  4. Unifi Adapter angeblich falscher Benutzer/Passwort
    6.6k
unifi
31 Beiträge 6 Kommentatoren 2.2k Aufrufe 6 Beobachtet
  • NegaleinN Negalein
    soeben sind mir diese Errors aufgefallen.
    host.iobroker	2021-02-21 00:48:14.730	info	Restart adapter system.adapter.unifi.0 because enabled
    host.iobroker	2021-02-21 00:48:14.730	info	instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at runMicrotasks (<anonymous>)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.iobroker	2021-02-21 00:48:14.729	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: Error: Not exists
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    host.iobroker	2021-02-21 00:48:14.728	error	Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    host.iobroker	2021-02-21 00:48:14.727	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
    unifi.0	2021-02-21 00:48:14.105	info	(14126) Terminated (NO_ERROR): Without reason
    unifi.0	2021-02-21 00:48:14.105	debug	(14126) Plugin sentry destroyed
    unifi.0	2021-02-21 00:48:14.103	info	(14126) terminating
    unifi.0	2021-02-21 00:48:13.897	error	(14126) Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobr
    unifi.0	2021-02-21 00:48:13.879	error	(14126) unhandled promise rejection: Not exists
    unifi.0	2021-02-21 00:48:13.878	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    unifi.0	2021-02-21 00:48:13.869	debug	(14126) fetchNetworks: 1
    unifi.0	2021-02-21 00:48:13.842	info	(14126) cleaned everything up...
    unifi.0	2021-02-21 00:48:13.841	error	(14126) ReplyError: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt
    unifi.0	2021-02-21 00:48:13.834	error	(14126) unhandled promise rejection: Error ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    unifi.0	2021-02-21 00:48:13.831	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.iobroker	2021-02-21 00:48:13.807	warn	Objects 127.0.0.1:43616 Error from InMemDB: Error: ERROR delObject unifi.0.default.vouchers.voucher_.duration: Not exists
    saeft_2003
    Was habt ihr bei polling time im Adapter eingestellt?
    • S saeft_2003
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      @saeft_2003 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
      schon verschiedene Zeiten probiert.
      20 Sek.
      30 Sek.
      36 Sek.
      200 Sek.
      60 Sek.
      Bringt keine Änderung
      ° Fixer ---> iob fix
        @nashra sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
        Geh mal in den Adapter und trage Name und Passwort neu ein und dann Speicherm/Beenden,
        hat bei mir geholfen d.h. seitdem keine Meldung deswegen mehr.
        hab noch immer das Problem.
        Adapter ist auch Gelb. verbunden mit Unifi: falsch
        Es werden auch die Endgeräte als Offline angezeigt, obwohl sie Online sind.
        Controller ist auch jederzeit erreichbar.
        Hier das Debug-Log von soeben
        unifi.0	2021-02-20 23:42:27.764	debug	(20641) fetchDevices: 6
        unifi.0	2021-02-20 23:42:25.275	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:25.090	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:23.783	debug	(20641) fetchDevices: 6
        unifi.0	2021-02-20 23:42:23.766	debug	(20641) fetchDevices: 6
        unifi.0	2021-02-20 23:42:23.718	debug	(20641) fetchDevices: 6
        unifi.0	2021-02-20 23:42:22.254	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:22.251	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:22.208	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:22.008	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:22.005	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:22.001	debug	(20641) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        unifi.0	2021-02-20 23:42:09.957	debug	(20641) system.adapter.admin.0: logging true
        unifi.0	2021-02-20 23:42:08.190	debug	(20641) system.adapter.admin.0: logging false
        unifi.0	2021-02-20 23:42:06.458	debug	(20641) fetchClients: 20
        unifi.0	2021-02-20 23:42:06.146	debug	(20641) fetchSiteSysinfo: 1
        unifi.0	2021-02-20 23:42:06.101	debug	(20641) fetchSites: default
        unifi.0	2021-02-20 23:42:06.056	debug	(20641) Login successful
        unifi.0	2021-02-20 23:42:05.475	debug	(20641) Update started
