  4. kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4
    5.2k
44 Beiträge 6 Kommentatoren 4.1k Aufrufe 5 Beobachtet
  • A AMagnum
    @paul53 nun habe ich das System neu aufgesetzt.
    pi@SmartHomePi4:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.22.0
    /usr/bin/node
    v12.22.0
    /usr/bin/npm
    6.14.11
    nodejs:
      Installed: 12.22.0-1nodesource1
      Candidate: 12.22.0-1nodesource1
      Version table:
     *** 12.22.0-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u1 500
    pi@SmartHomePi4:~ $ uname -a
    Linux SmartHomePi4 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
    pi@SmartHomePi4:~ $ sudo lsb_release -a
    No LSB modules are available.
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    pi@SmartHomePi4:~ $ ls -l /dev/ttyA*
    crw-rw---- 1 root dialout 166,  0 Apr  5 21:03 /dev/ttyACM0
    crw-rw---- 1 root dialout 204, 64 Apr  5 20:28 /dev/ttyAMA0
    pi@SmartHomePi4:~ $ sudo grep dialout /etc/group
    dialout:x:20:pi,iobroker
    pi@SmartHomePi4:~ $ iobroker -v
    3.2.16
    Der Adapter zeigt nun
    Das Logfile im ioBroker gibt folgendes nun aus:
    zwave2.0	2021-04-05 21:07:20.395	info	(8247) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.0, js-controller: 3.2.16
    host.SmartHomePi4	2021-04-05 21:07:18.335	info	instance system.adapter.zwave2.0 started with pid 8247
    host.SmartHomePi4	2021-04-05 21:07:15.811	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    zwave2.0	2021-04-05 21:07:15.254	info	(8228) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zwave2.0	2021-04-05 21:07:15.253	info	(8228) terminating
    zwave2.0	2021-04-05 21:07:15.251	info	(8228) Shutting down driver...
    zwave2.0	2021-04-05 21:07:15.249	info	(8228) Got terminate signal TERMINATE_YOURSELF
    host.SmartHomePi4	2021-04-05 21:07:15.249	info	stopInstance system.adapter.zwave2.0 send kill signal
    host.SmartHomePi4	2021-04-05 21:07:15.241	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
    zwave2.0	2021-04-05 21:06:21.183	warn	(8228) No serial port configured. Please select one in the adapter settings!
    zwave2.0	2021-04-05 21:06:21.132	info	(8228) starting. Version 1.8.11 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.0, js-controller: 3.2.16
    host.SmartHomePi4	2021-04-05 21:06:19.095	info	instance system.adapter.zwave2.0 started with pid 8228
    host.SmartHomePi4	2021-04-05 21:06:17.099	info	iobroker exit 0
    host.SmartHomePi4	2021-04-05 21:06:16.013	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0 created
    host.SmartHomePi4	2021-04-05 21:06:15.908	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.connection: false
    host.SmartHomePi4	2021-04-05 21:06:15.878	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.inclusion: 0
    host.SmartHomePi4	2021-04-05 21:06:15.849	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.exclusion: false
    host.SmartHomePi4	2021-04-05 21:06:15.819	info	iobroker host.SmartHomePi4 Set default value of zwave2.0.info.healingNetwork: false
    host.SmartHomePi4	2021-04-05 21:06:15.786	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.alive created
    host.SmartHomePi4	2021-04-05 21:06:15.755	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.connected created
    host.SmartHomePi4	2021-04-05 21:06:15.725	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.compactMode created
    host.SmartHomePi4	2021-04-05 21:06:15.697	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.cpu created
    host.SmartHomePi4	2021-04-05 21:06:15.666	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.cputime created
    host.SmartHomePi4	2021-04-05 21:06:15.637	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memHeapUsed created
    host.SmartHomePi4	2021-04-05 21:06:15.607	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memHeapTotal created
    host.SmartHomePi4	2021-04-05 21:06:15.578	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.memRss created
    host.SmartHomePi4	2021-04-05 21:06:15.550	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.uptime created
    host.SmartHomePi4	2021-04-05 21:06:15.521	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.inputCount created
    host.SmartHomePi4	2021-04-05 21:06:15.491	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.outputCount created
    host.SmartHomePi4	2021-04-05 21:06:15.463	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.eventLoopLag created
    host.SmartHomePi4	2021-04-05 21:06:15.434	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.sigKill created
    host.SmartHomePi4	2021-04-05 21:06:15.404	info	iobroker host.SmartHomePi4 object system.adapter.zwave2.0.logLevel created
    host.SmartHomePi4	2021-04-05 21:06:15.375	info	iobroker host.SmartHomePi4 object zwave2.0.info created
    host.SmartHomePi4	2021-04-05 21:06:15.347	info	iobroker host.SmartHomePi4 object zwave2.0.info.connection created
    host.SmartHomePi4	2021-04-05 21:06:15.318	info	iobroker host.SmartHomePi4 object zwave2.0.info.inclusion created
    host.SmartHomePi4	2021-04-05 21:06:15.289	info	iobroker host.SmartHomePi4 object zwave2.0.info.exclusion created
    host.SmartHomePi4	2021-04-05 21:06:15.261	info	iobroker host.SmartHomePi4 object zwave2.0.info.healingNetwork created
    host.SmartHomePi4	2021-04-05 21:06:15.249	info	iobroker host.SmartHomePi4 create instance zwave2
    Was mache ich nur falsch? Habe nun kein Z-WAY installiert, also ganz ohne! Und alles nur unter pi-User und sudo.
