  4. Heizungssteuerung mit Siemens-Webserver OZW 672
    1.0k
    6.1k
26 Beiträge 2 Kommentatoren 5.0k Aufrufe
  • G Offline
    gerry22
    ` > Log
    13:58:33.457 [info] javascript.0 Start javascript script.js.test34
    13:58:33.458 [info] javascript.0 script.js.test34: registered 0 subscriptions and 1 schedule
    13:59:00.463 [info] javascript.0 script.js.test34: http://192.168.178.58/api/auth/login.js … Password_3
    13:59:01.471 [info] javascript.0 script.js.test34: [object Object]
    13:59:01.472 [info] javascript.0 script.js.test34: 6e35b358-92a5-4e38-ba99-636db9829d64
    13:59:01.472 [info] javascript.0 script.js.test34: http://192.168.178.58/api/menutree/read … 64&Id=1143
    13:59:01.525 [info] javascript.0 script.js.test34: [object Object]
    13:59:01.526 [info] javascript.0 script.js.test34: undefined
    13:59:06.980 [info] javascript.0 Stop script script.js.test34 `
    • G Offline
      gerry22
      Ich habe unten mal ein````
      log (results);
      Leider erhalte ich den "valid"-Fehler.
      Log
      14:47:49.788 [info] javascript.0 Stop script script.js.test34
      14:47:50.050 [info] javascript.0 Start javascript script.js.test34
      14:47:50.051 [info] javascript.0 script.js.test34: registered 0 subscriptions and 1 schedule
      14:48:00.173 [info] javascript.0 script.js.test34: http://192.168.178.58/api/auth/login.json?user=Admin3&pwd=Password_3
      14:48:01.068 [info] javascript.0 script.js.test34: [object Object]
      14:48:01.070 [info] javascript.0 script.js.test34: 1c8248fb-ead5-40db-8304-99e536d23193
      14:48:01.070 [info] javascript.0 script.js.test34: http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=1c8248fb-ead5-40db-8304-99e536d23193&Id=1143
      14:48:01.126 [info] javascript.0 script.js.test34: { "Result": { "Success": "false", "Error": { "Txt": "session not valid", "Nr": "2" } } }
      14:48:01.128 [info] javascript.0 script.js.test34: [object Object]
      14:48:01.128 [info] javascript.0 script.js.test34: undefined
      Auf der CCU2 hole ich die SessionId so:````
      var url = "https://192.168.178.58/api/auth/login.json?user=Administrator&pwd=Password.2";
      dom.GetObject("CUxD.CUX2801001:1.CMD_SETS").State("wget -q --no-check-certificate -O - '"#url#"'");
      dom.GetObject("CUxD.CUX2801001:1.CMD_QUERY_RET").State(1);
      string srueck = dom.GetObject("CUxD.CUX2801001:1.CMD_RETS").State();
      ! if ( (srueck.Find("false") == -1) && (srueck) ) {
      string tmpa  = srueck.StrValueByIndex(",",0).StrValueByIndex(":",1);
      string sSID = tmpa.Substr(2, tmpa.Length()-3);
      WriteLine(" SessionID erfolgreich geholt:"#sSID);
      Wenn ich es hier mit ioBroker nicht hinbekomme dann muss ich das Script wohl auf der CCU2 weiter laufen lassen und die SessionId von dort an ioBroker übergeben. Das müsste doch gehen.
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        Es liegt nicht am ioBroker sondern unserer Dummheit ;)
        Ich verstehe nur nicht wo der Fehler liegt die Session ID sieht ok aus, trotzdem schluckt er die nicht
        Send from mobile device
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Probier Mal objekt.Data.Value anstatt Objekt.Value
          • G Offline
            gerry22
            Ich habe bei der zweiten Abfrage die Apostroph durch Anführungszeichen ersetzt.````
            schedule("*/1 * * * *", function () {
            var objekt;
            //Username und password variable setzen
            var username = "Admin3";
            var password = "Password_3";
            var sessionId;
            var value;
            //(TEST)
            log('http://192.168.178.58/api/auth/login.json?user=' + username + '&pwd=' + password);
            //URL request fuer die session ID
            try {
                require("request")
                ('http://192.168.178.58/api/auth/login.json?user=' + username + '&pwd=' + password, function (error, response, results) {
                objekt = JSON.parse(results);
            //(TEST)results ins log schreiben
                log (objekt);
            //Session ID in variable speichern
                sessionId = objekt.SessionId;
            //Session ID ins log schreiben
                log (sessionId);
            //(TEST)URL zur Json-Abfrage der Außentemperatur (Id=1143) erzeugen
                log('http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=' + sessionId + '&Id=1143');
            // URL der Temperatur abfragen und in eine variable schreiben
                require("request")
                ("http://192.168.178.58/api/menutree/read_datapoint.json?SessionId=" + sessionId + "&Id=1143", function (error, response, results){
                   log (results);
                   value = objekt.Data.Value;
                   log(value);
                } catch (e) { console.error(e); }
            ergibt folgendes Log:
              ` > Log
            > 01:14:10.660 [info] javascript.0 Start javascript script.js.test40
            > 01:14:10.661 [info] javascript.0 script.js.test40: registered 0 subscriptions and 1 schedule
            > 01:15:00.661 [info] javascript.0 script.js.test40: [http://192.168.178.58/api/auth/login.js … Password_3](http://192.168.178.58/api/auth/login.json?user=Admin3&pwd=Password_3)
            > 01:15:01.563 [info] javascript.0 script.js.test40: [object Object]
            > 01:15:01.564 [info] javascript.0 script.js.test40: 04b3cec8-5e9b-4792-95c1-85dbfdd7cf0d
            > 01:15:01.565 [info] javascript.0 script.js.test40: [http://192.168.178.58/api/menutree/read … 0d&Id=1143](http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=04b3cec8-5e9b-4792-95c1-85dbfdd7cf0d&Id=1143)
            > 01:15:01.894 [info] javascript.0 script.js.test40: { "Data": { "Type": "Numeric", "Value": " 14.2", "Unit": "°C" }, "Result": { "Success": "true" } }
            > 01:15:01.897 [info] javascript.0 script.js.test40: 14.2
            > 01:15:08.812 [info] javascript.0 Stop script script.js.test40 `
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              Und siehe da im Log steht jetzt auch der Wert 14.2 also geschafft !
              Als nästen Schritt wolltest du das jetzt in ein object schreiben und dan alle x Minuten Update ?
