  4. Rechteprobleme mit Backitup und NFS NAS sicherung
backitup nfs nas backup
117 Beiträge 8 Kommentatoren 18.7k Aufrufe 7 Beobachtet
  • L luft-post
    moin,
    habe gerade ein Problem mit meinen Backitup :-|
    Ziel ist es mein Backup auf meine NAS zu bekommen. Wenn ich nach meinen Verständnis alles richtig einstelle (NFS als Verbindungstyp und als root-Benutzer mounten) wird meine NAS Ordner gemountet aber schmeißt Fehler wegen Zugriffsrechten auf /opt/iobroker/backups/
    Ergebnis ist das lokal und auf der NAS keine Backup landet.
    Gestartet...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.iobroker 7733 states saved
    [DEBUG] [iobroker] - host.iobroker 8201 objects saved
    [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2020_11_20-15_11_57_Iobrokerbackup_backupiobroker.tar.gz'
    [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
    [DEBUG] [iobroker] - done
    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h localhost -P 3306 > /opt/iobroker/backups/mysql_2020_11_20-15_12_09_backupiobroker.sql
    /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2020_11_20-15_12_09_backupiobroker.sql: Permission denied
    [ERROR] [historyDB] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2020_11_20-15_12_09_backupiobroker.tar.gz'
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [history] - backitup.0.history.html
    [DEBUG] [history] - backitup.0.history.json
    [EXIT] 9
    [DEBUG] [umount] - mount activ... umount in 60 Seconds!!
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 9
    Wenn ich "als root-Benutzer mounten" deaktiviere mir nicht mehr gemountet aber bekomme lokal mein Backup abgelegt.
    Gestartet...
    [ERROR] [mount] - [undefined mount: only root can do that
    [ERROR] [mount] - [IGNORED] Error: Command failed: mount 192.168.2.2:/volume1/iobroker_backup /opt/iobroker/backups
    [DEBUG] [iobroker] - host.iobroker 7747 states saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_11_20-15_03_29_Iobrokerbackup_backupiobroker.tar.gz
    [DEBUG] [mysql] - MySql File deleted!
    [DEBUG] [mysql] - done
    [DEBUG] [historyDB] - done
    [EXIT] 0
    der Ordner /opt/iobroker/backups/ in der Gruppe und Besitzer iobroker.
    Hab auch schon den Fixer drüberlaufen lassen aber ohne Erfolg :-|
    Habt Ihr eine Idee dazu?
    gruß
    Matthias
    O Offline
    O Offline
    Oromis
    schrieb am zuletzt editiert von Oromis
    #101
    @luft-post Hallo,
    ich habe gerade die Sicherung mit Backitup zu meiner Synology NAS per NFS hinbekommen.
    Um nicht als root eine NFS-Verbindung herstellen zu müssen, muss auf dem Host (bei mir der Rpi) die fstab in /etc/fstab bearbeitet werden.
    Hier ist mein Eintrag: "users" führt dazu, dass sämtliche user auf dem Rpi mounten dürfen. Die NFS-Version habe ich in der NAS-Oberfläche ausgewählt. Auf Wunsch kann ich Screenshots senden.
    NAS:/volume1/backup     /opt/iobroker/backups   nfs     auto,nfsvers=4.1,users,defaults,rsize=32768,wsize=32768,intr 0  0
    Dann war das Problem, dass Backitup nicht die Rechte hatte in backups zu schreiben, sobald eine NFS-Verbindung da war (ohne ging es). Ich habe mit
    ls -l /opt/iobroker
    gesehen, dass in den Ordner backups gar niemand schreiben darf:
    total 320
    d---------    4 root     root       4096 Nov 30 20:25 backups
    -rwxrwxrwx+   1 iobroker iobroker    237 Nov 16 11:51 INSTALLER_INFO.txt
    lrwxrwxrwx    1 iobroker iobroker     22 Nov 16 11:51 iob -> /opt/iobroker/iobroker
    -rwxr-xr-x+   1 iobroker iobroker    309 Nov 16 11:51 iobroker
    drwxrwxr-x+   8 iobroker iobroker   4096 Nov 30 18:11 iobroker-data
    drwxrwxr-x+   2 iobroker iobroker   4096 Nov 30 20:44 log
    drwxrwxr-x+ 502 iobroker iobroker  20480 Nov 25 22:34 node_modules
    -rw-rwxr--+   1 iobroker iobroker    492 Nov 25 22:34 package.json
    -rw-rwxr--+   1 iobroker iobroker 281765 Nov 25 22:34 package-lock.json
    Also habe ich die read/write-Rechte verändert.
