  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    2.6k
    4.7k
    4.0k
2.4k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
    @marchusar
    bei Kia kenn ich mich nich aus, ist das mit ccNC Infotainment? was bedeutet (vor FL) ???
    marchusar
    #1921
    @neuschwansteini Vor Facelift, also noch das alte Entertainment System.
      @marchusar
      Schick mal bitte die Langfassung von iob diag .
      marchusar
      schrieb am zuletzt editiert von marchusar
      #1922
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      * Some output is masked. For full results please use 'iob diag --unmask' *
      Press any key to continue
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: raspberrypi4
             Icon name: computer
      Operating System: Raspbian GNU/Linux 12 (bookworm)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
      OS is similar to: debian
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       16:20:36 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-04-30 16:20:36 CEST
                 Universal time: Wed 2025-04-30 14:20:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            4.0G        1.7G        1.5G        1.1M        1.0G        2.3G
      Swap:           209M          0B        209M
      Total:          4.2G        1.7G        1.7G
      Active iob-Instances: 	19
               3837 M total memory
               1647 M used memory
                449 M active memory
               1820 M inactive memory
               1397 M free memory
                295 M buffer memory
                662 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 16:20:37 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
      Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 22.2 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3837.7 total,   1396.7 free,   1648.8 used,    957.9 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2189.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                    Type      Size  Used Avail Use% Mounted on
      /dev/root                     ext4      917G   16G  865G   2% /
      devtmpfs                      devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs                         tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs                         tmpfs     768M  928K  767M   1% /run
      tmpfs                         tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1                     vfat      253M   49M  204M  20% /boot
      //192.168.178.5/Data/ioBroker cifs      3.6T  3.1T  567G  85% /opt/iobroker/backups
      tmpfs                         tmpfs     384M     0  384M   0% /run/user/1000
      Show mounted filesystems:
      TARGET                  SOURCE                        FSTYPE OPTIONS
      /                       /dev/sda2                     ext4   rw,noatime
      |-/boot                 /dev/sda1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/opt/iobroker/backups //192.168.178.5/Data/ioBroker cifs   rw,relatime,vers=3.0,cache=strict,username=marc,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.5,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      3.8G	/var/
      2.4G	/var/log/journal/416a7ba8464c4fd4b4fcb0daf197cbfb
      2.4G	/var/log
      665M	/var/lib
      Archived and active journals take up 2.3G in the file system.
      /opt/iobroker/backups:
      285M	/opt/iobroker/backups/
      20K	/opt/iobroker/backups/cert
      0	/opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      1.4G	/opt/iobroker/iobroker-data/
      831M	/opt/iobroker/iobroker-data/files
      617M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      23M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
      17M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.e96554dd.chunk.js.map
      8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.19.1
      /usr/bin/node 		v20.19.1
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.31.0
      nodejs:
        Installed: 20.19.1-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
       *** 20.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2+rpi1 500
              500 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 3045397)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.6.3
      javascript: 	8.8.3
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : raspberrypi4                             -  enabled, port: 11443, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
        system.adapter.bluelink.0               : bluelink              : raspberrypi4                             -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi4                             - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
        system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
      + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
        system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4                             - disabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4                             -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi4                             -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
      + system.adapter.radar2.0                 : radar2                : raspberrypi4                             -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
        system.adapter.sayit.0                  : sayit                 : raspberrypi4                             - disabled
        system.adapter.sayit.1                  : sayit                 : raspberrypi4                             - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4                             - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi4                             -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4                             - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 11444, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : raspberrypi4                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4                             -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "bluelink"     : 2.3.6    , installed 3.1.2
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "synochat"     : 1.3.3    , installed 1.3.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
      Objects and States
      Objects: 	4326
      States: 	3542
      Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm InRelease
      Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15423      931/dnsmasq
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13750      924/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       23465327   7089/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19535      2327/io.sonoff.0
      tcp        0      0 192.168.178.6:12001     0.0.0.0:*               LISTEN      1001       19761      2406/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15040      856/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15035      856/iobroker.js-con
      tcp        0      0 192.168.178.6:12010     0.0.0.0:*               LISTEN      1001       18305      2537/io.hm-rpc.1
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10403573   13791/io.admin.0
      tcp6       0      0 :::11443                :::*                    LISTEN      1001       23463646   6962/io.admin.1
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10394353   12831/io.web.1
      tcp6       0      0 :::11444                :::*                    LISTEN      1001       23463849   7041/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15404      924/sshd: /usr/sbin
      udp        0      0 0.0.0.0:47941           0.0.0.0:*                           108        13544      477/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18362      2657/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18363      2657/io.tuya.0
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15422      931/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       16377      2315/io.radar2.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15419      931/dnsmasq
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13542      477/avahi-daemon: r
      udp6       0      0 :::51335                :::*                                108        13545      477/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13543      477/avahi-daemon: r
      2025-04-30 16:17:36.147  - error: bluelink.0 (26380) Error: The state contains the forbidden properties day, time!
          at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
          at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
          at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
          at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:133:30)
          at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21)
          at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
          at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
      2025-04-30 16:17:36.148  - error: bluelink.0 (26380) The state contains the forbidden properties day, time!
