  4. Test PV Forecast Adapter
    apollon77A
forecastphotovoltaik
881 Beiträge 114 Kommentatoren 448.0k Aufrufe 108 Beobachtet
  • P PatrickWalther
    @latzi hallo, was hast du bei pv-systeme eingetragen?
    LatziL
    LatziL
    Latzi
    schrieb am zuletzt editiert von Latzi
    #241
    @patrickwalther
    Nach dem Adapterstart hab ich folgende Meldungen (mit dem warn am Ende):
    2022-02-21 19:51:06.614 - info: host.Pi4-Server instance system.adapter.pvforecast.0 started with pid 6789
    2022-02-21 19:51:10.131 - info: pvforecast.0 (6789) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v14.19.0, js-controller: 3.3.22
    2022-02-21 19:51:10.240 - info: pvforecast.0 (6789) Create States for: Sued
    2022-02-21 19:51:10.242 - info: pvforecast.0 (6789) Create States for: West
    2022-02-21 19:51:10.254 - info: pvforecast.0 (6789) getPv
    2022-02-21 19:51:10.255 - info: pvforecast.0 (6789) apikey: false
    2022-02-21 19:51:10.256 - info: pvforecast.0 (6789) url for platn Sued : https://api.forecast.solar/estimate/48.xxxx/14.xxxx/7/-3/9
    2022-02-21 19:51:10.335 - info: pvforecast.0 (6789) url for platn West : https://api.forecast.solar/estimate/48.xxxx/14.xxxx/7/87/3
    2022-02-21 19:51:10.530 - info: pvforecast.0 (6789) Recive data for Sued: {"result":{"watts":{"2022-02-21 06:50:00":0,"2022-02-21 06:55:00":63,"2022-02-21 07:00:00":319,"2022-02-21 08:00:00":850,"2022-02-21 09:00:00":1311,"2022-02-21 10:00:00":1655,"2022-02-21 11:00:00":1851,"2022-02-21 12:00:00":1993,"2022-02-21 13:00:00":2348,"2022-02-21 14:00:00":2148,"2022-02-21 15:00:00":1664,"2022-02-21 16:00:00":960,"2022-02-21 17:00:00":382,"2022-02-21 17:19:00":72,"2022-02-21 17:38:00":0,"2022-02-22 06:48:00":0,"2022-02-22 06:54:00":72,"2022-02-22 07:00:00":339,"2022-02-22 08:00:00":872,"2022-02-22 09:00:00":1333,"2022-02-22 10:00:00":1693,"2022-02-22 11:00:00":1939,"2022-02-22 12:00:00":2113,"2022-02-22 13:00:00":2236,"2022-02-22 14:00:00":2360,"2022-02-22 15:00:00":1996,"2022-02-22 16:00:00":1187,"2022-02-22 17:00:00":372,"2022-02-22 17:20:00":72,"2022-02-22 17:39:00":0},"watt_hours":{"2022-02-21 06:50:00":0,"2022-02-21 06:55:00":5,"2022-02-21 07:00:00":32,"2022-02-21 08:00:00":882,"2022-02-21 09:00:00":2193,"2022-02-21 10:00:00":3848,"2022-02-21 11:00:00":5699,"2022-02-21 12:00:00":7692,"2022-02-21 13:00:00":10040,"2022-02-21 14:00:00":12188,"2022-02-21 15:00:00":13852,"2022-02-21 16:00:00":14812,"2022-02-21 17:00:00":15194,"2022-02-21 17:19:00":15217,"2022-02-21 17:38:00":15217,"2022-02-22 06:48:00":0,"2022-02-22 06:54:00":7,"2022-02-22 07:00:00":41,"2022-02-22 08:00:00":913,"2022-02-22 09:00:00":2246,"2022-02-22 10:00:00":3939,"2022-02-22 11:00:00":5878,"2022-02-22 12:00:00":7991,"2022-02-22 13:00:00":10227,"2022-02-22 14:00:00":12587,"2022-02-22 15:00:00":14583,"2022-02-22 16:00:00":15770,"2022-02-22 17:00:00":16142,"2022-02-22 17:20:00":16166,"2022-02-22 17:39:00":16166},"watt_hours_day":{"2022-02-21":15217,"2022-02-22":16166}},"message":{"code":0,"type":"success","text":"","info":{"latitude":48.xxxx,"longitude":14.xxxx,"place":"xxxx, AT","timezone":"Europe/Vienna"},"ratelimit":{"period":3600,"limit":12,"remaining":8}}}
