  4. Unifi Adapter angeblich falscher Benutzer/Passwort
    6.6k
unifi
31 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • NegaleinN Negalein
    soeben sind mir diese Errors aufgefallen.
    host.iobroker	2021-02-21 00:48:14.730	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-02-21 00:48:14.730	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: Error: Not exists
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    unifi.0	2021-02-21 00:48:14.105	info	(14126) Terminated (NO_ERROR): Without reason
    unifi.0	2021-02-21 00:48:14.105	debug	(14126) Plugin sentry destroyed
    unifi.0	2021-02-21 00:48:14.103	info	(14126) terminating
    unifi.0	2021-02-21 00:48:13.897	error	(14126) Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobr
    unifi.0	2021-02-21 00:48:13.879	error	(14126) unhandled promise rejection: Not exists
    unifi.0	2021-02-21 00:48:13.878	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0	2021-02-21 00:48:13.869	debug	(14126) fetchNetworks: 1
    unifi.0	2021-02-21 00:48:13.842	info	(14126) cleaned everything up...
    unifi.0	2021-02-21 00:48:13.841	error	(14126) ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt
    unifi.0	2021-02-21 00:48:13.834	error	(14126) unhandled promise rejection: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    unifi.0	2021-02-21 00:48:13.831	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-02-21 00:48:13.807	warn	Objects 127.0.0.1:43616 Error from InMemDB: Error: ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    crunchipC Offline
    crunchipC Offline
    @negalein sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
    stimmt eventuell etwas mit deiner Voucher config nicht
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      @crunchip sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
      die hab ich noch garnicht aktiv.
      Läuft derzeit noch ohne USG.
      ° Fixer ---> iob fix
        @negalein
        und vor deiner "erneuten" Eingabe von Benutzer und Passwort ging der Adapter noch? Eventuell vertippt?
        in welchem Netzwerk läuft denn iobroker
        Starte mal den Js-Controller neu und schau ob die Meldung wieder kommt
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        Meldung kommt trotzdem
          crunchipC Offline
          crunchipC Offline
          @negalein hmm, du könntest noch node.js aktualisieren
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            komisch ist ja, dass es immer lief.
            War nur der Fehler mit Password.
            Der Adapter wurde ist aktuell seitdem ich ihn nutze.
            crunchipC F 2 Antworten Letzte Antwort
              crunchipC Offline
              crunchipC Offline
              @negalein aber den Js-Controller haste ja zwischenzeitlich angehoben, redis läuft auch schon immer, oder hast das auch erst umgestellt?
              Redis war Blödsinn, haste ja gar nicht
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Nein, der ist schon lange auf 3.1.6
                Den aktuellen verwende ich noch nicht
                Nein, hatte ich nie
                  Frank579
                  @negalein ich hatte kürzlich auch ein Problem mit dem Unifi Adapter, hatte damals eine beta vom Javascript installiert, frag aber bitte nicht welche 🙈.... Weiß auch nicht ob es die Fehlermeldung war, aber evtl. ein Versuch .Hab aktuell die 4.10.15 damit läuft es.
                    Nein, hatte ich nie
                    crunchipC Offline
                    crunchipC Offline
                    @negalein hast du den Unifi Controller selbst mal neu gestartet?
                    Was hast du alles aktiv in den Settings beim Unifi Adapter?, vllt mal bei allen die Aktualisierung deaktivieren und mal schauen, was dann im log erscheint.
                      besteht eigentlich bei irgendwem noch das Problem mit der Meldung
                      Ja, hab den Thread gerade entdeckt.
                      Controller 6.0.28
                      Controller ist IMMER erreichbar
                      Polling 34 Sek.
                      kommt ziehmlich oft
                      Heute 14:59	error	unifi.0	Error: Login required. Check username and password.
                      Heute 13:45	error	unifi.0	Error: Login required. Check username and password.
                      Heute 13:00	error	unifi.0	Error: Login required. Check username and password.
                      Heute 12:15	error	unifi.0	Error: Login required. Check username and password.
                      Heute 12:00	error	unifi.0	Error: Login required. Check username and password.
                      Heute 11:00	error	unifi.0	Error: Login required. Check username and password.
                      Heute 07:35	error	unifi.0	Error: Login required. Check username and password.
                      Heute 07:15	error	unifi.0	Error: Login required. Check username and password.
                      Heute 07:07	error	unifi.0	Error: Login required. Check username and password.
                      Heute 07:00	error	unifi.0	Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872 at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49 at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      Heute 07:00	error	unifi.0	unhandled promise rejection: Not exists
                      Heute 07:00	error	unifi.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      Heute 06:55	error	unifi.0	Error: Login required. Check username and password.
                      Heute 06:45	error	unifi.0	Error: Login required. Check username and password.
                      Heute 06:30	error	unifi.0	Error: Login required. Check username and password.
                      Heute 06:16	error	unifi.0	Error: Login required. Check username and password.
                      Heute 06:01	error	unifi.0	Error: Login required. Check username and password.
                      Heute 05:45	error	unifi.0	Error: Login required. Check username and password.
                      Heute 05:26	error	unifi.0	Error: Login required. Check username and password.
                      Heute 05:24	error	unifi.0	Error: Login required. Check username and password.
                      Hab es immer ignoriert, da eigentlich alles läuft.
                      crunchipC Offline
                      crunchipC Offline
                      Controller 6.0.28
                      hast du bewusst diese Version, aktuell ist v6.0.45
                      • F Frank579
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        @frank579 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
                        Danke! Nach downgrade auf 4.10.15 sind die host Meldungen weg.
                        auch schon neu gestartet.
                        Werde mal alles deaktivieren und dann schaun.
                        Ja, da am Anfang Meldungen auf FB waren, dass noch Fehler sind.
