  4. Homematic Instanzen liefern keine Namen
37 Beiträge 6 Kommentatoren 4.9k Aufrufe 3 Beobachtet
  • dslraserD dslraser
    @webmaik
    wenn ich meine Instanz auf debug stelle und die Geräte neu einlese fängt das so an...
    (und warum hast Du andere Ports als ich, standen die da bei der Adapter Konfiguration schon drinn ?)
    2021-03-29 11:29:07.218 - warn: hm-rpc.0 (25999) Got terminate signal. Checking desired PID: 26053 vs own PID 25999
    2021-03-29 11:29:07.872 - error: host.iobroker instance system.adapter.hm-rpc.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2021-03-29 11:29:07.872 - info: host.iobroker Do not restart adapter system.adapter.hm-rpc.0 because desired by instance
    2021-03-29 11:29:08.065 - debug: hm-rpc.0 (26053) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-03-29 11:29:08.111 - debug: hm-rpc.0 (26053) Objects client ready ... initialize now
    2021-03-29 11:29:08.114 - debug: hm-rpc.0 (26053) Objects create System PubSub Client
    2021-03-29 11:29:08.115 - debug: hm-rpc.0 (26053) Objects create User PubSub Client
    2021-03-29 11:29:08.116 - debug: hm-rpc.0 (26053) Objects client initialize lua scripts
    2021-03-29 11:29:08.143 - debug: hm-rpc.0 (26053) Objects connected to redis: 127.0.0.1:9001
    2021-03-29 11:29:08.152 - debug: hm-rpc.0 (26053) objectDB connected
    2021-03-29 11:29:08.154 - debug: hm-rpc.0 (26053) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-03-29 11:29:08.174 - debug: hm-rpc.0 (26053) States create System PubSub Client
    2021-03-29 11:29:08.176 - debug: hm-rpc.0 (26053) States create User PubSub Client
    2021-03-29 11:29:08.248 - debug: hm-rpc.0 (26053) States connected to redis: 127.0.0.1:9000
    2021-03-29 11:29:08.249 - debug: hm-rpc.0 (26053) statesDB connected
    2021-03-29 11:29:08.890 - debug: hm-rpc.0 (26053) Plugin sentry Initialize Plugin (enabled=true)
    2021-03-29 11:29:09.108 - info: hm-rpc.0 (26053) starting. Version 1.14.35 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.21.0, js-controller: 3.2.16
    2021-03-29 11:29:09.444 - info: hm-rpc.0 (26053) xmlrpc server is trying to listen on 192.168.1.250:2010
    2021-03-29 11:29:09.445 - info: hm-rpc.0 (26053) xmlrpc client is trying to connect to 192.168.1.66:2010/ with ["http://192.168.1.250:2010","iobroker:hm-rpc.0"]
    2021-03-29 11:29:09.446 - debug: hm-rpc.0 (26053) Connect...
    2021-03-29 11:29:09.447 - debug: hm-rpc.0 (26053) xmlrpc -> 192.168.1.66:2010/ init ["http://192.168.1.250:2010","iobroker:hm-rpc.0"]
    2021-03-29 11:29:09.458 - debug: hm-rpc.0 (26053) start connecting interval
    2021-03-29 11:29:09.496 - info: hm-rpc.0 (26053) Connected
    2021-03-29 11:29:09.497 - debug: hm-rpc.0 (26053) clear connecting interval
    2021-03-29 11:29:09.497 - debug: hm-rpc.0 (26053) start ping interval
    2021-03-29 11:29:09.505 - info: hm-rpc.0 (26053) xmlrpc <- listDevices ["iobroker:hm-rpc.0"]
    2021-03-29 11:29:09.508 - debug: hm-rpc.0 (26053) No suitable Lua script, fallback to keys!: function(doc) {
    if (doc._id.match(/^hm-rpc\.[0-9]+\.\*?[A-Za-z0-9_-]+(\.[0-9]+)?$/)) {
    emit(doc._id, {ADDRESS:(doc.native?doc.native.ADDRESS:''),VERSION:(doc.native?doc.native.VERSION:'')});
    2021-03-29 11:29:09.736 - info: hm-rpc.0 (26053) xmlrpc -> 0 devices
    2021-03-29 11:29:11.072 - info: hm-rpc.0 (26053) xmlrpc <- newDevices 541
    @dslraser sagte in Homematic Instanzen liefern keine Namen:
    das sind die Ports für ioBroker, das müsste in Ordnung sein
    W 1 Antwort Letzte Antwort
      W Offline
      W Offline
      webmaik
      Ich habe die Ports auch einmal geändert,
      aber es ändert sich nichts.
      • W webmaik
        dslraserD Offline
        dslraserD Offline
        dslraser
        @webmaik sagte in Homematic Instanzen liefern keine Namen:
        Ich habe keine Idee mehr, aber @foxriver76 vielleicht ?
          ich hab es (vielleicht)!