    2022-02-21 19:51:10.644 - info: pvforecast.0 (6789) Recive data for West: {"result":{"watts":{"2022-02-21 06:50:00":0,"2022-02-21 06:55:00":18,"2022-02-21 07:00:00":96,"2022-02-21 08:00:00":263,"2022-02-21 09:00:00":413,"2022-02-21 10:00:00":526,"2022-02-21 11:00:00":590,"2022-02-21 12:00:00":642,"2022-02-21 13:00:00":762,"2022-02-21 14:00:00":717,"2022-02-21 15:00:00":574,"2022-02-21 16:00:00":343,"2022-02-21 17:00:00":142,"2022-02-21 17:19:00":27,"2022-02-21 17:38:00":0,"2022-02-22 06:48:00":0,"2022-02-22 06:54:00":21,"2022-02-22 07:00:00":99,"2022-02-22 08:00:00":267,"2022-02-22 09:00:00":418,"2022-02-22 10:00:00":536,"2022-02-22 11:00:00":615,"2022-02-22 12:00:00":678,"2022-02-22 13:00:00":726,"2022-02-22 14:00:00":788,"2022-02-22 15:00:00":699,"2022-02-22 16:00:00":449,"2022-02-22 17:00:00":149,"2022-02-22 17:20:00":30,"2022-02-22 17:39:00":0},"watt_hours":{"2022-02-21 06:50:00":0,"2022-02-21 06:55:00":2,"2022-02-21 07:00:00":10,"2022-02-21 08:00:00":273,"2022-02-21 09:00:00":686,"2022-02-21 10:00:00":1212,"2022-02-21 11:00:00":1802,"2022-02-21 12:00:00":2444,"2022-02-21 13:00:00":3206,"2022-02-21 14:00:00":3923,"2022-02-21 15:00:00":4497,"2022-02-21 16:00:00":4840,"2022-02-21 17:00:00":4982,"2022-02-21 17:19:00":4990,"2022-02-21 17:38:00":4990,"2022-02-22 06:48:00":0,"2022-02-22 06:54:00":2,"2022-02-22 07:00:00":12,"2022-02-22 08:00:00":279,"2022-02-22 09:00:00":697,"2022-02-22 10:00:00":1233,"2022-02-22 11:00:00":1848,"2022-02-22 12:00:00":2526,"2022-02-22 13:00:00":3252,"2022-02-22 14:00:00":4040,"2022-02-22 15:00:00":4739,"2022-02-22 16:00:00":5188,"2022-02-22 17:00:00":5337,"2022-02-22 17:20:00":5347,"2022-02-22 17:39:00":5347},"watt_hours_day":{"2022-02-21":4990,"2022-02-22":5347}},"message":{"code":0,"type":"success","text":"","info":{"latitude":48.xxxx,"longitude":14.xxxx,"place":"xxxx, AT","timezone":"Europe/Vienna"},"ratelimit":{"period":3600,"limit":12,"remaining":9}}}
    2022-02-21 19:51:10.832 - warn: pvforecast.0 (6789) Clear yet terminated timer undefined
    DiginixD MeistertrM 2 Antworten Letzte Antwort
    • LatziL Latzi
      @patrickwalther
      DiginixD
      DiginixD
      Diginix
      #242
      @latzi Lösch die Geokoordinaten aus dem Logauszug außer es ist dir egal oder du hast nicht die deines Hauses genommen. Ich trag in allen Adaptern oder Tasmota oder Shellys welche aus dem Ortskern ein. Dann muss ich bei iobroker Logs nie dran denken sie zu anonymisieren falls sie mit rein kommen.
      Immerhin hat er nun Werte für beide Anlagen abgerufen und sollte auch Objekte mit den Werten erstellt haben. Den Fehler habe ich bei mir nicht. Müsste @PatrickWalther beurteilen.
