  4. Nach Shutdown vom Raspberry ioBroker weg
rebootproblem
61 Beiträge 4 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • GlasfaserG Glasfaser
    @jmeister79
    und jetzt :
    cd /opt/iobroker
    iobroker start
    iobroker status
    iobroker list instances
    jmeister79J Offline
    jmeister79J Offline
    jmeister79
    @Glasfaser
    pi@iobrokerpi:~ $ cd /opt/iobroker
    pi@iobrokerpi:/opt/iobroker $
    pi@iobrokerpi:/opt/iobroker $ iobroker start
    pi@iobrokerpi:/opt/iobroker $ iobroker status
    No objects found!
    pi@iobrokerpi:/opt/iobroker $ iobroker list instances
    No objects found!
    • jmeister79J jmeister79
      @Thomas-Braun
          Welcome to the ioBroker installation fixer!
          Script version: 2020-06-15
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
      Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
      Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [331 kB]
      Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
      Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.7 kB]
      Fetched 13.4 MB in 13s (1,007 kB/s)
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
      chown: changing ownership of '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/jest-resolve-dependencies/node_modules/ansi-styles/readme.md': Structure needs cleaning
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
      @jmeister79 sagte in Nach Shutdown vom Raspberry ioBroker weg:
      das habt ihr aber gesehen?
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        @Homoran
        Ja ..
        ist bei mir auch ( Syn Docker ) , deshalb nicht beachtet :
        sudo: Hostname iobroker kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
          @Homoran
          Ja ..
          @Glasfaser sagte in Nach Shutdown vom Raspberry ioBroker weg:
          Syn Docker
          dann bin ich wieder ganz still 😴
            Syn Docker
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            @Homoran sagte in Nach Shutdown vom Raspberry ioBroker weg:
            Eingentlich nicht ... er hat eine PI
              @Glasfaser ich habe viel zu wenig Ahnung von Linux und lese deswegen bei euch immer gerne mit um das zu ändern ;-)
              mir war vorhin nur aufgefallen:
              pi@iobrokerpi:~ $ which iobroker
              /usr/bin/iobroker
              pi@iobrokerpi:~ $ ls -la /usr/bin/iobroker
              lrwxrwxrwx 1 root root 22 Sep 16 14:19 /usr/bin/iobroker -> /opt/iobroker/iobroker
              pi@iobrokerpi:~ $ ls -la /opt/iobroker/iobroker
              -rwxr-xr-x+ 1 iobroker iobroker 305 Sep 16 14:19 /opt/iobroker/iobroker
              kann das aber nicht zuordnen.
              Ist das von einer Installation unter root, und der User iobroker kommt da ggf. nicht dran?
              GlasfaserG jmeister79J 2 Antworten Letzte Antwort
                @Glasfaser
                No objects found!
                No objects found!
                @jmeister79
                apt policy acl
                  /usr/bin/iobroker
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  Ich vergleiche auch nur ;)
                  ist bei mir auch :
                  root@iobroker:/opt/iobroker#  ls -la /usr/bin/iobroker
                  lrwxrwxrwx 1 root root 22 Sep 26 15:35 /usr/bin/iobroker -> /opt/iobroker/iobroker
                  r
                    /usr/bin/iobroker
                    jmeister79J Offline
                    jmeister79J Offline
                    jmeister79
                    @Homoran ich will nichts ausschliessen aber wenn ich jetzt mal streng nach sherlock vorgehe:
                    Das ding läuft jetzt seit zwei Jahren (jaja mit problemen) und seit ca 14 Tagen von USB eigentlich sehr stabil bis auf das Zigbeeproblem durch fehlendes Verlängerungskabel.
                    Warum nach reboot das jetzt?
