  4. Nach 2 Jahre Updaten klappt aber nicht
update
46 Beiträge 4 Kommentatoren 6.2k Aufrufe 4 Beobachtet
    badplay
    Hey versuche die ganze Zeit zu updaten folgendes bekomme ich wenn ich die folgenden Schritte versuche:
    node -v
    v10.23.0
    npm -v
    6.14.8
    nodejs -v
    v10.23.0
    iobroker stop
    iobroker backup
    iobroker update
    iobroker upgrade self
    iobroker start
    pi@raspberrypi:~ $ iobroker upgrade self
    Update js-controller from @1.5.14 to @3.1.6
    NPM version: 6.14.8
    npm install iobroker.js-controller@3.1.6 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/get-stream/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/locate-path/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/tar/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/minipass/node_modules
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/get-stream/node_modules
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/get-stream/node_modules'
    npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/get-stream/node_modules']
    npm ERR!   stack:
    npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/get-stream/node_modules\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/get-stream/node_modules' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/pi/.npm/_logs/2020-11-02T18_34_06_056Z-debug.log
    host.raspberrypi Cannot install iobroker.js-controller@3.1.6: 243
    pi@raspberrypi:~ $
    Mod-Edit: Code in code-tags gesetzt!
    im Admin panel steht ich soll js.controller updaten aber das klappt ja eben nicht
    • B badplay
      node -v
      v10.23.0
      npm -v
      6.14.8
      nodejs -v
      v10.23.0
      iobroker stop
      iobroker backup
      iobroker update
      iobroker start
      NPM version: 6.14.8
      npm ERR! errno -13
      npm ERR!   stack:
      npm ERR!
      npm ERR!
      pi@raspberrypi:~ $
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @badplay fixer ausführen curl -sL https://iobroker.net/fix.sh | bash -
      Videotutorials & mehr
      B 1 Antwort Letzte Antwort
      • foxriver76F foxriver76
        badplay
        @foxriver76 hab ich jetzt gemacht, lese was von neuem User aber wie lautet dieser? ich gehe als Pi in Putty
        • B badplay
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          @badplay der wird nun automatisch für alle iobroker Prozesse genutzt, du loggst dich weiterhin mit deinem bisherigen Nutzer an. Nach dem der Fixer durch ist einfach die oben von dir erwähnten Schritte erneut durchführen.
            badplay
            @foxriver76 verusche ich
            login as: pi
            pi@192.168.1.164's password:
            Linux raspberrypi 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Mon Nov  2 18:32:33 2020 from 192.168.1.113
            pi@raspberrypi:~ $ sudo iobroker stopsudo iobroker stop
            Commands:
            iobroker setup [--objects <host>] [--states <host>] [custom]
            iobroker start
            iobroker stop
            iobroker start <adapter>
            iobroker stop <adapter>
            iobroker start all
            iobroker restart
            iobroker restart <adapter>
            iobroker info
            iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
            iobroker install <adapter>
            iobroker url <url> [<name>]
            iobroker del <adapter>
            iobroker del <adapter>.<instance>
            iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f]
            iobroker upgrade [repository url]
            iobroker upgrade self [repository url]
            iobroker upgrade <adapter> [repository url]
            iobroker upload <pathToLocalFile> <pathIniobroker>
            iobroker upload all
            iobroker upload <adapter>
            iobroker object get <id>
            iobroker object del <id>
            iobroker object chmod <object-mode> [state-mode] <id>
            iobroker object chown <user> <group> <id>
            iobroker object list <id>
