  4. Port lass sich mit SSH nicht ändern
46 Beiträge 5 Kommentatoren 4.9k Aufrufe 4 Beobachtet
  • H heli-wolf
    So jetzt mal nur dmesg
    pi@ioBroker-RasPi4:/opt/iobroker $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.58-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1245 SMP Fri Jul 12 17:25:51 BST 2019
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
    [    0.000000] On node 0 totalpages: 242688
    [    0.000000]   Normal zone: 2133 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
    [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
    [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
    [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                       lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                       modules : 0x7f000000 - 0x80000000   (  16 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 26351 entries in 78 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000023] Switching to timer-based delay loop, resolution 52ns
    [    0.000284] Console: colour dummy device 80x30
    [    0.000906] console [tty1] enabled
    [    0.000963] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.001009] pid_max: default: 32768 minimum: 301
    [    0.001366] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001402] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.002343] CPU: Testing write buffer coherency: ok
    [    0.002827] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.003498] Setting up static identity map for 0x100000 - 0x10003c
    [    0.003668] rcu: Hierarchical SRCU implementation.
    [    0.004487] smp: Bringing up secondary CPUs ...
    [    0.005348] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.006276] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.007135] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.007255] smp: Brought up 1 node, 4 CPUs
    [    0.007338] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.007362] CPU: All CPU(s) started in HYP mode.
    [    0.007382] CPU: Virtualization extensions available.
    [    0.008377] devtmpfs: initialized
    [    0.021277] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.021550] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.021599] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.022205] pinctrl core: initialized pinctrl subsystem
    [    0.023091] NET: Registered protocol family 16
    [    0.026047] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.031728] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.031765] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.031984] Serial: AMBA PL011 UART driver
    [    0.034282] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.069162] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
    [    0.071088] SCSI subsystem initialized
    [    0.071325] usbcore: registered new interface driver usbfs
    [    0.071408] usbcore: registered new interface driver hub
    [    0.071521] usbcore: registered new device driver usb
    [    0.090297] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:40, variant start
    [    0.100129] raspberrypi-firmware soc:firmware: Firmware hash is 6c3fe3f096a93de3b34252ad98cdccadeb534be2
    [    0.111791] clocksource: Switched to clocksource arch_sys_counter
    [    0.201549] VFS: Disk quotas dquot_6.6.0
    [    0.201659] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.201863] FS-Cache: Loaded
    [    0.202089] CacheFiles: Loaded
    [    0.212101] NET: Registered protocol family 2
    [    0.212885] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.212950] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.213081] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.213286] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.213441] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.213507] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.213835] NET: Registered protocol family 1
    [    0.214416] RPC: Registered named UNIX socket transport module.
    [    0.214443] RPC: Registered udp transport module.
    [    0.214465] RPC: Registered tcp transport module.
    [    0.214487] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.216191] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    0.219231] Initialise system trusted keyrings
    [    0.219441] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.229162] FS-Cache: Netfs 'nfs' registered for caching
    [    0.229753] NFS: Registering the id_resolver key type
    [    0.229798] Key type id_resolver registered
    [    0.229820] Key type id_legacy registered
    [    0.229851] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.232200] Key type asymmetric registered
    [    0.232230] Asymmetric key parser 'x509' registered
    [    0.232297] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    [    0.232477] io scheduler noop registered
    [    0.232502] io scheduler deadline registered (default)
    [    0.232705] io scheduler cfq registered
    [    0.232729] io scheduler mq-deadline registered (default)
    [    0.232753] io scheduler kyber registered
    [    0.235885] bcm2708_fb soc:fb: FB found 1 display(s)
    [    0.244890] Console: switching to colour frame buffer device 82x26
    [    0.251714] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
    [    0.258462] bcm2835-rng 3f104000.rng: hwrng registered
    [    0.261142] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    0.266449] vc-sm: Videocore shared memory driver
    [    0.269197] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    0.285062] brd: module loaded
    [    0.297640] loop: module loaded
    [    0.300697] Loading iSCSI transport class v2.0-870.
