  4. Node-Red
  5. Payload String zerlegen
    6.4k
77 Beiträge 7 Kommentatoren 19.6k Aufrufe 7 Beobachtet
  • riste76R Offline
    riste76R Offline
    riste76
    Hallo Gemeinde,
    ich habe eine kleine Herausforderung, ich möchte aus diesem String:
    mqtt/0/tele/zisterne/SENSOR : msg.payload : string[58]
    "{"Time":"2021-06-20T20:16:28","SR04":{"Distance":130.544}}"
    die 130.544 extrahieren....
    könnt ihr mir einen Tipp geben wie ich das machen kann?
    Vielen Dank im Voraus, Gruß
    Christian
    • riste76R riste76
      Hallo Gemeinde,
      Christian
      mickymM Offline
      mickymM Offline
      mickym
      @riste76 sagte in Payload String zerlegen:
             "id": "f70f29ac.e79a08",
             "type": "inject",
             "z": "dce8fa20.2e93c8",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "{\"Time\":\"2021-06-20T20:16:28\",\"SR04\":{\"Distance\":130.544}}",
             "payloadType": "str",
             "x": 470,
             "y": 3080,
             "wires": [
                     "c3b8297b.63a338"
             "id": "e304c54b.d7a758",
             "type": "debug",
             "name": "",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "false",
             "statusVal": "",
             "statusType": "auto",
             "x": 1010,
             "y": 3080,
             "wires": []
             "id": "c3b8297b.63a338",
             "type": "json",
             "name": "",
             "property": "payload",
             "action": "",
             "pretty": false,
             "x": 610,
             "y": 3080,
             "wires": [
                     "cfabc75c.493b78"
             "id": "cfabc75c.493b78",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "payload.SR04.Distance",
                     "tot": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 810,
             "y": 3080,
             "wires": [
                     "e304c54b.d7a758"
      Hier bitte:
      riste76R 66er6 2 Antworten Letzte Antwort
      • mickymM mickym
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "x": 470,
               "y": 3080,
               "wires": [
                       "c3b8297b.63a338"
               "type": "debug",
               "name": "",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1010,
               "y": 3080,
               "wires": []
               "type": "json",
               "name": "",
               "action": "",
               "pretty": false,
               "x": 610,
               "y": 3080,
               "wires": [
                       "cfabc75c.493b78"
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 810,
               "y": 3080,
               "wires": [
                       "e304c54b.d7a758"
        Hier bitte:
        riste76R Offline
        riste76R Offline
        riste76
        @mickym
        vielen Dank!
        funktioniert
        • mickymM mickym
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 470,
                 "y": 3080,
                 "wires": [
                         "c3b8297b.63a338"
                 "type": "debug",
                 "name": "",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1010,
                 "y": 3080,
                 "wires": []
                 "type": "json",
                 "name": "",
                 "action": "",
                 "pretty": false,
                 "x": 610,
                 "y": 3080,
                 "wires": [
                         "cfabc75c.493b78"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 810,
                 "y": 3080,
                 "wires": [
                         "e304c54b.d7a758"
          Hier bitte:
          66er6 Offline
          66er6 Offline
          66er
          @mickym
          Ich möchte das Thema mal aufgreifen und hoffe, Du kannst mir auch den Weg weisen.
          Ich habe versucht, Deine Lösung nachzubauen für folgenden JSON, den ich aus dem MQTT-Adapter nach NodeRed hole:
          {"src":"shellyplus1-xxxxxxxxxxxxx","dst":"ShellyPlus1/events","method":"NotifyStatus","params":{"ts":1632490225.43,"switch:0":{"id":0,"output":true,"source":"WS_in"}}}
          Ich brauche den Wert von "output", der true oder false sein kann.
          Wie müßte ich den Flow korrekt ändern?
          Vielen Dank schon mal für jegliche Unterstützung.
