  4. Javascript Adapter rot (out of memory)
javascript
82 Beiträge 6 Kommentatoren 12.2k Aufrufe 5 Beobachtet
    @maxpd
    iobroker stop
    iobroker start
    Und dann schau nochmal, was das Adapter im log ausgibt, wenn der startet.
    maxpd
    @Thomas-Braun
    Bislang nur Zeile 16 gelöscht und iobroker neu gestartet.
    Fehler ist weiterhin der gleiche.
    host.iobroker	2020-05-08 10:57:34.353	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker	2020-05-08 10:57:34.353	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: ^
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: throw e;
    host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    host.iobroker	2020-05-08 10:57:33.963	info	instance system.adapter.zigbee.0 started with pid 7660
    maxpd
    • M maxpd
      @Thomas-Braun
      @maxpd
      Stop den iobroker nochmal.
      Und dann im Verzeichnis /opt/iobroker stehend:
      iobroker rebuild iobroker.zigbee --install
      • M maxpd
        @Thomas-Braun
        @maxpd Wenn das nicht ausreicht, im gleichen Verzeichnis
        npm rebuild bindings
          @maxpd
          maxpd
          @Thomas-Braun da waren wir gestern schonmal. Den Befehl gibt es nicht.
          pi@iobroker:/opt/iobroker $ rebuild iobroker.zigbee --install
          -bash: rebuild: Kommando nicht gefunden.
          pi@iobroker:/opt/iobroker $ iobroker rebuild iobroker.zigbee --install
          Commands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start
          iobroker stop
          iobroker start <adapter>
          iobroker stop <adapter>
          iobroker start all
          iobroker restart
          iobroker restart <adapter>
          iobroker info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter>
          iobroker url <url> [<name>]
          iobroker del <adapter>
          iobroker del <adapter>.<instance>
          iobroker update [repository url] [--updatable/--u] [--installed/--i]
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url]
          iobroker upgrade <adapter> [repository url]
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all
          iobroker upload <adapter>
          iobroker object get <id>
          iobroker object set <id> <json-value>
          iobroker object set <id> propertyname=value
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id>
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instanceid] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path>
          iobroker validate <backup name or path>
          iobroker <command> --timeout 5000
          iobroker status [all]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status
          iobroker compact <enable|on|disable|off>
          iobroker compact <adapter>.<instance> status
          iobroker compact <adapter>.<instance> group <group-id>
          iobroker compact <adapter>.<instance> <disable|off>
          iobroker compact <adapter>.<instance> <enable|on> [group-id]
          iobroker version [adapter]
          iobroker [adapter] -v
          Options:
            --help     Hilfe anzeigen  [boolean]
            --version  Version anzeigen  [boolean]
          nach dem Binding rebuild habe ich weiterhin den gleichen Fehler.
          maxpd
          • M maxpd
            Commands:
            iobroker start
            iobroker stop
            iobroker start all
            iobroker restart
            iobroker info
            iobroker upload all
            iobroker rm <file>
            iobroker file sync
            iobroker host this
            iobroker clean
            iobroker backup
            iobroker uuid
            iobroker unsetup
            iobroker fix
            Options:
            @maxpd
            Dann über npm.
            npm rebuild iobroker.zigbee
              @maxpd
              Dann über npm.
              maxpd
              @Thomas-Braun
              funktioniert auch nicht.
              pi@iobroker:/opt/iobroker $ npm rebuild iobroker.zigbee
              iobroker.zigbee@1.0.4 /opt/iobroker/node_modules/iobroker.zigbee
              anschließend auch bindings gesetzt. Fehler bleibt gleich 😵
              maxpd
              • M maxpd
                @Thomas-Braun
                #66
                @maxpd Mehr kommt da nicht an Ausgabe?