    @amagnum
    Das gemacht?
    A 1 Antwort Letzte Antwort
      @amagnum
      Das gemacht?
      AMagnum
      @thomas-braun Ja hatte ich gemacht. Habe dort /dev/ttyAMA0 eingetragen und Adapter auch neu gestartet. Das Logfile oben ist nach dem Eintrag des TTY.
      • A AMagnum
        AMagnum
        • A AMagnum
          @amagnum
          Und auf ttyACM0 läuft der zigbee?
            @amagnum
            AMagnum
            pi@SmartHomePi4:~ $ npx @serialport/list
            /dev/ttyACM0    usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2427885-if00   dresden elektronik ingenieurtechnik GmbH
            /dev/ttyAMA0
            /dev/ttyS0
            Ja auf dem Port ttyACM0 läuft der ConBee_II Stick. Mich wundert es, dass mit dem o.g. Befehl keine Ausgabe für ttyAMA0 gemacht wird. Ich hätte irgendwie gedacht, dass dort auch was stehen sollte.
            • A AMagnum
              /dev/ttyAMA0
              /dev/ttyS0
              @amagnum
              Da kann ich nicht weiterhelfen, ich kenne die Hardware nicht.
                @amagnum
                AMagnum
                @thomas-braun trotzdem vielen Dank für Deine Hilfe
                • A AMagnum
                  Habe nun im Verzeichnis /opt/iobroker/node_modules/iobroker.zwave2 den Befehl npm i zwave-js@3.2.0 aufgerufen. Nun ist zumindest im Logfile des Adapters der Fehler mit libnode.so.64 verschwunden. Sieht also schon etwas besser aus.
                  Dafür bekommt der Adapter keine Verbindung zum /dev/ttyAMA0 hin. Das TTY ist im Web-Interface (Z-Wave) korrekt eingestellt und ist auch unter /dev zu sehen.
                  Alles sehr eigenartig.
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @amagnum sagte in kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4:
                  Ahhhh - NEIN! Niemals manuell eine eigene Version der Library installieren. Die ist eng mit dem Adapter verzahnt.
                  Zeig mal deine detaillierte Logdatei (die neueste): https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
                  • tugsiT Offline
                    tugsiT Offline
                    tugsi
                    @amagnum
                    ich habe den ZWave2.0 noch nicht installiert bei mir, steht noch auf meiner ToDo-Liste.
                    Aber ich kann Dir sagen, dass mit dem alten ZWave und den Razberry ich auch das Device auf
                    /dev/ttyAMA0
                    habe.
                    Aber hast Du bei dem neuaufsetzen das beherzigt, was @paul53 geschrieben hat:
                    • Z-Way? Dann greift die sich den Razberry und der Zugriff ist blockiert.
                    Es kann immer nur ein Tool auf ein serielles Gerät zugreifen, ausser es wird jedesmal extra abgemeldet, dies wäre aber hier nicht der Fall.
                    Ist schon lange her, dass ich den Razberry installiert habe, damals hatte ich auch erst noch getestet und mir glaub ich auch Z-Way oder so draufgemacht, um zu schauen, ob das Teil funzt.
