  4. Diskussion zum HowTo nodejs-Installation und upgrade
    1.0k
    6.1k
nodejs
844 Beiträge 91 Kommentatoren 309.0k Aufrufe 63 Beobachtet
  • T tschombe
    danke für die rückmeldung,
    wow das diag kannte ich bisher nicht, hier die komplette info,
    sieht irgendwie ziemlich kaputt aus:
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v7+
    Installation:           Native
    Timezone:               Europe/Berlin (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Uncaught Rejection: Error: Cannot find module '@sentry/integrations'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginHandler.js
    - /opt/iobroker/node_modules/@iobroker/plugin-base/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1026:15)
        at Function.Module._load (node:internal/modules/cjs/loader:871:27)
        at Module.require (node:internal/modules/cjs/loader:1098:19)
        at require (node:internal/modules/cjs/helpers:108:18)
        at SentryPlugin._registerSentry (/opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js:103:36)
        at SentryPlugin.init (/opt/iobroker/node_modules/@iobroker/plugin-sentry/index.js:96:14)
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.0
                            /usr/bin/node           v16.20.0
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            922M        166M        320M        0.0K        435M        690M
    Swap:             0B          0B          0B
    Total:          922M        166M        320M
    Require stack:
    Active iob-Instances:   0
    Require stack:
    ioBroker Core:          js-controller           4.0.24
                            admin                   "admin" not found
    Require stack:
    ioBroker Status:
    Require stack:
    Objects:                0
    States:                 0
    Size of iob-Database:
    4.8M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.7M    /opt/iobroker/iobroker-data/objects.jsonl
    4.0K    /opt/iobroker/iobroker-data/states.json
    #561
    @tschombe sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
    New, das ist die Zusammenfassung. Der vollständige Kram steht davor.
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    liefert?
    1GB ist erfahrungsgemäß mittlerweile aber auch zu wenig für einen sinnvollen Betrieb des iobrokers.
      tschombe
      #562
      ok, dh man sollte direkt auf einen raspi 4 gehen?
      dann muss ich mal hardware shopping gehen
      wie lange läuft dieses script? scheint sich bei mir igendwie hier aufgehangen zu haben,
      oder braucht das evtl relativ lange:
      pi@homematicPI:/opt/iobroker $ cd /opt/iobroker
      pi@homematicPI:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      (##################) ⠇ reify:iobroker.admin: timing reifyNode:node_modules/iobroker.javascript Completed in 79961ms
      es ist noch nicht vollständig durchgelaufen
        tschombe
        #563
        anscheinend wurde es irgendwie abgebrochen:
        Getötet############) ⠇ reify:iobroker.admin: timing reifyNode:node_modules/iobroker.javascript Completed in 79961ms
        • frank2604F Offline
          frank2604F Offline
          frank2604
          #564
          Ich möchte von node.js 14 auf 18 updaten.
          Laut der Anleitung wird ein sauber npm-tree benötigt.
          Überprüfung mit
          cd /opt/iobroker
          npm ls | grep -E 'github|ERR'
          ergibt bei mir:
          │ │ │ ├── github-from-package@0.0.0
          npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
          npm ERR! peer dep missing: @iobroker/types@^5.0.11, required by @iobroker/adapter-core@3.0.3
          Und nun?
          Intel NUC8 i3, Proxmox, VM Ubuntu, ioBroker
          Philips HUE, Homematic CCU3, Zigbee, Yamaha MusicCast, Vorwerk ...
          • frank2604F frank2604
            Überprüfung mit
            cd /opt/iobroker
            ergibt bei mir:
            Und nun?
            #565
            @frank2604 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
            Und nun?
            Nichts. Weiter machen.
            Ich hab es im HowTo ergänzt.
            frank2604F 1 Antwort Letzte Antwort
              Und nun?
              frank2604F Offline
              frank2604F Offline
              frank2604
              #566
              Danke. Ist soweit alles fehlerfrei durchgelaufen.