                  maxpd
                  #67
                  @Thomas-Braun nein, das war alles
                  maxpd
                  • M maxpd
                    #68
                    @maxpd
                    iobroker list instances
                      @maxpd
                      maxpd
                      #69
                      @Thomas-Braun
                      pi@iobroker:/opt/iobroker $ iobroker list instances
                      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.chromecast.0            : chromecast            - disabled
                      + system.adapter.cloud.0                 : cloud                 -  enabled
                        system.adapter.daswetter.0             : daswetter             -  enabled
                      + system.adapter.denon.0                 : denon                 -  enabled
                      + system.adapter.discovery.0             : discovery             -  enabled
                      + system.adapter.google-sharedlocations.0: google-sharedlocations -  enabled
                        system.adapter.history.0               : history               - disabled
                      + system.adapter.hm-rega.0               : hm-rega               -  enabled
                      + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
                      + system.adapter.info.0                  : info                  -  enabled
                        system.adapter.iot.0                   : iot                   - disabled
                      + system.adapter.javascript.0            : javascript            -  enabled
                      + system.adapter.lgtv.0                  : lgtv                  -  enabled
                      + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
                        system.adapter.ping.0                  : ping                  - disabled
                      + system.adapter.sayit.0                 : sayit                 -  enabled, port: 0
                        system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
                      + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.1              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.telegram.2              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.text2command.0          : text2command          -  enabled
                        system.adapter.tr-064.0                : tr-064                - disabled
                      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.wifilight.0             : wifilight             -  enabled
                      + system.adapter.yeelight-2.0            : yeelight-2            -  enabled
                        system.adapter.zigbee.0                : zigbee                -  enabled
                      + instance is alive
                      maxpd
                      • M maxpd
                        @Thomas-Braun
                        + instance is alive
                        #70
                        @maxpd Keine Ahnung...
                        Vielleicht ziehst du das gesamte System auf 'latest' und node12?
                          maxpd
                          #71
                          @Thomas-Braun Versuchen kann ichs. Mit welchen Befehlen?
                          maxpd
                          • M maxpd
                            #72
                            @maxpd
                            iobroker stop
                            iobroker fix
                            iobroker start
                            Dann im Admin beim 'Schraubenschlüssel' - 'Haupteinstellungen' auf 'latest' stellen.
                            iobroker update
                            iobroker upgrade
                            Dann in /opt/iobroker
                            npm rebuild
                            iobroker start
                            Das müsste es gewesen sein...
                            • Thomas BraunT Online
                              #73
                              Vorher vielleicht auch noch node12 installieren:
                              curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                              sudo apt update
                              sudo apt dist-upgrade
                                maxpd
                                schrieb am zuletzt editiert von maxpd
                                #74
                                puuuhhh durchsäht von fehlern
                                pi@iobroker:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_12.x | sud                                                             o -E bash -
                                ## Installing the NodeSource Node.js 12.x repo...
                                ## Populating apt-get cache...
                                + apt-get update
                                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                Holen:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,                                                             0 MB]
                                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                                OK:5 https://www.pivccu.de/piVCCU stable InRelease
                                Es wurden 13,0 MB in 1 min 6 s geholt (198 kB/s).
                                ## Confirming "buster" is supported...
                                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Rele                                                             ase'
                                ## Adding the NodeSource signing key to your keyring...
                                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                                OK
                                ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                                + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources                                                             .list.d/nodesource.list
                                + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/so                                                             urces.list.d/nodesource.list
                                ## Running `apt-get update` for you...
                                + apt-get update
                                OK:1 https://deb.nodesource.com/node_12.x buster InRelease
                                OK:2 https://www.pivccu.de/piVCCU stable InRelease
                                OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                OK:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                                ## You may also need development tools to build native addons:
                                     sudo apt-get install gcc g++ make
                                ## To install the Yarn package manager, run:
                                     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                                     echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/s                                                             ources.list.d/yarn.list
                                     sudo apt-get update && sudo apt-get install yarn
                                pi@iobroker:/opt/iobroker $ sudo apt update
                                OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                Fehl:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut werden (2a00:1                                                             098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreichbar) Verbin                                                             dung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (93.93.128.19                                                             3), Zeitüberschreitung aufgetreten
                                Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u                                                             m sie anzuzeigen.
                                W: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/dists/bust                                                             er/InRelease Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut wer                                                             den (2a00:1098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreich                                                             bar) Verbindung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (9                                                             3.93.128.193), Zeitüberschreitung aufgetreten
                                W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignorier                                                             t oder alte an ihrer Stelle benutzt.
                                Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                pi@iobroker:/opt/iobroker $ apt dist-upgrade
                                E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                                pi@iobroker:/opt/iobroker $ sudo apt dist-upgrade
                                Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                                  rpi.gpio-common
                                Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                                  libldap-2.4-2 libldap-common
                                2 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                Es müssen 288 kB an Archiven heruntergeladen werden.
