  4. zigbee nach update gelb
    6.1k
50 Beiträge 12 Kommentatoren 6.9k Aufrufe 12 Beobachtet
    mpl1338
    seit einem update der Letzen tage ist zigbee gelb.
    Proxmox:
    lsusb
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 005: ID 0451:16c8 Texas Instruments, Inc.
    Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
    Bus 001 Device 004: ID 8087:0aaa Intel Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    ls -la /dev/bus/usb/001/005
    crw-rw-r-- 1 root root 189, 4 May 24 17:57 /dev/bus/usb/001/005
    ls -la /dev/ttyACM0
    crw-rw-rw- 1 root dialout 166, 0 May 24 18:10 /dev/ttyACM0
    proxmox conf:
    lxc.cgroup.devices.allow: c 189:* rwm
    lxc.mount.entry: /dev/bus/usb/001/005 dev/bus/usb/001/005 none bind,optional,create=file
    lxc.cgroup.devices.allow: c 166:* rwm
    lxc.mount.entry: /dev/ttyACM0 dev/ttyACM0 none bind,optional,create=file
    iobroker LXC container
    lsusb
    ls -al /dev/bus/usb/001/005
    ls -al /dev/ttyACM0
    iobroker log
    zigbee.0	2021-05-24 18:19:33.385	error	(2787) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
    zigbee.0	2021-05-24 18:19:33.385	error	(2787) Failed to start Zigbee
    zigbee.0	2021-05-24 18:19:33.280	info	(2787) Installed Version: iobroker.zigbee@1.5.5
    zigbee.0	2021-05-24 18:19:33.272	info	(2787) Starting Zigbee npm ...
    zigbee.0	2021-05-24 18:19:33.271	info	(2787) Try to reconnect. 1 attempts left
    zigbee.0	2021-05-24 18:19:23.270	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
    zigbee.0	2021-05-24 18:19:23.270	error	at Generator.next (<anonymous>)
    zigbee.0	2021-05-24 18:19:23.270	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:193:41)
    zigbee.0	2021-05-24 18:19:23.270	error	(2787) TypeError: Cannot read property 'error' of undefined
    zigbee.0	2021-05-24 18:19:23.270	error	(2787) Failed to start Zigbee
    zigbee.0	2021-05-24 18:19:21.681	info	(2787) Installed Version: iobroker.zigbee@1.5.5
    zigbee.0	2021-05-24 18:19:21.564	info	(2787) Starting Zigbee npm ...
    zigbee.0	2021-05-24 18:19:21.534	info	(2787) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    host.iobroker	2021-05-24 18:19:20.739	info	instance system.adapter.zigbee.0 started with pid 2787
    host.iobroker	2021-05-24 18:19:18.254	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    knx.0	2021-05-24 18:19:17.755	debug	(1054) system.adapter.admin.0: logging true
    zigbee.0	2021-05-24 18:19:17.727	error	(1568) Cannot read property 'getEntries' of null
    zigbee.0	2021-05-24 18:19:17.727	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2021-05-24 18:19:17.727	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    zigbee.0	2021-05-24 18:19:17.727	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:368:20)
    zigbee.0	2021-05-24 18:19:17.727	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
    zigbee.0	2021-05-24 18:19:17.727	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    zigbee.0	2021-05-24 18:19:17.727	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:210:49)
    zigbee.0	2021-05-24 18:19:17.727	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    zigbee.0	2021-05-24 18:19:17.727	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
    zigbee.0	2021-05-24 18:19:17.727	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
    zigbee.0	2021-05-24 18:19:17.727	error	(1568) TypeError: Cannot read property 'getEntries' of null
    zigbee.0	2021-05-24 18:19:17.727	error	(1568) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2021-05-24 18:19:17.727	error	(1568) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2021-05-24 18:19:17.726	info	(1568) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-05-24 18:19:17.726	info	(1568) terminating
    zigbee.0	2021-05-24 18:19:17.726	warn	(1568) Failed to stop zigbee during startup
    zigbee.0	2021-05-24 18:19:17.725	info	(1568) Zigbee: disabling joining new devices.
    zigbee.0	2021-05-24 18:19:17.724	info	(1568) cleaned everything up...
    zigbee.0	2021-05-24 18:19:17.724	info	(1568) Got terminate signal TERMINATE_YOURSELF
    host.iobroker	2021-05-24 18:19:17.724	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.iobroker	2021-05-24 18:19:17.720	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    knx.0	2021-05-24 18:19:16.316	debug	(1054) system.adapter.admin.0: logging false
    zigbee.0	2021-05-24 18:19:12.258	error	(1568) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    was tut dem Zigbee Adapter weh?
