  4. Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol
    2.3k
    4.2k
111 Beiträge 6 Kommentatoren 14.5k Aufrufe 7 Beobachtet
  • R Rookie50
    @liv-in-sky hier das Blockly:
      <variables>
        <variable id="V!?b;m:_l0eU[qp:2SFO">result</variable>
      </variables>
      <block type="text_join" id="4(WJ8JQ5i=h371i{O,Gx" disabled="true" x="1263" y="-3137">
        <mutation items="5"></mutation>
        <value name="ADD0">
          <block type="text" id="8%K;p%N|6+p7q3AUWIx}">
            <field name="TEXT">http://</field>
          </block>
        </value>
        <value name="ADD1">
          <block type="get_value" id="NQJLL*}lv=eg,Y|jp6It">
            <field name="OID">0_userdata.0.Rookie.dieIP</field>
          </block>
        </value>
        <value name="ADD2">
          <block type="text" id="*K6dCQuo,^7.bb#wcY/V">
            <field name="TEXT">:11000/Folders?&amp;service=LocalMusic</field>
          </block>
        </value>
        <value name="ADD3">
          <block type="text" id="Ws(9{4OpO]NL2S0lx[Ja">
            <field name="TEXT">&amp;path=</field>
          </block>
        </value>
        <value name="ADD4">
          <block type="get_value" id="}3$_/Oiqr~$+E?UcbD!G">
            <field name="OID">0_userdata.0.Rookie.braucheNeueDatenNeu</field>
          </block>
        </value>
      </block>
      <block type="comment" id="v0M32(PRj34s1Di,:=gY" x="-63" y="-3063">
        <field name="COMMENT">holt start daten - root ordner</field>
        <next>
          <block type="schedule" id="t:}s~p^B_9Who+:7wtq~">
            <field name="SCHEDULE">*/30 * * * *</field>
            <statement name="STATEMENT">
              <block type="request" id="I6rYHt4A!iG?_jn{8XgO">
                <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                <field name="WITH_STATEMENT">TRUE</field>
                <field name="LOG">debug</field>
                <value name="URL">
                  <shadow type="text" id="{j7;c#y:g^xO}}Aj~/c]">
                    <field name="TEXT">http://192.168.101.107:11000/Folders?&amp;service=LocalMusic&amp;path=%2F%2F192.168.101.20%2Fmusic%2FBest%20of</field>
                  </shadow>
                  <block type="text_join" id="ZF$TN+yFuwmjO3G2]C3S">
                    <value name="ADD0">
                      <block type="text" id="Q4sSPYrC|(Iq}Od,2+sy">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="}=@5A?KbJp+oeczBbn8j">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="JMY{LdKQw,LYR!G`{8)O">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="debug" id="WV$pQ0~9+,%o*^4x-FZs">
                    <value name="TEXT">
                      <shadow type="text">
                      </shadow>
                      <block type="variables_get" id="2x%*T/Rg?1#Pg,~3zNFn">
                        <field name="VAR" id="V!?b;m:_l0eU[qp:2SFO">result</field>
                      </block>
                    </value>
                    <next>
                      <block type="update" id="Mk1.W[|]*#%L^q-E=~y*">
                        <field name="OID">0_userdata.0.Rookie.startXML</field>
                        <value name="VALUE">
                          <block type="variables_get" id="ax.+|:3mB$=C,$r-smVb">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
              <block type="request" id=")FaT:*h|xNP=q3@TmeAW">
                <value name="URL">
                  </shadow>
                  <block type="text_join" id="`$qKv{o!)^nZ}Op+E;pd">
                    <value name="ADD0">
                      <block type="text" id="5,xtrHj#,dU=06WjB1-I">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="t,WdT/?XM=MbUh@8B|`X">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="y:[S^_f1ust[{?]M{2)m">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="debug" id="y^k~DIV`iU`.#+QDRble">
                    <value name="TEXT">
                      </shadow>
                      <block type="variables_get" id="J$aetB4Wy1dZi$7=(m,j">
                      </block>
                    </value>
                    <next>
                      <block type="update" id="M}ufB2T]3GhRm.0n.wCK">
                          <block type="variables_get" id="^Rh#h4z|_xaS%:jjW7;{">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="comment" id="uwKrN/G!j[ud[u@1QR()" x="637" y="-3013">
        <field name="COMMENT">holt Daten</field>
        <next>
          <block type="on_ext" id="N0#32_-c70.%tK[:LtJ%">
            <value name="OID0">
              <shadow type="field_oid" id="G#-!zS8!EsQlucJw^9md">
                <field name="oid">0_userdata.0.Rookie.braucheNeueDatenNeu</field>
              </shadow>
            </value>
              <block type="debug" id="MgSAh8UGx{N=1mV[57:Z">
                <value name="TEXT">
                  <shadow type="text" id="N@^8_se}L8h$pPuiF%ec">
                  </shadow>
                  <block type="text_join" id="bvItJ0`oBtd$WYv1POUJ">
                    <value name="ADD0">
                      <block type="text" id="0J-9IJ^j@qC2Faj`~k+R">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="4@TIc0,d3M-oOY3B-33)">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="kP?r1Z%PqX11,1ykbm7M">
                      </block>
                    </value>
                    <value name="ADD3">
                      <block type="text" id="Zb2HLfnz;QZ/+l2K,6=c">
                      </block>
                    </value>
                    <value name="ADD4">
                      <block type="get_value" id="aLdz2c4i#X`TFqLwymF4">
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="control" id="*Gf3Lq,S4]YjTU:PxU/9">
                    <field name="OID">0_userdata.0.Rookie.LOG.URL</field>
                      <block type="text_join" id="94xkBN)Mj32X;Rk.T5no">
                        <value name="ADD0">
                          <block type="text" id="xV[LVgV)_pvjD3@#8ltj">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="get_value" id="R5qUlXB5Nt6Z+EN)Z6,m">
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id="c1Oy`ur2xW{C]RgQ|JRm">
                          </block>
                        </value>
                        <value name="ADD3">
                          <block type="text" id="fk5{t|T|F..)]DH+DgGU">
                          </block>
                        </value>
                        <value name="ADD4">
                          <block type="get_value" id=".^}eU!l?yKkJmiKCF@RU">
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="request" id="8xkanaj=7q/R@]pZxS;3">
                        <field name="LOG">log</field>
                        <value name="URL">
                          <shadow type="text" id="vhX,`pssA5?!=7xz517O">
                          </shadow>
                          <block type="text_join" id="};@G%YX9~`ODL8{JUo:e">
                            <value name="ADD0">
                              <block type="text" id="i.8r7X@t8=@AwI*J||s6">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="T)N-4aiOkb-S7LxDP(2=">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="b|8{4d9.,`XLJ)XF;vKr">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="vN=,qONjV]{?N:b2btaY">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="get_value" id="[5c*W8en`EAjgmf]_J{O">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="debug" id="88@B_=#eYb^`|[0q`J@6" disabled="true">
                            <value name="TEXT">
                              <shadow type="text" id="itD-2J12O=Mu1Z@WmnF?">
                              </shadow>
                              <block type="variables_get" id="tbs,D1!8.05BBk=G-!Z6">
                              </block>
                            </value>
                            <next>
                              <block type="control" id="1%u4czlp)1vbbyd%za(z">
                                <field name="OID">0_userdata.0.Rookie.bekommeXML</field>
                                  <block type="variables_get" id="IVHki$jCs)Yqb:]Fd|]H">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
      <block type="comment" id="zH38gdL8~[siVvu8CO[n" x="88" y="-1438">
        <field name="COMMENT">sendet mp3 play</field>
        <next>
          <block type="on_ext" id="ThVmDpi$2B{5u:B(:Q(T">
            <value name="OID0">
              <shadow type="field_oid" id="Wyp5f+DI{wEAGEIM}B$Y">
                <field name="oid">0_userdata.0.Rookie.STEUERUNG.PLAYmp3</field>
              </shadow>
            </value>
              <block type="debug" id="%!0^GACFy!r{ilCK4Y6;">
                <value name="TEXT">
                  </shadow>
                  <block type="text_join" id="V2$00f#[L]Brjv0o2+lw">
                    <mutation items="6"></mutation>
                    <value name="ADD0">
                      <block type="text" id="T_r5cwr!P[e#HL5P[4t}">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="Z/+5Inhc]oPYh40]5UpG">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="vaCac{Fs90Y$_:GN@1YN">
                        <field name="TEXT">:11000/Add?service=LocalMusic</field>
                      </block>
                    </value>
                    <value name="ADD3">
                      <block type="text" id="[}Q++:vHUVV{9;n^jQyL">
                        <field name="TEXT">&amp;playnow=1&amp;where=next</field>
                      </block>
                    </value>
                    <value name="ADD4">
                      <block type="text" id="6)_SN(z~:`f5kV2MTu*_">
                        <field name="TEXT">&amp;file=</field>
                      </block>
                    </value>
                    <value name="ADD5">
                      <block type="get_value" id="!tNn7~e}_d;=N7{Kljjb">
                        <field name="OID">0_userdata.0.Rookie.STEUERUNG.PLAYmp3</field>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="control" id="g89wiwrIwl]{*VOE2~yf">
                      <block type="text_join" id=":Gn0ItSvwo2eV]j!O(b7">
                        <value name="ADD0">
                          <block type="text" id="[ad)NVw[SYCsPBmAlq#c">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="get_value" id="x8lLQ1q997Yk/wWj{BJK">
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id=")@he!vfKv%ACb;s5E/lZ">
                            <field name="TEXT">:11000/Add?&amp;service=LocalMusic</field>
                          </block>
                        </value>
                        <value name="ADD3">
                          <block type="text" id="tw~ilay$Ux{_@c^_fjly">
                            <field name="TEXT">&amp;playnow=-1</field>
                          </block>
                        </value>
                        <value name="ADD4">
                          <block type="text" id="h02Vn$[i%U$9~dt+NSL;">
                          </block>
                        </value>
                        <value name="ADD5">
                          <block type="get_value" id="^s$T5CBxuqnT8]3h:}6x">
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="request" id="HmA5|uKGJbOnCp/w7p%5" disabled="true">
                        <value name="URL">
                          </shadow>
                          <block type="text_join" id="P4]g7Ii9jy)E-HOIPUp{">
                            <value name="ADD0">
                              <block type="text" id="R{3Df_5n53l[.B#ThOBh">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="v7Se%3Hk7.A|MO,0GX47">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="?-4{g!+U9h|Tn$VYENz8">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="fve1Y,Ezl.|F]$#J:M!d">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="get_value" id="A7+Y;K`0HU4Y2lz#Fos|">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="debug" id="S9LK@;M(^q2io/#j=Xmf" disabled="true">
                            <value name="TEXT">
                              </shadow>
                              <block type="variables_get" id="|D-qgb:I.vH-baOSaBa:">
                              </block>
                            </value>
                            <next>
                              <block type="update" id="XZaO@~:FJM-=*VgQCuBu">
                                  <block type="variables_get" id="nJI4),xDQUS6sjs(Q[RJ">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="comment" id="Zy-`i2yz8~@YSm5aTbyp">
                <field name="COMMENT">sendet add mp3 next</field>
                <next>
                  <block type="on_ext" id="^uM%Q]roe/evLR%_@}IW">
                    <value name="OID0">
                      <shadow type="field_oid" id="B.WB{+_a{DM+Y]wMR4x.">
                        <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDmp3</field>
                      </shadow>
                    </value>
                      <block type="debug" id=":(#d^8)4;P6@uH[ho42s">
                        <value name="TEXT">
                          </shadow>
                          <block type="text_join" id="yQ8hW9A4ShV:[0f+C/hc">
                            <value name="ADD0">
                              <block type="text" id="?|=0r)+JMy2T_TVbRa#o">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="C1*ytTz??Yh75At#{Y~(">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="HuI*YO-[U2KS@/ISsqz-">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="*SzX1j0}q54ra7KiyfW=">
                                <field name="TEXT">&amp;playnow=-1&amp;where=next</field>
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="text" id="H;*jiC);QY)VHkt8EWT2">
                              </block>
                            </value>
                            <value name="ADD5">
                              <block type="get_value" id="E#a3xI|w=]a=5m-i*;;t">
                                <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDmp3</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="zsM,|)u^+#i!+1BXgE-h">
                              <block type="text_join" id="i5Nir(SHEU[=HIP;71*/">
                                <value name="ADD0">
                                  <block type="text" id="X|uM$HkBMPLS~GD+U,gq">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="get_value" id="9s{En1KN~$k|ui$2+Gln">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="NWN0F:b{SQ~?(C^}fc|U">
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="text" id="h]oaTV(1Z50mMvGgh^j4">
                                  </block>
                                </value>
                                <value name="ADD4">
                                  <block type="text" id="-1.jsx-TOT-(`%(hVwc3">
                                  </block>
                                </value>
                                <value name="ADD5">
                                  <block type="get_value" id="kjUDvhbTu8$%E^$7H{2*">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="request" id="%Bj*Pe[}(?w_sMK7|$GX" disabled="true">
                                <value name="URL">
                                  </shadow>
                                  <block type="text_join" id="$X5|m1-qt8.3!,fDAe_1">
                                    <value name="ADD0">
                                      <block type="text" id="ntH8HxOiItc334h*7QQu">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="get_value" id="#?qL/NUaO!#a?p-.p:d!">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="AEQL(.}@n51PPBd2dIMw">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      <block type="text" id="f?XgQWNe2^Rb,80Dzq2g">
                                      </block>
                                    </value>
                                    <value name="ADD4">
                                      <block type="get_value" id="ErFZl+zwV$,qdS%KmyT.">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="debug" id="9H%}qkAm)kq0DL.0ih=-" disabled="true">
                                    <value name="TEXT">
                                      </shadow>
                                      <block type="variables_get" id="tRJ+ge29B-t[W`:x^GS0">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="update" id="W@6Q98*{)G]CtMONHOqX">
                                          <block type="variables_get" id="JM4Zn?(!+VGN*ZQz$M],">
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                      <block type="comment" id="A;]3}_esIT9Y6?Z_t4x4">
                        <field name="COMMENT">sendet add mp3 last</field>
                        <next>
                          <block type="on_ext" id="AA+8d]nGD3}L^!{GgObw">
                            <value name="OID0">
                              <shadow type="field_oid" id="hDwMq_$@HnS,w?MNNpu8">
                                <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDmp3Last</field>
                              </shadow>
                            </value>
                              <block type="debug" id="Bk)wW1*!?O|]l6O)J96Y">
                                <value name="TEXT">
                                  </shadow>
                                  <block type="text_join" id="[upb72zmekWTmi8TTO%.">
                                    <value name="ADD0">
                                      <block type="text" id=")8c^`7V_.ML=!+O-dYGh">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="get_value" id="8#w^xzjCT$IF(ud$sC.%">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="/)/{1DVoZ(M4vE#{MF^H">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      <block type="text" id="H[h^}wK1_y;=.%UY;?h-">