    [    0.303871] libphy: Fixed MDIO Bus: probed
    [    0.306379] usbcore: registered new interface driver lan78xx
    [    0.308839] usbcore: registered new interface driver smsc95xx
    [    0.311193] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.341498] dwc_otg 3f980000.usb: base=(ptrval)
    [    0.544156] Core Release: 2.80a
    [    0.546530] Setting default values for core params
    [    0.548970] Finished setting default values for core params
    [    0.751701] Using Buffer DMA mode
    [    0.754101] Periodic Transfer Interrupt Enhancement - disabled
    [    0.756518] Multiprocessor Interrupt Enhancement - disabled
    [    0.758883] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.761219] Dedicated Tx FIFOs mode
    [    0.763921] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
    [    0.768482] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    0.779355] dwc_otg: Microframe scheduler enabled
    [    0.779413] WARN::hcd_init_fiq:457: FIQ on core 1
    [    0.781633] WARN::hcd_init_fiq:458: FIQ ASM at 80650e04 length 36
    [    0.783838] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [    0.786091] dwc_otg 3f980000.usb: DWC OTG Controller
    [    0.788344] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    0.790657] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    [    0.792978] Init: Port Power? op_state=1
    [    0.795211] Init: Power Port (0)
    [    0.797626] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    0.802156] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.804570] usb usb1: Product: DWC OTG Controller
    [    0.806936] usb usb1: Manufacturer: Linux 4.19.58-v7+ dwc_otg_hcd
    [    0.809356] usb usb1: SerialNumber: 3f980000.usb
    [    0.812321] hub 1-0:1.0: USB hub found
    [    0.814589] hub 1-0:1.0: 1 port detected
    [    0.817349] dwc_otg: FIQ enabled
    [    0.817355] dwc_otg: NAK holdoff enabled
    [    0.817360] dwc_otg: FIQ split-transaction FSM enabled
    [    0.817371] Module dwc_common_port init
    [    0.817665] usbcore: registered new interface driver usb-storage
    [    0.820112] mousedev: PS/2 mouse device common for all mice
    [    0.823312] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    0.825931] bcm2835-cpufreq: min=600000 max=1200000
    [    0.828751] sdhci: Secure Digital Host Controller Interface driver
    [    0.831157] sdhci: Copyright(c) Pierre Ossman
    [    0.833952] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [    0.836852] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    0.839516] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.843621] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.846380] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.849134] usbcore: registered new interface driver usbhid
    [    0.851755] usbhid: USB HID core driver
    [    0.855069] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    [    0.859194] [vc_sm_connected_init]: start
    [    0.868024] [vc_sm_connected_init]: end - returning 0
    [    0.871550] Initializing XFRM netlink socket
    [    0.874005] NET: Registered protocol family 17
    [    0.876497] Key type dns_resolver registered
    [    0.879330] Registering SWP/SWPB emulation handler
    [    0.882438] registered taskstats version 1
    [    0.884838] Loading compiled-in X.509 certificates
    [    0.894463] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    0.896982] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
    [    0.903838] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    0.906366] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [    0.934986] sdhost: log_buf @ (ptrval) (fad07000)
    [    0.972278] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.976248] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.980099] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.985121] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.987240] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    0.990610] of_cfs_init
    [    0.992765] of_cfs_init: OK
    [    0.995248] Waiting for root device PARTUUID=52e4cf4c-02...
    [    1.041915] Indeed it is in host mode hprt0 = 00021501
    [    1.109320] random: fast init done
    [    1.128536] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.136070] mmc0: new high speed SDHC card at address aaaa
    [    1.139504] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
    [    1.148201]  mmcblk0: p1 p2
    [    1.177296] mmc1: new high speed SDIO card at address 0001
    [    1.185686] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.189970] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.200260] devtmpfs: mounted
    [    1.207863] Freeing unused kernel memory: 1024K
    [    1.210491] Run /sbin/init as init process
    [    1.251856] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    1.254466] Indeed it is in host mode hprt0 = 00001101
    [    1.492181] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
    [    1.497370] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.500900] hub 1-1:1.0: USB hub found
    [    1.503797] hub 1-1:1.0: 5 ports detected
    [    1.799335] systemd[1]: System time before build time, advancing clock.
    [    1.821842] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    1.930678] NET: Registered protocol family 10
    [    1.934745] Segment Routing with IPv6
    [    1.952185] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
    [    1.957740] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.963448] smsc95xx v1.0.6
    [    1.976599] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    1.986432] systemd[1]: Detected architecture arm.
    [    2.015948] systemd[1]: Set hostname to <ioBroker-RasPi4>.
    [    2.030433] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
    [    2.055603] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d3:e9:79
    [    2.353977] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
    [    2.363328] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
    [    2.822596] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.836894] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.840713] systemd[1]: Listening on udev Control Socket.
    [    2.847918] random: systemd: uninitialized urandom read (16 bytes read)
    [    2.851267] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.871513] systemd[1]: Listening on Syslog Socket.
    [    2.883388] systemd[1]: Created slice system-getty.slice.