    • M mpl1338
      Proxmox:
      lsusb
      ls -la /dev/ttyACM0
      proxmox conf:
      lsusb
      ls -al /dev/ttyACM0
      iobroker log
      arteckA Offline
      arteckA Offline
      arteck
      @mpl1338 was für coordinator ?? und was hast du in den Einstellungen eingegeben
      • arteckA arteck
        mpl1338
        @arteck
        dein stick....
        bis vor dem update ging alles. Einstellungen nicht geändert
        • M mpl1338
          @arteck
          dein stick....
          arteckA Offline
          arteckA Offline
          arteck
          @mpl1338 installiere bitte JETZT von GIT nicht das du eine buggy Version erwischt hast
          https://github.com/ioBroker/ioBroker.zigbee
          • arteckA arteck
            mpl1338
            zigbee.0	2021-05-24 19:17:59.412	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
            zigbee.0	2021-05-24 19:17:59.412	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
            zigbee.0	2021-05-24 19:17:59.412	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
            zigbee.0	2021-05-24 19:17:59.412	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
            zigbee.0	2021-05-24 19:17:59.412	error	at new Promise (<anonymous>)
            zigbee.0	2021-05-24 19:17:59.412	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
            zigbee.0	2021-05-24 19:17:59.412	error	at Generator.next (<anonymous>)
            zigbee.0	2021-05-24 19:17:59.412	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
            zigbee.0	2021-05-24 19:17:59.412	error	(4592) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
            zigbee.0	2021-05-24 19:17:59.411	error	(4592) Failed to start Zigbee
            zigbee.0	2021-05-24 19:17:59.312	info	(4592) Installed Version: ioBroker/ioBroker.zigbee#931800aecb03758f9cf7d92a751609de574b1b37
            zigbee.0	2021-05-24 19:17:59.306	info	(4592) Starting Zigbee npm ...
            zigbee.0	2021-05-24 19:17:59.305	info	(4592) Try to reconnect. 1 attempts left
            zigbee.0	2021-05-24 19:17:49.304	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
            zigbee.0	2021-05-24 19:17:49.304	error	at Generator.next (<anonymous>)
            zigbee.0	2021-05-24 19:17:49.304	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:201:35)
            zigbee.0	2021-05-24 19:17:49.304	error	(4592) Error: startup failed - configuration-adapter mismatch - see logs above for more information
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) Failed to start Zigbee
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) Re-commissioning your network will require re-pairing of all devices!
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) Please update configuration to prevent further issues.
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) - Channel List: configured=11, adapter=11
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) - Network Key: configured=blabla, adapter=blabla
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) - Extended PAN ID: configured=blabla, adapter=00124b00062d6098
            zigbee.0	2021-05-24 19:17:49.303	error	(4592) - PAN ID: configured=6754, adapter=6754
            zigbee.0	2021-05-24 19:17:49.302	error	(4592) Configuration is not consistent with adapter state/backup!
            zigbee.0	2021-05-24 19:17:47.677	info	(4592) Installed Version: ioBroker/ioBroker.zigbee#931800aecb03758f9cf7d92a751609de574b1b37
            zigbee.0	2021-05-24 19:17:47.576	info	(4592) Starting Zigbee npm ...
            zigbee.0	2021-05-24 19:17:47.528	info	(4592) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            immernoch
            crunchipC Thomas BraunT 2 Antworten Letzte Antwort
            • M mpl1338
              immernoch
              crunchipC Abwesend
              crunchipC Abwesend
              @mpl1338 du fährst mit npm 7.x ??
              • M mpl1338
                immernoch
                @mpl1338
                npm@7 ist auch nicht die empfohlene Version zu deinem node12.
                  arteckA Offline
                  arteckA Offline
                  arteck
                  wie @crunchip gerade schreibt.... da haben wir das Problem
                    mpl1338
                    update auf 7 erfolgte erst eben.
