  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.8k
2.5k Beiträge 163 Kommentatoren 1.3m Aufrufe 150 Beobachtet
    @ilovegym
    danke für die schnelle Antwort
    Ich verstehe, dass es so aussieht als wäre die API grade nicht da, ich habe das Problem aber immer. Ich habe es sofort danach per Blue Link App probiert und es funktionierte ohne Probleme:
    Ich habe es auch jetzt nochmal getestet, das Problem bleibt bestehen:
    2023-01-07 17:18:26.698 - info: bluelink.0 (746776) Login to api
    2023-01-07 17:18:30.898 - info: bluelink.0 (746776) 1 Vehicles found
    2023-01-07 17:18:53.526 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
    2023-01-07 17:18:53.575 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
    2023-01-07 17:18:53.623 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
    2023-01-07 17:18:53.671 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
    2023-01-07 17:18:53.740 - info: bluelink.0 (746776) State value to set for "bluelink.0.KMHKR81XXXXXXXXXX.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
    2023-01-07 17:19:30.685 - info: bluelink.0 (746776) Starting clima for vehicle
    2023-01-07 17:19:30.868 - error: bluelink.0 (746776) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-01-07 17:19:30.869 - error: bluelink.0 (746776) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
    2023-01-07 17:19:30.870 - error: bluelink.0 (746776) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
    at U (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:11700)
    at G. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
    at Generator.throw ()
    at a (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
    at processTicksAndRejections (internal/process/task_queues.js:95:5)
    2023-01-07 17:19:30.871 - error: bluelink.0 (746776) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"8eedf86c-2516-4759-be49-01d593e5886b"}
    2023-01-07 17:19:30.882 - info: bluelink.0 (746776) Adapter bluelink cleaned up everything...
    2023-01-07 17:19:30.883 - info: bluelink.0 (746776) terminating
    2023-01-07 17:19:30.885 - warn: bluelink.0 (746776) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-01-07 17:19:31.433 - error: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-01-07 17:19:31.434 - info: host.raspberrypi Restart adapter system.adapter.bluelink.0 because enabled
    @Michaelnorge Wo finde ich den Button "jqui-icon toggle" =) ?
    Ich klicke mich fleißig durch das iobroker UI, finde ihn aber nicht.
    arteckA Offline
    arteckA Offline
    arteck
    #781
    @williwilliwilli
    installier bitte die GIT version.. du scheinst was älteres da zu haben
      stefan.cloer
      #782
      Hallo zusammen, wenn ich manuell auf die letzte GIT Version update funktioniert bei mir der Adapter leider gar nicht mehr. In der Instanz-Liste wird nur noch folgendes angezeigt
      Im LOG ist vom Bluelink Adapter gar nichts zu sehen nur der Host Adapter spukt folgendes aus
      Kann mir jemand sagen wo das Problem liegen könnte?
      tugsiT 1 Antwort Letzte Antwort
      • S stefan.cloer
        tugsiT Offline
        tugsiT Offline
        tugsi
        #783
        @stefan-cloer sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
        Merkwürdig, hast Du einen alten JS-Controller installiert?
        Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
        • tugsiT tugsi
          stefan.cloer
          #784
          Nein, der Javascript Controller ist Version 6.1.4
          • S stefan.cloer
            arteckA Offline
            arteckA Offline
            arteck
            #785
            @stefan-cloer was hat den javascript mit dem js-controller zu un ??
            bitte die ausgabe von
            iob diag
            • arteckA Offline
              arteckA Offline
              arteck
              #786
              ich habe eine version zum testen da ich es nicht kann auf GIT
              https://github.com/Newan/ioBroker.bluelink/tarball/heating_number
              unter heating sollten jetzt zahlen eingebbar sein
              und dann schauen obs tut
              evtl. Datenpunkt löschen der wird dann neu erzeugt
              in zuge dessen auch die Temperatur.. irgendwie hab ich das geühl das es F ist und nicht C
              ? 3 Antworten Letzte Antwort
              • arteckA arteck
                #787
                @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                Guten Morgen,
                startet bei mir leider nicht:
                2023-01-11 09:17:34.239  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3666387
                2023-01-11 09:17:34.366  - error: host.iobrokerS Caught by controller[0]: /opt/iobroker/node_modules/iobroker.bluelink/main.js:99
                2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:                     let airTempF = (airTempC.val × 9/5) + 32;
                2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]: SyntaxError: Invalid or unexpected token
                2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at Object.compileFunction (node:vm:360:18)
                2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1094:15)
                2023-01-11 09:17:34.367  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1129:27)
                2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32)
                2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                2023-01-11 09:17:34.368  - error: host.iobrokerS Caught by controller[0]:     at node:internal/main/run_main_module:22:47
                2023-01-11 09:17:34.368  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2023-01-11 09:17:34.369  - info: host.iobrokerS Restart adapter system.adapter.bluelink.0 because enabled
                2023-01-11 09:17:37.395  - info: tuya.0 (3639062) bf51aaad135aa1ced0dhmw: Error on Reconnect (3): connect EHOSTUNREACH 10.1.12.101:6668
                2023-01-11 09:17:42.722  - info: host.iobrokerS "system.adapter.bluelink.0" disabled
                • arteckA arteck
                  #788
                  @arteck die Temp ist im Original von der bluelinkapp diese 02H0 die im Adapter irgendwo umgerechnet werden..
