  4. Telegramm bekomme ich nicht grün (GELÖST)
telegramm
65 Beiträge 3 Kommentatoren 7.3k Aufrufe 1 Beobachtet
  • H Henny112
    @Thomas-Braun mache ich mal eben mal sehen passiert
    Henny112
    #41
    @Henny112 js controller habe 2.2.9 das ol oder
      @Henny112
      Jetzt sind es fünf.
      Zeilenweise eingeben oder reinkopieren.
      Henny112
      #42
      @Thomas-Braun
      host.raspberrypi	2020-05-28 23:18:44.391	info	instance system.adapter.radar2.0 started with pid 6611
      host.raspberrypi	2020-05-28 23:18:38.874	info	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2020-05-28 23:18:38.874	error	Caught by controller[0]: }
      host.raspberrypi	2020-05-28 23:18:38.874	error	Caught by controller[0]: ]
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
      host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
      host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
      host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: ^
      host.raspberrypi	2020-05-28 23:18:38.870	error	Caught by controller[0]: throw err;
      host.raspberrypi	2020-05-28 23:18:38.870	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
      host.raspberrypi	2020-05-28 23:18:38.675	info	stopInstance system.adapter.telegram.0 send kill signal
      host.raspberrypi	2020-05-28 23:18:38.672	info	stopInstance system.adapter.telegram.0 (force=false, process=true)
      host.raspberrypi	2020-05-28 23:18:38.669	info	"system.adapter.telegram.0" disabled
      host.raspberrypi	2020-05-28 23:18:38.601	info	instance system.adapter.telegram.0 started with pid 6422
      host.raspberrypi	2020-05-28 23:18:37.552	info	Restart adapter system.adapter.telegram.0 because enabled
      host.raspberrypi	2020-05-28 23:18:37.552	error	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: }
      host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: ]
      host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
      host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
      host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
      host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: requireStack: [
      host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
      host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: Require stack:
      host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
      host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: ^
      host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: throw err;
      host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
      host.raspberrypi	2020-05-28 23:18:37.302	info	instance system.adapter.telegram.0 started with pid 6415
      host.raspberrypi	2020-05-28 23:18:36.266	info	Restart adapter system.adapter.telegram.0 because enabled
      • H Henny112
        @Thomas-Braun
        #43
        @Henny112 sagte in Telegramm bekomme ich nicht grün:
        cd /opt/iobroker
        npm i array.prototype.findindex
        iobroker fix
        H 1 Antwort Letzte Antwort
          cd /opt/iobroker
          iobroker fix
          Henny112
          #44
          @Thomas-Braun
          unverändert zeigt das selbe an wie vorher +
          • H Henny112
            @Thomas-Braun
            #45
            @Henny112 Zeig mal den Konsolenoutput
              Henny112
              #46
              @Thomas-Braun Was für ein ding wie komme ich da hin was du meinst
              • H Henny112
                #47
                @Henny112 Die Rückmeldungen auf die drei Befehle.
                H 2 Antworten Letzte Antwort
                  Henny112
                  #48
                  @Thomas-Braun du meinst das mit node von oben ?
                    Henny112
                    #49
                    @Thomas-Braun
                    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
                    /usr/bin/nodejs
                    v12.17.0
                    /usr/bin/node
                    v12.17.0
                    /usr/bin/npm
                    6.14.4
                    pi@raspberrypi:~ $
                    • H Henny112
                      #50
                      @Henny112
                      cd /opt/iobroker
                      iobroker fix
                      Was kommt da zurück? Bitte komplette Ausgaben posten.
                        @Henny112
                        cd /opt/iobroker
                        iobroker fix
                        Henny112
                        #51
                        @Thomas-Braun sagte in Telegramm bekomme ich nicht grün:
                        iobroker fix
                        Dann muss ich ja wieder alles stoppen sonst läuft der fixer doch nicht oder ?
