  4. PH-Messung
    6.3k
PH-Messung
432 Beiträge 48 Kommentatoren 145.5k Aufrufe 50 Beobachtet
  • coyoteC coyote
    @apollon77
    Also, das hier kommt wenn ich das Gerät etwas länger aus lasse, keine Ahnung 30s oder so
    root@debian:/home/coyote/ph803w/node_modules/node-ph803w/example# DEBUG=ph803w* node data.js 192.168.66.56
      ph803w:device Connected to TCP 192.168.66.56:12416 +0ms
      ph803w:device Write and register for response type 7: 0000000303000006 +3ms
      ph803w:device Passcode received: IIXODDIHLL +10ms
      ph803w:device Resolve for message type 7: IIXODDIHLL +0ms
      ph803w:device Write and register for response type 9: 000000030f000008000a4949584f444449484c4c +1ms
      ph803w:device login success +13ms
      ph803w:device Resolve for message type 9: true +0ms
      ph803w:device Write and register for response type 145: 000000030400009002 +1ms
      ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.33,"redox":-113,"phSwitch":false,"redoxSwitch":true} +45ms
    Data: {"binFlags1":"11","binFlags2":"10","ph":7.33,"redox":-113,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Resolve for message type 145: [object Object] +2ms
      ph803w:device Send ping +4s
      ph803w:device received pong +12ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-112,"phSwitch":false,"redoxSwitch":true} +1s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-112,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-112,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Send ping +3s
      ph803w:device received pong +3ms
      ph803w:device received pong +5ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-111,"phSwitch":false,"redoxSwitch":true} +2s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-111,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.33,"redox":-111,"phSwitch":false,"redoxSwitch":true} +0ms
      ph803w:device Send ping +2s
      ph803w:device Ping response overdue, reconnect +8s
      ph803w:device Destroy socket +1ms
      ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.66.56:12416 +29s
    Error: Error: connect EHOSTUNREACH 192.168.66.56:12416
    (node:32240) UnhandledPromiseRejectionWarning: Error
        at Socket.<anonymous> (/home/coyote/ph803w/node_modules/node-ph803w/lib/device.js:78:28)
        at Socket.emit (events.js:314:20)
        at emitErrorNT (internal/streams/destroy.js:92:8)
        at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
        at processTicksAndRejections (internal/process/task_queues.js:84:21)
    (node:32240) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
    (node:32240) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Stecke ich es aus und nach paar Sek. wieder ein, siehts so aus
      ph803w:device Write and register for response type 7: 0000000303000006 +4ms
      ph803w:device Passcode received: IIXODDIHLL +5ms
      ph803w:device Resolve for message type 7: IIXODDIHLL +1ms
      ph803w:device Write and register for response type 9: 000000030f000008000a4949584f444449484c4c +0ms
      ph803w:device login success +16ms
      ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.38,"redox":-87,"phSwitch":false,"redoxSwitch":true} +53ms
    Data: {"binFlags1":"11","binFlags2":"10","ph":7.38,"redox":-87,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Resolve for message type 145: [object Object] +1ms
      ph803w:device received pong +4ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-84,"phSwitch":false,"redoxSwitch":true} +849ms
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-84,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-84,"phSwitch":false,"redoxSwitch":true} +1ms
      ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-83,"phSwitch":false,"redoxSwitch":true} +3s
    Data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-83,"phSwitch":false,"redoxSwitch":true}
      ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":-83,"phSwitch":false,"redoxSwitch":true} +7ms
      ph803w:device Send ping +1s
      ph803w:device Destroy socket +0ms
      ph803w:device Connected to TCP 192.168.66.56:12416 +10s
      ph803w:device Socket end, Reconnect: true +10s
    Mehr tut sich da leider nicht mehr
    #95
    @coyote alles klar. Checke nach dem Film morgen .. :-)) aber hilfreiches log. Danke.
