Fritzbox DECT Adapter
@foxthefox
es gibt eine 2.5.8 um den Fehler von @wollerosekaufe zu ergründen -
@foxthefox sagte in Fritzbox DECT Adapter:
@jleg
und wie genau geht das?
in ioBroker.docs hab ichs grad nicht gefundenhttps://iobroker.readthedocs.io/de/latest/development/iopackage.html#confval-common.messages
(imo sehr gute Doku!)
@jleg
nur mal so zur Info, bin die nächste Zeit offline
@foxthefox
moin, war auch paar tage unterwegs :>
gerade nochmal die statistik und debug angemacht, bleibt leider dabeifritzdect.0 2023-11-17 22:47:32.676 warn [Polling] <== TypeError: Cannot read properties of null (reading 'val') fritzdect.0 2023-11-17 22:47:32.662 debug With 000000000000got the following to parse{"devicestats":{"temperature":{"stats":{"count":"96","grid":"900","datatime":"1700257650","_@attribute":"30,30,30,30,30,30,30,35,35,35,55,30,30,30,35,35,35,35,40,40,40,40,40,40,45,45,50,50,55,55,55,60,60,65,65,65,65,60,60,55,55,55,55,55,55,55,65,65,55,55,50,40,35,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,30,35,30,30,35,35,35,35,35,35,35,35,35,35,35,35"}},"voltage":{"stats":{"count":"360","grid":"10","datatime":"1700257650","_@attribute":"238936,238855,238920,238918,238896,238242,238695,238519,238457,238425,238435,238193,238069,238252,238252,238252,238252,238252,238252,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237860,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237894,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237240,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,237384,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238220,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238300,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,238465,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,237793,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238290,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,238184,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,237962,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238686,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238754,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238647,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238995,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,238780,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237721,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,237047,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236187,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236188,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236272,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,236410,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237006,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237879,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237656,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237978,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237565,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237288,237473,237473,237473,237473,237473"}},"power":{"stats":{"count":"360","grid":"10","datatime":"1700257650","_@attribute":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}},"energy":{"stats":[{"count":"12","grid":"2678400","datatime":"1700248463","_@attribute":"0,0,0,0,0,0,0,0,1,0,0,0"},{"count":"31","grid":"86400","datatime":"1700248463","_@attribute":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}]}}} -
@foxthefox
Danke, mache mich weiter auf die Suche was da der Störenfried ist.
Bei mir läuft es leider korrekt durch, aber ich werde den Unterschied schon noch finden. -
Unter Umständen habe ich die Problematik gefunden.
Es existiert eine Version 2.5.9 in github, bitte testen.
@foxthefox said in Fritzbox DECT Adapter:
das schaut sehr gut aus <3
vmtl. nur ein kurzer hänger der influxdb, aber sicherheitshalber mal als notiz:
influxdb.0 2023-11-19 14:21:34.240 info Connected! influxdb.0 2023-11-19 14:21:33.945 info Applying retention policy for iobroker to 31536000 seconds. Shard Group Duration (calculated): 604800 seconds influxdb.0 2023-11-19 14:21:33.733 info Influx DB Version used: 2.x influxdb.0 2023-11-19 14:21:33.732 info Connecting https://odroidc4:8086/ ... influxdb.0 2023-11-19 14:21:23.727 error Error during ping: Error: socket hang up. Attempting reconnect. influxdb.0 2023-11-19 14:21:23.717 info Add point that had error for fritzdect.0.DECT_0000000000.operationmode to buffer again, error-count=1 influxdb.0 2023-11-19 14:21:23.717 warn Error on writePoint("{"value":"Comfort","time":"2023-11-19T13:21:12.172Z","from":"system.adapter.fritzdect.0","q":0,"ack":true}): Error: socket hang up / "socket hang up"" influxdb.0 2023-11-19 14:21:23.714 warn Point could not be written to database: iobroker€
btw der andere fehler mit den docker logs> iobroker | 2023-11-05T14:07:21.461112467Z strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes) > iobroker | 2023-11-05T14:07:21.461303722Z strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)hat nichts mit deinem adapter zu tun. das kommt bei mehreren wenn man in die einstellungen geht.
hab mal einen thread dazu aufgemacht https://forum.iobroker.net/topic/70355/zertifikatsproblem-definitions-certificatesprops -
danke für den coolen Adapter, der bei mir schon lange sehr zuverlässig funktioniert.