                    Ich habe gerade mal den ZWave2.0 installiert und meinen ZWave ausgeschaltet und den einfach mit /dev/ttyAMA0 gestartet und er läuft, findet allerdings die alten Geräte nicht mehr, da ja jetzt ein anderer Schlüssel da ist, aber er hat den Razberry als NODE1 drin.
                    Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                    • AlCalzoneA AlCalzone
                      AMagnum
                      @alcalzone Guten Morgen,
                      Habe keine eigene Version der Library installiert, alles ist Standard. Ich hatte das System ja neu aufgesetzt. Alles ganz frisch, im ioBroker nur admin.0, discovery.0 und info.0 und den zwave2. Kein Z-WAY installiert, damit der Port nicht durch eine andere SW belegt wird.
                      Hier meine aktuelle Konfiguration:
                      /usr/bin/nodejs
                      v12.22.0
                      /usr/bin/node
                      v12.22.0
                      /usr/bin/npm
                      6.14.11
                      nodejs:
                        Version table:
                      Release:        10
                      Codename:       buster
                      crw-rw---- 1 root dialout 166,  0 Apr  5 21:03 /dev/ttyACM0   << das ist mein Connbee2 zigbee
                      3.2.16
                      Habe jetzt mal den zwave2 Adapter im ioBroker gelöscht und neu hinzugefügt. Wenn man ihn hinzugügt, kommt zwar im ioBroker-Log die Meldung No serial port configured, aber dann trage ich ja den Port ein. Ist eventuell nur bem Hinzugügen so. Dann habe ich den Adaper mal beendet (08:05 Uhr) und neu gestartet (08:07 Uhr).
                      Hier das Log beim beenden:
                      08:03:21.387 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                      08:03:21.391 DRIVER   version 6.6.3
                      08:03:21.392 DRIVER
                      08:03:21.392 DRIVER   starting driver...
                      08:03:21.419 DRIVER   opening serial port /dev/ttyAMA0
                      08:03:21.444 DRIVER   serial port opened
                      08:03:21.446 SERIAL » [NAK]        (0x15)
                      08:05:36.670 DRIVER   destroying driver instance...
                      und hier beim Starten
                      08:07:41.415 DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                      08:07:41.419 DRIVER   version 6.6.3
                      08:07:41.420 DRIVER
                      08:07:41.420 DRIVER   starting driver...
                      08:07:41.447 DRIVER   opening serial port /dev/ttyAMA0
                      08:07:41.467 DRIVER   serial port opened
                      08:07:41.468 SERIAL » [NAK]        (0x15)
                      Das NAK wundert mich. Ich muss dazu sagen, es gibt bisher keine Geräte im Z-Wave-Netz, die ich angelernt habe, alles noch ganz leer.
                      Komisch ist auch, dass unter /opt/iobroker/iobroker-data es kein zwave2.0/cache Verzeichnis gibt. Liegt aber vielleicht auch daran, weil keine Verbindung zustande kommt. Der Adapter bleibt im Status gelb, also true, true, false.
                      In Deinem angegebenen Link beschreibst Du, dass bei einem NAK wohl die Kommunikation mit dem Gerät nicht geklappt hat und eventuell eine Geräte-Konfiguration fehlt und man einen Pull-Request im zwave-js repo anlegen sollte. Dort gibt es auch einen Link zu einer Doku, leider funktioniert der Link nicht (https://alcalzone.github.io/node-zwave-js/#/development/config-files). Vielleicht würde ich mit der Beschreibung weiterkommen?
                      Danke für Deine Hilfe.
