  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 327.9k Aufrufe 63 Beobachtet
  • frank2604F frank2604
    Danke. Ist soweit alles fehlerfrei durchgelaufen.
    Alle Instanzen bis auf den Zigbee laufen wieder. Der meldet im Log folgendes:
    host.vm-iobroker-02
    2023-08-12 11:31:07.119	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.vm-iobroker-02
    2023-08-12 11:31:07.119	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.vm-iobroker-02
    2023-08-12 11:31:07.119	error	Caught by controller[0]: Node.js v18.17.1
    host.vm-iobroker-02
    2023-08-12 11:31:07.119	error	Caught by controller[0]: }
    host.vm-iobroker-02
    2023-08-12 11:31:07.119	error	Caught by controller[0]: ]
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js',
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: requireStack: [
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:21:1)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    host.vm-iobroker-02
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: Require stack:
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: Error: Cannot find module '@iobroker/types'
    host.vm-iobroker-02
    2023-08-12 11:31:07.118	error	Caught by controller[0]: ^
    host.vm-iobroker-02
    2023-08-12 11:31:07.117	error	Caught by controller[0]: throw err;
    host.vm-iobroker-02
    2023-08-12 11:31:07.117	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
    host.vm-iobroker-02
    2023-08-12 11:31:06.702	info	instance system.adapter.zigbee.0 started with pid 14766
    host.vm-iobroker-02
    2023-08-12 11:31:06.600	info	"system.adapter.zigbee.0" enabled
    frank2604F Offline
    frank2604F Offline
    frank2604
    #567
    @Thomas-Braun
    Hat sich erledigt. Habe im Verzeichnis:
    das ausgeführt:
    Jetzt läuft auch Zigbee wieder.
    Intel NUC8 i3, Proxmox, VM Ubuntu, ioBroker
    Philips HUE, Homematic CCU3, Zigbee, Yamaha MusicCast, Vorwerk ...
      skorpil
      #568
      Als Node und Linux dummy habe ich folgende Frage:
      Mein ioBroker meldet seit gestern , dass es wohl neue Versionen gibt:
      Node.js: v18.17.1(18.18.0)
      NPM: 9.6.7(9.8.1)
      Ich habe mit sudo apt-get Update und Upgrade versucht, die Updates durchzuführen. Es bleibt aber alles beim Alten. Die anschließende Abfrage zeigt:
      nodejs:
      Installiert: 18.17.1-deb-1nodesource1
      Installationskandidat: 18.17.1-deb-1nodesource1
      Versionstabelle:
      *** 18.17.1-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
      12.22.12~dfsg-1~deb11u4 500
      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      12.22.12~dfsg-1~deb11u3 500
      500 http://deb.debian.org/debian bullseye/main amd64 Packages
      Frage an die Profis: was mache ich falsch? Wie installiere ich Node.js 18.18.0 bzw. Npm 9.8.1? Bzw. sollte ich das überhaupt updated?
      W 1 Antwort Letzte Antwort
      • S skorpil
        NPM: 9.6.7(9.8.1)
        nodejs:
        Versionstabelle:
        W Online
        W Online
        Wildbill
        #569
        @skorpil Schau ein Stück weiter oben in die Signatur von @Thomas-Braun . Da gibt es einen Link zu einem NodeJS Fixer Skript.
        Das aktualisiert Dir auf die aktuelle Version 18.18.0 (die Du auch verwenden solltest).
        Gruss, Jürgen
        S 2 Antworten Letzte Antwort
        • W Wildbill
          Gruss, Jürgen
          skorpil
          #570
          @wildbill Dankeschön, das hatte ich offenbar überlesen. Ich werde es so versuchen.
          • W Wildbill
            Gruss, Jürgen
            skorpil
            #571
            @wildbill feedback is breakfast for champions: hat funktioniert. Danke!
              mcreuter
              #572
              Hey so sieht es aus wenn ich die Installation nochmal durchgehe:
              Von allein wollte der nicht auf die neuste Version!
              System latest offizelles Docker Image...
              Ich hoffe das es damit gerade gezogen und aktuell ist.
              Vielleicht kann mir jemand das bestätigen??
