  4. Javascript Adapter rot (out of memory)
    6.0k
javascript
82 Beiträge 6 Kommentatoren 11.8k Aufrufe 5 Beobachtet
  • M maxpd
    @Thomas-Braun
    Bislang nur Zeile 16 gelöscht und iobroker neu gestartet.
    Fehler ist weiterhin der gleiche.
    host.iobroker	2020-05-08 10:57:34.353	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker	2020-05-08 10:57:34.353	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: ^
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: throw e;
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.iobroker	2020-05-08 10:57:33.963	info	instance system.adapter.zigbee.0 started with pid 7660
    #61
    @maxpd
    Stop den iobroker nochmal.
    Und dann im Verzeichnis /opt/iobroker stehend:
    iobroker rebuild iobroker.zigbee --install
    • M maxpd
      @Thomas-Braun
      #62
      @maxpd Wenn das nicht ausreicht, im gleichen Verzeichnis
      npm rebuild bindings
        @maxpd
        maxpd
        #63
        @Thomas-Braun da waren wir gestern schonmal. Den Befehl gibt es nicht.
        pi@iobroker:/opt/iobroker $ rebuild iobroker.zigbee --install
        -bash: rebuild: Kommando nicht gefunden.
        pi@iobroker:/opt/iobroker $ iobroker rebuild iobroker.zigbee --install
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start
        iobroker stop
        iobroker start <adapter>
        iobroker stop <adapter>
        iobroker start all
        iobroker restart
        iobroker restart <adapter>
        iobroker info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter>
        iobroker url <url> [<name>]
        iobroker del <adapter>
        iobroker del <adapter>.<instance>
        iobroker update [repository url] [--updatable/--u] [--installed/--i]
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url]
        iobroker upgrade <adapter> [repository url]
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all
        iobroker upload <adapter>
        iobroker object get <id>
        iobroker object set <id> <json-value>
        iobroker object set <id> propertyname=value
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id>
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instanceid] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path>
        iobroker validate <backup name or path>
        iobroker <command> --timeout 5000
        iobroker status [all]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status
        iobroker compact <enable|on|disable|off>
        iobroker compact <adapter>.<instance> status
        iobroker compact <adapter>.<instance> group <group-id>
        iobroker compact <adapter>.<instance> <disable|off>
        iobroker compact <adapter>.<instance> <enable|on> [group-id]
        iobroker version [adapter]
        iobroker [adapter] -v
        Options:
          --help     Hilfe anzeigen  [boolean]
          --version  Version anzeigen  [boolean]
        nach dem Binding rebuild habe ich weiterhin den gleichen Fehler.
        maxpd
        Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
        • M maxpd
          Commands:
          iobroker start
          iobroker stop
          iobroker start all
          iobroker restart
          iobroker info
          iobroker upload all
          iobroker rm <file>
          iobroker file sync
          iobroker host this
          iobroker clean
          iobroker backup
          iobroker uuid
          iobroker unsetup
          iobroker fix
          Options:
          #64
          @maxpd
          Dann über npm.
          npm rebuild iobroker.zigbee
            @maxpd
            Dann über npm.
            maxpd
            #65
            @Thomas-Braun
            funktioniert auch nicht.
            pi@iobroker:/opt/iobroker $ npm rebuild iobroker.zigbee
            iobroker.zigbee@1.0.4 /opt/iobroker/node_modules/iobroker.zigbee
            anschließend auch bindings gesetzt. Fehler bleibt gleich 😵
            maxpd
            • M maxpd
              @Thomas-Braun
              #66
              @maxpd Mehr kommt da nicht an Ausgabe?
                maxpd
                #67
                @Thomas-Braun nein, das war alles
                maxpd
                • M maxpd
                  #68
                  @maxpd
                  iobroker list instances
                    @maxpd
                    maxpd
                    #69
                    @Thomas-Braun
                    pi@iobroker:/opt/iobroker $ iobroker list instances
                    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.chromecast.0            : chromecast            - disabled
                    + system.adapter.cloud.0                 : cloud                 -  enabled
                      system.adapter.daswetter.0             : daswetter             -  enabled
                    + system.adapter.denon.0                 : denon                 -  enabled
                    + system.adapter.discovery.0             : discovery             -  enabled
                    + system.adapter.google-sharedlocations.0: google-sharedlocations -  enabled
                      system.adapter.history.0               : history               - disabled
                    + system.adapter.hm-rega.0               : hm-rega               -  enabled
                    + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                    + system.adapter.info.0                  : info                  -  enabled
                      system.adapter.iot.0                   : iot                   - disabled
                    + system.adapter.javascript.0            : javascript            -  enabled
                    + system.adapter.lgtv.0                  : lgtv                  -  enabled
                    + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
                      system.adapter.ping.0                  : ping                  - disabled
                    + system.adapter.sayit.0                 : sayit                 -  enabled, port: 0
                      system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
                    + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.1              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.2              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    + system.adapter.text2command.0          : text2command          -  enabled
                      system.adapter.tr-064.0                : tr-064                - disabled
                    + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wifilight.0             : wifilight             -  enabled
                    + system.adapter.yeelight-2.0            : yeelight-2            -  enabled
                      system.adapter.zigbee.0                : zigbee                -  enabled
                    + instance is alive
                    maxpd
                    • M maxpd
                      @Thomas-Braun
                      + instance is alive
                      #70
                      @maxpd Keine Ahnung...
                      Vielleicht ziehst du das gesamte System auf 'latest' und node12?
                        maxpd
                        #71
                        @Thomas-Braun Versuchen kann ichs. Mit welchen Befehlen?
                        maxpd
                        • M maxpd
                          #72
                          @maxpd
                          iobroker stop
                          iobroker fix
                          iobroker start
                          Dann im Admin beim 'Schraubenschlüssel' - 'Haupteinstellungen' auf 'latest' stellen.
                          iobroker update
                          iobroker upgrade
                          Dann in /opt/iobroker
                          npm rebuild
                          iobroker start
                          Das müsste es gewesen sein...
                          • Thomas BraunT Online
                            #73
                            Vorher vielleicht auch noch node12 installieren:
                            curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                            sudo apt update
                            sudo apt dist-upgrade
                              maxpd
                              schrieb am zuletzt editiert von maxpd
                              #74
                              puuuhhh durchsäht von fehlern
                              pi@iobroker:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_12.x | sud                                                             o -E bash -
                              ## Installing the NodeSource Node.js 12.x repo...
                              ## Populating apt-get cache...
                              + apt-get update
                              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                              Holen:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,                                                             0 MB]
                              OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                              OK:5 https://www.pivccu.de/piVCCU stable InRelease
                              Es wurden 13,0 MB in 1 min 6 s geholt (198 kB/s).
                              ## Confirming "buster" is supported...
                              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Rele                                                             ase'
                              ## Adding the NodeSource signing key to your keyring...
                              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                              OK
                              ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                              + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources                                                             .list.d/nodesource.list
                              + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/so                                                             urces.list.d/nodesource.list
                              ## Running `apt-get update` for you...
                              + apt-get update
                              OK:1 https://deb.nodesource.com/node_12.x buster InRelease
                              OK:2 https://www.pivccu.de/piVCCU stable InRelease
                              OK:3 http://archive.raspberrypi.org/debian buster InRelease
                              OK:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                              ## You may also need development tools to build native addons:
                                   sudo apt-get install gcc g++ make
                              ## To install the Yarn package manager, run:
                                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                                   echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/s                                                             ources.list.d/yarn.list
                                   sudo apt-get update && sudo apt-get install yarn
                              pi@iobroker:/opt/iobroker $ sudo apt update
                              OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                              Fehl:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut werden (2a00:1                                                             098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreichbar) Verbin                                                             dung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (93.93.128.19                                                             3), Zeitüberschreitung aufgetreten
                              Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u                                                             m sie anzuzeigen.
                              W: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/dists/bust                                                             er/InRelease Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut wer                                                             den (2a00:1098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreich                                                             bar) Verbindung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (9                                                             3.93.128.193), Zeitüberschreitung aufgetreten
                              W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignorier                                                             t oder alte an ihrer Stelle benutzt.
                              Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                              pi@iobroker:/opt/iobroker $ apt dist-upgrade
                              E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                              pi@iobroker:/opt/iobroker $ sudo apt dist-upgrade
                              Paketaktualisierung (Upgrade) wird berechnet... Fertig
                              Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                                rpi.gpio-common
                              Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                              Die folgenden Pakete werden aktualisiert (Upgrade):
                                libldap-2.4-2 libldap-common
                              2 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 288 kB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] j
                              Holen:1 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u2 [89,8 kB]
                              Holen:2 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u2 [198 kB]
                              Es wurden 288 kB in 60 s geholt (4.798 B/s).
                              Changelogs werden gelesen... Fertig
                              (Lese Datenbank ... 117901 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../libldap-common_2.4.47+dfsg-3+rpi1+deb10u2_all.deb ...
                              Entpacken von libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                              libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u2_armhf.deb ...
                              Entpacken von libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                              libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                              Trigger für man-db (2.8.5-2) werden verarbeitet ...