                      • A AMagnum
                        /usr/bin/nodejs
                        v12.22.0
                        /usr/bin/node
                        v12.22.0
                        /usr/bin/npm
                        6.14.11
                        nodejs:
                          Version table:
                        Release:        10
                        Codename:       buster
                        3.2.16
                        08:03:21.392 DRIVER
                        08:07:41.420 DRIVER
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @amagnum Das NAK ist das erste Kommando, was nach dem Start an den Stick gesendet wird, um die Kommunikation zu initialisieren. Kurz danach sollte der Adapter aber mit dem Laden der Konfiguration beginnen - das passiert bei dir nicht. Zeig bitte mal die Ausgabe von:
                        cd /opt/iobroker/node_modules/iobroker.zwave2
                        npm ls
                          npm ls
                          AMagnum
                          @alcalzone sagte in kleines Projekt Z-Wave und Zigbee gleichzeitig auf PI4:
                          pi@SmartHomePi4:/opt/iobroker/node_modules/iobroker.zwave2 $ npm ls
                          iobroker.zwave2@1.8.11 /opt/iobroker/node_modules/iobroker.zwave2
                          ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.4.0
                          ├── UNMET DEPENDENCY alcalzone-shared@^3.0.2
                          ├── UNMET DEPENDENCY fs-extra@^9.1.0
                          └── UNMET DEPENDENCY zwave-js@^6.3.0
                          npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.8.11
                          npm ERR! missing: alcalzone-shared@^3.0.2, required by iobroker.zwave2@1.8.11
                          npm ERR! missing: fs-extra@^9.1.0, required by iobroker.zwave2@1.8.11
                          npm ERR! missing: zwave-js@^6.3.0, required by iobroker.zwave2@1.8.11
                          oh, sieht nicht gut aus.
                          A tugsiT 2 Antworten Letzte Antwort
                          • A AMagnum
                            AMagnum
                            @amagnum Was soll ich nun machen?
                            • A AMagnum
                              tugsiT Offline
                              tugsiT Offline
                              tugsi
                              @amagnum
                              Also ich habe da keine großartig andere Leistung, einzig benutze ich die Version 1.9.0 schon.
                              Stell mal unter Haupteinstellungen des iObrokers unter Verwahrungsort auf BETA, dann bekommst auch die 1.9.0.
                              Wobei ich jetzt nicht geschaut habe, welche Änderungen da gemacht wurden seitdem.
                              iobroker.zwave2@1.9.0 /opt/iobroker/node_modules/iobroker.zwave2
                              ├─┬ fs-extra@9.1.0
                              │ ├── UNMET DEPENDENCY at-least-node@^1.0.0
                              │ ├── graceful-fs@4.2.6
                              │ ├─┬ jsonfile@6.1.0
                              │ │ ├── graceful-fs@4.2.6 deduped
                              │ │ └── universalify@2.0.0 deduped
                              └── UNMET DEPENDENCY zwave-js@^7.0.0-beta.1
                              npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.9.0
                              npm ERR! missing: alcalzone-shared@^3.0.2, required by iobroker.zwave2@1.9.0
                              npm ERR! missing: zwave-js@^7.0.0-beta.1, required by iobroker.zwave2@1.9.0
                              npm ERR! missing: at-least-node@^1.0.0, required by fs-extra@9.1.0
                              Auch wenn Du noch keine Geräte hast, es gibt ja das "Hauptgerät" also NODE1, Dein Razberry
                              • tugsiT tugsi
                                @amagnum
                                ├─┬ fs-extra@9.1.0
                                AMagnum
                                schrieb am zuletzt editiert von AMagnum
                                @alcalzone
                                Habe nun im Verzeichnis /opt/iobroker/node_modules/iobroker.zwave2 den Befehl npm install --production aufgerufen (bin mir aber gerade unsicher, ob ich hier das richtige gemacht habe, Verzweiflungstat). Es wurde sehr viel geladen und übersetzt, es gibt aber gerade im Bereich von serialport viele Warnungen. Ich denke das ist der native Anteil des Treibers. Eventuell kann daher der Adapter nicht mit dem tty kommunizieren.
                                Hier die Ausgaben, leider etwas viel Output:
                                pi@SmartHomePi4:/opt/iobroker/node_modules/iobroker.zwave2 $ npm install --production
                                npm WARN deprecated parcel-bundler@1.12.5: Parcel v1 is no longer maintained. Please migrate to v2, which is published under the 'parcel' package. See https://v2.parceljs.org/getting-started/migration for details.
                                npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
                                npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                > @serialport/bindings@9.0.7 install /opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings
                                > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                prebuild-install WARN install No prebuilt binaries found (target=12.22.0 runtime=node arch=arm libc= platform=linux)
                                make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings/build'
                                  CXX(target) Release/obj.target/bindings/src/serialport.o
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                ../src/serialport.cpp: At global scope:
                                ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                In file included from ../../../nan/nan.h:56,
                                                 from ../src/./serialport.h:6,
                                                 from ../src/serialport.cpp:1:
                                /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                       (node::addon_register_func) (regfunc),                          \
                                /home/iobroker/.cache/node-gyp/12.22.0/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(serialport, init);
                                  CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                  CXX(target) Release/obj.target/bindings/src/poller.o
                                  CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                                  SOLINK_MODULE(target) Release/obj.target/bindings.node
                                  COPY Release/bindings.node
                                make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@serialport/bindings/build'
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/glob-watcher/node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.2.7 (node_modules/@parcel/watcher/node_modules/chokidar/node_modules/fsevents):
                                added 147 packages from 179 contributors and audited 1836 packages in 84.352s
                                24 packages are looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                Wenn ich nun aber npm ls aufrufe, dann kommt folgende Ausgabe.