      2025-04-30 16:17:36.640  - info: bluelink.0 (26380) terminating
      2025-04-30 16:17:36.650  - warn: bluelink.0 (26380) get state error: Connection is closed.
      2025-04-30 16:17:36.656  - warn: bluelink.0 (26380) get state error: Connection is closed.
      2025-04-30 16:17:36.664  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
      2025-04-30 16:17:36.666  - warn: bluelink.0 (26380) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.breakOilStatus: DB closed
      2025-04-30 16:17:36.667  - warn: bluelink.0 (26380) get state error: Connection is closed.
      2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
      2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
      2025-04-30 16:17:36.672  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.remoteWaitingTimeAlert": Connection is closed.
      2025-04-30 16:17:36.848  - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-04-30 16:17:36.848  - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
      2025-04-30 16:17:36.849  - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
      2025-04-30 16:20:00.015  - info: javascript.0 (2234) script.js.common.Kia.Update_from_Server: Refresh vehicle status from Server.
      iob diag has finished.
      ? Meister MopperM 2 Antworten Letzte Antwort
      • M marchusar
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 3837 M total memory
                 1647 M used memory
                  449 M active memory
                 1397 M free memory
                  295 M buffer memory
                  662 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        3.8G	/var/
        2.4G	/var/log
        665M	/var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.6.3
        javascript: 	8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	4326
        States: 	3542
        Pending Updates: 0
        #1923
        @marchusar probier dann mal die Stable 2.3.6, bzw 2.3.7 die sind mit dem alten Infotainment gut gelaufen.
        Darauf achten, dass die Daten vom Server geholt werden, sonst zieht's dir die 12V leer...
          marchusar
          #1924
          @neuschwansteini Die 3.1.0 läuft bei mir einwandfrei. Nur die 3.1.1 und 3.1.2 laufen nicht. Und ich hatte mich auf die Streckendaten gefreut, die nun wieder drin sein sollen
          ? 1 Antwort Letzte Antwort
          • M marchusar
            #1925
            @marchusar
            achsooooooooooooooooooooo...
            na, das ist noch im Dev... das kann dauern.. kommt drauf an, wie @arteck Zeit und Lust hat..
              @marchusar
              marchusar
              #1926
              @neuschwansteini Wäre schön ... es schreiben halt ein paar, dass es bei denen läuft nachdem sie PIN und Passwort neu gesetzt haben - das habe ich schon versucht... dann bleibe ich bei 3.1.0 bis ich was anderes lese ...
              • M marchusar
                ```bash
                Script v.2025-02-23
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Swap:           209M          0B        209M
                         3837 M total memory
                         1647 M used memory
                          449 M active memory
                         1397 M free memory
                          295 M buffer memory
                          662 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                *** FILESYSTEM ***
                /var:
                3.8G	/var/
                2.4G	/var/log
                665M	/var/lib
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm 		10.8.2
                /usr/bin/npx 		10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin: 		7.6.3
                javascript: 	8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	4326
                States: 	3542
                Pending Updates: 0
                Meister MopperM Online
                Meister Mopper
                #1927
                @marchusar
                Ich habe einen Niro EV '22 und bleibe auch erstmal bei der v3.1.0 im stable, weil die nachfolgenden Versionen noch nicht verlässlich funktionieren.
                Mit der v3.1.0 bekomme ich zumindest von den Kia-Servern mehr oder weniger regelmäßig Daten (Kia ist offenbar ständig am basteln). Das Fzg steuern kann ich jedoch mit der v3.1.0 zuverlässig.
                Hat zwar vermutlich nichts mit deinem Problem zu tun, aber:
                Warum fährst du auf dem RPI4 ein 32-Bit System?
                Warum sind zwei Admin installiert?
                Wozu verwendest du den web.1?
                Das solltest du anpassen:
                HINT:
                /dev/ttyACM0
                Proxmox und HA - dank KI/AI endlich "blocklyfrei"
                • M marchusar
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #1928
                  @marchusar sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                  installier mal die GIT
                  https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck
                  im LOG wird jetzt ein error mit dem anfange PARSECHECK stehen..
                  poste mal die Zeilen vor dem abbruch.. vielleicht kann ich da schon was sehen
                  sonst
                  brauch ich deine Login Daten . das Problem ist mir bekannt aber ich kann es nicht nachstellen da mein PHEV in diesen Teil des sources nicht reinläuft..
                  die und pin nicht vergessen
                  @Neuschwansteini FL = FaceLift
                  MaBu59M M 3 Antworten Letzte Antwort
                  • arteckA arteck
                    sonst
                    MaBu59M Offline
                    MaBu59M Offline
                    MaBu59
                    schrieb am zuletzt editiert von MaBu59
                    #1929
                    @arteck
                    Ich verfolge schon länger die Posts hier. Bei mir läuft auch nur die Version 3.1.0, Ich habe den Adapter kompett gelöscht und mit deiner URL frisch installiert.
