  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
2.5k Beiträge 163 Kommentatoren 1.3m Aufrufe 150 Beobachtet
  • arteckA arteck
    @ilovegym jetzt, guck nochmal
    #790
    @arteck nee haengt jetzt in ner rebuild-schleife, versucht es 3x, bricht dann ab.
    2023-01-11 09:41:52.409  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3696947
    2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
    2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       throw err;
    2023-01-11 09:41:52.903  - error: host.iobrokerS Caught by controller[0]:       ^
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
    2023-01-11 09:41:52.904  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
    2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
    2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-01-11 09:41:52.906  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.bluelink/node_modules/bluelinky/package.json',
    2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
    2023-01-11 09:41:52.907  - error: host.iobrokerS Caught by controller[0]: }
    2023-01-11 09:41:52.907  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-01-11 09:41:52.907  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    hab dann im Verzeichnis node_modules/iobroker.bluelink das manuell angestossen:
    ilovegym@iobrokerS /opt/iobroker/node_modules/iobroker.bluelink $ npm install --production
    npm WARN config production Use `--omit=dev` instead.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    added 137 packages, and audited 138 packages in 20s
    6 packages are looking for funding
      run `npm fund` for details
    2 moderate severity vulnerabilities
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
      arteckA Offline
      arteckA Offline
      arteck
      #791
      @ilovegym
      nochmal bitte
      • arteckA arteck
        @ilovegym
        nochmal bitte
        #792
        @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
        @ilovegym
        nochmal bitte
        jetzt kommt das:
        2023-01-11 10:10:17.367  - info: host.iobrokerS "system.adapter.bluelink.0" enabled
        2023-01-11 10:10:17.416  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3730679
        2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]: node:internal/modules/cjs/loader:408
        2023-01-11 10:10:17.865  - error: host.iobrokerS Caught by controller[0]:       throw err;
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:       ^
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/bluelinky/dist/index.js'. Please verify that the package.json has a valid "main" entry
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at tryPackage (node:internal/modules/cjs/loader:400:19)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:841:27)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:103:18)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:4:19)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1165:14)
        2023-01-11 10:10:17.866  - error: host.iobrokerS Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
        2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1043:32) {
        2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
        2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   path: '/opt/iobroker/node_modules/bluelinky/package.json',
        2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]:   requestPath: 'bluelinky'
        2023-01-11 10:10:17.867  - error: host.iobrokerS Caught by controller[0]: }
        2023-01-11 10:10:17.867  - error: host.iobrokerS instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2023-01-11 10:10:17.867  - info: host.iobrokerS Rebuild for adapter system.adapter.bluelink.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        2023-01-11 10:10:18.662  - info: lightcontrol.0 (3668) [ Controller ] Reaching, Group="BueroOGB" Property="actualLux" NewVal="5", OldVal="5"
        2023-01-11 10:10:23.419  - info: host.iobrokerS "system.adapter.bluelink.0" disabled
          @ilovegym
          nochmal bitte
          jetzt kommt das:
          arteckA Offline
          arteckA Offline
          arteck
          #793
          @ilovegym ok nimm wieder das orginal
          https://github.com/Newan/ioBroker.bluelink
          muss ich später schauen
          • arteckA arteck
            #794
            @arteck ok kein thema!
            der ging auch nicht, kam auch dieser Fehler, musste erst den Adapter komplett loeschen, dann aus dem latest installieren, der wollte starten, kam aber immer der Fehler dass die Sprache DE nicht unterstuetzt wird, obwohl ich EN eingestellt habe... ?