                                        <field name="TEXT">&amp;playnow=-1&amp;where=last</field>
                                      </block>
                                    </value>
                                    <value name="ADD4">
                                      <block type="text" id="Uj^W_FNVv`^F#dH+p{;S">
                                      </block>
                                    </value>
                                    <value name="ADD5">
                                      <block type="get_value" id="nhsyR*:{sXw~R-J-A(Kg">
                                        <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDmp3Last</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="control" id="k_g3+gG/!Ldc+-S;r{I]">
                                      <block type="text_join" id="|3zy0PvG!x1,|ab1fk6j">
                                        <value name="ADD0">
                                          <block type="text" id="C+:lvVog;L/vVZl*):BK">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="get_value" id="h*|VGKmzknAELZK(hpPs">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="K2?2~wN/Xh[VUpJa!kFs">
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          <block type="text" id="RXskyzdJ,+jF.gUiAb0W">
                                          </block>
                                        </value>
                                        <value name="ADD4">
                                          <block type="text" id="LOBG:)vl!V!6AgwN5zet">
                                          </block>
                                        </value>
                                        <value name="ADD5">
                                          <block type="get_value" id="pEWia6%vvTTOf6hdyy|S">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="request" id="oy;?aC0UQ9KtWk}fH|lZ" disabled="true">
                                        <value name="URL">
                                          </shadow>
                                          <block type="text_join" id="^UuA.^LZLn)pq9QTAE+l">
                                            <value name="ADD0">
                                              <block type="text" id="QfG==+Q56rN`=D%nQ$Pi">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="ic3M?^!6M;_4ppvrAz0O">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="AtkrQ:Ak{*v7PV1+xk?8">
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              <block type="text" id="gUGnUc}{bb7kEQ4UX3))">
                                              </block>
                                            </value>
                                            <value name="ADD4">
                                              <block type="get_value" id="O#@UNPH2h:9i+3n^+ip@">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="debug" id="=Sl1]201(S{=2TlF5,Sx" disabled="true">
                                            <value name="TEXT">
                                              </shadow>
                                              <block type="variables_get" id="uS/j8T]J_n~A!fx{6)Hi">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="update" id="4_6h?ol6xZNbmz-;?3Cv">
                                                  <block type="variables_get" id="+KR,f$?82=5taLI92{pV">
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
      <block type="comment" id="31:D[.TFR$!uczm2Ru_A" x="1188" y="-1412">
        <field name="COMMENT">sendet ordner play</field>
        <next>
          <block type="on_ext" id="W~RG;O:8Z][fdTA@MXOK">
            <value name="OID0">
              <shadow type="field_oid" id="RBe2vre|%7I^g6`EU1:/">
                <field name="oid">0_userdata.0.Rookie.STEUERUNG.PLAY</field>
              </shadow>
            </value>
              <block type="debug" id="0(2/PqFA%TNWf6)slm;4">
                <value name="TEXT">
                  </shadow>
                  <block type="text_join" id="_[Ki9GFVdb(M(RPeX,AL">
                    <value name="ADD0">
                      <block type="text" id="3zST{G{u1|M-0[sl?09s">
                      </block>
                    </value>
                    <value name="ADD1">
                      <block type="get_value" id="Yq6VQySbRpybk+1pp-(y">
                      </block>
                    </value>
                    <value name="ADD2">
                      <block type="text" id="=KU3.xuWu[7N~cSf,4tz">
                      </block>
                    </value>
                    <value name="ADD3">
                      <block type="text" id="P[Vdowa/Hch$`,lV:)4T">
                      </block>
                    </value>
                    <value name="ADD4">
                      <block type="text" id="XPh]1k}_RUIxcdv4feoK">
                      </block>
                    </value>
                    <value name="ADD5">
                      <block type="get_value" id="OP,8m)8V02LCv9h{G%|D">
                        <field name="OID">0_userdata.0.Rookie.STEUERUNG.PLAY</field>
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                  <block type="control" id="=2.{F8hxzHyJx|bu7hpc">
                      <block type="text_join" id="YW/6H|z#}4ALjw(C(0Y~">
                        <value name="ADD0">
                          <block type="text" id="iMYI;kibl}*)FuJB~G@t">
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="get_value" id="0AoQm[Ut#8F+9egAwpZ+">
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id=";Rob|cMTNS4+uQ,B,{xn">
                          </block>
                        </value>
                        <value name="ADD3">
                          <block type="text" id="DOav*.JJH_TVJ+#!8!M=">
                          </block>
                        </value>
                        <value name="ADD4">
                          <block type="text" id="G3veM_kktZ{2x1WtK5Hc">
                          </block>
                        </value>
                        <value name="ADD5">
                          <block type="get_value" id="hg[mzaP1UvvqHI;=v^DC">
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="request" id="lv,9mzT}OdK;3/[3*YCA" disabled="true">
                        <value name="URL">
                          </shadow>
                          <block type="text_join" id="5Lp[2~k!ZQgZf([_[%pW">
                            <value name="ADD0">
                              <block type="text" id="-C:d]eW//,yT?Al`oxr5">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="x)f}hor{bL,|aKwpH6__">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="mpy*oDj=}|#2n1lk,D2t">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="YLpY7I,vJXO~]w7tm9c+">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="get_value" id="W0VHGV~@BGp+wSl9a!+`">
                              </block>
                            </value>
                          </block>
                        </value>
                          <block type="debug" id="{V4E9%O;6.Qsj_Tpf5xV" disabled="true">
                            <value name="TEXT">
                              </shadow>
                              <block type="variables_get" id="hP)64*3:X6%PQkpbpUH4">
                              </block>
                            </value>
                            <next>
                              <block type="update" id="P{~59nDP}[l(yMV~Cl^T">
                                  <block type="variables_get" id="QoH4|C(HW7wu0+Nq!$Uo">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <next>
              <block type="comment" id="{Q4khG|~QFFFL7!t/cE~">
                <field name="COMMENT">sendet add ordner next</field>
                <next>
                  <block type="on_ext" id="h4B,*3sx[0:R33g.gII{">
                    <value name="OID0">
                      <shadow type="field_oid" id="ayp^uC4o6CQwQkGT=+hV">
                        <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADD</field>
                      </shadow>
                    </value>
                      <block type="debug" id="L`UcgHbW/[{7[*=*2HN}">
                        <value name="TEXT">
                          </shadow>
                          <block type="text_join" id="E+27V2wEZ:TJRE/cE%t-">
                            <value name="ADD0">
                              <block type="text" id="nQSoKnI{GDmFSPFz0J[f">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="get_value" id="SZ46d$R!#4(mIp!|^}R0">
                              </block>
                            </value>
                            <value name="ADD2">
                              <block type="text" id="yY]a`MR4bj6L@/[QdT3T">
                              </block>
                            </value>
                            <value name="ADD3">
                              <block type="text" id="!xhW,$bO0n.4B30Mi~s@">
                              </block>
                            </value>
                            <value name="ADD4">
                              <block type="text" id="PLa._{4|p6022mpCAv*i">
                              </block>
                            </value>
                            <value name="ADD5">
                              <block type="get_value" id="U$m(kZL$J2l_Hc[5UNsU">
                                <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADD</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="`MJI0e42z5YT+`[nv${3">
                              <block type="text_join" id="=C=YG$d;:x2njQjwR{0{">
                                <value name="ADD0">
                                  <block type="text" id="*1sf)bQY*KTa2=!z;p*,">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="get_value" id="s)`vT19lJTc.IWtj})Dl">
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="*f$z10Mb:UGCTA^]2A+|">
                                  </block>
                                </value>
                                <value name="ADD3">
                                  <block type="text" id="}|wjxmT)@-A%TK525q):">
                                  </block>
                                </value>
                                <value name="ADD4">
                                  <block type="text" id="6F6:_u#^~U6}yVmnTO2P">
                                  </block>
                                </value>
                                <value name="ADD5">
                                  <block type="get_value" id=":^!;v@it;1U|^{^.IE)m">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="request" id="6BiCh=6#]ddTd%G^q=RR" disabled="true">
                                <value name="URL">
                                  </shadow>
                                  <block type="text_join" id="z$7*K8Cv]zK%XAToPCke">
                                    <value name="ADD0">
                                      <block type="text" id="H.,0GA?[@At-M4Rz}uZ|">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="get_value" id="CqCmqe.`WRFrxCo28kG^">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="~aicH`I`-k_m!%eY4(7v">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      <block type="text" id="0xFDbu9r{OCKngn7WIO{">
                                      </block>
                                    </value>
                                    <value name="ADD4">
                                      <block type="get_value" id="@IKg#B|B[/TM.Ak|V{`q">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="debug" id="FKV$INmgRf0V6]a8cg,|" disabled="true">
                                    <value name="TEXT">
                                      </shadow>
                                      <block type="variables_get" id="6h%Hv8Jh[2/YVuvHtei0">
                                      </block>
                                    </value>
                                    <next>
                                      <block type="update" id="6JN{C550~j[]O]wb|teq">
                                          <block type="variables_get" id="]o3Bf*.+{M#*ugTiQ4mh">
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                      <block type="comment" id="e5|h@r{pn6D1#Zw]OnN{">
                        <field name="COMMENT">sendet add ordner last</field>
                        <next>
                          <block type="on_ext" id="51U4{l7Kg7u4ttnU(vlv">
                            <value name="OID0">
                              <shadow type="field_oid" id="p{B7-G[!B=KV=ns6H!Ey">
                                <field name="oid">0_userdata.0.Rookie.STEUERUNG.ADDLast</field>
                              </shadow>
                            </value>
                              <block type="debug" id="lelwcg81pt],cL~E#2CC">
                                <value name="TEXT">
                                  </shadow>
                                  <block type="text_join" id="v}ouCP~FGCj5fT57Ip5p">
                                    <value name="ADD0">
                                      <block type="text" id="*Ia_@%o]sJM[j3s~HXfQ">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="get_value" id="F@M}+Fnkyl4/:c1GY|Xd">
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id=".(J0$^^{,Xl3`L{EosA5">
                                      </block>
                                    </value>
                                    <value name="ADD3">
                                      <block type="text" id="51W-[lp~=z.ZS.d#evM~">
                                        <field name="TEXT">&amp;playnow=1&amp;where=last</field>
                                      </block>
                                    </value>
                                    <value name="ADD4">
                                      <block type="text" id="=,w1VR4$$U^XF~mCQ:tK">
                                      </block>
                                    </value>
                                    <value name="ADD5">
                                      <block type="get_value" id="LKJi{SYL|js[w6K|fQn(">
                                        <field name="OID">0_userdata.0.Rookie.STEUERUNG.ADDLast</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                  <block type="control" id="tRqLL:X=_EQzl;%.vOb#">
                                      <block type="text_join" id="SeUJUC4KxF$YIT+7}KLK">
                                        <value name="ADD0">
                                          <block type="text" id="#kXFho0qaRQW{@OwD)m2">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="get_value" id="wO{d!F9/@6B+u)670]iI">
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="u4Q)OLDG@uPcTUk9|H:U">
                                          </block>
                                        </value>
                                        <value name="ADD3">
                                          <block type="text" id="%jz[ZS!N[0sKUxmGHej1">
                                          </block>
                                        </value>
                                        <value name="ADD4">
                                          <block type="text" id="OjpjT(r*d7{eao:$SXnQ">
                                          </block>
                                        </value>
                                        <value name="ADD5">
                                          <block type="get_value" id="nbmV+[fKh:!X`TP$:1PH">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                      <block type="request" id="p]TD.RpVp[:!~{i*jZ-b" disabled="true">
                                        <value name="URL">
                                          </shadow>
                                          <block type="text_join" id="RST0|=/S2MNRGZl-J~!7">
                                            <value name="ADD0">
                                              <block type="text" id="V~dU.pr$8~z]Krd838k,">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="DOVbO*9S|~R#6XCNeY(n">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="a+k9YmmA5U`apkj?XBbe">
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              <block type="text" id="EONW,X{a)$tfR`P7d=UY">
                                              </block>
                                            </value>
                                            <value name="ADD4">
                                              <block type="get_value" id="(IrpNczt0rZJG;JlkF_v">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="debug" id="#Atf8cpT)*Vs;/zy5*,4" disabled="true">
                                            <value name="TEXT">
                                              </shadow>
                                              <block type="variables_get" id="etIj=}dUqBH+K9+#wi`g">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="update" id="/#RLDq[bl*#C!LUhdbI`">
                                                  <block type="variables_get" id="DF_b6=Uftwc?QFk5;oz]">
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    #61
    @rookie50
    wenn du die shortcats aus der liste weghaben willst - ändere einfach diese zeile - dann sind die emojis in der letzten spalte weg
    ist das table-script
    R 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      @rookie50
      Rookie50
      #62
      @liv-in-sky
      Guten Morgen, ich muss noch schauen, ob ich den shortcut benötige.