                              Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                              pi@iobroker:/opt/iobroker $ iobroker stop
                              pi@iobroker:/opt/iobroker $ iobroker fix
                              library: loaded
                              Library version=2020-04-12
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2020-04-12
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              OK:1 https://www.pivccu.de/piVCCU stable InRelease
                              OK:2 http://archive.raspberrypi.org/debian buster InRelease
                              Installed gcc-c++
                              Installed python-dev
                                  Checking ioBroker user and directory permissions (2/3)
                              Created /etc/sudoers.d/iobroker
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                              pi@iobroker:/opt/iobroker $ iobroker start
                              pi@iobroker:/opt/iobroker $ iobroker update
                              Used repository: latest
                              hash unchanged, use cached sources
                              update done
                              Adapter    "accuweather"   : 1.1.3
                              Adapter    "admin"         : 4.1.1    , installed 4.0.9 [Updateable]
                              Adapter    "alarm"         : 0.3.0
                              Adapter    "alexa2"        : 3.1.2
                              Adapter    "alpha2"        : 1.0.0
                              Adapter    "amazon-dash"   : 1.1.0
                              Adapter    "artnet"        : 1.2.2
                              Adapter    "asterisk"      : 1.0.6
                              Adapter    "asuswrt"       : 1.0.1
                              Adapter    "b-control-em"  : 0.2.1
                              Adapter    "backitup"      : 1.5.6
                              Adapter    "beckhoff"      : 1.2.1
                              Adapter    "benq"          : 0.2.2
                              Adapter    "binance"       : 1.1.2
                              Adapter    "ble"           : 0.11.6
                              Adapter    "blink4home"    : 0.1.1
                              Adapter    "bmw"           : 1.4.0
                              Adapter    "boblight"      : 0.0.1
                              Adapter    "bosesoundtouch": 0.9.2
                              Adapter    "botvac"        : 1.0.0
                              Adapter    "bring"         : 1.7.2
                              Adapter    "broadlink2"    : 2.0.3
                              Adapter    "bsblan"        : 0.0.6
                              Adapter    "bshb"          : 0.1.10
                              Adapter    "calendar"      : 1.2.0
                              Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                              Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                              Adapter    "comfoair"      : 1.1.1
                              Adapter    "contact"       : 1.1.3
                              Adapter    "contactid"     : 1.0.0
                              Adapter    "coronavirus-statistics": 0.5.9
                              Adapter    "corrently"     : 0.0.2
                              Adapter    "countdown"     : 1.1.0
                              Adapter    "cul"           : 1.2.1
                              Adapter    "daikin"        : 1.0.5
                              Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                              Adapter    "deconz"        : 1.3.7
                              Adapter    "denon"         : 1.7.7    , installed 1.7.4 [Updateable]
                              Adapter    "devices"       : 0.3.6
                              Adapter    "digitalstrom"  : 2.0.5
                              Adapter    "discovergy"    : 0.5.4
                              Adapter    "discovery"     : 2.3.5    , installed 2.2.2 [Updateable]
                              Adapter    "doorbird"      : 0.1.5
                              Adapter    "ds18b20"       : 1.1.4
                              Adapter    "dwd"           : 2.4.8
                              Adapter    "ebus"          : 2.0.0
                              Adapter    "ecovacs-deebot": 0.5.8
                              Adapter    "egigeozone"    : 0.1.2
                              Adapter    "ekey"          : 1.1.0
                              Adapter    "email"         : 1.0.6
                              Adapter    "emby"          : 1.0.2
                              Adapter    "energymanager" : 1.2.2
                              Adapter    "enet"          : 1.0.1
                              Adapter    "epson_stylus_px830": 0.2.1
                              Adapter    "exchangerates" : 0.0.12
                              Adapter    "fakeroku"      : 0.2.1
                              Adapter    "fb-checkpresence": 1.0.1
                              Adapter    "feiertage"     : 1.0.19
                              Adapter    "fhem"          : 1.4.1
                              Adapter    "find-my-iphone": 0.2.17
                              Adapter    "firetv"        : 1.0.0
                              Adapter    "fitbit-api"    : 0.1.1
                              Adapter    "flot"          : 1.9.2
                              Adapter    "foobar2000"    : 1.0.0
                              Adapter    "fritzbox"      : 0.2.1
                              Adapter    "fritzdect"     : 0.3.2
                              Adapter    "fronius"       : 1.0.5
                              Adapter    "fullcalendar"  : 1.1.0
                              Adapter    "fullybrowser"  : 1.0.3
                              Adapter    "g-homa"        : 0.5.1
                              Adapter    "geofency"      : 0.3.2
                              Adapter    "gruenbeck"     : 0.0.18
                              Adapter    "habpanel"      : 0.4.1
                              Adapter    "haier"         : 1.0.3
                              Adapter    "ham"           : 1.1.2
                              Adapter    "ham-wemo"      : 1.0.1
                              Adapter    "harmony"       : 1.2.2
                              Adapter    "hass-mqtt"     : 0.0.7
                              Adapter    "heatingcontrol": 0.5.0
                              Adapter    "heytech"       : 0.2.0
                              Adapter    "hid"           : 0.1.17
                              Adapter    "hilink"        : 0.2.7
                              Adapter    "history"       : 1.9.6    , installed 1.8.7 [Updateable]
                              Adapter    "hm-rega"       : 2.6.6    , installed 2.5.5 [Updateable]
                              Adapter    "hm-rpc"        : 1.14.2   , installed 1.12.10 [Updateable]
                              Adapter    "hmip"          : 0.0.11
                              Adapter    "hombot"        : 0.1.3
                              Adapter    "homeconnect"   : 0.0.26
                              Adapter    "homee"         : 1.0.5
                              Adapter    "homepilot"     : 1.1.4
                              Adapter    "hp-ilo"        : 1.0.5
                              Adapter    "hs100"         : 1.1.2
                              Adapter    "hue"           : 3.2.8
                              Adapter    "hue-extended"  : 1.3.2
                              Adapter    "hyperion"      : 0.0.9
                              Adapter    "i2c"           : 0.0.6
                              Adapter    "ical"          : 1.7.0
                              Adapter    "icons-addictive-flavour-png": 0.1.0
                              Adapter    "icons-fatcow-hosting": 0.1.0
                              Adapter    "icons-icons8"  : 0.0.1
                              Adapter    "icons-material-png": 0.1.0
                              Adapter    "icons-material-svg": 0.1.0
                              Adapter    "icons-mfd-png" : 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.2
                              Adapter    "icons-ultimate-png": 1.0.1
                              Adapter    "influxdb"      : 1.8.4
                              Adapter    "info"          : 1.7.2    , installed 1.5.6 [Updateable]
                              Adapter    "innogy-smarthome": 0.3.4
                              Adapter    "intesishome"   : 0.1.2
                              Adapter    "iogo"          : 0.5.10
                              Adapter    "iot"           : 1.4.14   , installed 1.4.14
                              Adapter    "iqontrol"      : 0.3.7
                              Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                              Adapter    "jeelink"       : 0.1.3
                              Controller "js-controller" : 3.0.20   , installed 2.2.9 [Updateable]
                              Adapter    "js2fs"         : 0.1.5
                              Adapter    "kecontact"     : 0.1.0
                              Adapter    "klf200"        : 0.9.5
                              Adapter    "km200"         : 2.0.3
                              Adapter    "knmi-weather"  : 0.2.0
                              Adapter    "knx"           : 1.0.41
                              Adapter    "kodi"          : 2.0.2
                              Adapter    "kress"         : 2.5.5
                              Adapter    "lametric"      : 0.0.7
                              Adapter    "landroid"      : 1.0.3
                              Adapter    "lcn"           : 0.6.3
                              Adapter    "letrika_comgw" : 0.0.5
                              Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                              Adapter    "lgtv-rs"       : 0.1.0
                              Adapter    "lgtv11"        : 1.0.5
                              Adapter    "lifx"          : 0.1.1
                              Adapter    "lightify"      : 0.2.16
                              Adapter    "link"          : 0.5.9
                              Adapter    "linkeddevices" : 1.1.4
                              Adapter    "lovelace"      : 1.0.16
                              Adapter    "loxone"        : 1.0.0
                              Adapter    "luftdaten"     : 0.0.11
                              Adapter    "lupusec"       : 1.2.6
                              Adapter    "luxtronik1"    : 0.2.3
                              Adapter    "material"      : 0.13.8
                              Adapter    "maxcube"       : 0.1.2
                              Adapter    "maxcul"        : 1.1.2
                              Adapter    "mbus"          : 2.2.0
                              Adapter    "mclighting"    : 0.1.1
                              Adapter    "megad"         : 1.2.1
                              Adapter    "megadd"        : 0.2.0
                              Adapter    "megaesp"       : 0.1.0
                              Adapter    "mercedesme"    : 0.0.21
                              Adapter    "mercury"       : 0.1.1
                              Adapter    "meross"        : 1.3.13
                              Adapter    "meteoalarm"    : 1.1.0
                              Adapter    "miele"         : 0.1.5
                              Adapter    "mielecloudservice": 1.2.1
                              Adapter    "mihome"        : 1.3.0
                              Adapter    "mihome-airpurifier": 0.1.7
                              Adapter    "mihome-lamp"   : 1.1.0
                              Adapter    "mihome-plug"   : 0.2.1
                              Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                              Adapter    "miio"          : 0.0.13
                              Adapter    "mikrotik"      : 1.0.12
                              Adapter    "milight"       : 0.3.6
                              Adapter    "milight-smart-light": 0.4.1
                              Adapter    "mobile"        : 0.5.0
                              Adapter    "modbus"        : 3.0.0
                              Adapter    "moma"          : 1.2.6
                              Adapter    "mpd"           : 1.0.5
                              Adapter    "mqtt"          : 2.1.1
                              Adapter    "mqtt-client"   : 1.3.1
                              Adapter    "multicast"     : 0.1.5
                              Adapter    "musiccast"     : 0.1.3
                              Adapter    "mydlink"       : 1.0.9
                              Adapter    "myq"           : 0.1.1
                              Adapter    "mysensors"     : 2.0.0
                              Adapter    "myvbus"        : 0.0.4
                              Adapter    "nanoleaf-lightpanels": 0.8.2
                              Adapter    "nello"         : 2.0.8
                              Adapter    "netatmo"       : 1.3.1
                              Adapter    "nibeuplink"    : 0.3.0
                              Adapter    "nina"          : 0.0.23
                              Adapter    "node-red"      : 1.17.2
                              Adapter    "noolitef"      : 0.0.2
                              Adapter    "nuki"          : 1.2.3
                              Adapter    "nuki-extended" : 2.2.5
                              Adapter    "nut"           : 1.1.3
                              Adapter    "odl"           : 1.0.5
                              Adapter    "oilfox"        : 2.1.0
                              Adapter    "onkyo"         : 2.0.3
                              Adapter    "onvif"         : 0.4.2