              Alle Instanzen bis auf den Zigbee laufen wieder. Der meldet im Log folgendes:
              host.vm-iobroker-02
              2023-08-12 11:31:07.119	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              host.vm-iobroker-02
              2023-08-12 11:31:07.119	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.vm-iobroker-02
              2023-08-12 11:31:07.119	error	Caught by controller[0]: Node.js v18.17.1
              host.vm-iobroker-02
              2023-08-12 11:31:07.119	error	Caught by controller[0]: }
              host.vm-iobroker-02
              2023-08-12 11:31:07.119	error	Caught by controller[0]: ]
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js',
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: requireStack: [
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:21:1)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
              host.vm-iobroker-02
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: Require stack:
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
              host.vm-iobroker-02
              2023-08-12 11:31:07.118	error	Caught by controller[0]: ^
              host.vm-iobroker-02
              2023-08-12 11:31:07.117	error	Caught by controller[0]: throw err;
              host.vm-iobroker-02
              2023-08-12 11:31:07.117	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
              host.vm-iobroker-02
              2023-08-12 11:31:06.702	info	instance system.adapter.zigbee.0 started with pid 14766
              host.vm-iobroker-02
              2023-08-12 11:31:06.600	info	"system.adapter.zigbee.0" enabled
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                host.vm-iobroker-02
                frank2604F Offline
                frank2604F Offline
                frank2604
                #567
                @Thomas-Braun
                Hat sich erledigt. Habe im Verzeichnis:
                das ausgeführt:
                Jetzt läuft auch Zigbee wieder.
                  skorpil
                  #568
                  Als Node und Linux dummy habe ich folgende Frage:
                  Mein ioBroker meldet seit gestern , dass es wohl neue Versionen gibt:
                  Node.js: v18.17.1(18.18.0)
                  NPM: 9.6.7(9.8.1)
                  Ich habe mit sudo apt-get Update und Upgrade versucht, die Updates durchzuführen. Es bleibt aber alles beim Alten. Die anschließende Abfrage zeigt:
                  nodejs:
                  Installiert: 18.17.1-deb-1nodesource1
                  Installationskandidat: 18.17.1-deb-1nodesource1
                  Versionstabelle:
                  *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
                  12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                  12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                  Frage an die Profis: was mache ich falsch? Wie installiere ich Node.js 18.18.0 bzw. Npm 9.8.1? Bzw. sollte ich das überhaupt updated?
                  W 1 Antwort Letzte Antwort
                  • S skorpil
                    NPM: 9.6.7(9.8.1)
                    nodejs:
                    Versionstabelle:
                    W Online
                    W Online
                    Wildbill
                    #569
                    @skorpil Schau ein Stück weiter oben in die Signatur von @Thomas-Braun . Da gibt es einen Link zu einem NodeJS Fixer Skript.
                    Das aktualisiert Dir auf die aktuelle Version 18.18.0 (die Du auch verwenden solltest).
                    Gruss, Jürgen
                    S 2 Antworten Letzte Antwort
                    • W Wildbill
                      Gruss, Jürgen
                      skorpil
                      #570
                      @wildbill Dankeschön, das hatte ich offenbar überlesen. Ich werde es so versuchen.
                      • W Wildbill
                        Gruss, Jürgen
                        skorpil
                        #571
                        @wildbill feedback is breakfast for champions: hat funktioniert. Danke!
                          mcreuter
                          #572
                          Hey so sieht es aus wenn ich die Installation nochmal durchgehe:
                          Von allein wollte der nicht auf die neuste Version!
                          System latest offizelles Docker Image...
                          Ich hoffe das es damit gerade gezogen und aktuell ist.
                          Vielleicht kann mir jemand das bestätigen??
                          DANKE
                          root@iobroker:/opt/iobroker# uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt
                          update &> /dev/null && sudo apt update && apt policy nodejs
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          /usr/bin/npx
                          /usr/bin/corepack
                          v18.18.0
                          v18.18.0
                          9.8.1
                          9.8.1
                          0.19.0
                          5.0.12
                          root
                          root
                          /opt/iobroker
                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists... Done
                          Building dependency tree... Done
                          All packages are up to date.
                          nodejs:
                            Installed: 18.18.0-1nodesource1
                            Candidate: 18.18.0-1nodesource1
                            Version table:
                           *** 18.18.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                                  500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                          Mod-EDIT: Code in Code-Tags setzen!
                          • M mcreuter
                            DANKE
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            /usr/bin/corepack
                            v18.18.0
                            v18.18.0
                            9.8.1
                            9.8.1
                            0.19.0
                            5.0.12
                            root
                            root
                            /opt/iobroker
                            nodejs:
                              Version table:
                            #573
                            @mcreuter
                            Beim Docker zieht man sich i. A. einen frischen aus dem Regal.
                              @mcreuter
                              mcreuter
                              #574
                              Was meinst du damit genau?
                              Der Docker Container Manager zieht sich immer das latest Image und migriert diese direkt.
                              https://registry.hub.docker.com/r/iobroker/iobroker/
                              Aber updaten tut sich da kein Node und npm.... Habe das immer manuell gemacht bisher...