              DANKE
              root@iobroker:/opt/iobroker# uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt
              update &> /dev/null && sudo apt update && apt policy nodejs
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              /usr/bin/corepack
              v18.18.0
              v18.18.0
              9.8.1
              9.8.1
              0.19.0
              5.0.12
              root
              root
              /opt/iobroker
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists... Done
              All packages are up to date.
              nodejs:
                Installed: 18.18.0-1nodesource1
                Candidate: 18.18.0-1nodesource1
                Version table:
               *** 18.18.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
                      500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
              Mod-EDIT: Code in Code-Tags setzen!
              • M mcreuter
                DANKE
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                /usr/bin/corepack
                v18.18.0
                v18.18.0
                9.8.1
                9.8.1
                0.19.0
                5.0.12
                root
                root
                /opt/iobroker
                nodejs:
                  Version table:
                #573
                @mcreuter
                Beim Docker zieht man sich i. A. einen frischen aus dem Regal.
                  @mcreuter
                  mcreuter
                  #574
                  Was meinst du damit genau?
                  Der Docker Container Manager zieht sich immer das latest Image und migriert diese direkt.
                  https://registry.hub.docker.com/r/iobroker/iobroker/
                  Aber updaten tut sich da kein Node und npm.... Habe das immer manuell gemacht bisher...
                  Nur jetzt über die neue Methode von dir, da die alte nicht mehr ging :_)
                  • M mcreuter
                    #575
                    @mcreuter sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                    Ich hab ja keine Aktien in den Dingern, aber die kommen eigentlich immer mit passender Umgebung vorgekocht daher. Ich glaube in der Version 9 des Docker-Images ist dann auch nodejs@18.18.0 eingebacken.
                      mcreuter
                      #576
                      @thomas-braun Ok, kein Ding kann man ja buanet mal fragen...
                      https://github.com/buanet/ioBroker.docker
                      JA kann sein, die V9 ist als Beta pre Release schon in arbeit mit Debian 12 soweit ich das gesehen habe :-)
                      https://github.com/buanet/ioBroker.docker/tree/v9.0.0-beta.1
                      • Änderungen:
                        remove special settings script and env for zwave (#377)
                        simplify ci/ reduce gh actions
                        ignore errors in "silent cleanup" on first start (#369)
                        cleanup/ restructure repo
                        update nodejs setup process
                        update base image to debian 12 (bookworm)
                        improve security by avoiding root (exept startup script itself)
                        restrict iobroker commanline commands (start/ stop/ node fix)
                        integrate maintenance script into iobroker command
                        move container config files location
                      • J Offline
                        Jack01
                        schrieb am zuletzt editiert von Jack01
                        #577
                        Auch bei mir hat der normale Befehl per update und upgrade nicht zum Erfolg geführt. Ich habe dann den Link von @thomas-braun genutzt und den iob node fix laufen lassen. Das hat geklappt. Verstanden habe ich es aber nicht, da die Pfade ja scheinbar richtig waren und frühere Updates immer funktioniert haben.
                        Vielen Dank an alle Helfer!
                        ioBroker nodejs fixer 2023-09-24
                        Recommended nodejs-version is: 18.18.0
                        Checking your installation now. Please be patient!
                        Your current setup is:
                        /usr/bin/nodejs         v18.17.1
                        /usr/bin/node           v18.17.1
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        /usr/bin/corepack       0.18.0
                        We found these nodejs versions available for installation:
                        nodejs:
                          Installed: 18.17.1-deb-1nodesource1
                          Candidate: 18.17.1-deb-1nodesource1
                          Version table:
                                500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        Nothing to do - Your installation is using the correct paths.
                        You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
                        Press <y> to continue or any other key to quit
                        Trying to fix your installation now. Please be patient.
                        Waiting for ioBroker to shut down - Give me a minute...
                        *** These repos are active on your system:
                        Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                        Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
                        Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
                        Fetched 694 kB in 2s (399 kB/s)
                        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                        Package: nodejs
                        Pin: origin deb.nodesource.com
                        Pin-Priority: 1001
                        *** These repos are active after the adjustments:
                        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                        Get:6 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                        Get:7 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
                        Get:8 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [5262 B]
                        Fetched 22.7 kB in 2s (9910 B/s)
                        Installing the recommended nodejs version now!
                        (Reading database ... 50588 files and directories currently installed.)
                        Preparing to unpack .../nodejs_18.18.0-1nodesource1_arm64.deb ...
                        Detected old npm client, removing...
                        Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                        Setting up nodejs (18.18.0-1nodesource1) ...
                        Processing triggers for man-db (2.9.4-2) ...
                        We tried our best to fix your nodejs. Please run iob diag again to verify.