                              Adapter    "openhab"       : 1.1.0
                              Adapter    "openligadb"    : 1.1.0
                              Adapter    "opentherm"     : 0.1.9
                              Adapter    "openweathermap": 0.1.0
                              Adapter    "opi"           : 0.1.1
                              Adapter    "oppoplayer"    : 0.2.1
                              Adapter    "owfs"          : 0.6.4
                              Adapter    "owntracks"     : 0.6.2
                              Adapter    "panasonic-viera": 1.0.2
                              Adapter    "parser"        : 1.0.7
                              Adapter    "paw"           : 0.3.2
                              Adapter    "phantomjs"     : 1.0.1
                              Adapter    "pi-hole"       : 1.2.3
                              Adapter    "piface"        : 1.0.0
                              Adapter    "pimatic"       : 0.2.1
                              Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                              Adapter    "places"        : 0.7.0
                              Adapter    "plenticore"    : 2.1.3
                              Adapter    "plex"          : 0.8.11
                              Adapter    "plexconnect"   : 0.0.7
                              Adapter    "pollenflug"    : 1.0.6
                              Adapter    "primelab"      : 1.0.2
                              Adapter    "proxmox"       : 1.0.2
                              Adapter    "proxy"         : 1.2.1
                              Adapter    "pushbullet"    : 0.0.11
                              Adapter    "pushover"      : 2.0.2
                              Adapter    "pushsafer"     : 0.1.8
                              Adapter    "radar2"        : 1.2.5
                              Adapter    "radiohead"     : 1.0.5
                              Adapter    "rainbird"      : 0.2.2
                              Adapter    "rflink"        : 2.1.5
                              Adapter    "rickshaw"      : 1.0.0
                              Adapter    "ring"          : 1.1.2
                              Adapter    "roadtraffic"   : 0.2.0
                              Adapter    "robonect"      : 0.1.3
                              Adapter    "roomba"        : 1.1.1
                              Adapter    "rpi2"          : 1.2.0
                              Adapter    "rssfeed"       : 0.0.28
                              Adapter    "s7"            : 1.1.8
                              Adapter    "samsung"       : 0.2.9
                              Adapter    "sanext"        : 0.0.4
                              Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                              Adapter    "sbfspot"       : 3.0.0
                              Adapter    "scenes"        : 1.1.0
                              Adapter    "schoolfree"    : 0.6.0
                              Adapter    "senec"         : 1.0.8
                              Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                              Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                              Adapter    "sia"           : 1.0.4
                              Adapter    "siegenia"      : 1.0.0
                              Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                              Adapter    "sma-em"        : 0.5.7
                              Adapter    "smappee"       : 0.2.2
                              Adapter    "smartmeter"    : 3.1.2
                              Adapter    "snips"         : 1.5.0
                              Adapter    "snmp"          : 0.5.0
                              Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                              Adapter    "solarlog"      : 2.0.0
                              Adapter    "solarviewdatareader": 0.2.0
                              Adapter    "solarwetter"   : 1.0.0
                              Adapter    "sonnen"        : 1.5.0
                              Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                              Adapter    "sonos"         : 2.0.1
                              Adapter    "sonus"         : 0.1.1
                              Adapter    "sony-bravia"   : 1.0.1
                              Adapter    "sourceanalytix": 0.4.2
                              Adapter    "spotify-premium": 1.0.0
                              Adapter    "sql"           : 1.12.5
                              Adapter    "squeezebox"    : 1.0.0
                              Adapter    "squeezeboxrpc" : 1.0.1
                              Adapter    "starline"      : 1.0.0
                              Adapter    "statistics"    : 0.2.2
                              Adapter    "stiebel-isg"   : 1.4.11
                              Adapter    "stockmarket"   : 0.0.2
                              Adapter    "sunnyportal"   : 0.1.5
                              Adapter    "swiss-weather-api": 0.2.0
                              Adapter    "synology"      : 0.1.7
                              Adapter    "systeminfo"    : 0.3.1
                              Adapter    "tado"          : 0.1.9
                              Adapter    "tahoma"        : 0.3.3
                              Adapter    "tankerkoenig"  : 2.0.9
                              Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                              Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                              Adapter    "tesla-motors"  : 0.2.3
                              Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                              Adapter    "tileboard"     : 0.1.1
                              Adapter    "tinker"        : 1.1.0
                              Adapter    "tino"          : 0.1.3
                              Adapter    "tinyrx4"       : 0.1.5
                              Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                              Adapter    "tradfri"       : 2.6.2
                              Adapter    "trashschedule" : 0.0.5
                              Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                              Adapter    "tuya"          : 3.2.3
                              Adapter    "tvspielfilm"   : 2.0.1
                              Adapter    "unifi"         : 0.4.3
                              Adapter    "unifi-protect" : 0.0.11
                              Adapter    "upnp"          : 1.0.16
                              Adapter    "vaillant"      : 0.0.10
                              Adapter    "valloxmv"      : 1.0.3
                              Adapter    "vcard"         : 0.0.9
                              Adapter    "vedirect"      : 0.1.0
                              Adapter    "velux"         : 0.0.5
                              Adapter    "viessmann"     : 1.2.4
                              Adapter    "viessmannapi"  : 1.3.2
                              Adapter    "virtualpowermeter": 1.2.1
                              Adapter    "vis"           : 1.2.6
                              Adapter    "vis-bars"      : 0.1.4
                              Adapter    "vis-canvas-gauges": 0.1.5
                              Adapter    "vis-colorpicker": 1.2.0
                              Adapter    "vis-fancyswitch": 1.1.0
                              Adapter    "vis-google-fonts": 0.1.0
                              Adapter    "vis-history"   : 1.0.0
                              Adapter    "vis-hqwidgets" : 1.1.4
                              Adapter    "vis-inventwo"  : 1.3.3
                              Adapter    "vis-jqui-mfd"  : 1.0.12
                              Adapter    "vis-justgage"  : 1.0.2
                              Adapter    "vis-keyboard"  : 0.0.2
                              Adapter    "vis-lcars"     : 1.0.4
                              Adapter    "vis-map"       : 1.0.4
                              Adapter    "vis-material"  : 0.1.3
                              Adapter    "vis-material-webfont": 0.0.3
                              Adapter    "vis-materialdesign": 0.3.6
                              Adapter    "vis-metro"     : 1.1.2
                              Adapter    "vis-players"   : 0.1.6
                              Adapter    "vis-plumb"     : 1.0.2
                              Adapter    "vis-rgraph"    : 0.0.2
                              Adapter    "vis-timeandweather": 1.1.7
                              Adapter    "vis-weather"   : 2.5.2
                              Adapter    "vodafone-speedtest": 0.0.4
                              Adapter    "volvo"         : 0.0.2
                              Adapter    "vr200"         : 1.0.0
                              Adapter    "vw-connect"    : 0.0.11
                              Adapter    "weatherunderground": 3.2.1
                              Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                              Adapter    "web-speedy"    : 0.2.0
                              Adapter    "weishaupt-wem" : 0.0.8
                              Adapter    "wiffi-wz"      : 2.2.0
                              Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                              Adapter    "windows-control": 0.1.3
                              Adapter    "wlanthermo-nano": 0.1.1
                              Adapter    "wled"          : 0.5.0
                              Adapter    "wm-bus"        : 0.3.1
                              Adapter    "wolf"          : 1.2.0
                              Adapter    "worx"          : 1.0.2
                              Adapter    "xbox"          : 0.6.3
                              Adapter    "xs1"           : 1.0.2
                              Adapter    "yahka"         : 0.11.0
                              Adapter    "yamaha"        : 0.3.19
                              Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                              Adapter    "youtube"       : 0.0.8
                              Adapter    "yr"            : 2.0.3
                              Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                              Adapter    "zoneminder"    : 0.3.3
                              Adapter    "zont"          : 0.5.4
                              Adapter    "zwave"         : 2.0.1
                              Adapter    "zwave2"        : 0.11.7
                              pi@iobroker:/opt/iobroker $ iobroker upgrade
                              Adapter "accuweather"    is not installed.
                              Update admin from @4.0.9 to @4.1.1
                              host.iobroker Adapter "system.adapter.admin.0" is stopped.
                              NPM version: 6.14.4
                              npm install iobroker.admin@4.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                              Package pixman-1 was not found in the pkg-config search path.
                              Perhaps you should add the directory containing `pixman-1.pc'
                              to the PKG_CONFIG_PATH environment variable
                              No package 'pixman-1' found
                              gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                              gyp ERR! configure error
                              gyp ERR! stack Error: `gyp` failed with exit code: 1
                              gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                              gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                              gyp ERR! System Linux 4.19.97-v7l+
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                              gyp ERR! cwd /opt/iobroker/node_modules/canvas
                              gyp ERR! node -v v12.16.3
                              gyp ERR! node-gyp -v v5.1.0
                              gyp ERR! not ok
                              node-pre-gyp ERR! build error
                              node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                              node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                              node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                              node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                              node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                              node-pre-gyp ERR! System Linux 4.19.97-v7l+
                              node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                              node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                              node-pre-gyp ERR! node -v v12.16.3
                              node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                              node-pre-gyp ERR! not ok
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              Update "system.adapter.admin.0"
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              Adapter "admin" updated
                              host.iobroker Adapter "system.adapter.admin.0" is started
                              Adapter "alarm"          is not installed.
                              Adapter "alexa2"         is not installed.
                              Adapter "alpha2"         is not installed.
                              Adapter "amazon-dash"    is not installed.
                              Adapter "artnet"         is not installed.
                              Adapter "asterisk"       is not installed.
                              Adapter "asuswrt"        is not installed.
                              Adapter "b-control-em"   is not installed.