                    Da kann ja nur mal wieder was kaputt sein.
                    ddas es ro ist ist doch schon falsch. ausserdem scannt er nach reboot das dateisystm nciht obwohl ich ihn durch
                    fsck.repair=yes
                    dazu zwinge.
                    grmpf
                    Menno
                    Nils
                      ist bei mir auch :
                      r
                      @Glasfaser
                      Nee, das passt. Ist ja auch nur ein Link, dem darf aber in dem Fall jeder folgen.
                        @Glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        @Thomas-Braun
                        du meinst @Homoran
                          @Thomas-Braun
                          du meinst @Homoran
                          @Glasfaser ja ;-)
                            @jmeister79
                            apt policy acl
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            @jmeister79
                            was ist hiermit !??
                            @Thomas-Braun sagte in Nach Shutdown vom Raspberry ioBroker weg:
                            @jmeister79
                            apt policy acl
                              fsck.repair=yes
                              dazu zwinge.
                              grmpf
                              Menno
                              Nils
                              fsck.repair=yes
                              dazu zwinge.
                              Das Dateisystem ist ja auch nicht defekt. Deswegen ist das auch rw gemounted und wird auch nicht einem fsck beim mounten unterzogen.
                              jmeister79J 1 Antwort Letzte Antwort
                                @jmeister79
                                apt policy acl
                                jmeister79J Offline
                                jmeister79J Offline
                                jmeister79
                                @Thomas-Braun
                                pi@iobrokerpi:~ $ apt policy acl
                                acl:
                                  Installed: 2.2.53-4
                                  Candidate: 2.2.53-4
                                  Version table:
                                 *** 2.2.53-4 500
                                        100 /var/lib/dpkg/status
                                  @Thomas-Braun
                                  acl:
                                    Installed: 2.2.53-4
                                    Candidate: 2.2.53-4
                                    Version table:
                                   *** 2.2.53-4 500
                                  @jmeister79
                                  sudo mount -o remount,acl /
                                    fsck.repair=yes
                                    dazu zwinge.
                                    jmeister79J Offline
                                    jmeister79J Offline
                                    jmeister79
                                    @Thomas-Braun
                                    Dann bezieht sich das hier auf die Boot Partition?
                                    [    3.225925] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [    3.236272] devtmpfs: mounted
                                    GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      @Thomas-Braun
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Glasfaser
                                      @jmeister79
                                      zeige mal die Ausgabe von :
                                      cd /opt/iobroker
                                      npm ls iobroker.js-controller
                                        @jmeister79
                                        cd /opt/iobroker
                                        jmeister79J Offline
                                        jmeister79J Offline
                                        jmeister79
                                        @Glasfaser said in Nach Shutdown vom Raspberry ioBroker weg:
                                        cd /opt/iobroker
                                        pi@iobrokerpi:/opt/iobroker $ npm ls iobroker.js-controller
                                        npm ERR! code MODULE_NOT_FOUND
                                        npm ERR! Cannot find module 'from2'
                                        npm ERR! Require stack:
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/mississippi/index.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/lib/entry-index.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/ls.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/locales/en.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/index.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/lib/with-tarball-stream.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/extract.js
                                        npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/index.js
                                        npm ERR! - /usr/lib/node_modules/npm/lib/fetch-package-metadata.js
                                        npm ERR! - /usr/lib/node_modules/npm/lib/install/deps.js
                                        npm ERR! - /usr/lib/node_modules/npm/lib/install/mutate-into-logical-tree.js
                                        npm ERR! - /usr/lib/node_modules/npm/lib/ls.js
                                        npm ERR! - /usr/lib/node_modules/npm/lib/npm.js
                                        npm ERR! - /usr/lib/node_modules/npm/bin/npm-cli.js
                                        npm ERR!     /home/iobroker/.npm/_logs/2020-09-26T14_03_34_872Z-debug.log
                                          cd /opt/iobroker
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Glasfaser
                                          @jmeister79
                                          Wenn @Thomas-Braun nichts anderes dazu sagt ... würde ich sagen du hast dein
                                          js-controller abgeschossen bzw. dein System .