          LG
          Stefan
          • 66er6 66er
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @66er sagte in Payload String zerlegen:
            Ja das war mit den Doppelpunkten in der Tat etwas tricky. Aber NodeRed bietet im Debug-Fenster eine ganz tolle Hilfe
            Wenn Du mit der Maus über den Wert der Dich interessiert fährst, kannst Du den Pfad innerhalb des Objektes kopieren:
            Somit sieht die Change Node dann so aus:
                   "id": "bb709554.04b598",
                   "type": "inject",
                   "z": "169f5b00.a13415",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"src\":\"shellyplus1-xxxxxxxxxxxxx\",\"dst\":\"ShellyPlus1/events\",\"method\":\"NotifyStatus\",\"params\":{\"ts\":1632490225.43,\"switch:0\":{\"id\":0,\"output\":true,\"source\":\"WS_in\"}}}",
                   "x": 610,
                   "y": 960,
                   "wires": [
                           "b10bf87d.eae1a8"
                   "id": "b10bf87d.eae1a8",
                   "type": "json",
                   "name": "",
                   "action": "",
                   "pretty": false,
                   "x": 760,
                   "y": 960,
                   "wires": [
                           "5af68d9f.4c24b4",
                           "d702c4c8.ddc6f8"
                   "id": "5af68d9f.4c24b4",
                   "type": "debug",
                   "name": "",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 940,
                   "y": 920,
                   "wires": []
                   "id": "4d5422a9.651b0c",
                   "type": "debug",
                   "name": "",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1150,
                   "y": 960,
                   "wires": []
                   "id": "d702c4c8.ddc6f8",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "payload.params[\"switch:0\"].output",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 950,
                   "y": 960,
                   "wires": [
                           "4d5422a9.651b0c"
            • 66er6 Offline
              66er6 Offline
              66er
              Werde ich gleich austesten. 👍
              Vielen Dank.
              (Und wieder was dazu lernen dürfen . ;-) )
              LG
              Stefan
              • mickymM mickym
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "x": 610,
                       "y": 960,
                       "wires": [
                               "b10bf87d.eae1a8"
                       "type": "json",
                       "name": "",
                       "action": "",
                       "pretty": false,
                       "x": 760,
                       "y": 960,
                       "wires": [
                               "5af68d9f.4c24b4",
                               "d702c4c8.ddc6f8"
                       "type": "debug",
                       "name": "",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 940,
                       "y": 920,
                       "wires": []
                       "type": "debug",
                       "name": "",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1150,
                       "y": 960,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 950,
                       "y": 960,
                       "wires": [
                               "4d5422a9.651b0c"
                66er6 Offline
                66er6 Offline
                66er
                @mickym sagte in Payload String zerlegen:
                Finale Rückmeldung: Funzt 1A 👍 👍 👍
                Vielen Dank nochmals.
                LG
                Stefan
                • mickymM mickym
                         "type": "inject",
                         "name": "",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "x": 610,
                         "y": 960,
                         "wires": [
                                 "b10bf87d.eae1a8"
                         "type": "json",
                         "name": "",
                         "action": "",
                         "pretty": false,
                         "x": 760,
                         "y": 960,
                         "wires": [
                                 "5af68d9f.4c24b4",
                                 "d702c4c8.ddc6f8"
                         "type": "debug",
                         "name": "",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 940,
                         "y": 920,
                         "wires": []
                         "type": "debug",
                         "name": "",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "statusVal": "",
                         "x": 1150,
                         "y": 960,
                         "wires": []
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 950,
                         "y": 960,
                         "wires": [
                                 "4d5422a9.651b0c"
                  66er6 Offline
                  66er6 Offline
                  66er
                  schrieb am zuletzt editiert von 66er
                  @mickym
                  Hallo und schönen Sonntag.
                  Nochmals Danke für Deine bisherige Unterstützung.
                  Das Gelernte konnte ich inzwischen auf weitere Gerätetypen umsetzen. Soweit so gut. 👍
                  Doch nun scheitere ich an einem Gerät mit 4 Kanälen, der JSON ist entsprechend umfangreicher:
                  {"ble":{},"cloud":{"connected":false},"eth":{"ip":null},"input:0":{"id":0,"state":false},"input:1":{"id":1,"state":false},"input:2":{"id":2,"state":false},"input:3":{"id":3,"state":false},"mqtt":{"connected":true},"switch:0":{"id": 0, "source": "UI", "output": false, "apower": 0.000, "voltage": 237.237,"aenergy": {"total":0.021,"by_minute":[0.000,0.000,0.000],"minute_ts":1633241652},"temperature":{"tC":null, "tF":null}},"switch:1":{"id": 1, "source": "init", "output": false, "apower": 0.000, "voltage": 237.292,"aenergy": {"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1633241652},"temperature":{"tC":null, "tF":null}},"switch:2":{"id": 2, "source": "init", "output": false, "apower": 0.000, "voltage": 238.268,"aenergy": {"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1633241652},"temperature":{"tC":null, "tF":null}},"switch:3":{"id": 3, "source": "init", "output": false, "apower": 0.000, "voltage": 238.230,"aenergy": {"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1633241651},"temperature":{"tC":null, "tF":null}},"sys":{"mac":"95CCA87E43AC","restart_required":false,"time":"08:14","unixtime":1633241653,"uptime":741,"ram_size":236340,"ram_free":147172,"fs_size":474641,"fs_free":317515,"available_updates":{"beta":{"version":"0.9.0-beta1"}}},"wifi":{"sta_ip":"192.168.1.182","status":"got ip","ssid":"IoT","rssi":-58}}
                  Wie bekomme ich da die 4 Werte "output" sauber raus? Obwohl ich nach Deiner Vorlage auch hier vorgegangen bin, kommen am Debug-Node auch Meldungen der anderen Kanäle raus.