      ..:: So long! Tom ::..
      LatziL 1 Antwort Letzte Antwort
      • DiginixD Diginix
        LatziL
        LatziL
        Latzi
        #243
        @diginix
        Danke, bei den Ergebnissen hatte ich´s rausgenommen, jedoch bei der url übersehen 👍
        Daten kommen an, DP´s werden erzeugt, alles soweit gut - mich irritiert nur die warn-Meldung (kommt weiterhin im 10 Minutentakt).
        • LatziL Latzi
          @diginix
          DiginixD
          DiginixD
          Diginix
          #244
          @latzi Eigentlich hast du ja alle 60 min eingestellt, deswegen ist das mit den 10 min komisch. Als wüsste der Adapter nichts von den 60 min. Trag doch nochmal 30 min ein und dann ggf. noch mal 60 min, damit es neu gespeichert wird. Ich habe abweichend noch den Haken für Werte pro Stunde. Vllt stimmt ohne den Haken noch was im Adapter nicht...
          MeistertrM 1 Antwort Letzte Antwort
          • DiginixD Diginix
            MeistertrM
            MeistertrM
            Meistertr
            #245
            @diginix das mit den 10 min ist schon richtig, das ist nur ein interner Daten Abruf. ich schau mal, da wird ein timout nicht zurückgesetzt. hab bei mir im Produktionssystem irgendwie auch eine Dauer loop drin, schau ich heute Abend ob ich die eliminieren kann..
            • LatziL Latzi
              @patrickwalther
              MeistertrM
              MeistertrM
              Meistertr
              #246
              @latzi fehler der warnung gefunden wird gefixed
              LatziL 2 Antworten Letzte Antwort
              • MeistertrM Meistertr
                LatziL
                LatziL
                Latzi
                #247
                @meistertr
                super, vielen Dank !👍 👏
                  LatziL
                  LatziL
                  Latzi
                  #248
                  @meistertr sagte in Test PV Forecast Adapter:
                  läuft seit dem update bisher problemlos, vielen Dank @Meistertr !!!
                  • O
                    O
                    oxident
                    schrieb am zuletzt editiert von oxident
                    #249
                    Habe jetzt auch die 0.1.x Instanz gelöscht und den Adapter deinstalliert. Dann den 0.2.2er installiert und alle Daten eingegeben.
                    Komischerweise sind die Werte in der summary jetzt etwas "verschoben" ... ich schätze mal, um eine Tausenderstelle:
                    Meiner Meinung nach müssten alle Werte durch 1000 dividiert werden. Bei den Einzelanlagen (2 Stk. bei mir) sieht es okay aus.
                    UPDATE: Nein, die Gesamtleistung bei den Einzelanlagen scheint auch um den Faktor 1000 zu hoch zu sein:
                    Einzelwerte pro Anlage sind jedoch korrekt.
                    • O oxident
                      DiginixD
                      DiginixD
                      Diginix
                      schrieb am zuletzt editiert von Diginix
                      #250
                      @oxident Ja, bei mir ist es auch falsch. Aber ich denke es ist nur die Einheit falsch im Datenpunkt.
                      Früher war es Wh. Die Einheit wieder auf Wh zu stellen ist mMn einfacher als alle Werte zu teilen und zu runden.
                      O 1 Antwort Letzte Antwort
                      • DiginixD Diginix
                        O
                        O
                        oxident
                        #251
                        @diginix Hmm, hätte ich kein Problem mit, müsste aber für diverse Skripte wissen, wo die Reise mittelfristig hingeht 😀
                        • O oxident
                          MeistertrM
                          MeistertrM
                          Meistertr
                          #252
                          @oxident ich passe es heute abend alles an und mache es in der config auswählbar ob kw oder watt
                          Joe MJ 1 Antwort Letzte Antwort
                            Joe MJ
                            Joe MJ
                            Joe M
                            schrieb am zuletzt editiert von Joe M
                            #253
                            @meistertr
                            Super Sache dein Adapter! Danke.