                    zurück zu 6:
                    which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.13
                    nodejs:
                      Installed: 12.22.1-1nodesource1
                      Candidate: 12.22.1-1nodesource1
                      Version table:
                     *** 12.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                            500 http://ftp.debian.org/debian buster/main amd64 Packages
                            500 http://security.debian.org buster/updates/main amd64 Packages
                    zigbee.0	2021-05-24 19:41:43.508	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                    zigbee.0	2021-05-24 19:41:43.508	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                    zigbee.0	2021-05-24 19:41:43.508	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                    zigbee.0	2021-05-24 19:41:43.508	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                    zigbee.0	2021-05-24 19:41:43.508	error	at new Promise (<anonymous>)
                    zigbee.0	2021-05-24 19:41:43.508	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                    zigbee.0	2021-05-24 19:41:43.508	error	at Generator.next (<anonymous>)
                    zigbee.0	2021-05-24 19:41:43.508	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                    zigbee.0	2021-05-24 19:41:43.508	error	(5962) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                    zigbee.0	2021-05-24 19:41:43.508	error	(5962) Failed to start Zigbee
                    iobroker
                    Platform
                    linux
                    Betriebssystem
                    linux
                    Architektur
                    x64
                    CPUs
                    Geschwindigkeit
                    3600 MHz
                    Modell
                    Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
                    RAM
                    4 GB
                    System Betriebszeit
                    4 T. 23:16:12
                    Node.js
                    v12.22.1
                    Festplatte Größe
                    12 GB
                    Festplatte frei
                    7.81 GB
                    Anzahl der Adapter
                    411
                    NPM
                    v6.14.13
                    Betriebszeit
                    00:02:58
                    Aktive Instanzen
                    25
                    Hostname
                    iobroker
                    und problem immernoch da
                    • M mpl1338
                      zurück zu 6:
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v12.22.1
                      v12.22.1
                      6.14.13
                      nodejs:
                        Version table:
                      iobroker
                      Platform
                      linux
                      Betriebssystem
                      linux
                      Architektur
                      x64
                      CPUs
                      Geschwindigkeit
                      3600 MHz
                      Modell
                      RAM
                      4 GB
                      System Betriebszeit
                      4 T. 23:16:12
                      Node.js
                      v12.22.1
                      Festplatte Größe
                      12 GB
                      Festplatte frei
                      7.81 GB
                      Anzahl der Adapter
                      411
                      NPM
                      v6.14.13
                      Betriebszeit
                      00:02:58
                      Aktive Instanzen
                      25
                      Hostname
                      iobroker
                      @mpl1338 Was liegt denn da drauf?
                      sudo lsof /dev/ttyACM0
                        mpl1338
                        @thomas-braun said in zigbee nach update gelb:
                        COMMAND  PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                        node    1305 iobroker   27uW  CHR  166,0      0t0  361 /dev/ttyACM0
                        • M mpl1338
                          @mpl1338
                          Stop den Adapter,
                          sudo -u iobroker kill 1305
                          Adapter starten.
                          • M mpl1338
                            zurück zu 6:
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.1
                            v12.22.1
                            6.14.13
                            nodejs:
                              Version table:
                            iobroker
                            Platform
                            linux
                            Betriebssystem
                            linux
                            Architektur
                            x64
                            CPUs
                            Geschwindigkeit
                            3600 MHz
                            Modell
                            RAM
                            4 GB
                            System Betriebszeit
                            4 T. 23:16:12
                            Node.js
                            v12.22.1
                            Festplatte Größe
                            12 GB
                            Festplatte frei
                            7.81 GB
                            Anzahl der Adapter
                            411
                            NPM
                            v6.14.13
                            Betriebszeit
                            00:02:58
                            Aktive Instanzen
                            25
                            Hostname
                            iobroker
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @mpl1338 proxmox selbst mal neu gestartet, bzw stick mal abgesteckt?
                              mpl1338
                              @crunchip
                              mehrmals
                              @Thomas-Braun
                              keine besserung
                              M Thomas BraunT 2 Antworten Letzte Antwort
                              • M mpl1338
                                @crunchip
                                mehrmals
                                @Thomas-Braun
                                keine besserung
                                mpl1338
                                downgrade auf 1.4.1 und es geht wieder....
                                • M mpl1338
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @mpl1338 seltsam
                                  • M mpl1338
                                    @crunchip
                                    mehrmals
                                    @Thomas-Braun
                                    keine besserung
                                    @mpl1338
                                    iobroker stop
                                    Damn nochmal schauen ob das File noch offen ist, process ggf. killen,
                                    iobroker start
                                      @mpl1338
                                      iobroker stop
                                      iobroker start
                                      mpl1338
                                      bin jetzt auf 1.4.1 runter - da läufts wieder
                                        Peter213
                                        Habe auch gerade Update gemacht und der Adapter bleibt rot. Folgende Fehler habe ich:
                                        Hat einer eine Idee?
                                        • P Peter213
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @peter213 multihost ?
                                          P 1 Antwort Letzte Antwort