                  Bin für Deine Unterstützung sehr dankbar.
                  Edit:
                  So sieht mein aktuelles Ergebnis aus:
                  Auch die von Dir gezeigte Pfadübernahme aus dem DEBUG bringt mir leider nicht das gewünschte Ergebnis.
                  LG
                  Stefan
                  66er6 1 Antwort Letzte Antwort
                  • 66er6 66er
                    @mickym
                    Edit:
                    66er6 Offline
                    66er6 Offline
                    66er
                    Gefühlt 1000 Versuche später:
                    Geschafft und erledigt. 👍
                    (Freu' mich, denn am Besten bleibt es haften, wenn man selbst drauf gekommen ist. ;-) )
                    Die einzelnen Kanäle habe ich nun mittels eines "Switch" mit 4 Bedingungen gefiltert. Der restliche Ablauf funktioniert dann unverändert. 😊
                    LG
                    Stefan
                    • 66er6 66er
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @66er Ehrlich gesagt verstehe ich das Problem nicht. Man kann auch diese Werte ganz normal über den Pfad selektieren (Pfad kopieren):
                             "id": "f86a9994.9674a8",
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "{\"ble\":{},\"cloud\":{\"connected\":false},\"eth\":{\"ip\":null},\"input:0\":{\"id\":0,\"state\":false},\"input:1\":{\"id\":1,\"state\":false},\"input:2\":{\"id\":2,\"state\":false},\"input:3\":{\"id\":3,\"state\":false},\"mqtt\":{\"connected\":true},\"switch:0\":{\"id\": 0, \"source\": \"UI\", \"output\": false, \"apower\": 0.000, \"voltage\": 237.237,\"aenergy\": {\"total\":0.021,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:1\":{\"id\": 1, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 237.292,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:2\":{\"id\": 2, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 238.268,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241652},\"temperature\":{\"tC\":null, \"tF\":null}},\"switch:3\":{\"id\": 3, \"source\": \"init\", \"output\": false, \"apower\": 0.000, \"voltage\": 238.230,\"aenergy\": {\"total\":0.000,\"by_minute\":[0.000,0.000,0.000],\"minute_ts\":1633241651},\"temperature\":{\"tC\":null, \"tF\":null}},\"sys\":{\"mac\":\"95CCA87E43AC\",\"restart_required\":false,\"time\":\"08:14\",\"unixtime\":1633241653,\"uptime\":741,\"ram_size\":236340,\"ram_free\":147172,\"fs_size\":474641,\"fs_free\":317515,\"available_updates\":{\"beta\":{\"version\":\"0.9.0-beta1\"}}},\"wifi\":{\"sta_ip\":\"192.168.1.182\",\"status\":\"got ip\",\"ssid\":\"IoT\",\"rssi\":-58}}",
                             "x": 270,
                             "y": 1280,
                             "wires": [
                                     "6cd75bd9.78f334"
                             "id": "6cd75bd9.78f334",
                             "type": "json",
                             "name": "",
                             "action": "",
                             "pretty": false,
                             "x": 440,
                             "y": 1280,
                             "wires": [
                                     "d59ab49f.83adb8",
                                     "e409ee82.60264",
                                     "7e3fb303.82128c",
                                     "efc2f40c.3bb7f8",
                                     "b65c559e.7ae848"
                             "id": "efc2f40c.3bb7f8",
                             "type": "change",
                             "name": "switch3",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "payload[\"switch:3\"].output",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 640,
                             "y": 1340,
                             "wires": [
                                     "1011a999.7fcb76"
                             "id": "7e3fb303.82128c",
                             "type": "change",
                             "name": "switch2",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "payload[\"switch:2\"].output",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 640,
                             "y": 1300,
                             "wires": [
                                     "4d31248e.23a35c"
                             "id": "e409ee82.60264",
                             "type": "change",
                             "name": "switch1",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "payload[\"switch:1\"].output",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 640,
                             "y": 1260,
                             "wires": [
                                     "91670dba.155fc"
                             "id": "d59ab49f.83adb8",
                             "type": "change",
                             "name": "switch0",
                             "rules": [
                                     "t": "set",
                                     "p": "payload",
                                     "pt": "msg",
                                     "to": "payload[\"switch:0\"].output",
                                     "tot": "msg"
                             "action": "",
                             "property": "",
                             "from": "",
                             "to": "",
                             "reg": false,
                             "x": 640,
                             "y": 1220,
                             "wires": [
                                     "5c94d229.fcf79c"
                             "id": "b65c559e.7ae848",
                             "type": "debug",
                             "name": "",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "true",