                            Glaube da hat sich weiterhin ein Dreher in der 0.2.3 versteckt:
                            Die Anlagenleistung im Reiter PV-Systems muss ich bei mir in Watt eintragen, dann passen die Stündlichen Werte und auch der Haken "values in watt instead of kw" funktioniert dann korrekt.
                            Dann ist aber die "power_day_kWh" um einen tausender zu hoch.
                            Bei Eintrag der Anlagenleistung im Reiter PV-Systems in KW stimmt die Tagesleistung, dann sind aber die Stundenwerte um den Faktor 1000 zu klein.
                            • DiginixD
                              DiginixD
                              Diginix
                              #254
                              @Meistertr
                              Wäre auch cool wenn der Adapter mal ins latest käme, bekomme von den Updates gar nichts mit wenn ich nicht regelmäßig bei Git vorbei schaue. Hab mir jetzt mal ein Watch gesetzt.
                              @joe-m Bei mir passen mMn alle Werte inkl Einheit wenn ich Watt im Adapter einstelle.
                              Achso die stündlichen sind dann in kW obwohl Watt eingestellt ist und auch als Einheit genommen wird.
                              In der JSONTable passt es aber und die verwende ich.
                              • P
                                P
                                PatrickWalther
                                #255
                                @diginix hallo, bin dabei, da ich allerdings viele Gesundheitliche Probleme habe ist es für mich momentan gar nicht einfach. Versuche aber mein bestes.
                                • P PatrickWalther
                                  DiginixD
                                  DiginixD
                                  Diginix
                                  #256
                                  @patrickwalther Kein Stress und gute Besserung!
                                  Mit 0.2.3 und Einstellung "Watt" ist für mich vorerst alles ok in den Objekten, mit denen ich arbeite.
                                  • MeistertrM
                                    MeistertrM
                                    Meistertr
                                    #257
                                    seit heute morgen gibt es die 0.2.4 in der kann man nun auch die Vorhersagen von solcast nutzen. vorteil hier: der api key ist kostenlos und man bekommt eine Auflösung von 30min. Meines erachtens sind die Vorhersagen auch noch etwas genauer als die von forecast.solar
                                    LatziL DiginixD 2 Antworten Letzte Antwort
                                      LatziL
                                      LatziL
                                      Latzi
                                      #258
                                      @meistertr
                                      hab ich gleich mal ausprobiert, erhalte aber einen Fehler, anbei log dazu:
                                      2022-02-26 10:00:24.276 - info: host.Pi4-Server "system.adapter.pvforecast.0" enabled
                                      2022-02-26 10:00:24.843 - info: host.Pi4-Server instance system.adapter.pvforecast.0 started with pid 2426
                                      2022-02-26 10:00:27.355 - info: pvforecast.0 (2426) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v14.19.0, js-controller: 3.3.22
                                      2022-02-26 10:00:27.403 - info: pvforecast.0 (2426) Create States for weather
                                      2022-02-26 10:00:27.605 - info: pvforecast.0 (2426) Create States for: Sued
                                      2022-02-26 10:00:27.606 - info: pvforecast.0 (2426) Create States for: West
                                      2022-02-26 10:00:27.715 - info: pvforecast.0 (2426) getPv
                                      2022-02-26 10:00:27.716 - info: pvforecast.0 (2426) apikey: true
                                      2022-02-26 10:00:27.717 - info: pvforecast.0 (2426) url for plant Sued : https://api.solcast.com.au/world_pv_power/forecasts?format=json&hours=48&loss_factor=1&latitude=4x.xxx&longitude=1x.xxx&tilt=7&azimuth=-177&capacity=9&api_key=blablabla
                                      2022-02-26 10:00:27.792 - info: pvforecast.0 (2426) url for plant West : https://api.solcast.com.au/world_pv_power/forecasts?format=json&hours=48&loss_factor=1&latitude=4x.xxx&longitude=1x.xxx&tilt=7&azimuth=93&capacity=3&api_key=blablabla
