  4. Sit Update von JS auf 3.14 Tradfi Adapter immer wieder Rot
tradfri adapter
72 Beiträge 6 Kommentatoren 7.1k Aufrufe 4 Beobachtet
  • H Offline
    Homebroker
    schrieb am zuletzt editiert von Homebroker
    #41
      "ts": 1591268206856,
      "user": "system.user.admin",
      "protectedNative": [
        "securityCode",
        "identity",
        "psk"
      "encryptedNative": [],
      "instanceObjects": [
          "_id": "info",
          "type": "channel",
          "common": {
            "name": "Adapter-Information"
          "native": {}
          "_id": "info.connection",
          "type": "state",
          "common": {
            "role": "indicator.connected",
            "name": "Whether the adapter is connected to the gateway",
            "type": "boolean",
            "read": true,
            "write": false,
            "def": false
          "native": {}
      "objects": [],
      "enums": {},
      "common": {
        "name": "tradfri",
        "version": "2.6.3",
        "title": "IKEA Trådfri",
        "license": "MIT",
        "platform": "Javascript/Node.js",
        "main": "build/main.js",
        "mode": "daemon",
        "extIcon": "https://raw.githubusercontent.com/AlCalzone/ioBroker.tradfri/master/admin/tradfri.png",
        "readme": "https://github.com/AlCalzone/ioBroker.tradfri/blob/master/README.md",
        "loglevel": "info",
        "type": "lighting",
        "installedFrom": "iobroker.tradfri@2.6.3",
        "installedVersion": "2.6.3",
        "host": "raspberrypi",
        "enabled": true,
        "messagebox": true,
        "materialize": true,
        "compact": true,
        "news": {
          "2.6.2": {
            "en": "* Bugfix: The unhandled error handler should now correctly log the error even if `adapter` is not defined",
            "de": "* Bugfix: Der nicht behandelte Fehlerbehandler sollte den Fehler jetzt korrekt protokollieren, auch wenn \"Adapter\" nicht definiert ist",
            "ru": "* Исправление: необработанный обработчик ошибок теперь должен корректно регистрировать ошибку, даже если `адаптер` не определен",
            "pt": "* Correção de erro: O manipulador de erros não manipulados agora deve registrar corretamente o erro, mesmo que o `adaptador` não esteja definido",
            "nl": "* Bugfix: de niet-verwerkte foutafhandelaar moet de fout nu correct registreren, zelfs als `adapter` niet is gedefinieerd",
            "fr": "* Bugfix: le gestionnaire d'erreurs non géré devrait maintenant correctement enregistrer l'erreur même si `adaptateur` n'est pas défini",
            "it": "* Bugfix: il gestore degli errori non gestiti dovrebbe ora registrare correttamente l'errore anche se `adapter` non è definito",
            "es": "* Corrección de errores: el controlador de errores no manejado ahora debe registrar correctamente el error incluso si no se ha definido `adaptador`",
            "pl": "* Bugfix: Nieobsługiwany moduł obsługi błędów powinien teraz poprawnie rejestrować błąd, nawet jeśli `adapter 'nie jest zdefiniowany",
            "zh-cn": "*修正:未处理的错误处理程序现在应该正确记录错误,即使未定义`adapter`"
          "2.6.1": {
            "en": "* Bugfix: Blinds would not always be stopped",
            "de": "* Bugfix: Blinds würden nicht immer gestoppt",
            "ru": "* Исправление: жалюзи не всегда останавливались",
            "pt": "* Correção de erros: as cortinas nem sempre eram interrompidas",
            "nl": "* Bugfix: blinds werden niet altijd gestopt",
            "fr": "* Bugfix: les stores ne seraient pas toujours arrêtés",
            "it": "* Bugfix: i blind non sarebbero sempre stati fermati",
            "es": "* Corrección de errores: las persianas no siempre se detendrían",
            "pl": "* Bugfix: Żaluzje nie zawsze były zatrzymywane",
            "zh-cn": "*错误修正:百叶窗不会总是停止"
          "2.6.0": {
            "en": "* Support stopping blinds at their current position",