    Im /opt/iobroker Verzeichnis dazu
    sudo chmod 777 backups/
    eingeben.
    Nun steht folgendes:
    drwxrwxrwx    4 root     root       4096 Nov 30 20:25 backups
    Das Backup lief jetzt per Backitup problemlos durch.
    Wie gesagt: Screenshots von Backitup-Einstellungen und Synology-NAS-Einstellungen liefer ich gerne nach.
    Als Pfad in Backitup habe ich übrigens /volume1/backup stehen.
    • O Oromis
      @luft-post Hallo,
      ls -l /opt/iobroker
      total 320
      eingeben.
      #102
      @oromis sagte in Rechteprobleme mit Backitup und NFS NAS sicherung:
      chmod 777 backups/
      Darf auf Verzeichnisse mit ACLs nicht verwendet werden.
      Und 777 ist i.d.R. ohnehin Murks.
      getfacl /opt/iobroker/backups
      sagt?
      O 1 Antwort Letzte Antwort
        chmod 777 backups/
        sagt?
        O Offline
        O Offline
        Oromis
        #103
        @thomas-braun Ich hatte mir auch schon überlegt, dass iobroker fix wohl die Rechte wieder anpasst.
        getfacl: Removing leading '/' from absolute path names
        # file: opt/iobroker/backups
        # owner: iobroker
        # group: iobroker
        user::rwx
        group::r-x
        group:iobroker:rwx
        mask::rwx
        other::r-x
        default:user::rwx
        default:group::r-x
        default:group:iobroker:rwx
        default:mask::rwx
        default:other::r-x
        ist meine Ausgabe. Hast du eine alternative Idee, wie man das Rechteproblem mit NFS umgehen kann?
        • O Oromis
          # owner: iobroker
          # group: iobroker
          user::rwx
          group::r-x
          group:iobroker:rwx
          mask::rwx
          other::r-x
          default:user::rwx
          default:group::r-x
          default:mask::rwx
          default:other::r-x
          #104
          Hast du das jetzt getan?
          Denn die Ausgabe von getfacl sieht jetzt richtig aus, mit dem chmod 777 müsste die eigentlich anders aussehen.
          Die Rechte müssen auf dem Server angepasst werden, nicht auf dem Client/Mountpunkt.
          NFS funktioniert über die uid der jeweiligen user (jedenfalls in der Grundeinstellung). Musst halt schauen was der 'iobroker' für eine uid hat und die entsprechend auf dem Server berechtigen.
            O Offline
            O Offline
            Oromis
            #105
            @thomas-braun Nein, ich habe "iobroker fix" noch nicht drüberlaufen lassen. Nach einem erfolgreichen Backitup-Backup liefert
            ls -l /opt/iobroker
            total 320
            drwxrwxr-x+   2 iobroker iobroker   4096 Nov 27 23:48 backups
            drwxrwxr-x+   8 iobroker iobroker   4096 Nov 30 22:08 iobroker-data
            drwxrwxr-x+   2 iobroker iobroker   4096 Nov 30 21:16 log
            also eine Änderung.
            Den zweiten Teil mit den Rechten verstehe ich nicht ganz: Meinst du die Eintragung in /etc/fstab auf dem Rpi?
            • O Oromis
              ls -l /opt/iobroker
              total 320
              also eine Änderung.
              #106
              Nein, auf dem NFS-Server müssen die User gleichlautend angelegt sein.
              Außer man spasht da, aber in der reinen Lehre macht man das nicht.
