  4. Nach Shutdown vom Raspberry ioBroker weg
rebootproblem
61 Beiträge 4 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • jmeister79J jmeister79
    @Thomas-Braun
        Welcome to the ioBroker installation fixer!
        Script version: 2020-06-15
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
    Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [331 kB]
    Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
    Get:6 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58.7 kB]
    Fetched 13.4 MB in 13s (1,007 kB/s)
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
    chown: changing ownership of '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/jest-resolve-dependencies/node_modules/ansi-styles/readme.md': Structure needs cleaning
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    GlasfaserG Offline
    GlasfaserG Offline
    @jmeister79
    und jetzt :
    cd /opt/iobroker
    iobroker start
    iobroker status
    iobroker list instances
    jmeister79J 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @jmeister79
      und jetzt :
      cd /opt/iobroker
      iobroker start
      iobroker status
      jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @Glasfaser
      pi@iobrokerpi:~ $ cd /opt/iobroker
      pi@iobrokerpi:/opt/iobroker $
      pi@iobrokerpi:/opt/iobroker $ iobroker start
      pi@iobrokerpi:/opt/iobroker $ iobroker status
      No objects found!
      pi@iobrokerpi:/opt/iobroker $ iobroker list instances
      No objects found!
        @Thomas-Braun
        Installed gcc-c++
        Autostart enabled!
        @jmeister79 sagte in Nach Shutdown vom Raspberry ioBroker weg:
        das habt ihr aber gesehen?
          GlasfaserG Offline
          GlasfaserG Offline
          @Homoran
          Ja ..
          ist bei mir auch ( Syn Docker ) , deshalb nicht beachtet :
          sudo: Hostname iobroker kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
            @Homoran
            Ja ..
            @Glasfaser sagte in Nach Shutdown vom Raspberry ioBroker weg:
            Syn Docker
            dann bin ich wieder ganz still 😴
              Syn Docker
              GlasfaserG Offline
              GlasfaserG Offline
              @Homoran sagte in Nach Shutdown vom Raspberry ioBroker weg:
              Eingentlich nicht ... er hat eine PI
                @Glasfaser ich habe viel zu wenig Ahnung von Linux und lese deswegen bei euch immer gerne mit um das zu ändern ;-)
                mir war vorhin nur aufgefallen:
                pi@iobrokerpi:~ $ which iobroker
                /usr/bin/iobroker
                pi@iobrokerpi:~ $ ls -la /usr/bin/iobroker
                lrwxrwxrwx 1 root root 22 Sep 16 14:19 /usr/bin/iobroker -> /opt/iobroker/iobroker
                pi@iobrokerpi:~ $ ls -la /opt/iobroker/iobroker
                -rwxr-xr-x+ 1 iobroker iobroker 305 Sep 16 14:19 /opt/iobroker/iobroker
                kann das aber nicht zuordnen.
                Ist das von einer Installation unter root, und der User iobroker kommt da ggf. nicht dran?
                GlasfaserG jmeister79J 2 Antworten Letzte Antwort
                  @Glasfaser
                  No objects found!
                  No objects found!
                  @jmeister79
                  apt policy acl
                    /usr/bin/iobroker
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Ich vergleiche auch nur ;)
                    ist bei mir auch :
                    root@iobroker:/opt/iobroker#  ls -la /usr/bin/iobroker
                    lrwxrwxrwx 1 root root 22 Sep 26 15:35 /usr/bin/iobroker -> /opt/iobroker/iobroker
                    r
                      /usr/bin/iobroker
                      jmeister79J Offline
                      jmeister79J Offline
                      jmeister79
                      @Homoran ich will nichts ausschliessen aber wenn ich jetzt mal streng nach sherlock vorgehe:
                      Das ding läuft jetzt seit zwei Jahren (jaja mit problemen) und seit ca 14 Tagen von USB eigentlich sehr stabil bis auf das Zigbeeproblem durch fehlendes Verlängerungskabel.
