  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 530.7k Aufrufe 93 Beobachtet
  • Hant0rH Hant0r
    @maximal1981 ach cool, kannst du das mal bitte exportieren und hier einfügen?
    maximal1981M Offline
    maximal1981
    #781
    @hant0r
    <block xmlns="https://developers.google.com/blockly/xml" type="controls_forEach" id="vZbxi%A.Z4NK.,]GJf)g" x="13" y="13">
      <field name="VAR" id="pkt|st/Cek!e1rU)d:03">i</field>
      <value name="LIST">
        <block type="selector" id="OPLe^Bf?~}UAZWL/)zt7">
          <field name="TEXT">channel[state.id=unifi.0.default.clients.*.is_guest]</field>
        </block>
      </value>
      <statement name="DO">
        <block type="controls_if" id=".1zT|W;Hi*6~j(y-dw44">
          <value name="IF0">
            <block type="get_value_var" id="F0$j|B1T|Erp$blJ|5r.">
              <value name="OID">
                <shadow type="text" id="uHNphjS^h7Zh|eF:[2HV">
                  <field name="TEXT"></field>
                </shadow>
                <block type="variables_get" id="a@;ce{1B.J=16UwPtP(8">
                </block>
              </value>
            </block>
          </value>
          <statement name="DO0">
            <block type="controls_if" id="Cc((*OSV]#!gyL;)bhm}">
              <value name="IF0">
                <block type="get_value_var" id="a+V9qy^A)h%.;9[A.p/{">
                  <value name="OID">
                    <shadow type="text">
                    </shadow>
                    <block type="text_join" id="f7eDd5B[|h%CwdvDH)ZT">
                      <value name="ADD0">
                        <block type="text_getSubstring" id="}F(}=/aI47ar,nmgv3Es">
                          <mutation at1="false" at2="true"></mutation>
                          <field name="WHERE1">FIRST</field>
                          <field name="WHERE2">FROM_END</field>
                          <value name="STRING">
                            <block type="variables_get" id="7:a33VN;jOwS?0#KJHIm">
                            </block>
                          </value>
                          <value name="AT2">
                            <block type="math_number" id="jR;$5/3[PUr~d@q`rVrI">
                              <field name="NUM">9</field>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="ADD1">
                        <block type="text" id="}DVtEPx5rLg/1/QX98JY">
                          <field name="TEXT">is_online</field>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
                <block type="debug" id="kV~NE!s|Ek`WRWA_3z=f">
                  <field name="Severity">warn</field>
                  <value name="TEXT">
                    <shadow type="text" id="+/+uj1X|3wvPa+EL==Aa">
                    </shadow>
                    <block type="get_value_var" id="ld$Y]!h,n*asj4VOLP05">
                      <value name="OID">
                        <shadow type="text" id="lorWqtUi2q{,SgHNm,O(">
                        </shadow>
                        <block type="text_join" id="%Mj,=I9Y(7rI(SPf26H^">
                          <value name="ADD0">
                            <block type="text_getSubstring" id="A;bSBAJzH#KBwHr(oJ|I">
                                <block type="variables_get" id="p!Le_?0:lGo(BlaN1p;3">
                                </block>
                              </value>
                              <value name="AT2">
                                <block type="math_number" id="rd+j#2SK?tM@Kg0$z:k?">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="text" id="Ir%@AjEm,i:bfX5S~Ay0">
                              <field name="TEXT">hostname</field>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </statement>
            </block>
          </statement>
        </block>
      </statement>
    </block>
    • Hant0rH Offline
      Hant0rH Offline
      Hant0r
      #782
      @maximal1981 Mega, vielen lieben Dank - wieder was gelernt :D
        Malz1902
        #783
        also bei mir läuft der 24/7 durch
        W 1 Antwort Letzte Antwort
        • M Malz1902
          W Offline
          W Offline
          warp735
          #784
          @malz1902
          Bei mir auch... Nur bei Updates kommen Absturz Meldungen. 1x Neustart und gut ist
          • F Offline
            fliegema
            #785
            Moin Freunde des smarten Homes,
            nutze den Adapter (v0.6.6) schon länger und bis dato hat dieser immer tadelos funktioniert.
            Leider bekomme ich nun folgende Fehlermeldungen (leider kommt zwischen debug und info keine andere Meldung zustande):
            Eben habe ich den Adapter zum xten Mal neu gestartet und es kommt kein Fehler mehr und die Datenpunkte werden übertragen.
