  4. ioBroker/Proxmox LXC Container: Kein Restore möglich
proxmox lxc restore
64 Beiträge 7 Kommentatoren 8.1k Aufrufe 4 Beobachtet
    @Kaiman55
    hmm ich würd erstmal mit
    cd /opt/iobroker
    systemctl stop iobroker
    iobroker fix
    systemctl start iobroker
    beobachten, obs ein Rechte-Problem war.
    Mehr helfen natürlich die Logfiles, also in
    /opt/iobroker/logs
    und
    /var/log
    und mit
    dmesg
    mal schauen, was geht..
    Kaiman55
    #61
    @ilovegym
    Moin Bernd,
    der Befehl "systemctl stop iobroker" wurde mit der folgenden Fehlermeldung quittiert:
    iobroker@iobroker-1804:~$ cd /opt/iobroker
    iobroker@iobroker-1804:/opt/iobroker$ systemctl stop iobroker
    Failed to stop iobroker.service: The name org.freedesktop.PolicyKit1 was not pro vided by any .service files
    See system logs and 'systemctl status iobroker.service' for details.
    Ich habe dann das normale "iobroker stop" probiert und anschliessend "iobroker fix"
    Das hast dann geklappt:
    iobroker@iobroker-1804:/opt/iobroker$ iobroker stop
    iobroker@iobroker-1804:/opt/iobroker$ iobroker fix
    library: loaded
    Library version=2020-06-12
        Welcome to the ioBroker installation fixer!
        Script version: 2020-06-15
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
    Hit:2 https://deb.nodesource.com/node_10.x bionic InRelease
    Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
    Get:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
    Get:5 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [1054 kB]
    Get:6 http://archive.ubuntu.com/ubuntu bionic-updates/main Translation-en [352 kB]
    Get:7 http://archive.ubuntu.com/ubuntu bionic-updates/restricted amd64 Packages [91.2 kB]
    Get:8 http://archive.ubuntu.com/ubuntu bionic-updates/restricted Translation-en [19.9 kB]
    Get:9 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1103 kB]
    Get:10 http://archive.ubuntu.com/ubuntu bionic-updates/universe Translation-en [343 kB]
    Get:11 http://archive.ubuntu.com/ubuntu bionic-security/main amd64 Packages [832 kB]
    Get:12 http://archive.ubuntu.com/ubuntu bionic-security/main Translation-en [260 kB]
    Get:13 http://archive.ubuntu.com/ubuntu bionic-security/restricted amd64 Packages [82.0 kB]
    Get:14 http://archive.ubuntu.com/ubuntu bionic-security/restricted Translation-en [17.8 kB]
    Get:15 http://archive.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [697 kB]
    Get:16 http://archive.ubuntu.com/ubuntu bionic-security/universe Translation-en [231 kB]
    Fetched 5260 kB in 4s (1401 kB/s)
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
    [sudo] password for iobroker:
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
    Und es hat diesmal tatsächlich geholfen.
    Alles ist wieder schnell wie am Anfang.
    Warum es mit dem Fix nicht schon beim ersten Mal geklappt hat, verstehe ich zwar nicht, aber ich freue mich sehr, dass wieder alles aktuell und schnell ist.
    Ein kleines Problem gibt es noch.
    Mein Blockly Scipt was per TR-064 den Anrufer raussucht und dann per Alexa ansagt (Scipt habe ich vor Ewigkeiten aus dem Forum) sagt nix mehr.
    Habe gelesen, dass man beim TR-64 Adapter das Passwort nochmal setzen soll. Aber gebracht hat es nichts.
    Meiner Meinung nach sind alle Objekte vorhanden.
    Andere Alexa Ansagen (Entschärfen Alarm bsw) funktionieren.
    Aber ich denke da schreibe ich nochmal einen neuen Eintrag, damit es hier nicht zu unübersichtlich wird.
    Da poste ich dann auch das Script.
    LG Kai
    • K Kaiman55
      @ilovegym
      Moin Bernd,
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      LG Kai
      crunchipC Abwesend
      crunchipC Abwesend
      #62
      @Kaiman55 sagte in ioBroker/Proxmox LXC Container: Kein Restore möglich:
      Falls deine Fritzbox ein Update bekommen hat, musst du den callmonitor wieder aktivieren
      K 1 Antwort Letzte Antwort
        Kaiman55
        #63
        @crunchip
        Danke für den Tipp.
        Aber wenn ich aktuell das alte Image von ioBroker aktiviere, also mit dem alten TR-064 läuft es sofort wieder.
        Mit dem gleichen Script.
        Der Monitor müsste demnach doch noch aktiv sein, oder?
        Ich probiere es nachher mal
        • K Kaiman55
          @crunchip
          Danke für den Tipp.
          crunchipC Abwesend
          crunchipC Abwesend
          #64
          @Kaiman55 ok, dann liegt es in dem Fall nicht am callmonitor
          Starte die Instanz neu und seh im Log nach, was er für Meldung/Hinweis zeigt, sollte z.b. callmonitor... oder Passwort.... dann als Hinweis auftauchen.
          Welche Version vom JS-Controller hast du installiert? Das Problem mit Passwort hing mit der Version vom tr-64 und Js-Controller zusammen.