                              Adapter "backitup"       is not installed.
                              Adapter "beckhoff"       is not installed.
                              Adapter "benq"           is not installed.
                              Adapter "binance"        is not installed.
                              Adapter "ble"            is not installed.
                              Adapter "blink4home"     is not installed.
                              Adapter "bmw"            is not installed.
                              Adapter "boblight"       is not installed.
                              Adapter "bosesoundtouch" is not installed.
                              Adapter "botvac"         is not installed.
                              Adapter "bring"          is not installed.
                              Adapter "broadlink2"     is not installed.
                              Adapter "bsblan"         is not installed.
                              Adapter "bshb"           is not installed.
                              Adapter "calendar"       is not installed.
                              Adapter "chromecast"     is up to date.
                              Adapter "cloud"          is up to date.
                              Adapter "comfoair"       is not installed.
                              Adapter "contact"        is not installed.
                              Adapter "contactid"      is not installed.
                              Adapter "coronavirus-statistics" is not installed.
                              Adapter "corrently"      is not installed.
                              Adapter "countdown"      is not installed.
                              Adapter "cul"            is not installed.
                              Adapter "daikin"         is not installed.
                              Adapter "daswetter"      is up to date.
                              Adapter "deconz"         is not installed.
                              Update denon from @1.7.4 to @1.7.7
                              NPM version: 6.14.4
                              npm install iobroker.denon@1.7.7 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                              Update "system.adapter.denon.0"
                              upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                              upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index.html index.html text/html
                              upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                              Adapter "denon" updated
                              Adapter "devices"        is not installed.
                              Adapter "digitalstrom"   is not installed.
                              Adapter "discovergy"     is not installed.
                              Update discovery from @2.2.2 to @2.3.5
                              NPM version: 6.14.4
                              npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
                              In file included from ../src/./serialport.h:6,
                                               from ../src/serialport.cpp:1:
                              ../../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                              ../../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                              ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                 uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                              ../src/serialport.cpp: At global scope:
                              ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                               SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                              ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                               SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                              In file included from ../../../../../nan/nan.h:54,
                              /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                     (node::addon_register_func) (regfunc),                          \
                              /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
                                 NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                              ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                               NODE_MODULE(serialport, init);
                              In file included from ../src/serialport.h:6,
                                               from ../src/serialport_unix.cpp:2:
                              ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                              ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                   snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                              ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                              ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                              ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                   snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                              ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                              In file included from ../src/poller.cpp:1:
                              gyp ERR! not ok
                              upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                              Update "system.adapter.discovery.0"
                              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                              Adapter "discovery" updated
                              Adapter "doorbird"       is not installed.
                              Adapter "ds18b20"        is not installed.
                              Adapter "dwd"            is not installed.
                              Adapter "ebus"           is not installed.
                              Adapter "ecovacs-deebot" is not installed.
                              Adapter "egigeozone"     is not installed.
                              Adapter "ekey"           is not installed.
                              Adapter "email"          is not installed.
                              Adapter "emby"           is not installed.
                              Adapter "energymanager"  is not installed.
                              Adapter "enet"           is not installed.
                              Adapter "epson_stylus_px830" is not installed.
                              Adapter "exchangerates"  is not installed.
                              Adapter "fakeroku"       is not installed.
                              Adapter "fb-checkpresence" is not installed.
                              Adapter "feiertage"      is not installed.
                              Adapter "fhem"           is not installed.
                              Adapter "find-my-iphone" is not installed.
                              Adapter "firetv"         is not installed.
                              Adapter "fitbit-api"     is not installed.
                              Adapter "flot"           is not installed.
                              Adapter "foobar2000"     is not installed.
                              Adapter "fritzbox"       is not installed.
                              Adapter "fritzdect"      is not installed.
                              Adapter "fronius"        is not installed.
                              Adapter "fullcalendar"   is not installed.
                              Adapter "fullybrowser"   is not installed.
                              Adapter "g-homa"         is not installed.
                              Adapter "geofency"       is not installed.
                              Adapter "gruenbeck"      is not installed.
                              Adapter "habpanel"       is not installed.
                              Adapter "haier"          is not installed.
                              Adapter "ham"            is not installed.
                              Adapter "ham-wemo"       is not installed.
                              Adapter "harmony"        is not installed.
                              Adapter "hass-mqtt"      is not installed.
                              Adapter "heatingcontrol" is not installed.
                              Adapter "heytech"        is not installed.
                              Adapter "hid"            is not installed.
                              Adapter "hilink"         is not installed.
                              Update history from @1.8.7 to @1.9.6
                              NPM version: 6.14.4
                              npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/wordsCustom.js wordsCustom.js application/javascript
                              upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                              Update "system.adapter.history.0"
                              upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                              upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                              upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                              upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                              upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                              Adapter "history" updated
                              Update hm-rega from @2.5.5 to @2.6.6
                              NPM version: 6.14.4
                              npm install iobroker.hm-rega@2.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                              Update "system.adapter.hm-rega.0"
                              upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                              upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                              upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                              Adapter "hm-rega" updated
                              Update hm-rpc from @1.12.10 to @1.14.2
                              NPM version: 6.14.4
                              npm install iobroker.hm-rpc@1.14.2 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              Update "system.adapter.hm-rpc.0"
                              upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/96_hm-tc-it-wm-w-eu_thumb.png icons/96_hm-tc-it-wm-w-eu_thumb.png image/png
                              upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/49_hm-sec-wds_thumb.png icons/49_hm-sec-wds_thumb.png image/png
                              upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                              upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                              upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                              upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                              upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                              upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                              upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                              upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                              upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                              upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                              upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                              upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                              upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                              upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                              upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                              upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                              upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                              upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                              upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                              upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                              upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                              upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                              upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                              upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                              upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                              upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                              upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                              upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                              upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                              Adapter "hm-rpc" updated
                              Adapter "hmip"           is not installed.
                              Adapter "hombot"         is not installed.
                              Adapter "homeconnect"    is not installed.
                              Adapter "homee"          is not installed.
                              Adapter "homepilot"      is not installed.
                              Adapter "hp-ilo"         is not installed.
                              Adapter "hs100"          is not installed.
                              Adapter "hue"            is not installed.
                              Adapter "hue-extended"   is not installed.
                              Adapter "hyperion"       is not installed.
                              Adapter "i2c"            is not installed.
                              Adapter "ical"           is not installed.
                              Adapter "icons-addictive-flavour-png" is not installed.
                              Adapter "icons-fatcow-hosting" is not installed.
                              Adapter "icons-icons8"   is not installed.
                              Adapter "icons-material-png" is not installed.
                              Adapter "icons-material-svg" is not installed.
                              Adapter "icons-mfd-png"  is not installed.
                              Adapter "icons-mfd-svg"  is not installed.
                              Adapter "icons-open-icon-library-png" is not installed.
                              Adapter "icons-ultimate-png" is not installed.
                              Adapter "influxdb"       is not installed.
                              Update info from @1.5.6 to @1.7.2
                              NPM version: 6.14.4
                              npm install iobroker.info@1.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                              Update "system.adapter.info.0"
                              upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                              upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                              upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                              upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                              upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                              upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                              upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                              upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                              upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                              upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                              upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                              upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                              upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                              upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                              upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                              upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                              upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                              upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                              upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                              upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                              upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                              upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                              upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                              upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                              upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                              upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                              Adapter "info" updated
                              Adapter "innogy-smarthome" is not installed.
                              Adapter "intesishome"    is not installed.
                              Adapter "iogo"           is not installed.
                              Adapter "iot"            is up to date.
                              Adapter "iqontrol"       is not installed.
                              Adapter "javascript"     is up to date.
                              Adapter "jeelink"        is not installed.
                              Adapter "js2fs"          is not installed.
                              Adapter "kecontact"      is not installed.
                              Adapter "klf200"         is not installed.
                              Adapter "km200"          is not installed.
                              Adapter "knmi-weather"   is not installed.
                              Adapter "knx"            is not installed.
                              Adapter "kodi"           is not installed.
                              Adapter "kress"          is not installed.
                              Adapter "lametric"       is not installed.
                              Adapter "landroid"       is not installed.
                              Adapter "lcn"            is not installed.
                              Adapter "letrika_comgw"  is not installed.
                              Adapter "lgtv"           is up to date.
                              Adapter "lgtv-rs"        is not installed.
                              Adapter "lgtv11"         is not installed.
                              Adapter "lifx"           is not installed.
                              Adapter "lightify"       is not installed.
                              Adapter "link"           is not installed.
                              Adapter "linkeddevices"  is not installed.
                              Adapter "lovelace"       is not installed.
                              Adapter "loxone"         is not installed.
                              Adapter "luftdaten"      is not installed.
                              Adapter "lupusec"        is not installed.
                              Adapter "luxtronik1"     is not installed.
                              Adapter "material"       is not installed.
                              Adapter "maxcube"        is not installed.
                              Adapter "maxcul"         is not installed.
                              Adapter "mbus"           is not installed.
                              Adapter "mclighting"     is not installed.
                              Adapter "megad"          is not installed.
                              Adapter "megadd"         is not installed.
                              Adapter "megaesp"        is not installed.
                              Adapter "mercedesme"     is not installed.
                              Adapter "mercury"        is not installed.
                              Adapter "meross"         is not installed.
                              Adapter "meteoalarm"     is not installed.
                              Adapter "miele"          is not installed.
                              Adapter "mielecloudservice" is not installed.
                              Adapter "mihome"         is not installed.
                              Adapter "mihome-airpurifier" is not installed.
                              Adapter "mihome-lamp"    is not installed.
                              Adapter "mihome-plug"    is not installed.
                              Update mihome-vacuum from @1.1.5 to @2.0.7
                              NPM version: 6.14.4
                              npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the canvas@2.6.1 install script.