            "de": "* Unterstützung beim Stoppen von Jalousien an ihrer aktuellen Position",
            "ru": "* Поддержка остановки блайндов в их текущем положении",
            "pt": "* Suporte para parar as cortinas na posição atual",
            "nl": "* Ondersteuning voor het stoppen van jaloezieën op hun huidige positie",
            "fr": "* Soutenir l'arrêt des stores à leur position actuelle",
            "it": "* Supporta l'arresto dei bui nella loro posizione attuale",
            "es": "* Soporte para detener las persianas en su posición actual",
            "pl": "* Obsługa zatrzymywania żaluzji w ich bieżącej pozycji",
            "zh-cn": "*支持将百叶窗停在当前位置"
          "2.5.2": {
            "en": "* Fix: Suppress log warnings for Symfonisk remotes",
            "de": "* Korrektur: Unterdrückung von Protokollwarnungen für Symfonisk-Fernbedienungen",
            "ru": "* Исправлено: Подавление предупреждений журнала для удаленных пользователей Symfonisk.",
            "pt": "* Correção: suprimir avisos de log para controles remotos Symfonisk",
            "nl": "* Oplossing: logboekwaarschuwingen onderdrukken voor Symfonisk-afstandsbedieningen",
            "fr": "* Correction: supprimer les avertissements de journal pour les télécommandes Symfonisk",
            "it": "* Correzione: sopprimere gli avvisi del registro per i telecomandi Symfonisk",
            "es": "* Solución: elimine las advertencias de registro para los controles remotos Symfonisk",
            "pl": "* Poprawka: Pomija ostrzeżenia dziennika dla pilotów Symfonisk",
            "zh-cn": "*修复:抑制Symfonisk遥控器的日志警告"
          "2.5.1": {
            "en": "Made it possible to operate plugs using virtual groups",
            "de": "Ermöglicht den Betrieb von Steckern mit virtuellen Gruppen",
            "ru": "Сделано возможным управлять пробками с помощью виртуальных групп",
            "pt": "Tornou possível operar plugues usando grupos virtuais",
            "nl": "Maakte het mogelijk om pluggen te bedienen met behulp van virtuele groepen",
            "fr": "A rendu possible le fonctionnement des prises à l'aide de groupes virtuels",
            "it": "Ha reso possibile il funzionamento delle spine tramite gruppi virtuali",
            "es": "Hizo posible operar enchufes usando grupos virtuales",
            "pl": "Umożliwiło obsługę wtyczek przy użyciu grup wirtualnych",
            "zh-cn": "使使用虚拟组操作插头成为可能"
          "2.5.0": {
            "en": "More device types are allowed in virtual groups",
            "de": "Weitere Gerätetypen sind in virtuellen Gruppen zulässig",
            "ru": "В виртуальных группах разрешено использовать больше типов устройств",
            "pt": "Mais tipos de dispositivos são permitidos em grupos virtuais",
            "nl": "Meer apparaattypen zijn toegestaan in virtuele groepen",
            "fr": "Plus de types d'appareils sont autorisés dans les groupes virtuels",
            "it": "Sono consentiti più tipi di dispositivi nei gruppi virtuali",
            "es": "Se permiten más tipos de dispositivos en grupos virtuales",
            "pl": "Więcej typów urządzeń jest dozwolonych w grupach wirtualnych",
            "zh-cn": "虚拟组中允许更多设备类型"
          "2.4.7": {
            "en": "Fixed small display issues with 3rd party bulbs",
            "de": "Kleine Anzeigeprobleme mit Glühlampen von Drittanbietern wurden behoben",
            "ru": "Исправлены небольшие проблемы с отображением ламп сторонних производителей",
            "pt": "Corrigidos pequenos problemas de exibição com lâmpadas de terceiros",
            "nl": "Kleine weergaveproblemen met lampen van derden opgelost",
            "fr": "Correction de petits problèmes d'affichage avec les ampoules de tiers",
            "it": "Risolti piccoli problemi di visualizzazione con lampadine di terze parti",
            "es": "Se corrigieron pequeños problemas de visualización con bombillas de terceros",