                                Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                                Möchten Sie fortfahren? [J/n] j
                                Holen:1 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u2 [89,8 kB]
                                Holen:2 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u2 [198 kB]
                                Es wurden 288 kB in 60 s geholt (4.798 B/s).
                                Changelogs werden gelesen... Fertig
                                (Lese Datenbank ... 117901 Dateien und Verzeichnisse sind derzeit installiert.)
                                Vorbereitung zum Entpacken von .../libldap-common_2.4.47+dfsg-3+rpi1+deb10u2_all.deb ...
                                Entpacken von libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                                libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                                Vorbereitung zum Entpacken von .../libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u2_armhf.deb ...
                                Entpacken von libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                                libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                                Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                                pi@iobroker:/opt/iobroker $ iobroker stop
                                pi@iobroker:/opt/iobroker $ iobroker fix
                                library: loaded
                                Library version=2020-04-12
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2020-04-12
                                    You might need to enter your password a couple of times.
                                    Installing prerequisites (1/3)
                                OK:1 https://www.pivccu.de/piVCCU stable InRelease
                                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                Installed gcc-c++
                                Installed python-dev
                                    Checking ioBroker user and directory permissions (2/3)
                                    Checking autostart (3/3)
                                Enabling autostart...
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                pi@iobroker:/opt/iobroker $ iobroker start
                                pi@iobroker:/opt/iobroker $ iobroker update
                                Used repository: latest
                                hash unchanged, use cached sources
                                update done
                                Adapter    "accuweather"   : 1.1.3
                                Adapter    "admin"         : 4.1.1    , installed 4.0.9 [Updateable]
                                Adapter    "alarm"         : 0.3.0
                                Adapter    "alexa2"        : 3.1.2
                                Adapter    "alpha2"        : 1.0.0
                                Adapter    "amazon-dash"   : 1.1.0
                                Adapter    "artnet"        : 1.2.2
                                Adapter    "asterisk"      : 1.0.6
                                Adapter    "asuswrt"       : 1.0.1
                                Adapter    "b-control-em"  : 0.2.1
                                Adapter    "backitup"      : 1.5.6
                                Adapter    "beckhoff"      : 1.2.1
                                Adapter    "benq"          : 0.2.2
                                Adapter    "binance"       : 1.1.2
                                Adapter    "ble"           : 0.11.6
                                Adapter    "blink4home"    : 0.1.1
                                Adapter    "bmw"           : 1.4.0
                                Adapter    "boblight"      : 0.0.1
                                Adapter    "bosesoundtouch": 0.9.2
                                Adapter    "botvac"        : 1.0.0
                                Adapter    "bring"         : 1.7.2
                                Adapter    "broadlink2"    : 2.0.3
                                Adapter    "bsblan"        : 0.0.6
                                Adapter    "bshb"          : 0.1.10
                                Adapter    "calendar"      : 1.2.0
                                Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                                Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                                Adapter    "comfoair"      : 1.1.1
                                Adapter    "contact"       : 1.1.3
                                Adapter    "contactid"     : 1.0.0
                                Adapter    "coronavirus-statistics": 0.5.9
                                Adapter    "corrently"     : 0.0.2
                                Adapter    "countdown"     : 1.1.0
                                Adapter    "cul"           : 1.2.1
                                Adapter    "daikin"        : 1.0.5
                                Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                                Adapter    "deconz"        : 1.3.7
                                Adapter    "denon"         : 1.7.7    , installed 1.7.4 [Updateable]
                                Adapter    "devices"       : 0.3.6
                                Adapter    "digitalstrom"  : 2.0.5
                                Adapter    "discovergy"    : 0.5.4
                                Adapter    "discovery"     : 2.3.5    , installed 2.2.2 [Updateable]
                                Adapter    "doorbird"      : 0.1.5
                                Adapter    "ds18b20"       : 1.1.4
                                Adapter    "dwd"           : 2.4.8