                              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                              npm ERR!     /home/iobroker/.npm/_logs/2020-05-08T10_19_53_090Z-debug.log
                              host.iobroker Cannot install iobroker.mihome-vacuum@2.0.7: 1
                              pi@iobroker:/opt/iobroker $ iobroker upgrade self
                              Controller is running. Please stop ioBroker first.
                              ^[[A^[[Api@iobroker:/opt/iobroker $ iobroker upgrade self
                              Update js-controller from @2.2.9 to @3.0.20
                              NPM version: 6.14.4
                              npm install iobroker.js-controller@3.0.20 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                              gyp ERR! not ok
                              Starting node restart.js
                              > protobufjs@6.8.9 postinstall /opt/iobroker/node_modules/protobufjs
                              > node scripts/postinstall
                              > serialport@8.0.8 postinstall /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                              > node thank-you.js
                              Thank you for using serialport!
                              If you rely on this package, please consider supporting our open collective:
                              > https://opencollective.com/serialport/donate
                              > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                              > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                              prebuild-install WARN install No prebuilt binaries found (target=12.16.3 runtime=node arch=arm libc= platform=linux)
                              gyp ERR! clean error
                              gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                              gyp ERR! not ok
                              npm ERR! errno 1
                              npm ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                              npm ERR!
                              npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
                              npm ERR!     /home/pi/.npm/_logs/2020-05-08T10_25_49_001Z-debug.log
                              Fehler bleibt bestehen.
                              Eine Idee wäre noch ein Downgrade von Node.js zurück auf die 10er zu machen und schauen ob es wirklich nur die Schleife im Blockly war, die den JS Adapter zum Absturz brachte.
                              maxpd
                              • M maxpd
                                + apt-get update
                                OK
                                + apt-get update
                                  rpi.gpio-common
                                library: loaded
                                Installed gcc-c++
                                Autostart enabled!
                                update done
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                NPM version: 6.14.4
                                gyp ERR! not ok
                                > node thank-you.js
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                #75
                                @maxpd
                                sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                                Und dann nochmal versuchen.
                                  @maxpd
                                  maxpd
                                  #76
                                  @Thomas-Braun said in Javascript Adapter rot (out of memory):
                                  nochmal alles komplett versuchen?
                                  vorher auf default zurückswitchen?
                                  maxpd
                                  • M maxpd
                                    #77
                                    @maxpd Bleib mal auf 'latest'
                                    Die Pakete von gerade eben einspielen und dann nochmal
                                    iobroker update
                                    iobroker upgrade
                                    npm rebuild
                                      iobroker update
                                      iobroker upgrade
                                      npm rebuild
                                      maxpd
                                      #78
                                      @Thomas-Braun hat jetzt schon wesentlich länger gedauert. Würde auch sagen sieht gut aus, mit Ausnahme npm rebuild.
                                      update done
                                      Adapter    "admin"         : 4.1.1    , installed 4.1.1
                                      Adapter    "denon"         : 1.7.7    , installed 1.7.7
                                      Adapter    "discovery"     : 2.3.5    , installed 2.3.5
                                      Adapter    "history"       : 1.9.6    , installed 1.9.6
                                      Adapter    "hm-rega"       : 2.6.6    , installed 2.6.6
                                      Adapter    "hm-rpc"        : 1.14.2   , installed 1.14.2
                                      Adapter    "info"          : 1.7.2    , installed 1.7.2
                                      Controller "js-controller" : 3.0.20   , installed 3.0.20
                                      Adapter "admin"          is up to date.
                                      Adapter "denon"          is up to date.
                                      Adapter "discovery"      is up to date.
                                      Adapter "history"        is up to date.
                                      Adapter "hm-rega"        is up to date.
                                      Adapter "hm-rpc"         is up to date.
                                      Adapter "info"           is up to date.
                                      NPM version: 6.14.4
                                      In file included from ../src/backend/Backend.h:6,
                                                       from ../src/backend/Backend.cc:1:
                                                       from ../src/backend/ImageBackend.h:3,
                                                       from ../src/backend/ImageBackend.cc:1:
                                                       from ../src/backend/PdfBackend.h:3,
                                                       from ../src/backend/PdfBackend.cc:1:
                                                       from ../src/backend/SvgBackend.h:3,
                                                       from ../src/backend/SvgBackend.cc:1:
                                      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                                      ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                                         E(ptr - data > imgdOffset, "image data overlaps with another structure");
                                      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                       #define E(cond, msg) if(cond) return setErr(msg)
                                      ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                                         E(ptr - data + imgdSize > len, "not enough image data");
                                                       from ../src/Backends.h:3,
                                                       from ../src/Backends.cc:1:
                                                       from ../src/Canvas.h:5,
                                                       from ../src/Canvas.cc:3:
                                      ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                                      ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
                                           if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                      ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                           uv_queue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                      ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                           uv_queue_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                      In file included from ../src/CanvasGradient.h:5,
                                                       from ../src/CanvasGradient.cc:3:
                                      In file included from ../src/CanvasPattern.h:6,
                                                       from ../src/CanvasPattern.cc:3:
                                                       from ../src/CanvasRenderingContext2d.h:6,
                                                       from ../src/CanvasRenderingContext2d.cc:3:
                                                       from ../src/closure.h:5,
                                                       from ../src/closure.cc:1:
                                      In file included from ../src/Image.h:8,
                                                       from ../src/Image.cc:3:
                                      In file included from ../src/ImageData.h:5,
                                                       from ../src/ImageData.cc:3:
                                                       from ../src/init.cc:17:
                                      In file included from ../../nan/nan.h:54,
                                      ../src/init.cc: At global scope:
                                      ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
                                       NODE_MODULE(canvas, init);
                                      upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                      Update "system.adapter.mihome-vacuum.0"
                                      upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                                      upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                                      upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                                      upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                                      upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                                      upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                                      upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                                      upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                      upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                      upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                      upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                      Adapter "mihome-vacuum" updated
                                      Adapter "miio"           is not installed.
                                      Adapter "mikrotik"       is not installed.
                                      Adapter "milight"        is not installed.
                                      Adapter "milight-smart-light" is not installed.
                                      Adapter "mobile"         is not installed.
                                      Adapter "modbus"         is not installed.
                                      Adapter "moma"           is not installed.
                                      Adapter "mpd"            is not installed.
                                      Adapter "mqtt"           is not installed.
                                      Adapter "mqtt-client"    is not installed.
                                      Adapter "multicast"      is not installed.
                                      Adapter "musiccast"      is not installed.
                                      Adapter "mydlink"        is not installed.
                                      Adapter "myq"            is not installed.
                                      Adapter "mysensors"      is not installed.
                                      Adapter "myvbus"         is not installed.
                                      Adapter "nanoleaf-lightpanels" is not installed.
                                      Adapter "nello"          is not installed.
                                      Adapter "netatmo"        is not installed.
                                      Adapter "nibeuplink"     is not installed.
                                      Adapter "nina"           is not installed.
                                      Adapter "node-red"       is not installed.
                                      Adapter "noolitef"       is not installed.
                                      Adapter "nuki"           is not installed.
                                      Adapter "nuki-extended"  is not installed.
                                      Adapter "nut"            is not installed.
                                      Adapter "odl"            is not installed.
                                      Adapter "oilfox"         is not installed.
                                      Adapter "onkyo"          is not installed.
                                      Adapter "onvif"          is not installed.
                                      Adapter "openhab"        is not installed.
                                      Adapter "openligadb"     is not installed.
                                      Adapter "opentherm"      is not installed.
                                      Adapter "openweathermap" is not installed.
                                      Adapter "opi"            is not installed.
                                      Adapter "oppoplayer"     is not installed.
                                      Adapter "owfs"           is not installed.
                                      Adapter "owntracks"      is not installed.
                                      Adapter "panasonic-viera" is not installed.
                                      Adapter "parser"         is not installed.
                                      Adapter "paw"            is not installed.
                                      Adapter "phantomjs"      is not installed.
                                      Adapter "pi-hole"        is not installed.
                                      Adapter "piface"         is not installed.
                                      Adapter "pimatic"        is not installed.
                                      Update ping from @1.3.2 to @1.4.7
                                      NPM version: 6.14.4
                                      npm install iobroker.ping@1.4.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                      Update "system.adapter.ping.0"
                                      upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                      upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html
                                      upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
                                      Adapter "ping" updated
                                      Adapter "places"         is not installed.
                                      Adapter "plenticore"     is not installed.
                                      Adapter "plex"           is not installed.
                                      Adapter "plexconnect"    is not installed.
                                      Adapter "pollenflug"     is not installed.
                                      Adapter "primelab"       is not installed.
                                      Adapter "proxmox"        is not installed.
                                      Adapter "proxy"          is not installed.
                                      Adapter "pushbullet"     is not installed.
                                      Adapter "pushover"       is not installed.
                                      Adapter "pushsafer"      is not installed.
                                      Adapter "radar2"         is not installed.
                                      Adapter "radiohead"      is not installed.
                                      Adapter "rainbird"       is not installed.
                                      Adapter "rflink"         is not installed.
                                      Adapter "rickshaw"       is not installed.
                                      Adapter "ring"           is not installed.
                                      Adapter "roadtraffic"    is not installed.
                                      Adapter "robonect"       is not installed.
                                      Adapter "roomba"         is not installed.
                                      Adapter "rpi2"           is not installed.
                                      Adapter "rssfeed"        is not installed.
                                      Adapter "s7"             is not installed.
                                      Adapter "samsung"        is not installed.
                                      Adapter "sanext"         is not installed.
                                      Adapter "sayit"          is up to date.
                                      Adapter "sbfspot"        is not installed.
                                      Adapter "scenes"         is not installed.
                                      Adapter "schoolfree"     is not installed.
                                      Adapter "senec"          is not installed.
                                      Update shelly from @3.1.6 to @3.2.7
                                      NPM version: 6.14.4
                                      npm install iobroker.shelly@3.2.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                                      Update "system.adapter.shelly.0"
                                      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                                      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                                      Adapter "shelly" updated
                                      Update shuttercontrol from @0.4.3 to @0.5.0
                                      host.iobroker Adapter "system.adapter.shuttercontrol.0" is stopped.