      Leider hattest du recht, bis dato kann ich mir die Tabelle nur anzeigen lassen und nicht bedienen.
      Allerdings würde mir diese Anzeige schon fast reichen.
      LG
      liv-in-skyL 4 Antworten Letzte Antwort
      • R Rookie50
        @liv-in-sky
        LG
        liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        #63
        @rookie50
        dann müßten wir evtl eine 2te tabelle schreiben, die du nur für iqontrol hast - wäre auch nicht wild .
        in iqontrol reicht dann eigentlich nur eine spalte und die suche kann auch weg
        ich schau mal ob ich die ein solches script vorbereiten kann - dann einfach dazufügen und in iqontrol einbinden
        bleibt nur noch die steuerung in iqontrol
        • R Rookie50
          @liv-in-sky
          LG
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #64
          @rookie50
          bitte 2- spaltig für iqontrol
          einfach neues script anlegen undes gibt einen neuen dp untr javascript.0..... für die tabelle
           //@liv-in-sky 2021  23.3.-15:40
          // DAS WIDGET IN DER VIS
          // das Standard html-Widget wird genutzt in der VIS - dazu den DP javascript.x.Tabellen@Liv.TestTabelleVIS.HTMLTableVis als binding angeben d.h.
          // im html-teil des widgets wird dier daten punkt in geschweiften klammern angegeben z.B. {javascript.0.Tabellen@Liv.TestTabelleVIS.HTMLTableVis}
          // @ts-ignore
          let braucheEinVISWidget=true;                          // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
          let  dpVIS="SongsTabelleIQontrol"                            // WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  Ist der Name zum datenpunkt anlegen
          let braucheEinJSON=false;                               // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
          let  dpJSON="SongsTabelleJSONIControl"                          // WICHTIG wenn braucheEinJSON auf true gesetzt !!   Ist der Name zum datenpunkt anlegen
          let mySchedule="  */15 * * * * ";                         // jede minute
          //ZUSÄTZLICH VARIABLEN
          let sortierenEIN=false;
          let farbeInaktiverShelly="#5590CA"
          let welcheSortierung=1;          // je nach spalte von 0 bis 6
          let geteiteVersionsAnzeige=true; // version in spalte 7 wird 2-zeilig
          const schalterUmrahmung="0"                              //wenn überschriften buttons sind , den rahmen mit 0 wegmachen
          let mitSearch=true;
          let ipButtonColorONBkground="#CBCBCA";
          let powerButtonColorONSchrift="black";
           let ipButtonColorONBkground2="#5590CA";
          let powerButtonColorONSchrift2="white";
          let flexboxView=false;   // startet im flexbox modus - keine tabelle
          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3 - es MÜSSEN in allen Arrays die GLEICHE Anzahl für die Werte sein
          let htmlFeld=        ["","NAME","PLAY","ADD",""];              // GLEICHE ANZAHL !! NAME/ÜBERSCHRIFT DER SPALTE
          let val=             ["true","true","false","false","false"];                 // GLEICHE ANZAHL !! SPALTE ANZEIGEN/AUSBLENDEN UND HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WERDEN -  jeder val[x] muss unten in der schleife gesetzt werden !!
          let Feld1lAlign=     ["center","left","center","center","center"];         // GLEICHE ANZAHL !! AUSRICHTUNG IN DER SPALTE
          let htmlSpalte1Weite=["25px","200px","25px","95px","0px"];                        // GLEICHE ANZAHL !! BREITE DER SPALTE, wenn "0px" auto
          let schalterInSpaltenUeberschrift=[true,true,true,true,true,true,true,true];                  // WENN BUTTONS INSTALLIERT WERDEN - sonst false
          let symbolSchalter=              ["na","&check;","&cross;"];        //ONLINE SYMBOLE         // SYMBOLE DER BUTTONS - standardmäßig sind die spaltennamen (htmlFeld) genutzt - werden im standard nicht genutzt
          //Symbole für Tabelle z.b.: ⚪  ⚫ ⭕  ➕ ➖ 🎵 🔴 🔵 ⏱ 💀 👍 👎 📑 💲 👀 🔹 ✅ ❌ ⚠️ mehr: https://emojiterra.com/de/ oder https://unicode-table.com/de/html-entities/
          //hier werden die styles für die tabelle definiert
          //ÜBERSCHRIFT ÜBER TABELLE
          const htmlUberschrift=false;                             // mit Überschrift über der tabelle
          const htmlSignature=true;                               // anstatt der Überscghrift eine signature: - kleiner - anliegend
          const htmlFeldUeber='BlueSound Library';                // für Überschrift und Signature falls htmlUberschrift und htmlSignature ist true
          const htmlFarbUber="white";                              // Farbe der Überschrift
          const htmlSchriftWeite="normal";                         // bold, normal - Fettschrift für Überschrift
          const htmlUEberFontGroesse="18px";                       // schriftgröße überschrift
          //SEITENLEISTE
          const ichWillSeitenLeiste=true;                          // links einblenden einer Seitenleiste
          const nameSeitenLeiste="BLUESOUND"
          const breiteSeitenleiste=35;
          const schriftGroesseSeitenleiste=14;
          const abstandSeitentextVonOben=4;
          const htmlFarbSeiteSchrift="white";
          const htmlBackgroundFarbeSeitenliste="blue";
          //BUTTON ÜBERSCHRIFT
          const htmlBackgroundButtonUeberschrift="transparent";
          //SUCHE
          let bkgroundSearch=1;                                    //   hintergrund für suche-ergebnis und flexboxen    // 1: carbon; 2: iobroker; 3: colored bubbles;  4: gradient farben von htmlFarbTableColorGradient1; 5: gradient farben wie farbeUngeradeZeilen; 6: heller hintergrund
          const sucheEin=false;
          const sucheHoehe=25;
          let mehrfachTabelle=1;                                   // bis zu 3 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3 !!!
          const trennungsLinie=1;                                // extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
          const farbetrennungsLinie="#5590CA";                     // bei mehreren Tabellen nebeneinander wird ein Strich zw. den Tabellen gezogen
          const htmlFarbTableColorUber="white"                     // Spalten-Überschrift in der tabelle - für die einzelnen Spalten //"#BDBDBD";
          const htmlFarbZweiteTabelle="white";                     // Farbe der Spalten-Überschrift bei jeder 2.ten Tabelle
          //ÜBERSCHRIFT SPALTEN - OBERSTE ZEILE IN TAB
          const UeberSchriftHoehe=30;                            // Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
          const LinieUnterUeberschrift="1";                        // Liniehoehe nur unter Spaltenüberschrift
          const farbeLinieUnterUeberschrift="#233E58";               // LinienFarbe unter Spaltenüberschrift
          const groesseUeberschrift=12;
          const UeberschriftStyle="normal"                         // möglich "bold"
          const UeberschriftSpalten=true;                          // ein- oder ausblenden der spatlen-überschriften
          //GANZE TABELLE
          const abstandZelle="7";                                  // legt den abstand in den zellen zum rahmen fest
          const zeilenAbstand=20;                                   // legt den abstand zwischen den zeilen fest
          const farbeUngeradeZeilen="#2F2F2F";                     // Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2 - bei "transparent" gewinnt htmlFarbTableColorGradient1
          const farbeGeradeZeilen="#3c3c3c"//"#151515";            // Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2   - bei "transparent" gewinnt htmlFarbTableColorGradient2
          let weite="300";                                        // Weite der Tabelle - verhindert das dynamische breiter werden, wenn werte unterschiedliche werte haben
          let hoeheTabelle=387;
          const zentriert=true;                                    // ganze tabelle zentriert im html Widget - muss in pixel angegeben werden oder "auto"
          const backgroundAll="#000000";                           // Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
          const htmlSchriftart="Helvetica"//"Ubuntu-Regular"                    // "Jura-DemiBold"   //"RobotoCondensed-Bold"   //"Helvetica"; .....
          const htmlSchriftgroesse="12px";                         // schriftgröße in den zellen
          const rahmenBreite="1px";                                //mit 0 ist äußerer rahmen weg
          //FELDER UND RAHMEN
          const htmlFarbFelderschrift="#CBCBCA";                   // SchriftFarbe der Felder
          const htmlFarbFelderschrift2="#CBCBCA";                  // SchriftFarbe der Felder für jede 2te Tabelle
          const htmlGragient=[150,30,70];                          // einstellung des gradienten
          const htmlFarbTableColorGradient1="#0F263D";             // Gradient - Hintergrund der Tabelle - Verlauffarbe
          const htmlFarbTableColorGradient2= "#233E58"//"#5590CA";              // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
          const htmlFarbTableBorderColor="grey";                   // Farbe des Rahmen - ist dieser gleich den gradienten, sind die rahmen unsichtbar
          let htmlRahmenLinien="none";                             // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
          // AB HIER NICHTS  ÄNDERN -------------------------------------------------------------------------------------------------
          // AB HIER NICHTS  ÄNDERN ---------------------------------erst wieder ab Zeile 134----------------------------------------
          let borderHelpBottum;
          let borderHelpRight;
          let htmlcenterHelp;
          let htmlcenterHelp2;
          let trHelperClass=" ";
          let htmlTabUeber4;
          let htmlTabUeber2;
          let htmlTabUeber2_1;
          let searchMe;
          let htmlSeitenleiste;
          let htmlTabStyle;
          let htmlTabUeber3="";       //wird in function writeHTML gesetzt - wegen umschalten views
          let buttonScript; //scripte am ende einfügen
          let bkgDiv;   //background scroll-div
          let scrollBar; //dünne scrollbar
          let aktiv=-1; let inaktiv=0;
          let myButtonUeberschrift; //not in use
          let htmlZentriert;   //css
          let einmalAbstand; //seitenleiste
          if(String(htmlRahmenLinien)=="rows") {borderHelpBottum=1;borderHelpRight=0;}
          if(String(htmlRahmenLinien)=="cols") {borderHelpBottum=0;borderHelpRight=1;}
          if(String(htmlRahmenLinien)=="none") {borderHelpBottum=0;borderHelpRight=0;}
          if(String(htmlRahmenLinien)=="all")  {borderHelpBottum=1;borderHelpRight=1;}
          if(weite=="auto") {weite="100%"} else {weite=String(Number(weite)*mehrfachTabelle)}
           makeMyCSS();
           makeMySearch_Seitenleiste();
           makeMyVisScripte();
          if ( !(val.length == Feld1lAlign.length && htmlSpalte1Weite.length == htmlFeld.length && val.length == htmlFeld.length) || (mehrfachTabelle<1 || mehrfachTabelle>3) )
               { log("Anzahle der Definitions Arrays sind ungleich ODER mehrfachTabelle ist falsch - Script wurde gestoppt !!!","error");
                   // @ts-ignore
                   stopScript();}
          let langeGesamt=0;
          let htmlTabUeber="";
          let htmlOut="";
          let mix;
          let counter;
          let makeJsonWidget;
          let myObject=[];
          let mitAlphabet=false;
          needDP();
          function writeHTML(){
              // rückkopplung zu vis -werteliste
          setTimeout(function () {  setState("0_userdata.0.Rookie.VIEW.SEUERUNG.toPlay",false);
                                       setState("0_userdata.0.Rookie.VIEW.SEUERUNG.addNext",false);
                                       setState("0_userdata.0.Rookie.VIEW.SEUERUNG.addLast",false);
                                   }, 500);
              aktiv=-1;  inaktiv=0;
          let seitenLeistenTest="";
          //log(flexboxView.toString())
          flexboxView ? htmlTabUeber3=`</tr></thead><tbody></tbody></table><div class="divFlexBoxen${dpVIS}">` :
                       htmlTabUeber3=`</tr></thead><tbody class="scrollContent${dpVIS}" > `;
          let htmlTabUeber1=htmlTabUeber4
          myObject=[]
          let helperLeerzeile=""
          let makeJsonWidget=[];
          htmlOut="";
          counter=-1;
          //---------alle val[x] werte müssen von euch bestimmt werden - val[0],val[1],val[2] !!!-------------------------------------------------------------
          let valueuptime
          let myReturnJson=[]
          let myDataJson=JSON.parse(getState("0_userdata.0.Rookie.VIEW.JSON").val)
          myReturnJson.push({
                "nummer": "0",
                "anzeige":"return",
                "value" : "Return",
                "file" : "⏱"
          let myJSONDATA =myReturnJson.concat(myDataJson)
          //log(JSON.stringify(myJSONDATA))
          for (let i=0; i<myJSONDATA.length;i++) {           // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
                 val[0]=val[1]=val[1]=val[2]=val[3]= "missingState";
                     // log( myJSONDATA.anzeige)
                  myObject.push({                "value0" : myJSONDATA[i].anzeige,            //  "INSTANCE"
                                                 "value1" : myJSONDATA[i].nummer,            //  "SINCE"
                                                 "value2" : myJSONDATA[i].file,            //  "STATUS"
                                                 "value3" : myJSONDATA[i].value
                                                    //   ID
                    makeJsonWidget.push({        [htmlFeld[0]] : val[0],  //  "INSTANCE"
                                                 [htmlFeld[1]] : val[1],  //  "SINCE"
                                                 [htmlFeld[2]] : val[2]
                                                           // diese function muss als letztes in der eigenen schleife aufgerufen werden
             };                                            // Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