            "pl": "Naprawiono małe problemy z wyświetlaniem w żarówkach innych firm",
            "zh-cn": "修复了第三方灯泡的小型显示问题"
          "2.4.6": {
            "en": "Group states for blinds are now synchronized correctly",
            "de": "Gruppenstatus für Jalousien werden jetzt korrekt synchronisiert",
            "ru": "Состояния группы для блайндов теперь правильно синхронизированы",
            "pt": "Os estados do grupo para blinds agora estão sincronizados corretamente",
            "nl": "Groepstoestanden voor blinds worden nu correct gesynchroniseerd",
            "fr": "Les états de groupe pour les stores sont maintenant correctement synchronisés",
            "it": "Gli stati di gruppo per i blind sono ora sincronizzati correttamente",
            "es": "Los estados de grupo para persianas ahora se sincronizan correctamente",
            "pl": "Stany grup dla blindów są teraz poprawnie synchronizowane",
            "zh-cn": "百叶窗的组状态现在可以正确同步"
          "2.4.5": {
            "en": "Suppressed log warnings for motion sensors",
            "de": "Logwarnungen für Bewegungssensoren unterdrückt",
            "ru": "Подавленные предупреждения журнала для датчиков движения",
            "pt": "Avisos de log suprimidos para sensores de movimento",
            "nl": "Onderdrukte logwaarschuwingen voor bewegingssensoren",
            "fr": "Alertes de journalisation supprimées pour les détecteurs de mouvement",
            "it": "Avvisi di registro eliminati per i sensori di movimento",
            "es": "Advertencias de registro suprimidas para sensores de movimiento",
            "pl": "Ukryte ostrzeżenia dziennika dla czujników ruchu",
            "zh-cn": "禁止运动传感器的日志警告"
          "2.4.4": {
            "en": "Suppressed log warnings for slave remotes and signal repeaters",
            "de": "Logwarnungen für Slave-Fernbedienungen und Signalwiederholer unterdrückt",
            "ru": "Подавленные предупреждения журнала для ведомых пультов и ретрансляторов сигнала",
            "pt": "Advertências de log suprimidas para controles remotos escravos e repetidores de sinal",
            "nl": "Onderdrukte logwaarschuwingen voor slave-afstandsbedieningen en signaalrepeaters",
            "fr": "Alertes de journalisation supprimées pour les télécommandes esclaves et les répéteurs de signaux",
            "it": "Avvisi di registro eliminati per telecomandi slave e ripetitori di segnale",
            "es": "Advertencias de registro suprimidas para controles remotos esclavos y repetidores de señal",
            "pl": "Ukryte ostrzeżenia dziennika dla pilotów slave i repeaterów sygnałów",
            "zh-cn": "从属遥控器和信号中继器的禁止日志警告"
          "2.4.3": {
            "en": "Fix: Operate blinds when states are changed",
            "de": "Fix: Jalousien betätigen, wenn Zustände geändert werden",
            "ru": "Исправлено: работа блайндов при смене состояний",
            "pt": "Correção: operar blinds quando os estados são alterados",
            "nl": "Oplossing: jaloezieën bedienen wanneer staten worden gewijzigd",
            "fr": "Corrigé: Utiliser les stores quand les états sont changés",
            "it": "Correzione: aziona i blind quando cambiano gli stati",
            "es": "Solución: operar persianas cuando se cambian los estados",
            "pl": "Poprawka: uruchamiaj żaluzje, gdy zmienia się stan",
            "zh-cn": "修复:状态更改时操作百叶窗"
          "2.4.2": {
            "en": "Fix: also create objects for blinds",
            "de": "Fix: Objekte für Jalousien werden nun korrekt erstellt",
            "ru": "Исправлено: также создавать объекты для жалюзи",
            "pt": "Correção: também cria objetos para blinds",
            "nl": "Oplossing: maak ook objecten voor blinds",
            "fr": "Correction: créer également des objets pour les stores",
            "it": "Correzione: crea anche oggetti per persiane",
