  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 530.4k Aufrufe 93 Beobachtet
  • coyoteC coyote
    Bekomme seit gestern den Adapter nicht mehr zum Laufen.
    Jemand ne Idee?
    unifi.0
    2022-10-08 14:37:44.072	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    unifi.0
    2022-10-08 14:37:44.071	debug	Plugin sentry destroyed
    unifi.0
    2022-10-08 14:37:44.071	info	terminating
    unifi.0
    2022-10-08 14:37:44.070	info	cleaned everything up...
    unifi.0
    2022-10-08 14:37:44.064	error	Cannot read properties of undefined (reading 'captureException')
    unifi.0
    2022-10-08 14:37:44.063	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:218:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:22)
    unifi.0
    2022-10-08 14:37:44.062	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    unifi.0
    2022-10-08 14:37:44.062	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0
    2022-10-08 14:37:44.060	error	[updateUnifiData-login site undefined] error: Cannot read properties of undefined (reading 'create'), stack: TypeError: Cannot read properties of undefined (reading 'create') at Controller._init (/opt/iobroker/node_modules/node-unifi/unifi.js:2975:28) at Controller.login (/opt/iobroker/node_modules/node-unifi/unifi.js:80:31) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:241:41) at Unifi.onReady (/opt/iobroker/node_modules/iobroker.unifi/main.js:102:22) at Unifi.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8226:26
    unifi.0
    2022-10-08 14:37:44.047	debug	Update started
    unifi.0
    2022-10-08 14:37:44.046	debug	updateInterval = 60
    unifi.0
    2022-10-08 14:37:44.045	debug	controller = 192.168.66.35:8443
    unifi.0
    2022-10-08 14:37:44.044	info	UniFi adapter is ready
    Hab die Anmeldedaten schon neu eingegeben, ohne Port probiert, auf eine ältere Version downgegraded 0.6.0 / 0.6.1 leider alles ohne Erfolg.
    Unifi Network Application: 7.2.94
    crunchipC Offline
    crunchipC Offline
    #721
    @coyote https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/613
    coyoteC 1 Antwort Letzte Antwort
      coyoteC Offline
      coyoteC Offline
      coyote
      #722
      @crunchip 😊 hätte ich doch besser erst nochmal auf GitHub geschaut. Gestern Nacht gab es noch kein issue dazu, daher hatte ich heute mittag gar nicht erst geschaut.
      Dann warten wir mal ab 👍
      • coyoteC coyote
        crunchipC Offline
        crunchipC Offline
        #723
        @coyote sagte in Adapter: ioBroker.unifi:
        doch, den das hatte ich ja heut Nacht direkt eröffnet, nachdem da Update rein kam
          coyoteC Offline
          coyoteC Offline
          coyote
          #724
          @crunchip kommt natürlich jetzt auf die Uhrzeit an 😁 Als ich geschaut hatte, war noch keins. Das Update war schon früher da, als vor 15 Stunden.
          I 1 Antwort Letzte Antwort
          • coyoteC coyote
            I Offline
            I Offline
            Idefix01
            #725
            @crunchip
            Die stable Version 0.5.10 funktioniert einwandfrei. Kann es sein das es eine Beta Version ist?
            • I Idefix01
              @crunchip
              crunchipC Offline
              crunchipC Offline
              #726
              @idefix01 sagte in Adapter: ioBroker.unifi:
              ja
              github:	0.6.3
              latest:	0.6.3 for 0 days
              stable:	0.5.10 for 16 months
              • O Offline
                O Offline
                oxident
                #727
                Komischerweise läuft der Adapter bei mir nur in v0.5.1 oder kleiner "rund". Bei allen späteren Versionen (bis 0.6.3) habe ich arge Probleme:
                • is_online wird teilweise gar nicht oder erst mehrere Minuten nach tatsächlicher Änderung aktualisiert
                • speedtest Resultate werden manchmal nur beim Adapter-Neustart aktualisiert
                Ich habe schon ein wenig mit der Refresh-Time "gespielt" und momentan aktualisiert der Adapter alle 20sec und die is_online Erkennung steht bei 40sec. Damit klappt es mehr schlecht als recht.
                Dennoch habe ich einige (stationäre) WLAN-Clients die hin und wieder für mehrere Minuten als offline angezeigt werden obwohl es dafür keinen Grund gibt. Weder im Unifi-Controller noch am Gerät selber ist eine Unterbrechung zu sehen.