                    Das sind die Zeilen aus dem Log.
                    Ich hoffe, sie helfen dir weiter.
                    Den Adapter finde ich richtig toll. Danke für deinen unermüdlichen Einsatz SUPER!!
                    Manfred
                    2025-05-02 18:57:13.468 - info: host.iobroker-pi iobroker url https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck --host iobroker-pi --debug
                    2025-05-02 18:57:15.779 - info: host.iobroker-pi iobroker install Newan/ioBroker.bluelink#parsecheck
                    2025-05-02 18:57:16.119 - info: host.iobroker-pi iobroker NPM version: 10.8.2
                    2025-05-02 18:57:16.121 - info: host.iobroker-pi iobroker Installing Newan/ioBroker.bluelink#parsecheck... (System call)
                    2025-05-02 18:57:27.369 - info: host.iobroker-pi iobroker
                    2025-05-02 18:57:27.370 - info: host.iobroker-pi iobroker removed 120 packages, and changed 1 package in 11s
                    2025-05-02 18:57:27.372 - info: host.iobroker-pi iobroker 280 packages are looking for funding run `npm fund` for details
                    2025-05-02 18:57:27.464 - info: host.iobroker-pi iobroker upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
                    2025-05-02 18:57:27.479 - info: host.iobroker-pi iobroker upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
                    2025-05-02 18:57:27.492 - info: host.iobroker-pi iobroker Updating objects from io-package.json for adapter "bluelink" with version "3.1.2"
                    2025-05-02 18:57:28.547 - info: host.iobroker-pi iobroker exit 0
                    2025-05-02 18:58:01.723 - info: host.iobroker-pi iobroker add bluelink auto --host iobroker-pi --debug
                    2025-05-02 18:58:04.052 - info: host.iobroker-pi iobroker host.iobroker-pi create instance bluelink
                    2025-05-02 18:58:04.066 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.alive created
                    2025-05-02 18:58:04.074 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.connected created
                    2025-05-02 18:58:04.082 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.compactMode created
                    2025-05-02 18:58:04.089 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cpu created
                    2025-05-02 18:58:04.097 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cputime created
                    2025-05-02 18:58:04.104 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapUsed created
                    2025-05-02 18:58:04.114 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapTotal created
                    2025-05-02 18:58:04.124 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memRss created
                    2025-05-02 18:58:04.132 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.uptime created
                    2025-05-02 18:58:04.141 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.inputCount created
                    2025-05-02 18:58:04.147 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.outputCount created
                    2025-05-02 18:58:04.155 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.eventLoopLag created
                    2025-05-02 18:58:04.162 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.sigKill created
                    2025-05-02 18:58:04.172 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.logLevel created
                    2025-05-02 18:58:04.178 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info created
                    2025-05-02 18:58:04.184 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info.connection created
                    2025-05-02 18:58:04.190 - info: host.iobroker-pi iobroker host.iobroker-pi Set default value of bluelink.0.info.connection: false
                    2025-05-02 18:58:04.206 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0 created
                    2025-05-02 18:58:05.250 - info: host.iobroker-pi iobroker exit 0
                    2025-05-02 18:58:08.043 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3381411
                    2025-05-02 18:58:10.920 - info: bluelink.0 (3381411) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                    2025-05-02 18:58:10.947 - error: bluelink.0 (3381411) Check Settings. No Username set
                    2025-05-02 19:01:47.770 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 (force=false, process=true)
                    2025-05-02 19:01:47.780 - info: bluelink.0 (3381411) Got terminate signal TERMINATE_YOURSELF
                    2025-05-02 19:01:47.782 - info: bluelink.0 (3381411) Adapter bluelink cleaned up everything...
