  4. PH-Messung
PH-Messung
432 Beiträge 48 Kommentatoren 145.4k Aufrufe 50 Beobachtet
  • coyoteC coyote
    @apollon77
    Log wenn Gerät eingeschaltet, dann ausgeschaltet. Nach ca. 30s bricht er dann komplett ab.
    root@debian:/home/coyote/ph803w/node_modules/node-ph803w/example# DEBUG=ph803w*        node data.js 192.168.66.56
      ph803w:device Connected to TCP 192.168.66.56:12416 +0ms
      ph803w:device Write and register for response type 7: 0000000303000006 +2ms
      ph803w:device Passcode received: IIXODDIHLL +7ms
      ph803w:device Resolve for message type 7: IIXODDIHLL +1ms
      ph803w:device Write and register for response type 9: 000000030f000008000a4949        584f444449484c4c +0ms
      ph803w:device login success +16ms
      ph803w:device Resolve for message type 9: true +0ms
      ph803w:device Write and register for response type 145: 000000030400009002 +1m        s
      ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.35,"re        dox":96,"phSwitch":false,"redoxSwitch":true} +48ms
    Data: {"binFlags1":"11","binFlags2":"10","ph":7.35,"redox":96,"phSwitch":false,"        redoxSwitch":true}
      ph803w:device Resolve for message type 145: [object Object] +2ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"r        edox":94,"phSwitch":false,"redoxSwitch":true} +3s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":94,"phSwitch":false,        "redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {        "binFlags1":"100","binFlags2":"10","ph":7.35,"redox":94,"phSwitch":false,"redoxS        witch":true} +0ms
      ph803w:device Send ping +1s
      ph803w:device received pong +3ms
      ph803w:device Send ping +4s
      ph803w:device received pong +16ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true} +707ms
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Send ping +3s
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true} +3s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device received pong +2ms
      ph803w:device received pong +43ms
      ph803w:device Ping response overdue, reconnect +8s
      ph803w:device Destroy socket +0ms
      ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.66.56:12416 +28s
    Error: Error: connect EHOSTUNREACH 192.168.66.56:12416
    (node:13947) UnhandledPromiseRejectionWarning: Error
        at Socket.<anonymous> (/home/coyote/ph803w/node_modules/node-ph803w/lib/device.js:78:28)
        at Socket.emit (events.js:314:20)
        at emitErrorNT (internal/streams/destroy.js:92:8)
        at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
        at processTicksAndRejections (internal/process/task_queues.js:84:21)
    (node:13947) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    (node:13947) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Zweites Log, Gerät nach ca. 10-15s wieder eingesteckt.
      ph803w:device Write and register for response type 7: 0000000303000006 +12ms
      ph803w:device Write and register for response type 9: 000000030f000008000a4949584f444449484c4c +1ms
      ph803w:device login success +7ms
      ph803w:device Resolve for message type 9: true +1ms
      ph803w:device Write and register for response type 145: 000000030400009002 +1ms
      ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.42,"redox":-59,"phSwitch":false,"redoxSwitch":true} +47ms
    Data: {"binFlags1":"11","binFlags2":"10","ph":7.42,"redox":-59,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true} +3s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device received pong +5ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true} +3s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Send ping +764ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true} +1s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Connected to TCP 192.168.66.56:12416 +10s
      ph803w:device Socket end, Reconnect: true +10s
    skinni
    #101
    Reconnect geht bei mir jetzt gar nicht mehr. Zumindest kommen keine Werte mehr. Er bricht aber auch nicht ab
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true} +1s
    Data: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Destroy socket +1ms
      ph803w:device Connected to TCP 192.168.88.128:12416 +10s
    • apollon77A Offline
      #102
      Grrmpf ... war wohl doch zu spät gestern Abend ... Hab die Änderungen nicht zu GitHub gepusht :-) Also bitte "Nochmal" das ganze
        skinni
        #103
        Alles unter Vorbehalt, weil es gestern bei mir auch schon nicht lief und bei Coyote gings. Kanns an diesen Meldungen liegen, das es nicht funktioniert? Mal sehn was die anderen sagen.
        pi@iobroker:~ $ npm install Apollon77/node-ph803w
        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        Hier hab ich das Gerät angemacht, script laufen lassen, Gerät aus, gewartet und wieder an.
        pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node data.js 192.168.88.128
          ph803w:device Connected to TCP 192.168.88.128:12416 +0ms
          ph803w:device Write and register for response type 7: 0000000303000006 +4ms
          ph803w:device Passcode received: IVEXBRFPMQ +8ms
          ph803w:device Resolve for message type 7: IVEXBRFPMQ +0ms
          ph803w:device Write and register for response type 9: 000000030f000008000a49564558425246504d51 +1ms
          ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.09,"redox":729,"phSwitch":false,"redoxSwitch":true} +56ms
        Data: {"binFlags1":"11","binFlags2":"10","ph":7.09,"redox":729,"phSwitch":false,"redoxSwitch":true}
          ph803w:device received pong +6ms
          ph803w:device received pong +73ms
          ph803w:device received pong +4ms
          ph803w:device received pong +9ms
          ph803w:device received pong +10ms
          ph803w:device received pong +8ms
          ph803w:device received pong +7ms
          ph803w:device Connected to TCP 192.168.88.128:12416 +13s
        Dann aus, script anund Gerät an:
          ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.88.128:12416 +0ms
        Error: Error: connect EHOSTUNREACH 192.168.88.128:12416
        Hab dann vermutlich erst heute Mittag wieder Zeit zu testen.
        coyoteC 1 Antwort Letzte Antwort
        • S skinni
          coyoteC Offline
          coyoteC Offline
          coyote
          #104
          @skinni nein, das passt schon. Die Fehlermeldungen kommen bei mir auch beim Installieren.