            // Sortierungen---------------------------------------------------------
            //welcheSortierung=3
            if( sortierenEIN && (welcheSortierung==3 || welcheSortierung==4 || welcheSortierung==1)    ) {
                       if(welcheSortierung==3) myObject.sort(function (alpha, beta) { return  Number(beta["value4"]) -Number(alpha["value4"]);   });
                       if(welcheSortierung==4) myObject.sort(function (alpha, beta) { /*log(beta.valueuptime+" --" +alpha.valueuptime);*/ return  beta.valueuptime -alpha.valueuptime;   });
                       if(welcheSortierung==1)   myObject.sort( function( a, b )   {
                                                   	a = a["value1"].split( '.' );
                                                   	b = b["value1"].split( '.' );
                                                 	for( var i = 0; i < a.length; i++ )	{
             	                                 	if( ( a[i] = parseInt( a[i] ) ) < ( b[i] = parseInt( b[i] ) ) )
             	                         		return -1;	else if( a[i] > b[i] )
             	                            	return 1;}  	return 0;} );
                       } else {
              switch (welcheSortierung) {
                 case 0: sortMe("alpha","value0");break;
                 case 1: break;
                 case 2: sortMe("bool","value2");break;
                 case 3: break;
                 case 4: break;
                 case 5: sortMe("alpha","value5");break;
                 case 6: sortMe("alpha","value6");break;
             for(let zz=0;zz<myObject.length;zz++){
           // Unterüberschften ------------------------------------------------------
                  if (mitAlphabet){
                    if( myObject[zz].value0[0]!=helperLeerzeile){ tabelleAusbessern();
        counter=-1;  for(let ic=0;ic<mehrfachTabelle;ic++ ) { for (let tt=0 ;tt<val.length;tt++)
        { tt==0 && ic==0 ? val[tt]=(myObject[zz].value0[0]).toUpperCase() : val[tt]="&ensp;"
        counter++;tabelleBind();langeGesamt++; }
                    helperLeerzeile=myObject[zz].value0[0] } ; sortierenEIN=false;}
           // Zuteilung der Tabellenspalten-------------------------------------------
             aktiv++
              val[0]=""
              val[1]=myObject[zz].value0;
              log(myObject[zz].value3)
              val[2]=myObject[zz].value1; // log(typeof val[2])
             // val[2]=myObject[zz].value2;
           //  let valButton2=""
             // val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton2+"\')\">"+"➡️" + "</button>"
              val[4]= ""// "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnShortcut\(\'"+"valButton"+"\')\">"+"🤍" + "</button>" //myObject[zz].value3;
          //log(myObject[zz].value3)
            let valButton=myObject[zz].value1;
            if (myObject[zz].value2.includes("📁"))   { let valButton=myObject[zz].value1;
                                                       val[0]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnNewFolder\(\'"+valButton+"\')\">"+myObject[zz].value2 + "</button>"
                                                       valButton=encodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val+"/"+myObject[zz].value3)
                                                        val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderPlay\(\'"+valButton+"\')\">"+"▶️" + "</button>"
                                                        val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAdd\(\'"+valButton+"\')\">"+"⏩" + "</button>"
                                                        val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
            if (myObject[zz].value2.includes("⏱"))   {val[0]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnNewFolder\(\'"+valButton+"\')\">"+myObject[zz].value2 + "</button>"
                                                        val[2]=""; val[2]="";val[4]=decodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val.replace(/^.+\/(.+)$/,"$1"))
                                                        val[3]=""}
            if (myObject[zz].value2.includes("🎵"))   {val[0]= "<font color=\"#A4ACF0\">"+" &#9834;"+" </font> " //+ myObject[zz].value2+" "+val[0]
                                                       let valButton=encodeURI(myObject[zz].value3)
                                                       val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"▶️" + "</button>"
                                                       val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Add\(\'"+valButton+"\')\">"+"⏩" + "</button>"
                                                     //   val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"⏩" + "</button>"
                                                       val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3AddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
          /* &#127926;
             if (!myObject[zz].value2) {val[2]=symbolSchalter[2];inaktiv++}
              if (myObject[zz].value2)  {val[2]=symbolSchalter[1];aktiv++}
              if (!myObject[zz].value2) {     val[0]="<font color=\""+farbeInaktiverShelly +"\">"+val[0]+"</font>";
                                             val[1]="<font color=\""+farbeInaktiverShelly +"\">"+val[1]+"</font>";
                                             val[2]="<font color=\""+farbeInaktiverShelly +"\">"+val[2]+"</font>";
                                             val[3]="<font color=\""+farbeInaktiverShelly +"\">"+val[3]+"</font>";
                                             val[4]="<font color=\""+farbeInaktiverShelly +"\">"+val[4]+"</font>";
                                             val[5]="<font color=\""+farbeInaktiverShelly +"\">"+val[5]+"</font>";
                                             val[6]="<font color=\""+farbeInaktiverShelly +"\">"+val[6]+"</font>";
               counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
              flexboxView ? flexboxBind() : tabelleBind();                                   // HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT
               langeGesamt++;                                   // WICHTIG Seitenleiste
             htmlTabUeber2=""
          //SpaltenÜberschrift
          for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { if (!schalterInSpaltenUeberschrift[ue] ) {
                             htmlTabUeber2=htmlTabUeber2.concat("<td  style=\"color:"+htmlFarbTableColorUber+"\">"+htmlFeld[ue]+"</td>")}
                             else {let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
                              if(ue==htmlSpalte1Weite.length-1) {htmlTabUeber2=htmlTabUeber2.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+
        "<button class=\"myButt"+dpVIS+"\" style=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text\-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button>"+" <font style=\"; font-weight: normal; font-size :"+groesseUeberschrift+"; color: "+htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+";\" >"+aktiv+"</th>")} else{
                                                 htmlTabUeber2=htmlTabUeber2.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\">"+""
        +"<button class=\"myButt"+dpVIS+"\" style\=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"\; color: "
        +htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text-align:left\" value=\"toggle\" onclick=\"setOnOtherValue\(\'"+valButton+"\')\">"
        +htmlFeld[ue]+"</button></th>")} } //symbolSchalter[ue]
          //SpaltenÜberschrift bei mehrfachtabelle
          if (!flexboxView){ htmlTabUeber2_1=""
          for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { let valButton="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+ue;
             if(ue==htmlSpalte1Weite.length) {htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+""
        +"<button class=\"myButt"+dpVIS+"\" style\=\" border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color\: "+htmlBackgroundButtonUeberschrift+"; color: "
             else{ if(ue==0){htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+"\" >"+""
             } else{
        +htmlFeld[ue]+"</button></th>")}}  }
          }else { htmlTabUeber2_1="";for (let ue=0;ue<htmlSpalte1Weite.length;ue++) { htmlTabUeber2_1=htmlTabUeber2_1.concat("<th class=\"myTHclass"+dpVIS+" toDel"+dpVIS+" emptyFlex2_1"+dpVIS+"\">"+htmlFeld[ue]+"</th>")}
          /*    for (let ue=0;ue<htmlSpalte1Weite.length;ue++) {
        +htmlFeld[ue]+"</button></th>")}*/
           htmlTabUeber="";
           switch (mehrfachTabelle) {
             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2_1+htmlTabUeber3; break;
             flexboxView ? flexboxFinish() :  tabelleFinish();
                if (braucheEinJSON ) {setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis",JSON.stringify(makeJsonWidget),1000 )}
          } // function ende
          //MAIN:
          schedule(mySchedule,  function () {
           writeHTML();
          // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
          on({id: "0_userdata.0.Rookie.VIEW.JSON", change: "any"}, function (obj) {
           // var value = obj.state.val;
           // log("bekommeXML: "+value)
                writeHTML();
          setTimeout(function () {writeHTML();  }, 2050);
           function tabelleBind(){
             case 1: if(counter%2==0)   {htmlOut=htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
                                         for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>"); // style=\"width:"+htmlSpalte1Weite[u]+"\"
        }  htmlOut=htmlOut.concat("</tr>");   break;
                                         } else   {htmlOut=htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
                                                   for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>"); //style=\"width:"+htmlSpalte1Weite[u]+"\"
             case 2: if(counter%4==0){  if(counter%2==0)  {htmlOut = htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
                                                           for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                          } else { for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } break;
                                     } else {
                                       if(counter%2==0)  {htmlOut=htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+" toDel"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                          } else {        for(let u=0;u<val.length;u++){ htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  }  break;}
             case 3: if(counter%2==0)  {  if(counter%3==0 ) {htmlOut = htmlOut+"<tr class=\"myclasstr_gerade"+dpVIS+" \">";
                                                             for(let u=0;u<val.length;u++){if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
                                         } else { if(counter%3==1)  {for(let u=0;u<val.length;u++){  if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+ "; color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>")}
        } else  { for(let u=0;u<val.length;u++){  htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");
        }  htmlOut=htmlOut.concat("</tr>");  } }  break;
                                       else {
                                          if(counter%3==0 )  {htmlOut = htmlOut+"<tr class=\"myclasstr_ungerade"+dpVIS+" \">";
                                                             for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\">"+val[u]+"</td>");} else
        {htmlOut=htmlOut.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+" toDel"+dpVIS+" toDel"+dpVIS+"\" style=\" border-right:"+trennungsLinie+"px solid "+farbetrennungsLinie+ ";\">"+val[u]+"</td>")}
                                       } else{ if(counter%3==1 )  { for(let u=0;u<val.length;u++){ if(u<val.length-1) {htmlOut=htmlOut.concat("<td class=\"myclasstd_normal"+dpVIS+" toDel"+dpVIS+"\" style=\"color:"+htmlFarbFelderschrift2+"\">"+val[u]+"</td>");} else
                  } //switch ende
           function tabelleAusbessern() {         // bessert mei mehrfachtabellen die nicht vollen zeilenn aus - bevor die unterüberschriften kommen
                 case 1:    break;
                 case 2:    let helpMehrfach="</td>";
                            for(let w=0;w<val.length;w++){helpMehrfach=helpMehrfach.concat("<td>&ensp;</td>")};helpMehrfach=helpMehrfach.concat("</tr>")
                            if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach);
                            break;
                 case 3:   let helpMehrfach2="</td>";
                           for(let w=0;w<val.length;w++){helpMehrfach2=helpMehrfach2.concat("<td>&ensp;</td>")};helpMehrfach2=helpMehrfach2.concat("</tr>")
                           if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach2);
                           let helpMehrfach3="</td>";
                           let helpMehrfach31="";for(let w=0;w<val.length;w++){helpMehrfach31=helpMehrfach31.concat("<td>&ensp;</td>")}
                           for(let w=0;w<val.length;w++){if(w<val.length-1) {helpMehrfach3=helpMehrfach3.concat("<td>&ensp;</td>")} else
        {helpMehrfach3=helpMehrfach3.concat("<td class=\"myclasstd_trennungslinie"+dpVIS+"\" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td>"+helpMehrfach31)}
                                                             };helpMehrfach3=helpMehrfach3.concat("</tr>")
                           if(counter%3==0)  htmlOut = htmlOut.replace(/<\/td>$/, helpMehrfach3);  break; }}
           function tabelleFinish() {
                 case 1:    break;
                            break;
                  var htmlUeber=    "<p  class=\"divWeiten"+dpVIS+"\" style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlUEberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), 'SS:mm:ss')+"</p>";
                  if(mitSearch) htmlUeber=htmlUeber+searchMe
