  4. Unifi Adapter angeblich falscher Benutzer/Passwort
    6.6k
unifi
31 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    soeben sind mir diese Errors aufgefallen.
    host.iobroker	2021-02-21 00:48:14.730	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-02-21 00:48:14.730	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: Error: Not exists
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    unifi.0	2021-02-21 00:48:14.105	info	(14126) Terminated (NO_ERROR): Without reason
    unifi.0	2021-02-21 00:48:14.105	debug	(14126) Plugin sentry destroyed
    unifi.0	2021-02-21 00:48:14.103	info	(14126) terminating
    unifi.0	2021-02-21 00:48:13.897	error	(14126) Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobr
    unifi.0	2021-02-21 00:48:13.879	error	(14126) unhandled promise rejection: Not exists
    unifi.0	2021-02-21 00:48:13.878	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0	2021-02-21 00:48:13.869	debug	(14126) fetchNetworks: 1
    unifi.0	2021-02-21 00:48:13.842	info	(14126) cleaned everything up...
    unifi.0	2021-02-21 00:48:13.841	error	(14126) ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt
    unifi.0	2021-02-21 00:48:13.834	error	(14126) unhandled promise rejection: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    unifi.0	2021-02-21 00:48:13.831	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-02-21 00:48:13.807	warn	Objects 127.0.0.1:43616 Error from InMemDB: Error: ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    ° Fixer ---> iob fix
    S crunchipC 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      saeft_2003
      Was habt ihr bei polling time im Adapter eingestellt?
      • S saeft_2003
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @saeft_2003 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
        schon verschiedene Zeiten probiert.
        20 Sek.
        30 Sek.
        36 Sek.
        200 Sek.
        60 Sek.
        Bringt keine Änderung
          @nashra sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
          Geh mal in den Adapter und trage Name und Passwort neu ein und dann Speicherm/Beenden,
          hat bei mir geholfen d.h. seitdem keine Meldung deswegen mehr.
          hab noch immer das Problem.
          Adapter ist auch Gelb. verbunden mit Unifi: falsch
          Es werden auch die Endgeräte als Offline angezeigt, obwohl sie Online sind.
          Controller ist auch jederzeit erreichbar.
          Hier das Debug-Log von soeben
          unifi.0	2021-02-20 23:42:27.764	debug	(20641) fetchDevices: 6
          unifi.0	2021-02-20 23:42:25.275	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:25.090	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:23.783	debug	(20641) fetchDevices: 6
          unifi.0	2021-02-20 23:42:23.766	debug	(20641) fetchDevices: 6
          unifi.0	2021-02-20 23:42:23.718	debug	(20641) fetchDevices: 6
          unifi.0	2021-02-20 23:42:22.254	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:22.251	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:22.208	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:22.008	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:22.005	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:22.001	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi.0	2021-02-20 23:42:09.957	debug	(20641) system.adapter.admin.0: logging true
          unifi.0	2021-02-20 23:42:08.190	debug	(20641) system.adapter.admin.0: logging false
          unifi.0	2021-02-20 23:42:06.458	debug	(20641) fetchClients: 20
          unifi.0	2021-02-20 23:42:06.146	debug	(20641) fetchSiteSysinfo: 1
          unifi.0	2021-02-20 23:42:06.101	debug	(20641) fetchSites: default
          unifi.0	2021-02-20 23:42:06.056	debug	(20641) Login successful
          unifi.0	2021-02-20 23:42:05.475	debug	(20641) Update started
          unifi.0	2021-02-20 23:41:42.051	debug	(20641) fetchClients: 20
          unifi.0	2021-02-20 23:41:38.231	debug	(20641) fetchSiteSysinfo: 1
          unifi.0	2021-02-20 23:41:38.187	debug	(20641) fetchSites: default
          unifi.0	2021-02-20 23:41:38.155	debug	(20641) Login successful