                             "targetType": "full",
                             "statusVal": "",
                             "x": 420,
                             "y": 1360,
                             "wires": []
                             "id": "5c94d229.fcf79c",
                             "type": "debug",
                             "name": "switch0",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "complete": "payload",
                             "targetType": "msg",
                             "statusVal": "",
                             "x": 820,
                             "y": 1220,
                             "wires": []
                             "id": "91670dba.155fc",
                             "type": "debug",
                             "name": "switch1",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 820,
                             "y": 1260,
                             "wires": []
                             "id": "4d31248e.23a35c",
                             "type": "debug",
                             "name": "switch2",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 820,
                             "y": 1300,
                             "wires": []
                             "id": "1011a999.7fcb76",
                             "type": "debug",
                             "name": "switch3",
                             "active": true,
                             "tosidebar": true,
                             "console": false,
                             "tostatus": false,
                             "statusVal": "",
                             "x": 820,
                             "y": 1340,
                             "wires": []
                      Verstehe nicht warum man da irgendwas filtern muss - klappt ganz normal:
                      • mickymM mickym
                               "type": "inject",
                               "name": "",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 270,
                               "y": 1280,
                               "wires": [
                                       "6cd75bd9.78f334"
                               "type": "json",
                               "name": "",
                               "action": "",
                               "pretty": false,
                               "x": 440,
                               "y": 1280,
                               "wires": [
                                       "d59ab49f.83adb8",
                                       "e409ee82.60264",
                                       "7e3fb303.82128c",
                                       "efc2f40c.3bb7f8",
                                       "b65c559e.7ae848"
                               "type": "change",
                               "name": "switch3",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 640,
                               "y": 1340,
                               "wires": [
                                       "1011a999.7fcb76"
                               "type": "change",
                               "name": "switch2",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 640,
                               "y": 1300,
                               "wires": [
                                       "4d31248e.23a35c"
                               "type": "change",
                               "name": "switch1",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 640,
                               "y": 1260,
                               "wires": [
                                       "91670dba.155fc"
                               "type": "change",
                               "name": "switch0",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 640,
                               "y": 1220,
                               "wires": [
                                       "5c94d229.fcf79c"
                               "type": "debug",
                               "name": "",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "true",
                               "statusVal": "",
                               "x": 420,
                               "y": 1360,
                               "wires": []
                               "type": "debug",
                               "name": "switch0",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 820,
                               "y": 1220,
                               "wires": []
                               "type": "debug",
                               "name": "switch1",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 820,
                               "y": 1260,
                               "wires": []
                               "type": "debug",
                               "name": "switch2",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 820,
                               "y": 1300,
                               "wires": []
                               "type": "debug",
                               "name": "switch3",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 820,
                               "y": 1340,
                               "wires": []
                        66er6 Offline
                        66er6 Offline
                        66er
                        @mickym
                        Danke für's Feedback.
                        Vielleicht hatte sich auch bei mir ein Fehler eingeschlichen!?
                        Stehe ja erst am Anfang mit MQTT und NodeRed.
                        Da heißt es schon mal hinfallen, aufstehen und weitermachen.
                        Danke nochmal. 👍
                        (PS: Werde es nochmal gegenchecken. Sollte dann ja auch bei mir laufen.)