                      Warum nach reboot das jetzt?
                      Da kann ja nur mal wieder was kaputt sein.
                      ddas es ro ist ist doch schon falsch. ausserdem scannt er nach reboot das dateisystm nciht obwohl ich ihn durch
                      fsck.repair=yes
                      dazu zwinge.
                      grmpf
                      Menno
                      Nils
                        ist bei mir auch :
                        r
                        @Glasfaser
                        Nee, das passt. Ist ja auch nur ein Link, dem darf aber in dem Fall jeder folgen.
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @Thomas-Braun
                          du meinst @Homoran
                            @Thomas-Braun
                            du meinst @Homoran
                            @Glasfaser ja ;-)
                              @jmeister79
                              apt policy acl
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @jmeister79
                              was ist hiermit !??
                              @Thomas-Braun sagte in Nach Shutdown vom Raspberry ioBroker weg:
                              @jmeister79
                              apt policy acl
                                fsck.repair=yes
                                dazu zwinge.
                                grmpf
                                Menno
                                Nils
                                fsck.repair=yes
                                dazu zwinge.
                                Das Dateisystem ist ja auch nicht defekt. Deswegen ist das auch rw gemounted und wird auch nicht einem fsck beim mounten unterzogen.
                                  @jmeister79
                                  apt policy acl
                                  jmeister79J Offline
                                  jmeister79J Offline
                                  jmeister79
                                  @Thomas-Braun
                                  pi@iobrokerpi:~ $ apt policy acl
                                  acl:
                                    Installed: 2.2.53-4
                                    Candidate: 2.2.53-4
                                    Version table:
                                   *** 2.2.53-4 500
                                    @Thomas-Braun
                                    acl:
                                      Installed: 2.2.53-4
                                      Candidate: 2.2.53-4
                                      Version table:
                                     *** 2.2.53-4 500
                                    @jmeister79
                                    sudo mount -o remount,acl /
                                      fsck.repair=yes
                                      dazu zwinge.
                                      jmeister79J Offline
                                      jmeister79J Offline
                                      jmeister79
                                      @Thomas-Braun
                                      Dann bezieht sich das hier auf die Boot Partition?
                                      [    3.225925] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                      [    3.236272] devtmpfs: mounted
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                        @Thomas-Braun
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @jmeister79
                                        zeige mal die Ausgabe von :
                                        cd /opt/iobroker
                                        npm ls iobroker.js-controller
                                          @jmeister79
                                          cd /opt/iobroker
                                          jmeister79J Offline
                                          jmeister79J Offline
                                          jmeister79
                                          @Glasfaser said in Nach Shutdown vom Raspberry ioBroker weg:
                                          cd /opt/iobroker
                                          pi@iobrokerpi:/opt/iobroker $ npm ls iobroker.js-controller
                                          npm ERR! code MODULE_NOT_FOUND
                                          npm ERR! Cannot find module 'from2'
                                          npm ERR! Require stack:
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/mississippi/index.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/lib/entry-index.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/ls.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/locales/en.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/cacache/index.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/lib/with-tarball-stream.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/extract.js
                                          npm ERR! - /usr/lib/node_modules/npm/node_modules/pacote/index.js
                                          npm ERR! - /usr/lib/node_modules/npm/lib/fetch-package-metadata.js
                                          npm ERR! - /usr/lib/node_modules/npm/lib/install/deps.js
                                          npm ERR! - /usr/lib/node_modules/npm/lib/install/mutate-into-logical-tree.js
                                          npm ERR! - /usr/lib/node_modules/npm/lib/ls.js
                                          npm ERR! - /usr/lib/node_modules/npm/lib/npm.js
                                          npm ERR! - /usr/lib/node_modules/npm/bin/npm-cli.js
                                          npm ERR!     /home/iobroker/.npm/_logs/2020-09-26T14_03_34_872Z-debug.log
