  4. Wallbox, PV mit openWB in iobroker einbinden
    2.5k
    4.5k
120 Beiträge 23 Kommentatoren 37.9k Aufrufe 29 Beobachtet
  • madingM mading
    @wolfirr unterhalb, leg‘ einfach deine eigene Ordnerstruktur an.
    W Offline
    W Offline
    Wolfirr
    #81
    @mading endlich konnte ich bei Sonnenschein den Speicher mal wieder richtig betreiben und das Blockly nochmal laufen lassen und testen. Dabei ist mir folgender Debug ausgegeben worden und ich weiß nicht, wo der Fehler liegen kann?
    Danke im Voraus
    Debug Output:
    15.2.2024, 12:55:39.788	[info ]: javascript.0 (1832412) Start javascript script.js.Speicher.SN103
    15.2.2024, 12:55:39.871	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: schedule(cron=* * * * *)
    15.2.2024, 12:55:39.873	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1707994275680,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707994275680}
    15.2.2024, 12:55:39.874	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
    15.2.2024, 12:55:39.875	[error]: javascript.0 (1832412) script.js.Speicher.SN103 Error by subscription (trigger): Wrong ID of type boolean or number.
    15.2.2024, 12:55:39.875	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
    15.2.2024, 12:56:00.049	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getObject(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, enumName=undefined) => {"_id":"fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W","type":"state","common":{"name":"ESS_Minutenwerte 03_Battery_to_Household_in_W","type":"number","role":"value","read":true,"write":false,"custom":{"influxdb.0":{"enabled":true,"storageType":"Number","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000}}},"native":{"Name":"ESS_Minutenwerte","Attribute":"03_Battery_to_Household_in_W","Readings":true,"type":"number","role":"value"},"value":{"val":"0"},"from":"system.adapter.influxdb.0","user":"system.user.admin","ts":1704876495776}
    15.2.2024, 12:56:00.050	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
    15.2.2024, 12:56:00.051	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":1963,"ack":true,"ts":1707998056473,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707998056473}
    15.2.2024, 12:56:00.052	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: setForeignState(id=0_userdata.0.eigeneDatenpunkte.Caterva.SN103.LeistungSN103, state={"val":-1963,"ack":true,"ts":1707998160052,"q":0,"from":"system.adapter.javascript.0","lc":1707998160052,"c":"script.js.Speicher.SN103"})
    15.2.2024, 12:56:00.053	[warn ]: javascript.0 (1832412) script.js.Speicher.SN103: setForeignState(id=0_userdata.0.eigeneDatenpunkte.Caterva.SN103.LeistungSN103, state={"val":-1963,"ack":true,"ts":1707998160052,"q":0,"from":"system.adapter.javascript.0","lc":1707998160052,"c":"script.js.Speicher.SN103"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
    15.2.2024, 12:56:00.055	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
    15.2.2024, 12:56:00.058	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":70,"ack":true,"ts":1707997876082,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1707997876082}
    15.2.2024, 12:56:00.059	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":70,"retain":true}, hasCallback=true)
    15.2.2024, 12:56:20.056	[error]: javascript.0 (1832412) script.js.Speicher.SN103: timeout
    15.2.2024, 12:56:20.058	[error]: javascript.0 (1832412) script.js.Speicher.SN103: timeout
    15.2.2024, 12:57:00.052	[info ]: javascript.0 (1832412) script.js.Speicher.SN103: getObject(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, enumName=undefined) => {"_id":"fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W","type":"state","common":{"name":"ESS_Minutenwerte 03_Battery_to_Household_in_W","type":"number","role":"value","read":true,"write":false,"custom":{"influxdb.0":{"enabled":true,"storageType":"Number","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000}}},"native":{"Name":"ESS_Minutenwerte","Attribute":"03_Battery_to_Household_in_W","Readings":true,"type":"number","role":"value"},"value":{"val":"0"},"from":"system.adapter.influxdb.0","user":"system.user.admin","ts":1704876495776}
    madingM 1 Antwort Letzte Antwort
    • W Wolfirr
      Danke im Voraus
      Debug Output:
      madingM Offline
      madingM Offline
      mading
      #82
      @wolfirr
      Es gibt wohl ein Problem mit 1832412) script.js.Speicher.SN103 Error by subscription (trigger): Wrong ID of type boolean or number.
      Was ist das für ein DP?