          Eigentlich sieht es ja so aus wie bei mir, nur das beim zweiten mal das Script das Gerät nicht findet.
          Ich habe zwar jetzt die neue Version installiert, kann aber erst heute Mittag/Abend testen mit Gerät aus/ein schalten
          • coyoteC coyote
            coyoteC Offline
            coyoteC Offline
            coyote
            #105
            @apollon77
            Also jetzt gerade nochmal getestet.
            Wenn ich das Script starte und dann das Gerät einstecke, verbindet er sich. Man darf aber auch da nicht so lange warten.
            Ansonsten gleiches wie gestern, stecke ich das Teil aus und warte über 30s bricht er ab, warte ich etwas kürzer kommt wieder:
              #106
              @skinni sagte in PH-Messung:
              ooooookkkk ... ich glaube ich hab jetzt meinen Denkfehler gefunden. Bitte nochmal Reconnect versuchen
              • apollon77A apollon77
                coyoteC Offline
                coyoteC Offline
                coyote
                #107
                @apollon77 👍 👍 👍
                Funktioniert, gute Arbeit so ohne eigenes Gerät👍
                Gerät eingesteckt, Script start -> läuft
                Gerät ausgesteckt, 15s später eingesteckt ->läuft
                Gerät ausgesteckt, 1min später eingesteckt -> läuft
                Probiere jetzt noch Script start und Gerät ausgesteckt, denke das geht aber auch.
                Noch was testen?
                Ansonsten kannst nen Adapter draus machen😊 👌
                  skinni
                  schrieb am zuletzt editiert von skinni
                  #108
                  Jetzt war ich gerade draußen und hab getestet da kommst du mir zuvor
                  Hat bei mir auch alles geklappt, sowohl der Start mit ausgestecktem Gerät, als auch sämtliche Unterbrechungen.
                    #109
                    Cool, danke.
                    Dann baue ich als Nächstes mal noch die Auto Discovery. Melde mich. Danach ist Adapter fix gemacht.
                    Jemand noch irgendwelche korrelationen im binFlag1zum Display oder so gefunden?!
                      skinni
                      #110
                      nee sorry, ich weiß du hättest da gerne was :) Ist bei mir immer 100 bis auf das erste Paket mit 11.
                      Mir ist gerade aufgefallen, dass es manchmal selten Daten gibt. Gefühlt ist es so, wenn sich die Werte stabilisiert haben, aber das ist nur eine Vermutung. Evtl. wenn keine Änderung war, gibts kein Update.
                      Wenn ich das script neu starte verbindet es sich, aber bekommt weiterhin nichts. Scheint also am Gerät selbst zu liegen. Die Abstände bis Daten kommen können also variieren.
                        ph803w:device Resolve for message type 7: {"type":"Buffer","data":[73,86,69,88,66,82,70,80,77,81]} +1ms
                        ph803w:device login success +9ms
                        ph803w:device Write and register for response type 145: 000000030400009002 +2ms
                        ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +48ms
                      Data: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true}
                        ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +3ms
                        ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true} +1s
                      Data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true}
                        ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true} +1ms
                        ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +1s
                      Data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true}
                        ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +0ms
                      coyoteC apollon77A 2 Antworten Letzte Antwort
                      • S skinni
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        #111
                        @skinni das kann gut sein. Konnte ich leider noch nicht testen, da mein Gerät noch auf dem Tisch liegt und sich die Werte eben ständig ändern.
                        • S skinni
                          #112
                          @skinni also das nur Updates kommen bei Änderungen war auch mein Gefühl. Was ja ok ist. Aber alles klar. Dann haben wir halt nur 4 Werte pro gerät bisher. Alles ok
                          • Marc RM Offline
                            Marc RM Offline
                            Marc R
                            #113
                            So habs endlich auch geschafft das Ding auf einem alten Raspi zu installieren! Cool vielen lieben Dank für all die Arbeit!
                            • I Offline
                              I Offline
                              ioUser 0
                              #114
                              Wahnsinn, was ihr hier auf die Beine gestellt habt 👍 .
                              Bis wann kann man mit einem Adapter für ioBroker rechnen?
                              • ? Offline
                                #115
                                ist es schon möglich den Adapter zu testen?
                                Muss man für die Installation anders vorgehen als mit normalen Adapter, die man von github installiert?
                                  coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  #116
                                  @sven-n gibt noch kein Adapter, Apollon hat ein node Script gebastelt. Weiter oben im Thread hat er geschrieben, wie man es installiert
                                  ? 1 Antwort Letzte Antwort
                                  • coyoteC coyote
                                    #117
                                    @coyote auf seinem github gibt es doch schon was oder sehe ich das falsch?
                                      #118
                                      @sven-n ja da ist ein leeres repository. Finger weg ;-)
                                      ? coyoteC 2 Antworten Letzte Antwort
                                        #119
                                        @apollon77 ok danke dir
                                        • Marc RM Offline
                                          Marc RM Offline
                                          Marc R
                                          schrieb am zuletzt editiert von Marc R
                                          #120
                                          Ich habs endlich geschafft die Werte in mein Home Assistant zu bringen inkl. Grafik und geschätzer FC Kalkulation!
                                          Lieben Dank für Eure Arbeit!