                                Adapter    "ebus"          : 2.0.0
                                Adapter    "ecovacs-deebot": 0.5.8
                                Adapter    "egigeozone"    : 0.1.2
                                Adapter    "ekey"          : 1.1.0
                                Adapter    "email"         : 1.0.6
                                Adapter    "emby"          : 1.0.2
                                Adapter    "energymanager" : 1.2.2
                                Adapter    "enet"          : 1.0.1
                                Adapter    "epson_stylus_px830": 0.2.1
                                Adapter    "exchangerates" : 0.0.12
                                Adapter    "fakeroku"      : 0.2.1
                                Adapter    "fb-checkpresence": 1.0.1
                                Adapter    "feiertage"     : 1.0.19
                                Adapter    "fhem"          : 1.4.1
                                Adapter    "find-my-iphone": 0.2.17
                                Adapter    "firetv"        : 1.0.0
                                Adapter    "fitbit-api"    : 0.1.1
                                Adapter    "flot"          : 1.9.2
                                Adapter    "foobar2000"    : 1.0.0
                                Adapter    "fritzbox"      : 0.2.1
                                Adapter    "fritzdect"     : 0.3.2
                                Adapter    "fronius"       : 1.0.5
                                Adapter    "fullcalendar"  : 1.1.0
                                Adapter    "fullybrowser"  : 1.0.3
                                Adapter    "g-homa"        : 0.5.1
                                Adapter    "geofency"      : 0.3.2
                                Adapter    "gruenbeck"     : 0.0.18
                                Adapter    "habpanel"      : 0.4.1
                                Adapter    "haier"         : 1.0.3
                                Adapter    "ham"           : 1.1.2
                                Adapter    "ham-wemo"      : 1.0.1
                                Adapter    "harmony"       : 1.2.2
                                Adapter    "hass-mqtt"     : 0.0.7
                                Adapter    "heatingcontrol": 0.5.0
                                Adapter    "heytech"       : 0.2.0
                                Adapter    "hid"           : 0.1.17
                                Adapter    "hilink"        : 0.2.7
                                Adapter    "history"       : 1.9.6    , installed 1.8.7 [Updateable]
                                Adapter    "hm-rega"       : 2.6.6    , installed 2.5.5 [Updateable]
                                Adapter    "hm-rpc"        : 1.14.2   , installed 1.12.10 [Updateable]
                                Adapter    "hmip"          : 0.0.11
                                Adapter    "hombot"        : 0.1.3
                                Adapter    "homeconnect"   : 0.0.26
                                Adapter    "homee"         : 1.0.5
                                Adapter    "homepilot"     : 1.1.4
                                Adapter    "hp-ilo"        : 1.0.5
                                Adapter    "hs100"         : 1.1.2
                                Adapter    "hue"           : 3.2.8
                                Adapter    "hue-extended"  : 1.3.2
                                Adapter    "hyperion"      : 0.0.9
                                Adapter    "i2c"           : 0.0.6
                                Adapter    "ical"          : 1.7.0
                                Adapter    "icons-addictive-flavour-png": 0.1.0
                                Adapter    "icons-fatcow-hosting": 0.1.0
                                Adapter    "icons-icons8"  : 0.0.1
                                Adapter    "icons-material-png": 0.1.0
                                Adapter    "icons-material-svg": 0.1.0
                                Adapter    "icons-mfd-png" : 1.0.2
                                Adapter    "icons-mfd-svg" : 1.0.2
                                Adapter    "icons-open-icon-library-png": 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1
                                Adapter    "influxdb"      : 1.8.4
                                Adapter    "info"          : 1.7.2    , installed 1.5.6 [Updateable]
                                Adapter    "innogy-smarthome": 0.3.4
                                Adapter    "intesishome"   : 0.1.2
                                Adapter    "iogo"          : 0.5.10
                                Adapter    "iot"           : 1.4.14   , installed 1.4.14
                                Adapter    "iqontrol"      : 0.3.7
                                Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                                Adapter    "jeelink"       : 0.1.3
                                Controller "js-controller" : 3.0.20   , installed 2.2.9 [Updateable]
                                Adapter    "js2fs"         : 0.1.5
                                Adapter    "kecontact"     : 0.1.0
                                Adapter    "klf200"        : 0.9.5
                                Adapter    "km200"         : 2.0.3
                                Adapter    "knmi-weather"  : 0.2.0
                                Adapter    "knx"           : 1.0.41
                                Adapter    "kodi"          : 2.0.2
                                Adapter    "kress"         : 2.5.5
                                Adapter    "lametric"      : 0.0.7
                                Adapter    "landroid"      : 1.0.3
                                Adapter    "lcn"           : 0.6.3
                                Adapter    "letrika_comgw" : 0.0.5