                  var htmlUnter= "<div class=\"divWeiten"+dpVIS+"\" style=\"margin-top: 10px; color:"+htmlFarbUber+"; height: 30px; font-family:"+htmlSchriftart+"; font-size: 85%; text-align: center;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");"</div>";
                       var htmlOutVIS="";
                       if (htmlUberschrift)
                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript ;
                      } else {
                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript;
                     if (braucheEinVISWidget)  setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis", htmlOutVIS ,1000);
           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; height: 30px; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((new Date().getTime())), "SS:mm:ss");+"</div>"
          //htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
           //log(htmlOut);
          function flexboxBind(){
            htmlOut=htmlOut+"<div class=\"divFlexBoxenEinzeln"+dpVIS+" divInFlex"+dpVIS+"\"> <div  style=\"font-size: 125%; font-weight: bold\">"+val[0]+"</style></div><br>IP: "+val[1]+"<br>RSSI: "+val[4]
        +" </div>"
           //setStateDelayed("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis", myFlexer ,1000);  "<br> "+val[3]+   "<br> "+val[5]+
           //log(htmlOut)
          function flexboxFinish(){
          // htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</tbody></table></div></div>"+htmlUnter+"</center>"+ buttonScript ;
             var htmlOutVIS="";
                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript ;
                      } else {
                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</div></div></div>"+htmlUnter+"</center>"+ buttonScript;
           // htmlOut=htmlOut+"<div> val[0] <br> val[2] </div>"
          async function needDP(){
             for(let s=0;s<schalterInSpaltenUeberschrift.length;s++){ if(schalterInSpaltenUeberschrift[s]){
             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte"+s))) {
                 await createStateAsync("Tabellen@Liv."+dpVIS+".Spalte"+s, false,{type: "boolean", name: "Schalter_Spalte"+s, role: "value", read: true, write: true, } ); }
             if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".HTMLTableVis"))) {
                 await createStateAsync("Tabellen@Liv."+dpVIS+".HTMLTableVis", "empty",{type: "string", name: "HTML_Standard_Widget_mit_Binding", role: "value", read: true, write: true, } ); }
              if (!(await existsStateAsync("javascript." + instance + ".Tabellen@Liv."+dpVIS+".JSONVis"))) {
                 await createStateAsync("Tabellen@Liv."+dpVIS+".JSONVis", "",{type: "string", name: "JSON Format", role: "value", read: true, write: true, } ); }
             let arrTriggerSchalter=[]
             $("javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte*").each(function(id, i) {
                    arrTriggerSchalter.push(id)
           //  log(arrTriggerSchalter.toString())
             on({id: arrTriggerSchalter, ack: false, change: "any"}, function (obj) {
               //  log(obj.id)
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte0") welcheSortierung=1;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte1" )  welcheSortierung=1 ;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte2" )  welcheSortierung=1;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte4")  welcheSortierung=3;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte3" )  welcheSortierung=1;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte5") welcheSortierung=5;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte6" )  welcheSortierung=6;
               if (obj.id=="javascript." + instance + ".Tabellen@Liv."+dpVIS+".Spalte7" )  flexboxView=!flexboxView;
             //  log(String(mehrfachTabelle))
                 writeHTML();
          }, 900);
             });}, 5050);
          //SORTIEREN
          function sortMe(myType,value){
          if(myType=="alpha" ){ myObject.sort(function (alpha, beta) {
                      if ((alpha[value].toString().toUpperCase()).trim() > (beta[value].toString().toUpperCase()).trim())
                         return 1;
                      if ((beta[value].toString().toUpperCase()).trim()> (alpha[value].toUpperCase().toString()).trim())
                         return -1;
                      return 0;
          if(myType=="bool" ) {
            myObject .sort(function(x, y) { return x[value] - y[value] }); }
            if(myType=="num" )   { myObject.sort(function (alpha, beta) {
                               return  beta[value] -alpha[value];   });}
          function makeMyCSS() {
             trHelperClass=" ";
          for (let jj=0;jj<(Feld1lAlign.length)*mehrfachTabelle;jj++) {  //"td:nth-child(1) {width: "+htmlSpalte1Weite[0]+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite[1]+"}"+
                 trHelperClass= trHelperClass+ " .scrollContent"+dpVIS+" td"+":nth-of-type("+(jj+1)+") {width: "+htmlSpalte1Weite[jj]+"; text-align: "+Feld1lAlign[jj]+" }"
           //log(trHelperClass)
          switch (bkgroundSearch){
             case 1 :   bkgDiv=`background:
                                radial-gradient(black 15%, transparent 16%) 0 0,
                                radial-gradient(black 15%, transparent 16%) 8px 8px,
                                radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 0 1px,
                                radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 8px 9px;
                                background-color:#282828;
                                background-size:16px 16px;`; break;
            case 2 : bkgDiv=`background:
                             url(data:image/gif;base64,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)`
                            ; break
            case 3 : bkgDiv=`background:
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.15) 30%, rgba(255,255,255,.3) 32%, rgba(255,255,255,0) 33%) 0 0,
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.1) 11%, rgba(255,255,255,.3) 13%, rgba(255,255,255,0) 14%) 0 0,
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 17%, rgba(255,255,255,.43) 19%, rgba(255,255,255,0) 20%) 0 110px,
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 11%, rgba(255,255,255,.4) 13%, rgba(255,255,255,0) 14%) -130px -170px,
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.2) 11%, rgba(255,255,255,.4) 13%, rgba(255,255,255,0) 14%) 130px 370px,
                             radial-gradient(rgba(255,255,255,0) 0, rgba(255,255,255,.1) 11%, rgba(255,255,255,.2) 13%, rgba(255,255,255,0) 14%) 0 0,
                             linear-gradient(45deg, #343702 0%, #184500 20%, #187546 30%, #006782 40%, #0b1284 50%, #760ea1 60%, #83096e 70%, #840b2a 80%, #b13e12 90%, #e27412 100%);
                             background-size: 470px 470px, 970px 970px, 410px 410px, 610px 610px, 530px 530px, 730px 730px, 100% 100%;
                             background-color: #840b2a;`; break;
            case 4 : bkgDiv=`background: radial-gradient(${htmlFarbTableColorGradient1}, ${htmlFarbTableColorGradient2});`; break;   //265686 5590CA 2F2F2F 3c3c3c
            case 5 : bkgDiv=`background: radial-gradient(${farbeUngeradeZeilen}, ${farbeGeradeZeilen});`; break;   //265686 5590CA 2F2F2F 3c3c3c
            case 6 : bkgDiv=`background: radial-gradient(#bfbcbc, #ffffff);`; break;   //265686 5590CA 2F2F2F 3c3c3c
          scrollBar=` .thescroller${dpVIS}::-webkit-scrollbar { width: 5px;}
          .thescroller${dpVIS}::-webkit-scrollbar-track {background: transparent; width: 5px;}
          .thescroller${dpVIS}::-webkit-scrollbar-thumb {border-radius: 40px; border: transparent ; background: ${htmlFarbTableColorGradient1}; }
          .thescroller${dpVIS} {scrollbar-width: thin; scrollbar-color: ${htmlFarbTableColorGradient1} transparent;}}`
          myButtonUeberschrift=" .myButt"+dpVIS+" {border-radius: 4px; border:"+schalterUmrahmung+"px solid; background-color: "+htmlBackgroundButtonUeberschrift+"\; color: "+htmlFarbTableColorUber+"; font-family: "+htmlSchriftart+"; font-size :"+groesseUeberschrift+"px; text-align:left;}"
                    htmlZentriert=   "<style>"+                       // <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no\" />
                     /*weite*/          " .divWeiten"+dpVIS+" {  width: "+weite+"px }"+
                     /*thead*/          " .fixedHeader"+dpVIS+" { position: sticky; top: 0px ; overflow-y:auto; overflow-x: hidden; width: 100%;  height: "+UeberSchriftHoehe+"px; border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+";"+
                                                        " font-family:"+htmlSchriftart+"\;  color:"+htmlFarbTableColorUber+"; "+  //  border-spacing:"+abstandZelle+"px;
                                                        " font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+";  background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+ //
                     /*tbody */         " .scrollContent"+dpVIS+" { width: 100%;  overflow-y: scroll;   }"+ // height: "+hoeheTabelle2+"px;
                                        " .scrollContent"+dpVIS+" td {padding: "+abstandZelle+"px;}"+
                     /*div*/            " .tableContainer"+dpVIS+" {  display: flex; flex-direction: column;  height: "+hoeheTabelle+"px; width: "+weite+"px; overflow-y:auto; overflow-x: hidden ; "
        +bkgDiv+" }"+  // position: sticky; top: 0; background-color: black;
                     /*seitenl*/        " .seitenleiste"+dpVIS+" { background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); color: " //background-color: "+htmlBackgroundFarbeSeitenliste+";
        +htmlFarbSeiteSchrift+ ";font-size:"+schriftGroesseSeitenleiste+"px; vertical-align:top; text-align:center; width: "+breiteSeitenleiste+"px}"+  //margin-top: 30px;
                                        " .flexContainer"+dpJSON+" {display: flex; width: "+weite+"px}"+
                     /*table*/          " .tablezusatz"+dpVIS+" {  border:"+rahmenBreite+";  "+  //table-layout: fixed;
                                                       "width:100%; color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+";"+
                                                       "font-family:"+htmlSchriftart+"; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+
                                        " .mythclass0"+dpVIS+" {    }"+  //text-align:"+Feld1lAlign[0]+"
                                        " .mythclass1"+dpVIS+" {   }"+
                                        " .mythclass2"+dpVIS+" {   }"+
                                        " .mythclass3"+dpVIS+" {  }"+
                                        " .mythclass4"+dpVIS+" {  }"+
                                        " .mythclass5"+dpVIS+" {  }"+
                                        " .mythclass6"+dpVIS+" {   }"+
                                        " .divFlexBoxen"+dpVIS+" {overflow-y: scroll; display: flex; flex-direction: row; flex-wrap: wrap; width: 100%; height: "+(hoeheTabelle-(Number(UeberSchriftHoehe)))+"px;  align-items: center; justify-content: center; }"+
                                        " .divFlexBoxenEinzeln"+dpVIS+" { padding: 20px; color: "+htmlFarbFelderschrift+"; border: 2px solid; border-radius: 25px; width: auto; height: auto; border-color: "+htmlFarbTableColorGradient2+"; margin: 10px;}"+
                                        " .divInFlex"+dpVIS+" {  background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" 10%,"+htmlFarbTableColorGradient1+" 20%); }"+ //  "+htmlGragient[1]+"   "+htmlGragient[2]+"
                                        " .emptyFlex2_1"+dpVIS+" { color: transparent; background-image: none !important; background-color: "+htmlFarbTableColorGradient1+" !important;}"+
                                      //  " th {position: sticky; top: 0px ; height: "+UeberSchriftHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%); }"+  //position: sticky; top: 0px ;
                                        " .myclassueber_spalte_button     {color:"+htmlFarbTableColorUber+"}"+
                                        " .myclassueber_spalte_ohne_button{color:"+htmlFarbTableColorUber+"}"+
                                        " .myTHclass"+dpVIS+" {position: sticky; top: 0px ; height: "+UeberSchriftHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+htmlGragient[2]+"%);}"+
                                        " .myTRclass"+dpVIS+" {}"+
                                        " .myclasstr_gerade"+dpVIS+" { height:"+zeilenAbstand+"px; background-color:"+farbeGeradeZeilen+"}"+  //border-spacing:"+abstandZelle+"px;
                                        " .myclasstr_ungerade"+dpVIS+" {  height:"+zeilenAbstand+"px;  background-color:"+farbeUngeradeZeilen+"}"+ //border-spacing:"+abstandZelle+"px;
                                        " .myclasstd_normal"+dpVIS+" {}"+
                                        " .myclasstd_trennungslinie"+dpVIS+" {}"+
                                        " .myinputclass"+dpVIS+" {width: "+weite+"px; border: 1px solid; border-color: "+htmlFarbTableColorGradient2+"; margin-bottom: 15px;  color: "+htmlFarbTableColorUber+
        "; height: "+sucheHoehe+"px; background-image: linear-gradient("+htmlGragient[0]+"deg,"+htmlFarbTableColorGradient2+" "+htmlGragient[1]+"%,"+htmlFarbTableColorGradient1+" "+
        htmlGragient[2]+"%); font-family:"+htmlSchriftart+"\; font-size: 110%; color: "+htmlFarbTableColorUber+"}"+
                                     trHelperClass+scrollBar+ //myButtonUeberschrift+
                                   //     " .thescroller"+dpVIS+"::-webkit-scrollbar {width: 0px; }"+
                                        "</style>"+'<center>'
          //not in use
          //alt -  falls eine extra html datei gebraucht wird
          /*let htmlStart; //file
          const path = "/htmlexample.html";                        //FIlenamen definieren
          const home ='vis.0'                                      //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
          let   braucheEinFile=false;                              // bei true wird ein file geschrieben
          htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html;  http-equiv=\"refresh\" content=\"30\"; charset=utf-8\">"+
                             " </style></head><body> <div>";  */
          }// endCSS
          function makeMySearch_Seitenleiste() {
            einmalAbstand=`<br>
           let seitenLeistenTest="&#128472;";
          seitenLeistenTest= "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnRefresh\(\'"+"valButton"+"\')\">"+seitenLeistenTest + "</button>"
           for (let f=0;f<abstandSeitentextVonOben;f++){
               seitenLeistenTest=seitenLeistenTest+`<br>
           for (let i=0;i<nameSeitenLeiste.length;i++){
               seitenLeistenTest=seitenLeistenTest+nameSeitenLeiste[i]+`<br>
           htmlSeitenleiste="";
           if (ichWillSeitenLeiste) htmlSeitenleiste= "<div class=\"flexContainer"+dpJSON+"\"> <div class=\"seitenleiste"+dpVIS+"\">"+seitenLeistenTest+"</div>" ;// htmlTabUeber1=htmlTabUeber1+
          searchMe="";
          sucheEin ? searchMe="<div class=\"divWeiten"+dpVIS+"\"><input class=\"myinputclass"+dpVIS+"\" type=\"search\" id=\"search"+dpVIS+"\" placeholder=\"Filter by Item\""+">"+"</div>" :
                     searchMe=""
          searchMe=searchMe+htmlSeitenleiste
          htmlTabStyle= "<div class=\"tableContainer"+dpVIS+" thescroller"+dpVIS+"\" >"+
                             "<table class=\"tablezusatz"+dpVIS+"\" rules=\""+htmlRahmenLinien+"\">"+
                             "<thead class=\"fixedHeader"+dpVIS+"\">"
          htmlTabUeber4="<tr class=\"myTRclass"+dpVIS+"\">";
          function makeMyVisScripte() {
              let valSpalte=[] ;
             for(let kk=0;kk<val.length;kk++){
               valSpalte.push(val[kk])
             let spaltenAnzeigeScript=`$(document).ready(function() { `
             let spaltenAnzeigeScriptEnd=` });` ;
          for (let ff=0;ff<(valSpalte.length);ff++){
                                                 // log(valSpalte[ff]);
                                                  if (valSpalte[ff]=="false") { spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1)}).toDel${dpVIS},th:nth-child(${(ff+1)}).toDel${dpVIS}').hide();`)
        if (mehrfachTabelle==2) {spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1+valSpalte.length)}).toDel${dpVIS},th:nth-child(${(ff+1+valSpalte.length)}).toDel${dpVIS}').hide();`) }
        if (mehrfachTabelle==3) {spaltenAnzeigeScript=spaltenAnzeigeScript.concat(`$('td:nth-child(${(ff+1+(2*valSpalte.length))}).toDel${dpVIS},th:nth-child(${(ff+1+(2*valSpalte.length))}).toDel${dpVIS}').hide();`) }
          buttonScript =   '<script> function setOnOtherValue(myval) {	var Self = this;	Self.servConn.getStates(myval, (error, states) => {  console.log(states); self.servConn.setState(myval, !states[myval].val);}  )}; '
                               + 'function setOnNewFolder(myval) {	var Self = this;	vis.setValue("0_userdata.0.Rookie.holdData",myval)}; '
                               + 'function setOnMp3Play(myval)    {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.PLAYmp3",myval)}; '
                               + 'function setOnMp3Add(myval)     {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDmp3",myval)}; '
                               + 'function setOnFolderPlay(myval) {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.PLAY",myval)}; '
                               + 'function setOnFolderAdd(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADD",myval)}; '
                               + 'function setOnFolderAddLast(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDLast",myval)}; '
                               + 'function setOnMp3AddLast(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.STEUERUNG.ADDmp3Last",myval)}; '
                               + 'function setOnRefresh(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.refreshAnzeige",true)}; '
                               + 'function setOnShortcut(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.now",true)}; '
                               + 'function setOnShortcutUsage(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.useShortcut",myval)}; '
                               + 'function setOnShortcutDelete(myval)  {	var Self = this;	vis.setValue("0_userdata.0.Rookie.SHORTCUT.deleteShortcut",myval)}; '
                               + '$( "button.myButt'+dpVIS+'" ).click(function() {  $( this ).slideUp() });' //'[class*="test"]' [class~="value"]   "[class~='gerade']"
              /*search*/       + `var allRows = $("[class*='gerade${dpVIS}']");  $("input.myinputclass${dpVIS}").on("keydown keyup", function() {  allRows.hide();  $("tr:contains('" + $(this).val() + "')").show();});`
              /*search*/       + `var allRows2 = $("div.divFlexBoxenEinzeln${dpVIS}"); console.log(allRows2);  $("input.myinputclass${dpVIS}").on("keydown keyup", function() {  allRows2.hide();  $("div.divFlexBoxenEinzeln${dpVIS}:contains('" + $(this).val() + "')").show();});`
                               + `$( ".seitenleiste${dpVIS}" ).click(function() {var Self = this; var myvali='javascript.0.Tabellen@Liv.ShellyTabelleVIS.Spalte7'; vis.setValue(myvali,true)    });`
              /*dbclick*/      + `$( "[class*='gerade${dpVIS}']" ).dblclick(function() {var Self = this; var myvali='javascript.${instance}.Tabellen@Liv.${dpVIS}.Spalte7'; vis.setValue(myvali,true)    });`
              /*dbclick*/      + `$( "[class*='divFlexBoxen${dpVIS}']" ).dblclick(function() {var Self = this; var myvali='javascript.${instance}.Tabellen@Liv.${dpVIS}.Spalte7'; vis.setValue(myvali,true)    });`
                               +   spaltenAnzeigeScript  +  spaltenAnzeigeScriptEnd
                               +'</script>'
          • R Rookie50
            @liv-in-sky
            LG
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            #65
            @rookie50
            soweit ich @da_Woody verstanden habe, kannst du einen teil der vis in iqontrol einbinden
            d.h.
            kannst du eine neue view machen, in der nur die valuelist widgets links oben zu sehen sind und die refresh und buttons
            diesen kleine view dann in iqontrol einbinden - dann solltest du doch direkt bedienen können
            du kannst nur nicht in der tabelle arbeiten, da dies direkt ein html ist - die neie kleine view wenn eingebunden ist, ist die grundlage vis - drüber ist iqontrol - dann sollte das funktionieren
            • R Rookie50
              @liv-in-sky
              LG
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #66
              @rookie50
              habe gerade gemerkt, dass ich die anderen spalten nur ausblende mit jquery, was in iqontrol nicht funktioniert - daher sieht man in iqontrol alle spalten
              das muss ichj anders lösen
              du bekommst ein neues/anderes table script für iqontrol
                @rookie50
                Rookie50
                #67
                @liv-in-sky 💋
                liv-in-skyL 3 Antworten Letzte Antwort
                • R Rookie50
                  @liv-in-sky 💋
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  #68
                  @rookie50 wie bindet man die vis seite in iqontrol ein - habe schon länger nicht damit gearbeitet
                  oder willst du kurz bei mir auf den pc drauf gehen
                  • R Rookie50
                    @liv-in-sky 💋
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    #69
                    @rookie50
                    für iqontrol - kann man sicher noch schöner einstellen - aber es funzt :-)
                    SCRIPT FÜR IQONTROL - 2 spaltig
                    // @ts-ignore
                    let mitSearch=true;
                    let htmlFeld=        ["","NAME"];              // GLEICHE ANZAHL !! NAME/ÜBERSCHRIFT DER SPALTE
                    let val=             ["true","true"];                 // GLEICHE ANZAHL !! SPALTE ANZEIGEN/AUSBLENDEN UND HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WERDEN -  jeder val[x] muss unten in der schleife gesetzt werden !!
                    let Feld1lAlign=     ["center","left"];         // GLEICHE ANZAHL !! AUSRICHTUNG IN DER SPALTE
                    let htmlSpalte1Weite=["25px","200px"];                        // GLEICHE ANZAHL !! BREITE DER SPALTE, wenn "0px" auto
                    //SEITENLEISTE
                    //SUCHE
                    //GANZE TABELLE
                    //FELDER UND RAHMEN
                    let htmlcenterHelp;
                    let htmlTabUeber4;
                    let htmlTabUeber2;
                    let searchMe;
                    let htmlTabStyle;
                     makeMyCSS();
                     makeMyVisScripte();
                             // @ts-ignore
                             stopScript();}
                    let langeGesamt=0;
                    let htmlOut="";
                    let mix;
                    let counter;
                    let makeJsonWidget;
                    let myObject=[];
                    needDP();
                                             }, 500);
                    myObject=[]
                    htmlOut="";
                    counter=-1;
                    let valueuptime
                    let myReturnJson=[]
                    myReturnJson.push({
                          "nummer": "0",
                          "anzeige":"return",
                          "value" : "Return",
                          "file" : "⏱"
                           val[0]=val[1]= "missingState";
                                                              //   ID
                                 } else {
                           case 1: break;
                           case 3: break;
                           case 4: break;
                            if (mitAlphabet){
                       aktiv++
                        val[0]=""
                    //    val[2]=myObject[zz].value1; // log(typeof val[2])
                     //   val[4]= ""// "<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnShortcut\(\'"+"valButton"+"\')\">"+"🤍" + "</button>" //myObject[zz].value3;
        //  val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderPlay\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        //  val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAdd\(\'"+valButton+"\')\">"+"⏩" + "</button>"
        //  val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFolderAddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
        // val[2]=""; val[2]="";val[4]=decodeURI(getState("0_userdata.0.Rookie.braucheNeueDatenNeu").val.replace(/^.+\/(.+)$/,"$1"))
        // val[3]=""
        // val[2]="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Play\(\'"+valButton+"\')\">"+"▶️" + "</button>"
        // val[3]="<button style\=\"border:none\; background-color\:transparent\; color\:lightblue\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3Add\(\'"+valButton+"\')\">"+"⏩" + "</button>"
                                                              //   val[3]=val[3]+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1.5em\; text\-align:left\" value=\"toggle\" onclick=\"setOnMp3AddLast\(\'"+valButton+"\')\">"+"⏭️" + "</button>"
                    /* &#127926;
                       htmlTabUeber2=""
                       } else{
                     htmlTabUeber="";
                    } // function ende
                    //MAIN:
                     writeHTML();
                          writeHTML();
                                               } else {
                                                 else {
                            } //switch ende
                           case 1:    break;
                                      break;
                           case 1:    break;
                                      break;
                                 var htmlOutVIS="";
                                } else {
                     //log(htmlOut);
        +" </div>"
                     //log(htmlOut)
                       var htmlOutVIS="";
                                } else {
                         //  log(obj.id)
                           writeHTML();
                    }, 900);
                       });}, 5050);
                    //SORTIEREN
                                   return 1;
                                   return -1;
                                return 0;
                       trHelperClass=" ";
                                      ; break
                    //not in use
                    }// endCSS
                      einmalAbstand=`<br>
                    searchMe="";
                               searchMe=""
                        let valSpalte=[] ;
                                         +'</script>'
                    • R Rookie50
                      @liv-in-sky 💋
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      #70
                      @rookie50
                      so würde es mit shortcuts aussehen - nur in table view anwendbar
                        Rookie50
                        #71
                        @liv-in-sky
                        hi, seit wir xml2json benutzen, funktioniert die Status Anzeige nicht mehr :-(
                        Ich denke, dass hängt zusammen und ich muss das nun mit JS zerlegen und in Objekte schreiben.
                        LG
                        • R Rookie50
                          @liv-in-sky
                          LG
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          #72
                          @rookie50
                          glaub ich nicht - das blockly ruft das module nicht auf
                          ist den der dp noch aktuell - ich nutze den nicht
                            Rookie50
                            #73
                            @liv-in-sky said in Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol:
                            In meiner "ursprünglichen Steuerung" habe in den DP für die Anzeige von Album, Titel und Artist genutzt. Den Status habe ich alle 5 Sekunden abfragt, für fortschrittsbalken usw.
