  4. Was sagt das Log aus?
log
17 Beiträge 4 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • KusselinK Offline
    KusselinK Offline
    Kusselin
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.cul@1.2.1',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.4
    3 info using node@v12.18.0
    4 verbose npm-session 3b3e98686580eaf8
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 silly fetchPackageMetaData error for iobroker.cul@1.2.1 request to https://registry.npmjs.org/iobroker.cul failed, reason: connect EHOSTUNREACH 104.16.19.35:443
    8 timing stage:rollbackFailedOptional Completed in 5ms
    9 timing stage:runTopLevelLifecycles Completed in 21089ms
    10 verbose type system
    11 verbose stack FetchError: request to https://registry.npmjs.org/iobroker.cul failed, reason: connect EHOSTUNREACH 104.16.19.35:443
    11 verbose stack     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
    11 verbose stack     at ClientRequest.emit (events.js:315:20)
    11 verbose stack     at TLSSocket.socketErrorListener (_http_client.js:426:9)
    11 verbose stack     at TLSSocket.emit (events.js:315:20)
    11 verbose stack     at emitErrorNT (internal/streams/destroy.js:92:8)
    11 verbose stack     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
    11 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)
    12 verbose cwd /opt/iobroker
    13 verbose Linux 4.19.118-v7+
    14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.cul@1.2.1" "--loglevel" "error" "--prefix" "/opt/iobroker"
    15 verbose node v12.18.0
    16 verbose npm  v6.14.4
    17 error code EHOSTUNREACH
    18 error errno EHOSTUNREACH
    19 error request to https://registry.npmjs.org/iobroker.cul failed, reason: connect EHOSTUNREACH 104.16.19.35:443
    20 verbose exit [ 1, true ]
    Danke für ne Info...trotz geupdatetem iobroker kommt die Meldung bei installation eines Adapters....System ist pi 3 mit buster
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • KusselinK Kusselin
      1 verbose cli [
      1 verbose cli ]
      Dr. BakteriusD Online
      Dr. Bakterius
      @Kusselin sagte in Was sagt das Log aus?:
      Die Adresse ist nicht erreichbar gewesen. Gerade von mir versucht, da klappt alles. Passt bei dir die Internetverbindung vom Raspi?
      • KusselinK Offline
        KusselinK Offline
        Kusselin
        Internet funzt
          Internet funzt
          @Kusselin
          Könnte mir npm 6.14.5 funktionieren.
          Am besten nodejs updaten, dann sollte npm automatisch mitkommen.
          • KusselinK Offline
            KusselinK Offline
            Kusselin
            O.K. danke Jungs, danke Thomas....
            ne Frage noch....bitte nicht steinigen.....wenn du schreibst updaten und zb das nodejs....wie mach ich das generell??
            bzw. wenn ich alles also alle adapter und auch das iobroker auf den neuesten Stand bringen will, was muss ich da speziell genau machen?
            Bei fhem zb. gebe ich oben in die Kommandozeile "UPDATE" ein...dann wird alles geupdatet..wie ist das bei iobroker? Danek euch
              Dr. Bakterius
              @Kusselin Sieh mal auf dieser (und jeder anderen) Seite rechts oben in den roten Kasten. Da findest du eine Beschreibung. Und die Adapter lassen sich alle im Admin-Bereich einzeln oder auch alle in einem Rutsch updaten.
              • KusselinK Offline
                KusselinK Offline
                Kusselin
                vor lauter Bäume sieht man den Wald net gell..
                https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                • KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  so und heute habe ich mal den host aktualisiert und dann kommt das raus...was sagt mir das alles mit den Fehlermeldungen???
                  pi@raspberrypi:~ $ iobroker upgrade self
                  Update js-controller from @3.1.4 to @3.1.6
                  NPM version: 6.14.5
                  npm install iobroker.js-controller@3.1.6 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
                  info sharp Attempting to build from source via node-gyp but this may fail due to the above error
                  info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                  ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
                   #include <vips/vips8>
                  compilation terminated.
                  make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                  gyp ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2
                  gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                  gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.19.66-v7+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/sharp
                  gyp ERR! node -v v10.21.0
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                  Starting node restart.js
                    NPM version: 6.14.5
                    gyp ERR! not ok
                    Dr. Bakterius
                    @Kusselin Das sind gyp-Errors. Die habe ich auch immer und trotzdem läuft alles. Wie sieht es denn bei dir aus? Wurde der js-Controller upgedatet? Läuft das System?
                    Aber wolltest du nicht eigentlich node.js updaten? Hat das funktioniert?
                    • KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      schrieb am zuletzt editiert von Kusselin
                      Hi, System läuft soweit.
                      node.js habe ich noch nicht geupdatet.....dazu kann ich ja oben rechts im roten Kasten die beschreibung befolgen...richtig?
                      Ich schau mal heute abend welche node version ich aktuell habe mit "node -v"
                      Könnt ihr mir dann sagen ob ich aupdaten muss oder soll?
                        @Kusselin
                        Das dürfte dann nodejs 10.21.0 bei dir sein. Ich würde auf den node12-Zweig springen. Geht ja per apt easy von der Hand, wenn die Vorversion richtig installiert worden ist.
                        • KusselinK Offline
                          KusselinK Offline
                          Kusselin
                          hab die v10.21.0
                            hab die v10.21.0
                            @Kusselin
                            Wie gesagt, ich würde auf node12 gehen.
                            • KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              Dann einfach der Anleitung oben HowTo: Node.js-Update
                              folgen, richtig?
                                folgen, richtig?
                                @Kusselin Jein... :-)
                                Ich persönlich mache es immer etwas anders als in der Anleitung. Aber prinzipiell funktioniert das nach Anleitung, ja.
                                  @Thomas-Braun sagte in Was sagt das Log aus?:
                                  könntest du mir das mal zusammenfassen und als PN schicken?
                                  Habe ich schon mehrfach live mitverfolgt aber mangels Linux-Kenntnis nie behalten können
                                  Werde ich mal an einer Testinstallation ausprobieren und ggf. als Alternative mit in die Doku übernehmen.
                                    @Homoran
                                    Siehe https://forum.iobroker.net/topic/35090/nodejs-installation-und-upgrades-unter-linux-debian