            2023-01-11 10:33:07.025  - info: host.iobrokerS instance system.adapter.bluelink.0 started with pid 3758144
            2023-01-11 10:33:07.806  - debug: bluelink.0 (3758144) Redis Objects: Use Redis connection: 10.10.2.10:6379
            2023-01-11 10:33:07.826  - debug: bluelink.0 (3758144) Objects client ready ... initialize now
            2023-01-11 10:33:07.828  - debug: bluelink.0 (3758144) Objects create System PubSub Client
            2023-01-11 10:33:07.829  - debug: bluelink.0 (3758144) Objects create User PubSub Client
            2023-01-11 10:33:08.245  - debug: bluelink.0 (3758144) Objects client initialize lua scripts
            2023-01-11 10:33:08.249  - debug: bluelink.0 (3758144) Objects connected to redis: 10.10.2.10:6379
            2023-01-11 10:33:08.300  - debug: bluelink.0 (3758144) Redis States: Use Redis connection: 10.10.2.10:6379
            2023-01-11 10:33:08.306  - debug: bluelink.0 (3758144) States create System PubSub Client
            2023-01-11 10:33:08.307  - debug: bluelink.0 (3758144) States create User PubSub Client
            2023-01-11 10:33:08.317  - debug: bluelink.0 (3758144) States connected to redis: 10.10.2.10:6379
            2023-01-11 10:33:08.470  - info: bluelink.0 (3758144) starting. Version 2.2.6 (non-npm: Newan/ioBroker.bluelink#heating_number) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.0, js-controller: 4.0.24
            2023-01-11 10:33:08.496  - info: bluelink.0 (3758144) Login to api
            2023-01-11 10:33:08.498  - error: bluelink.0 (3758144) Error in login/on function
            2023-01-11 10:33:08.499  - error: bluelink.0 (3758144) The language code DE is not managed. Only cs, da, nl, en, fi, fr, de, it, pl, hu, no, sk, es, sv are.
            Bin dann auf den letzten Snapshot zurueck, hatte ja vorher einen gemacht..
              arteckA Offline
              arteckA Offline
              arteck
              #795
              @ilovegym
              ahh sehr gut
              kannst nochmal schauen
              • arteckA arteck
                @ilovegym
                ahh sehr gut
                #796
                @ilovegym
                ahh sehr gut
                ja, jetzt kommt auch nur das
                2023-01-11 11:35:06.470  - info: bluelink.0 (56583) starting. Version 2.2.6 (non-npm: Newan/ioBroker.bluelink#heating_number) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.0, js-controller: 4.0.24
                2023-01-11 11:35:06.518  - info: bluelink.0 (56583) Login to api
                2023-01-11 11:35:06.520  - error: bluelink.0 (56583) Error in login/on function
                2023-01-11 11:35:06.520  - error: bluelink.0 (56583) The language code DE is not managed. Only cs, da, nl, en, fi, fr, de, it, pl, hu, no, sk, es, sv are.
                ich habs auf EN stehen.. der Adapter gibt sonst keine Meldungen aus, auch nicht auf debug, und reagiert nicht auf force_refresh oder sonstwas..
                  @ilovegym
                  ahh sehr gut
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #797
                  @ilovegym kannst du den ändern..speichern und nochmal ändern.. ich glaube du hast da was falsches in den alten einstellungen
                  ahh gefunden ..habs in master korrigiert aber incht in meiner änderung..
                  instalier mal neu
                  ? 2 Antworten Letzte Antwort
                  • arteckA arteck
                    instalier mal neu
                    #798
                    @arteck ah, da hatte ich schon die Instanz geloescht.. aber nicht schlimm, nochmal runtergeladen, installiert, jetzt kommt kein Fehler beim Login, Objekte werden angelegt.
                    Hab versucht mal die clima zu starten kommt das:
                    2023-01-11 11:58:44.385  - error: bluelink.0 (81824) ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/spa/notifications/register - {"retCode":"F","resCode":"9999","resMsg":"Undefined Error - Response timeout","msgId":"e9101f46-6bfe-46f5-adb0-cff1ac87ae40"}
                    2023-01-11 11:58:44.386  - error: bluelink.0 (81824) Please logout in the app and relogin in the app
                    hab ich gemacht was da stand, jetzt gehts :-)
                    super, danke!!
                    • arteckA arteck
                      instalier mal neu
                      #799
                      @arteck ich teste heute mittag noch das setzen der einzelnen Werte, erstmal was futtern jetzt...
