  4. [fixed] jscontroller, Update auf 0.14.0 fehlgeschlagen :-(
18 Beiträge 7 Kommentatoren 3.2k Aufrufe
    MistyReblaus
    Verwendet habe ich brav die Befehle aus der Host Registerkarte:
    cd /opt/iobroker
    sudo iobroker stop
    sudo iobroker update
    sudo iobroker upgrade self
    sudo iobroker start
    Hier die Ausgaben:
    i@raspi3:/opt/iobroker $ sudo iobroker upgrade self
    npm install iobroker.js-controller --production --prefix "/opt/iobroker" (System        call)
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/roo        t/.node-gyp/4.6.1"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/n        ode_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix        -dgram/.node-gyp"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/n        ode_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-com        pat/node_modules/ursa/.node-gyp"
    fs.js:549
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-c        ontroller/lib/setup/../../../../killall.sh'
        at Error (native)
        at Object.fs.openSync (fs.js:549:18)
        at Object.fs.writeFileSync (fs.js:1156:15)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/        setupSetup.js:88:24)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:554:23
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib        /setup.js:575:11)
        at Module._compile (module.js:409:26)
        at Object.Module._extensions..js (module.js:416:10)
        at Module.load (module.js:343:32)
        at Function.Module._load (module.js:300:12)
    npm ERR! Linux 4.4.36-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller        " "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v4.6.1
    npm ERR! npm  v2.15.9
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.js-controller@0.14.0 install: `node lib/setup.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.14.0 install script 'node lib/se        tup.js setup first'.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/setup.js setup first
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs iobroker.js-controller
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR!     npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    host.raspi3 Cannot install iobroker.js-controller: 1
    pi@raspi3:/opt/iobroker $ sudo iobroker start
    module.js:327
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js'
        at Function.Module._resolveFilename (module.js:325:15)
        at Function.Module._load (module.js:276:25)
        at Function.Module.runMain (module.js:441:10)
        at startup (node.js:139:18)
        at node.js:974:3</anonymous>
    • BluefoxB Offline
      BluefoxB Offline
      cd /opt/iobroker
      sudo chmod 777 * -R
      sudo npm i iobroker.js-controller
      sudo iobroker start
        MistyReblaus
        Danke, funktioniert wieder.
        Habe ich bei der Installation etwas falsch gemacht?
        • BluefoxB Offline
          BluefoxB Offline
          @MistyReblaus:
          Habe ich bei der Installation etwas falsch gemacht? `
          Eigentlich nicht. Nun beim dem update werden einige Prozesse als nicht sudo gestartet und die Prozesse haben kein Zugriff auf root Dateien. Und weil die Installation war unter root. Man konnte nach der Installation dann alle Dateien in iobroker für normale User zugänglich machen (mit chmod).
          Das verhalten vom System zum System unterschiedlich und deswegen es ist schwer eine Uni-Lösung dafür zu finden.
          Also, wenn man nichts versteht, dann immer (sudo chmod 777 * -R) und npm unter sudo :lol:
            Abry88
            Ich habe ein ähnliches Problem.
            Habe auch das Update wie beschrieben durchgeführt.
            Nachdem ich "iobroker start" ausgeführt habe und alles gestartet ist habe ich jedoch keinen Zugriff auf die Admin oder Vis Oberfläche :(
            Obwohl alle Adapter auch der Admin läuft…
            Kann mir vielleicht jemand einen Tip geben?
              Hast du auch mal den RasPi neu gestartet?
              evtl. ist der Port doppelt besetzt, weil der admin doppelt läuft.
              Sonst gehe mal wie von Bluefox beschrieben vor und mach vorher noch ein
              sudo npm cache clean
              Rainer
                Abry88
                Hat leider keinen Erfolg :(
                Welche npm Version brauche ich denn? Aktuell ist 2.15.9 installiert und node Version ist 4.6.1
                VG Abry
                  Semenchkare
                  ich hatte das Problem auch an meinem RaspiII.
                  Hatte via Konsole eine Instanz auf einem anderen Port (8889) erzeugt. Den Befehl habe ich gerade nicht mehr hier, bitte im Forum danach suchen.
                  Danach habe ich den Admin auf dem anderen Port erreichen können. den admin.0 habe ich gelöscht, den 8889 gelöscht.
                  Dann nochmal mit 8081 einen in der Konsole erzeugt. Schwupps - es ging wieder alles Normal.
                  D.h., die Instanz war "zerschossen"
                  Viele Grüße
                  Semenchkare
                  raspberry 5 8GB mit iobroker,
                  raspberry 5 8GB mit Raspberrymatic
                    @Semenchkare:
                    Hatte via Konsole eine Instanz auf einem anderen Port (8889) erzeugt. Den Befehl habe ich gerade nicht mehr hier, `
                    http://www.iobroker.net/?page_id=3928&l … stallieren
                    Rainer
                      Abry88
                      Danke für den Tip.
                      Das hatte ich auch schon probiert. Allerdings keine Chance leider.
                      Hab es jetzt wieder zurück gesetzt.
                      Vielleicht noch als Anmerkung.
                      IoBroker läuft auf OSX und beim Update nach "iobroker upgrade self"
                      kommt folgendes:
                      __Execute: chmod 777 -R /iobroker
                      chmod: -R: No such file or directory
                      Chmod finished. Restart controller
                      Starting node restart.js__
                      Da ist ein Fehler meiner Meinung nach. Der Befehl müsste lauten:
                      "chmod -R 777 /iobroker" richtig?
                        dtp
                        Warum machst Du es nicht exakt so, wie Bluefox es geschrieben hat?
                        cd /opt/iobroker
                        sudo chmod 777 * -R
                        sudo iobroker start
                        Gruß,
                        Thorsten
                          Abry88
                          Habe ich probiert.
                          kommt die gleiche bzw ähnliche Fehlermeldung das -R kein Ordner und keine Datei ist.
                            Wenn dein System den asterisk nicht mag versuch es wirklich mal mit
                            sudo chmod -R 777 /opt/iobroker
                            Rainer
                              Abry88
                              Habe ich gemacht.
                              Der Befehl wird auch soweit umgesetzt. Das Ergebnis ist aber das gleiche.
                              Kein Zugriff auf Admin oder Vis usw..
                                Hast du nach dem chmod noch mal versucht den Controller zu installieren?
                                Und vorher ein sudo npm cache clean gemacht?
                                Rainer
                                • Alex1808A Offline
                                  Alex1808A Offline
                                  Alex1808
                                  habe auf VM und Raspberry ohne Problemen update auf 0.14.0 durchgeführt.
                                    MistyReblaus
                                    Bei meinem Problem oben habe ich es auf einem Raspi 3 installieren wollen.
                                      Abry88
                                      @Homoran
                                      ja das habe ich auch schon versucht.
                                      Kein Erfolg.