                                      NPM version: 6.14.4
                                      npm install iobroker.shuttercontrol@0.5.0 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                      Update "system.adapter.shuttercontrol.0"
                                      upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                      upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                      upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                      Adapter "shuttercontrol" updated
                                      host.iobroker Adapter "system.adapter.shuttercontrol.0" is started
                                      Adapter "sia"            is not installed.
                                      Adapter "siegenia"       is not installed.
                                      Adapter "simple-api"     is up to date.
                                      Adapter "sma-em"         is not installed.
                                      Adapter "smappee"        is not installed.
                                      Adapter "smartmeter"     is not installed.
                                      Adapter "snips"          is not installed.
                                      Adapter "snmp"           is not installed.
                                      Update socketio from @3.0.6 to @3.0.7
                                      NPM version: 6.14.4
                                      npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                                      upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                                      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                                      Adapter "socketio" updated
                                      Adapter "solarlog"       is not installed.
                                      Adapter "solarviewdatareader" is not installed.
                                      Adapter "solarwetter"    is not installed.
                                      Adapter "sonnen"         is not installed.
                                      Adapter "sonoff"         is up to date.
                                      Adapter "sonos"          is not installed.
                                      Adapter "sonus"          is not installed.
                                      Adapter "sony-bravia"    is not installed.
                                      Adapter "sourceanalytix" is not installed.
                                      Adapter "spotify-premium" is not installed.
                                      Adapter "sql"            is not installed.
                                      Adapter "squeezebox"     is not installed.
                                      Adapter "squeezeboxrpc"  is not installed.
                                      Adapter "starline"       is not installed.
                                      Adapter "statistics"     is not installed.
                                      Adapter "stiebel-isg"    is not installed.
                                      Adapter "stockmarket"    is not installed.
                                      Adapter "sunnyportal"    is not installed.
                                      Adapter "swiss-weather-api" is not installed.
                                      Adapter "synology"       is not installed.
                                      Adapter "systeminfo"     is not installed.
                                      Adapter "tado"           is not installed.
                                      Adapter "tahoma"         is not installed.
                                      Adapter "tankerkoenig"   is not installed.
                                      Update telegram from @1.4.3 to @1.5.9
                                      host.iobroker Adapter "system.adapter.telegram.1" is stopped.
                                      host.iobroker Adapter "system.adapter.telegram.2" is stopped.
                                      NPM version: 6.14.4
                                      npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                      Update "system.adapter.telegram.0"
                                      Update "system.adapter.telegram.1"
                                      Update "system.adapter.telegram.2"
                                      upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                      upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                                      upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                                      upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                                      upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                      Adapter "telegram" updated
                                      host.iobroker Adapter "system.adapter.telegram.1" is started
                                      host.iobroker Adapter "system.adapter.telegram.2" is started
                                      Adapter "terminal"       is up to date.
                                      Adapter "tesla-motors"   is not installed.
                                      Adapter "text2command"   is up to date.
                                      Adapter "tileboard"      is not installed.
                                      Adapter "tinker"         is not installed.
                                      Adapter "tino"           is not installed.
                                      Adapter "tinyrx4"        is not installed.
                                      Update tr-064 from @0.4.18 to @4.0.1
                                      NPM version: 6.14.4
                                      npm install iobroker.tr-064@4.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                      Update "system.adapter.tr-064.0"
                                      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                      Adapter "tr-064" updated
                                      Adapter "tradfri"        is not installed.
                                      Adapter "trashschedule"  is not installed.
                                      Adapter "tunnelbroker-endpoint-updater" is not installed.
                                      Adapter "tuya"           is not installed.
                                      Adapter "tvspielfilm"    is not installed.
                                      Adapter "unifi"          is not installed.
                                      Adapter "unifi-protect"  is not installed.
                                      Adapter "upnp"           is not installed.
                                      Adapter "vaillant"       is not installed.
                                      Adapter "valloxmv"       is not installed.
                                      Adapter "vcard"          is not installed.
                                      Adapter "vedirect"       is not installed.
                                      Adapter "velux"          is not installed.
                                      Adapter "viessmann"      is not installed.
                                      Adapter "viessmannapi"   is not installed.
                                      Adapter "virtualpowermeter" is not installed.
                                      Adapter "vis"            is not installed.
                                      Adapter "vis-bars"       is not installed.
                                      Adapter "vis-canvas-gauges" is not installed.
                                      Adapter "vis-colorpicker" is not installed.
                                      Adapter "vis-fancyswitch" is not installed.
                                      Adapter "vis-google-fonts" is not installed.
                                      Adapter "vis-history"    is not installed.
                                      Adapter "vis-hqwidgets"  is not installed.
                                      Adapter "vis-inventwo"   is not installed.
                                      Adapter "vis-jqui-mfd"   is not installed.
                                      Adapter "vis-justgage"   is not installed.
                                      Adapter "vis-keyboard"   is not installed.
                                      Adapter "vis-lcars"      is not installed.
                                      Adapter "vis-map"        is not installed.
                                      Adapter "vis-material"   is not installed.
                                      Adapter "vis-material-webfont" is not installed.
                                      Adapter "vis-materialdesign" is not installed.
                                      Adapter "vis-metro"      is not installed.
                                      Adapter "vis-players"    is not installed.
                                      Adapter "vis-plumb"      is not installed.
                                      Adapter "vis-rgraph"     is not installed.
                                      Adapter "vis-timeandweather" is not installed.
                                      Adapter "vis-weather"    is not installed.
                                      Adapter "vodafone-speedtest" is not installed.
                                      Adapter "volvo"          is not installed.
                                      Adapter "vr200"          is not installed.
                                      Adapter "vw-connect"     is not installed.
                                      Adapter "weatherunderground" is not installed.
                                      Update web from @3.0.7 to @3.0.8
                                      host.iobroker Adapter "system.adapter.web.0" is stopped.
                                      NPM version: 6.14.4
                                      npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                                      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                                      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                                      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                                      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                                      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                                      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                                      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                                      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                                      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                                      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                                      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                                      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                                      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                                      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                                      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                                      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                                      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                                      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                                      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                      Update "system.adapter.web.0"
                                      Adapter "web" updated
                                      host.iobroker Adapter "system.adapter.web.0" is started
                                      Adapter "web-speedy"     is not installed.
                                      Adapter "weishaupt-wem"  is not installed.
                                      Adapter "wiffi-wz"       is not installed.
                                      Adapter "wifilight"      is up to date.
                                      Adapter "windows-control" is not installed.
                                      Adapter "wlanthermo-nano" is not installed.
                                      Adapter "wled"           is not installed.
                                      Adapter "wm-bus"         is not installed.
                                      Adapter "wolf"           is not installed.
                                      Adapter "worx"           is not installed.
                                      Adapter "xbox"           is not installed.
                                      Adapter "xs1"            is not installed.
                                      Adapter "yahka"          is not installed.
                                      Adapter "yamaha"         is not installed.
                                      Adapter "yeelight-2"     is up to date.
                                      Adapter "youtube"        is not installed.
                                      Adapter "yr"             is not installed.
                                      Update zigbee from @1.0.4 to @1.1.1
                                      host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
                                      NPM version: 6.14.4
                                      npm install iobroker.zigbee@1.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                      Update "system.adapter.zigbee.0"
                                      upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
                                      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                                      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/jiawen.png img/jiawen.png image/png
                                      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/iluminize_511_040.png img/iluminize_511_040.png image/png
                                      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
                                      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
                                      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
                                      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_MS01.png img/ewelink_MS01.png image/png
                                      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                                      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                                      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                                      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
                                      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                                      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
                                      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0218.png img/TS0218.png image/png
                                      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0215.png img/TS0215.png image/png
                                      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTW017.png img/LTW017.png image/png
                                      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC015.png img/LTC015.png image/png
                                      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC014.png img/LTC014.png image/png
                                      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
                                      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                                      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                                      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                                      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                      Adapter "zigbee" updated
                                      host.iobroker Adapter "system.adapter.zigbee.0" is started
                                      Adapter "zoneminder"     is not installed.
                                      Adapter "zont"           is not installed.
                                      Adapter "zwave"          is not installed.
                                      Adapter "zwave2"         is not installed.
                                      Host    "iobroker"       is up to date.
                                      pi@iobroker:/opt/iobroker $ npm rebuild
                                      > node thank-you.js
                                      gyp ERR! not ok
                                      npm ERR! errno 1
                                      npm ERR!