            iobroker state get <id> [
            iobroker state getplain <id> [--pretty]
            iobroker state getvalue <id>
            iobroker state set <id> <value> [ack]
            iobroker state del <id>
            iobroker message <adapter>[.instanceid] <command> [<message>]
            iobroker list <type> [filter]
            iobroker chmod <mode> <file>
            iobroker chown <user> <group> <file>
            iobroker touch <file>
            iobroker rm <file>
            iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
            iobroker file write <filesystem-path-to-read> <iobroker-path-to-read>
            iobroker user add <user> [--ingroup group] [--password pass]
            iobroker user del <user>
            iobroker user passwd <user> [--password pass]
            iobroker user enable <user>
            iobroker user disable <user>
            iobroker user get <user>
            iobroker user check <user> [--password pass]
            iobroker group add <group>
            iobroker group del <group>
            iobroker group list <group>
            iobroker group enable <group>
            iobroker group disable <group>
            iobroker group get <group>
            iobroker group adduser <group> <user>
            iobroker group deluser <group> <user>
            iobroker host this
            iobroker host <hostname>
            iobroker host set <hostname>
            iobroker host remove <hostname>
            iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
            iobroker license <license.file or license.text>
            iobroker clean
            iobroker backup
            iobroker restore <backup name or path>
            iobroker <command> --timeout 5000
            iobroker status [all]
            iobroker repo [name]
            iobroker repo add <name> <path or url>
            iobroker repo set <name>
            iobroker repo del <name>
            iobroker uuid
            iobroker unsetup
            iobroker multihost <enable|disable> [--secure true|false]
            iobroker multihost browse
            iobroker multihost connect
            iobroker version [adapter]
            iobroker [adapter] -v
            Options:
              --help     Show help  [boolean]
              --version  Show version number  [boolean]
            pi@raspberrypi:~ $ iobroker stop
            pi@raspberrypi:~ $ iobroker update
            Used repository: default
            hash not changed, use actual sources
            update done
            Adapter    "admin"         : 4.0.10   , installed 2.0.9 [Updateable]
            Adapter    "alarm"         : 1.2.4
            Adapter    "alexa2"        : 3.3.1    , installed 1.1.3 [Updateable]
            Adapter    "alpha2"        : 1.0.0
            Adapter    "amazon-dash"   : 1.1.0
            Adapter    "artnet"        : 1.2.2
            Adapter    "asterisk"      : 1.0.6
            Adapter    "asuswrt"       : 1.0.1    , installed 1.0.0 [Updateable]
            Adapter    "b-control-em"  : 0.2.1
            Adapter    "backitup"      : 1.6.7
            Adapter    "beckhoff"      : 1.2.2
            Adapter    "benq"          : 0.2.0
            Adapter    "binance"       : 1.1.3
            Adapter    "ble"           : 0.11.8
            Adapter    "bmw"           : 1.3.3
            Adapter    "bosesoundtouch": 0.2.4
            Adapter    "botvac"        : 1.0.0
            Adapter    "bring"         : 1.7.2
            Adapter    "broadlink2"    : 2.0.3
            Adapter    "bsblan"        : 0.1.5
            Adapter    "bshb"          : 0.1.10
            Adapter    "chromecast"    : 2.3.1
            Adapter    "cloud"         : 3.0.4    , installed 2.6.2 [Updateable]
            Adapter    "comfoair"      : 0.3.2
            Adapter    "contactid"     : 1.0.1
            Adapter    "coronavirus-statistics": 0.6.1
            Adapter    "countdown"     : 1.1.0
            Adapter    "cul"           : 1.2.1