                                      2022-02-26 10:00:28.447 - info: pvforecast.0 (2426) Recive data for Sued: {"forecasts":[{"period_end":"2022-02-26T09:30:00.0000000Z","period":"PT30M","pv_estimate":1.815},{"period_end":"2022-02-26T10:00:00.0000000Z","period":"PT30M","pv_estimate":2.387},{"period_end":"2022-02-26T10:30:00.0000000Z","period":"PT30M","pv_estimate":2.885},{"period_end":"2022-02-26T11:00:00.0000000Z","period":"PT30M","pv_estimate":3.044},{"period_end":"2022-02-26T11:30:00.0000000Z","period":"PT30M","pv_estimate":2.651},{"period_end":"2022-02-26T12:00:00.0000000Z","period":"PT30M","pv_estimate":2.23},{"period_end":"2022-02-26T12:30:00.0000000Z","period":"PT30M","pv_estimate":2.054},{"period_end":"2022-02-26T13:00:00.0000000Z","period":"PT30M","pv_estimate":1.936},{"period_end":"2022-02-26T13:30:00.0000000Z","period":"PT30M","pv_estimate":1.725},{"period_end":"2022-02-26T14:00:00.0000000Z","period":"PT30M","pv_estimate":1.427},{"period_end":"2022-02-26T14:30:00.0000000Z","period":"PT30M","pv_estimate":1.108},{"period_end":"2022-02-26T15:00:00.0000000Z","period":"PT30M","pv_estimate":0.866},{"period_end":"2022-02-26T15:30:00.0000000Z","period":"PT30M","pv_estimate":0.589},{"period_end":"2022-02-26T16:00:00.0000000Z","period":"PT30M","pv_estimate":0.263},{"period_end":"2022-02-26T16:30:00.0000000Z","period":"PT30M","pv_estimate":0.088},{"period_end":"2022-02-26T17:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T17:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T18:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T18:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T19:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T19:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T20:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T20:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T21:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T21:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T22:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T22:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T23:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T23:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T00:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T00:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T01:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T01:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T02:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T02:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T03:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T03:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T04:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T04:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T05:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T05:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T06:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T06:30:00.0000000Z","period":"PT30M","pv_estimate":0.081},{"period_end":"2022-02-27T07:00:00.0000000Z","period":"PT30M","pv_estimate":0.268},{"period_end":"2022-02-27T07:30:00.0000000Z","period":"PT30M","pv_estimate":0.812},{"period_end":"2022-02-27T08:00:00.0000000Z","period":"PT30M","pv_estimate":1.833},{"period_end":"2022-02-27T08:30:00.0000000Z","period":"PT30M","pv_estimate":2.848},{"period_end":"2022-02-27T09:00:00.0000000Z","period":"PT30M","pv_estimate":3.453},{"period_end":"2022-02-27T09:30:00.0000000Z","period":"PT30M","pv_estimate":4.046},{"period_end":"2022-02-27T10:00:00.0000000Z","period":"PT30M","pv_estimate":4.505},{"period_end":"2022-02-27T10:30:00.0000000Z","period":"PT30M","pv_estimate":4.916},{"period_end":"2022-02-27T11:00:00.0000000Z","period":"PT30M","pv_estimate":5.119},{"period_end":"2022-02-27T11:30:00.0000000Z","period":"PT30M","pv_estimate":5.191},{"period_end":"2022-02-27T12:00:00.0000000Z","period":"PT30M","pv_estimate":5.118},{"period_end":"2022-02-27T12:30:00.0000000Z","period":"PT30M","pv_estimate":4.993},{"period_end":"2022-02-27T13:00:00.0000000Z","period":"PT30M","pv_estimate":4.694},{"period_end":"2022-02-27T13:30:00.0000000Z","period":"PT30M","pv_estimate":4.3},{"period_end":"2022-02-27T14:00:00.0000000Z","period":"PT30M","pv_estimate":3.771},{"period_end":"2022-02-27T14:30:00.0000000Z","period":"PT30M","pv_estimate":3.145},{"period_end":"2022-02-27T15:00:00.0000000Z","period":"PT30M","pv_estimate":2.443},{"period_end":"2022-02-27T15:30:00.0000000Z","period":"PT30M","pv_estimate":1.698},{"period_end":"2022-02-27T16:00:00.0000000Z","period":"PT30M","pv_estimate":0.878},{"period_end":"2022-02-27T16:30:00.0000000Z","period":"PT30M","pv_estimate":0.178},{"period_end":"2022-02-27T17:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T17:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T18:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T18:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T19:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T19:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T20:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T20:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T21:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T21:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T22:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T22:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T23:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T23:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T00:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T00:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T01:