                        • H Henny112
                          iobroker fix
                          #52
                          @Henny112
                          Und?
                          iobroker stop
                          und gut ist.
                            @Henny112
                            cd /opt/iobroker
                            iobroker fix
                            Henny112
                            #53
                            @Thomas-Braun
                            pi@raspberrypi:~ $ cd /opt/iobroker
                            pi@raspberrypi:/opt/iobroker $ npm i array.prototype.findindex
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/node-bluetooth/package.json'
                            npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
                            + array.prototype.findindex@2.1.0
                            updated 1 package in 37.435s
                            32 packages are looking for funding
                              run `npm fund` for details
                            pi@raspberrypi:/opt/iobroker $ iobroker fix
                            library: loaded
                            Library version=2020-04-12
                            ioBroker or some processes are still running:
                             io.admin.0
                             io.admin.1
                             io.discovery.0
                             io.javascript.0
                             io.terminal.0
                             io.scenes.0
                             io.web.0
                             io.fritzdect.0
                             io.text2command.0
                             io.history.0
                             io.backitup.0
                             io.ping.0
                             io.alexa2.0
                             io.mihome.0
                             io.info.0
                             io.broadlink2.0
                             io.radar2.0
                             io.iot.0
                             io.tankerkoenig.0
                             io.bring.0
                             io.fritzbox.0
                             io.shelly.0
                             io.statistics.0
                             io.sourceanalytix.0
                             io.tuya.0
                            Please stop them first and try again!
                              @Henny112
                              Und?
                              iobroker stop
                              und gut ist.
                              Henny112
                              #54
                              @Thomas-Braun Ok dann mache ich noch einmal
                              • H Henny112
                                @Thomas-Braun
                                library: loaded
                                 io.admin.0
                                 io.admin.1
                                 io.discovery.0
                                 io.javascript.0
                                 io.terminal.0
                                 io.scenes.0
                                 io.web.0
                                 io.fritzdect.0
                                 io.text2command.0
                                 io.history.0
                                 io.backitup.0
                                 io.ping.0
                                 io.alexa2.0
                                 io.mihome.0
                                 io.info.0
                                 io.broadlink2.0
                                 io.radar2.0
                                 io.iot.0
                                 io.tankerkoenig.0
                                 io.bring.0
                                 io.fritzbox.0
                                 io.shelly.0
                                 io.statistics.0
                                 io.sourceanalytix.0
                                 io.tuya.0
                                #55
                                @Henny112 Da laufen auch zwei Admin-Instanzen. Soll das so sein?
                                  Henny112
                                  #56
                                  @Thomas-Braun Ja das richtig
                                  • H Henny112
                                    #57
                                    @Henny112
                                    iobroker del telegram
                                    und dann installierst du den nochmal:
                                    iobroker add telegram
                                      @Henny112
                                      Henny112
                                      #58
                                      @Thomas-Braun
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/ch        okidar/node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@        2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}        )
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (n        ode_modules/iobroker.info/node_modules/osx-temperature-sensor):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-tempe        rature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux"        ,"arch":"arm"})
                                      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modu        les/node-bluetooth/package.json'
                                      updated 1 package in 32.141s
                                      library: loaded
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2020-04-12
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/3)
                                      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                      Installed gcc-c++
                                          Checking ioBroker user and directory permissions (2/3)
                                      Created /etc/sudoers.d/iobroker
                                          Checking autostart (3/3)
        Enabling autostart...
                                      Autostart enabled!
                                      • H Henny112
                                        @Thomas-Braun
                                        library: loaded
                                        Installed gcc-c++
                                        Autostart enabled!
                                        #59
                                        @Henny112
                                        In /opt/iobroker
                                        npm i ajv
                                          @Henny112
                                          In /opt/iobroker
                                          npm i ajv
                                          Henny112
                                          #60
                                          /opt/iobroker
                                          Was genau soll ich machen ? Telegramm ist meine ich wieder da