                Nutze eine UDM Pro 1.12.30 mit zwei APs und drei Unifi-Switches. Meine Clients-Liste ist jedoch mit über 300 Einträgen recht groß. Kann es daran liegen?
                Bei Github gibt es zwar ein paar closed issues dazu, aber das hat sich alles entweder von selbst oder durch ein Update erledigt.
                • O oxident
                  crunchipC Offline
                  crunchipC Offline
                  #728
                  @oxident sagte in Adapter: ioBroker.unifi:
                  das Problem hab ich aktuell auch, zeitweise wird gar nicht mehr aktualisiert
                  JackDanielJ 1 Antwort Letzte Antwort
                    JackDanielJ Online
                    JackDanielJ Online
                    JackDaniel
                    #729
                    @crunchip sagte in Adapter: ioBroker.unifi:
                    hier auch das gleiche :(
                    ich lass nun den adapter alle 6 stunden einfach neu starten, dann gehts ohne problem hier
                    Carpe diem
                    F O 2 Antworten Letzte Antwort
                    • JackDanielJ JackDaniel
                      Frank579
                      #730
                      Bei mir auch das gleiche.. bis gerade dachte ich es läge am neuen Handy (Android 12) trat zeitgleich mit dem Wechsel des Handys auf.
                      Bin für die Anwesenheits Geschichte jetzt auf Owntracks gewechselt läuft stabiler.
                        O Offline
                        O Offline
                        oxident
                        #731
                        @jackdaniel Guter Tipp, danke.
                        War da nicht mal was, dass es immer dann nicht mehr aktualisierte, wenn die UDM ein Backup gemacht hat? Ich weiß nicht mehr, wo ich das gelesen habe, aber irgendwas klingelt da bei mir ;-)
                        crunchipC NashraN 2 Antworten Letzte Antwort
                        • O oxident
                          crunchipC Offline
                          crunchipC Offline
                          #732
                          @oxident hab zwar nur nen UDR, aber Backup mach ich Sonntag, Ausfall war aber mitten unter der Woche
                            darkiop
                            #733
                            Schaut euch mal
                            https://github.com/GodHunter/iobroker-unifi-presence
                            an. Hier wird der .last_seen DP benutzt und funktioniert zuverlässig.
                            • Meister MopperM Online
                              Meister Mopper
                              #734
                              @darkiop sagte in Adapter: ioBroker.unifi:
                              Das ist zumindest untersuchungswürdig. 'last_seen' ist weitestgehend aktuell. 'is_online' hängt teilweise deutlich hinterher.
                              Proxmox und HA ...
                                darkiop
                                #735
                                @meister-mopper sagte in Adapter: ioBroker.unifi:
                                Funktioniert hier bei 2 Personen einwandfrei ;)
                                • D darkiop
                                  crunchipC Offline
                                  crunchipC Offline
                                  #736
                                  @darkiop nutzt bei mir allerdings nix, wenn zeitweise gar keine Datenpunkte mehr aktualisiert werden.
                                  Das Script hatte ich früher glaub ich schon mal laufen.
                                  Es lief auch vorm Adapter ein Script, (was @liv-in-sky gebastelt hatte ), welches sich die Daten vom Controller holt. Aber alles nicht so 100% zufrieden stellend.
                                  Letztendlich funktioniert jedoch bei mir der radar2 Adapter da zuverlässig und erkennt die Anwesenheit
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    #737
                                    @crunchip
                                    das script funktioniert mittlerweile nicht mehr, da die zusätzliche node nicht mehr installierbar ist
                                    crunchipC D 2 Antworten Letzte Antwort
                                    • liv-in-skyL liv-in-sky
                                      @crunchip
                                      crunchipC Offline
                                      crunchipC Offline
                                      #738
                                      @liv-in-sky ich schrieb ja....vorm Adapter, also auch schon ne Weile her😉
                                      aber gut zu wissen, wollt eh mal meine Sammlung ausmisten
                                        @crunchip
                                        darkiop
                                        schrieb am zuletzt editiert von darkiop
                                        #739
                                        Die 0.6.3 aus dem Latest-Repo läuft hier mit der UDM-P (UniFi OS 1.12.30 / Network 7.3.73) unauffällig.
                                        Auf welchen Versionen bist du?
                                        O 1 Antwort Letzte Antwort
                                        • D darkiop
                                          O Offline
                                          O Offline
                                          oxident
                                          #740
                                          @darkiop Exakt die gleichen, teste aber gerade den halbtäglichen Neustart. Scheint erstmal zu funktionieren.
