  5. Wettervorhersage über echo-dot und aquara motion ausgeben
    5.1k
46 Beiträge 4 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • KusselinK Kusselin
    @crunchip das heisst du bist 24/7 online....... o.k. dann hau dir mal einen Kaffee rein :-)
    crunchipC Offline
    crunchipC Offline
    #41
    @kusselin sagte in Wettervorhersage über echo-dot und aquara motion ausgeben:
    fast😁
      <variables>
        <variable id="#BdIe|ykthpZOE^sN#yV">lautstärke</variable>
        <variable id="3J#e:ZX!~|d@j+DQu^4*">erstemal</variable>
      </variables>
      <block type="on_ext" id="7}}|wSv/]f|s+A~UK3_~" x="-1212" y="-112">
        <field name="CONDITION">gt</field>
        <value name="OID0">
          <shadow type="field_oid" id="]W6/A-4_~;uB[o)PWyO;">
            <field name="oid">zigbee.0.00158d00044b132b.occupancy</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="gv/II(MWg45zzx[ETsyb">
            <value name="IF0">
              <block type="logic_negate" id="{nkKts97]x/o+6;edx/u">
                <value name="BOOL">
                  <block type="variables_get" id="6i;z2-fW1bzsaS=hndM*">
                    <field name="VAR" id="3J#e:ZX!~|d@j+DQu^4*">erstemal</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="variables_set" id="G!C.[c:E~A{Z|ZyTuG;X">
                <field name="VAR" id="#BdIe|ykthpZOE^sN#yV">lautstärke</field>
                <value name="VALUE">
                  <block type="get_value" id="mW^Tp`a9/4k#OIq?nsza">
                    <field name="OID">alexa2.0.Echo-Devices.G090U509910703K5.Commands.speak-volume</field>
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="m3%jUq*z,qnS.k,!TE$4">
                      <block type="logic_boolean" id="MU1@Oxn5UaYcn!}LT}YF">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="u9d3SrJzs2(mZAL%tnVZ">
                          <block type="math_number" id="GJutfx]I^={0cPeS-9|6">
                            <field name="NUM">80</field>
                          </block>
                        </value>
                        <next>
                          <block type="control" id="`TcoL#W4~xr!?;Ef/1A9">
                            <field name="OID">alexa2.0.Echo-Devices.G090U509910703K5.Commands.speak</field>
                              <block type="text" id="J{8/oWHrlQ}fyK=ep0lU">
                                <field name="TEXT">Guten Morgen</field>
                              </block>
                            </value>
                            <next>
                              <block type="control" id="zk+v.%/8@D$+yAz,D:hS">
                                <field name="OID">alexa2.0.Echo-Devices.G090U509910703K5.Commands.weather</field>
                                  <block type="logic_boolean" id="=Lf7m-u9kPEN5t3V}wv6">
                                  </block>
                                </value>
                                <next>
                                  <block type="control" id="/4Bt2}U6uee76{g#qiFe">
                                      <block type="variables_get" id="#cF3:c353cj(al]7W:up">
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="schedule" id=":IhFs0spzL1ILi;]}N#v">
            <field name="SCHEDULE">0 6 * * *</field>
              <block type="variables_set" id="4V.-Roq+]6ou7U8?E+:}">
                  <block type="logic_boolean" id="f]-`aChZknAu?Jg.Ga=h">
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
      Die wetteransage in fhem ist halt etwas professioneller das läuft über das Modul Wetter. Ich kann aber nicht zigbee in fhem und gleichzeitig in iobroker laufen lassen..... :-(
      Eine Möglichkeit wäre jetzt noch ein Wetteradapter zu installieren (nur welchen? - das Wetter, weatherunderground?) der das Wetter für meine Region detaillierter ansagt..richtig? das geht alles
      crunchipC Offline
      crunchipC Offline
      #42
      könntest du, die Variante mit dem Alexa Weather ist eben, wenn du nicht explizit einen Wetter Adapter hast. Wenn dein Standort in Alexa hinterlegt ist, bekommst du ja für deine Region das Wetter angesagt.
      Die Formulierung im Detail(eher Kurzform) ist dann wieder bei jedem Wetteradapter etwas anders, sofern ein Datenpunkt vorhanden ist, bzw könntest du dir auch deinen individuellen Text zusammen basteln mit den vorhandenen Datenpunkten.
      KusselinK 1 Antwort Letzte Antwort
        KusselinK Offline
        KusselinK Offline
        Kusselin
        schrieb am zuletzt editiert von Kusselin
        #43
        @crunchip vielen Dank für deinen Script mit Lautstärke....funzt :-)
        Jetzt ist mir meien Plug-Steckdose aus der eigentliche Steckdose raus gefallen.. :-(
        Jetzt ist der Cube natürlich mit verbindung rot....Habe jetzt nochmal drübergepairt.....jetzt verbindet sich der Cube wieder mit demn Zigbeestick udn nicht mehr mit der Plug steckdose :-(
        Frage: Kann sich der Cube ev. noch mit der näheren Plufdode im nachhinein verbinden oder muss ich jetzt mit den Cube nah an die Plugdose udn nochmal drüberpairen?
        EDIT Cube: Eben hab ich nochmal geschaut bei Netzwerkkarte....jetzt hat sich der Cube autom. mit der Plugsteckdose verbunden..top!
        Gruss
        • KusselinK Offline
          KusselinK Offline
          Kusselin
          #44
          Und...kann man bei Admin nun bedenkenlos auf 5.0.7 updaten?
            Gruss
            #45
            Was soll bedenkenlos bei einer Beta-Version bedeuten?
            Beta ist immer bedenklich, im wahrsten Sinne des Wortes. Da muss man nämlich immer einiges bedenken.
            Davon ab ist die letzte Beta-Version 5.0.8 per heute.
              Gruss
              crunchipC Offline
              crunchipC Offline
              #46
              hättest nur mal den Knopf drücken müssen, nicht zwangsläufig neu pairen
              der sucht sich automatisch den Weg, das kann man nicht beeinflussen
              NEIN!!
              Wobei, du hast ja schon bedenkenlos auf admin v5.x angehoben😜