    • coyoteC coyote
      @apollon77
      #96
      @coyote sagte in PH-Messung:
      Ok, war doch schneller alsgedacht ... Please check again.
      Wenn ich Dich um einen Zusatztest bitten darf: Starte mal neu während das Gerät aus ist ... und schalte es dann ein, verbindet er sich dann korrekt?
      Marc RM S J coyoteC 4 Antworten Letzte Antwort
      • apollon77A apollon77
        Marc RM Offline
        Marc RM Offline
        Marc R
        #97
        @apollon77 würde mich da gerne auch als Tester zur Verfügung stellen... Wie installiere ich das am besten? Ich laufe auf Home Assistant, nicht iobroker leider. Soll ich iobroker auf einem separaten Raspi installieren oder gibt es da einfachere Lösungen, zb Virtual Machine auf Win8 oder sowas? Lieben Dank
          skinni
          #98
          @apollon77 In beiden Fällen negativ. Hab das script laufen lassen, dann den PH-803w aus und gewartet, aber die Pause war wohl zu lange. Dann hab ich ihn wieder eingeschaltet, bin reingelaufen und hab das script gestartet, aber es konnte sich nicht verbinden.
          Update hab ich gerade eben vorher gemacht.
            ph803w:device received pong +9ms
            ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.88.128:12416 +29s
          Error: Error: connect EHOSTUNREACH 192.168.88.128:12416
          (node:9875) UnhandledPromiseRejectionWarning: Error
              at Socket.<anonymous> (/home/pi/node_modules/node-ph803w/lib/device.js:78:28)
          (node:9875) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          (node:9875) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node data.js 192.168.88.128
            ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.88.128:12416 +0ms
          (node:15611) UnhandledPromiseRejectionWarning: Error
          (node:15611) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          (node:15611) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            johnbobjamesson
            #99
            @apollon77 Ich hab's hier eingerichtet und kann auf Zuruf testen, aber ihr kommt ja momentan so aus. Nur, falls Du noch jemanden brauchst, melde Dich. Ach, und danke für die ganze Arbeit! Ich freue mich so darauf, hoffentlich irgendwann die Daten im iobroker zu haben :)
            Grüße, Claudio
              coyoteC Offline
              coyoteC Offline
              coyote
              #100
              @apollon77
              Log wenn Gerät eingeschaltet, dann ausgeschaltet. Nach ca. 30s bricht er dann komplett ab.
                ph803w:device Write and register for response type 7: 0000000303000006 +2ms
                ph803w:device Passcode received: IIXODDIHLL +7ms
                ph803w:device Write and register for response type 9: 000000030f000008000a4949        584f444449484c4c +0ms
                ph803w:device Write and register for response type 145: 000000030400009002 +1m        s
                ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.35,"re        dox":96,"phSwitch":false,"redoxSwitch":true} +48ms
              Data: {"binFlags1":"11","binFlags2":"10","ph":7.35,"redox":96,"phSwitch":false,"        redoxSwitch":true}
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"r        edox":94,"phSwitch":false,"redoxSwitch":true} +3s
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.35,"redox":94,"phSwitch":false,        "redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {        "binFlags1":"100","binFlags2":"10","ph":7.35,"redox":94,"phSwitch":false,"redoxS        witch":true} +0ms
                ph803w:device received pong +16ms
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true} +707ms
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":93,"phSwitch":false,"redoxSwitch":true} +0ms
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true} +3s
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.36,"redox":92,"phSwitch":false,"redoxSwitch":true} +0ms
                ph803w:device received pong +2ms
                ph803w:device received pong +43ms
                ph803w:device Socket error: Error: connect EHOSTUNREACH 192.168.66.56:12416 +28s
              (node:13947) UnhandledPromiseRejectionWarning: Error
              (node:13947) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
              (node:13947) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
              Zweites Log, Gerät nach ca. 10-15s wieder eingesteckt.
