
                                   "to": "payload.SDM630.Total",
                                   "tot": "msg"
                           "action": "",
                           "property": "",
                           "from": "",
                           "to": "",
                           "reg": false,
                           "x": 430,
                           "y": 4340,
                           "wires": [
                                   "c9e73544e1bfa520",
                                   "680cd23566aafb30"
                           "id": "680cd23566aafb30",
                           "type": "debug",
                           "name": "Total",
                           "active": true,
                           "tosidebar": true,
                           "console": false,
                           "tostatus": false,
                           "statusVal": "",
                           "x": 630,
                           "y": 4380,
                           "wires": []
                           "id": "57f13d6f733e5c9d",
                           "type": "ui_group",
                           "name": "Test",
                           "tab": "20b3095113f94d70",
                           "order": 2,
                           "disp": true,
                           "width": "6",
                           "collapse": false,
                           "className": ""
                           "id": "20b3095113f94d70",
                           "type": "ui_tab",
                           "name": "Home",
                           "order": 1,
                           "disabled": false,
                           "hidden": false
                    • mickymM mickym
                      In der Text-Node:
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "x": 230,
                             "y": 4260,
                             "wires": [
                                     "479307770498d089",
                                     "7e8331652d9d7389",
                                     "ae5bde5b22da03b0"
                             "type": "debug",
                             "name": "Objekt",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 390,
                             "y": 4260,
                             "wires": []
                             "type": "ui_gauge",
                             "name": "",
                             "order": 2,
                             "width": 0,
                             "height": 0,
                             "gtype": "gage",
                             "title": "Total",
                             "label": "units",
                             "min": 0,
                             "max": "1000",
                             "colors": [
                                 "#00b500",
                                 "#e6e600",
                                 "#ca3838"
                             "seg1": "",
                             "seg2": "",
                             "className": "",
                             "x": 630,
                             "y": 4340,
                             "wires": []
                             "type": "ui_text",
                             "order": 3,
                             "width": 0,
                             "height": 0,
                             "name": "",
                             "label": "Total",
                             "className": "",
                             "x": 390,
                             "y": 4300,
                             "wires": []
                             "type": "change",
                             "name": "",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 430,
                             "y": 4340,
                             "wires": [
                                     "c9e73544e1bfa520",
                                     "680cd23566aafb30"
                             "type": "debug",
                             "name": "Total",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 630,
                             "y": 4380,
                             "wires": []
                             "type": "ui_group",
                             "name": "Test",
                             "order": 2,
                             "disp": true,
                             "width": "6",
                             "collapse": false,
                             "className": ""
                             "type": "ui_tab",
                             "name": "Home",
                             "order": 1,
                             "disabled": false,
                             "hidden": false
                      rieders
                      Vielen Dank für die Hilfe.
                      Das Auslesen funktioniert super.
                      Ich weiß nur nicht wie du aus dem debug2 den Pfad ausgelesen hast, bei mir sieht das ganz anders aus.
                      Jetzt kann ich die Daten an Venus OS übergeben und hoffentlich als virtualen Zähler sehen.
                      • R rieders
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @rieders Hab ich gar nicht, da ich deinen Flow ja nicht importieren konnte (nicht in CodeTags), aber Du hast ja die Daten zum Glück bzw. das Objekt gepostet und so habe ich es einfach in die Inject Node geschrieben. Du kannst übrigens direkt in ein Objekt wandeln lassen, dann kannst du das direkt nach der mqtt-In Node machen, in dem Du Dir ein analysiertes Objekt ausgeben lässt.
                        Dann brauchst nach der mqtt-In auch nichts mehr konvertieren.
                        frankthegreatF 1 Antwort Letzte Antwort
                        • mickymM mickym
                          frankthegreatF Offline
                          frankthegreat
                          @mickym
                          Sorry, das ich mich hier mit ranhänge. Mein Problem ist denk mal ähnlich.
                          Ich möchte relatives Dimmen von KNX auf Zigbee umsetzen.
                          Dazu müßte wohl auch der Payload zerlegt werden 🤔
                          Hier die Ausgaben vom KNX.