                      • arteckA arteck
                        ich habe eine version zum testen da ich es nicht kann auf GIT
                        https://github.com/Newan/ioBroker.bluelink/tarball/heating_number
                        unter heating sollten jetzt zahlen eingebbar sein
                        und dann schauen obs tut
                        evtl. Datenpunkt löschen der wird dann neu erzeugt
                        in zuge dessen auch die Temperatur.. irgendwie hab ich das geühl das es F ist und nicht C
                        #800
                        alsoooo der Datenpunkt wurde mit 0 angelegt, ich habe alle 4 Werte durchprobiert, es schaltete sich nur die Clima und Frontscheibenheizung an, lt App ( im I5 sass ich jetzt nicht), in der App waren auf der Remote-Seite alle Haken gesetzt, und in der Status Anzeige nach einem Refresh nur Clima und Frontscheibe aktiv...
                        Habs nicht geschafft vom iobroker die Lenkradheizung und Heckscheibe anzuwerfen.. kann aber auch daran liegen, dass das Fahrzeug schon vorgeheizt war... vor ner Stunde.. und da ist die Intelligence vom Auto selbst ja schlauer und startet das nicht nochmal.. so zumindest meine Erfahrung... muss morgen / spaeter nochmal testen...
                        Vielleicht noch jemand dabei ?
                        Fehler kommen auf jeden Fall keine mehr, auch die Sprache funktioniert und bleibt jetzt auf Deutsch.
                        • arteckA arteck
                          @stefan-cloer was hat den javascript mit dem js-controller zu un ??
                          bitte die ausgabe von
                          iob diag
                          stefan.cloer
                          #801
                          @arteck was immer du heute geändert hast, mit der heutigen GIT Version läuft bei mir auch alles wieder...
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #802
                            dann belibt nur die heater funktion zu testen
                            • ? Offline
                              #803
                              @arteck also ich habe festgestellt, dass der Adapter das wohl richtig raus sendet.
                              Anscheinend ist aber die KI (BMS) des Fahrzeugs da nochmal ganz schlau dazwischen und macht nur das, was ihr notwendig erscheint.. ( wenn es schon eine gewisse Waerme hat, dann wird wohl kein Lenkrad beheizt, egal was ich schalte.. auch von der App her hat man da keinen Erfolg.. )
                              Was habt ihr so festgestellt?
                              • WinniW Offline
                                WinniW Offline
                                Winni
                                #804
                                Nur zur Info, es gibt ein Update für die Infotainment Software:
                                https://update.hyundai.com/EU/DE/updateNoticeView/1001
                                Damit ist zumindest der km-Stand im Adapter wieder da 😀
                                Meister MopperM ? WinniW 3 Antworten Letzte Antwort
                                • WinniW Winni
                                  Meister MopperM Online
                                  Meister Mopper
                                  #805
                                  @winni sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Die habe ich installiert, und der Kilometerstand ist bei mir leider nicht da.
                                  Proxmox und HA ...
                                  • WinniW Winni
                                    #806
                                    @winni ah, gerade gesehen, danke!
                                    Download ist gestartet...
                                    @Meister-Mopper hast du nach dem Update zur Sicherheit das Infotainment mal resetted? Manchmal braucht der n extra Reboot...
                                    Bin mal gespannt obs bei mir geht, dass der KM Stand auch in der App falsch ist, ist schon doof..
                                      Meister Mopper
                                      #807
                                      @ilovegym
                                      Guter Hinweis, ich resette den nachher mal.
                                      Proxmox und HA ...
                                      • WinniW Winni
                                        WinniW Offline
                                        WinniW Offline
                                        Winni
                                        #808
                                        @winni Die Freude war nur von kurzer Dauer, die km stehen jetzt wieder auf 0. 😨
                                        FredFF ? 2 Antworten Letzte Antwort
                                        • WinniW Winni
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          Most Active Forum Testing
                                          #809
                                          @winni Hätte mich auch gewundert... meine mit diesem Update ging der km Stand nicht mehr