                ph803w:device Write and register for response type 7: 0000000303000006 +12ms
                ph803w:device login success +7ms
                ph803w:device Resolve for message type 9: true +1ms
                ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.42,"redox":-59,"phSwitch":false,"redoxSwitch":true} +47ms
              Data: {"binFlags1":"11","binFlags2":"10","ph":7.42,"redox":-59,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true} +3s
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-56,"phSwitch":false,"redoxSwitch":true} +0ms
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true} +3s
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.38,"redox":-57,"phSwitch":false,"redoxSwitch":true} +0ms
                ph803w:device Send ping +764ms
                ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true} +1s
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true}
                ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.39,"redox":-56,"phSwitch":false,"redoxSwitch":true} +0ms
              • coyoteC coyote
                @apollon77
                skinni
                #101
                Reconnect geht bei mir jetzt gar nicht mehr. Zumindest kommen keine Werte mehr. Er bricht aber auch nicht ab
                  ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true} +1s
                Data: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true}
                  ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":6.95,"redox":690,"phSwitch":false,"redoxSwitch":true} +0ms
                  ph803w:device Connected to TCP 192.168.88.128:12416 +10s
                • apollon77A Offline
                  #102
                  Grrmpf ... war wohl doch zu spät gestern Abend ... Hab die Änderungen nicht zu GitHub gepusht :-) Also bitte "Nochmal" das ganze
                    skinni
                    #103
                    Alles unter Vorbehalt, weil es gestern bei mir auch schon nicht lief und bei Coyote gings. Kanns an diesen Meldungen liegen, das es nicht funktioniert? Mal sehn was die anderen sagen.
                    pi@iobroker:~ $ npm install Apollon77/node-ph803w
                    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                    npm WARN pi No description
                    npm WARN pi No repository field.
                    npm WARN pi No README data
                    npm WARN pi No license field.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    Hier hab ich das Gerät angemacht, script laufen lassen, Gerät aus, gewartet und wieder an.
                      ph803w:device Connected to TCP 192.168.88.128:12416 +0ms
                      ph803w:device Passcode received: IVEXBRFPMQ +8ms
                      ph803w:device Resolve for message type 7: IVEXBRFPMQ +0ms
                      ph803w:device Write and register for response type 9: 000000030f000008000a49564558425246504d51 +1ms
                      ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.09,"redox":729,"phSwitch":false,"redoxSwitch":true} +56ms
                    Data: {"binFlags1":"11","binFlags2":"10","ph":7.09,"redox":729,"phSwitch":false,"redoxSwitch":true}
                      ph803w:device received pong +6ms
                      ph803w:device received pong +73ms
                      ph803w:device received pong +10ms
                      ph803w:device received pong +8ms
                      ph803w:device received pong +7ms
                      ph803w:device Connected to TCP 192.168.88.128:12416 +13s
                    Dann aus, script anund Gerät an:
                    Hab dann vermutlich erst heute Mittag wieder Zeit zu testen.
                    coyoteC 1 Antwort Letzte Antwort
                    • S skinni
                      coyoteC Offline
                      coyoteC Offline
                      coyote
                      #104
                      @skinni nein, das passt schon. Die Fehlermeldungen kommen bei mir auch beim Installieren.
                      Eigentlich sieht es ja so aus wie bei mir, nur das beim zweiten mal das Script das Gerät nicht findet.
                      Ich habe zwar jetzt die neue Version installiert, kann aber erst heute Mittag/Abend testen mit Gerät aus/ein schalten
                      • coyoteC coyote
                        coyoteC Offline
                        coyoteC Offline
                        coyote
                        #105
                        @apollon77
                        Also jetzt gerade nochmal getestet.
                        Wenn ich das Script starte und dann das Gerät einstecke, verbindet er sich. Man darf aber auch da nicht so lange warten.