            Adapter    "daikin"        : 1.0.5
            Adapter    "daswetter"     : 3.0.4
            Adapter    "deconz"        : 1.3.11
            Adapter    "denon"         : 1.7.7
            Adapter    "devices"       : 0.3.6
            Adapter    "digitalstrom"  : 0.5.5
            Adapter    "discovergy"    : 0.5.0
            Adapter    "discovery"     : 2.3.7    , installed 1.2.4 [Updateable]
            Adapter    "doorio"        : 1.1.0
            Adapter    "ds18b20"       : 1.1.4
            Adapter    "dwd"           : 2.4.10
            Adapter    "ebus"          : 2.1.1
            Adapter    "ecovacs-deebot": 1.0.3
            Adapter    "egigeozone"    : 0.1.2
            Adapter    "ekey"          : 1.1.0
            Adapter    "email"         : 1.0.7
            Adapter    "emby"          : 1.0.2
            Adapter    "energymanager" : 1.2.3
            Adapter    "enet"          : 1.0.1
            Adapter    "epson_stylus_px830": 0.2.1
            Adapter    "exchangerates" : 0.0.13
            Adapter    "fakeroku"      : 0.2.1
            Adapter    "fb-checkpresence": 1.0.4
            Adapter    "feiertage"     : 1.0.17
            Adapter    "fhem"          : 1.5.3
            Adapter    "find-my-iphone": 0.2.15
            Adapter    "firetv"        : 0.0.27
            Adapter    "flot"          : 1.9.2
            Adapter    "foobar2000"    : 2.0.3
            Adapter    "fritzbox"      : 0.2.1
            Adapter    "fritzdect"     : 0.2.4
            Adapter    "fronius"       : 1.0.5
            Adapter    "fullcalendar"  : 1.1.0
            Adapter    "fullybrowser"  : 2.0.1
            Adapter    "g-homa"        : 0.5.3
            Adapter    "geofency"      : 0.3.2
            Adapter    "gruenbeck"     : 0.0.18
            Adapter    "habpanel"      : 0.4.3
            Adapter    "haier"         : 1.0.2
            Adapter    "ham"           : 1.1.2
            Adapter    "ham-wemo"      : 1.0.1
            Adapter    "harmony"       : 1.2.2    , installed 1.1.5 [Updateable]
            Adapter    "heatingcontrol": 1.0.0
            Adapter    "heytech"       : 1.0.0
            Adapter    "hid"           : 0.1.17
            Adapter    "history"       : 1.9.10   , installed 1.8.5 [Updateable]
            Adapter    "hm-rega"       : 2.6.21
            Adapter    "hm-rpc"        : 1.14.24
            Adapter    "hmip"          : 1.3.1
            Adapter    "homeconnect"   : 0.0.30
            Adapter    "homee"         : 1.0.7
            Adapter    "homepilot"     : 1.0.3
            Adapter    "hp-ilo"        : 1.0.6
            Adapter    "hs100"         : 2.0.1
            Adapter    "hue"           : 3.3.8
            Adapter    "hue-extended"  : 2.0.0
            Adapter    "ical"          : 1.7.4
            Adapter    "icons-addictive-flavour-png": 0.1.0
            Adapter    "icons-fatcow-hosting": 0.1.0
            Adapter    "icons-icons8"  : 0.0.1
            Adapter    "icons-material-png": 0.1.0
            Adapter    "icons-material-svg": 0.1.0
            Adapter    "icons-mfd-png" : 1.0.2
            Adapter    "icons-mfd-svg" : 1.0.2
            Adapter    "icons-open-icon-library-png": 0.1.2
            Adapter    "icons-ultimate-png": 1.0.1
            Adapter    "influxdb"      : 1.9.1
            Adapter    "info"          : 1.7.2
            Adapter    "innogy-smarthome": 0.3.6
            Adapter    "iogo"          : 0.5.10
            Adapter    "iot"           : 1.5.3
            Adapter    "iqontrol"      : 1.3.3
            Adapter    "jarvis"        : 1.0.9
            Adapter    "javascript"    : 4.8.4    , installed 3.6.4 [Updateable]
            Adapter    "jeelink"       : 0.1.0
            Controller "js-controller" : 3.1.6    , installed 1.5.14 [Updateable]
            Adapter    "kecontact"     : 0.1.0
            Adapter    "klf200"        : 1.0.1
            Adapter    "km200"         : 1.1.6
            Adapter    "knmi-weather"  : 1.0.0