            "es": "Solución: también crea objetos para persianas",
            "pl": "Poprawka: twórz także obiekty dla żaluzji",
            "zh-cn": "修复:还为百叶窗创建对象"
          "2.4.0": {
            "en": "Added support for blinds",
            "de": "Unterstützung für Jalousien hinzugefügt",
            "ru": "Добавлена поддержка жалюзи",
            "pt": "Adicionado suporte para blinds",
            "nl": "Ondersteuning toegevoegd voor blinds",
            "fr": "Ajout du support pour les stores",
            "it": "Aggiunto supporto per i bui",
            "es": "Se agregó soporte para persianas",
            "pl": "Dodano obsługę żaluzji",
            "zh-cn": "增加了对百叶窗的支持"
          "2.3.0": {
            "en": "The gateway can now be discovered automatically",
            "de": "Automatische Erkennung des Gateways hinzugefügt",
            "ru": "Шлюз теперь может быть обнаружен автоматически",
            "pt": "O gateway pode agora ser descobertos automaticamente",
            "nl": "De gateway kan nu worden ontdekt automatisch",
            "fr": "La passerelle peut maintenant être découvert automatiquement",
            "it": "Il gateway può ora essere individuati automaticamente",
            "es": "La puerta de enlace puede ahora ser descubiertos automáticamente",
            "pl": "Brama może być wykryty automatycznie",
            "zh-cn": "该网关,现在可以自动发现"
          "2.2.0": {
            "en": "Expose the battery percentage for devices with a battery",
            "de": "Legen Sie den Batterieprozentsatz für Geräte mit Akku offen",
            "ru": "Выставьте процент батареи для устройств с батареей",
            "pt": "Exponha a porcentagem da bateria para dispositivos com bateria",
            "nl": "Stel het batterijpercentage bloot voor apparaten met een batterij",
            "fr": "Exposer le pourcentage de batterie pour les appareils dotés d'une batterie",
            "it": "Esporre la percentuale della batteria per i dispositivi con una batteria",
            "es": "Exponer el porcentaje de batería para dispositivos con batería.",
            "pl": "Odsłonić procent baterii dla urządzeń z baterią",
            "zh-cn": "显示带电池的设备的电池百分比"
          "2.1.0": {
            "en": "* Support for compact mode\n* Optimizations and fixes under the hood\n* When `node-aead-crypto` is not installed, display instructions on how to fix it",
            "de": "* Unterstützung für den Kompaktmodus\n* Optimierungen und Korrekturen unter der Haube\n* Wenn `node-aead-crypto` nicht installiert ist, zeigen Sie Anweisungen zur Behebung an",
            "ru": "* Поддержка компактного режима\n* Оптимизация и исправления под капотом\n* Когда `node-aead-crypto` не установлен, отобразите инструкции о том, как это исправить",
            "pt": "* Suporte para o modo compacto\n* Otimizações e correções sob o capô\n* Quando o `node-aead-crypto` não está instalado, exibe instruções sobre como corrigi-lo",
            "nl": "* Ondersteuning voor de compacte modus\n* Optimalisaties en oplossingen onder de motorkap\n* Wanneer `node-aead-crypto` niet is geïnstalleerd, geeft u instructies voor het oplossen ervan op",
            "fr": "* Prise en charge du mode compact\n* Optimisations et corrections sous le capot\n* Lorsque `node-aead-crypto` n'est pas installé, affiche les instructions pour le corriger.",
            "it": "* Supporto per la modalità compatta\n* Ottimizzazioni e correzioni sotto il cofano\n* Quando `node-aead-crypto` non è installato, visualizzare le istruzioni su come risolverlo",
            "es": "* Soporte para modo compacto.\n* Optimizaciones y correcciones bajo el capó.\n* Cuando `node-aead-crypto` no está instalado, muestra instrucciones sobre cómo solucionarlo",
            "pl": "* Wsparcie dla trybu kompaktowego\n* Optymalizacje i poprawki pod maską\n* Kiedy `node-aead-crypto` nie jest zainstalowany, wyświetl instrukcje, jak to naprawić",