          Habe mir erst die lange Fehlermeldung angesehen, und keine massiven Diskrepanzen gesehen, dann hab eich es in den json-viewer kopiert
          http://jsonviewer.stack.hu/
          Da kam "ungültiges json"
          Nach hinzufügen einer schließenden geschweiften Klammer am Ende
          "00021BE9A0CA6A:3":{"Name":"Schaltsteckdose%20Pool%20Schaltaktor","Interface":"HmIP-RF"},
          "00021BE9A0CA6A:4":{"Name":"HMIP-PS%2000021BE9A0CA6A%3A4","Interface":"HmIP-RF"},
          "00021BE9A0CA6A:5":{"Name":"HMIP-PS%2000021BE9A0CA6A%3A5","Interface":"HmIP-RF"},
          "00021BE9A0CA6A:6":{"Name":"Schaltsteckdose%20Pool%20Wochenprogramm","Interface":"HmIP-RF"}}
          war es dann ein gültiges json. und konnte ausgewertet werden:
          Warum die Klammer fehlt, oder ob das nur im log so ist, wird wohl wirklich nur @foxriver76 beantworten können
          • W webmaik
            Allerdings habe ich auch Fehler im Log:
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            @webmaik Welche Version von rega ist das? Der Favorites Fehler sollte eigentlich nicht mehr passieren dürfen.
            Videotutorials & mehr
            • foxriver76F foxriver76
              W Offline
              W Offline
              webmaik
              @foxriver76
              Version 3.0.16
              • W webmaik
                @foxriver76
                Version 3.0.16
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                @webmaik Ah ne passt, habe was verwechselt, kann kommen wenn man aktiv was falsches rein schreibt.
                • foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  Du kannst mal das Skript von https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/regascripts/devices.fn direkt auf der CCU ausführen. Damit werden die Namen ausgelesen, wurde seit 2014 nie verändert und sehe da auch nix was dazu führen sollte
                    W Offline
                    W Offline
                    webmaik
                    @foxriver76
                    Das Script lässt sich erst einmal ausführen, allerdings hört er nicht beim letzten Gerät aus, sondern etwas vorher.
                    {"0010D8A98AD4A5":{"Name":"Aussen%20Temperatur%20Sensor%20Carport","Interface":"HmIP-RF"},
                    "0010D8A98AD4A5:0":{"Name":"Aussen%20Temperatur%20Sensor%20Carport%3A0","Interface":"HmIP-RF"},
                    "0010D8A98AD4A5:1":{"Name":"Temperatur%2FFeuchtigkeit%20Carport","Interface":"HmIP-RF"},
                    "0010D8A98AD4A5:2":{"Name":"Temperatur%20Carport","Interface":"HmIP-RF"},
                    "0010D8A98AD4A5:3":{"Name":"Feuchtigkeit%20Carport","Interface":"HmIP-RF"},
                    "0014DBE991392A":{"Name":"Bewegungsmelder%20Badezimmer","Interface":"HmIP-RF"},
                    "0014DBE991392A:0":{"Name":"Bewegungsmelder%20Badezimmer%3A0","Interface":"HmIP-RF"},
                    "0014DBE991392A:1":{"Name":"HmIP-SMI55%200014DBE991392A%3A1","Interface":"HmIP-RF"},
                    "0014DBE991392A:2":{"Name":"HmIP-SMI55%200014DBE991392A%3A2","Interface":"HmIP-RF"},
                    "0014DBE991392A:3":{"Name":"Bewegung%20Bad","Interface":"HmIP-RF"},
                    "0014DBE991392A:4":{"Name":"HmIP-SMI55%200014DBE991392A%3A4","Interface":"HmIP-RF"},
                    "0014DBE9913970":{"Name":"Bewegungsmelder%20Flur%201OG%202","Interface":"HmIP-RF"},
                    "0014DBE9913970:0":{"Name":"Bewegungsmelder%20Flur%201OG%202%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913970:1":{"Name":"Bewegungsmelder%20Flur%201OG%3A1","Interface":"HmIP-RF"},
                    "0014DBE9913970:2":{"Name":"Bewegungsmelder%20Flur%201OG%3A2","Interface":"HmIP-RF"},
                    "0014DBE9913970:3":{"Name":"Bewegungsmelder%20Flur%201OG%3A3","Interface":"HmIP-RF"},
                    "0014DBE9913970:4":{"Name":"Bewegungsmelder%20Flur%201OG%3A4","Interface":"HmIP-RF"},
                    "0014DBE9913935":{"Name":"Bewegungsmelder%20Flur%201OG","Interface":"HmIP-RF"},
                    "0014DBE9913935:0":{"Name":"Bewegungsmelder%20Flur%201OG%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913935:1":{"Name":"Bewegungsmelder%20Flur%201OG%3A1%201","Interface":"HmIP-RF"},
                    "0014DBE9913935:2":{"Name":"Bewegungsmelder%20Flur%201OG%3A2%201","Interface":"HmIP-RF"},
                    "0014DBE9913935:3":{"Name":"Bewegungsmelder%20Flur%201OG%3A3%201","Interface":"HmIP-RF"},
                    "0014DBE9913935:4":{"Name":"Bewegungsmelder%20Flur%201OG%3A4%201","Interface":"HmIP-RF"},
                    "0014DBE9913971":{"Name":"Bewegungsmelder%20Flur%20EG","Interface":"HmIP-RF"},
                    "0014DBE9913971:0":{"Name":"Bewegungsmelder%20Flur%20EG%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913971:1":{"Name":"Bewegungsmelder%20Flur%20EG%3A1","Interface":"HmIP-RF"},
                    "0014DBE9913971:2":{"Name":"Bewegungsmelder%20Flur%20EG%3A2","Interface":"HmIP-RF"},
                    "0014DBE9913971:3":{"Name":"Bewegung%20Flur%20EG","Interface":"HmIP-RF"},
                    "0014DBE9913971:4":{"Name":"Bewegungsmelder%20Flur%20EG%3A4","Interface":"HmIP-RF"},
                    "0014DBE9913975":{"Name":"Bewegungsmelder%20Gaestebad","Interface":"HmIP-RF"},
                    "0014DBE9913975:0":{"Name":"Bewegungsmelder%20Gaestebad%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913975:1":{"Name":"Bewegungsmelder%20G%E4stebad%20Taster%201","Interface":"HmIP-RF"},
                    "0014DBE9913975:2":{"Name":"Bewegungsmelder%20G%E4stebad%20Taster%202","Interface":"HmIP-RF"},
                    "0014DBE9913975:3":{"Name":"Bewegungsmelder%20G%E4stebad","Interface":"HmIP-RF"},
                    "0014DBE9913975:4":{"Name":"Bewegungsmelder%20Gaestebad%3A4","Interface":"HmIP-RF"},
                    "0014DBE99139F0":{"Name":"Bewegungsmelder%20Kueche","Interface":"HmIP-RF"},
                    "0014DBE99139F0:0":{"Name":"Bewegungsmelder%20Kueche%3A0","Interface":"HmIP-RF"},
                    "0014DBE99139F0:1":{"Name":"Bewegungsmelder%20Kueche%3A1","Interface":"HmIP-RF"},
                    "0014DBE99139F0:2":{"Name":"Bewegungsmelder%20Kueche%3A2","Interface":"HmIP-RF"},