                        LG
                        Stefan
                        • 66er6 66er
                          @mickym
                          Danke nochmal. 👍
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @66er Du kannst auch jedes Switch Objekt nur auf die Objektebene herauslösen und dann die Eigenschaften eines Switches in einem 2. Schritt bearbeiten. Deiner Fantasie sind keine Grenzen gesetzt:
                                 "type": "inject",
                                 "name": "",
                                 "props": [
                                         "p": "payload"
                                 "repeat": "",
                                 "crontab": "",
                                 "once": false,
                                 "onceDelay": 0.1,
                                 "topic": "",
                                 "x": 330,
                                 "y": 1320,
                                 "wires": [
                                         "6cd75bd9.78f334"
                                 "type": "json",
                                 "name": "",
                                 "action": "",
                                 "pretty": false,
                                 "x": 500,
                                 "y": 1320,
                                 "wires": [
                                         "d59ab49f.83adb8",
                                         "e409ee82.60264",
                                         "7e3fb303.82128c",
                                         "efc2f40c.3bb7f8",
                                         "b65c559e.7ae848"
                                 "type": "change",
                                 "name": "switch3",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[\"switch:3\"]",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 700,
                                 "y": 1480,
                                 "wires": [
                                         "666be515.af213c",
                                         "9b305a05.dd89e8"
                                 "type": "change",
                                 "name": "switch2",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[\"switch:2\"]",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 700,
                                 "y": 1400,
                                 "wires": [
                                         "1306fb28.2e72e5",
                                         "ffe7aeed.e875e"
                                 "type": "change",
                                 "name": "switch1",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[\"switch:1\"]",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 700,
                                 "y": 1320,
                                 "wires": [
                                         "1ab33829.4b2438",
                                         "9a153f8f.51f3a"
                                 "type": "change",
                                 "name": "switch0",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload[\"switch:0\"]",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 700,
                                 "y": 1240,
                                 "wires": [
                                         "10fa2b5a.1d3fd5",
                                         "d9d71e77.faca5"
                                 "type": "debug",
                                 "name": "",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "complete": "true",
                                 "statusVal": "",
                                 "x": 480,
                                 "y": 1400,
                                 "wires": []
                                 "id": "10fa2b5a.1d3fd5",
                                 "type": "change",
                                 "name": "output",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload.output",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1220,
                                 "wires": [
                                         "21f577ba.3b76c8"
                                 "id": "d9d71e77.faca5",
                                 "type": "change",
                                 "name": "energy",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "to": "payload.aenergy.total",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1260,
                                 "wires": [
                                         "f8d0d07f.86fff"
                                 "id": "1ab33829.4b2438",
                                 "type": "change",
                                 "name": "output",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1300,
                                 "wires": [
                                         "d763e07f.5c467"
                                 "id": "9a153f8f.51f3a",
                                 "type": "change",
                                 "name": "energy",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1340,
                                 "wires": [
                                         "ae57bd4a.003a3"
                                 "id": "1306fb28.2e72e5",
                                 "type": "change",
                                 "name": "output",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1380,
                                 "wires": [
                                         "63096a35.170df4"
                                 "id": "ffe7aeed.e875e",
                                 "type": "change",
                                 "name": "energy",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1420,
                                 "wires": [
                                         "678ced56.3d2c44"
                                 "id": "666be515.af213c",
                                 "type": "change",
                                 "name": "output",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1460,
                                 "wires": [
                                         "85150103.9bf37"
                                 "id": "9b305a05.dd89e8",
                                 "type": "change",
                                 "name": "energy",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "msg"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 890,
                                 "y": 1500,
                                 "wires": [
                                         "5dfb6b7f.67f114"
                                 "id": "21f577ba.3b76c8",
                                 "type": "debug",
                                 "name": "switch 0 output",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1220,
                                 "wires": []
                                 "id": "f8d0d07f.86fff",
                                 "type": "debug",
                                 "name": "switch 0 energy",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1260,
                                 "wires": []
                                 "id": "d763e07f.5c467",
                                 "type": "debug",
                                 "name": "switch 1 output",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1300,
                                 "wires": []
                                 "id": "ae57bd4a.003a3",
                                 "type": "debug",
                                 "name": "switch 1 energy",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1340,
                                 "wires": []
                                 "id": "63096a35.170df4",
                                 "type": "debug",
                                 "name": "switch 2 output",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1380,
                                 "wires": []
                                 "id": "678ced56.3d2c44",
                                 "type": "debug",
                                 "name": "switch 2 energy",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1420,
                                 "wires": []
                                 "id": "85150103.9bf37",
                                 "type": "debug",
                                 "name": "switch 3 output",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1460,
                                 "wires": []
                                 "id": "5dfb6b7f.67f114",
                                 "type": "debug",
                                 "name": "switch 3 energy",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 1080,
                                 "y": 1500,
                                 "wires": []