                O Offline
                O Offline
                Oromis
                #107
                @thomas-braun So etwas ähnliches schreibt Synology auch in ihrer Hilfe:
                https://kb.synology.com/en-br/DSM/help/DSM/AdminCenter/file_share_privilege_nfs?version=7
                If AUTH_SYS security flavor is implemented: The client must have exactly the same numerical UID (user identifier) and GID (group identifier) on the NFS client and Synology NAS, or else the client will be assigned the permissions of others when accessing the shared folder. To avoid any permissions conflicts, you can select Map all users to admin from Squash or give "Everyone" permissions to the shared folder.
                "Map all users to admin" wird jedoch nach einer kurzen Googlesuche sicherheitstechnisch abgeraten und hat bei mir auch nicht funktioniert. Erst der entsprechende Eintrag in der fstab auf dem Rpi, hat dafür gesorgt, dass ich ohne sudo mounten konnte.
                Hier meine Einstellungen in der NAS:
                Was ich aber noch nicht so wirklich verstehe:
                • Warum fehlen jedem Benutzer inkl. root die rwx-Rechte bei aktivem Mount über NFS für den Ordner /opt/iobroker/backups? Bzw. wie kann Backitup auch ohne NFS-Verbindung bei "d---------" überhaupt in dem Ordner Verzeichnisse erstellen? Oder ändern sich die Rechte in "d---------" mit dem mount per NFS und davor sind sie sowas wie "drwxrwxr-x+"? Also so wie es bei mir aktuell ausschaut.
                • Warum ist der NFS-Mount ohne sudo über /etc/fstab ein Problem, wenn das Backup auch mit einem Mount mit Root-Rechte fehl schlägt?
                Edit: Ah, ich hoffe ich reime mir jetzt keinen Müll zusammen, aber kann es sein, dass /opt/iobroker/backups ohne NFS-Mount relativ normale rwx-Rechte hat und dann eben - so wie es in der Synology-Hilfe auch steht ("...or else the client will be assigned the permissions of others when accessing the shared folder.") - bei einem NFS-Mount die Rechte entzogen werden. Mit dem chmod habe ich dann vermutlich "or give "Everyone" permissions to the shared folder" durchgeführt. Eleganter wäre es dann also, wie du schreibst, auf der NAS einen Benutzer, der die gleiche UID und GID, wie auf dem Rpi der iobroker-Benutzer, zu erstellen. Ist das so sinnvoll?
                • O Oromis
                  #108
                  Weil die lokalen uid nicht auf dem NFS-Server bererchtigt sind.
                  Über die ACL-Rechte. Der Order hat ja mehr als die in ls gezeigten Rechte. Sieht man am + am Ende der Rechte.
                  Ist kein Problem. Aber auf dem Server müssen die user halt auch Rechte haben.
                    O Offline
                    O Offline
                    Oromis
                    #109
                    @thomas-braun Okay, super danke. Sorry, für mich ist das alles Neuland als Windows-User.
                    Ich habe meinen vorherigen Post nochmal editiert, während du die Antwort geschrieben hast (habs durchgestrichen, da es z.T. Müll war, was ich geschrieben habe, nachdem ich deine Erklärung gelesen habe). D.h. mein letzter Satz in dem Edit "Eleganter wäre es dann also, wie du schreibst, auf der NAS einen Benutzer, der die gleiche UID und GID, wie auf dem Rpi der iobroker-Benutzer, zu erstellen. Ist das so sinnvoll?" wäre dann die saubere Lösung?
                    • O Oromis
                      #110
                      Das wäre der übliche Weg wie NFS tickt. Ob das auf der Synology so umsetzbar ist weiß ich nicht, hab so'ne Kiste nicht.
                        O Offline
                        O Offline
                        Oromis
                        #111
                        @thomas-braun Danke dir, das werde ich mal erforschen. Da auf meinem Pi sonst überhaupt nichts läuft außer iobroker, kann ich mit dem aktuellen Stand erstmal leben, solange Updates nicht wieder was daran ändern.