                                Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                                Adapter    "lgtv-rs"       : 0.1.0
                                Adapter    "lgtv11"        : 1.0.5
                                Adapter    "lifx"          : 0.1.1
                                Adapter    "lightify"      : 0.2.16
                                Adapter    "link"          : 0.5.9
                                Adapter    "linkeddevices" : 1.1.4
                                Adapter    "lovelace"      : 1.0.16
                                Adapter    "loxone"        : 1.0.0
                                Adapter    "luftdaten"     : 0.0.11
                                Adapter    "lupusec"       : 1.2.6
                                Adapter    "luxtronik1"    : 0.2.3
                                Adapter    "material"      : 0.13.8
                                Adapter    "maxcube"       : 0.1.2
                                Adapter    "maxcul"        : 1.1.2
                                Adapter    "mbus"          : 2.2.0
                                Adapter    "mclighting"    : 0.1.1
                                Adapter    "megad"         : 1.2.1
                                Adapter    "megadd"        : 0.2.0
                                Adapter    "megaesp"       : 0.1.0
                                Adapter    "mercedesme"    : 0.0.21
                                Adapter    "mercury"       : 0.1.1
                                Adapter    "meross"        : 1.3.13
                                Adapter    "meteoalarm"    : 1.1.0
                                Adapter    "miele"         : 0.1.5
                                Adapter    "mielecloudservice": 1.2.1
                                Adapter    "mihome"        : 1.3.0
                                Adapter    "mihome-airpurifier": 0.1.7
                                Adapter    "mihome-lamp"   : 1.1.0
                                Adapter    "mihome-plug"   : 0.2.1
                                Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                                Adapter    "miio"          : 0.0.13
                                Adapter    "mikrotik"      : 1.0.12
                                Adapter    "milight"       : 0.3.6
                                Adapter    "milight-smart-light": 0.4.1
                                Adapter    "mobile"        : 0.5.0
                                Adapter    "modbus"        : 3.0.0
                                Adapter    "moma"          : 1.2.6
                                Adapter    "mpd"           : 1.0.5
                                Adapter    "mqtt"          : 2.1.1
                                Adapter    "mqtt-client"   : 1.3.1
                                Adapter    "multicast"     : 0.1.5
                                Adapter    "musiccast"     : 0.1.3
                                Adapter    "mydlink"       : 1.0.9
                                Adapter    "myq"           : 0.1.1
                                Adapter    "mysensors"     : 2.0.0
                                Adapter    "myvbus"        : 0.0.4
                                Adapter    "nanoleaf-lightpanels": 0.8.2
                                Adapter    "nello"         : 2.0.8
                                Adapter    "netatmo"       : 1.3.1
                                Adapter    "nibeuplink"    : 0.3.0
                                Adapter    "nina"          : 0.0.23
                                Adapter    "node-red"      : 1.17.2
                                Adapter    "noolitef"      : 0.0.2
                                Adapter    "nuki"          : 1.2.3
                                Adapter    "nuki-extended" : 2.2.5
                                Adapter    "nut"           : 1.1.3
                                Adapter    "odl"           : 1.0.5
                                Adapter    "oilfox"        : 2.1.0
                                Adapter    "onkyo"         : 2.0.3
                                Adapter    "onvif"         : 0.4.2
                                Adapter    "openhab"       : 1.1.0
                                Adapter    "openligadb"    : 1.1.0
                                Adapter    "opentherm"     : 0.1.9
                                Adapter    "openweathermap": 0.1.0
                                Adapter    "opi"           : 0.1.1
                                Adapter    "oppoplayer"    : 0.2.1
                                Adapter    "owfs"          : 0.6.4
                                Adapter    "owntracks"     : 0.6.2
                                Adapter    "panasonic-viera": 1.0.2
                                Adapter    "parser"        : 1.0.7
                                Adapter    "paw"           : 0.3.2
                                Adapter    "phantomjs"     : 1.0.1
                                Adapter    "pi-hole"       : 1.2.3
                                Adapter    "piface"        : 1.0.0
                                Adapter    "pimatic"       : 0.2.1
                                Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                                Adapter    "places"        : 0.7.0
                                Adapter    "plenticore"    : 2.1.3
                                Adapter    "plex"          : 0.8.11
                                Adapter    "plexconnect"   : 0.0.7
                                Adapter    "pollenflug"    : 1.0.6
                                Adapter    "primelab"      : 1.0.2
                                Adapter    "proxmox"       : 1.0.2
                                Adapter    "proxy"         : 1.2.1
                                Adapter    "pushbullet"    : 0.0.11