    [    3.624943] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.779110] systemd-journald[105]: Received request to flush runtime journal from PID 1
    [    4.310726] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.314331] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    4.314348] [vc_sm_connected_init]: start
    [    4.318570] [vc_sm_connected_init]: installed successfully
    [    4.324294] media: Linux media interface: v0.10
    [    4.381102] videodev: Linux video capture interface: v2.00
    [    4.478204] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.478877] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.501761] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.504093] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.513047] bcm2835_audio soc:audio: card created with 8 channels
    [    4.527474] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.545106] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    4.545120] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    4.552383] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    4.552397] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    4.560985] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    4.561000] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    4.723929] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    4.854692] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    4.924318] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    [    4.929991] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    4.930286] usbcore: registered new interface driver brcmfmac
    [    5.138368] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [    5.138501] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
    [    5.139542] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
    [    6.274702] random: crng init done
    [    6.274733] random: 7 urandom warning(s) missed due to ratelimiting
    [    6.403259] uart-pl011 3f201000.serial: no DMA platform data
    [    6.404685] 8021q: 802.1Q VLAN Support v1.8
    [    6.863083] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [    6.863096] brcmfmac: power management disabled
    [    7.223992] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [    8.810902] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
    [   11.318267] Bluetooth: Core ver 2.22
    [   11.318364] NET: Registered protocol family 31
    [   11.318371] Bluetooth: HCI device and connection manager initialized
    [   11.318392] Bluetooth: HCI socket layer initialized
    [   11.318405] Bluetooth: L2CAP socket layer initialized
    [   11.318446] Bluetooth: SCO socket layer initialized
    [   11.337284] Bluetooth: HCI UART driver ver 2.3
    [   11.337300] Bluetooth: HCI UART protocol H4 registered
    [   11.337389] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   11.337605] Bluetooth: HCI UART protocol Broadcom registered
    [   11.718745] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   11.718753] Bluetooth: BNEP filters: protocol multicast
    [   11.718771] Bluetooth: BNEP socket layer initialized
    @heli-wolf
    Der Kernel ist steinalt.
    sudo  apt update
    sudo apt dist-upgrade
    sudo reboot
    H 1 Antwort Letzte Antwort
      @heli-wolf
      sudo  apt update
      sudo reboot
      heli-wolf
      ich vermute er hat zuwenig Speicherplatz?
      pi@ioBroker-RasPi4:/opt/iobroker $ sudo apt update
      Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,8 kB]
      Fehl:1 http://archive.raspberrypi.org/debian buster InRelease
        Fehler beim Schreiben der Ausgabedatei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 46.235.231.151 80]
      Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      Fehl:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Fehler beim Schreiben der Ausgabedatei - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar) [IP: 93.93.128.193 80]
      Ign:3 https://deb.nodesource.com/node_10.x buster InRelease
      Fehl:4 https://deb.nodesource.com/node_10.x buster Release
        Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate.  Could not handshake: Error in the certificate verification. [IP: 23.6.112.43 443]
      Paketlisten werden gelesen... Fehler!
      E: Das Depot »https://deb.nodesource.com/node_10.x buster Release« enthält keine Release-Datei mehr.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      E: Schreibfehler - write (28: Auf dem Gerät ist kein Speicherplatz mehr verfügbar)
      E: E/A-Fehler beim Speichern des Quell-Zwischenspeichers
      E: Die Paketliste oder die Statusdatei konnte nicht eingelesen oder geöffnet werden.
      pi@ioBroker-RasPi4:/opt/iobroker $ sudo apt dist-upgrade
      pi@ioBroker-RasPi4:/opt/iobroker $ sudo reboot
      • H heli-wolf
        @heli-wolf df -h
          @heli-wolf df -h
          heli-wolf
          pi@ioBroker-RasPi4:/opt/iobroker $ df -h
          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
          /dev/root       3,4G    3,4G     0  100% /
          devtmpfs        459M       0  459M    0% /dev
          tmpfs           464M       0  464M    0% /dev/shm
          tmpfs           464M     18M  446M    4% /run
          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
          tmpfs           464M       0  464M    0% /sys/fs/cgroup
          /dev/mmcblk0p1  253M     40M  214M   16% /boot
          tmpfs            93M       0   93M    0% /run/user/1000
          • H heli-wolf
            @heli-wolf
            Wie erwartet ist dein / rappelvoll.
            Die Karte ist doch größer, hast du kein Resizing bei der Installation durchgeführt?
            • H heli-wolf
              @heli-wolf Du hast nur eine 4 GB-Karte drin?????
              die ist voll, dann kann da auch nichts mehr geschrieben werden
                heli-wolf
                ich muss ehrlich gestehen ich weiß nicht was RESIZING ist, daher habe ich es mit Sicherheit nicht durchgeführt.