            Adapter    "knx"           : 1.0.39
            Adapter    "kodi"          : 2.0.4
            Adapter    "kostal-piko-ba": 1.1.1
            Adapter    "kress"         : 2.5.5
            Adapter    "lametric"      : 0.0.9
            Adapter    "landroid"      : 1.0.3
            Adapter    "lcn"           : 0.3.2
            Adapter    "letrika_comgw" : 0.0.5
            Adapter    "lgtv"          : 1.1.10
            Adapter    "lgtv-rs"       : 0.1.0
            Adapter    "lgtv11"        : 1.0.5
            Adapter    "lifx"          : 0.1.0
            Adapter    "lightify"      : 0.2.16
            Adapter    "link"          : 0.5.9
            Adapter    "linkeddevices" : 1.2.2
            Adapter    "linux-control" : 1.0.0
            Adapter    "logparser"     : 1.1.0
            Adapter    "lovelace"      : 1.0.16
            Adapter    "loxone"        : 2.0.2
            Adapter    "luftdaten"     : 0.0.17
            Adapter    "lupusec"       : 1.2.9
            Adapter    "luxtronik1"    : 0.2.2
            Adapter    "material"      : 0.13.9
            Adapter    "maxcube"       : 0.1.2
            Adapter    "maxcul"        : 1.3.0
            Adapter    "mbus"          : 2.3.0
            Adapter    "mclighting"    : 0.1.1
            Adapter    "megad"         : 1.2.1
            Adapter    "megadd"        : 0.2.0
            Adapter    "megaesp"       : 0.1.0
            Adapter    "melcloud"      : 1.0.6
            Adapter    "mercedesme"    : 0.0.21
            Adapter    "mercury"       : 0.1.1
            Adapter    "meross"        : 1.5.0
            Adapter    "meteoalarm"    : 1.0.9
            Adapter    "midea"         : 0.0.6
            Adapter    "miele"         : 0.1.5
            Adapter    "mielecloudservice": 2.0.0
            Adapter    "mihome"        : 1.3.0    , installed 1.2.3 [Updateable]
            Adapter    "mihome-lamp"   : 1.1.0
            Adapter    "mihome-plug"   : 0.2.0
            Adapter    "mihome-vacuum" : 2.0.7
            Adapter    "mikrotik"      : 1.0.11
            Adapter    "milight"       : 0.3.6
            Adapter    "milight-smart-light": 0.2.7
            Adapter    "mobile"        : 1.0.1    , installed 0.4.11 [Updateable]
            Adapter    "modbus"        : 3.1.6
            Adapter    "moma"          : 1.2.6
            Adapter    "mpd"           : 1.0.5
            Adapter    "mqtt"          : 2.1.9
            Adapter    "mqtt-client"   : 1.3.1
            Adapter    "musiccast"     : 0.1.3
            Adapter    "mydlink"       : 1.1.7
            Adapter    "mysensors"     : 2.0.1
            Adapter    "nanoleaf-lightpanels": 0.8.1
            Adapter    "nello"         : 2.0.6
            Adapter    "netatmo"       : 1.3.1
            Adapter    "nibeuplink"    : 0.3.0
            Adapter    "nina"          : 0.0.22
            Adapter    "node-red"      : 1.17.2
            Adapter    "nuki"          : 1.3.1
            Adapter    "nuki-extended" : 2.3.0
            Adapter    "nut"           : 1.1.3
            Adapter    "odl"           : 1.0.5
            Adapter    "oilfox"        : 0.0.5
            Adapter    "onkyo"         : 2.0.3
            Adapter    "onvif"         : 0.4.4
            Adapter    "openhab"       : 1.1.0
            Adapter    "openligadb"    : 1.1.0
            Adapter    "openweathermap": 0.1.0
            Adapter    "opi"           : 0.1.1
            Adapter    "oppoplayer"    : 0.2.1
            Adapter    "owfs"          : 0.6.4
            Adapter    "owntracks"     : 0.6.3
            Adapter    "panasonic-viera": 1.0.2
            Adapter    "parser"        : 1.0.7
            Adapter    "paw"           : 0.0.7
            Adapter    "phantomjs"     : 1.0.1
            Adapter    "pi-hole"       : 1.3.1
            Adapter    "piface"        : 1.0.0
            Adapter    "pimatic"       : 0.3.0
            Adapter    "ping"          : 1.4.8    , installed 1.3.2 [Updateable]
            Adapter    "places"        : 1.0.0