                          Taster ist gedrückt und soll runterdimmen:
                          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":1},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[1]},"previouspayload":{"decr_incr":0,"data":0},"_msgid":"34735868e6770bd1"}
                          Taster losgelassen, dimmen soll stoppen:
                          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":0},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[0]},"previouspayload":{"decr_incr":0,"data":1},"_msgid":"a4982ca3e5461702"}
                          Taster ist gedrückt und soll hochdimmen:
                          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":1,"data":1},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[9]},"previouspayload":{"decr_incr":0,"data":0},"_msgid":"12ada754ecbda05f"}
                          {"topic":"1/4/26","devicename":"","payload":{"decr_incr":0,"data":0},"payloadmeasureunit":"unknown","payloadsubtypevalue":"unknown","knx":{"event":"GroupValue_Write","dpt":"3.007","dptdesc":"Dimming control","source":"1.1.4","destination":"1/4/26","rawValue":[0]},"previouspayload":{"decr_incr":1,"data":1},"_msgid":"dabb632a5c74b60d"}
                          Änderungen sehe ich hier jeweils bei :
                          {"decr_incr":x,"data":x}
                          Die Befehle für die Zigbee Leuchtmittel hab ich getestet, bei direktem schicken auf den DP funktionieren die schonmal.
                          z.B.
                          hochdimmen={"brightness_move": 40}
                          runterdimmen={"brightness_move": -40}
                          stoppen={"brightness_move": 0}
                          Hab schon etliche Stunden mit der "Change" Node rumprobiert, allerdings ohne Erfolg 😞
                          Wie muß ich vorgehen, um die KNX Befehle auf Zigbee umzusetzen?
                          • mickymM Offline
                            mickymM Offline
                            mickym
                            @frankthegreat Na ja - da ist noch etwas mehr Logik im Spiel und das muss man sich trotz aller Flows genau überlegen. Ich hab ja mal einen softdimmer ähnlich mit einem vis Widget erstellt.
                            das mit dem hoch und runter Dimmen - kann man grundsätzlich mit mehreren Arten machen wahrscheinlich gibts den brightness Datenpunkt im Zigbee auch als absolute Werte. Move geht auch und vereinfacht das Ganze wohl eher.
                            Im Prinzip, wenn es sich so darstellt, dann wäre
                            data: 1 immer gedrückt = dimmen
                            data: 0 immer losgelassen = stoppen
                            decr_incr: 1 bei data 1 = hochdimmen
                            decr_incr: 0 bei data 1 = runterdimmen.
                            Da wir immer stoppen egal wie gerade gedimmt wurde, ist uns egal welchen Zustand das Teil vorher hatte. Auf dieser Basis probieren wird das mal - kleinen Moment. ;)
                            So müsste das jetzt mal quick & dirty funktionieren:
                            Statt der Inject Node halt Deine KNX Nodes dran machen und hinten halt in den brightness_move Datenpunkt ausgeben.
                                   "id": "65b061e782f70ac9",
                                   "type": "inject",
                                   "z": "f71771fc316ba18f",
                                   "name": "dim down",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "{\"decr_incr\":0,\"data\":1}",
                                   "x": 340,
                                   "y": 140,
                                   "wires": [
                                           "240e3279819f0eae"
                                   "id": "2e68f247a519c9b3",
                                   "type": "inject",
                                   "name": "stop",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "{\"decr_incr\":0,\"data\":0}",
                                   "x": 350,
                                   "y": 220,
                                   "wires": [
                                           "240e3279819f0eae"
                                   "id": "7efd5166901d779b",
                                   "type": "inject",
                                   "name": "dim up",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "{\"decr_incr\":1,\"data\":1}",
                                   "x": 350,
                                   "y": 180,
                                   "wires": [
                                           "240e3279819f0eae"
                                   "id": "240e3279819f0eae",
                                   "type": "switch",
                                   "name": "",
                                   "property": "payload.data",
                                   "propertyType": "msg",
                                   "rules": [
                                           "t": "eq",
                                           "v": "0",
                                           "vt": "num"
                                           "t": "eq",
                                           "v": "1",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 530,
                                   "y": 180,
                                   "wires": [
                                           "2e23dae4976566fd"
                                           "2e5b171c27e7e26a"
                                   "id": "2e23dae4976566fd",
                                   "type": "change",
                                   "name": "stop dimming",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "0",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 830,
                                   "y": 160,
                                   "wires": [
                                           "26db997e0e9ac3b2"
                                   "id": "2e5b171c27e7e26a",
                                   "type": "switch",
                                   "name": "",
                                   "property": "payload.decr_incr",
                                   "rules": [
                                           "t": "eq",
                                           "v": "0",
                                           "vt": "num"
                                           "t": "eq",
                                           "v": "1",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 670,
                                   "y": 220,
                                   "wires": [
                                           "75612c32dc30ca8a"
                                           "28f8664528857291"
                                   "outputLabels": [
                                       "dim down",
                                       "dim up"
                                   "id": "75612c32dc30ca8a",
                                   "type": "change",
                                   "name": "dim down",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "-40",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 840,
                                   "y": 200,
                                   "wires": [
                                           "26db997e0e9ac3b2"
                                   "id": "28f8664528857291",
                                   "type": "change",
                                   "name": "dim up",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "40",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 240,
                                   "wires": [
                                           "26db997e0e9ac3b2"
                                   "id": "26db997e0e9ac3b2",
                                   "type": "debug",
                                   "name": "brightness move",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 200,
                                   "wires": []
                            Das geht auch mit einer switch Node - nur dann muss man halt JSONATA verwenden und bei der ersten Übereinstimmung stoppen - dafür schaut der Flow übersichtlicher aus.