                                ├─┬ @iobroker/adapter-core@2.4.0
                                │ └─┬ @types/iobroker@3.2.8
                                │   └── @types/node@14.14.37 deduped
                                ├── @types/node@14.14.37
                                ├─┬ alcalzone-shared@3.0.3
                                │ └─┬ debug@4.3.1
                                │   └── ms@2.1.2
                                ├─┬ fs-extra@9.1.0
                                │ ├── at-least-node@1.0.0
                                ├─┬ source-map-support@0.5.19
                                │ ├── buffer-from@1.1.1
                                │ └── source-map@0.6.1
                                └─┬ zwave-js@6.6.3
                                  ├─┬ @alcalzone/jsonl-db@1.2.4
                                  │ ├── alcalzone-shared@3.0.3 deduped
                                  │ └── fs-extra@9.1.0 deduped
                                  ├─┬ @sentry/integrations@6.2.5
                                  │ ├── @sentry/types@6.2.5
                                  │ ├─┬ @sentry/utils@6.2.5
                                  │ │ ├── @sentry/types@6.2.5 deduped
                                  │ │ └── tslib@1.14.1 deduped
                                  │ ├─┬ localforage@1.9.0
                                  │ │ └─┬ lie@3.1.1
                                  │ │   └── immediate@3.0.6
                                  │ └── tslib@1.14.1
                                  ├─┬ @sentry/node@6.2.5
                                  │ ├─┬ @sentry/core@6.2.5
                                  │ │ ├── @sentry/hub@6.2.5 deduped
                                  │ │ ├─┬ @sentry/minimal@6.2.5
                                  │ │ │ ├── @sentry/hub@6.2.5 deduped
                                  │ │ │ ├── @sentry/types@6.2.5 deduped
                                  │ │ │ └── tslib@1.14.1 deduped
                                  │ │ ├── @sentry/utils@6.2.5 deduped
                                  │ ├─┬ @sentry/hub@6.2.5
                                  │ ├─┬ @sentry/tracing@6.2.5
                                  │ │ ├── @sentry/minimal@6.2.5 deduped
                                  │ ├── cookie@0.4.1
                                  │ ├─┬ https-proxy-agent@5.0.0
                                  │ │ ├─┬ agent-base@6.0.2
                                  │ │ │ └── debug@4.3.1 deduped
                                  │ ├── lru_map@0.3.3
                                  ├─┬ @zwave-js/config@6.6.3
                                  │ ├── @zwave-js/core@6.6.3 deduped
                                  │ ├── @zwave-js/shared@6.6.3 deduped
                                  │ ├── ansi-colors@4.1.1 deduped
                                  │ ├── fs-extra@9.1.0 deduped
                                  │ ├── json-logic-js@2.0.1
                                  │ ├─┬ json5@2.2.0
                                  │ │ └── minimist@1.2.5
                                  │ ├─┬ semver@7.3.5
                                  │ │ └─┬ lru-cache@6.0.0
                                  │ │   └── yallist@4.0.0
                                  │ └── winston@3.3.3 deduped
                                  ├─┬ @zwave-js/core@6.6.3
                                  │ ├── @alcalzone/jsonl-db@1.2.4 deduped
                                  │ ├── moment@2.29.1
                                  │ ├─┬ moment-timezone@0.5.33
                                  │ │ └── moment@2.29.1 deduped
                                  │ ├── nrf-intel-hex@1.3.0
                                  ├─┬ @zwave-js/serial@6.6.3
                                  │ ├── serialport@9.0.7 deduped
                                  ├─┬ @zwave-js/shared@6.6.3
                                  │ └── alcalzone-shared@3.0.3 deduped
                                  ├── reflect-metadata@0.1.13
                                  ├─┬ serialport@9.0.7
                                  │ ├─┬ @serialport/binding-mock@9.0.7
                                  │ │ ├─┬ @serialport/binding-abstract@9.0.7
                                  │ ├─┬ @serialport/bindings@9.0.7
                                  │ │ ├── @serialport/binding-abstract@9.0.7 deduped
                                  │ │ ├── @serialport/parser-readline@9.0.7 deduped
                                  │ │ ├─┬ bindings@1.5.0
                                  │ │ │ └── file-uri-to-path@1.0.0
                                  │ │ ├── debug@4.3.1 deduped
                                  │ │ ├── nan@2.14.2
                                  │ │ └─┬ prebuild-install@6.1.1