          unifi.0	2021-02-20 23:41:37.463	debug	(20641) Update started
          unifi.0	2021-02-20 23:41:10.576	debug	(20641) fetchClients: 20
          unifi.0	2021-02-20 23:41:10.142	debug	(20641) fetchSiteSysinfo: 1
          unifi.0	2021-02-20 23:41:10.112	debug	(20641) fetchSites: default
          unifi.0	2021-02-20 23:41:10.088	debug	(20641) Login successful
          unifi.0	2021-02-20 23:41:09.453	debug	(20641) Update started
          unifi.0	2021-02-20 23:40:45.657	debug	(20641) system.adapter.admin.0: logging true
          unifi.0	2021-02-20 23:40:45.170	debug	(20641) fetchClients: 20
          unifi.0	2021-02-20 23:40:42.698	debug	(20641) fetchSiteSysinfo: 1
          unifi.0	2021-02-20 23:40:42.636	debug	(20641) fetchSites: default
          unifi.0	2021-02-20 23:40:42.601	debug	(20641) Login successful
          unifi.0	2021-02-20 23:40:41.083	debug	(20641) Update started
          unifi.0	2021-02-20 23:40:41.082	debug	(20641) updateInterval = 28
          unifi.0	2021-02-20 23:40:41.078	debug	(20641) controller = 10.0.1.151:8443
          unifi.0	2021-02-20 23:40:41.015	info	(20641) UniFi adapter is ready
          unifi.0	2021-02-20 23:40:40.948	info	(20641) starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.18.3, js-controller: 3.1.6
          unifi.0	2021-02-20 23:40:40.340	debug	(20641) Plugin sentry Initialize Plugin (enabled=true)
          unifi.0	2021-02-20 23:40:37.932	debug	(20641) statesDB connected
          unifi.0	2021-02-20 23:40:37.931	debug	(20641) States connected to redis: 0.0.0.0:9000
          unifi.0	2021-02-20 23:40:37.841	debug	(20641) States create System PubSub Client
          unifi.0	2021-02-20 23:40:37.827	debug	(20641) States create User PubSub Client
          unifi.0	2021-02-20 23:40:37.776	debug	(20641) Redis States: Use Redis connection: 0.0.0.0:9000
          unifi.0	2021-02-20 23:40:37.763	debug	(20641) objectDB connected
          unifi.0	2021-02-20 23:40:37.721	debug	(20641) Objects connected to redis: 0.0.0.0:9001
          unifi.0	2021-02-20 23:40:37.614	debug	(20641) Objects client initialize lua scripts
          unifi.0	2021-02-20 23:40:37.612	debug	(20641) Objects create User PubSub Client
          unifi.0	2021-02-20 23:40:37.611	debug	(20641) Objects create System PubSub Client
          unifi.0	2021-02-20 23:40:37.590	debug	(20641) Objects client ready ... initialize now
          unifi.0	2021-02-20 23:40:37.499	debug	(20641) Redis Objects: Use Redis connection: 0.0.0.0:9001
          unifi.0	2021-02-20 23:40:30.740	info	(19932) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          unifi.0	2021-02-20 23:40:30.738	info	(19932) terminating
          unifi.0	2021-02-20 23:40:30.735	info	(19932) cleaned everything up...
          unifi.0	2021-02-20 23:40:30.732	info	(19932) Got terminate signal TERMINATE_YOURSELF
          unifi.0	2021-02-20 23:40:19.059	info	(19932) UniFi adapter is ready
          unifi.0	2021-02-20 23:40:19.009	info	(19932) starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.18.3, js-controller: 3.1.6
          unifi.0	2021-02-20 23:40:01.939	info	(4519) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          unifi.0	2021-02-20 23:40:01.937	info	(4519) terminating
          unifi.0	2021-02-20 23:40:01.936	info	(4519) cleaned everything up...
          unifi.0	2021-02-20 23:40:01.930	info	(4519) Got terminate signal TERMINATE_YOURSELF
          crunchipC Offline
          crunchipC Offline
          @negalein
          und vor deiner "erneuten" Eingabe von Benutzer und Passwort ging der Adapter noch? Eventuell vertippt?
          in welchem Netzwerk läuft denn iobroker
          Starte mal den Js-Controller neu und schau ob die Meldung wieder kommt
          NegaleinN 2 Antworten Letzte Antwort
            @negalein
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @crunchip sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
            Ja und Nein
            War vorher auch schon ab und zu (Meldung Error: Login required. Check username and password.).
            Aber nicht mit den Errors wie gerade.