                        *** RESTARTING ioBroker NOW! ***
                         Please refresh or restart your browser in a few moments.
                        pi@raspberrypi:/opt/iobroker $
                        Proxmox LXC
                        Node.js: V22.22.2
                        NPM: 10.9.7
                        JS-controller: 7.0.7
                        • J Jack01
                          /usr/bin/npm            9.6.7
                          /usr/bin/npx            9.6.7
                          nodejs:
                            Version table:
                          Package: nodejs
                          Pin-Priority: 1001
                          #578
                          @jack01 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                          Der Aufbau der Paketquelle hat sich geändert und daher muss entsprechend in deinem System auch einiges umgestellt werden. Neue Versionen von nodejs kommen nur noch über das neue Repository.
                          Das node-fix-Skript nimmt dir das weitgehend ab.
                            Jack01
                            #579
                            @thomas-braun OK, Danke.
                            Ist das so dann OK für künftige Updates oder muß ich jetzt noch etwas manuell anpassen?
                            Proxmox LXC
                            Node.js: V22.22.2
                            NPM: 10.9.7
                            • J Jack01
                              #580
                              @jack01
                              Künftige Updates laufen jetzt wieder wie gehabt über den üblichen
                              sudo apt update
                              sudo apt full-upgrade
                              Weg mit.
                                @jack01
                                sudo apt update
                                Weg mit.
                                Jack01
                                #581
                                @thomas-braun Na das ist ja ein cooles Script. Kannte ich noch garnicht.
                                                     v.2023-06-20
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                        Machine ID: 620e922bf61543a9808841485d366ecc
                                           Boot ID: 14db67d510ce44cea2db1fdd81b8c10d
                                  Operating System: Debian GNU/Linux 11 (bullseye)
                                            Kernel: Linux 6.1.21-v8+
                                      Architecture: arm64
                                Kernel:                 aarch64
                                Userland:               arm64
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                                        /usr/bin/node           v18.18.0
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.8G        1.9G        142M        0.0K        1.7G        1.8G
                                Swap:            99M         26M         73M
                                Total:          3.9G        1.9G        216M
                                Active iob-Instances:   25
                                Active repo(s): stable
                                ioBroker Core:          js-controller           5.0.12
                                                        admin                   6.10.1
                                Objects type: jsonl
                                States  type: redis
                                Objects:                9583
                                States:                 8935
                                Size of iob-Database:
                                16M     /opt/iobroker/iobroker-data/objects.jsonl
                                1.8M    /opt/iobroker/iobroker-data/states.jsonl
                                Proxmox LXC
                                Node.js: V22.22.2
                                NPM: 10.9.7
                                • L Offline
                                  LJSven
                                  #582
                                  Ich bekomme auf meinem Tinkerboard nodejs 16 nicht installiert. Es kommt immer diese Meldung
                                  Get:1 https://deb.nodesource.com/node_16.x stretch/main armhf nodejs armhf 16.20.2-1nodesource1 [24.2 MB]
                                  Err:1 https://deb.nodesource.com/node_16.x stretch/main armhf nodejs armhf 16.20.2-1nodesource1
                                    Writing more data than expected (24245194 > 24241614)
                                    Hashes of expected file:
                                  Was muss ich machen? Ratlos
                                  • L LJSven
                                    Jan1
                                    #583
                                    @ljsven
                                    1. Stretch ist tot
                                    2. Node 16 ist alt und 18 empfohlen
                                    Somit erstmal das OS auf der Kiste auf den aktuellen Stand bringen, der Rest sollte dann automatisch laufen
                                    L 1 Antwort Letzte Antwort
                                    • J Jan1
                                      @ljsven
                                      1. Stretch ist tot
                                      LJSven
                                      #584
                                      @jan1 sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                                      @ljsven
                                      1. Stretch ist tot
                                      Welches Image soll ich installieren? Hast du einen Link?
                                      • L LJSven
                                        @ljsven
                                        1. Stretch ist tot
                                        Jan1
                                        #585
                                        @ljsven
                                        Ich habe kein Tinkerboard und natürlich ein aktuelles Image ;)
                                        Wobei Image??? kann man das Ding nicht manuell einrichten?
                                        • J Jan1
                                          @ljsven
                                          LJSven
                                          #586
                                          @ljsven
                                          Ich meinte eher das passende OS für die Kiste. Ich war der Meinung, dass ich das aktuelle habe