            "zh-cn": "*支持紧凑的模式\n*优化和修复盖下\n*当`节点-aead-加密`是没有安装,显示说明如何解决它"
          "2.0.0": {
            "en": "Switched to material design, dropped Admin v2 support.",
            "de": "Zu material design gewechselt und Admin v2 Unterstützung gestrichen.",
            "ru": "Перешли на материал конструкции, за админ поддержка V2.",
            "pt": "Mudou para material de desenho, caiu de Administração v2 suporte.",
            "nl": "Geschakeld-ontwerp van het materiaal, liet Admin v2 ondersteuning.",
            "fr": "Passé à la conception de matériel, a chuté de l'Admin v2 de soutien.",
            "it": "Commutato in material design, è sceso Admin v2 supporto.",
            "es": "De conmutación para el diseño de materiales, cayó Administrador v2 apoyo.",
            "pl": "Przeszli na materiał konstrukcji, za admin wsparcie V2.",
            "zh-cn": "切换到的材料设计,下降了管理v2的支持。"
          "2.6.3": {
            "en": "Bugfix: Changed the role of RGB states to `level.color.rgb`",
            "de": "Bugfix: Die Rolle der RGB-Zustände wurde in \"level.color.rgb\" geändert",
            "ru": "Исправлено: изменена роль состояний RGB на `level.color.rgb`",
            "pt": "Correção de bug: Alterada a função dos estados RGB para `level.color.rgb`",
            "nl": "Bugfix: de rol van RGB-staten gewijzigd in `level.color.rgb`",
            "fr": "Bugfix: Changé le rôle des états RVB en `level.color.rgb`",
            "it": "Bugfix: modificato il ruolo degli stati RGB in `level.color.rgb`",
            "es": "Corrección de errores: se cambió la función de los estados RGB a `level.color.rgb`",
            "pl": "Bugfix: Zmieniono rolę stanów RGB na `level.color.rgb`",
            "zh-cn": "错误修正:将RGB状态的角色更改为`level.color.rgb`"
        "titleLang": {
          "de": "IKEA Trådfri",
          "en": "IKEA Trådfri",
          "es": "IKEA Trådfri",
          "fr": "IKEA Trådfri",
          "it": "IKEA Trådfri",
          "nl": "IKEA Trådfri",
          "pl": "IKEA Trådfri",
          "pt": "IKEA Trådfri",
          "ru": "IKEA Trådfri",
          "zh-cn": "宜家Trådfri"
        "desc": {
          "en": "Communicates with IKEA Trådfri Gateway to control devices",
          "de": "Kommuniziert mit IKEA Trådfri Gateway, um Geräte zu steuern",
          "ru": "Общается с ИКЕА шлюз Trådfri для управления устройствами",
          "pt": "Comunica-se com a IKEA Trådfri Gateway para dispositivos de controle de",
          "nl": "Communiceert met de IKEA Trådfri Gateway om de apparatuur te bedienen",
          "fr": "Communique avec IKEA Trådfri Passerelle de dispositifs de contrôle de la",
          "it": "Comunica con IKEA Trådfri Gateway per dispositivi di controllo",
          "es": "Se comunica con IKEA Trådfri Puerta de entrada a los dispositivos de control de",
          "pl": "Komunikuje się z IKEA brama Trådfri do zarządzania urządzeniami",
          "zh-cn": "与IKEA Trådfri网关,以控制设备"
        "authors": [
          "AlCalzone <d.griesel@gmx.net>"
        "keywords": [
          "ikea",
          "tradfri"
        "dependencies": [
            "js-controller": ">=1.4.2"
        "icon": "tradfri.png"
      "native": {
        "host": "192.168.178.73",
        "securityCode": "gpt6OjyRvnafEN12",
        "identity": "tradfri_1591252791952",
        "psk": "uHP3Y1bougDNo0U5",
        "roundToDigits": 2,
        "discoverGateway": true,
        "preserveTransitionTime": true
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
      "_id": "system.adapter.tradfri.0",
      "type": "instance"
    • H Offline
      Homebroker
      #42
      undtradfri.pcap
      • H Offline
        Homebroker
        #43
        Sorry aber die Code Umwandlung hat nicht geklappt beim RAW Code
        • H Homebroker
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #44
          @Homebroker Alles gut, die nötigen Infos sind enthalten.