                    2025-05-02 19:01:47.783 - info: bluelink.0 (3381411) terminating
                    2025-05-02 19:01:47.784 - info: bluelink.0 (3381411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-05-02 19:01:47.819 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 send kill signal
                    2025-05-02 19:01:48.286 - info: bluelink.0 (3381411) terminating
                    2025-05-02 19:01:48.345 - info: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-05-02 19:01:52.136 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3386355
                    2025-05-02 19:01:54.595 - info: bluelink.0 (3386355) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                    2025-05-02 19:01:54.625 - info: bluelink.0 (3386355) Login to api
                    2025-05-02 19:01:57.529 - info: bluelink.0 (3386355) 1 Vehicles found
                    2025-05-02 19:01:58.384 - info: bluelink.0 (3386355) Read new update for KNACT811XXXXXXXXX from the server
                    2025-05-02 19:01:58.783 - error: bluelink.0 (3386355) PARSECHECK [object Object] coord [object Object]
                    2025-05-02 19:01:58.934 - error: bluelink.0 (3386355) PARSECHECK [object Object] speed [object Object]
                    2025-05-02 19:01:59.034 - error: bluelink.0 (3386355) PARSECHECK [object Object] accuracy [object Object]
                    2025-05-02 19:01:59.082 - error: bluelink.0 (3386355) PARSECHECK [object Object] vehicleLocation [object Object]
                    2025-05-02 19:01:59.430 - error: bluelink.0 (3386355) PARSECHECK [object Object] doorOpen [object Object]
                    2025-05-02 19:01:59.638 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:01:59.990 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc1 [object Object]
                    2025-05-02 19:02:00.111 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc2 [object Object]
                    2025-05-02 19:02:00.215 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc3 [object Object]
                    2025-05-02 19:02:00.278 - error: bluelink.0 (3386355) PARSECHECK [object Object] atc [object Object]
                    2025-05-02 19:02:00.279 - error: bluelink.0 (3386355) PARSECHECK [object Object] remainTime2 [object Object]
                    2025-05-02 19:02:00.394 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:00.498 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:02:00.499 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:02:00.726 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:02:00.727 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:02:00.977 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:02:01.075 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfo [object Object]
                    2025-05-02 19:02:01.190 - error: bluelink.0 (3386355) PARSECHECK [object Object] starttime [object Object]
                    2025-05-02 19:02:01.290 - error: bluelink.0 (3386355) PARSECHECK [object Object] endtime [object Object]
                    2025-05-02 19:02:01.291 - error: bluelink.0 (3386355) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                    2025-05-02 19:02:01.342 - error: bluelink.0 (3386355) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                    2025-05-02 19:02:01.513 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:02:01.514 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:02:01.779 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:02:01.886 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:02:01.887 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:02:01.888 - error: bluelink.0 (3386355) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                    2025-05-02 19:02:02.023 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:02:02.025 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                    at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:140:34)
                    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:25)
                    2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                    2025-05-02 19:02:02.046 - info: bluelink.0 (3386355) Adapter bluelink cleaned up everything...
                    2025-05-02 19:02:02.047 - info: bluelink.0 (3386355) terminating
                    2025-05-02 19:02:02.051 - warn: bluelink.0 (3386355) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-05-02 19:02:02.063 - error: bluelink.0 (3386355) PARSECHECK [object Object] ect [object Object]
                    2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:02.065 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:02.066 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                    2025-05-02 19:02:02.202 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:02.301 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:02:02.302 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:02:02.350 - error: bluelink.0 (3386355) PARSECHECK [object Object] dte [object Object]
                    2025-05-02 19:02:02.553 - info: bluelink.0 (3386355) terminating
                    2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.evModeRange.[object Object]
                    2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error: Connection is closed.
                    2025-05-02 19:02:02.566 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:02.568 - error: bluelink.0 (3386355) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                    2025-05-02 19:02:02.570 - error: bluelink.0 (3386355) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                    2025-05-02 19:02:02.619 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-05-02 19:02:02.620 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                    2025-05-02 19:02:33.340 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3387262
                    2025-05-02 19:02:35.793 - info: bluelink.0 (3387262) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                    2025-05-02 19:02:35.822 - info: bluelink.0 (3387262) Login to api
                    2025-05-02 19:02:37.874 - info: bluelink.0 (3387262) 1 Vehicles found
                    2025-05-02 19:02:38.224 - info: bluelink.0 (3387262) Read new update for KNACT811XXXXXXXXX from the server
                    2025-05-02 19:02:38.516 - error: bluelink.0 (3387262) PARSECHECK [object Object] coord [object Object]
                    2025-05-02 19:02:38.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] speed [object Object]
                    2025-05-02 19:02:38.621 - error: bluelink.0 (3387262) PARSECHECK [object Object] accuracy [object Object]
                    2025-05-02 19:02:38.624 - error: bluelink.0 (3387262) PARSECHECK [object Object] vehicleLocation [object Object]
                    2025-05-02 19:02:38.775 - error: bluelink.0 (3387262) PARSECHECK [object Object] doorOpen [object Object]
                    2025-05-02 19:02:38.837 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:02:39.033 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc1 [object Object]
                    2025-05-02 19:02:39.081 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc2 [object Object]
                    2025-05-02 19:02:39.129 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc3 [object Object]
                    2025-05-02 19:02:39.177 - error: bluelink.0 (3387262) PARSECHECK [object Object] atc [object Object]
                    2025-05-02 19:02:39.178 - error: bluelink.0 (3387262) PARSECHECK [object Object] remainTime2 [object Object]
                    2025-05-02 19:02:39.230 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:02:39.511 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:02:39.520 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfo [object Object]
                    2025-05-02 19:02:39.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] starttime [object Object]
                    2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] endtime [object Object]
                    2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                    2025-05-02 19:02:39.629 - error: bluelink.0 (3387262) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                    2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:02:39.828 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:02:39.834 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:02:39.835 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:02:39.836 - error: bluelink.0 (3387262) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                    2025-05-02 19:02:39.889 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:02:39.891 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.893 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.894 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.898 - info: bluelink.0 (3387262) Adapter bluelink cleaned up everything...