                    "0014DBE99139F0:3":{"Name":"Bewegungsmelder%20Kueche%3A3","Interface":"HmIP-RF"},
                    "0014DBE99139F0:4":{"Name":"Bewegungsmelder%20Kueche%3A4","Interface":"HmIP-RF"},
                    "0014DBE991397D":{"Name":"Bewegungsmelder%20Treppe%20oben","Interface":"HmIP-RF"},
                    "0014DBE991397D:0":{"Name":"Bewegungsmelder%20Treppe%20oben%3A0","Interface":"HmIP-RF"},
                    "0014DBE991397D:1":{"Name":"Bewegungsmelder%20Treppe%20oben%3A1","Interface":"HmIP-RF"},
                    "0014DBE991397D:2":{"Name":"Bewegungsmelder%20Treppe%20oben%3A2","Interface":"HmIP-RF"},
                    "0014DBE991397D:3":{"Name":"Bewegungsmelder%20Treppe%20oben%3A3","Interface":"HmIP-RF"},
                    "0014DBE991397D:4":{"Name":"Bewegungsmelder%20Treppe%20oben%3A4","Interface":"HmIP-RF"},
                    "0014DBE9913C17":{"Name":"Bewegungsmelder%20Treppe%20unten","Interface":"HmIP-RF"},
                    "0014DBE9913C17:0":{"Name":"Bewegungsmelder%20Treppe%20unten%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913C17:1":{"Name":"Bewegungsmelder%20Treppe%20unten%3A1","Interface":"HmIP-RF"},
                    "0014DBE9913C17:2":{"Name":"Bewegungsmelder%20Treppe%20unten%3A2","Interface":"HmIP-RF"},
                    "0014DBE9913C17:3":{"Name":"Bewegungsmelder%20Treppe%20unten%3A3","Interface":"HmIP-RF"},
                    "0014DBE9913C17:4":{"Name":"Bewegungsmelder%20Treppe%20unten%3A4","Interface":"HmIP-RF"},
                    "0014DBE9913988":{"Name":"Bewegungsmelder%20Wohnzimmer","Interface":"HmIP-RF"},
                    "0014DBE9913988:0":{"Name":"Bewegungsmelder%20Wohnzimmer%3A0","Interface":"HmIP-RF"},
                    "0014DBE9913988:1":{"Name":"Bewegungsmelder%20Wohnzimmer%3A1","Interface":"HmIP-RF"},
                    "0014DBE9913988:2":{"Name":"Bewegungsmelder%20Wohnzimmer%3A2","Interface":"HmIP-RF"},
                    "0014DBE9913988:3":{"Name":"Bewegungsmelder%20Wohnzimmer%3A3","Interface":"HmIP-RF"},
                    "0014DBE9913988:4":{"Name":"Bewegungsmelder%20Wohnzimmer%3A4","Interface":"HmIP-RF"},
                    "REQ0479900":{"Name":"Dimmaktor%20Bad","Interface":"BidCos-RF"},
                    "REQ0479900:0":{"Name":"Dimmaktor%20Bad%3A0","Interface":"BidCos-RF"},
                    "REQ0479900:1":{"Name":"Dimmaktor%20Bad%3A1","Interface":"BidCos-RF"},
                    "REQ0479900:2":{"Name":"Dimmaktor%20Bad%3A2","Interface":"BidCos-RF"},
                    "REQ0479900:3":{"Name":"Dimmaktor%20Bad%3A3","Interface":"BidCos-RF"},
                    "REQ1015484":{"Name":"Dimmaktor%20Flur%201OG","Interface":"BidCos-RF"},
                    "REQ1015484:0":{"Name":"Dimmaktor%20Flur%201OG%3A0","Interface":"BidCos-RF"},
                    "REQ1015484:1":{"Name":"Dimmaktor%20Flur%201OG%3A1","Interface":"BidCos-RF"},
                    "REQ0935723":{"Name":"Funk-Temperatur%20Sensor%20Sauna","Interface":"BidCos-RF"},
                    "REQ0935723:0":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A0","Interface":"BidCos-RF"},
                    "REQ0935723:1":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A1","Interface":"BidCos-RF"},
                    "REQ0935723:2":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A2","Interface":"BidCos-RF"},
                    "REQ0935723:3":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A3","Interface":"BidCos-RF"},
                    "REQ0935723:4":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A4","Interface":"BidCos-RF"},
                    "REQ0935723:5":{"Name":"Funk-Temperatur%20Sensor%20Sauna%3A5","Interface":"BidCos-RF"},
                    "00089BE9A1786D":{"Name":"Funkaktor%20Buero","Interface":"HmIP-RF"},
                    "00089BE9A1786D:0":{"Name":"Funkaktor%20Buero%3A0","Interface":"HmIP-RF"},
                    "00089BE9A1786D:1":{"Name":"Funkaktor%20Buero%3A1","Interface":"HmIP-RF"},
                    "00089BE9A1786D:2":{"Name":"Funkaktor%20Buero%3A2","Interface":"HmIP-RF"},
                    "00089BE9A1786D:3":{"Name":"Funkaktor%20Buero%3A3","Interface":"HmIP-RF"},
                    "00089BE9A1786D:4":{"Name":"Funkaktor%20Buero%3A4","Interface":"HmIP-RF"},
                    "00089BE9A1786D:5":{"Name":"Funkaktor%20Buero%3A5","Interface":"HmIP-RF"},
                    "00089BE9A1786D:6":{"Name":"Funkaktor%20Buero%3A6","Interface":"HmIP-RF"},
                    "00089BE9A1786D:7":{"Name":"Funkaktor%20Buero%3A7","Interface":"HmIP-RF"},
                    "REQ1589421":{"Name":"Funkaktor%20Carport","Interface":"BidCos-RF"},
                    "REQ1589421:0":{"Name":"Funkaktor%20Carport%3A0","Interface":"BidCos-RF"},
                    "REQ1589421:1":{"Name":"Steckdose%20Carport","Interface":"BidCos-RF"},
                    "REQ1589421:2":{"Name":"Steckdose%20Rasenm%E4her","Interface":"BidCos-RF"},
                    "00089BE99CD1EA":{"Name":"Funkaktor%20Kueche","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:0":{"Name":"Funkaktor%20Kueche%3A0","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:1":{"Name":"Funkaktor%20Kueche%3A1","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:2":{"Name":"Funkaktor%20Kueche%3A2","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:3":{"Name":"Funkaktor%20Kueche%3A3","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:4":{"Name":"Funkaktor%20Kueche%3A4","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:5":{"Name":"Funkaktor%20Kueche%3A5","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:6":{"Name":"Funkaktor%20Kueche%3A6","Interface":"HmIP-RF"},
                    "00089BE99CD1EA:7":{"Name":"Funkaktor%20Kueche%3A7","Interface":"HmIP-RF"},
                    "REQ1588696":{"Name":"Funkaktor%20Terrasse","Interface":"BidCos-RF"},
                    "REQ1588696:0":{"Name":"Funkaktor%20Terrasse%3A0","Interface":"BidCos-RF"},
                    "REQ1588696:1":{"Name":"Licht%20Terrasse","Interface":"BidCos-RF"},
                    "REQ1588696:2":{"Name":"Steckdose%20Terrasse","Interface":"BidCos-RF"},