        unifi.0	2021-02-20 23:41:42.051	debug	(20641) fetchClients: 20
        unifi.0	2021-02-20 23:41:38.231	debug	(20641) fetchSiteSysinfo: 1
        unifi.0	2021-02-20 23:41:38.187	debug	(20641) fetchSites: default
        unifi.0	2021-02-20 23:41:38.155	debug	(20641) Login successful
        unifi.0	2021-02-20 23:41:37.463	debug	(20641) Update started
        unifi.0	2021-02-20 23:41:10.576	debug	(20641) fetchClients: 20
        unifi.0	2021-02-20 23:41:10.142	debug	(20641) fetchSiteSysinfo: 1
        unifi.0	2021-02-20 23:41:10.112	debug	(20641) fetchSites: default
        unifi.0	2021-02-20 23:41:10.088	debug	(20641) Login successful
        unifi.0	2021-02-20 23:41:09.453	debug	(20641) Update started
        unifi.0	2021-02-20 23:40:45.657	debug	(20641) system.adapter.admin.0: logging true
        unifi.0	2021-02-20 23:40:45.170	debug	(20641) fetchClients: 20
        unifi.0	2021-02-20 23:40:42.698	debug	(20641) fetchSiteSysinfo: 1
        unifi.0	2021-02-20 23:40:42.636	debug	(20641) fetchSites: default
        unifi.0	2021-02-20 23:40:42.601	debug	(20641) Login successful
        unifi.0	2021-02-20 23:40:41.083	debug	(20641) Update started
        unifi.0	2021-02-20 23:40:41.082	debug	(20641) updateInterval = 28
        unifi.0	2021-02-20 23:40:41.078	debug	(20641) controller = 10.0.1.151:8443
        unifi.0	2021-02-20 23:40:41.015	info	(20641) UniFi adapter is ready
        unifi.0	2021-02-20 23:40:40.948	info	(20641) starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.18.3, js-controller: 3.1.6
        unifi.0	2021-02-20 23:40:40.340	debug	(20641) Plugin sentry Initialize Plugin (enabled=true)
        unifi.0	2021-02-20 23:40:37.932	debug	(20641) statesDB connected
        unifi.0	2021-02-20 23:40:37.931	debug	(20641) States connected to redis: 0.0.0.0:9000
        unifi.0	2021-02-20 23:40:37.841	debug	(20641) States create System PubSub Client
        unifi.0	2021-02-20 23:40:37.827	debug	(20641) States create User PubSub Client
        unifi.0	2021-02-20 23:40:37.776	debug	(20641) Redis States: Use Redis connection: 0.0.0.0:9000
        unifi.0	2021-02-20 23:40:37.763	debug	(20641) objectDB connected
        unifi.0	2021-02-20 23:40:37.721	debug	(20641) Objects connected to redis: 0.0.0.0:9001
        unifi.0	2021-02-20 23:40:37.614	debug	(20641) Objects client initialize lua scripts
        unifi.0	2021-02-20 23:40:37.612	debug	(20641) Objects create User PubSub Client
        unifi.0	2021-02-20 23:40:37.611	debug	(20641) Objects create System PubSub Client
        unifi.0	2021-02-20 23:40:37.590	debug	(20641) Objects client ready ... initialize now
        unifi.0	2021-02-20 23:40:37.499	debug	(20641) Redis Objects: Use Redis connection: 0.0.0.0:9001
        unifi.0	2021-02-20 23:40:30.740	info	(19932) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        unifi.0	2021-02-20 23:40:30.738	info	(19932) terminating
        unifi.0	2021-02-20 23:40:30.735	info	(19932) cleaned everything up...
        unifi.0	2021-02-20 23:40:30.732	info	(19932) Got terminate signal TERMINATE_YOURSELF
        unifi.0	2021-02-20 23:40:19.059	info	(19932) UniFi adapter is ready
        unifi.0	2021-02-20 23:40:19.009	info	(19932) starting. Version 0.5.8 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.18.3, js-controller: 3.1.6
        unifi.0	2021-02-20 23:40:01.939	info	(4519) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        unifi.0	2021-02-20 23:40:01.937	info	(4519) terminating
        unifi.0	2021-02-20 23:40:01.936	info	(4519) cleaned everything up...
        unifi.0	2021-02-20 23:40:01.930	info	(4519) Got terminate signal TERMINATE_YOURSELF
        crunchipC Abwesend
        crunchipC Abwesend
        @negalein
        und vor deiner "erneuten" Eingabe von Benutzer und Passwort ging der Adapter noch? Eventuell vertippt?
        in welchem Netzwerk läuft denn iobroker
        Starte mal den Js-Controller neu und schau ob die Meldung wieder kommt
        NegaleinN 2 Antworten Letzte Antwort
          @negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          @crunchip sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
          Ja und Nein
          War vorher auch schon ab und zu (Meldung Error: Login required. Check username and password.).