            Der Controller ist ein: Ubuntu 20.04.6 LTS (GNU/Linux 5.15.0-1038-oracle x86_64) mit Unifi 7.4.162
            Vouchers, Alarm, DPI und Gateway Traffic sind deaktiviert.
            Irgendwelche Ideen?
            Gruss
            Cheers
            • F fliegema
              Irgendwelche Ideen?
              Gruss
              Meister MopperM Online
              Meister Mopper
              #786
              @fliegema sagte in Adapter: ioBroker.unifi:
              Irgendwelche Ideen?
              Hast du heute das update des Adapters durchgeführt? In diesem Fall kommt diese Meldung, weil eine gewisse Zeit der Controller nicht erreichbar ist.
              Proxmox und HA ...
              F 1 Antwort Letzte Antwort
                Irgendwelche Ideen?
                fliegema
                #787
                @meister-mopper jup, hatte durch Zufall gesehen, dass es ein Update gibt. Hat mir der vorhergehenden Version aber auch nicht geklappt, es fing direkt nach dem Unif Adapter Update an. Habe auch bis auf 5.1. gedowngraded hat aber leider auch keinen Erfolg gebracht.
                Kann ich irgendwie noch mehr debug Code zur Verfügung stellen?
                Cheers
                • Meister MopperM Online
                  Meister Mopper
                  schrieb am zuletzt editiert von Meister Mopper
                  #788
                  @fliegema
                  Ok, dann stell mal hier das Ergebnis von
                  iob diag ein,
                  aber bitte in code tags
                  Proxmox und HA ...
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    #789
                    Irgendwelche Ideen?
                    einfach mal das passwort neu eintragen in der Instanz
                      Irgendwelche Ideen?
                      fliegema
                      #790
                      Danke für die Hinweise, hat leider noch nicht geklappt.
                      @crunchip said in Adapter: ioBroker.unifi:
                      Irgendwelche Ideen?
                      Hatte ich bereits probiert und eben erneut ein neues Passwort vergeben. Er synced auch manchmal die Datenpunkte aber verabschiedet sich in den roten Status.
                      @meister-mopper said in Adapter: ioBroker.unifi:
                      @fliegema
                      iob diag ein,
                      2023-07-08 13:51:24.150  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 621374
                      2023-07-08 13:51:25.027  - info: unifi.0 (621374) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2023-07-08 13:51:25.183  - info: unifi.0 (621374) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v16.20.0, js-controller: 4.0.24
                      2023-07-08 13:51:25.228  - info: unifi.0 (621374) UniFi adapter is ready
                      2023-07-08 13:51:30.556  - error: unifi.0 (621374) [updateUnifiData-login site undefined] error: timeout of 5000ms exceeded, stack: AxiosError: timeout of 5000ms exceeded
                          at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3047:16)
                          at RedirectableRequest.emit (node:events:513:28)
                          at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)
                          at listOnTimeout (node:internal/timers:559:17)
                          at processTimers (node:internal/timers:502:7)
                      2023-07-08 13:51:30.557  - error: unifi.0 (621374) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-07-08 13:51:30.557  - error: unifi.0 (621374) unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                      2023-07-08 13:51:30.557  - error: unifi.0 (621374) TypeError: Cannot read properties of undefined (reading 'captureException')
                          at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53)
                          at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:268:22)
                      2023-07-08 13:51:30.557  - error: unifi.0 (621374) Cannot read properties of undefined (reading 'captureException')
                      2023-07-08 13:51:30.571  - info: unifi.0 (621374) cleaned everything up...
                      2023-07-08 13:51:30.571  - info: unifi.0 (621374) terminating
                      2023-07-08 13:51:30.572  - warn: unifi.0 (621374) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-07-08 13:51:31.135  - error: host.ioBroker instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-07-08 13:51:31.135  - info: host.ioBroker Restart adapter system.adapter.unifi.0 because enabled
                      2023-07-08 13:51:32.215  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 621464
                      2023-07-08 13:51:33.513  - info: unifi.0 (621464) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2023-07-08 13:51:33.942  - info: unifi.0 (621464) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v16.20.0, js-controller: 4.0.24
                      2023-07-08 13:51:34.084  - info: unifi.0 (621464) UniFi adapter is ready
                      Hier hat er es mal für 1min überlebt, danach wieder auf rot.