                    "0008DBE9A3F53E":{"Name":"Funkdimmaktor%20Leo","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:0":{"Name":"Funkdimmaktor%20Leo%3A0","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:1":{"Name":"Funkdimmaktor%20Leo%3A1","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:2":{"Name":"Funkdimmaktor%20Leo%3A2","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:3":{"Name":"Funkdimmaktor%20Leo%3A3","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:4":{"Name":"Funkdimmaktor%20Leo%3A4","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:5":{"Name":"Funkdimmaktor%20Leo%3A5","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:6":{"Name":"Funkdimmaktor%20Leo%3A6","Interface":"HmIP-RF"},
                    "0008DBE9A3F53E:7":{"Name":"Funkdimmaktor%20Leo%3A7","Interface":"HmIP-RF"},
                    "REQ1015479":{"Name":"Funkdimmaktor%20Treppe","Interface":"BidCos-RF"},
                    "REQ1015479:0":{"Name":"Funkdimmaktor%20Treppe%3A0","Interface":"BidCos-RF"},
                    "REQ1015479:1":{"Name":"Dimmaktor%20Treppe%3A1","Interface":"BidCos-RF"},
                    "REQ0479966":{"Name":"Funkdimmaktor%20Wohnzimmer","Interface":"BidCos-RF"},
                    "REQ0479966:0":{"Name":"Funkdimmaktor%20Wohnzimmer%3A0","Interface":"BidCos-RF"},
                    "REQ0479966:1":{"Name":"Funkdimmaktor%20Wohnzimmer%3A1","Interface":"BidCos-RF"},
                    "REQ0479966:2":{"Name":"Funkdimmaktor%20Wohnzimmer%3A2","Interface":"BidCos-RF"},
                    "REQ0479966:3":{"Name":"Funkdimmaktor%20Wohnzimmer%3A3","Interface":"BidCos-RF"},
                    "REQ1032180":{"Name":"Klingelsensor","Interface":"BidCos-RF"},
                    "REQ1032180:0":{"Name":"Klingelsensor%3A0","Interface":"BidCos-RF"},
                    "REQ1032180:1":{"Name":"Klingelsensor%20Taster","Interface":"BidCos-RF"},
                    "HmIP-RCV-1":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:0":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A0","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:1":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A1","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:2":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A2","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:3":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A3","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:4":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A4","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:5":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A5","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:6":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A6","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:7":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A7","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:8":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A8","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:9":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A9","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:10":{"Name":"Sauna%20Beleuchtung%20AN","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:11":{"Name":"Saunabeleuchtung%20AUS","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:12":{"Name":"Aussenbeleuchtung%20AN","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:13":{"Name":"Aussenbeleuchtung%20AUS","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:14":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A14","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:15":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A15","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:16":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A16","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:17":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A17","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:18":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A18","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:19":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A19","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:20":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A20","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:21":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A21","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:22":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A22","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:23":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A23","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:24":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A24","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:25":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A25","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:26":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A26","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:27":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A27","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:28":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A28","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:29":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A29","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:30":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A30","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:31":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A31","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:32":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A32","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:33":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A33","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:34":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A34","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:35":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A35","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:36":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A36","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:37":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A37","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:38":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A38","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:39":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