          Warum sudo böse ist: https://forum.iobroker.net/post/17109
          • H Offline
            Homebroker
            #45
            Habs jetzt nachträglich hinbekommen. Danke schon mal für die Arbeit die Du Dir machst!
            • H Homebroker
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #46
              @Homebroker Vielleicht kannst du mir gerade weiterhelfen. Du hast eine Gruppe "leer", in der "Lampe Fernseher" drin ist. Beim Abfragen der Szenen für diese Gruppe erhält der Adapter erst die Liste der Szenen, wenn er aber die Details zu diesen Szenen abfragen will, kommt "not found" (und er stürzt ab).
              Alle anderen funktionieren. Ist mit dieser Gruppe irgendetwas besonderes bzw. kann man in der Tradfri-App was dazu erkennen?
              • H Offline
                Homebroker
                #47
                Diese Gruppe kann ich in der App nicht löschen. Ich soll alle Geräte erst entfernen, obwohl sie keine Geräte enthält.
                • H Homebroker
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #48
                  @Homebroker Interessant, dann hat die App selbst wohl auch ein Problem damit :D
                  Laut deinem Log ist da wie gesagt noch die Lampe "Lampe Fernseher" drin.
                  Ich werde später zusehen, dass der Adapter bei sowas zumindest nicht mehr abstürzt.
                  • AlCalzoneA AlCalzone
                    #49
                    @AlCalzone @Homebroker
                    Ich hatte mal sowas ähnliches, da sind plötzlich Tradfri-Geräte in einer anderen Gruppe gelandet, konnte man in der App auch nicht mehr löschen oder korrigieren. Ich musste den ganzen Sums dann zurücksetzen und ganz bei Null anfangen. :-(
                    • H Offline
                      Homebroker
                      #50
                      Also der Witz an der Sache ist das es bis zum Admin Update ohne Probleme lief.
                      • H Offline
                        Homebroker
                        #51
                        Genau das war es. nun läuft der Adapter wieder. Gateway reset und alles neu eingerichtet.
                        • H Homebroker
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #52
                          @Homebroker der Fehler wurde in älteren Versionen von js-controller übersehen bzw ignoriert und ist daher nie aufgefallen.
                          Jetzt ist alles ein bisschen strenger.
                          • H Offline
                            Homebroker
                            #53
                            @Thomas-Braun
                            Du hattest erwähn das bei mir erst mal eine Basis wieder rein müsste. hat sich das nun mit dem umstellen auf "latest" beim Verwahrort erledigt oder muss ich da noch was weiter machen?
                            J Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                            • H Homebroker
                              @Thomas-Braun
                              Jan1
                              #54
                              @Homebroker
                              Wenn Du alle Updates die dieses Repo hergibt gemacht hast und in der Adapter Übersicht alle Zustände denen entsprechen, die dieses Repo anbietet, dann ist die Basis vorhanden ;-)
                              Wobei das auch auf default funktioniert hätte, nur dass bei Dir zu Beginn auch einige Versionen drin waren, die höher als die im default waren und das etwas umständlicher geworden wäre. Latest ist aber OK und kann so bleiben.
                              • H Homebroker
                                @Thomas-Braun
                                #55
                                @Homebroker
                                Nö, scheint jetzt alles i. O.
                                Kannst auch den Verwahrort wieder auf 'default' setzen. Oder auf 'latest' lassen... Wie du magst (und handeln kannst).
