  4. ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung
140 Beiträge 8 Kommentatoren 23.0k Aufrufe 4 Beobachtet
  • G Offline
    GOETSCHHOFER
    Hallo crunchip,
    habe heute backitup zur Datensicherung auf meine Fritzbox 7590 für meine RSPPI3+ installiert.
    Nur bekomme ich leider bei NAS eine Fehlermeldung und die Daten sind im backup-Ordner auf der Fritzbox nicht vorhanden.
    Danke für deine Hilfe.
    LG
    Karl
    Gestartet...
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
    Retrying with upper case share name
    mount error(6): No such device or address
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
    [DEBUG] [iobroker] - host.raspberrypi 4777 states saved
    [DEBUG] [iobroker] - host.raspberrypi 5033 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-17_58_42_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 22MB so far...
    [DEBUG] [influxDB] - Packed 38MB so far...
    [DEBUG] [influxDB] - Packed 57MB so far...
    [DEBUG] [influxDB] - Packed 73MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-17_58_58_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    MOD-Edit: Code in code-tags gesetzt!
    J 1 Antwort Letzte Antwort
    • G GOETSCHHOFER
      Hallo crunchip,
      LG
      Karl
      Gestartet...
      Jan1
      @goetschhofer
      Dein Mount zur Fritz funktioniert nicht. Zeig mal wie Du das eingetragen hast und selbst als Anfänger gilt, Logs werden in Code Tags gepostet und nicht einfach rein kopiert.
      G 1 Antwort Letzte Antwort
      • J Jan1
        @goetschhofer
        GOETSCHHOFER
        @jan1
        Hallo Jan,
        sorry, dies habe ich leider in der Eile übersehen.
        Jetzt schreibt er zwar eine Datei in den Backupordner in der Fritzbox, aber ich bekomme ich noch immer eine Fehlermeldung ?.
        Danke für die Hilfe.
        LG
        Karl
        Started iobroker ...
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-18_17_54_backupiobroker.tar.gz
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_03_27-18_18_10_backupiobroker"
        backup: copy: read /opt/iobroker/backups/influxDB_2021_03_27-18_18_10_backupiobroker/meta.00: input/output error
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 0
        Thomas BraunT J 2 Antworten Letzte Antwort
        • G GOETSCHHOFER
          @jan1
          Hallo Jan,
          LG
          Karl
          [EXIT] 0
          @goetschhofer
          SMB 1.0 sollte nicht mehr verwendet werden. Hier läuft das mit SMB 3.1.1 und einer Fritzbox.
          • G GOETSCHHOFER
            @jan1
            Hallo Jan,
            LG
            Karl
            [EXIT] 0
            Jan1
            @goetschhofer
            In den Backups Ordner schreibt er immer, wenn der rest nicht geht ;)
            Dein Pfad ist wohl falsch. Zuerst steht der Freigabe Name dann kommt der Pfad. Schau mal was Du in der Fritz hier drin stehen hast:
            crunchipC G 2 Antworten Letzte Antwort
            • J Jan1
              @goetschhofer
              crunchipC Offline
              crunchipC Offline
              @jan1
              @goetschhofer sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
              sein Influx hat nicht funktioniert
              @GOETSCHHOFER zeig mal die Einstellung von Influx
                @jan1
                Jan1
                @crunchip
                Genau das sollte doch dann das Backup vom Backups Ordner auf das NAS schieben.
                • J Jan1
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  @jan1 hat er doch gemacht, das backup vom iobroker, nur das influx nicht, daher passt sein cifs Pfad, nur die Einstellung von Influx ist noch falsch
                    Jan1
                    @crunchip
                    Mir brauchst nix erklären, da das bei mir schon immer läuft ;)
                    Hab mich stur an die Anleitung gehalten und siehe da, macht schön sein Geschäftchen auf die SSD an der Fritz :)
                    • J Jan1
                      @goetschhofer
                      GOETSCHHOFER
                      @Thomas-Braun: Habe es auch mit SMB 3.1.1 probiert, aber auch eine Fehlermeldung.
                      @jan1: Habe es jetzt mal mit dem Pfad der Netzwerkfreigabe probiert, aber ich bekomme auch eine Fehlermeldung.
                      @crunchip: Einstellungen influxdb
                      Danke für eure UntEINSTELLUNGEN INFLUXDB.JPG erstützung.
                      LG
                      Karl
                      HEIMNETZFREIGABE-FRITZBOX-7590-27.3.2021.JPG ```
                      [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/FRITZ.NAS/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
                      mount error(2): No such file or directory
                      [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/FRITZ.NAS/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-19_08_59_backupiobroker.tar.gz
                      [DEBUG] [influxDB] - Packed 26MB so far...
                      [DEBUG] [influxDB] - Packed 76MB so far...
