  4. Telegramm bekomme ich nicht grün (GELÖST)
telegramm
65 Beiträge 3 Kommentatoren 7.3k Aufrufe 1 Beobachtet
  • H Offline
    Henny112
    host.raspberrypi	2020-05-28 22:52:13.994	info	Do not restart adapter system.adapter.telegram.0 because disabled or deleted
    host.raspberrypi	2020-05-28 22:52:13.993	error	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-05-28 22:52:13.993	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: ^
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-05-28 22:52:13.992	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
    host.raspberrypi	2020-05-28 22:52:12.979	info	"system.adapter.telegram.0" disabled
    host.raspberrypi	2020-05-28 22:52:12.714	info	Restart adapter system.adapter.telegram.0 because enabled
    host.raspberrypi	2020-05-28 22:52:12.714	error	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-05-28 22:52:12.714	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-05-28 22:52:12.714	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-05-28 22:52:12.714	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-05-28 22:52:12.714	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: ^
    host.raspberrypi	2020-05-28 22:52:12.713	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-05-28 22:52:12.712	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
    host.raspberrypi	2020-05-28 22:52:12.482	info	instance system.adapter.telegram.0 started with pid 705
    host.raspberrypi	2020-05-28 22:52:11.454	info	Restart adapter system.adapter.telegram.0 because enabled
    H 1 Antwort Letzte Antwort
    • H Henny112
      Henny112
      Das ganze passiert immer wenn Telegramm angeschaltet wird. Dann ist es so. Im Adapter sehe ich seit dem auch keine Benutzer mehr
      • GlasfaserG Glasfaser
        @Henny112
        das fehlt noch wie @Thomas-Braun angefordert hat.
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v
        und dein Log auch bitte einmal neu vollständig in </> CodeTags posten .
        EDIT ... Hat sich erledigt ...
        Henny112
        @Glasfaser Was meisnt du ?
        • H Henny112
          @Henny112
          lsb_release -a
          • H Offline
            Henny112
            @Thomas-Braun sagte in Telegramm bekomme ich nicht grün:
            lsb_release -a
            pi@raspberrypi:~ $ lsb_release -a
            No LSB modules are available.
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            • H Henny112
              GlasfaserG Offline
              GlasfaserG Offline
              @Henny112
              Sorry hatte den Text schon vorgeschrieben ... aber erst später abgeschickt ... kahm was dazwischen
              und hat sich alles Zeitlich überschnitten da du schon auf seine Frage geantwortet hast .
              Vergesse meine Anfrage :)
              • H Henny112
                @Thomas-Braun oh wie war das denn noch ?
                @Henny112
                iobroker  stop
                curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                sudo apt update
                sudo apt dist-upgrade
                sudo reboot
                  @Henny112
                  iobroker  stop
                  sudo apt update
                  sudo reboot
                  Henny112
                  @Thomas-Braun kann ich die so nach und nach eingeben ?
                  Oder muss dabei was beachten? SInd ja 3 Befehle
                  • H Henny112
                    @Henny112
                    Jetzt sind es fünf.
                    Zeilenweise eingeben oder reinkopieren.
                    H 2 Antworten Letzte Antwort
                      @Henny112
                      Jetzt sind es fünf.
                      Henny112
                      @Thomas-Braun mache ich mal eben mal sehen passiert
                      • H Henny112
                        Henny112
                        @Henny112 js controller habe 2.2.9 das ol oder
                          @Henny112
                          Jetzt sind es fünf.
                          Henny112
                          @Thomas-Braun
                          host.raspberrypi	2020-05-28 23:18:44.391	info	instance system.adapter.radar2.0 started with pid 6611
                          host.raspberrypi	2020-05-28 23:18:38.874	info	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi	2020-05-28 23:18:38.874	error	Caught by controller[0]: }
                          host.raspberrypi	2020-05-28 23:18:38.874	error	Caught by controller[0]: ]
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: requireStack: [
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
                          host.raspberrypi	2020-05-28 23:18:38.873	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
                          host.raspberrypi	2020-05-28 23:18:38.872	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: Require stack:
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
                          host.raspberrypi	2020-05-28 23:18:38.871	error	Caught by controller[0]: ^
                          host.raspberrypi	2020-05-28 23:18:38.870	error	Caught by controller[0]: throw err;
                          host.raspberrypi	2020-05-28 23:18:38.870	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
                          host.raspberrypi	2020-05-28 23:18:38.675	info	stopInstance system.adapter.telegram.0 send kill signal
                          host.raspberrypi	2020-05-28 23:18:38.672	info	stopInstance system.adapter.telegram.0 (force=false, process=true)
                          host.raspberrypi	2020-05-28 23:18:38.669	info	"system.adapter.telegram.0" disabled
                          host.raspberrypi	2020-05-28 23:18:38.601	info	instance system.adapter.telegram.0 started with pid 6422
                          host.raspberrypi	2020-05-28 23:18:37.552	info	Restart adapter system.adapter.telegram.0 because enabled
                          host.raspberrypi	2020-05-28 23:18:37.552	error	instance system.adapter.telegram.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: }
                          host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: ]
                          host.raspberrypi	2020-05-28 23:18:37.552	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.telegram/main.js'
                          host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/index.js',
                          host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: '/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js',
                          host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: requireStack: [
                          host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                          host.raspberrypi	2020-05-28 23:18:37.551	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19) {
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:879:14)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js:2:1)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
                          host.raspberrypi	2020-05-28 23:18:37.550	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.telegram/main.js
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/index.js
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: - /opt/iobroker/node_modules/node-telegram-bot-api/src/telegram.js
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: Require stack:
                          host.raspberrypi	2020-05-28 23:18:37.549	error	Caught by controller[0]: Error: Cannot find module 'array.prototype.findindex'
                          host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: ^
                          host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: throw err;
                          host.raspberrypi	2020-05-28 23:18:37.548	error	Caught by controller[0]: internal/modules/cjs/loader.js:969
                          host.raspberrypi	2020-05-28 23:18:37.302	info	instance system.adapter.telegram.0 started with pid 6415
                          host.raspberrypi	2020-05-28 23:18:36.266	info	Restart adapter system.adapter.telegram.0 because enabled
                          • H Henny112
                            @Thomas-Braun
                            @Henny112 sagte in Telegramm bekomme ich nicht grün:
                            cd /opt/iobroker
                            npm i array.prototype.findindex
                            iobroker fix
                              cd /opt/iobroker
                              iobroker fix
                              Henny112
                              @Thomas-Braun
                              unverändert zeigt das selbe an wie vorher +
                              • H Henny112
                                @Thomas-Braun
                                @Henny112 Zeig mal den Konsolenoutput
                                  Henny112
                                  @Thomas-Braun Was für ein ding wie komme ich da hin was du meinst
                                  • H Henny112
                                    @Henny112 Die Rückmeldungen auf die drei Befehle.
                                      Henny112
                                      @Thomas-Braun du meinst das mit node von oben ?
                                        Henny112
                                        @Thomas-Braun
                                        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
                                        /usr/bin/nodejs
                                        v12.17.0
                                        /usr/bin/node
                                        v12.17.0
                                        /usr/bin/npm
                                        6.14.4
                                        pi@raspberrypi:~ $
                                        • H Henny112
                                          @Henny112
                                          cd /opt/iobroker
                                          iobroker fix
                                          Was kommt da zurück? Bitte komplette Ausgaben posten.