                              Nur jetzt über die neue Methode von dir, da die alte nicht mehr ging :_)
                              • M mcreuter
                                #575
                                @mcreuter sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                Ich hab ja keine Aktien in den Dingern, aber die kommen eigentlich immer mit passender Umgebung vorgekocht daher. Ich glaube in der Version 9 des Docker-Images ist dann auch nodejs@18.18.0 eingebacken.
                                  mcreuter
                                  #576
                                  @thomas-braun Ok, kein Ding kann man ja buanet mal fragen...
                                  https://github.com/buanet/ioBroker.docker
                                  JA kann sein, die V9 ist als Beta pre Release schon in arbeit mit Debian 12 soweit ich das gesehen habe :-)
                                  https://github.com/buanet/ioBroker.docker/tree/v9.0.0-beta.1
                                  • Änderungen:
                                    remove special settings script and env for zwave (#377)
                                    simplify ci/ reduce gh actions
                                    ignore errors in "silent cleanup" on first start (#369)
                                    cleanup/ restructure repo
                                    update nodejs setup process
                                    update base image to debian 12 (bookworm)
                                    improve security by avoiding root (exept startup script itself)
                                    restrict iobroker commanline commands (start/ stop/ node fix)
                                    integrate maintenance script into iobroker command
                                    move container config files location
                                  • J Offline
                                    Jack01
                                    schrieb am zuletzt editiert von Jack01
                                    #577
                                    Auch bei mir hat der normale Befehl per update und upgrade nicht zum Erfolg geführt. Ich habe dann den Link von @thomas-braun genutzt und den iob node fix laufen lassen. Das hat geklappt. Verstanden habe ich es aber nicht, da die Pfade ja scheinbar richtig waren und frühere Updates immer funktioniert haben.
                                    Vielen Dank an alle Helfer!
                                    ioBroker nodejs fixer 2023-09-24
                                    Recommended nodejs-version is: 18.18.0
                                    Checking your installation now. Please be patient!
                                    Your current setup is:
                                    /usr/bin/nodejs         v18.17.1
                                    /usr/bin/node           v18.17.1
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    /usr/bin/corepack       0.18.0
                                    We found these nodejs versions available for installation:
                                    nodejs:
                                      Installed: 18.17.1-deb-1nodesource1
                                      Candidate: 18.17.1-deb-1nodesource1
                                      Version table:
                                            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    Nothing to do - Your installation is using the correct paths.
                                    You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                                    Press <y> to continue or any other key to quit
                                    Trying to fix your installation now. Please be patient.
                                    Waiting for ioBroker to shut down - Give me a minute...
                                    *** These repos are active on your system:
                                    Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                    Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                                    Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
                                    Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
                                    Fetched 694 kB in 2s (399 kB/s)
                                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                                    Package: nodejs
                                    Pin: origin deb.nodesource.com
                                    Pin-Priority: 1001
                                    *** These repos are active after the adjustments:
                                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:4 https://repos.influxdata.com/debian stable InRelease
                                    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                                    Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                                    Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
                                    Fetched 22.7 kB in 2s (9910 B/s)
                                    Installing the recommended nodejs version now!
                                    (Reading database ... 50588 files and directories currently installed.)
                                    Preparing to unpack .../nodejs_18.18.0-1nodesource1_arm64.deb ...
                                    Detected old npm client, removing...
                                    Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                                    Setting up nodejs (18.18.0-1nodesource1) ...
                                    Processing triggers for man-db (2.9.4-2) ...
                                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                                    *** RESTARTING ioBroker NOW! ***
                                     Please refresh or restart your browser in a few moments.
                                    pi@raspberrypi:/opt/iobroker $
                                    Proxmox LXC
                                    Node.js: V22.22.2
                                    NPM: 10.9.7
                                    JS-controller: 7.0.7
                                    • J Jack01
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      Package: nodejs
                                      Pin-Priority: 1001
                                      #578
                                      @jack01 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                      Der Aufbau der Paketquelle hat sich geändert und daher muss entsprechend in deinem System auch einiges umgestellt werden. Neue Versionen von nodejs kommen nur noch über das neue Repository.
                                      Das node-fix-Skript nimmt dir das weitgehend ab.
                                      J 1 Antwort Letzte Antwort
                                        Jack01
                                        #579
                                        @thomas-braun OK, Danke.
                                        Ist das so dann OK für künftige Updates oder muß ich jetzt noch etwas manuell anpassen?
                                        Proxmox LXC
                                        Node.js: V22.22.2
                                        NPM: 10.9.7
                                        • J Jack01
                                          #580
                                          @jack01
                                          Künftige Updates laufen jetzt wieder wie gehabt über den üblichen
                                          sudo apt update
                                          sudo apt full-upgrade
                                          Weg mit.