                          • mickymM mickym
                                   "type": "inject",
                                   "name": "",
                                   "props": [
                                           "p": "payload"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "x": 330,
                                   "y": 1320,
                                   "wires": [
                                           "6cd75bd9.78f334"
                                   "type": "json",
                                   "name": "",
                                   "action": "",
                                   "pretty": false,
                                   "x": 500,
                                   "y": 1320,
                                   "wires": [
                                           "d59ab49f.83adb8",
                                           "e409ee82.60264",
                                           "7e3fb303.82128c",
                                           "efc2f40c.3bb7f8",
                                           "b65c559e.7ae848"
                                   "type": "change",
                                   "name": "switch3",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 700,
                                   "y": 1480,
                                   "wires": [
                                           "666be515.af213c",
                                           "9b305a05.dd89e8"
                                   "type": "change",
                                   "name": "switch2",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 700,
                                   "y": 1400,
                                   "wires": [
                                           "1306fb28.2e72e5",
                                           "ffe7aeed.e875e"
                                   "type": "change",
                                   "name": "switch1",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 700,
                                   "y": 1320,
                                   "wires": [
                                           "1ab33829.4b2438",
                                           "9a153f8f.51f3a"
                                   "type": "change",
                                   "name": "switch0",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 700,
                                   "y": 1240,
                                   "wires": [
                                           "10fa2b5a.1d3fd5",
                                           "d9d71e77.faca5"
                                   "type": "debug",
                                   "name": "",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "true",
                                   "statusVal": "",
                                   "x": 480,
                                   "y": 1400,
                                   "wires": []
                                   "type": "change",
                                   "name": "output",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1220,
                                   "wires": [
                                           "21f577ba.3b76c8"
                                   "type": "change",
                                   "name": "energy",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1260,
                                   "wires": [
                                           "f8d0d07f.86fff"
                                   "type": "change",
                                   "name": "output",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1300,
                                   "wires": [
                                           "d763e07f.5c467"
                                   "type": "change",
                                   "name": "energy",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1340,
                                   "wires": [
                                           "ae57bd4a.003a3"
                                   "type": "change",
                                   "name": "output",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1380,
                                   "wires": [
                                           "63096a35.170df4"
                                   "type": "change",
                                   "name": "energy",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1420,
                                   "wires": [
                                           "678ced56.3d2c44"
                                   "type": "change",
                                   "name": "output",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1460,
                                   "wires": [
                                           "85150103.9bf37"
                                   "type": "change",
                                   "name": "energy",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 1500,
                                   "wires": [
                                           "5dfb6b7f.67f114"
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1220,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1260,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1300,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1340,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1380,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1420,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1460,
                                   "wires": []
                                   "type": "debug",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 1080,
                                   "y": 1500,
                                   "wires": []
                            66er6 Offline
                            66er6 Offline
                            66er
                            @mickym
                            Sieht ja fast aus, wie mein Ergebnis. 👍
                            So bin ich zu Erfolg gekommen:
                            LG
                            Stefan
                            • 66er6 66er
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @66er Falls Du das nur in eigene DP wegschreiben willst, dann kannst Dir ja mal meinen Subflow anschauen:
                              https://forum.iobroker.net/topic/43856/json-string-oder-java-object-in-iobroker-struktur
                              Seit Admin 5 musst Du dann zwar noch etwas nacharbeiten, in dem Du mit einem Skript die fehlenden Objekte noch erzeugst. Aber falls Du ihn nutzen willst, bekommst Du so alles in DP zerlegt.
                              IN meinen Augen ist das zwar nicht sinnvoll, aber ich sehe ja, dass Du mit Deinem Flow nichts anderes machst.
                              Oder Du nimmst den mqtt-Adapter im iobroker - dann hast Du ebenfalls alles als einzelne Datenpunkte.
                              • mickymM mickym
                                66er6 Offline
                                66er6 Offline
                                66er
                                Schau mir den anderen Link natürlich noch an.
                                Warum ist das nicht sinnvoll? (Ich lerne mich ja gerade erst ein und wenn ich hier was falsch mache, sollte ich verstehen warum.)
                                Versuchsweise schreibe ich die Werte da rein und visualisiere sie dann.
                                Leider geben die Geräte nur einen "Sammelstring" nach MQTT und keine einzelnen, direkt verwertbare Datenpunkte.
                                LG
                                Stefan
                                • 66er6 66er
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @66er OK zum Visualisieren hängt davon ab, was Du halt nutzt. Für VIS ja.
                                  Wenn Du das Node-Red Dashborad nutzt, dann fütterst Du ja den switch mit der payload und der Switch behält ja den Status.
                                  Aber Du hast Recht für VIS ist es sinnvoll.
                                  Ansonsten ist zwar schön alles in eigene Datenpunkte zu schreiben, aber gibt Dir ja keinen Mehrwert, weil die Info letztlich in dem JSON String enthalten ist. Wie gesagt für VIS ist es sinnvoll.
                                  • mickymM mickym
                                    66er6 Offline
                                    66er6 Offline
                                    66er
                                    @mickym
                                    Ja, ich nutze VIS.
                                    Hier noch ein Screenshot von MQTT:
                                    Im RPC-String unter events steht alles drin.