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #789
                    @ilovegym jetzt, guck nochmal
                    ? 1 Antwort Letzte Antwort
                    • arteckA arteck
                      #790
                      @arteck nee haengt jetzt in ner rebuild-schleife, versucht es 3x, bricht dann ab.
                      2023-01-11 09:41:52.409  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3696947
                      2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
                      2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       throw err;
                      2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       ^
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
                      2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
                      2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/package.json',
                      2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
                      2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]: }
                      2023-01-11 09:41:52.907  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2023-01-11 09:41:52.907  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      hab dann im Verzeichnis node_modules/iobroker.bluelink das manuell angestossen:
                      ilovegym@iobrokerS /opt/iobroker/node_modules/iobroker.bluelink $ npm install --production
                      npm WARN config production Use `--omit=dev` instead.
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      added 137 packages, and audited 138 packages in 20s
                      6 packages are looking for funding
                        run `npm fund` for details
                      2 moderate severity vulnerabilities
                      Some issues need review, and may require choosing
                      a different dependency.
                      Run `npm audit` for details.
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #791
                        @ilovegym
                        nochmal bitte
                        • arteckA arteck
                          @ilovegym
                          nochmal bitte
                          #792
                          @ilovegym
                          nochmal bitte
                          jetzt kommt das:
                          2023-01-11 10:10:17.367  - info: host.iobrokerS "system.adapter.bluelink.0" enabled
                          2023-01-11 10:10:17.416  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3730679
                          2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
                          2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]:       throw err;
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:       ^
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
                          2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                          2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
                          2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/bluelinky/package.json',
                          2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
                          2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]: }
                          2023-01-11 10:10:17.867  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2023-01-11 10:10:17.867  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          2023-01-11 10:10:18.662  - info: lightcontrol.0 (3668) [ Controller ] Reaching, Group="BueroOGB" Property="actualLux" NewVal="5", OldVal="5"
                          2023-01-11 10:10:23.419  - info: host.iobrokerS "system.adapter.bluelink.0" disabled
                            @ilovegym
                            nochmal bitte
                            jetzt kommt das:
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #793
                            @ilovegym ok nimm wieder das orginal
                            muss ich später schauen
                            • arteckA arteck
                              #794
                              @arteck ok kein thema!
                              der ging auch nicht, kam auch dieser Fehler, musste erst den Adapter komplett loeschen, dann aus dem latest installieren, der wollte starten, kam aber immer der Fehler dass die Sprache DE nicht unterstuetzt wird, obwohl ich EN eingestellt habe... ?
                              2023-01-11 10:33:07.025  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3758144
                              2023-01-11 10:33:07.806  - debug: bluelink.0 (3758144) Redis Objects: Use Redis connection: 10.10.2.10:6379
                              2023-01-11 10:33:07.826  - debug: bluelink.0 (3758144) Objects client ready ... initialize now
                              2023-01-11 10:33:07.828  - debug: bluelink.0 (3758144) Objects create System PubSub Client
                              2023-01-11 10:33:07.829  - debug: bluelink.0 (3758144) Objects create User PubSub Client
                              2023-01-11 10:33:08.245  - debug: bluelink.0 (3758144) Objects client initialize lua scripts
                              2023-01-11 10:33:08.249  - debug: bluelink.0 (3758144) Objects connected to redis: 10.10.2.10:6379
                              2023-01-11 10:33:08.300  - debug: bluelink.0 (3758144) Redis States: Use Redis connection: 10.10.2.10:6379
                              2023-01-11 10:33:08.306  - debug: bluelink.0 (3758144) States create System PubSub Client
                              2023-01-11 10:33:08.307  - debug: bluelink.0 (3758144) States create User PubSub Client
                              2023-01-11 10:33:08.317  - debug: bluelink.0 (3758144) States connected to redis: 10.10.2.10:6379
                              2023-01-11 10:33:08.470  - info: bluelink.0 (3758144) starting. Version 2.2.6 (non-npm: Newan/ioBroker.bluelink#heating_number) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.0, js-controller: 4.0.24
                              2023-01-11 10:33:08.496  - info: bluelink.0 (3758144) Login to api
                              2023-01-11 10:33:08.498  - error: bluelink.0 (3758144) Error in login/on function
                              2023-01-11 10:33:08.499  - error: bluelink.0 (3758144) The language code DE is not managed. Only cs, da, nl, en, fi, fr, de, it, pl, hu, no, sk, es, sv are.