A39","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:40":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A40","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:41":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A41","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:42":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A42","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:43":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A43","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:44":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A44","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:45":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A45","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:46":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A46","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:47":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A47","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:48":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A48","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:49":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A49","Interface":"HmIP-RF"},
                    "HmIP-RCV-1:50":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%3A50","Interface":"HmIP-RF"},
                    "BidCoS-RF":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)","Interface":"BidCos-RF"},
                    "BidCoS-RF:0":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A0","Interface":"BidCos-RF"},
                    "BidCoS-RF:1":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A1","Interface":"BidCos-RF"},
                    "BidCoS-RF:2":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A2","Interface":"BidCos-RF"},
                    "BidCoS-RF:3":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A3","Interface":"BidCos-RF"},
                    "BidCoS-RF:4":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A4","Interface":"BidCos-RF"},
                    "BidCoS-RF:5":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A5","Interface":"BidCos-RF"},
                    "BidCoS-RF:6":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A6","Interface":"BidCos-RF"},
                    "BidCoS-RF:7":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A7","Interface":"BidCos-RF"},
                    "BidCoS-RF:8":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A8","Interface":"BidCos-RF"},
                    "BidCoS-RF:9":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A9","Interface":"BidCos-RF"},
                    "BidCoS-RF:10":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A10","Interface":"BidCos-RF"},
                    "BidCoS-RF:11":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A11","Interface":"BidCos-RF"},
                    "BidCoS-RF:12":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A12","Interface":"BidCos-RF"},
                    "BidCoS-RF:13":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A13","Interface":"BidCos-RF"},
                    "BidCoS-RF:14":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A14","Interface":"BidCos-RF"},
                    "BidCoS-RF:15":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A15","Interface":"BidCos-RF"},
                    "BidCoS-RF:16":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A16","Interface":"BidCos-RF"},
                    "BidCoS-RF:17":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A17","Interface":"BidCos-RF"},
                    "BidCoS-RF:18":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A18","Interface":"BidCos-RF"},
                    "BidCoS-RF:19":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A19","Interface":"BidCos-RF"},
                    "BidCoS-RF:20":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A20","Interface":"BidCos-RF"},
                    "BidCoS-RF:21":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A21","Interface":"BidCos-RF"},
                    "BidCoS-RF:22":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A22","Interface":"BidCos-RF"},
                    "BidCoS-RF:23":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A23","Interface":"BidCos-RF"},
                    "BidCoS-RF:24":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A24","Interface":"BidCos-RF"},
                    "BidCoS-RF:25":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A25","Interface":"BidCos-RF"},
                    "BidCoS-RF:26":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A26","Interface":"BidCos-RF"},
                    "BidCoS-RF:27":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A27","Interface":"BidCos-RF"},
                    "BidCoS-RF:28":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A28","Interface":"BidCos-RF"},
                    "BidCoS-RF:29":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A29","Interface":"BidCos-RF"},
                    "BidCoS-RF:30":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A30","Interface":"BidCos-RF"},
                    "BidCoS-RF:31":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A31","Interface":"BidCos-RF"},
                    "BidCoS-RF:32":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A32","Interface":"BidCos-RF"},
                    "BidCoS-RF:33":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A33","Interface":"BidCos-RF"},
                    "BidCoS-RF:34":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A34","Interface":"BidCos-RF"},
                    "BidCoS-RF:35":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A35","Interface":"BidCos-RF"},
                    "BidCoS-RF:36":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A36","Interface":"BidCos-RF"},
                    "BidCoS-RF:37":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A37","Interface":"BidCos-RF"},
                    "BidCoS-RF:38":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A38","Interface":"BidCos-RF"},
                    "BidCoS-RF:39":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A39","Interface":"BidCos-RF"},
                    "BidCoS-RF:40":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A40","Interface":"BidCos-RF"},