                • H heli-wolf
                  @heli-wolf
                  Das ist jetzt etwas komplexer zu fixen.
                  Diese Anleitung schaut auf den ersten Blick recht brauchbar aus:
                  https://raspberrypi.stackexchange.com/questions/499/how-can-i-resize-my-root-partition
                    @heli-wolf
                    heli-wolf
                    ok, danke
                    Werde ich demnächst mal angehen.
                    Das heißt ich muss nicht auf eine größere micro SD Karte umstellen und alles neu installieren?
                    • H heli-wolf
                      @heli-wolf sagte in Port lass sich mit SSH nicht ändern:
                      würde in diesem Fall df -h nicht die Gesamtgröße der SD angeben?
                      Bin mir da ziemlich sicher
                      Deswegen die Frage nach der Karte ich bin mir sicher, dass die nur 4GB hat
                        Nee, das OS kennt nur die in den Partitionen zugeteilten Größen.
                        Der Rest von der Karte ist quasi Ödland und nicht mit einem Dateisystem bebaut.
                        Laut dmesg:
                        Da wäre also noch Platz. Wenn da nicht was komplett anderes auch noch drauf läuft. Das würde mich aber wundern. Wie gesagt, vermutlich ein Image auf die Karte gebügelt und die Partition nicht vergrößert.
                          Laut dmesg:
                          @thomas-braun sagte in Port lass sich mit SSH nicht ändern:
                          und woher weiß dmesg es dann?
                          EDIT: und ja df -h weiß es nicht - gerade geprüft
                            dmesg fragt direkt bei der Hardware an was die denn kann, df schaut auf das Dateisystem.
                              heli-wolf
                              ich habe mir die Karte jetzt mal angesehen und es ist wirklich eine 16 GB Karte.
                              Werde mich morgen mal über die Anleitung zum Resizing machen.
                              Aber wie schaut das mit dem Backup aus, wie ich das jetzt so überflogen habe sind die Daten danach überschrieben, oder?
                              Wie mache ich am einfachsten ein Backup meiner jetztigen Daten?
                              • H heli-wolf
                                @heli-wolf
                                Nee, der Witz an der Anleitung ist, dass es (zumindest theoretisch) ohne Datenverlust funktionieren sollte. Das Backup macht man da nur aus Sicherheitsgründen, falls es doch in die Buxe geht.
                                Backup: Hängt davon ab was du da für Möglichkeiten hast. Und wie weit dich das rappelvolle System noch was machen lässt.
                                Ich würde bei mir über einen externen Card-Reader vermutlich ein Image ziehen. Oder gar kein aktuelles Backup der ganzen Karte ziehen und mich auf mein Backup nur des ioBrokers verlassen.
                                Hängt halt von deiner Situation ab.
                                  @heli-wolf
                                  heli-wolf
                                  kann ich auch über den WinSCP einfach die gesamte SD Card auf meine Festplatte kopieren und bei Bedarf dann zurückspielen?
                                  • H heli-wolf
                                    @heli-wolf
                                    Ich kenne kein WinSCP. Ich kenne auch keine Betriebssysteme, die mit Win anfangen.
                                    • wendy2702W Offline
                                      wendy2702W Offline
                                      wendy2702
                                      @heli-wolf Nein.
                                      Das geht nicht.
                                      Du kannst mit zum Beispiel dem Programm Etcher ein image der so Karte erstellen und das bei bedarf wieder zurück spielen.
                                        werft doch nicht alles durcheinander!
                                        Backup ist immer gut!
                                        Dieses dann mit WINSCP oder filezilla (für Thomas: das sind Filetransferprogramme) das Backup natürlich von /opt/iobroker/backups auf den PC sichern!
                                        Dann über sudo raspi-config das Dateisystem erweitern.
                                        Das sollte zerstörungsfrei gehen, könnte aber verssagen, wenn die Karte wirklich ganz voll ist.
                                        In dem Fall sollte das jetzt hoffentlich auf dem PC liegende Backup vor dem nächsten Versuch des Resize in /opt/iobroker/Backups gelöscht werden
                                        Eine Kopie einer nicht korrekten Karte bringt gar nichts, weil die anschließend nur genauso wiederhergestellt werden kann, schlimmstenfalls sogar nur auf eine 32GB Karte
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          wendy2702
                                          @homoran sagte in Port lass sich mit SSH nicht ändern:
                                          Habe nichts durcheinander geworfen.
                                          Wollte und habe eigentlich nur die Frage beantwortet und „einfaches“ Kopieren, womit auch immer funktioniert bei einer kompletten SD Karte nunmal nicht.