                      Versionsstände:
                      Core adapters versions
                      admin:          6.3.5
                      javascript:     7.0.3
                      Operatingsystem:        Ubuntu 22.04.2 LTS
                      Kernel:                 5.15.74-1-pve
                      Installation:           lxc
                      Timezone:               Europe/Berlin (CEST, +0200)
                      User-ID:                1001
                      X-Server:               false
                      Pending OS-Updates:     6
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                              /usr/local/bin/node             v16.20.0
                                              /usr/local/bin/npm              8.19.4
                                              /usr/local/bin/npx              8.19.4
                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                      *** nodejs is NOT correctly installed ***
                      Hier wunder mich das "nicht korrekt installiert", habe einmal iob fix gemacht und danach kam es auch wieder.
                      Gruss
                      Cheers
                      ? crunchipC 2 Antworten Letzte Antwort
                      • F fliegema
                        Irgendwelche Ideen?
                        @fliegema
                        iob diag ein,
                        Versionsstände:
                        admin:          6.3.5
                        javascript:     7.0.3
                        Installation:           lxc
                        User-ID:                1001
                        X-Server:               false
                        Gruss
                        #791
                        @fliegema
                        Schau mal, ich denke deine Node Installation ist nicht ok… Nodejs v18 und Node v16…?
                        • F fliegema
                          Irgendwelche Ideen?
                          @fliegema
                          iob diag ein,
                          Versionsstände:
                          admin:          6.3.5
                          javascript:     7.0.3
                          Installation:           lxc
                          User-ID:                1001
                          X-Server:               false
                          Gruss
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #792
                          @fliegema nodejs ist falsch installiert
                          https://forum.iobroker.net/post/460727
                            @fliegema
                            fliegema
                            #793
                            @ilovegym said in Adapter: ioBroker.unifi:
                            @fliegema
                            Korrekt, habe ich nun korrigiert.
                            Danke für den Link, habe in einem anderen Beitrag noch einen Befehl gefunden, welcher das Verzeichnis löscht, damit die v18 auch endlich startet.
                            Kurze Zusammenfassung, falls noch Jemand diese Infos braucht:
                            Kudos an: Help 1 & Help 2
                            iob stop
                            sudo rm /usr/local/bin/n*
                            sudo apt purge --autoremove nodejs* npm node-* libnode*
                            curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash
                            apt policy nodejs
                            sudo apt install nodejs
                            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                            iob fix
                            iob start
                            Die oben genannten Befehle haben bei mir unter
                            sowie
                            Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                            Kernel:                 6.1.21-v7l+
                            und
                            Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                            Kernel:                 5.10.103-v7+
                            funktioniert.
                                                    /usr/bin/node           v18.16.1
                                                    /usr/bin/npm            9.5.1
                                                    /usr/bin/npx            9.5.1
                            Zum Unifi Adapater zurück, der bringt mir leider nach wie vor die gleichen Fehlermeldungen:
                            2023-07-08 16:43:26.513  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 11431
                            2023-07-08 16:43:27.483  - info: unifi.0 (11431) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2023-07-08 16:43:27.600  - info: unifi.0 (11431) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.16.1, js-controller: 4.0.24
                            2023-07-08 16:43:27.649  - info: unifi.0 (11431) UniFi adapter is ready
                            2023-07-08 16:43:33.039  - error: unifi.0 (11431) [updateUnifiData-login site undefined] error: timeout of 5000ms exceeded, stack: AxiosError: timeout of 5000ms exceeded
                                at listOnTimeout (node:internal/timers:569:17)
                                at process.processTimers (node:internal/timers:512:7)
                            2023-07-08 16:43:33.040  - error: unifi.0 (11431) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2023-07-08 16:43:33.040  - error: unifi.0 (11431) unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                            2023-07-08 16:43:33.040  - error: unifi.0 (11431) TypeError: Cannot read properties of undefined (reading 'captureException')
                            2023-07-08 16:43:33.041  - error: unifi.0 (11431) Cannot read properties of undefined (reading 'captureException')
                            2023-07-08 16:43:33.049  - info: unifi.0 (11431) cleaned everything up...