            Adapter    "plex"          : 0.8.11
            Adapter    "plexconnect"   : 0.0.7
            Adapter    "pollenflug"    : 1.0.6
            Adapter    "proxmox"       : 1.0.1
            Adapter    "proxy"         : 1.1.1
            Adapter    "pushbullet"    : 0.0.11
            Adapter    "pushover"      : 2.0.2
            Adapter    "pushsafer"     : 0.1.8
            Adapter    "radar2"        : 1.0.9
            Adapter    "radiohead"     : 1.0.7
            Adapter    "rflink"        : 2.0.0
            Adapter    "rickshaw"      : 1.0.0
            Adapter    "ring"          : 1.1.3
            Adapter    "robonect"      : 0.1.3
            Adapter    "roomba"        : 1.1.1
            Adapter    "rpi2"          : 1.2.0
            Adapter    "s7"            : 1.1.8
            Adapter    "samsung"       : 0.2.9
            Adapter    "sayit"         : 1.9.8
            Adapter    "sbfspot"       : 4.0.2
            Adapter    "scenes"        : 2.1.7    , installed 1.1.0 [Updateable]
            Adapter    "schoolfree"    : 0.6.3
            Adapter    "schwoerer-ventcube": 1.3.0
            Adapter    "shelly"        : 4.0.3
            Adapter    "shuttercontrol": 0.8.6
            Adapter    "sia"           : 1.0.4
            Adapter    "siegenia"      : 1.0.0
            Adapter    "simple-api"    : 2.4.6    , installed 2.0.0 [Updateable]
            Adapter    "smappee"       : 0.2.2
            Adapter    "smartgarden"   : 1.0.1
            Adapter    "smartmeter"    : 3.1.5
            Adapter    "snips"         : 1.5.1
            Adapter    "snmp"          : 0.5.0
            Adapter    "socketio"      : 3.0.13   , installed 2.1.1 [Updateable]
            Adapter    "solarlog"      : 2.0.0
            Adapter    "solarviewdatareader": 0.2.1
            Adapter    "solarwetter"   : 1.0.0
            Adapter    "sonnen"        : 1.6.0
            Adapter    "sonoff"        : 2.3.3    , installed 2.2.2 [Updateable]
            Adapter    "sonos"         : 2.1.0
            Adapter    "sony-bravia"   : 1.0.1
            Adapter    "spotify-premium": 1.0.0
            Adapter    "sql"           : 1.15.2
            Adapter    "squeezebox"    : 1.0.0
            Adapter    "squeezeboxrpc" : 1.0.0
            Adapter    "starline"      : 1.0.0
            Adapter    "statistics"    : 0.2.2
            Adapter    "stiebel-isg"   : 1.5.1
            Adapter    "sunnyportal"   : 0.1.5
            Adapter    "swiss-weather-api": 0.3.2
            Adapter    "synology"      : 0.1.18
            Adapter    "systeminfo"    : 0.3.1
            Adapter    "tahoma"        : 0.3.2
            Adapter    "tankerkoenig"  : 2.0.5
            Adapter    "telegram"      : 1.5.9
            Adapter    "terminal"      : 0.1.2
            Adapter    "tesla-motors"  : 0.2.3
            Adapter    "text2command"  : 1.3.0
            Adapter    "tinker"        : 1.1.0
            Adapter    "tr-064"        : 4.0.9
            Adapter    "tradfri"       : 2.6.3
            Adapter    "trashschedule" : 0.0.11
            Adapter    "tunnelbroker-endpoint-updater": 0.0.1
            Adapter    "tuya"          : 3.3.15
            Adapter    "tvspielfilm"   : 1.0.4
            Adapter    "unifi"         : 0.5.8
            Adapter    "upnp"          : 1.0.16
            Adapter    "vaillant"      : 0.0.10
            Adapter    "valloxmv"      : 1.1.1
            Adapter    "vcard"         : 0.0.9
            Adapter    "velux"         : 0.0.5
            Adapter    "viessmann"     : 1.3.2
            Adapter    "virtualpowermeter": 1.2.1
            Adapter    "vis"           : 1.2.12   , installed 1.1.7 [Updateable]
            Adapter    "vis-bars"      : 0.1.4
            Adapter    "vis-canvas-gauges": 0.1.5
            Adapter    "vis-colorpicker": 1.1.1
            Adapter    "vis-fancyswitch": 1.1.0
            Adapter    "vis-google-fonts": 0.1.0
            Adapter    "vis-history"   : 1.0.0
            Adapter    "vis-hqwidgets" : 1.1.4