                                   "id": "9c42920aa2d032db",
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "jsonata_exp",
                                           "v": "payload.data = 0",
                                           "vt": "jsonata"
                                           "t": "jsonata_exp",
                                           "v": "payload.decr_incr = 0",
                                           "vt": "jsonata"
                                           "t": "jsonata_exp",
                                           "v": "payload.decr_incr = 1",
                                           "vt": "jsonata"
                                   "checkall": "false",
                                   "repair": false,
                                   "outputs": 3,
                                   "x": 670,
                                   "y": 380,
                                   "wires": [
                                           "9b040f37641b3023"
                                           "af3bf63193955ef5"
                                           "fa5c8b6c4663ba2f"
                                   "id": "b20aff26a7c2e42c",
                                   "type": "inject",
                                   "name": "dim down",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 480,
                                   "y": 340,
                                   "wires": [
                                           "9c42920aa2d032db"
                                   "id": "00cc24ce0bd3bc46",
                                   "type": "inject",
                                   "name": "stop",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 490,
                                   "y": 420,
                                   "wires": [
                                           "9c42920aa2d032db"
                                   "id": "291666bfb387eb09",
                                   "type": "inject",
                                   "name": "dim up",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 490,
                                   "y": 380,
                                   "wires": [
                                           "9c42920aa2d032db"
                                   "id": "9b040f37641b3023",
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "0",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 830,
                                   "y": 340,
                                   "wires": [
                                           "f3660815c7c7b3df"
                                   "id": "af3bf63193955ef5",
                                   "type": "change",
                                   "name": "dim down",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "-40",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 840,
                                   "y": 380,
                                   "wires": [
                                           "f3660815c7c7b3df"
                                   "id": "fa5c8b6c4663ba2f",
                                   "type": "change",
                                   "name": "dim up",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "40",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 420,
                                   "wires": [
                                           "f3660815c7c7b3df"
                                   "id": "f3660815c7c7b3df",
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 380,
                                   "wires": []
                            • mickymM mickym
                                     "type": "inject",
                                     "name": "dim down",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 340,
                                     "y": 140,
                                     "wires": [
                                             "240e3279819f0eae"
                                     "type": "inject",
                                     "name": "stop",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 350,
                                     "y": 220,
                                     "wires": [
                                             "240e3279819f0eae"
                                     "type": "inject",
                                     "name": "dim up",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 350,
                                     "y": 180,
                                     "wires": [
                                             "240e3279819f0eae"
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "eq",
                                             "v": "0",
                                             "vt": "num"
                                             "t": "eq",
                                             "v": "1",
                                             "vt": "num"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 530,
                                     "y": 180,
                                     "wires": [
                                             "2e23dae4976566fd"
                                             "2e5b171c27e7e26a"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "0",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 830,
                                     "y": 160,
                                     "wires": [
                                             "26db997e0e9ac3b2"
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "eq",
                                             "v": "0",
                                             "vt": "num"
                                             "t": "eq",
                                             "v": "1",
                                             "vt": "num"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 670,
                                     "y": 220,
                                     "wires": [
                                             "75612c32dc30ca8a"
                                             "28f8664528857291"
                                     "outputLabels": [
                                         "dim down",
                                         "dim up"
                                     "type": "change",
                                     "name": "dim down",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "-40",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 840,
                                     "y": 200,
                                     "wires": [
                                             "26db997e0e9ac3b2"
                                     "type": "change",
                                     "name": "dim up",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "40",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 850,
                                     "y": 240,
                                     "wires": [
                                             "26db997e0e9ac3b2"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1040,
                                     "y": 200,
                                     "wires": []
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "jsonata_exp",