      W 1 Antwort Letzte Antwort
      • madingM mading
        @wolfirr
        W Offline
        W Offline
        Wolfirr
        #83
        @mading Hallo Mading, auf was referenziert die '1832412'? Finde dazu keinen Zusammenhang. Habe noch sehen, dass da ein verstecktes Blockly war, dass ich nicht gesehen hatte. Nachdem ich es entfernt habe, kommt nur noch der Timeout:
        21:49:00.568	info	javascript.0 (1832412) Start javascript script.js.Speicher.SN103
        21:49:00.783	info	javascript.0 (1832412) script.js.Speicher.SN103: schedule(cron=* * * * *)
        21:49:00.784	info	javascript.0 (1832412) script.js.Speicher.SN103: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
        21:50:00.056	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
        21:50:00.057	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
        21:50:00.059	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
        21:50:00.061	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
        21:50:00.065	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
        21:50:20.060	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
        21:50:20.065	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
        21:51:00.044	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
        21:51:00.045	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
        21:51:00.047	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
        21:51:00.048	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
        21:51:00.049	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
        21:51:20.047	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
        21:51:20.049	error	javascript.0 (1832412) script.js.Speicher.SN103: timeout
        21:52:00.040	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.03_Battery_to_Household_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708103715789,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103715789}
        21:52:00.040	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.05_PV_to_Battery_in_W, timerId=undefined) => {"val":0,"ack":true,"ts":1708094176184,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708094176184}
        21:52:00.042	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/W","message":"0","retain":true}, hasCallback=true)
        21:52:00.043	info	javascript.0 (1832412) script.js.Speicher.SN103: getState(id=fhem.0.ESS_Minutenwerte.01_SoC_in_Pct, timerId=undefined) => {"val":13,"ack":true,"ts":1708103895547,"q":0,"from":"system.adapter.fhem.0","user":"system.user.admin","lc":1708103895547}
        21:52:00.044	info	javascript.0 (1832412) script.js.Speicher.SN103: sendTo(instance=mqtt.0, cmd=sendMessage2Client, msg={"topic":"openWB/set/houseBattery/%Soc","message":13,"retain":true}, hasCallback=true)
        Wolfirr
        • W Wolfirr
          Wolfirr
          madingM Offline
          madingM Offline
          mading
          #84
          @wolfirr schwer zu sagen. Wie oft schickst du Updates an den Speicher oder fragst ihn ab? Wie ist der Speicher angebunden (WLan/ LAN)?
          • W Offline
            W Offline
            Wolfirr
            #85
            @mading Danke soweit, ich hab noch ein paar Änderungen und Tests durchgeführt, dann die openWB auf V2 upgedated. Jetzt kommen die Daten an der openWB an und werden auch richtig angezeigt. Hoffe, dass nun auch das PV-Überschussladen richtig funktioniert.
            In der V1.9 openWB war anscheinend ein Fehler mit MQTT, da ich immer Schwierigkeiten hatte den Topic richtig zu bezeichnen und die Schreibweise der houseBattery irgendwie nicht korrekt erkannt wurde.
            Die Gerätschaften sind alle per LAN angeschlossen, da bei mir das WLAN schwierig ist mit dauerhafter Verbindung in die verschiedenen Gebäude.
            Herzlichen Dank an eure Unterstützung!
            Wenn jemand Fragen hat, wie man iobroker mit openWB V2.0 anbindet, jetzt hab ich etwas Erfahrung sammel dürfen und kann vielleicht auch helfen.
            • W Wolfirr
              Mar-Bus
              #86
              @wolfirr
              Hallo wolfirr,
              ich bin leider nicht sehr erfahren mit MQTT. Ich bin ebenfalls mit dem iobroker unterwegs und möchte Daten meiner openWB mit dem Softwarestand 2.1.4 auslesen.
              Dazu habe ich den mqtt-client als Adapter heruntergeladen und die ip-Adresse der openWB eingetragen, siehe den Screenshot.
              Leider bekomme ich aber keine Daten unter den Objekten eingelesen. Mir ist allerdings auch nicht klar, wer als MQTT-Broker agiert. Muss ich dazu erst noch einen MQTT-Broker installieren, oder übernimmt das bereits die openWB? Muss in der openWB die Brücke aktiviert werden? Welche Funktion hat diese Brücke?
              Herzliche Dank im Voraus, vielleicht kannst Du mir dazu ein paar Infos geben?
              A 1 Antwort Letzte Antwort
              • M Mar-Bus
                @wolfirr
                Hallo wolfirr,
                A Online
                A Online
                ag
                #87
                @mar-bus
                Hallo.
                Hier https://forum.iobroker.net/topic/43655/wallbox-pv-mit-openwb-in-iobroker-einbinden/64
                habe ich beschrieben wie ich das bei mir gelöst habe.
                Die openWB ist der Mqtt Broker.
                Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
                /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
                js-controller 7.0.6 admin 7.4.10
                M 2 Antworten Letzte Antwort
                • A ag
                  @mar-bus
                  Hallo.
                  Mar-Bus
                  #88
                  @ag
                  Danke für die Info, zwei kurze Fragen:
                  Wenn ich das richtige sehe, hast du sowohl den Broker als auch den Client in deinem iobroker eingerichtet. Werden beide Adapter gebraucht? Oder ist der Broker aus anderen Gründen installiert worden?
                  Die Brücke muss auch eingerichtet werden?
                  Herzliche Grüße
                  • A ag
                    @mar-bus
                    Hallo.