                              Bin dann auf den letzten Snapshot zurueck, hatte ja vorher einen gemacht..
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #795
                                @ilovegym
                                ahh sehr gut
                                kannst nochmal schauen
                                • arteckA arteck
                                  @ilovegym
                                  ahh sehr gut
                                  #796
                                  @ilovegym
                                  ahh sehr gut
                                  ja, jetzt kommt auch nur das
                                  2023-01-11 11:35:06.470  - info: bluelink.0 (56583) starting. Version 2.2.6 (non-npm: Newan/ioBroker.bluelink#heating_number) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.0, js-controller: 4.0.24
                                  2023-01-11 11:35:06.518  - info: bluelink.0 (56583) Login to api
                                  2023-01-11 11:35:06.520  - error: bluelink.0 (56583) Error in login/on function
                                  2023-01-11 11:35:06.520  - error: bluelink.0 (56583) The language code DE is not managed. Only cs, da, nl, en, fi, fr, de, it, pl, hu, no, sk, es, sv are.
                                  ich habs auf EN stehen.. der Adapter gibt sonst keine Meldungen aus, auch nicht auf debug, und reagiert nicht auf force_refresh oder sonstwas..
                                    @ilovegym
                                    ahh sehr gut
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #797
                                    @ilovegym kannst du den ändern..speichern und nochmal ändern.. ich glaube du hast da was falsches in den alten einstellungen
                                    ahh gefunden ..habs in master korrigiert aber incht in meiner änderung..
                                    instalier mal neu
                                    ? 2 Antworten Letzte Antwort
                                    • arteckA arteck
                                      instalier mal neu
                                      #798
                                      @arteck ah, da hatte ich schon die Instanz geloescht.. aber nicht schlimm, nochmal runtergeladen, installiert, jetzt kommt kein Fehler beim Login, Objekte werden angelegt.
                                      Hab versucht mal die clima zu starten kommt das:
                                      2023-01-11 11:58:44.385  - error: bluelink.0 (81824) ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/notifications/register - {"retCode":"F","resCode":"9999","resMsg":"Undefined Error - Response timeout","msgId":"e9101f46-6bfe-46f5-adb0-cff1ac87ae40"}
                                      2023-01-11 11:58:44.386  - error: bluelink.0 (81824) Please logout in the app and relogin in the app
                                      hab ich gemacht was da stand, jetzt gehts :-)
                                      super, danke!!
                                      • arteckA arteck
                                        instalier mal neu
                                        #799
                                        @arteck ich teste heute mittag noch das setzen der einzelnen Werte, erstmal was futtern jetzt...
                                        • arteckA arteck
                                          #800
                                          alsoooo der Datenpunkt wurde mit 0 angelegt, ich habe alle 4 Werte durchprobiert, es schaltete sich nur die Clima und Frontscheibenheizung an, lt App ( im I5 sass ich jetzt nicht), in der App waren auf der Remote-Seite alle Haken gesetzt, und in der Status Anzeige nach einem Refresh nur Clima und Frontscheibe aktiv...
                                          Habs nicht geschafft vom iobroker die Lenkradheizung und Heckscheibe anzuwerfen.. kann aber auch daran liegen, dass das Fahrzeug schon vorgeheizt war... vor ner Stunde.. und da ist die Intelligence vom Auto selbst ja schlauer und startet das nicht nochmal.. so zumindest meine Erfahrung... muss morgen / spaeter nochmal testen...
                                          Vielleicht noch jemand dabei ?
                                          Fehler kommen auf jeden Fall keine mehr, auch die Sprache funktioniert und bleibt jetzt auf Deutsch.