                    "BidCoS-RF:41":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A41","Interface":"BidCos-RF"},
                    "BidCoS-RF:42":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A42","Interface":"BidCos-RF"},
                    "BidCoS-RF:43":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A43","Interface":"BidCos-RF"},
                    "BidCoS-RF:44":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A44","Interface":"BidCos-RF"},
                    "BidCoS-RF:45":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A45","Interface":"BidCos-RF"},
                    "BidCoS-RF:46":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A46","Interface":"BidCos-RF"},
                    "BidCoS-RF:47":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A47","Interface":"BidCos-RF"},
                    "BidCoS-RF:48":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A48","Interface":"BidCos-RF"},
                    "BidCoS-RF:49":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A49","Interface":"BidCos-RF"},
                    "BidCoS-RF:50":{"Name":"RaspberryPi%20Virtuelle%20Fernbedienung%20(%20drahtlos%20)%3A50","Interface":"BidCos-RF"},
                    "001F5A4993DD7B":{"Name":"RaspberryPi%20Zentrale","Interface":"HmIP-RF"},
                    "001F5A4993DD7B:0":{"Name":"RaspberryPi%20Zentrale%3A0","Interface":"HmIP-RF"},
                    "0001DBE9A19E31":{"Name":"SchaltMess%20Steckdose%20Poolpumpe","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:0":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A0","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:1":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A1","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:2":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A2","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:3":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A3","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:4":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A4","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:5":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A5","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:6":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A6","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:7":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A7","Interface":"HmIP-RF"},
                    "0001DBE9A19E31:8":{"Name":"SchaltMess%20Steckdose%20Poolpumpe%3A8","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1":{"Name":"SchaltMess%20Steckdose%20Waschmaschine","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:0":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A0","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:1":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A1","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:2":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A2","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:3":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A3","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:4":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A4","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:5":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A5","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:6":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A6","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:7":{"Name":"SchaltMess%20Steckdose%20Waschmaschine%3A7","Interface":"HmIP-RF"},
                    "0001DBE9A19EB1:8":{"Name":"HMIP-PSM%200001DBE9A19EB1%3A8","Interface":"HmIP-RF"},
                    "0001DBE9A19C14":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:0":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A0","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:1":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A1","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:2":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A2","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:3":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A3","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:4":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A4","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:5":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A5","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:6":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A6","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:7":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A7","Interface":"HmIP-RF"},
                    "0001DBE9A19C14:8":{"Name":"SchaltMess%20Steckdose%20Waeschetrockner%3A8","Interface":"HmIP-RF"},
                    "00089BE99CD1B4":{"Name":"Schaltaktor%20Gaestebad","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:0":{"Name":"Schaltaktor%20Gaestebad%3A0","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:1":{"Name":"Schaltaktor%20G%E4stebad%20Statusmitteilung%20Schaltausgang","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:2":{"Name":"Schaltaktor%20G%E4stebad","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:3":{"Name":"HmIP-FSM%2000089BE99CD1B4%3A3","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:4":{"Name":"HmIP-FSM%2000089BE99CD1B4%3A4","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:5":{"Name":"Schaltaktor%20G%E4stebad%20Statusmeldung%20Messkanal","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:6":{"Name":"Schaltaktor%20G%E4stebad%20Konfiguration%20Entscheidungswert","Interface":"HmIP-RF"},
                    "00089BE99CD1B4:7":{"Name":"Schaltaktor%20G%E4stebad%20Wochenprogramm","Interface":"HmIP-RF"},
                    "00089BE99CD191":{"Name":"Schaltaktor%20Licht%20Flur%20EG","Interface":"HmIP-RF"},
                    "00089BE99CD191:0":{"Name":"Schaltaktor%20Licht%20Flur%20EG%3A0","Interface":"HmIP-RF"},
                    "00089BE99CD191:1":{"Name":"Schaltaktor%20Licht%20Flur%20EG%3A1","Interface":"HmIP-RF"},
                    "00089BE99CD191:2":{"Name":"Schaltaktor%20Licht%20Flur%20EG","Interface":"HmIP-RF"},