                                      npm ERR!     /home/pi/.npm/_logs/2020-05-08T11_11_28_882Z-debug.log
                                      maxpd
                                      Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
                                      • M maxpd
                                        pi@iobroker:/opt/iobroker $ iobroker update
                                        Used repository: latest
                                        hash unchanged, use cached sources
                                        update done
                                        Adapter    "accuweather"   : 1.1.3
                                        Adapter    "alarm"         : 0.3.0
                                        Adapter    "alexa2"        : 3.1.2
                                        Adapter    "alpha2"        : 1.0.0
                                        Adapter    "amazon-dash"   : 1.1.0
                                        Adapter    "artnet"        : 1.2.2
                                        Adapter    "asterisk"      : 1.0.6
                                        Adapter    "asuswrt"       : 1.0.1
                                        Adapter    "b-control-em"  : 0.2.1
                                        Adapter    "backitup"      : 1.5.6
                                        Adapter    "beckhoff"      : 1.2.1
                                        Adapter    "benq"          : 0.2.2
                                        Adapter    "binance"       : 1.1.2
                                        Adapter    "ble"           : 0.11.6
                                        Adapter    "blink4home"    : 0.1.1
                                        Adapter    "bmw"           : 1.4.0
                                        Adapter    "boblight"      : 0.0.1
                                        Adapter    "bosesoundtouch": 0.9.2
                                        Adapter    "botvac"        : 1.0.0
                                        Adapter    "bring"         : 1.7.2
                                        Adapter    "broadlink2"    : 2.0.3
                                        Adapter    "bsblan"        : 0.0.6
                                        Adapter    "bshb"          : 0.1.10
                                        Adapter    "calendar"      : 1.2.0
                                        Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                                        Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                                        Adapter    "comfoair"      : 1.1.1
                                        Adapter    "contact"       : 1.1.3
                                        Adapter    "contactid"     : 1.0.0
                                        Adapter    "coronavirus-statistics": 0.5.9
                                        Adapter    "corrently"     : 0.0.2
                                        Adapter    "countdown"     : 1.1.0
                                        Adapter    "cul"           : 1.2.1
                                        Adapter    "daikin"        : 1.0.5
                                        Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                                        Adapter    "deconz"        : 1.3.7
                                        Adapter    "devices"       : 0.3.6
                                        Adapter    "digitalstrom"  : 2.0.5
                                        Adapter    "discovergy"    : 0.5.4
                                        Adapter    "doorbird"      : 0.1.5
                                        Adapter    "ds18b20"       : 1.1.4
                                        Adapter    "dwd"           : 2.4.8
                                        Adapter    "ebus"          : 2.0.0
                                        Adapter    "ecovacs-deebot": 0.5.8
                                        Adapter    "egigeozone"    : 0.1.2
                                        Adapter    "ekey"          : 1.1.0
                                        Adapter    "email"         : 1.0.6
                                        Adapter    "emby"          : 1.0.2
                                        Adapter    "energymanager" : 1.2.2
                                        Adapter    "enet"          : 1.0.1
                                        Adapter    "epson_stylus_px830": 0.2.1
                                        Adapter    "exchangerates" : 0.0.12
                                        Adapter    "fakeroku"      : 0.2.1
                                        Adapter    "fb-checkpresence": 1.0.1
                                        Adapter    "feiertage"     : 1.0.19
                                        Adapter    "fhem"          : 1.4.1
                                        Adapter    "find-my-iphone": 0.2.17
                                        Adapter    "firetv"        : 1.0.0
                                        Adapter    "fitbit-api"    : 0.1.1
                                        Adapter    "flot"          : 1.9.2
                                        Adapter    "foobar2000"    : 1.0.0
                                        Adapter    "fritzbox"      : 0.2.1
                                        Adapter    "fritzdect"     : 0.3.2
                                        Adapter    "fronius"       : 1.0.5
                                        Adapter    "fullcalendar"  : 1.1.0
                                        Adapter    "fullybrowser"  : 1.0.3
                                        Adapter    "g-homa"        : 0.5.1
                                        Adapter    "geofency"      : 0.3.2
                                        Adapter    "gruenbeck"     : 0.0.18
                                        Adapter    "habpanel"      : 0.4.1
                                        Adapter    "haier"         : 1.0.3
                                        Adapter    "ham"           : 1.1.2
                                        Adapter    "ham-wemo"      : 1.0.1
                                        Adapter    "harmony"       : 1.2.2
                                        Adapter    "hass-mqtt"     : 0.0.7
                                        Adapter    "heatingcontrol": 0.5.0
                                        Adapter    "heytech"       : 0.2.0
                                        Adapter    "hid"           : 0.1.17
                                        Adapter    "hilink"        : 0.2.7
                                        Adapter    "hmip"          : 0.0.11
                                        Adapter    "hombot"        : 0.1.3
                                        Adapter    "homeconnect"   : 0.0.26
                                        Adapter    "homee"         : 1.0.5
                                        Adapter    "homepilot"     : 1.1.4
                                        Adapter    "hp-ilo"        : 1.0.5
                                        Adapter    "hs100"         : 1.1.2
                                        Adapter    "hue"           : 3.2.8
                                        Adapter    "hue-extended"  : 1.3.2
                                        Adapter    "hyperion"      : 0.0.9
                                        Adapter    "i2c"           : 0.0.6
                                        Adapter    "ical"          : 1.7.0
                                        Adapter    "icons-addictive-flavour-png": 0.1.0
                                        Adapter    "icons-fatcow-hosting": 0.1.0
                                        Adapter    "icons-icons8"  : 0.0.1
                                        Adapter    "icons-material-png": 0.1.0
                                        Adapter    "icons-material-svg": 0.1.0
                                        Adapter    "icons-mfd-png" : 1.0.2
                                        Adapter    "icons-mfd-svg" : 1.0.2
                                        Adapter    "icons-open-icon-library-png": 0.1.2
                                        Adapter    "icons-ultimate-png": 1.0.1
                                        Adapter    "influxdb"      : 1.8.4
                                        Adapter    "innogy-smarthome": 0.3.4
                                        Adapter    "intesishome"   : 0.1.2
                                        Adapter    "iogo"          : 0.5.10
                                        Adapter    "iot"           : 1.4.14   , installed 1.4.14
                                        Adapter    "iqontrol"      : 0.3.7
                                        Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                                        Adapter    "jeelink"       : 0.1.3
                                        Adapter    "js2fs"         : 0.1.5
                                        Adapter    "kecontact"     : 0.1.0
                                        Adapter    "klf200"        : 0.9.5
                                        Adapter    "km200"         : 2.0.3
                                        Adapter    "knmi-weather"  : 0.2.0
                                        Adapter    "knx"           : 1.0.41
                                        Adapter    "kodi"          : 2.0.2
                                        Adapter    "kress"         : 2.5.5
                                        Adapter    "lametric"      : 0.0.7
                                        Adapter    "landroid"      : 1.0.3
                                        Adapter    "lcn"           : 0.6.3
                                        Adapter    "letrika_comgw" : 0.0.5
                                        Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                                        Adapter    "lgtv-rs"       : 0.1.0
                                        Adapter    "lgtv11"        : 1.0.5
                                        Adapter    "lifx"          : 0.1.1
                                        Adapter    "lightify"      : 0.2.16
                                        Adapter    "link"          : 0.5.9
                                        Adapter    "linkeddevices" : 1.1.4
                                        Adapter    "lovelace"      : 1.0.16
                                        Adapter    "loxone"        : 1.0.0
                                        Adapter    "luftdaten"     : 0.0.11
                                        Adapter    "lupusec"       : 1.2.6
                                        Adapter    "luxtronik1"    : 0.2.3
                                        Adapter    "material"      : 0.13.8
                                        Adapter    "maxcube"       : 0.1.2
                                        Adapter    "maxcul"        : 1.1.2
                                        Adapter    "mbus"          : 2.2.0
                                        Adapter    "mclighting"    : 0.1.1
                                        Adapter    "megad"         : 1.2.1
                                        Adapter    "megadd"        : 0.2.0
                                        Adapter    "megaesp"       : 0.1.0
                                        Adapter    "mercedesme"    : 0.0.21
                                        Adapter    "mercury"       : 0.1.1
                                        Adapter    "meross"        : 1.3.13
                                        Adapter    "meteoalarm"    : 1.1.0
                                        Adapter    "miele"         : 0.1.5
                                        Adapter    "mielecloudservice": 1.2.1
                                        Adapter    "mihome"        : 1.3.0
                                        Adapter    "mihome-airpurifier": 0.1.7
                                        Adapter    "mihome-lamp"   : 1.1.0
                                        Adapter    "mihome-plug"   : 0.2.1
                                        Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                                        Adapter    "miio"          : 0.0.13
                                        Adapter    "mikrotik"      : 1.0.12
                                        Adapter    "milight"       : 0.3.6
                                        Adapter    "milight-smart-light": 0.4.1
                                        Adapter    "mobile"        : 0.5.0
                                        Adapter    "modbus"        : 3.0.0
                                        Adapter    "moma"          : 1.2.6
                                        Adapter    "mpd"           : 1.0.5
                                        Adapter    "mqtt"          : 2.1.1
                                        Adapter    "mqtt-client"   : 1.3.1
                                        Adapter    "multicast"     : 0.1.5
                                        Adapter    "musiccast"     : 0.1.3
                                        Adapter    "mydlink"       : 1.0.9
                                        Adapter    "myq"           : 0.1.1
                                        Adapter    "mysensors"     : 2.0.0
                                        Adapter    "myvbus"        : 0.0.4
                                        Adapter    "nanoleaf-lightpanels": 0.8.2
                                        Adapter    "nello"         : 2.0.8
                                        Adapter    "netatmo"       : 1.3.1
                                        Adapter    "nibeuplink"    : 0.3.0
                                        Adapter    "nina"          : 0.0.23
                                        Adapter    "node-red"      : 1.17.2
                                        Adapter    "noolitef"      : 0.0.2
                                        Adapter    "nuki"          : 1.2.3
                                        Adapter    "nuki-extended" : 2.2.5
                                        Adapter    "nut"           : 1.1.3
                                        Adapter    "odl"           : 1.0.5
                                        Adapter    "oilfox"        : 2.1.0
                                        Adapter    "onkyo"         : 2.0.3
                                        Adapter    "onvif"         : 0.4.2
                                        Adapter    "openhab"       : 1.1.0
                                        Adapter    "openligadb"    : 1.1.0
                                        Adapter    "opentherm"     : 0.1.9
                                        Adapter    "openweathermap": 0.1.0
                                        Adapter    "opi"           : 0.1.1
                                        Adapter    "oppoplayer"    : 0.2.1
                                        Adapter    "owfs"          : 0.6.4
                                        Adapter    "owntracks"     : 0.6.2
                                        Adapter    "panasonic-viera": 1.0.2
                                        Adapter    "parser"        : 1.0.7
                                        Adapter    "paw"           : 0.3.2
                                        Adapter    "phantomjs"     : 1.0.1
                                        Adapter    "pi-hole"       : 1.2.3