                                             "vt": "jsonata"
                                             "t": "jsonata_exp",
                                             "vt": "jsonata"
                                             "t": "jsonata_exp",
                                             "vt": "jsonata"
                                     "repair": false,
                                     "outputs": 3,
                                     "x": 670,
                                     "y": 380,
                                     "wires": [
                                             "9b040f37641b3023"
                                             "af3bf63193955ef5"
                                             "fa5c8b6c4663ba2f"
                                     "type": "inject",
                                     "name": "dim down",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 480,
                                     "y": 340,
                                     "wires": [
                                             "9c42920aa2d032db"
                                     "type": "inject",
                                     "name": "stop",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 490,
                                     "y": 420,
                                     "wires": [
                                             "9c42920aa2d032db"
                                     "type": "inject",
                                     "name": "dim up",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 490,
                                     "y": 380,
                                     "wires": [
                                             "9c42920aa2d032db"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "0",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 830,
                                     "y": 340,
                                     "wires": [
                                             "f3660815c7c7b3df"
                                     "type": "change",
                                     "name": "dim down",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "-40",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 840,
                                     "y": 380,
                                     "wires": [
                                             "f3660815c7c7b3df"
                                     "type": "change",
                                     "name": "dim up",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "40",
                                             "tot": "num"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 850,
                                     "y": 420,
                                     "wires": [
                                             "f3660815c7c7b3df"
                                     "type": "debug",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1040,
                                     "y": 380,
                                     "wires": []
                              frankthegreat
                              @mickym
                              Jepp...und läuft auf Anhieb 👏
                              Supi, danke dir. Abend gerettet.
                              Ich hatte hauptsächlich versucht in diesen DP zu schreiben. Da hatt's aber mit der Umwandlung nicht geklappt.
                              Aber so geht's natürlich auch.
                              Nochmal DANKE 👍
                              • R rieders
                                Hallo
                                "type": "mqtt in",
                                "qos": "2",
                                "nl": false,
                                "rap": true,
                                "rh": "2",
                                "inputs": 0,
                                "x": 180,
                                "y": 260,
                                "wires": [
                                "04a7ba72539a5cb1",
                                "df378652670347e0"
                                "type": "ui_gauge",
                                "name": "Test",
                                "order": 0,
                                "width": 0,
                                "height": 0,
                                "gtype": "gage",
                                "label": "",
                                "min": "1",
                                "max": "260",
                                "colors": [
                                "#b30000",
                                "#e6e600",
                                "#00b815"
                                "seg1": "",
                                "seg2": "",
                                "x": 890,
                                "y": 260,
                                "wires": []
                                "type": "ui_chart",
                                "name": "",
                                "order": 0,
                                "width": 0,
                                "height": 0,
                                "label": "chart",
                                "legend": "false",
                                "nodata": "",
                                "dot": false,
                                "ymin": "0",
                                "ymax": "260",
                                "removeOlder": 1,
                                "cutout": 0,
                                "useUTC": false,
                                "colors": [
                                "#1f77b4",
                                "#aec7e8",
                                "#ff7f0e",
                                "#2ca02c",
                                "#98df8a",
                                "#d62728",
                                "#ff9896",
                                "#9467bd",
                                "#c5b0d5"
                                "outputs": 1,
                                "x": 890,
                                "y": 320,
                                "wires": [
                                "type": "json",
                                "name": "V1",
                                "action": "",
                                "pretty": false,
                                "x": 450,
                                "y": 200,
                                "wires": [
                                "35354018b6c6c095",
                                "639599639f78788c"
                                "type": "debug",
                                "name": "debug 1",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 900,
                                "y": 200,
                                "wires": []
                                "type": "debug",
                                "name": "debug 2",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "statusVal": "",
                                "x": 620,
                                "y": 120,
                                "wires": []
                                "type": "change",
                                "name": "",
                                "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 670,
                                "y": 200,