            Adapter    "vis-icontwo"   : 0.31.0
            Adapter    "vis-inventwo"  : 1.3.8
            Adapter    "vis-jqui-mfd"  : 1.0.12
            Adapter    "vis-justgage"  : 1.0.2
            Adapter    "vis-keyboard"  : 0.0.2
            Adapter    "vis-lcars"     : 1.0.4
            Adapter    "vis-map"       : 1.0.4
            Adapter    "vis-material-advanced": 1.1.1
            Adapter    "vis-metro"     : 1.1.2
            Adapter    "vis-players"   : 0.1.6
            Adapter    "vis-plumb"     : 1.0.2
            Adapter    "vis-rgraph"    : 0.0.2
            Adapter    "vis-timeandweather": 1.1.7
            Adapter    "vis-weather"   : 2.5.2
            Adapter    "vr200"         : 1.0.0
            Adapter    "vw-connect"    : 0.0.15
            Adapter    "weatherunderground": 3.2.1
            Adapter    "web"           : 3.0.13   , installed 2.4.1 [Updateable]
            Adapter    "weishaupt-wem" : 0.0.8
            Adapter    "wiffi-wz"      : 2.2.0
            Adapter    "wifilight"     : 1.1.0
            Adapter    "windows-control": 0.1.5
            Adapter    "wled"          : 0.5.2
            Adapter    "wm-bus"        : 0.1.12
            Adapter    "wolf"          : 0.9.2
            Adapter    "worx"          : 1.2.3
            Adapter    "xbox"          : 0.6.8
            Adapter    "xs1"           : 1.0.2
            Adapter    "yahka"         : 0.11.0
            Adapter    "yamaha"        : 0.3.19
            Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.0 [Updateable]
            Adapter    "youtube"       : 0.0.11
            Adapter    "yr"            : 2.0.3
            Adapter    "zigbee"        : 1.2.1
            Adapter    "zont"          : 0.5.3
            Adapter    "zwave"         : 2.0.1
            Adapter    "zwave2"        : 1.7.5
            NPM version: 6.14.8
            ACHTUNG: Die Fehlerberichterstattung über Sentry wird beim nächsten Start von ioBroker aktiviert
            Wir von ioBroker wollen das stabilste Smart-Home-System bereitstellen.
            Um dies zu ermöglichen, haben wir uns entschlossen, eine automatische Fehler- und Crash-Reporting-Lösung in den js-Controller und auch in Adapter zu implementieren.
            DIESE BERICHTERSTATTUNG WIRD MIT DEM NÄCHSTEN START IHRES IOBROKERS AKTIVIERT!
            Bei Fehlern, die zum Absturz des js-Controllers oder eines der relevanten Adapter führen, werden die Fehlerdetails an einen Server gesendet. Für den js-controller und die Haupt-Adapter befindet sich dieser Server in Deutschland. Informationen zu Community-Adaptern sind in der Github-Readme-Datei des betroffenen Adapters zu finden. Dort steht welcher Sentry-Server verwendet wird.
            Die Fehlerberichterstattung kann, falls gewünscht, über den Befehl
            'iobroker plugin disable sentry'
            deaktiviert werden. Dieser Befehl stellt auch sicher, dass kein Adapter, der auf diesem Host ausgeführt wird, Absturzberichtsdaten an den Sentry-Server sendet.
            Host "raspberrypi" (linux) updated
            Execute: chmod -R 777 /opt/iobroker
            Chmod finished. Restart controller
            Starting node restart.js
            pi@raspberrypi:~ $ iobroker start
            pi@raspberrypi:~ $
            • B badplay
              login as: pi
              Commands:
              iobroker start
              iobroker stop
              iobroker start all
              iobroker restart
              iobroker info
              iobroker upload all
              iobroker rm <file>
              iobroker host this
              iobroker clean
              iobroker backup
              iobroker uuid
              iobroker unsetup
              Options:
              update done
              NPM version: 6.14.8
              pi@raspberrypi:~ $
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              schrieb am zuletzt editiert von foxriver76
              @badplay schaut doch gut aus.. oder noch Beschwerden?