          Aber nicht mit den Errors wie gerade.
          Passwort 1000%ig richtig
          Im selben wie der Controller
          ioBroker: 10.0.1.200
          Controller: 10.0.1.151
          Hab noch keine VLAN laufen.
          mach ich noch 👍
            crunchipC Abwesend
            crunchipC Abwesend
            @negalein sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
            stimmt eventuell etwas mit deiner Voucher config nicht
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              die hab ich noch garnicht aktiv.
              Läuft derzeit noch ohne USG.
                @negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                Meldung kommt trotzdem
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @negalein hmm, du könntest noch node.js aktualisieren
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    komisch ist ja, dass es immer lief.
                    War nur der Fehler mit Password.
                    Der Adapter wurde ist aktuell seitdem ich ihn nutze.
                    crunchipC F 2 Antworten Letzte Antwort
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @negalein aber den Js-Controller haste ja zwischenzeitlich angehoben, redis läuft auch schon immer, oder hast das auch erst umgestellt?
                      Redis war Blödsinn, haste ja gar nicht
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        Nein, der ist schon lange auf 3.1.6
                        Den aktuellen verwende ich noch nicht
                        Nein, hatte ich nie
                          Frank579
                          @negalein ich hatte kürzlich auch ein Problem mit dem Unifi Adapter, hatte damals eine beta vom Javascript installiert, frag aber bitte nicht welche 🙈.... Weiß auch nicht ob es die Fehlermeldung war, aber evtl. ein Versuch .Hab aktuell die 4.10.15 damit läuft es.
                            Nein, hatte ich nie
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @negalein hast du den Unifi Controller selbst mal neu gestartet?
                            Was hast du alles aktiv in den Settings beim Unifi Adapter?, vllt mal bei allen die Aktualisierung deaktivieren und mal schauen, was dann im log erscheint.
                              besteht eigentlich bei irgendwem noch das Problem mit der Meldung
                              Ja, hab den Thread gerade entdeckt.
                              Controller 6.0.28
                              Controller ist IMMER erreichbar
                              Polling 34 Sek.
                              kommt ziehmlich oft
                              Heute 14:59	error	unifi.0	Error: Login required. Check username and password.
                              Heute 13:45	error	unifi.0	Error: Login required. Check username and password.
                              Heute 13:00	error	unifi.0	Error: Login required. Check username and password.
                              Heute 12:15	error	unifi.0	Error: Login required. Check username and password.
                              Heute 12:00	error	unifi.0	Error: Login required. Check username and password.
                              Heute 11:00	error	unifi.0	Error: Login required. Check username and password.
                              Heute 07:35	error	unifi.0	Error: Login required. Check username and password.
                              Heute 07:15	error	unifi.0	Error: Login required. Check username and password.
                              Heute 07:07	error	unifi.0	Error: Login required. Check username and password.
                              Heute 07:00	error	unifi.0	Error: Not exists at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1588:72 at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2999:68 at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93872 at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49 at runMicrotasks () at processTicksAndRejections (internal/process/task_queues.js:97:5)
                              Heute 07:00	error	unifi.0	unhandled promise rejection: Not exists
                              Heute 07:00	error	unifi.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              Heute 06:55	error	unifi.0	Error: Login required. Check username and password.
                              Heute 06:45	error	unifi.0	Error: Login required. Check username and password.
                              Heute 06:30	error	unifi.0	Error: Login required. Check username and password.
                              Heute 06:16	error	unifi.0	Error: Login required. Check username and password.
                              Heute 06:01	error	unifi.0	Error: Login required. Check username and password.
                              Heute 05:45	error	unifi.0	Error: Login required. Check username and password.
                              Heute 05:26	error	unifi.0	Error: Login required. Check username and password.
                              Heute 05:24	error	unifi.0	Error: Login required. Check username and password.
                              Hab es immer ignoriert, da eigentlich alles läuft.
                              crunchipC Abwesend
                              crunchipC Abwesend
                              Controller 6.0.28
                              hast du bewusst diese Version, aktuell ist v6.0.45
                              • F Frank579
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @frank579 sagte in Unifi Adapter angeblich falscher Benutzer/Passwort:
                                Danke! Nach downgrade auf 4.10.15 sind die host Meldungen weg.
                                auch schon neu gestartet.
                                Werde mal alles deaktivieren und dann schaun.
                                Ja, da am Anfang Meldungen auf FB waren, dass noch Fehler sind.