                    2025-05-02 19:02:39.900 - info: bluelink.0 (3387262) terminating
                    2025-05-02 19:02:39.901 - warn: bluelink.0 (3387262) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-05-02 19:02:39.911 - error: bluelink.0 (3387262) PARSECHECK [object Object] ect [object Object]
                    2025-05-02 19:02:39.913 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:02:39.914 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.918 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.919 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                    2025-05-02 19:02:39.993 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:02:40.045 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                    2025-05-02 19:02:40.164 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:02:40.327 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                    2025-05-02 19:02:40.374 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfos [object Object]
                    2025-05-02 19:02:40.403 - info: bluelink.0 (3387262) terminating
                    2025-05-02 19:02:40.415 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                    2025-05-02 19:02:40.416 - error: bluelink.0 (3387262) Error: Connection is closed.
                    2025-05-02 19:02:40.418 - error: bluelink.0 (3387262) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                    2025-05-02 19:02:40.421 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                    2025-05-02 19:02:40.422 - error: bluelink.0 (3387262) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                    2025-05-02 19:02:40.472 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-05-02 19:02:40.472 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                    2025-05-02 19:03:11.070 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3388073
                    2025-05-02 19:03:13.585 - info: bluelink.0 (3388073) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                    2025-05-02 19:03:13.614 - info: bluelink.0 (3388073) Login to api
                    2025-05-02 19:03:15.038 - info: bluelink.0 (3388073) 1 Vehicles found
                    2025-05-02 19:03:15.320 - info: bluelink.0 (3388073) Read new update for KNACT811XXXXXXXXX from the server
                    2025-05-02 19:03:15.617 - error: bluelink.0 (3388073) PARSECHECK [object Object] coord [object Object]
                    2025-05-02 19:03:15.673 - error: bluelink.0 (3388073) PARSECHECK [object Object] speed [object Object]
                    2025-05-02 19:03:15.722 - error: bluelink.0 (3388073) PARSECHECK [object Object] accuracy [object Object]
                    2025-05-02 19:03:15.726 - error: bluelink.0 (3388073) PARSECHECK [object Object] vehicleLocation [object Object]
                    2025-05-02 19:03:15.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] doorOpen [object Object]
                    2025-05-02 19:03:15.942 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:03:16.094 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc1 [object Object]
                    2025-05-02 19:03:16.141 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc2 [object Object]
                    2025-05-02 19:03:16.188 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc3 [object Object]
                    2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] atc [object Object]
                    2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] remainTime2 [object Object]
                    2025-05-02 19:03:16.290 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:03:16.442 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:03:16.443 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:03:16.551 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:03:16.559 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfo [object Object]
                    2025-05-02 19:03:16.614 - error: bluelink.0 (3388073) PARSECHECK [object Object] starttime [object Object]
                    2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] endtime [object Object]
                    2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                    2025-05-02 19:03:16.665 - error: bluelink.0 (3388073) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                    2025-05-02 19:03:16.765 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                    2025-05-02 19:03:16.766 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                    2025-05-02 19:03:16.872 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                    2025-05-02 19:03:16.880 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                    2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                    2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                    2025-05-02 19:03:16.933 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:03:16.934 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:03:16.936 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                    2025-05-02 19:03:16.937 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                    2025-05-02 19:03:16.941 - info: bluelink.0 (3388073) Adapter bluelink cleaned up everything...
                    2025-05-02 19:03:16.942 - info: bluelink.0 (3388073) terminating
                    2025-05-02 19:03:16.943 - warn: bluelink.0 (3388073) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2025-05-02 19:03:16.946 - error: bluelink.0 (3388073) PARSECHECK [object Object] ect [object Object]
                    2025-05-02 19:03:16.947 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2025-05-02 19:03:16.948 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                    2025-05-02 19:03:16.949 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                    2025-05-02 19:03:16.950 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                    2025-05-02 19:03:17.008 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:03:17.061 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                    2025-05-02 19:03:17.162 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                    2025-05-02 19:03:17.213 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                    2025-05-02 19:03:17.214 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                    2025-05-02 19:03:17.217 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                    2025-05-02 19:03:17.221 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfos [object Object]
                    2025-05-02 19:03:17.445 - info: bluelink.0 (3388073) terminating
                    2025-05-02 19:03:17.462 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batteryPower.[object Object]
                    2025-05-02 19:03:17.463 - error: bluelink.0 (3388073) Error: Connection is closed.
                    2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] batteryPower [object Object]
                    2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] evStatus [object Object]
                    2025-05-02 19:03:17.468 - error: bluelink.0 (3388073) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                    2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.[object Object]
                    2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                    2025-05-02 19:03:17.524 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-05-02 19:03:17.524 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                    2025-05-02 19:03:17.524 - warn: host.iobroker-pi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                    • arteckA arteck
                      sonst
                      MaBu59M Offline
                      MaBu59M Offline
                      MaBu59
                      #1930
                      @arteck
                      Ich glaube, ich habe dir zu viele Zeilen gesendet. War mein erster Versuch. Sorry!!