            Passwort 1000%ig richtig
            Im selben wie der Controller
            ioBroker: 10.0.1.200
            Controller: 10.0.1.151
            Hab noch keine VLAN laufen.
            mach ich noch 👍
              crunchipC Offline
              crunchipC Offline
              @negalein sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
              stimmt eventuell etwas mit deiner Voucher config nicht
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                die hab ich noch garnicht aktiv.
                Läuft derzeit noch ohne USG.
                  @negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  Meldung kommt trotzdem
                    crunchipC Offline
                    crunchipC Offline
                    @negalein hmm, du könntest noch node.js aktualisieren
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      komisch ist ja, dass es immer lief.
                      War nur der Fehler mit Password.
                      Der Adapter wurde ist aktuell seitdem ich ihn nutze.
                      crunchipC F 2 Antworten Letzte Antwort
                        crunchipC Offline
                        crunchipC Offline
                        @negalein aber den Js-Controller haste ja zwischenzeitlich angehoben, redis läuft auch schon immer, oder hast das auch erst umgestellt?
                        Redis war Blödsinn, haste ja gar nicht
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Nein, der ist schon lange auf 3.1.6
                          Den aktuellen verwende ich noch nicht
                          Nein, hatte ich nie
                            Frank579
                            @negalein ich hatte kürzlich auch ein Problem mit dem Unifi Adapter, hatte damals eine beta vom Javascript installiert, frag aber bitte nicht welche 🙈.... Weiß auch nicht ob es die Fehlermeldung war, aber evtl. ein Versuch .Hab aktuell die 4.10.15 damit läuft es.
                              Nein, hatte ich nie
                              crunchipC Offline
                              crunchipC Offline
                              @negalein hast du den Unifi Controller selbst mal neu gestartet?
                              Was hast du alles aktiv in den Settings beim Unifi Adapter?, vllt mal bei allen die Aktualisierung deaktivieren und mal schauen, was dann im log erscheint.
                                besteht eigentlich bei irgendwem noch das Problem mit der Meldung
                                Ja, hab den Thread gerade entdeckt.
                                Controller 6.0.28
                                Controller ist IMMER erreichbar
                                Polling 34 Sek.
                                kommt ziehmlich oft
                                Heute 14:59	error	unifi.0	Error: Login required. Check username and password.
                                Heute 13:45	error	unifi.0	Error: Login required. Check username and password.
                                Heute 13:00	error	unifi.0	Error: Login required. Check username and password.
                                Heute 12:15	error	unifi.0	Error: Login required. Check username and password.
                                Heute 12:00	error	unifi.0	Error: Login required. Check username and password.
                                Heute 11:00	error	unifi.0	Error: Login required. Check username and password.
                                Heute 07:35	error	unifi.0	Error: Login required. Check username and password.
                                Heute 07:15	error	unifi.0	Error: Login required. Check username and password.
                                Heute 07:07	error	unifi.0	Error: Login required. Check username and password.
                                Heute 07:00	error	unifi.0	Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872 at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49 at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                Heute 07:00	error	unifi.0	unhandled promise rejection: Not exists
                                Heute 07:00	error	unifi.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                Heute 06:55	error	unifi.0	Error: Login required. Check username and password.
                                Heute 06:45	error	unifi.0	Error: Login required. Check username and password.
                                Heute 06:30	error	unifi.0	Error: Login required. Check username and password.
                                Heute 06:16	error	unifi.0	Error: Login required. Check username and password.
                                Heute 06:01	error	unifi.0	Error: Login required. Check username and password.
                                Heute 05:45	error	unifi.0	Error: Login required. Check username and password.
                                Heute 05:26	error	unifi.0	Error: Login required. Check username and password.
                                Heute 05:24	error	unifi.0	Error: Login required. Check username and password.
                                Hab es immer ignoriert, da eigentlich alles läuft.
                                crunchipC Offline
                                crunchipC Offline
                                Controller 6.0.28
                                hast du bewusst diese Version, aktuell ist v6.0.45
                                • F Frank579
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  @frank579 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
                                  Danke! Nach downgrade auf 4.10.15 sind die host Meldungen weg.
                                  auch schon neu gestartet.
                                  Werde mal alles deaktivieren und dann schaun.
                                  Ja, da am Anfang Meldungen auf FB waren, dass noch Fehler sind.