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T01:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T02:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T02:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T03:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T03:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T04:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T04:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T05:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T05:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T06:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T06:30:00.0000000Z","period":"PT30M","pv_estimate":0.189},{"period_end":"2022-02-28T07:00:00.0000000Z","period":"PT30M","pv_estimate":0.842},{"period_end":"2022-02-28T07:30:00.0000000Z","period":"PT30M","pv_estimate":1.626},{"period_end":"2022-02-28T08:00:00.0000000Z","period":"PT30M","pv_estimate":2.448},{"period_end":"2022-02-28T08:30:00.0000000Z","period":"PT30M","pv_estimate":3.138},{"period_end":"2022-02-28T09:00:00.0000000Z","period":"PT30M","pv_estimate":3.745}]}
                                      2022-02-26 10:00:28.908 - info: pvforecast.0 (2426) Recive data for West: {"forecasts":[{"period_end":"2022-02-26T09:30:00.0000000Z","period":"PT30M","pv_estimate":0.59},{"period_end":"2022-02-26T10:00:00.0000000Z","period":"PT30M","pv_estimate":0.757},{"period_end":"2022-02-26T10:30:00.0000000Z","period":"PT30M","pv_estimate":0.915},{"period_end":"2022-02-26T11:00:00.0000000Z","period":"PT30M","pv_estimate":0.97},{"period_end":"2022-02-26T11:30:00.0000000Z","period":"PT30M","pv_estimate":0.864},{"period_end":"2022-02-26T12:00:00.0000000Z","period":"PT30M","pv_estimate":0.735},{"period_end":"2022-02-26T12:30:00.0000000Z","period":"PT30M","pv_estimate":0.68},{"period_end":"2022-02-26T13:00:00.0000000Z","period":"PT30M","pv_estimate":0.641},{"period_end":"2022-02-26T13:30:00.0000000Z","period":"PT30M","pv_estimate":0.573},{"period_end":"2022-02-26T14:00:00.0000000Z","period":"PT30M","pv_estimate":0.476},{"period_end":"2022-02-26T14:30:00.0000000Z","period":"PT30M","pv_estimate":0.37},{"period_end":"2022-02-26T15:00:00.0000000Z","period":"PT30M","pv_estimate":0.291},{"period_end":"2022-02-26T15:30:00.0000000Z","period":"PT30M","pv_estimate":0.201},{"period_end":"2022-02-26T16:00:00.0000000Z","period":"PT30M","pv_estimate":0.09},{"period_end":"2022-02-26T16:30:00.0000000Z","period":"PT30M","pv_estimate":0.032},{"period_end":"2022-02-26T17:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T17:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T18:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T18:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T19:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T19:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T20:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T20:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T21:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T21:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T22:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T22:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T23:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-26T23:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T00:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T00:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T01:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T01:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T02:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T02:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T03:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T03:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T04:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T04:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T05:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T05:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T06:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T06:30:00.0000000Z","period":"PT30M","pv_estimate":0.023},{"period_end":"2022-02-27T07:00:00.0000000Z","period":"PT30M","pv_estimate":0.084},{"period_end":"2022-02-27T07:30:00.0000000Z","period":"PT30M","pv_estimate":0.24},{"period_end":"2022-02-27T08:00:00.0000000Z","period":"PT30M","pv_estimate":0.484},{"period_end":"2022-02-27T08:30:00.0000000Z","period":"PT30M","pv_estimate":0.675},{"period_end":"2022-02-27T09:00:00.0000000Z","period":"PT30M","pv_estimate":0.869},{"period_end":"2022-02-27T09:30:00.0000000Z","period":"PT30M","pv_estimate":1.045},{"period_end":"2022-02-27T10:00:00.0000000Z","period":"PT30M","pv_estimate":1.211},{"period_end":"2022-02-27T10:30:00.0000000Z","period":"PT30M","pv_estimate":1.34},{"period_end":"2022-02-27T11:00:00.0000000Z","period":"PT30M","pv_estimate":1.449},{"period_end":"2022-02-27T11:30:00.0000000Z","period":"PT30M","pv_estimate":1.504},{"period_end":"2022-02-27T12:00:00.0000000Z","period":"PT30M","pv_estimate":1.525},{"period_end":"2022-02-27T12:30:00.0000000Z","period":"PT30M","pv_estimate":1.514