                                "wires": [
                                "6f72cb37f4aa2278",
                                "b0fcb45d6d8ab9f4",
                                "9faaac80e56b9d83"
                                "type": "mqtt out",
                                "name": "V1",
                                "qos": "",
                                "retain": "",
                                "respTopic": "",
                                "contentType": "",
                                "userProps": "",
                                "correl": "",
                                "expiry": "",
                                "x": 750,
                                "y": 340,
                                "wires": []
                                "type": "function",
                                "outputs": 1,
                                "noerr": 0,
                                "initialize": "",
                                "finalize": "",
                                "libs": [],
                                "x": 560,
                                "y": 340,
                                "wires": [
                                "a5192d83b6ce2f1c"
                                "port": "1885",
                                "clientid": "",
                                "usetls": false,
                                "keepalive": "60",
                                "birthTopic": "",
                                "birthQos": "0",
                                "birthPayload": "",
                                "birthMsg": {},
                                "closeTopic": "",
                                "closeQos": "0",
                                "closePayload": "",
                                "closeMsg": {},
                                "willTopic": "",
                                "willQos": "0",
                                "willPayload": "",
                                "willMsg": {},
                                "userProps": "",
                                "sessionExpiry": ""
                                "type": "ui_group",
                                "name": "Test",
                                "order": 1,
                                "disp": true,
                                "width": "6",
                                "collapse": false
                                "name": "Venus OS",
                                "port": "1883",
                                "usetls": false,
                                "keepalive": "60",
                                "birthTopic": "",
                                "birthQos": "0",
                                "birthPayload": "",
                                "birthMsg": {},
                                "closeTopic": "",
                                "closeQos": "0",
                                "closePayload": "",
                                "closeMsg": {},
                                "willTopic": "",
                                "willQos": "0",
                                "willPayload": "",
                                "willMsg": {},
                                "userProps": "",
                                "sessionExpiry": ""
                                "type": "ui_tab",
                                "name": "Home",
                                "disabled": false,
                                "hidden": false
                                Grüße André
                                1 Offline
                                1 Offline
                                1984chris
                                @rieders @rieders Hallo Ich habe das gleiche Problem wie du
                                ![0_1684256284880_ausgabe.jpg](Uploading 100%)
                                konntest du das wie in Debug2 darstellen?
                                DANKE im Voraus
                                LG Christoph
                                1 1 Antwort Letzte Antwort
                                • 1 1984chris
                                  DANKE im Voraus
                                  LG Christoph
                                  1 Offline
                                  1 Offline
                                  1984chris
                                  1 mickymM 2 Antworten Letzte Antwort
                                  • 1 1984chris
                                    1 Offline
                                    1 Offline
                                    1984chris
                                    @1984chris ich will die einzelnen Werte L1,L2,L3 Ströme A_L1,A_l2 usw an die influxDB übertragen
                                    • 1 1984chris
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @1984chris Wenn ich Dir helfen soll, dann solltest Du den Wert in die Zwischenablage kopieren und hier in Codetags einbetten.
                                      Dann woher hast Du das - kommt das aus einer iobroker IN Node oder aus einer mqtt Node?
                                      Willst Du alle Werte in einzelne Datenpunkte zerlegen oder nur einzelne Werte extrahieren und weiter verarbeiten?
                                      Einzelne Werte kopierst Du in die Zwischenablage in dem Du mit der Maul im Debug Fenster neben den Wert fährst.
                                      Wenn Du es in der Zwischenablage hast, dann kopierst Du es bitte in Code-Tags wie hier dargestellt:
                                      Und wie gesagt - wer es nett, wenn Du ein paar Zeilen dazu schreiben möchtest, was Du möchtest
                                      • 1 1984chris
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @1984chris sagte in Payload String zerlegen:
                                        Dann wäre es wohl sinnvoll einzelne Werte zu erstellen, dann empfehle ich Dir meinen Flow - der den ganzen JSON in einzelne Datenpunkte schreibt:
                                        https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
                                        Dann brauchst Du nur diesen Flow zu importieren.
                                        Im 1. Post ist eigentlich alles beschrieben und welche Einstellungen Du machen willst. Falls Du noch Fragen hast, dann gerne. Also hängt davon ab, ob Du nur ein paar Werte haben willst oder alle Werte einzeln haben möchtest.
                                        • mickymM mickym
                                          1 Offline
                                          1 Offline
                                          1984chris
                                          @mickym ```
                                          {"Time":"2023-05-16T19:45:29","Tagstrom":{"V_L1":233,"V_L3":236,"V_L3":236,"A_L1":0.63,"A_L2":2.33,"A_L3":0.32,"W_IN":590,"W_OUT":0,"kWh_total_IN":19147.756,"kWh_total_OUT":776.383},"WäPu":{"V_L1":232,"V_L3":236,"V_L3":235,"A_L1":0.48,"A_L2":0.00,"A_L3":0.02,"W_IN":112,"W_OUT":0,"kWh_total_IN":21698.535,"kWh_total_OUT":0.000}}
                                          die Daten kommen von einenm Nodred in mqtt ich bekomme das auf der Debugseite nicht so angezeigt wie du im Beispiel. Will die einzelnen Werte dan in eine influxDB und weiter mit GRAFANA....