                      • MaBu59M MaBu59
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #1931
                        @mabu59 der knallt bei
                        reserveChargeInfo2
                        was immer da auch drin steht .. ich brauch die Login Daten..sonst wird das nix
                        • arteckA arteck
                          sonst
                          marchusar
                          #1932
                          @arteck
                          Sorry, war nicht am PC - hier jetzt die Log:
                          2025-05-04 15:53:55.158 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23102
                          2025-05-04 15:53:59.236 - info: bluelink.0 (23102) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                          2025-05-04 15:53:59.266 - info: bluelink.0 (23102) Login to api
                          2025-05-04 15:54:01.542 - info: bluelink.0 (23102) 1 Vehicles found
                          2025-05-04 15:54:01.674 - info: bluelink.0 (23102) Read new update for KNAC381xxx from the server
                          2025-05-04 15:54:01.984 - error: bluelink.0 (23102) PARSECHECK [object Object] coord [object Object]
                          2025-05-04 15:54:02.008 - error: bluelink.0 (23102) PARSECHECK [object Object] speed [object Object]
                          2025-05-04 15:54:02.021 - error: bluelink.0 (23102) PARSECHECK [object Object] accuracy [object Object]
                          2025-05-04 15:54:02.027 - error: bluelink.0 (23102) PARSECHECK [object Object] vehicleLocation [object Object]
                          2025-05-04 15:54:02.111 - error: bluelink.0 (23102) PARSECHECK [object Object] doorOpen [object Object]
                          2025-05-04 15:54:02.134 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:02.220 - error: bluelink.0 (23102) PARSECHECK [object Object] etc1 [object Object]
                          2025-05-04 15:54:02.232 - error: bluelink.0 (23102) PARSECHECK [object Object] etc2 [object Object]
                          2025-05-04 15:54:02.285 - error: bluelink.0 (23102) PARSECHECK [object Object] etc3 [object Object]
                          2025-05-04 15:54:02.298 - error: bluelink.0 (23102) PARSECHECK [object Object] atc [object Object]
                          2025-05-04 15:54:02.299 - error: bluelink.0 (23102) PARSECHECK [object Object] remainTime2 [object Object]
                          2025-05-04 15:54:02.318 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:02.375 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:02.376 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:02.407 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                          2025-05-04 15:54:02.408 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                          2025-05-04 15:54:02.478 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:02.490 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                          2025-05-04 15:54:02.491 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                          2025-05-04 15:54:02.492 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfo [object Object]
                          2025-05-04 15:54:02.517 - error: bluelink.0 (23102) PARSECHECK [object Object] starttime [object Object]
                          2025-05-04 15:54:02.575 - error: bluelink.0 (23102) PARSECHECK [object Object] endtime [object Object]
                          2025-05-04 15:54:02.576 - error: bluelink.0 (23102) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                          2025-05-04 15:54:02.585 - error: bluelink.0 (23102) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                          2025-05-04 15:54:02.655 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                          2025-05-04 15:54:02.656 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                          2025-05-04 15:54:02.727 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:02.737 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                          2025-05-04 15:54:02.738 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                          2025-05-04 15:54:02.739 - error: bluelink.0 (23102) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                          2025-05-04 15:54:02.806 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-05-04 15:54:02.807 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.810 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.810 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.821 - info: bluelink.0 (23102) Adapter bluelink cleaned up everything...
                          2025-05-04 15:54:02.824 - info: bluelink.0 (23102) terminating
                          2025-05-04 15:54:02.825 - warn: bluelink.0 (23102) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2025-05-04 15:54:02.830 - error: bluelink.0 (23102) PARSECHECK [object Object] ect [object Object]
                          2025-05-04 15:54:02.831 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-05-04 15:54:02.832 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.833 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.834 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                          2025-05-04 15:54:02.927 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:02.939 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:02.940 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:02.947 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                          2025-05-04 15:54:02.976 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:02.991 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:02.992 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:02.998 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                          2025-05-04 15:54:03.004 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfos [object Object]
                          2025-05-04 15:54:03.035 - error: bluelink.0 (23102) PARSECHECK [object Object] batteryPower [object Object]
                          2025-05-04 15:54:03.036 - error: bluelink.0 (23102) PARSECHECK [object Object] evStatus [object Object]
                          2025-05-04 15:54:03.173 - error: bluelink.0 (23102) PARSECHECK [object Object] tirePressureLamp [object Object]
                          2025-05-04 15:54:03.194 - error: bluelink.0 (23102) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                          2025-05-04 15:54:03.201 - error: bluelink.0 (23102) PARSECHECK [object Object] battery [object Object]
                          2025-05-04 15:54:03.217 - error: bluelink.0 (23102) PARSECHECK [object Object] stopLamp [object Object]
                          2025-05-04 15:54:03.247 - error: bluelink.0 (23102) PARSECHECK [object Object] headLamp [object Object]
                          2025-05-04 15:54:03.328 - info: bluelink.0 (23102) terminating
                          2025-05-04 15:54:03.396 - warn: bluelink.0 (23102) get state error: Connection is closed.