Ich bin in den letzten Tagen über diese Warnung im Log gestolpert, die alle paar Minuten auftaucht:State value to set for "fritzdect.0.DECT_xxx.celsius" has value "-0.5" less than min "0"Die Meldung sagt schon aus, was das Problem ist: Der Datenpunkt ist für 0 - 32°C angelegt. Bei meiner Außensteckdose im Gartenhaus kommen aber auch mal kältere Temperaturen vor. Ich habe den Range einfach von Hand geändert. Vielleicht wäre deutlich großzügigerer Bereich (etwa -30°C bis +50°C) sinnvoll. Kann ja auch sein, dass eine Innensteckdose mal hinter einem Ofen steckt.
@hansjochen Hallo, das kannst du selbst ändern. Im Objektordner beim Datenpunkt "celsius" auf den Stift klicken und dann runter scrollen.
Hallo @Winni
@winni sagte in Fritzbox DECT Adapter:
Danke für den Hinweis, damit hatte ich ja die Meldung bei mir ja auch weg bekommen. Ich dachte, dass ein großzügigerer Standard Wertebereich im Adapter sinnvoll wäre, weil das bei anderen bestimmt auch mal vorkommt.
Hallo @Winni
@hansjochen ok, hatte ich übersehen.
der Bereich ist schon länger mit -30..50°C im Adapter hinterlegt.
Allerdings werden angelegte Datenpunkte nicht überschrieben, d.h. damit die geänderten Wertebereiche auch wirksam werden, muß der Datenpunkt (oder der ganze Baum von der Instanz) gelöscht werden.
Beim Neustart wird der nichtexistierende Datenpunkt auch wieder angelegt, diesmal mit den geänderten Grenzen. -
Beim Neustart wird der nichtexistierende Datenpunkt auch wieder angelegt, diesmal mit den geänderten Grenzen.Danke für den Hinweis. Ich hatte nicht daran gedacht, nachzusehen, ob das schon behoben ist.
Ich schließe mich hier mal an. Ich habe einen Rolladen über die FRITZ!Box verbunden, und den Fritz dect Adapter installiert und richtige ip und Login Daten eingegeben - alles auf grün... Leider erscheint das Gerät unter den Objekten nicht. Jemand eine Idee woran das liegen kann?
Was zeigt das Log nach dem Start?
Da sollten Berechtigungen des Users angezeigt sein ( 2 ist gut).
Und danach sollte etwas stehen, wieviele Geräte angelegt werden und das es fertig ist.Es hilft auch auf der AdapterConfig Seite mal die Tasten für "Meine Geräte/My Devices" zu drücken.
Da sollte ein Fenster aufgehen und Text drin stehen (bestenfalls die ID von deinem Rollo usw.)
Wenn da nichts kommt, dann passt etwas mit login nicht, oder die Integration des Gerätes in der FB. -
Wenn da nichts kommt, dann passt etwas mit login nicht, oder die Integration des Gerätes in der FB.@foxthefox Würde auf den ersten Blick sagen, dass dem Benutzer die Berechtigung für die SmartHome Geräte fehlt. Ich habe mehrere Rollotron Dect in der Fritzbox und die funktionieren traumhaft.
@dragon sagte in Fritzbox DECT Adapter:
das freut mich zu hören.
gehe ich auch fast davon aus, das gilt es herauszufinden
Wenn da nichts kommt, dann passt etwas mit login nicht, oder die Integration des Gerätes in der FB.@foxthefox @Dragon
Danke euch, es lag tatsächlich am Login. Super, jetzt klappts.