                                  │ │   ├── detect-libc@1.0.3
                                  │ │   ├── expand-template@2.0.3
                                  │ │   ├── github-from-package@0.0.0
                                  │ │   ├── minimist@1.2.5 deduped
                                  │ │   ├── mkdirp-classic@0.5.3
                                  │ │   ├── napi-build-utils@1.0.2
                                  │ │   ├─┬ node-abi@2.21.0
                                  │ │   │ └── semver@5.7.1
                                  │ │   ├── noop-logger@0.1.1
                                  │ │   ├─┬ npmlog@4.1.2
                                  │ │   │ ├─┬ are-we-there-yet@1.1.5
                                  │ │   │ │ ├── delegates@1.0.0
                                  │ │   │ │ └─┬ readable-stream@2.3.7
                                  │ │   │ │   ├── core-util-is@1.0.2 deduped
                                  │ │   │ │   ├── inherits@2.0.4 deduped
                                  │ │   │ │   ├── isarray@1.0.0 deduped
                                  │ │   │ │   ├── process-nextick-args@2.0.1 deduped
                                  │ │   │ │   ├── safe-buffer@5.1.2
                                  │ │   │ │   ├─┬ string_decoder@1.1.1
                                  │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                                  │ │   │ │   └── util-deprecate@1.0.2 deduped
                                  │ │   │ ├── console-control-strings@1.1.0
                                  │ │   │ ├─┬ gauge@2.7.4
                                  │ │   │ │ ├── aproba@1.2.0
                                  │ │   │ │ ├── console-control-strings@1.1.0 deduped
                                  │ │   │ │ ├── has-unicode@2.0.1
                                  │ │   │ │ ├── object-assign@4.1.1
                                  │ │   │ │ ├── signal-exit@3.0.3
                                  │ │   │ │ ├─┬ string-width@1.0.2
                                  │ │   │ │ │ ├── code-point-at@1.1.0
                                  │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                  │ │   │ │ │ │ └── number-is-nan@1.0.1
                                  │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                                  │ │   │ │ ├─┬ strip-ansi@3.0.1
                                  │ │   │ │ │ └── ansi-regex@2.1.1
                                  │ │   │ │ └─┬ wide-align@1.1.3
                                  │ │   │ │   └── string-width@1.0.2 deduped
                                  │ │   │ └── set-blocking@2.0.0
                                  │ │   ├─┬ pump@3.0.0
                                  │ │   │ ├─┬ end-of-stream@1.4.4
                                  │ │   │ │ └── once@1.4.0 deduped
                                  │ │   │ └─┬ once@1.4.0
                                  │ │   │   └── wrappy@1.0.2
                                  │ │   ├─┬ rc@1.2.8
                                  │ │   │ ├── deep-extend@0.6.0
                                  │ │   │ ├── ini@1.3.8
                                  │ │   │ ├── minimist@1.2.5 deduped
                                  │ │   │ └── strip-json-comments@2.0.1
                                  │ │   ├─┬ simple-get@3.1.0
                                  │ │   │ ├─┬ decompress-response@4.2.1
                                  │ │   │ │ └── mimic-response@2.1.0
                                  │ │   │ ├── once@1.4.0 deduped
                                  │ │   │ └── simple-concat@1.0.1
                                  │ │   ├─┬ tar-fs@2.1.1
                                  │ │   │ ├── chownr@1.1.4
                                  │ │   │ ├── mkdirp-classic@0.5.3 deduped
                                  │ │   │ ├── pump@3.0.0 deduped
                                  │ │   │ └─┬ tar-stream@2.2.0
                                  │ │   │   ├─┬ bl@4.1.0
                                  │ │   │   │ ├─┬ buffer@5.7.1
                                  │ │   │   │ │ ├── base64-js@1.5.1
                                  │ │   │   │ │ └── ieee754@1.2.1
                                  │ │   │   │ └── readable-stream@3.6.0 deduped
                                  │ │   │   ├── end-of-stream@1.4.4 deduped
                                  │ │   │   ├── fs-constants@1.0.0
                                  │ │   └─┬ tunnel-agent@0.6.0
                                  │ │     └── safe-buffer@5.2.1 deduped
                                  │ ├── @serialport/parser-byte-length@9.0.7
