  4. Berechtigungsprobleme / Updates nicht möglich / Windows
7 Beiträge 2 Kommentatoren 767 Aufrufe 2 Beobachtet
    torstenhe
    Schönen guten Morgen,
    ich habe mehrfach versucht verschiedene Adapter zu aktualisieren aber es schlägt immer fehl.
    Hier eine Beispielmeldung:
    NPM version: 6.14.6
    npm install iobroker.vis-inventwo@2.9.2 --loglevel error (System call)
    npm ERR!
     code EPERMnpm ERR! syscall unlinknpm ERR! path C:\Program Files\iobroker\SmartHome1\node_modules\.utf-8-validate.DELETE\prebuilds\win32-x64\node-napi.nodenpm ERR! errno -4048
    npm
    ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\.utf-8-validate.DELETE\prebuilds\win32-x64\node-napi.node'
    npm ERR!
      [OperationalError: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\.utf-8-validate.DELETE\prebuilds\win32-x64\node-napi.node'] {npm
     ERR!   cause: [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartHome1\node_modules\.utf-8-validate.DELETE\prebuilds\win32-x64\node-napi.node'] {
    npm ERR!
         errno: -4048,npm
     ERR!     code: 'EPERM',npm ERR!     syscall: 'unlink',npm ERR!     path: 'C:\\Program Files\\iobroker\\SmartHome1\\node_modules\\.utf-8-validate.DELETE\\prebuilds\\win32-x64\\node-napi.node'npm ERR!   },npm ERR!   errno: -4048,npm ERR!   code: 'EPERM',npm ERR!   syscall: 'unlink',npm ERR!   path: 'C:\\Program Files\\iobroker\\SmartHome1\\node_modules\\.utf-8-validate.DELETE\\prebuilds\\win32-x64\\node-napi.node',npm ERR!   parent: 'SmartHome1'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.npm
     ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartHome1\env\npm-cache\_logs\2021-04-12T09_18_21_866Z-debug.log
    ERROR: host.ioBroker(SmartHome1) Cannot install iobroker.vis-inventwo@2.9.2: 4294963248
    Ich hab alles mögliche in den Foren gefunden aber es wird meist keine Windows-Installation behandelt.
    Habe versucht per Kommandozeile auf dem iobroker den Befehl "iobroker fix" auszuführen aber da tut sich nichts und mir werden nur "alle" Befehle angezeigt die ich auf der Kommandozeile nutzen kann.
    Vielleicht kann mir jemand helfen. :)
    LG
    • T torstenhe
      NPM version: 6.14.6
      npm ERR!
      npm
      npm ERR!
      npm ERR!
           errno: -4048,npm
      LG
      sigi234S Online
      sigi234S Online
      sigi234
      @torstenhe
      Folgende Schritte sind bei einem Update und Neuinstallation zwingend notwendig:
      data-Ordner sichern (nur bei Update)
      Frische Installation mit dem Installer von der Webseite (2019-11-23) aufsetzen. Dabei (falls Update) den zuvor gesicherten data-Ordner durch den Installer einlesen.
      Nichts weiter tun!
      ioBroker-Konsole der neuen Installation auf
      iobroker stop
      npm i iobroker.js-controller@stable --ignore-scripts
      iobroker start
      Diese führt dich zu folgendem Workaround:
      https://forum.iobroker.net/post/446928
      Immer Daten sichern!
      • sigi234S sigi234
        @torstenhe
        Nichts weiter tun!
        iobroker stop
        iobroker start
        torstenhe
        @sigi234
        Das ist jetzt nicht dein Ernst.
        Warum zum Teufel muss ich meinen iobroker neu installieren?
        Nichts ahnend möchte man seine Adapter aktualisieren, es geht nicht und dann muss man neu installieren?
        Es muss doch eine einfachere Lösung geben.
        Nichts für ungut und ich finde deine schnelle Hilfe echt super, nur für mich überraschend das ich mein System neu installieren muss. 😉
        • T torstenhe
          @sigi234
          sigi234S Online
          sigi234S Online
          sigi234
          @torstenhe sagte in Berechtigungsprobleme / Updates nicht möglich / Windows:
          updaten
          Zur Sicherheit mal
          iobroker stop
          dann:
          data-Ordner sichern
          Welche Vesionen hast du?
          Node.js: 12.21.0
          NPM: 6.14.11
          JS Controler: 3.2.16
          Admin: 4.2.1
          Web: 3.3.0
          Socket.io: 3.1.4
          Script Engine: 5.1.3
          • sigi234S sigi234
            updaten
            Zur Sicherheit mal
            iobroker stop
            dann:
            data-Ordner sichern
            Node.js: 12.21.0
            NPM: 6.14.11
            Admin: 4.2.1
            Web: 3.3.0
            Socket.io: 3.1.4
            torstenhe
            @sigi234
            Ich hab das jetzt mal durchgezogen.
            läuft wieder alles. :) Vielen Dank für deine Hilfe.
            Nur ist es trotzdem fraglich warum so etwas passiert. :)
            Hab jetzt aber ne veraltete node.js. v10.17.0 Hier muss ich wohl mal updaten.
            NPM ist auch veraltet. 6.11.3
            • T torstenhe
              @sigi234
              sigi234S Online
              sigi234S Online
              sigi234
              1: Konsole: iobroker stop
              2: Sicherung des Ordners: C:\Program Files\iobroker\deinhostname\nodejs auf dem Desktop
              3: Download der benötigten Node.js Version unter https://nodejs.org als Archiv nicht als msi Datei
              4: Entpacken des Downloads und kopieren den Gesamten Ordners über den vorhandenen C:\Program Files\iobroker\deinhostname\nodejs Ordner.
              5: Kopiere aus der Sicherungskopie des Desktops die Datei nodevars.bat in den Ordner C:\Program Files\iobroker\deinhostname\nodejs
              6: Konsole: iobroker start
              v12.22.1
              • sigi234S sigi234
                v12.22.1
                torstenhe
                @sigi234
                Jau. Habs genauso gemacht. Läuft.
                Danke.