                          2025-05-04 15:54:03.425 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                          2025-05-04 15:54:03.427 - warn: bluelink.0 (23102) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightFrontLamp: DB closed
                          2025-05-04 15:54:03.428 - warn: bluelink.0 (23102) get state error: Connection is closed.
                          2025-05-04 15:54:03.429 - error: bluelink.0 (23102) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                          2025-05-04 15:54:03.430 - error: bluelink.0 (23102) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                          2025-05-04 15:54:03.430 - error: bluelink.0 (23102) PARSECHECK [object Object] turnSignalLamp [object Object]
                          2025-05-04 15:54:03.431 - error: bluelink.0 (23102) PARSECHECK [object Object] lampWireStatus [object Object]
                          2025-05-04 15:54:03.435 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen": Connection is closed.
                          2025-05-04 15:54:03.684 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2025-05-04 15:54:03.685 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                          2025-05-04 15:54:34.900 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23155
                          2025-05-04 15:54:38.281 - info: bluelink.0 (23155) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                          2025-05-04 15:54:38.315 - info: bluelink.0 (23155) Login to api
                          2025-05-04 15:54:41.016 - info: bluelink.0 (23155) 1 Vehicles found
                          2025-05-04 15:54:41.199 - info: bluelink.0 (23155) Read new update for KNAC381xxx from the server
                          2025-05-04 15:54:41.518 - error: bluelink.0 (23155) PARSECHECK [object Object] coord [object Object]
                          2025-05-04 15:54:41.538 - error: bluelink.0 (23155) PARSECHECK [object Object] speed [object Object]
                          2025-05-04 15:54:41.595 - error: bluelink.0 (23155) PARSECHECK [object Object] accuracy [object Object]
                          2025-05-04 15:54:41.602 - error: bluelink.0 (23155) PARSECHECK [object Object] vehicleLocation [object Object]
                          2025-05-04 15:54:41.639 - error: bluelink.0 (23155) PARSECHECK [object Object] doorOpen [object Object]
                          2025-05-04 15:54:41.665 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:41.747 - error: bluelink.0 (23155) PARSECHECK [object Object] etc1 [object Object]
                          2025-05-04 15:54:41.805 - error: bluelink.0 (23155) PARSECHECK [object Object] etc2 [object Object]
                          2025-05-04 15:54:41.818 - error: bluelink.0 (23155) PARSECHECK [object Object] etc3 [object Object]
                          2025-05-04 15:54:41.833 - error: bluelink.0 (23155) PARSECHECK [object Object] atc [object Object]
                          2025-05-04 15:54:41.834 - error: bluelink.0 (23155) PARSECHECK [object Object] remainTime2 [object Object]
                          2025-05-04 15:54:41.885 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:41.935 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:41.936 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                          2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                          2025-05-04 15:54:42.035 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:42.046 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                          2025-05-04 15:54:42.047 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                          2025-05-04 15:54:42.048 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfo [object Object]
                          2025-05-04 15:54:42.069 - error: bluelink.0 (23155) PARSECHECK [object Object] starttime [object Object]
                          2025-05-04 15:54:42.082 - error: bluelink.0 (23155) PARSECHECK [object Object] endtime [object Object]
                          2025-05-04 15:54:42.083 - error: bluelink.0 (23155) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                          2025-05-04 15:54:42.091 - error: bluelink.0 (23155) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                          2025-05-04 15:54:42.115 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                          2025-05-04 15:54:42.116 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                          2025-05-04 15:54:42.186 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                          2025-05-04 15:54:42.200 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                          2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                          2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                          2025-05-04 15:54:42.266 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-05-04 15:54:42.267 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.269 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.270 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.275 - info: bluelink.0 (23155) Adapter bluelink cleaned up everything...
                          2025-05-04 15:54:42.276 - info: bluelink.0 (23155) terminating
                          2025-05-04 15:54:42.278 - warn: bluelink.0 (23155) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2025-05-04 15:54:42.282 - error: bluelink.0 (23155) PARSECHECK [object Object] ect [object Object]
                          2025-05-04 15:54:42.284 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-05-04 15:54:42.285 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.286 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.287 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                          2025-05-04 15:54:42.357 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:42.380 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                          2025-05-04 15:54:42.447 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                          2025-05-04 15:54:42.460 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                          2025-05-04 15:54:42.461 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                          2025-05-04 15:54:42.469 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                          2025-05-04 15:54:42.475 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfos [object Object]
                          2025-05-04 15:54:42.553 - error: bluelink.0 (23155) PARSECHECK [object Object] batteryPower [object Object]
                          2025-05-04 15:54:42.554 - error: bluelink.0 (23155) PARSECHECK [object Object] evStatus [object Object]
                          2025-05-04 15:54:42.656 - error: bluelink.0 (23155) PARSECHECK [object Object] tirePressureLamp [object Object]
                          2025-05-04 15:54:42.679 - error: bluelink.0 (23155) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                          2025-05-04 15:54:42.686 - error: bluelink.0 (23155) PARSECHECK [object Object] battery [object Object]
                          2025-05-04 15:54:42.699 - error: bluelink.0 (23155) PARSECHECK [object Object] stopLamp [object Object]
                          2025-05-04 15:54:42.774 - error: bluelink.0 (23155) PARSECHECK [object Object] headLamp [object Object]
                          2025-05-04 15:54:42.780 - info: bluelink.0 (23155) terminating
                          2025-05-04 15:54:42.791 - warn: bluelink.0 (23155) get state error: Connection is closed.