              Btw sudo ist nicht nötig für die iobroker Kommandos.
                badplay
                @foxriver76 hab jetzt folgendes durchlaufen lassen
                cd /opt/iobroker
                sudo iobroker stop
                sudo npm install iobroker.admin --production
                sudo npm install iobroker.js-controller --production
                sudo iobroker start
                da mein admin noch das total alte ist. war das ein fehler??
                naja er schreibt immer noch updates vorhanden, aber ich lass es doch updaten hmm
                foxriver76F HomoranH 2 Antworten Letzte Antwort
                • B badplay
                  cd /opt/iobroker
                  sudo iobroker stop
                  sudo iobroker start
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @badplay du solltest nur die iobroker Kommandos nutzen nicht npm direkt. Wo das Node Modul nun installiert wurde hängt von dem Verzeichnis ab in welchem du den Befehl ausgeführt hast und Rechteprobleme wirst du so auch wieder bekommen. iob upgrade name-des-adapters zum upgraden.
                  B 2 Antworten Letzte Antwort
                  • B badplay
                    cd /opt/iobroker
                    sudo iobroker stop
                    sudo iobroker start
                    @badplay wo hast du diese Befehle denn her?
                    Und bitte nutze code-tags!
                      badplay
                      @foxriver76 okay hmm keine ahnung wo das jetzt installiert ist. auf alle fälle läuft das updaten nun durch.
                      gibt es ein check up befehl danach ob alles richtig läuft und so ?
                        badplay
                        @foxriver76 im Admin gibt es nun folgenden error oder hinweiß
                        JS-Controller 2.x ist nicht kompatibel mit dem vis-Adapter, der kleiner als 1.2.2 ist
                        warningDie installierte Version von JS-Controller 2.x ist nicht mit dem vis-Adapter mit einer Version vor 1.2.2 kompatibel. Bitte aktualisieren Sie den Adapter, um Probleme zu vermeiden.
                        update ist durchgelaufen
                        • B badplay
                          @badplay
                          Hier wird ja wieder gehuddelt...
                          Lass das jetzt mal durchlaufen,
                          dann würde ich auch mal nach dem Grundsystem schauen.
                          sudo apt update
                          sudo apt dist-upgrade
                          sudo reboot
                          Und wenn die Kiste wieder oben ist, dann nochmal den Fixer drüber jagen.
                            @badplay
                            sudo apt update
                            sudo reboot
                            badplay
                            @Thomas-Braun said in Nach 2 Jahre Updaten klappt aber nicht:
                            sudo apt update
                            mach ich. bin gespannt
                              badplay
                              @Homoran durch google bzw forum
                              • B badplay
                                @badplay
                                Wenn das gleich richtig angelegt ist, dann
                                die Befehle 'iobroker' und 'npm' nie mit 'sudo' kombinieren.
                                • B badplay
                                  @badplay sagte in Nach 2 Jahre Updaten klappt aber nicht:
                                  In Google steht viel Mist
                                    @Homoran Und bei youtube wird auch viel Mist verzapft.
                                    Oh, das ist ja auch google...
                                    Google ist also böse!
                                      badplay
                                      @Thomas-Braun
                                      ok also kein sudo bei iobroker
                                      wie kann ich denn erkennen ob jetzt nachdem alles durch ist der js-controller die richtige Version hat ?
                                      Thomas BraunT B HomoranH 3 Antworten Letzte Antwort
                                      • B badplay
                                        @Thomas-Braun
                                        @badplay
                                        iobroker version
                                        • B badplay
                                          @Thomas-Braun
                                          badplay
                                          Wollte noch schnell meine Sonoff Steckdosen und die philipps hue lampen sowie die yeelight rgb lamp einfügen, aber weiß gar nicht mehr wie ich das immer gemacht habe uff. so lange her