                    "00089BE99CD191:3":{"Name":"HmIP-FSM%2000089BE99CD191%3A3","Interface":"HmIP-RF"},
                    "00089BE99CD191:4":{"Name":"HmIP-FSM%2000089BE99CD191%3A4","Interface":"HmIP-RF"},
                    "00089BE99CD191:5":{"Name":"Schaltaktor%20Licht%20Flur%20EG%3A5","Interface":"HmIP-RF"},
                    "00089BE99CD191:6":{"Name":"Schaltaktor%20Licht%20Flur%20EG%3A6","Interface":"HmIP-RF"},
                    "00089BE99CD191:7":{"Name":"Schaltaktor%20Licht%20Flur%20EG%3A7","Interface":"HmIP-RF"},
                    "00259BE995C18E":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201","Interface":"HmIP-RF"},
                    "00259BE995C18E:0":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A0","Interface":"HmIP-RF"},
                    "00259BE995C18E:1":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A1","Interface":"HmIP-RF"},
                    "00259BE995C18E:2":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A2","Interface":"HmIP-RF"},
                    "00259BE995C18E:3":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A3","Interface":"HmIP-RF"},
                    "00259BE995C18E:4":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A4","Interface":"HmIP-RF"},
                    "00259BE995C18E:5":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A5","Interface":"HmIP-RF"},
                    "00259BE995C18E:6":{"Name":"Sauna%20Steckdosen","Interface":"HmIP-RF"},
                    "00259BE995C18E:7":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A7","Interface":"HmIP-RF"},
                    "00259BE995C18E:8":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A8","Interface":"HmIP-RF"},
                    "00259BE995C18E:9":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A9","Interface":"HmIP-RF"},
                    "00259BE995C18E:10":{"Name":"Poolbeleuchtung%20Sauna","Interface":"HmIP-RF"},
                    "00259BE995C18E:11":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A11","Interface":"HmIP-RF"},
                    "00259BE995C18E:12":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A12","Interface":"HmIP-RF"},
                    "00259BE995C18E:13":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A13","Interface":"HmIP-RF"},
                    "00259BE995C18E:14":{"Name":"Poolbeleuchtung%20Mitte","Interface":"HmIP-RF"},
                    "00259BE995C18E:15":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A15","Interface":"HmIP-RF"},
                    "00259BE995C18E:16":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A16","Interface":"HmIP-RF"},
                    "00259BE995C18E:17":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A17","Interface":"HmIP-RF"},
                    "00259BE995C18E:18":{"Name":"Poolbeleuchtung%20Ecke","Interface":"HmIP-RF"},
                    "00259BE995C18E:19":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A19","Interface":"HmIP-RF"},
                    "00259BE995C18E:20":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A20","Interface":"HmIP-RF"},
                    "00259BE995C18E:21":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%201%3A21","Interface":"HmIP-RF"},
                    "00259BE995C247":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202","Interface":"HmIP-RF"},
                    "00259BE995C247:0":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A0","Interface":"HmIP-RF"},
                    "00259BE995C247:1":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A1","Interface":"HmIP-RF"},
                    "00259BE995C247:2":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A2","Interface":"HmIP-RF"},
                    "00259BE995C247:3":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A3","Interface":"HmIP-RF"},
                    "00259BE995C247:4":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A4","Interface":"HmIP-RF"},
                    "00259BE995C247:5":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A5","Interface":"HmIP-RF"},
                    "00259BE995C247:6":{"Name":"Saunabeleuchtung","Interface":"HmIP-RF"},
                    "00259BE995C247:7":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A7","Interface":"HmIP-RF"},
                    "00259BE995C247:8":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A8","Interface":"HmIP-RF"},
                    "00259BE995C247:9":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A9","Interface":"HmIP-RF"},
                    "00259BE995C247:10":{"Name":"Sauna%20Steckdosen%20Unterstand","Interface":"HmIP-RF"},
                    "00259BE995C247:11":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A11","Interface":"HmIP-RF"},
                    "00259BE995C247:12":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A12","Interface":"HmIP-RF"},
                    "00259BE995C247:13":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A13","Interface":"HmIP-RF"},
                    "00259BE995C247:14":{"Name":"Poolbeleuchtung","Interface":"HmIP-RF"},
                    "00259BE995C247:15":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A15","Interface":"HmIP-RF"},
                    "00259BE995C247:16":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A16","Interface":"HmIP-RF"},
                    "00259BE995C247:17":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A17","Interface":"HmIP-RF"},
                    "00259BE995C247:18":{"Name":"Beleuchtung%20Weidenwand","Interface":"HmIP-RF"},
                    "00259BE995C247:19":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A19","Interface":"HmIP-RF"},
                    "00259BE995C247:20":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A20","Interface":"HmIP-RF"},
                    "00259BE995C247:21":{"Name":"Schaltaktor%20Sauna%20Schaltkasten%202%3A21","Interface":"HmIP-RF"},
                    "00021BE9A0CA49":{"Name":"Schaltsteckdose%20Schlafzimmer","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:0":{"Name":"Schaltsteckdose%20Schlafzimmer%3A0","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:1":{"Name":"Schaltsteckdose%20Schlafzimmer%20Taster","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:2":{"Name":"Schaltsteckdose%20Schlafzimmer%20Statusmitteilung%20Schaltausgang","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:3":{"Name":"Schaltsteckdose%20Schlafzimmer%20Schaltaktor","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:4":{"Name":"HMIP-PS%2000021BE9A0CA49%3A4","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:5":{"Name":"HMIP-PS%2000021BE9A0CA49%3A5","Interface":"HmIP-RF"},