                      [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-19_09_19_backupiobroker.tar.gz
                      • G GOETSCHHOFER
                        LG
                        Karl
                        crunchipC Offline
                        crunchipC Offline
                        ich meinte die Einstellung im Backitup Adapter für Influx
                        Dein cifs hatte doch oben gepasst, smb3 musst du in der fritzbox aktivieren, nicht nur im Adapter, dann klappt das auch
                        J G HomoranH 3 Antworten Letzte Antwort
                          Jan1
                          @crunchip
                          SMB3 kannst in der Fritz nicht aktivieren, nur SMB1 weil 3 ab 7.24 eh aktiv ist ;)
                          @GOETSCHHOFER
                          Dein Pfad hatte wohl doch gestimmt. Ich vergesse gerne, dass der Freigabe Name default FRITZ.NAS ist.
                          Hat Dein angelegter User die Berechtigung auf das NAS zu schrieben?
                          • J Jan1
                            @crunchip
                            @GOETSCHHOFER
                            crunchipC Offline
                            crunchipC Offline
                            @jan1 sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
                            stimmt, allerdings hab ich noch v7.21 (7490), ich habs auf smb3.0 im Adapter stehen, die beiden höheren habe ich noch nicht probiert.
                              GOETSCHHOFER
                              schrieb am zuletzt editiert von GOETSCHHOFER
                              @crunchip
                              @Jan1
                              @Homoran
                              Dies wär jetzt meine Frage gewesen, wo ich SMBv3 finde, denn man kann nur SMBv1 einstellen.
                              Dieser Punkt hat sich damit erledigt.
                              Ja, der User iobroker_backitup hat die Berechtigung lesen/schreiben.
                                @GOETSCHHOFER
                                Bitte den Screenshot vom richtigen Adadpter!
                                @crunchip sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
                                • G GOETSCHHOFER
                                  @crunchip
                                  @Jan1
                                  @Homoran
                                  Jan1
                                  @goetschhofer
                                  Dann fällt mir nichts mehr ein, was falsch sein könnte.
                                  • J Jan1
                                    @goetschhofer
                                    GOETSCHHOFER
                                    @jan1
                                    @crunchip
                                    Ich habe es jetzt über FTP versucht und da hat er bei der InfluxDB keine Fehlermeldung erzeugt.
                                    Weiters habe ich Grafana und Javaskript zum backup ergänzt, nur hier dürften die Einstellungen noch nicht korrekt sein.
                                    Was muss man denn bei Javaskript hier einstellen ?
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-21_18_29_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-21_18_48_backupiobroker.tar.gz
                                    [DEBUG] [grafana] - Start Grafana Backup ...
                                    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                    [DEBUG] [grafana] - Created dashboard directory
                                    [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                    [DEBUG] [grafana] - Created datasource directory
                                    [DEBUG] [grafana] - start Grafana request ...
                                    [DEBUG] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http http:80
                                    [DEBUG] [grafana] - Grafana is not available!
                                    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                    [DEBUG] [grafana] - Grafana Backup cannot created ...
                                    [DEBUG] [grafana] - done
                                    [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
                                    [DEBUG] [javascripts] - done
                                    [DEBUG] [ftp] - FTP connected.
                                    [DEBUG] [ftp] - Send iobroker_2021_03_27-21_18_29_backupiobroker.tar.gz
                                    [DEBUG] [ftp] - Send influxDB_2021_03_27-21_18_48_backupiobroker.tar.gz
                                    [DEBUG] [ftp] - Send javascripts_2021_03_27-21_20_07_backupiobroker.tar.gz
                                    [ERROR] [ftp] - File "/opt/iobroker/backups/javascripts_2021_03_27-21_20_07_backupiobroker.tar.gz" not found
                                    [DEBUG] [ftp] - done
                                    [EXIT] 0
                                    crunchipC RolfMR 2 Antworten Letzte Antwort
                                    • G GOETSCHHOFER
                                      @jan1
                                      @crunchip
                                      [EXIT] 0
                                      crunchipC Offline
                                      crunchipC Offline
                                      den Pfad, den du in deiner javascript Instanz angegeben hast
                                      falls noch nicht geschehen, kannst du z.b. folgenden Pfad nehmen
                                      /home/mirrorscript.0
                                      zu Grafana
                                      nur die IP eintragen, der Port steht doch rechts
                                      • G GOETSCHHOFER
                                        @jan1
                                        @crunchip
                                        [EXIT] 0
                                        RolfMR Offline
                                        RolfMR Offline
                                        RolfM
                                        schrieb am zuletzt editiert von RolfM
                                        @goetschhofer sorry wenn ich mich hier einmische aber ich würde halt nur das s ichern und einstellen was du auch wirklich hast. Bei mir sieht das so aus, ich sichere problemlos per FTP auf ein QNAP-NAS.
                                        • RolfMR RolfM
                                          crunchipC Offline
                                          crunchipC Offline
                                          @rolfm sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
                                          macht er doch, iobroker, grafana und influx
                                          RolfMR 1 Antwort Letzte Antwort