                        Einfacher wäre natürlich die Sicherung mit einem USB-Stick am Pi ;)
                        • O Oromis
                          #112
                          @oromis
                          https://kb.synology.com/de-de/DSM/help/DSM/AdminCenter/file_share_privilege_nfs?version=7
                          Da ist es erklärt:
                          Wenn die Sicherheitsvariante AUTH_SYS implementiert wird: Der Client muss genau dieselbe numerische UID (Benutzer-ID) und GID (Gruppen-ID) auf dem NFS-Client und dem Synology NAS verwenden
                          Schau mit
                          sudo -u iobroker id
                          nach, der iobroker sollte eigentlich die 1001 haben.
                            @oromis
                            Da ist es erklärt:
                            Schau mit
                            sudo -u iobroker id
                            O Offline
                            O Offline
                            Oromis
                            #113
                            @thomas-braun Genau! Das habe ich auf Englisch oben in den Spoiler-Tags zitiert. Wie gesagt, ich schau mal nach den UID und GID auf der Synology. Aber nicht mehr heute ;)
                            Edit: Hier ist die Antwort:
                            https://www.synology-wiki.de/index.php/NFS-Konfiguration#NFS_und_Benutzerrechte
                            • O Oromis
                              #114
                              @oromis
                              Dann muss offenbar die uid des iobrokers von 1001 auf die ggf. abweichende von der Diskstation angepasst werden.
                                @oromis
                                O Offline
                                O Offline
                                Oromis
                                #115
                                Habe jetzt nach der Anleitung die UID und GID auf dem Rpi angepasst und iobroker fix laufen lassen. Das Backup lief ohne Probleme durch. Die Meldungen waren:
                                Started iobroker ...
                                [DEBUG] [mount] - nfs-mount command: "mount NAS:/volume1/backup /opt/iobroker/backups"
                                [DEBUG] [iobroker] - host.datenpi 438 states saved
                                [DEBUG] [iobroker] - host.datenpi 556 objects saved
                                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_12_01-20_45_04_backupiobroker.tar.gz
                                [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                [DEBUG] [influxDB] - Packed 22MB so far...
                                [DEBUG] [influxDB] - Packed 41MB so far...
                                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2022_12_01-20_45_30_backupiobroker.tar.gz
                                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                [DEBUG] [influxDB] - done
                                [DEBUG] [grafana] - Start Grafana Backup ...
                                [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                [DEBUG] [grafana] - Created dashboard directory
                                [DEBUG] [grafana] - Created dashboards_manually_restore directory
                                [DEBUG] [grafana] - Created datasource directory
                                [DEBUG] [grafana] - start Grafana request ...
                                [DEBUG] [grafana] - Grafana is available ... Status: 200
                                [DEBUG] [grafana] - found Dashboard: test
                                [DEBUG] [grafana] - found Dashboard: heizung
                                [DEBUG] [grafana] - found Dashboard: elektrische-energie
                                [DEBUG] [grafana] - start Grafana backup compress ...
                                [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2022_12_01-20_46_40_backupiobroker.tar.gz
                                [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                [DEBUG] [grafana] - done
                                [DEBUG] [cifs] - used copy path: /volume1/backup
                                [DEBUG] [historyHTML] - new history html values created
                                [DEBUG] [historyHTML] - done
                                [DEBUG] [historyJSON] - new history json values created
                                [DEBUG] [historyJSON] - done
                                [DEBUG] [umount] - mount activ, umount is started ...
                                [EXIT] 0
                                • O Oromis
                                  [EXIT] 0
                                  #116
                                  @oromis
                                  Schaut doch sehr gut aus.
                                  • O Offline
                                    O Offline
                                    Oromis
                                    #117
                                    Hallo, ich melde mich hier nur nochmal der Vollständigkeit halber. Der oben von mir beschriebene fstab-Eintrag ist falsch. Ich habe es gerade beim Umstieg auf bookworm bemerkt. Es fehlt die Option "tcp", sonst funktioniert das mounten nicht. Ansonsten stimmt alles im Thread zur Anpassung der uid/gid und den Synology-NAS-Einstellungen um eine NFS-Verbindung zur Synology-NAS für Backitup hinzubekommen. Kann also quasi als Anleitung benutzt werden.
                                    So wäre es korrekt:
                                    NAS:/volume1/backup /opt/iobroker/backups nfs auto,nfsvers=4.1,users,defaults,rsize=32768,wsize=32768,tcp,intr 0 0