                        Ansonsten gleiches wie gestern, stecke ich das Teil aus und warte über 30s bricht er ab, warte ich etwas kürzer kommt wieder:
                          #106
                          @skinni sagte in PH-Messung:
                          ooooookkkk ... ich glaube ich hab jetzt meinen Denkfehler gefunden. Bitte nochmal Reconnect versuchen
                            coyoteC Offline
                            coyoteC Offline
                            coyote
                            #107
                            @apollon77 👍 👍 👍
                            Funktioniert, gute Arbeit so ohne eigenes Gerät👍
                            Gerät eingesteckt, Script start -> läuft
                            Gerät ausgesteckt, 15s später eingesteckt ->läuft
                            Gerät ausgesteckt, 1min später eingesteckt -> läuft
                            Probiere jetzt noch Script start und Gerät ausgesteckt, denke das geht aber auch.
                            Noch was testen?
                            Ansonsten kannst nen Adapter draus machen😊 👌
                              skinni
                              schrieb am zuletzt editiert von skinni
                              #108
                              Jetzt war ich gerade draußen und hab getestet da kommst du mir zuvor
                              Hat bei mir auch alles geklappt, sowohl der Start mit ausgestecktem Gerät, als auch sämtliche Unterbrechungen.
                                #109
                                Cool, danke.
                                Dann baue ich als Nächstes mal noch die Auto Discovery. Melde mich. Danach ist Adapter fix gemacht.
                                Jemand noch irgendwelche korrelationen im binFlag1zum Display oder so gefunden?!
                                  skinni
                                  #110
                                  nee sorry, ich weiß du hättest da gerne was :) Ist bei mir immer 100 bis auf das erste Paket mit 11.
                                  Mir ist gerade aufgefallen, dass es manchmal selten Daten gibt. Gefühlt ist es so, wenn sich die Werte stabilisiert haben, aber das ist nur eine Vermutung. Evtl. wenn keine Änderung war, gibts kein Update.
                                  Wenn ich das script neu starte verbindet es sich, aber bekommt weiterhin nichts. Scheint also am Gerät selbst zu liegen. Die Abstände bis Daten kommen können also variieren.
                                    ph803w:device Resolve for message type 7: {"type":"Buffer","data":[73,86,69,88,66,82,70,80,77,81]} +1ms
                                    ph803w:device login success +9ms
                                    ph803w:device Write and register for response type 145: 000000030400009002 +2ms
                                    ph803w:device Retrieved data: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +48ms
                                  Data: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true}
                                    ph803w:device Resolve for message type 145: {"binFlags1":"11","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +3ms
                                    ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true} +1s
                                  Data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true}
                                    ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":689,"phSwitch":false,"redoxSwitch":true} +1ms
                                    ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +1s
                                  Data: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true}
                                    ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.14,"redox":690,"phSwitch":false,"redoxSwitch":true} +0ms
                                  coyoteC apollon77A 2 Antworten Letzte Antwort
                                  • S skinni
                                    coyoteC Offline
                                    coyoteC Offline
                                    coyote
                                    #111
                                    @skinni das kann gut sein. Konnte ich leider noch nicht testen, da mein Gerät noch auf dem Tisch liegt und sich die Werte eben ständig ändern.
                                    • S skinni
                                      #112
                                      @skinni also das nur Updates kommen bei Änderungen war auch mein Gefühl. Was ja ok ist. Aber alles klar. Dann haben wir halt nur 4 Werte pro gerät bisher. Alles ok
                                      • Marc RM Offline
                                        Marc RM Offline
                                        Marc R
                                        #113
                                        So habs endlich auch geschafft das Ding auf einem alten Raspi zu installieren! Cool vielen lieben Dank für all die Arbeit!
                                        • I Offline
                                          I Offline
                                          ioUser 0
                                          #114
                                          Wahnsinn, was ihr hier auf die Beine gestellt habt 👍 .
                                          Bis wann kann man mit einem Adapter für ioBroker rechnen?