                                    LG
                                    Stefan
                                    • 66er6 66er
                                      @mickym
                                      Ja, ich nutze VIS.
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @66er Ja wie gesagt, wenn Du nur das wieder in DP speicherst, was Du visualisierst - passt das schon!!!
                                      • mickymM mickym
                                        66er6 Offline
                                        66er6 Offline
                                        66er
                                        @mickym
                                        Prima,
                                        und ja: alle anderen Datenpunkt bleiben im JSON ohne das ich die anpacke.
                                        Danke, wieder mein Wissen und Verständnis für MQTT erweitert.👍
                                        LG
                                        Stefan
                                        R 1 Antwort Letzte Antwort
                                        • 66er6 66er
                                          @mickym
                                          Prima,
                                          rieders
                                          schrieb am zuletzt editiert von rieders
                                          Hallo
                                          Ich versuche gerade mein Stromzähler String zu zerlegen.
                                          Eine Verbindung zum mqtt-Broker besteht, die Daten werden auch im Debug angezeigt.
                                          Ich habe schon einiges Versuch, ich bekomme einfach nicht die Werte einzeln angezeigt.
                                          Smartmeter_Garten/tele/SENSOR : msg.payload : string[643]
                                          "{"Time":"2023-01-13T12:54:35","SDM630":{"1":178,"Voltage_P1":231.88,"Voltage_P2":231.5,"Voltage_P3":232.49,"Current_P1":0,"Current_P2":0.1,"Current_P3":0,"Power_P1":0,"Power_P2":22.35,"Power_P3":0,"Frequenz":50.01,"Total":534.694,"phase_angle":-9.73,"Import_nres":186.145,"Export_nres":348.549,"Export_P1":13.568,"Export_P2":334.981,"Export_P3":0,"Import_P1":19.409,"Import_P2":131.003,"Import_P3":35.733,"L1_total_kwh":32.977,"L2_total_kwh":465.984,"L3_total_kwh":35.733,"Blindleistung_L1":0,"Blindleistung_L2":-7.734,"Blindleistung_L3":0,"Scheinleistung_L1":0,"Scheinleistung_L2":22.627,"Scheinleistung_L3":0,"VAh_since_last_reset":565.815}}"
                                          Ich hoffe jemand kann mir weiter helfen.
                                          "id": "553525487db580b5",
                                          "type": "mqtt in",
                                          "z": "eb71b4cddc9da37a",
                                          "name": "Smartmeter_Garten/tele/SENSOR",
                                          "topic": "Smartmeter_Garten/tele/SENSOR",
                                          "qos": "2",
                                          "datatype": "auto-detect",
                                          "broker": "e7e1e2255e66e588",
                                          "nl": false,
                                          "rap": true,
                                          "rh": "2",
                                          "inputs": 0,
                                          "x": 180,
                                          "y": 260,
                                          "wires": [
                                          "04a7ba72539a5cb1",
                                          "df378652670347e0"
                                          "id": "b0fcb45d6d8ab9f4",
                                          "type": "ui_gauge",
                                          "name": "Test",
                                          "group": "67140eec2a9994a9",
                                          "order": 0,
                                          "width": 0,
                                          "height": 0,
                                          "gtype": "gage",
                                          "title": "Voltage_P1",
                                          "label": "",
                                          "format": "{{Value}}",
                                          "min": "1",
                                          "max": "260",
                                          "colors": [
                                          "#b30000",
                                          "#e6e600",
                                          "#00b815"
                                          "seg1": "",
                                          "seg2": "",
                                          "x": 890,
                                          "y": 260,
                                          "wires": []
                                          "id": "9faaac80e56b9d83",
                                          "type": "ui_chart",
                                          "name": "",
                                          "order": 0,
                                          "width": 0,
                                          "height": 0,
                                          "label": "chart",
                                          "chartType": "line",
                                          "legend": "false",
                                          "xformat": "HH:mm:ss",
                                          "interpolate": "linear",
                                          "nodata": "",
                                          "dot": false,
                                          "ymin": "0",
                                          "ymax": "260",
                                          "removeOlder": 1,
                                          "removeOlderPoints": "",
                                          "removeOlderUnit": "3600",
                                          "cutout": 0,
                                          "useOneColor": false,
                                          "useUTC": false,
                                          "colors": [
                                          "#1f77b4",
                                          "#aec7e8",
                                          "#ff7f0e",
                                          "#2ca02c",
                                          "#98df8a",
                                          "#d62728",
                                          "#ff9896",
                                          "#9467bd",
                                          "#c5b0d5"
                                          "outputs": 1,
                                          "useDifferentColor": false,
                                          "x": 890,
                                          "y": 320,
                                          "wires": [
                                          "id": "04a7ba72539a5cb1",
                                          "type": "json",
                                          "name": "V1",
                                          "action": "",
                                          "pretty": false,
                                          "x": 450,
                                          "y": 200,
                                          "wires": [
                                          "35354018b6c6c095",
                                          "639599639f78788c"
                                          "id": "6f72cb37f4aa2278",