                                        Adapter    "piface"        : 1.0.0
                                        Adapter    "pimatic"       : 0.2.1
                                        Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                                        Adapter    "places"        : 0.7.0
                                        Adapter    "plenticore"    : 2.1.3
                                        Adapter    "plex"          : 0.8.11
                                        Adapter    "plexconnect"   : 0.0.7
                                        Adapter    "pollenflug"    : 1.0.6
                                        Adapter    "primelab"      : 1.0.2
                                        Adapter    "proxmox"       : 1.0.2
                                        Adapter    "proxy"         : 1.2.1
                                        Adapter    "pushbullet"    : 0.0.11
                                        Adapter    "pushover"      : 2.0.2
                                        Adapter    "pushsafer"     : 0.1.8
                                        Adapter    "radar2"        : 1.2.5
                                        Adapter    "radiohead"     : 1.0.5
                                        Adapter    "rainbird"      : 0.2.2
                                        Adapter    "rflink"        : 2.1.5
                                        Adapter    "rickshaw"      : 1.0.0
                                        Adapter    "ring"          : 1.1.2
                                        Adapter    "roadtraffic"   : 0.2.0
                                        Adapter    "robonect"      : 0.1.3
                                        Adapter    "roomba"        : 1.1.1
                                        Adapter    "rpi2"          : 1.2.0
                                        Adapter    "rssfeed"       : 0.0.28
                                        Adapter    "s7"            : 1.1.8
                                        Adapter    "samsung"       : 0.2.9
                                        Adapter    "sanext"        : 0.0.4
                                        Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                                        Adapter    "sbfspot"       : 3.0.0
                                        Adapter    "scenes"        : 1.1.0
                                        Adapter    "schoolfree"    : 0.6.0
                                        Adapter    "senec"         : 1.0.8
                                        Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                                        Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                                        Adapter    "sia"           : 1.0.4
                                        Adapter    "siegenia"      : 1.0.0
                                        Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                                        Adapter    "sma-em"        : 0.5.7
                                        Adapter    "smappee"       : 0.2.2
                                        Adapter    "smartmeter"    : 3.1.2
                                        Adapter    "snips"         : 1.5.0
                                        Adapter    "snmp"          : 0.5.0
                                        Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                                        Adapter    "solarlog"      : 2.0.0
                                        Adapter    "solarviewdatareader": 0.2.0
                                        Adapter    "solarwetter"   : 1.0.0
                                        Adapter    "sonnen"        : 1.5.0
                                        Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                                        Adapter    "sonos"         : 2.0.1
                                        Adapter    "sonus"         : 0.1.1
                                        Adapter    "sony-bravia"   : 1.0.1
                                        Adapter    "sourceanalytix": 0.4.2
                                        Adapter    "spotify-premium": 1.0.0
                                        Adapter    "sql"           : 1.12.5
                                        Adapter    "squeezebox"    : 1.0.0
                                        Adapter    "squeezeboxrpc" : 1.0.1
                                        Adapter    "starline"      : 1.0.0
                                        Adapter    "statistics"    : 0.2.2
                                        Adapter    "stiebel-isg"   : 1.4.11
                                        Adapter    "stockmarket"   : 0.0.2
                                        Adapter    "sunnyportal"   : 0.1.5
                                        Adapter    "swiss-weather-api": 0.2.0
                                        Adapter    "synology"      : 0.1.7
                                        Adapter    "systeminfo"    : 0.3.1
                                        Adapter    "tado"          : 0.1.9
                                        Adapter    "tahoma"        : 0.3.3
                                        Adapter    "tankerkoenig"  : 2.0.9
                                        Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                                        Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                        Adapter    "tesla-motors"  : 0.2.3
                                        Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                                        Adapter    "tileboard"     : 0.1.1
                                        Adapter    "tinker"        : 1.1.0
                                        Adapter    "tino"          : 0.1.3
                                        Adapter    "tinyrx4"       : 0.1.5
                                        Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                                        Adapter    "tradfri"       : 2.6.2
                                        Adapter    "trashschedule" : 0.0.5
                                        Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                        Adapter    "tuya"          : 3.2.3
                                        Adapter    "tvspielfilm"   : 2.0.1
                                        Adapter    "unifi"         : 0.4.3
                                        Adapter    "unifi-protect" : 0.0.11
                                        Adapter    "upnp"          : 1.0.16
                                        Adapter    "vaillant"      : 0.0.10
                                        Adapter    "valloxmv"      : 1.0.3
                                        Adapter    "vcard"         : 0.0.9
                                        Adapter    "vedirect"      : 0.1.0
                                        Adapter    "velux"         : 0.0.5
                                        Adapter    "viessmann"     : 1.2.4
                                        Adapter    "viessmannapi"  : 1.3.2
                                        Adapter    "virtualpowermeter": 1.2.1
                                        Adapter    "vis"           : 1.2.6
                                        Adapter    "vis-bars"      : 0.1.4
                                        Adapter    "vis-canvas-gauges": 0.1.5
                                        Adapter    "vis-colorpicker": 1.2.0
                                        Adapter    "vis-fancyswitch": 1.1.0
                                        Adapter    "vis-google-fonts": 0.1.0
                                        Adapter    "vis-history"   : 1.0.0
                                        Adapter    "vis-hqwidgets" : 1.1.4
                                        Adapter    "vis-inventwo"  : 1.3.3
                                        Adapter    "vis-jqui-mfd"  : 1.0.12
                                        Adapter    "vis-justgage"  : 1.0.2
                                        Adapter    "vis-keyboard"  : 0.0.2
                                        Adapter    "vis-lcars"     : 1.0.4
                                        Adapter    "vis-map"       : 1.0.4
                                        Adapter    "vis-material"  : 0.1.3
                                        Adapter    "vis-material-webfont": 0.0.3
                                        Adapter    "vis-materialdesign": 0.3.6
                                        Adapter    "vis-metro"     : 1.1.2
                                        Adapter    "vis-players"   : 0.1.6
                                        Adapter    "vis-plumb"     : 1.0.2
                                        Adapter    "vis-rgraph"    : 0.0.2
                                        Adapter    "vis-timeandweather": 1.1.7
                                        Adapter    "vis-weather"   : 2.5.2
                                        Adapter    "vodafone-speedtest": 0.0.4
                                        Adapter    "volvo"         : 0.0.2
                                        Adapter    "vr200"         : 1.0.0
                                        Adapter    "vw-connect"    : 0.0.11
                                        Adapter    "weatherunderground": 3.2.1
                                        Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                                        Adapter    "web-speedy"    : 0.2.0
                                        Adapter    "weishaupt-wem" : 0.0.8
                                        Adapter    "wiffi-wz"      : 2.2.0
                                        Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                                        Adapter    "windows-control": 0.1.3
                                        Adapter    "wlanthermo-nano": 0.1.1
                                        Adapter    "wled"          : 0.5.0
                                        Adapter    "wm-bus"        : 0.3.1
                                        Adapter    "wolf"          : 1.2.0
                                        Adapter    "worx"          : 1.0.2
                                        Adapter    "xbox"          : 0.6.3
                                        Adapter    "xs1"           : 1.0.2
                                        Adapter    "yahka"         : 0.11.0
                                        Adapter    "yamaha"        : 0.3.19
                                        Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                                        Adapter    "youtube"       : 0.0.8
                                        Adapter    "yr"            : 2.0.3
                                        Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                                        Adapter    "zoneminder"    : 0.3.3
                                        Adapter    "zont"          : 0.5.4
                                        Adapter    "zwave"         : 2.0.1
                                        Adapter    "zwave2"        : 0.11.7
                                        Adapter "accuweather"    is not installed.
                                        Adapter "alarm"          is not installed.
                                        Adapter "alexa2"         is not installed.
                                        Adapter "alpha2"         is not installed.
                                        Adapter "amazon-dash"    is not installed.
                                        Adapter "artnet"         is not installed.
                                        Adapter "asterisk"       is not installed.
                                        Adapter "asuswrt"        is not installed.
                                        Adapter "b-control-em"   is not installed.
                                        Adapter "backitup"       is not installed.
                                        Adapter "beckhoff"       is not installed.
                                        Adapter "benq"           is not installed.
                                        Adapter "binance"        is not installed.
                                        Adapter "ble"            is not installed.
                                        Adapter "blink4home"     is not installed.
                                        Adapter "bmw"            is not installed.
                                        Adapter "boblight"       is not installed.
                                        Adapter "bosesoundtouch" is not installed.
                                        Adapter "botvac"         is not installed.
                                        Adapter "bring"          is not installed.
                                        Adapter "broadlink2"     is not installed.
                                        Adapter "bsblan"         is not installed.
                                        Adapter "bshb"           is not installed.
                                        Adapter "calendar"       is not installed.
                                        Adapter "chromecast"     is up to date.
                                        Adapter "cloud"          is up to date.
                                        Adapter "comfoair"       is not installed.
                                        Adapter "contact"        is not installed.
                                        Adapter "contactid"      is not installed.
                                        Adapter "coronavirus-statistics" is not installed.
                                        Adapter "corrently"      is not installed.
                                        Adapter "countdown"      is not installed.
                                        Adapter "cul"            is not installed.
                                        Adapter "daikin"         is not installed.
                                        Adapter "daswetter"      is up to date.
                                        Adapter "deconz"         is not installed.
                                        Adapter "devices"        is not installed.
                                        Adapter "digitalstrom"   is not installed.
                                        Adapter "discovergy"     is not installed.
                                        NPM version: 6.14.4
                                        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                        ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        NPM version: 6.14.4
                                        > node thank-you.js
                                        gyp ERR! System Linux 4.19.97-v7l+
                                        gyp ERR! node -v v12.16.3
                                        gyp ERR! node-gyp -v v5.1.0
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        #79
                                        @maxpd
                                        Und? Läuft zigbee nun?
                                          @maxpd
                                          maxpd
                                          #80
                                          @Thomas-Braun AAABBBBERRR Zigbeeeee läuft!!!!!!!!!!!!
                                          maxpd