                                  │ ├── @serialport/parser-cctalk@9.0.7
                                  │ ├── @serialport/parser-delimiter@9.0.7
                                  │ ├── @serialport/parser-inter-byte-timeout@9.0.7
                                  │ ├─┬ @serialport/parser-readline@9.0.7
                                  │ │ └── @serialport/parser-delimiter@9.0.7 deduped
                                  │ ├── @serialport/parser-ready@9.0.7
                                  │ ├── @serialport/parser-regex@9.0.7
                                  │ ├─┬ @serialport/stream@9.0.7
                                  ├── source-map-support@0.5.19 deduped
                                  ├─┬ winston@3.3.3
                                  │ ├─┬ @dabh/diagnostics@2.0.2
                                  │ │ ├─┬ colorspace@1.1.2
                                  │ │ │ ├─┬ color@3.0.0
                                  │ │ │ │ ├─┬ color-convert@1.9.3
                                  │ │ │ │ │ └── color-name@1.1.3
                                  │ │ │ │ └─┬ color-string@1.5.5
                                  │ │ │ │   ├── color-name@1.1.3 deduped
                                  │ │ │ │   └─┬ simple-swizzle@0.2.2
                                  │ │ │ │     └── is-arrayish@0.3.2
                                  │ │ │ └── text-hex@1.0.0
                                  │ │ ├── enabled@2.0.0
                                  │ │ └── kuler@2.0.0
                                  │ ├── async@3.2.0
                                  │ ├── is-stream@2.0.0
                                  │ ├─┬ logform@2.2.0
                                  │ │ ├── colors@1.4.0
                                  │ │ ├── fast-safe-stringify@2.0.7
                                  │ │ ├── fecha@4.2.1
                                  │ │ ├── ms@2.1.2 deduped
                                  │ │ └── triple-beam@1.3.0 deduped
                                  │ ├─┬ one-time@1.0.0
                                  │ │ └── fn.name@1.1.0
                                  │ ├─┬ readable-stream@3.6.0
                                  │ │ ├─┬ string_decoder@1.3.0
                                  │ │ │ └── safe-buffer@5.2.1
                                  │ ├── stack-trace@0.0.10
                                  │ ├── triple-beam@1.3.0
                                  │ └─┬ winston-transport@4.4.0
                                  │   ├─┬ readable-stream@2.3.7
                                  └── xstate@4.17.1
                                Adapter-Logfile sieht nicht bessere aus. Nach dem NAK kommt nichts weiter raus.
                                AlCalzoneA tugsiT 2 Antworten Letzte Antwort
                                • A AMagnum
                                  @alcalzone
                                  │ └─┬ debug@4.3.1
                                  │   └── ms@2.1.2
                                  ├─┬ fs-extra@9.1.0
                                  └─┬ zwave-js@6.6.3
                                    │ │ └─┬ lie@3.1.1
                                    │ └── tslib@1.14.1
                                    │ ├── cookie@0.4.1
                                    │ ├── lru_map@0.3.3
                                    │ ├─┬ json5@2.2.0
                                    │ ├─┬ semver@7.3.5
                                    │ ├── moment@2.29.1
                                    │ │ ├── nan@2.14.2
                                    │ │   ├─┬ pump@3.0.0
                                    │ │   ├─┬ rc@1.2.8
                                    │ │   │ ├── ini@1.3.8
                                    │ │   │   ├─┬ bl@4.1.0
                                    ├─┬ winston@3.3.3
                                    │ │ └── kuler@2.0.0
                                    │ ├── async@3.2.0
                                    │ ├─┬ logform@2.2.0
                                    │ │ ├── fecha@4.2.1
                                    └── xstate@4.17.1
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  Das sieht zwar erschreckend aus, ist aber okay so. Kannst du mal eine andere Adapter-Version ausprobieren? Am besten gleich die aktuellste. Adapter stoppen, dann:
                                  cd /opt/iobroker
                                  npm i iobroker.zwave2@latest
                                  iobroker upload zwave2
                                    cd /opt/iobroker
                                    AMagnum
                                    @alcalzone Habe die latest Version (1.9.2) geladen, bleibt aber bei NAK immer noch stehen.