                          2025-05-04 15:54:42.800 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                          2025-05-04 15:54:42.803 - warn: bluelink.0 (23155) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftFrontLamp: DB closed
                          2025-05-04 15:54:42.805 - warn: bluelink.0 (23155) get state error: Connection is closed.
                          2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                          2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                          2025-05-04 15:54:42.814 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                          2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                          2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                          2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] turnSignalLamp [object Object]
                          2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] lampWireStatus [object Object]
                          2025-05-04 15:54:43.003 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2025-05-04 15:54:43.003 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because
                            @marchusar
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/ttyACM0
                            marchusar
                            schrieb am zuletzt editiert von marchusar
                            #1933
                            @meister-mopper
                            Bei mir läuft u.a. die Homematic nicht, wenn ich auf 64bit umstelle. Gerade nochmal versucht...
                            Mein Zigbee läuft und bietet den Direktlink in der Config selbst so an. Auch hier hatte ich mit dem by-id Link schon mal Schwierigkeiten und seitdem ich es so nutze läuft es stabil.
                            Die je 2 Instanzen sind für lokalen Zugriff ohne Passwort und externen Zugriff mit SSL und Passwort. Das funktioniert auch einwandfrei.
                            • arteckA arteck
                              reserveChargeInfo2
                              marchusar
                              #1934
                              @arteck
                              meine reserveChargeInfo2 aus der 3.1.0 :
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                #1935
                                neue Version 3.1.3 ist unterwegs.. habe paar Fehler behoben..
                                und ich hätte mal hier
                                https://github.com/Newan/ioBroker.bluelink/tarball/bluelinky9
                                eine Version zum Testen ür alle die das neue System im Auto haben .. wo der ccs2Status Knoten weg fallen würde und die Infos ganz normal zur Verfügung stehen würden wie früher.. unter vehicleStatus ..
                                der ccs2Status Knoten würde dann nicht mehr aktualisiert..und könnte manuell gelöscht werden...
                                Peter V.P MaBu59M ? 3 Antworten Letzte Antwort
                                • arteckA arteck
                                  Peter V.P Offline
                                  Peter V.P Offline
                                  Peter V.
                                  #1936
                                  @arteck said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Mit dieser Version sind bei mir die (seltenen) Fehlermeldungen wieder weg und Maps läuft auch wieder.
                                  Kia Ceed BJ 2024
                                  Top, danke
                                  • arteckA arteck
                                    MaBu59M Offline
                                    MaBu59M Offline
                                    MaBu59
                                    #1937
                                    @arteck
                                    Diese Version erzeugt bei mir auch keine Fehlermeldungen mehr und läuft!!
                                    Siehst Du eine Chance, den "ccs2Status" ans Laufen zu bringen oder ist der Aufwand zu hoch?
                                    Danke für Deinen Einsatz!!
                                    • MaBu59M MaBu59
                                      @arteck
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #1938
                                      @mabu59 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                      was meinst du ???
                                      MaBu59M 1 Antwort Letzte Antwort
                                      • arteckA arteck
                                        #1939
                                        @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                        gerade mal getestet, sieht genauso aus wie die normale 3.1.3 .. nur mit einem Fehler beim Starten:
                                        bluelink.0
                                        2025-05-06 08:35:42.388	error	TypeError: Cannot read properties of undefined (reading 'airCtrlOn') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:620:46) at Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:392:28) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:298:21)
                                        hatte ich vorher gemacht, ist jetzt wieder da.. ?
                                        Ist die Version auch eine 3.1.3 ?
                                        • arteckA arteck
                                          was meinst du ???
                                          MaBu59M Offline
                                          MaBu59M Offline
                                          MaBu59
                                          #1940
                                          @arteck
                                          Du hast geschrieben "wo der ccs2Status Knoten weg fallen würde".
                                          Ich verstehe das so, ohne den Knoten funktioniert der Adapter, mit dem Knoten nicht.
                                          Der Knoten müßte angepasst werden, damit der Adapter funktioniert.
                                          Ich habe vermutet, dass der Aufwand dafür sehr hoch ist.