                                          "type": "debug",
                                          "name": "debug 1",
                                          "active": true,
                                          "tosidebar": true,
                                          "console": false,
                                          "tostatus": false,
                                          "statusVal": "",
                                          "x": 900,
                                          "y": 200,
                                          "wires": []
                                          "id": "35354018b6c6c095",
                                          "type": "debug",
                                          "name": "debug 2",
                                          "active": true,
                                          "tosidebar": true,
                                          "console": false,
                                          "tostatus": false,
                                          "statusVal": "",
                                          "x": 620,
                                          "y": 120,
                                          "wires": []
                                          "id": "639599639f78788c",
                                          "type": "change",
                                          "name": "",
                                          "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "payload["SDM630"].Voltage_P1",
                                          "tot": "msg"
                                          "action": "",
                                          "property": "",
                                          "from": "",
                                          "to": "",
                                          "reg": false,
                                          "x": 670,
                                          "y": 200,
                                          "wires": [
                                          "6f72cb37f4aa2278",
                                          "b0fcb45d6d8ab9f4",
                                          "9faaac80e56b9d83"
                                          "id": "a5192d83b6ce2f1c",
                                          "type": "mqtt out",
                                          "name": "V1",
                                          "topic": "Testzähler",
                                          "qos": "",
                                          "retain": "",
                                          "respTopic": "",
                                          "contentType": "",
                                          "userProps": "",
                                          "correl": "",
                                          "expiry": "",
                                          "broker": "d19896c9b4e98e28",
                                          "x": 750,
                                          "y": 340,
                                          "wires": []
                                          "id": "df378652670347e0",
                                          "type": "function",
                                          "name": "function 2",
                                          "func": "\nreturn msg;payload["SDM630"].Voltage_P1",
                                          "outputs": 1,
                                          "noerr": 0,
                                          "initialize": "",
                                          "finalize": "",
                                          "libs": [],
                                          "x": 560,
                                          "y": 340,
                                          "wires": [
                                          "a5192d83b6ce2f1c"
                                          "id": "e7e1e2255e66e588",
                                          "type": "mqtt-broker",
                                          "name": "mqtt-broker",
                                          "broker": "192.168.1.146",
                                          "port": "1885",
                                          "clientid": "",
                                          "autoConnect": true,
                                          "usetls": false,
                                          "protocolVersion": "4",
                                          "keepalive": "60",
                                          "cleansession": true,
                                          "birthTopic": "",
                                          "birthQos": "0",
                                          "birthPayload": "",
                                          "birthMsg": {},
                                          "closeTopic": "",
                                          "closeQos": "0",
                                          "closePayload": "",
                                          "closeMsg": {},
                                          "willTopic": "",
                                          "willQos": "0",
                                          "willPayload": "",
                                          "willMsg": {},
                                          "userProps": "",
                                          "sessionExpiry": ""
                                          "id": "67140eec2a9994a9",
                                          "type": "ui_group",
                                          "name": "Test",
                                          "tab": "71f6d060a354b8d9",
                                          "order": 1,
                                          "disp": true,
                                          "width": "6",
                                          "collapse": false
                                          "id": "d19896c9b4e98e28",
                                          "name": "Venus OS",
                                          "broker": "192.168.1.37",
                                          "port": "1883",
                                          "clientid": "test-client",
                                          "usetls": false,
                                          "keepalive": "60",
                                          "birthTopic": "",
                                          "birthQos": "0",
                                          "birthPayload": "",
                                          "birthMsg": {},
                                          "closeTopic": "",
                                          "closeQos": "0",
                                          "closePayload": "",
                                          "closeMsg": {},
                                          "willTopic": "",
                                          "willQos": "0",
                                          "willPayload": "",
                                          "willMsg": {},
                                          "userProps": "",
                                          "sessionExpiry": ""
                                          "id": "71f6d060a354b8d9",
                                          "type": "ui_tab",
                                          "name": "Home",
                                          "icon": "dashboard",
                                          "disabled": false,
                                          "hidden": false
                                          Grüße André
                                          mickymM 1 2 Antworten Letzte Antwort