                                    iobroker.zwave2@1.9.2 /opt/iobroker/node_modules/iobroker.zwave2
                                    ├── UNMET DEPENDENCY alcalzone-shared@^3.0.3
                                    └── UNMET DEPENDENCY zwave-js@^7.1.0
                                    npm ERR! missing: @iobroker/adapter-core@^2.4.0, required by iobroker.zwave2@1.9.2
                                    npm ERR! missing: alcalzone-shared@^3.0.3, required by iobroker.zwave2@1.9.2
                                    npm ERR! missing: fs-extra@^9.1.0, required by iobroker.zwave2@1.9.2
                                    npm ERR! missing: zwave-js@^7.1.0, required by iobroker.zwave2@1.9.2
                                    Vielleicht ist ja das RaZberry 2 Modul defekt. Ich habe nun einen Z-Wave USB Stick gekauft, wird demnächst geliefert (Modell Aeotec AEOEZW090-C). Dann nehme ich das RaZberry runter und versuche es mit dem Stick.
                                    Oder gibt es eine simple Methode, um mal etwas an das tty zu Senden und zu Empfangen. Früher hatte ich das mit alten Modemverbindungen gemacht. Da gab es immer so einen AT-Befehlssatz, das waren aber reine ASCII-Schnittstellen, hatte früher mit 300 bit/s angefangen. Oh man, das waren noch Zeiten.
                                    • A AMagnum
                                      @alcalzone
                                      │ └─┬ debug@4.3.1
                                      │   └── ms@2.1.2
                                      ├─┬ fs-extra@9.1.0
                                      └─┬ zwave-js@6.6.3
                                        │ │ └─┬ lie@3.1.1
                                        │ └── tslib@1.14.1
                                        │ ├── cookie@0.4.1
                                        │ ├── lru_map@0.3.3
                                        │ ├─┬ json5@2.2.0
                                        │ ├─┬ semver@7.3.5
                                        │ ├── moment@2.29.1
                                        │ │ ├── nan@2.14.2
                                        │ │   ├─┬ pump@3.0.0
                                        │ │   ├─┬ rc@1.2.8
                                        │ │   │ ├── ini@1.3.8
                                        │ │   │   ├─┬ bl@4.1.0
                                        ├─┬ winston@3.3.3
                                        │ │ └── kuler@2.0.0
                                        │ ├── async@3.2.0
                                        │ ├─┬ logform@2.2.0
                                        │ │ ├── fecha@4.2.1
                                        └── xstate@4.17.1
                                      tugsiT Offline
                                      tugsiT Offline
                                      tugsi
                                      @amagnum
                                      Es gab auch mal ein Beitrag, wo es um den Serialport ging:
                                      https://forum.iobroker.net/topic/6230/zwave-raspberrypi3-und-razberry-zwave-platine/4?_=1617715888271
                                      Lediglich der Serialport muss umkonfiguriert werden:
                                      sudo nano /boot/cmdline.txt
                                      -> console=serial0,115200 entfernen
                                      sudo nano /boot/config.txt
                                      -> folgendes einfügen bzw Auskommentierung entfernen:
                                      dtoverlay=pi3-miniuart-bt
                                      enable_uart=1
                                      force_turbo=1
                                      reboot
                                      Das habe ich bei mir auch drin.
                                      Ist leider schon zu lange her, dass ich mein RazBerry in Betrieb genommen habe, aber da ich in der config.txt die Einträge habe, gehe ich mal davon aus, dass ich das gemacht habe.
                                      Ist allerdings bei mir ein PI3 auch.
                                      • tugsiT tugsi
                                        @amagnum
                                        enable_uart=1
                                        force_turbo=1
                                        reboot
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @tugsi Inzwischen geht das auch per raspi-config meine ich.
                                          AMagnum
                                          @alcalzone ja funktioniert mit sudo raspi-config. Die Einträge in /boot/config.txt und /boot/cmdline.txt sind bei mir auch korrekt. Leider immer noch keine Verbindung zwischen zwave2-Adapter und ttyAMA0.