},{"period_end":"2022-02-27T13:00:00.0000000Z","period":"PT30M","pv_estimate":1.469},{"period_end":"2022-02-27T13:30:00.0000000Z","period":"PT30M","pv_estimate":1.383},{"period_end":"2022-02-27T14:00:00.0000000Z","period":"PT30M","pv_estimate":1.251},{"period_end":"2022-02-27T14:30:00.0000000Z","period":"PT30M","pv_estimate":1.084},{"period_end":"2022-02-27T15:00:00.0000000Z","period":"PT30M","pv_estimate":0.887},{"period_end":"2022-02-27T15:30:00.0000000Z","period":"PT30M","pv_estimate":0.671},{"period_end":"2022-02-27T16:00:00.0000000Z","period":"PT30M","pv_estimate":0.385},{"period_end":"2022-02-27T16:30:00.0000000Z","period":"PT30M","pv_estimate":0.088},{"period_end":"2022-02-27T17:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T17:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T18:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T18:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T19:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T19:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T20:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T20:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T21:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T21:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T22:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T22:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T23:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-27T23:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T00:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T00:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T01:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T01:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T02:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T02:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T03:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T03:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T04:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T04:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T05:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T05:30:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T06:00:00.0000000Z","period":"PT30M","pv_estimate":0},{"period_end":"2022-02-28T06:30:00.0000000Z","period":"PT30M","pv_estimate":0.038},{"period_end":"2022-02-28T07:00:00.0000000Z","period":"PT30M","pv_estimate":0.122},{"period_end":"2022-02-28T07:30:00.0000000Z","period":"PT30M","pv_estimate":0.326},{"period_end":"2022-02-28T08:00:00.0000000Z","period":"PT30M","pv_estimate":0.522},{"period_end":"2022-02-28T08:30:00.0000000Z","period":"PT30M","pv_estimate":0.728},{"period_end":"2022-02-28T09:00:00.0000000Z","period":"PT30M","pv_estimate":0.907}]}
                                      2022-02-26 10:00:30.894 - error: pvforecast.0 (2426) Axios Error Error: Request failed with status code 404
                                        DiginixD
                                        DiginixD
                                        Diginix
                                        #259
                                        @meistertr Bekomme mit 0.2.4 sowohl mit forecast als auch mit solcast auch pro Abruf diesen Fehler
                                        pvforecast.0 2022-02-26 13:25:46.593	error	Axios Error Error: Request failed with status code 404
                                        Außerdem ruft er auch trotz 30min Einstellung nur alle 60min die solcast Werte ab.
                                        • sonnenscheinS
                                          sonnenscheinS
                                          sonnenschein
                                          schrieb am zuletzt editiert von sonnenschein
                                          #260
                                          Hallo Zusammen:
                                          Habe jetzt mal den 0.1.9 runter geschmissen und 0.2.2 von der Katze installiert.
                                          Anscheinend ist das Thema SQL erst mal aus dem Adapter raus geflogen!
                                          Kann da jemand etwas zu sagen?
                                          Im VIS habe ich eine Tabelle und den Graph eingefügt und funktioniert.
                                          In Grafana bekomme ich das immer noch nicht gebacken den json graph anzubinden. Hat hier jemand ein Lösung wie das funktionieren kann?
                                          PlatformBetriebssystem:linux Architektur:arm64 CPUs:4 Geschwindigkeit:1800 MHz Modell:Cortex-A72
                                          RAM:3.7 GB System-Betriebszeit:00:19:02 Node.js:v20.18.0
                                          _nodeCurrent:20.18.0
                                          _npmCurrent:10.8.2
                                          Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.57-v8+
                                          mcBirneM 1 Antwort Letzte Antwort
                                          83.9k
                                          1.4m