                            • R Rookie50
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              liv-in-sky
                              #74
                              @rookie50 @rookie50 verstehe - aber ich kann mir nicht vorstellen, dass dieses installierte modul auswirkungen auf das javascript hat, wenn es nicht expleziet aufgerufen wird
                              ich war ja eh verwundert, das du ein xml format so lesen kannst
                              habe gerade keine idee
                              exportier' mal diesen block, dann schau ich mal bei mir
                              R 1 Antwort Letzte Antwort
                              • liv-in-skyL liv-in-sky
                                Rookie50
                                #75
                                @liv-in-sky
                                  <variables>
                                    <variable id="+QRm(=Ejp5.2FwDfrulq">originalText</variable>
                                    <variable id="]T:/?:QRL;m/1wq*S#7S">suchText</variable>
                                    <variable id="SoreJ$m[hJ}Vs4{au@E7">tauschText</variable>
                                    <variable type="cron" id="schedule1">schedule1</variable>
                                    <variable id="*mH[}F.6Kta#KW;c3jPW">Text</variable>
                                    <variable id="SqHEqX_`I0]e3Glpt9iD">AnzZeichenSuchtext</variable>
                                    <variable id="p[!d9g5$d1fizuo7WbDZ">aktualisierung_an</variable>
                                    <variable id="qbn;e*.QW/TlYV3N%sr=">wertelist_browser</variable>
                                    <variable id="moB_xt[#isik:YT0=J3/">Stelle</variable>
                                    <variable id="V!?b;m:_l0eU[qp:2SFO">result</variable>
                                    <variable id="Y#iAI*FR!oAWI_VKn4tj">Teil_1</variable>
                                    <variable id="?;zNzBa@_q5|lTMhID_F">Teil_2</variable>
                                  </variables>
                                  <block type="on_ext" id="P9gIT)?_8qk=2a=Gyw7i" x="1012" y="-2688">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="bUly[J[D=V%*PoJoQnK+">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Library_Folder</field>
                                      </shadow>
                                    </value>
                                    <statement name="STATEMENT">
                                      <block type="control" id="Z;;FV%9Jj|I*_609{miP">
                                        <field name="OID">0_userdata.0.Media.Bluesound.Küche.Library_Folderstring</field>
                                        <value name="VALUE">
                                          <block type="lists_getIndex" id=":cJHi4?i)mXdCqll-R:w">
                                            <mutation statement="false" at="true"></mutation>
                                            <field name="MODE">GET</field>
                                            <field name="WHERE">FROM_START</field>
                                              <block type="variables_get" id="`GQ])@$OJTDc$}!-8,Em">
                                                <field name="VAR" id="qbn;e*.QW/TlYV3N%sr=">wertelist_browser</field>
                                              </block>
                                            </value>
                                            <value name="AT">
                                              <block type="get_value" id="a]Lgdui6,TOK{?|zwGoz">
                                                <field name="OID">0_userdata.0.Media.Bluesound.Küche.Library_Folder</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="procedures_defreturn" id="*?%n[KG5e1!^tNun#Hj5" x="-812" y="-1913">
                                    <mutation>
                                      <arg name="originalText" varid="+QRm(=Ejp5.2FwDfrulq"></arg>
                                      <arg name="suchText" varid="]T:/?:QRL;m/1wq*S#7S"></arg>
                                      <arg name="tauschText" varid="SoreJ$m[hJ}Vs4{au@E7"></arg>
                                    </mutation>
                                    <field name="NAME">changeText</field>
                                    <statement name="STACK">
                                      <block type="variables_set" id="LyZ2%lYW+kfm,4)yV8UN">
                                        <field name="VAR" id="*mH[}F.6Kta#KW;c3jPW">Text</field>
                                          <block type="variables_get" id="da5*p]}sO:{{|ZE!nhDe">
                                            <field name="VAR" id="+QRm(=Ejp5.2FwDfrulq">originalText</field>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="yx;qp1@1fC(oiG4c5gZt">
                                            <field name="VAR" id="SqHEqX_`I0]e3Glpt9iD">AnzZeichenSuchtext</field>
                                              <block type="text_length" id="Jwz33ARDLc!=8:eDagDD">
                                                  <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="RZWm!~Yo4w5)66Gu|Gs_">
                                                    <field name="TEXT">abc</field>
                                                  </shadow>
                                                  <block type="variables_get" id="G2I+np)5qee]q{4)BlN2">
                                                    <field name="VAR" id="]T:/?:QRL;m/1wq*S#7S">suchText</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="variables_set" id="eAGK[85W)DRaIaN!oMiH">
                                                <field name="VAR" id="moB_xt[#isik:YT0=J3/">Stelle</field>
                                                  <block type="text_indexOf" id="/@rj}{;VUCJ8O|28^(Hf">
                                                    <field name="END">FIRST</field>
                                                      <block type="variables_get" id="}de%ffO*rIt%j6)99pf3">
                                                      </block>
                                                    </value>
                                                    <value name="FIND">
                                                      <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="7MprEQxoWq}#3~Xz:32k">
                                                        <field name="TEXT">%0D%0A</field>
                                                      </shadow>
                                                      <block type="variables_get" id="7)r.X1a~Tee1!dAwZy`!">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="controls_whileUntil" id="4lR}{f])DWKyjt}.(6cc">
                                                    <field name="MODE">WHILE</field>
                                                    <value name="BOOL">
                                                      <block type="logic_compare" id="e`eUWK6kyOU=[/x]M({`">
                                                        <field name="OP">GT</field>
                                                        <value name="A">
                                                          <block type="variables_get" id="}7HLWRwI(SDg1^@=czoV">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <block type="math_number" id="#y,za{r#@s7Ri.U!9v)A">
                                                            <field name="NUM">0</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <statement name="DO">
                                                      <block type="controls_if" id="PM@Su)b1YOhTZo2qPxB]">
                                                        <value name="IF0">
                                                          <block type="logic_compare" id="l,u?h{)Z-u/OozI,.79G">
                                                            <field name="OP">EQ</field>
                                                            <value name="A">
                                                              <block type="variables_get" id="B/K~z.ANK2);I3(uk4Bh">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <block type="math_number" id="|3~K:6jrHq7oxz=fL:Yz">
        <field name="NUM">1</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <statement name="DO0">
                                                          <block type="comment" id="uN{|N4-0EabDJqYE0]@#">
                                                            <field name="COMMENT">steht am Textanfang</field>
                                                            <next>
                                                              <block type="variables_set" id="9?Gy,w.t#1pdl^AOxc#Y">
        <field name="VAR" id="Y#iAI*FR!oAWI_VKn4tj">Teil_1</field>
        <block type="variables_get" id="h(#=bJ`DU%y/Jd9%HR9I">
        <field name="VAR" id="SoreJ$m[hJ}Vs4{au@E7">tauschText</field>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </statement>
                                                        <statement name="ELSE">
                                                          <block type="variables_set" id="{R*X,7K)DA^dq/.~KK7{">
                                                              <block type="text_getSubstring" id="Img0opt.EB#)RM-bp~hw">
        <mutation at1="false" at2="true"></mutation>
        <field name="WHERE1">FIRST</field>
        <field name="WHERE2">FROM_START</field>
        <value name="STRING">
        <block type="variables_get" id="A9h*F{tgJR0y[Q0uv7,=">
        </block>
        </value>
        <value name="AT2">
        <block type="math_arithmetic" id="([5R[:8Ywn-thKN@r:~}">
        <value name="A">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="u@:!j5WimCjV%fG9hPGs">
        </shadow>
        <block type="variables_get" id="U0qw,~,2KoaAc37UO{l#">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="DT#zRSRu1.y^|5Z#G37W">
        </shadow>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </statement>
                                                        <next>
                                                          <block type="variables_set" id="Else^,?QE9TTS.Y%K]W=">
                                                            <field name="VAR" id="?;zNzBa@_q5|lTMhID_F">Teil_2</field>
                                                              <block type="text_getSubstring" id="e8A7NqY7O!@K(aFlMpV#" inline="false">
        <mutation at1="true" at2="false"></mutation>
        <field name="WHERE1">FROM_START</field>
        <field name="WHERE2">LAST</field>
        <block type="variables_get" id="|jU0g8+eIgwn_|IB56)@">
        </block>
        </value>
        <value name="AT1">
        <block type="math_arithmetic" id="F#*%;R9ugmwaaas?WBwG">
        <field name="OP">ADD</field>
        <value name="A">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="8/I%=/~YReHV]Iwo{}(J">
        </shadow>
        <block type="variables_get" id="R0|a}kx2M~SYjPKS5Cc{">
        </block>
        </value>
        <value name="B">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";Q(aJ::90?0?H;-45cgS">
        </shadow>
        <block type="variables_get" id="dY33=1IVxkrSH1k1#X6A">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="variables_set" id="OcJS!-Ku1vQY4)I+r,gc">
        <block type="text_join" id="%%D@nUqB1tt^`?qrUahx">
        <value name="ADD0">
        <block type="variables_get" id="q]l%0Dpb89BZy1-m[TjM">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="f~POFU0}K4-w]xVc1?,`">
        </block>
        </value>
        <value name="ADD2">
        <block type="variables_get" id="U77~u,Qfmb2g[O19eHoh">
        </block>
        </value>
        </block>
        </value>
        <next>
        <block type="variables_set" id="lao?KUxF77Si~Xc2j%^{">
        <block type="text_indexOf" id="[),PN,ZrAW,C/~:K[x[:">
        <block type="variables_get" id="6{t:BeVh6=bsQF(zUhYG">
        </block>
        </value>
        <value name="FIND">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="{Vd/Su8uk@lo|:3KMi1L">
        </shadow>
        <block type="variables_get" id="r|~fKkGR#@1@G6_GX`-g">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <value name="RETURN">
                                      <block type="variables_get" id=".*DA-:q/GzURSEPH2ZiQ">
                                      </block>
                                    </value>
                                  </block>
                                  <block type="on_ext" id="7)?1A[QaPRjBlqqW+o#z" x="63" y="-412">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="4Cxg;]3:k%DD08c5=-Js">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Stop</field>
                                      </shadow>
                                    </value>
                                      <block type="request" id="kCp_:n8M$^4`Yd8P/QDy">
                                        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                                        <field name="WITH_STATEMENT">FALSE</field>
                                        <field name="LOG">log</field>
                                        <value name="URL">
                                          <shadow type="text">
                                          </shadow>
                                          <block type="text_join" id="9_6|XmgF-o!/IDX(c5bT">
                                            <value name="ADD0">
                                              <block type="text" id="XwRsM{jew`aTJtH3j?}s">
                                                <field name="TEXT">http://</field>
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="z$st~OHffc`QD:JOZ+!#">
                                                <field name="OID">0_userdata.0.Media.Bluesound.Küche.IP</field>
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="n)HC=rU!XSlaCyex#z%X">
                                                <field name="TEXT">:11000/Pause</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="ne37.PKv5;,!QHSm_fgN">
                                            <field name="VAR" id="p[!d9g5$d1fizuo7WbDZ">aktualisierung_an</field>
                                              <block type="logic_boolean" id="^YzQSIDrca_7O?HTR[5D">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="control" id="LGr{712ub`##FK*LT#r.">
                                                <field name="OID">0_userdata.0.Media.Bluesound.Küche.Album</field>
                                                  <block type="text" id="7=;d7DVIBgD|pizQtEk.">
                                                    <field name="TEXT"></field>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="{$ky,88PBycJNb_34u?s">
                                                    <field name="OID">0_userdata.0.Media.Bluesound.Küche.Artist</field>
                                                      <block type="text" id="4^f/?Q1fD1jKlt#O0|oy">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="qahg%}ZsU))Q7-cK+%u;">
                                                        <field name="OID">0_userdata.0.Media.Bluesound.Küche.Artwork</field>
                                                          <block type="text" id="YA@8X!#0E})?=mkC1KOc">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="control" id="F9%|.z),+M]!(=ay^L:Q">
                                                            <field name="OID">0_userdata.0.Media.Bluesound.Küche.Title</field>
                                                              <block type="text" id="i]ihlf?FnRJ.N~%W8Z-,">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="on_ext" id="Sev=?2(3{D4yq+plvjMb" x="63" y="88">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="HXG}[HRqL=^(d;AQ-zEp">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Volume</field>
                                      </shadow>
                                    </value>
                                      <block type="request" id="rbRv}2c3K%4[Y~3W+%pL">
                                        <value name="URL">
                                          <shadow type="text" id="VNQ.0-:w3QbzIc?p}Bbc">
                                          </shadow>
                                          <block type="text_join" id="HI?xKM3!O/VEYOS$sA^:">
                                            <mutation items="4"></mutation>
                                            <value name="ADD0">
                                              <block type="text" id="Dt^zH|?[^_G!jhLYd7Qw">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="h)W?TX7B.zju6}qYF~9t">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="UrXJd+5M=e+{(1oLCI3$">
                                                <field name="TEXT">:11000/Volume?level=</field>
                                              </block>
                                            </value>
                                            <value name="ADD3">
                                              <block type="get_value" id="-#T/owsH/L#Xb8+@1hlr">
                                                <field name="OID">0_userdata.0.Media.Bluesound.Küche.Volume</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="schedule_create" id="M#X-bGuZ*/4[[Y_2DLIY" x="1063" y="38">
                                    <field name="NAME">schedule1</field>
                                    <value name="SCHEDULE">
                                      <shadow type="field_cron" id="c,H@u,.r`kI)U^y26OW}">
                                        <field name="CRON">*/5 * * * * *</field>
                                      </shadow>
                                    </value>
                                      <block type="controls_if" id="|}Bar0g=4LVj}p~?ibC_">
                                        <value name="IF0">
                                          <block type="logic_compare" id="P1`Z^Sa+AdA:_05UjgTI">
                                            <value name="A">
                                              <block type="variables_get" id="fq,FvKXbM[?m::f~{pf`">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <block type="logic_boolean" id="pvO$luJo~o*uTsXz57QW">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="request" id=";[0C..zDNuE0%$7?q3}J">
                                            <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                                            <field name="WITH_STATEMENT">TRUE</field>
                                            <field name="LOG"></field>
                                            <value name="URL">
                                              </shadow>
                                              <block type="text_join" id="M^0:r7sEc~I%-g]mhk]q">
                                                <value name="ADD0">
                                                  <block type="text" id="q`pSxk|Uhmb22Hh|^V(}">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                  <block type="get_value" id="-/P7w.rYI!:K2E*|;a/Y">
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                  <block type="text" id="8@:guEjO^#pK|*l)[HZ2">
                                                    <field name="TEXT">:11000/Status</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <block type="debug" id="r/4N7uV7PWUR;X4?+@g+">
                                                <value name="TEXT">
                                                  <shadow type="text" id="XY2`wPREgSG^a!QpHSyu">
                                                  </shadow>
                                                  <block type="variables_get" id="d:Cig{Qu`#zSo)(h=c;o">
                                                    <field name="VAR" id="V!?b;m:_l0eU[qp:2SFO">result</field>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="{/RW2_=Bo)HGCaDG9LK7">
                                                      <block type="get_attr" id="bxMpbbDzyA@)Od7,Ke`N">
                                                        <value name="PATH">
                                                          <shadow type="text" id="(a!y4e1V2!SZjxXP4(fL">
                                                            <field name="TEXT">Artist</field>
                                                          </shadow>
                                                        </value>
                                                        <value name="OBJECT">
                                                          <block type="convert_object2json" id="xf:g*Hrm9+OOjr,Xa{f*">
                                                            <field name="PRETTIFY">TRUE</field>
                                                              <block type="variables_get" id=":m@N$w~ih,E,`B~^rLC!">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="debug" id="oU.~e_SdapGq:]WGpET(">
                                                        <value name="TEXT">
                                                          </shadow>
                                                          <block type="get_value" id="%dW84hzqcSzD=*`8@5!e">