                            2023-07-08 16:43:33.050  - info: unifi.0 (11431) terminating
                            2023-07-08 16:43:33.050  - warn: unifi.0 (11431) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2023-07-08 16:43:33.608  - error: host.ioBroker instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2023-07-08 16:43:33.608  - info: host.ioBroker Restart adapter system.adapter.unifi.0 because enabled
                            2023-07-08 16:43:34.670  - info: host.ioBroker instance system.adapter.unifi.0 started with pid 11485
                            2023-07-08 16:43:35.456  - info: unifi.0 (11485) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            2023-07-08 16:43:35.537  - info: unifi.0 (11485) starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.16.1, js-controller: 4.0.24
                            2023-07-08 16:43:35.603  - info: unifi.0 (11485) UniFi adapter is ready
                            habe auch nochmal Passwort neu eingetragen, leider kein Erfolg.
                            Cheers
                              crunchipC Abwesend
                              #794
                              @fliegema worauf läuft dein unifi bzw welche Firmware?
                              nach deiner nodejs Korrektur mal probiert den Adapter zu löschen und neu zu installieren?
                              ansonsten mal dort nachsehen, eventuell auch bei den bereits geschlossenen
                              https://github.com/iobroker-community-adapters/ioBroker.unifi/issues
                                mhuber
                                #795
                                ich bekomme bei mir im iobroker Log immer wieder (3-4x am Tag) diese Fehlermeldungen, manchmal funktioniert trotzdem noch alles normal, manchmal scheint aber die Verbindung zum CloudKey unterbrochen zu sein, ein Restart vom Adapter hilft dann immer.
                                Hab den iobroker im Docker laufen, überall (iobroker, Adapter, CloudKey...) latest Software, war aber auch in den letzten Releaes schon da der Fehler.
                                Hat jemand einen Tipp?
                                updateUnifiData site default] error: Request failed with status code 503, stack: AxiosError: Request failed with status code 503 at settle (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/core/settle.js:19:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/node-unifi/node_modules/axios/lib/adapters/http.js:570:11) at IncomingMessage.emit (node:events:525:35) at IncomingMessage.emit (node:domain:489:12) at endReadableNT (node:internal/streams/readable:1359:12) at processTicksAndRejections (node:internal/process/task_queues:82:21)
                                  fliegema
                                  #796
                                  @crunchip, Moin.
                                  Adapter löschen und neu installieren hat leider nicht geklappt. Gleiches Fehlerbild.
                                  Der Controller ist Ubuntu 20.04.6 LTS (GNU/Linux 5.15.0-1038-oracle x86_64) mit Unifi 7.4.162
                                  ich werde mal ein Issue aufmachen, gucken wir mal was kommt. Wobei der Log von sehr ähnlich aussieht.
                                  @mhuber said in Adapter: ioBroker.unifi:
                                  Cheers
                                  maduutoM F 2 Antworten Letzte Antwort
                                  • F fliegema
                                    @crunchip, Moin.
                                    maduutoM Offline
                                    maduutoM Offline
                                    maduuto
                                    #797
                                    Ich habe schon wieder das Problem, dass die Anwesenheit einfach nicht übermittelt wird., sprich der Status is_online nicht übermittelt wird (ggf andere Parameter auch nicht die nutze ich nur nicht) Ich probiere mal die Version 6.0.
                                    Unifi Controller ist auf dem aktuellsten Stand. Nach einem Adapterneustart funktioniert das meist einmalig.
                                    • maduutoM maduuto
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #798
                                      @maduuto dss hatte ich auch seit geraumer Zeit, seitdem mach ich einen Neustart der Instanz alle 6 Std.
                                        Digi-Bit
                                        #799
                                        Hallo
                                        Ich würde gerne einen Datenpunkt für WAN2 haben wollen, also wenn da einer schon ist dann sehe ich den nicht :(
                                        unifi.0.default.health.wan.wan_ip ist ja WAN1
                                        unifi.0.default.health.wan2.wan_ip müsste dann so aussehen oder wie ?
                                        Mann kann ja wohl auch daten punkte selber anlegen aber ich habe da kein Plan wie man das machen soll.
                                        Kann mich da mal einer in die richtige Richtung schuppsen ? ^^
                                        mfg
                                        Digi-Bit
                                        Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
                                        7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
                                        • D Digi-Bit
                                          Hallo
                                          mfg
                                          Digi-Bit
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #800
                                          @digi-bit es wird nur das abgerufen was der Adapter bringt