                    "00021BE9A0CA49:6":{"Name":"Schaltsteckdose%20Schlafzimmer%20Wochenprogramm","Interface":"HmIP-RF"},
                    "00021BE9A0CADE":{"Name":"Schaltsteckdose%20Wohnzimmer","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:0":{"Name":"Schaltsteckdose%20Wohnzimmer%3A0","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:1":{"Name":"Schaltsteckdose%20Wohnzimmer%20Taster","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:2":{"Name":"Schaltsteckdose%20Wohnzimmer%20Statusmitteilung%20Schaltausgang","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:3":{"Name":"Schaltsteckdose%20Wohnzimmer%20Schaltaktor","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:4":{"Name":"HMIP-PS%2000021BE9A0CADE%3A4","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:5":{"Name":"HMIP-PS%2000021BE9A0CADE%3A5","Interface":"HmIP-RF"},
                    "00021BE9A0CADE:6":{"Name":"Schaltsteckdose%20Wohnzimmer%20Wochenprogramm","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A:0":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe%3A0","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A:1":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe%3A1","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A:2":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe%3A2","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A:3":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe%3A3","Interface":"HmIP-RF"},
                    "00021BE9A0CA6A:6":{"Name":"Schaltsteckdose%20Wohnzimmer%20Stehlampe%3A6","Interface":"HmIP-RF"}
                    Hier hört er auf:
                    HomoranH Dr. BakteriusD 2 Antworten Letzte Antwort
                    • W webmaik
                      @foxriver76
                      Hier hört er auf:
                      @webmaik das ist auch der letzte Eintrag in deinem log, bevor das json abbricht
                      EDIT:
                      Hast du das den Namen geändert?
                      Kanal 0 und 1 heißen "Schaltsteckdose%20Wohnzimmer%20Stehlampe"
                      die übrigen "Schaltsteckdose Pool"
                      @foxriver76
                        EDIT:
                        @foxriver76
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @homoran sagte in Homematic Instanzen liefern keine Namen:
                        @foxriver76
                        Was möchtest du mir sagen? ;-)
                        Anscheinend ist die Ausgabe unvollständig, wie du ja sagst wird nicht alles gelistet, das Skript hört auf und macht somit auch die finale }nicht, und deshalb kann der Adapter das JSON nicht parsen.
                        Da das Skript allerdings nicht vollständig auf der CCU durchläuft und auch kein Fehler ausspuckt, sehe ich das Problem nicht beim Adapter. Man müsste mal in Erfahrung bringen in welchen Fällen das sein kann, dass das Skript abbricht - evtl. im Homematic Forum oder @jens-maus hat eine Ahnung woher so ein Verhalten rühren kann.
                        HomoranH W 2 Antworten Letzte Antwort
                        • W webmaik
                          @foxriver76
                          Hier hört er auf:
                          Dr. BakteriusD Offline
                          Dr. Bakterius
                          @webmaik Schuss ins blaue: Du hast das Gerät wo das Skript stoppt keinem Raum zugeteilt. Versuch es mal einem Raum zuzuordnen ob es dann klappt.
                            @foxriver76
                            @foxriver76 sagte in Homematic Instanzen liefern keine Namen:
                            genau das was du schreibst ;-)
                            Ursache liegt irgendwo auf der CCU
                              @dr-bakterius sagte in Homematic Instanzen liefern keine Namen:
                              warum sollte das wichtig sein?
                              ich habe nur ganz wenige Geräte einem Raum zugeteilt
                                @foxriver76
                                W Offline
                                W Offline
                                webmaik
                                @foxriver76
                                Ja es scheint wirklich da zu liegen,
                                ich habe erst einen Raum zugeordnet und danach auch die beiden Geräte die vor und nach dem Abbruch liegen gelöscht.
                                Ändert auch nichts.
                                Er liest die Funkheizthermometer nicht ein, da bricht das Script ab.
                                BlackmikeB 1 Antwort Letzte Antwort
                                • W webmaik
                                  @foxriver76
                                  Ändert auch nichts.
                                  BlackmikeB Offline
                                  BlackmikeB Offline
                                  Blackmike
                                  Problem haben wir drüben im orangenen forum gelöst. Mir räumen oder gewerken hatte das ganze nix zu tun. Ursächlich war eine alte geräteleiche, deren Interface Methode ins Nirvana referenzierte. Das führte, da das iobroker Script badobjects nicht abfängt, zu einem Bäng des auslesescriptes mit dem geschilderten Verhalten.
                                  Nach Aufspürung und Terminierung der geräteleiche lief es dann.
                                  Black
                                  die Wahrheit ist ein Chor aus Wind
                                  • BlackmikeB Blackmike
                                    Black
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    schrieb am zuletzt editiert von foxriver76
                                    @blackmike Rein Interesse halber, könntest du mal den Link zum Thread posten? Danke
                                    Edit habs: https://homematic-forum.de/forum/viewtopic.php?f=65&t=66673&p=654429#p654429