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="control" id="@bZr9b};$oYTUuo4%R}o">
                                                              <block type="get_attr" id="MaudAf+f={=+/[@.YiAS">
        <value name="PATH">
        <shadow type="text" id="w*/DnNB{!-GJ?7JF=7@1">
        <field name="TEXT">Title1</field>
        </shadow>
        </value>
        <block type="convert_object2json" id="vL38tFeC9Fzph.st)r)a">
        <block type="variables_get" id="uc6Qp:_~K8;|Fl;!e[17">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
                                                              <block type="control" id="FC5rZB)-,,SatPL;R%ch">
        <block type="get_attr" id="v:Pk6%L^{_`O~]iU*]S!">
        <value name="PATH">
        <shadow type="text" id="s|#2b2/u.A)dmz*70QZ*">
        <field name="TEXT">Album</field>
        </shadow>
        </value>
        <block type="convert_object2json" id="h7Mkq]AOylQhBn%a]sqv">
        <block type="variables_get" id="AjAH=xR@Sy+}Yf(MpiwJ">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="on_ext" id="e]gnXbSiVl)E$noe?^V$" x="63" y="438">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="W;X?Hsk#gh2u!0yivk?:">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Play</field>
                                      </shadow>
                                    </value>
                                      <block type="request" id="9UfbJ,`_p{H7tjSb%q;M">
                                        <value name="URL">
                                          </shadow>
                                          <block type="text_join" id="^O)H1tCk)ti#_u@M$j(~">
                                            <value name="ADD0">
                                              <block type="text" id="=0`FHbc*i1d1ymM3ii-i">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="*]8u~X?t:IE}6s1@08uz">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="a]i.p/k]p]pT8-E~@Tg^">
                                                <field name="TEXT">:11000/Play</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          <block type="debug" id="Kar+l3ay/3e*Z@s^oTw7">
                                            <value name="TEXT">
                                              <shadow type="text" id="*O75M[)TT}j+99P-^:0)">
                                                <field name="TEXT">Play</field>
                                              </shadow>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="request" id="{UWL!L(~vcmH5.W[57K}">
                                            <value name="URL">
                                              </shadow>
                                              <block type="text_join" id="a6cCA2F/ae.c22c6ll$v">
                                                <value name="ADD0">
                                                  <block type="text" id=",6lF8ga`N1WlxeS}SGB;">
                                                  </block>
                                                </value>
                                                <value name="ADD1">
                                                  <block type="get_value" id="eR+XA_m4gqepT,.|paZo">
                                                  </block>
                                                </value>
                                                <value name="ADD2">
                                                  <block type="text" id="d2p?+On8z~`f*foMjO,9">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                              <block type="variables_set" id="6!|3HClkm|e_U}g=bU^x">
                                                  <block type="logic_boolean" id="Fi2`VF(|]`_5gi8X!JjS">
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="on_ext" id="Y?Sm41$(D)9#lQ~lJxt$" x="1063" y="788">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="qiOnaC5?sd:D8in8LYMK">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Preset-to-Device</field>
                                      </shadow>
                                    </value>
                                      <block type="control" id="cS;^-5MCZ{MKw[a2n+L)">
                                          <block type="text" id="ve9_p/8=#,{S:X2aBE32">
                                          </block>
                                        </value>
                                        <next>
                                          <block type="control" id="JIp)0jG4h;z0Q/PS2?j9">
                                              <block type="text" id="~*8T!p+x}r~JZvjER)1}">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="control" id="_0I9awCziv3|idO*f=(b">
                                                  <block type="text" id="$uHD%}no[cYx}x=1UhzM">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id=".9nX+#/zx%?D~POpOJqc">
                                                      <block type="text" id="a3|PsRhd*K:n]h6G2`]_">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="request" id="*O+az%+o~^=N^ygHeGdS">
                                                        <value name="URL">
                                                          </shadow>
                                                          <block type="text_join" id="5@#cS:ojO`L5j+whHUZ*">
                                                            <value name="ADD0">
                                                              <block type="text" id="6}?si2ykB!h_3!VCIk+h">
                                                              </block>
                                                            </value>
                                                            <value name="ADD1">
                                                              <block type="get_value" id="#$e#XD,1j4e/!EU%IGEb">
                                                              </block>
                                                            </value>
                                                            <value name="ADD2">
                                                              <block type="text" id="%@wD?j}SO/eaG7VgXg6f">
        <field name="TEXT">:11000/Preset?id=</field>
                                                              </block>
                                                            </value>
                                                            <value name="ADD3">
                                                              <block type="get_value" id="]]hMV{`If#iu`uv8.|c+">
        <field name="OID">0_userdata.0.Media.Bluesound.Küche.Preset-to-Device</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="variables_set" id="Tp[P/O:|Nmlt{-L.!U2Z">
                                                              <block type="logic_boolean" id="HtN2V!HPA$KK(~^Sr5H3">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="on_ext" id="Wh^g89L2U~Q2P!xB2v(W" x="63" y="1063">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="bvV8Mh7ncyI1zYRI%q(Y">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Next</field>
                                      </shadow>
                                    </value>
                                      <block type="request" id="duTZyrhvq`n4~?crd%D=">
                                        <value name="URL">
                                          </shadow>
                                          <block type="text_join" id="ne;5K~2`^_,$c.Mb)jOL">
                                            <value name="ADD0">
                                              <block type="text" id="s-i-RYY[OhkJR/-{`J3%">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="W)=Wj(2O!B{,RMiQkP%!">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id=",?q;=).4=knA.uaTSU26">
                                                <field name="TEXT">:11000/Skip</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="]5*a-lWq6%KK{%Y$z1q9">
                                              <block type="logic_boolean" id="/gLkK^t(eQHTYX%(UG[l">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                  <block type="on_ext" id="`odlrViD:jSax`0iGUX9" x="63" y="1413">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="hn^w;}W(5?,1KEHYOWiE">
                                        <field name="oid">0_userdata.0.Media.Bluesound.Küche.Back</field>
                                      </shadow>
                                    </value>
                                      <block type="request" id=")%1(u2ly{{M%Eh:@^{(*">
                                        <value name="URL">
                                          </shadow>
                                          <block type="text_join" id="-~66J;|qC=wIfjc2k{/n">
                                            <value name="ADD0">
                                              <block type="text" id="aM]4qQ/_SExnce;e-6~Y">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="get_value" id="O,:%%n|zCNfY+VP}oy+2">
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              <block type="text" id="E}jdV)2|Q[@u*AwZmDEb">
                                                <field name="TEXT">:11000/Back</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="variables_set" id="wJdQ{R]3qGtM:l:kcQc1">
                                              <block type="logic_boolean" id="LdJOUJkyDK:F[axK{#vV">
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                • R Rookie50
                                  @liv-in-sky
                                    <variables>
                                    </variables>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                                </block>
                                              </value>
                                              <value name="AT">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                      <mutation>
                                      </mutation>
                                            </block>
                                          </value>
                                          <next>
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                        </block>
                                                      </value>
                                                      <value name="FIND">
                                                        </shadow>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                      <value name="BOOL">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                          <value name="IF0">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                              <next>
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </statement>
        </block>
        </value>
        <value name="AT2">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <next>
        </block>
        </value>
        <value name="AT1">
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        </block>
        </value>
        <next>
        </block>
        </value>
        <value name="FIND">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                        </block>
                                      </value>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="URL">
                                            </shadow>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </block>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="URL">
                                            </shadow>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                </block>
                                              </value>
                                              <value name="ADD3">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                              <value name="URL">
                                                </shadow>
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                  <value name="TEXT">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <next>
                                                          <value name="PATH">
                                                            </shadow>
                                                          </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="TEXT">
                                                            </shadow>
                                                            </block>
                                                          </value>
                                                          <next>
        <value name="PATH">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <next>
        <value name="PATH">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </next>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="URL">
                                            </shadow>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                              <value name="TEXT">
                                                </shadow>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="URL">
                                                </shadow>
                                                  <value name="ADD0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                      <next>
                                                          <value name="URL">
                                                            </shadow>
                                                              <value name="ADD0">
        </block>
                                                              </value>
                                                              <value name="ADD1">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        </block>
                                                              </value>
                                                              <value name="ADD3">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="URL">
                                            </shadow>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <value name="URL">
                                            </shadow>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                              <value name="ADD2">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </xml>
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  liv-in-sky
                                  #76
                                  @rookie50
                                  war wohl johnny cash
                                  habe es so gemacht
                                   <variables>
                                     <variable id="/;1~e`5S^.p~]8B6oCfz">x</variable>
                                   </variables>
                                   <block type="procedures_defcustomreturn" id="HC,qb9[L^()3b.Z]}1)2" x="1137" y="137">
                                     <mutation statements="false">
                                       <arg name="x" varid="/;1~e`5S^.p~]8B6oCfz"></arg>
                                     </mutation>
                                     <field name="NAME">bekomme json</field>
                                     <field name="SCRIPT">dmFyIHBhcnNlciA9IHJlcXVpcmUoJ3htbDJqc29uJyk7DQovL2xldCBteU9iamVjdD0ocGFyc2VyLnRvSnNvbih4bWwpKQ0KbG9nKEpTT04uc3RyaW5naWZ5KHBhcnNlci50b0pzb24oeCkpKTsNCnJldHVybiBwYXJzZXIudG9Kc29uKHgpOw==</field>
                                   </block>
                                   <block type="request" id=";[0C..zDNuE0%$7?q3}J" x="1138" y="187">
                                     <value name="URL">
                                       </shadow>
                                         <value name="ADD0">
                                           </block>
                                         </value>
                                         <value name="ADD1">
                                             <field name="OID">0_userdata.0.Rookie.dieIP</field>
                                           </block>
                                         </value>
                                         <value name="ADD2">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                         <value name="TEXT">
                                           </shadow>
                                           <block type="variables_get" id=":RL^.hCYzk5SpS$2/WJU">
                                           </block>
                                         </value>
                                         <next>
                                           <block type="debug" id="H(d^udzC$9atILaagZ,(">
                                             <value name="TEXT">
                                               <shadow type="text" id="LrpD,@7BlBuNBl8k)bC`">
                                               </shadow>
                                               <block type="get_attr" id="`tttnkxJx@Y4N5HYk7U4">
                                                 <value name="PATH">
                                                   <shadow type="text" id="lzg@:[A*Pr|`)6M`C7iX">
                                                     <field name="TEXT">status.artist</field>
                                                   </shadow>
                                                 </value>
                                                   <block type="procedures_callcustomreturn" id="uGTLbegc(}9kqf1Qe3|{">
                                                     <mutation name="bekomme json">
                                                       <arg name="x"></arg>
                                                     </mutation>
                                                     <value name="ARG0">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="control" id="{/RW2_=Bo)HGCaDG9LK7" disabled="true">
                                                     <value name="PATH">
                                                       </shadow>
                                                     </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                 <next>
                                                   <block type="debug" id="oU.~e_SdapGq:]WGpET(" disabled="true">
                                                     <value name="TEXT">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="control" id="@bZr9b};$oYTUuo4%R}o" disabled="true">
                                                             <value name="PATH">
                                                               </shadow>
                                                             </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="control" id="FC5rZB)-,,SatPL;R%ch" disabled="true">
        <value name="PATH">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                     </statement>
                                   </block>
                                  </xml>
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    da_Woody
                                    #77
                                    @liv-in-sky sagte in Dyn. Liste darstellen und als Auswahlliste in VIS, iQontrol:
                                    einfach den link als Background URL
                                    gruß vom Woody
                                    • da_WoodyD da_Woody
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      liv-in-sky
                                      #78
                                      @da_woody
                                      danke hab es schon https://forum.iobroker.net/post/624607
                                      da_WoodyD R 2 Antworten Letzte Antwort
                                        @da_woody
                                        da_WoodyD Online
                                        da_WoodyD Online
                                        da_Woody
                                        #79
                                        @liv-in-sky 👍 war ein paar std absent... nicht mitbekommen...
                                        morgen düse ich ja zum @Negalein , seinen 3d-drucker zusammen tackern...
                                        werd mich dann mal wieder mit den listen und einbinden über vis beschäftigen. auch mit dem mugge ding. hab ja auch eine veritable sammlung auf einem meiner NASen... ;)
                                        gruß vom Woody
                                          @da_woody
                                          Rookie50
                                          schrieb am zuletzt editiert von Rookie50
                                          #80
                                          @liv-in-sky ich habe gestern abend noch ein bisschen gestöbert und mir ist eingefallen, dass dieses System ja nicht nur von Bluesound eingesetzt wird :-D Siehe da, bei NAD gibt es sogar eine API Dokumentation:'
                                          https://nadelectronics.com/wp-content/uploads/2020/12/Custom-Integration-API-v1.0_Dec_2020.pdf