                                • H Offline
                                  Homebroker
                                  #56
                                  pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                                  system.adapter.admin                   : admin          - v4.1.1
                                  system.adapter.amazon-dash             : amazon-dash    - v0.3.1
                                  system.adapter.backitup                : backitup       - v1.5.8
                                  system.adapter.chromecast              : chromecast     - v2.3.1
                                  system.adapter.deconz                  : deconz         - v0.2.0
                                  system.adapter.devices                 : devices        - v0.3.6
                                  system.adapter.discovery               : discovery      - v2.3.6
                                  system.adapter.dwd                     : dwd            - v2.4.10
                                  system.adapter.email                   : email          - v1.0.6
                                  system.adapter.feiertage               : feiertage      - v1.0.19
                                  system.adapter.flot                    : flot           - v1.10.0
                                  system.adapter.fritzdect               : fritzdect      - v0.3.2
                                  system.adapter.fullcalendar            : fullcalendar   - v1.1.0
                                  system.adapter.history                 : history        - v1.9.8
                                  system.adapter.hm-rega                 : hm-rega        - v2.6.9
                                  system.adapter.hm-rpc                  : hm-rpc         - v1.14.5
                                  system.adapter.ical                    : ical           - v1.7.0
                                  system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
                                  system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                                  system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
                                  system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                  system.adapter.info                    : info           - v1.7.4
                                  system.adapter.javascript              : javascript     - v4.6.17
                                  system.adapter.kodi                    : kodi           - v1.0.0
                                  system.adapter.mihome                  : mihome         - v1.3.0
                                  system.adapter.modbus                  : modbus         - v2.0.9
                                  system.adapter.openhab                 : openhab        - v0.2.1
                                  system.adapter.parser                  : parser         - v1.0.7
                                  system.adapter.paw                     : paw            - v0.2.7
                                  system.adapter.pollenflug              : pollenflug     - v1.0.3
                                  system.adapter.roomba-rw               : roomba-rw      - v0.0.1
                                  system.adapter.sbfspot                 : sbfspot        - v3.0.0
                                  system.adapter.scenes                  : scenes         - v1.1.0
                                  system.adapter.schoolfree              : schoolfree     - v0.6.2
                                  system.adapter.shelly                  : shelly         - v3.2.8
                                  system.adapter.shuttercontrol          : shuttercontrol - v0.6.2
                                  system.adapter.socketio                : socketio       - v3.0.7
                                  system.adapter.sonoff                  : sonoff         - v2.3.3
                                  system.adapter.spotify-premium         : spotify-premium - v1.0.0
                                  system.adapter.systeminfo              : systeminfo     - v0.3.1
                                  system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
                                  system.adapter.telegram                : telegram       - v1.4.3
                                  system.adapter.terminal                : terminal       - v0.1.2
                                  system.adapter.tr-064                  : tr-064         - v0.4.14
                                  system.adapter.tradfri                 : tradfri        - v2.6.3
                                  system.adapter.vaillant                : vaillant       - v0.0.10
                                  system.adapter.vis                     : vis            - v1.2.6
                                  system.adapter.vis-bars                : vis-bars       - v0.1.4
                                  system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                                  system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                  system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                                  system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                                  system.adapter.vis-metro               : vis-metro      - v1.1.2
                                  system.adapter.vis-players             : vis-players    - v0.1.6
                                  system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                                  system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                  system.adapter.vis-weather             : vis-weather    - v2.5.2
                                  system.adapter.weatherunderground      : weatherunderground - v3.2.1
                                  system.adapter.web                     : web            - v3.0.8
                                  system.adapter.worx                    : worx           - v1.0.2
                                  system.adapter.yr                      : yr             - v2.0.3```
                                  code_text
                                  J 1 Antwort Letzte Antwort
                                  • H Offline
                                    Homebroker
                                    #57
                                    nur noch mal zum checken
                                    • H Homebroker
                                      code_text
                                      Jan1
                                      #58
                                      @Homebroker
                                      Schau einfach mal das an:
                                      Wenn die Versionen übereinstimmen, ist alle OK.
                                      Dann kannst links oben im IOBroker mal das Dreieck klicken und "Hosts" anhaken (falls nicht eh schon drin), wenn der auch kein Update mehr hergibt, ist Dein System aktuell.
                                      • H Offline
                                        Homebroker
                                        #59
                                        OK dann passt es soweit. Komisch nur beim "Open icon library set as PNG-Adapter" Installiert 1.3 verfügbar 1.2?
                                        • H Homebroker
                                          Jan1
                                          #60
                                          @Homebroker
                                          Da hast wohl was über Github installiert und nicht über den Admin. Kann man machen, wenn man weiß was man tut und die möglichen Konsequenzen kennt.