                    Mar-Bus
                    #89
                    @ag
                    Noch eine weitere Frage:
                    ist die Bezeichnung der Brücke im mqtt-client als Class-ID einzutragen, in deinem Beispielen ist die Class-ID "iobr_openwb", während die Brücke in der openWB "ioBroker" lautet, oder sind die Bezeichnungen unabhängig von einander und können beliebig gewählt werden?
                    Danke und Grüße
                    • M Mar-Bus
                      @ag
                      Danke und Grüße
                      A Online
                      A Online
                      ag
                      #90
                      @mar-bus
                      Ich habe auf der OpenWB keine Brücke eingerichtet.
                      Mit MQTT-Explorer kannst du die mal anschauen was die Box ohne Brücke so alles von sich gibt.
                      Den MQTT-Brocker Adapter hat bei mir keinen Bezug zur WB.
                      Die client-ID ist beliebig, muss aber in deinem Netz einmalig sein.
                      • A ag
                        @mar-bus
                        Mar-Bus
                        #91
                        @ag
                        Mit welcher Intention hast Du denn dann die Konfiguration der Brücke geteilt. Nur zur Info?
                        Herzliche Grüße
                        • M Mar-Bus
                          @ag
                          Herzliche Grüße
                          A Online
                          A Online
                          ag
                          #92
                          @mar-bus
                          Du hats mich erwischt :-), da war was aus der alten WB Software mit reingerutscht.
                          Aktuell so eingestellt:
                          • A ag
                            @mar-bus
                            Mar-Bus
                            #93
                            @ag
                            Ok, das macht dann Sinn. Ich habe mir jetzt den mqtt-explorer installiert, dort kann ich sehen, was die openwb published.
                            Leider klappt es mqtt-client-adapter im ioBroker nicht. Unter den Objekten des mqtt-clients werden keine Objekte angezeigt.
                            Irgendeine Idee?
                            • M Mar-Bus
                              @ag
                              Irgendeine Idee?
                              A Online
                              A Online
                              ag
                              #94
                              @mar-bus
                              Die Objekte die du brauchst musst du selbst anlegen und konfigurieren.
                              Beispiele hier:
                              • A ag
                                @mar-bus
                                Beispiele hier:
                                Mar-Bus
                                #95
                                @ag
                                Danke für die Hinweise, ich bin jetzt auf einem anderen Wege zum Erfolg gekommen.
                                Ich habe den mqtt-Broker/Client-Adapter installiert. Dann habe ich die Verbindungsdaten zur openWB als Client eingepflegt.
                                Im nächsten Schritt habe ich unter den Client Settings nur die Subscribe Pattern eingepflegt, die für mich interessant sind. Dabei hat der mqtt-explorer mir gute Dienste erwiesen.
                                Im letzten Schritt habe ich dann unter MQTT Einstellungen die Maske zum Bekanntgeben eigener States geleert, damit wird anscheinend wohl ein Publishing in Richtung openWB vermieden. Ich hatte davor immer Fehlermeldungen im Protokoll, weil Fehler beim Subsriben und Publishen auftraten.
                                Ein anderer Weg, aber dieser scheint jetzt zu funktionieren.
                                Danke für die Hilfe.
                                • M Mar-Bus
                                  @ag
                                  madingM Offline
                                  madingM Offline
                                  mading
                                  #96
                                  @mar-bus sagte in Wallbox, PV mit openWB in iobroker einbinden:
                                  @ag
                                  So funktioniert es auch problemlos mit owb 1.x. Hat jemand eine liste der wichtigsten topics zum lesen und setzen oder ggf. schon blockly gebaut? Bin noch auf 1.x und die läuft mit meinen Blockly gut. Im openwb Forum ist alles sehr stark verteilt und kaum/ nicht dokumentiert.
                                  L 1 Antwort Letzte Antwort
                                    MB11
                                    #97
                                    @lesiflo hallo
                                    habe soeben eine Verbindung mit dem MQTT Adapter alles ist grün aber bekomme keine Objekte angezeigt was mache ich falsch ?
                                    bin neu hier und habe schon einiges gelesen und ausprobiert aber komme nicht weiter bin erst am Anfang mit allem :)
                                    habe auch schon openWB installiert der Ordner ist auf dem Pi aber wie nutze ich die Daten dann im IObroker ? habe kein plan ?
                                    • madingM mading
                                      @ag
                                      L Online
                                      L Online
                                      lesiflo
                                      schrieb am zuletzt editiert von lesiflo
                                      #98
                                      @mading Schau mal hier Link Text
                                      • M MB11
                                        @lesiflo hallo
                                        L Online
                                        L Online
                                        lesiflo
                                        #99
                                        @mb11 Wie sind denn eine Einstellungen im mqtt Adapter?
                                        • L lesiflo
                                          madingM Offline
                                          madingM Offline
                                          mading
                                          #100
                                          @lesiflo sagte in Wallbox, PV mit openWB in iobroker einbinden:
                                          Danke, ich meine die 2.x