                                Adapter    "pushover"      : 2.0.2
                                Adapter    "pushsafer"     : 0.1.8
                                Adapter    "radar2"        : 1.2.5
                                Adapter    "radiohead"     : 1.0.5
                                Adapter    "rainbird"      : 0.2.2
                                Adapter    "rflink"        : 2.1.5
                                Adapter    "rickshaw"      : 1.0.0
                                Adapter    "ring"          : 1.1.2
                                Adapter    "roadtraffic"   : 0.2.0
                                Adapter    "robonect"      : 0.1.3
                                Adapter    "roomba"        : 1.1.1
                                Adapter    "rpi2"          : 1.2.0
                                Adapter    "rssfeed"       : 0.0.28
                                Adapter    "s7"            : 1.1.8
                                Adapter    "samsung"       : 0.2.9
                                Adapter    "sanext"        : 0.0.4
                                Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                                Adapter    "sbfspot"       : 3.0.0
                                Adapter    "scenes"        : 1.1.0
                                Adapter    "schoolfree"    : 0.6.0
                                Adapter    "senec"         : 1.0.8
                                Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                                Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                                Adapter    "sia"           : 1.0.4
                                Adapter    "siegenia"      : 1.0.0
                                Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                                Adapter    "sma-em"        : 0.5.7
                                Adapter    "smappee"       : 0.2.2
                                Adapter    "smartmeter"    : 3.1.2
                                Adapter    "snips"         : 1.5.0
                                Adapter    "snmp"          : 0.5.0
                                Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                                Adapter    "solarlog"      : 2.0.0
                                Adapter    "solarviewdatareader": 0.2.0
                                Adapter    "solarwetter"   : 1.0.0
                                Adapter    "sonnen"        : 1.5.0
                                Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                                Adapter    "sonos"         : 2.0.1
                                Adapter    "sonus"         : 0.1.1
                                Adapter    "sony-bravia"   : 1.0.1
                                Adapter    "sourceanalytix": 0.4.2
                                Adapter    "spotify-premium": 1.0.0
                                Adapter    "sql"           : 1.12.5
                                Adapter    "squeezebox"    : 1.0.0
                                Adapter    "squeezeboxrpc" : 1.0.1
                                Adapter    "starline"      : 1.0.0
                                Adapter    "statistics"    : 0.2.2
                                Adapter    "stiebel-isg"   : 1.4.11
                                Adapter    "stockmarket"   : 0.0.2
                                Adapter    "sunnyportal"   : 0.1.5
                                Adapter    "swiss-weather-api": 0.2.0
                                Adapter    "synology"      : 0.1.7
                                Adapter    "systeminfo"    : 0.3.1
                                Adapter    "tado"          : 0.1.9
                                Adapter    "tahoma"        : 0.3.3
                                Adapter    "tankerkoenig"  : 2.0.9
                                Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                                Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                Adapter    "tesla-motors"  : 0.2.3
                                Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                                Adapter    "tileboard"     : 0.1.1
                                Adapter    "tinker"        : 1.1.0
                                Adapter    "tino"          : 0.1.3
                                Adapter    "tinyrx4"       : 0.1.5
                                Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                                Adapter    "tradfri"       : 2.6.2
                                Adapter    "trashschedule" : 0.0.5
                                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                Adapter    "tuya"          : 3.2.3
                                Adapter    "tvspielfilm"   : 2.0.1
                                Adapter    "unifi"         : 0.4.3
                                Adapter    "unifi-protect" : 0.0.11
                                Adapter    "upnp"          : 1.0.16
                                Adapter    "vaillant"      : 0.0.10
                                Adapter    "valloxmv"      : 1.0.3
                                Adapter    "vcard"         : 0.0.9
                                Adapter    "vedirect"      : 0.1.0
                                Adapter    "velux"         : 0.0.5
                                Adapter    "viessmann"     : 1.2.4
                                Adapter    "viessmannapi"  : 1.3.2
                                Adapter    "virtualpowermeter": 1.2.1
                                Adapter    "vis"           : 1.2.6
                                Adapter    "vis-bars"      : 0.1.4
                                Adapter    "vis-canvas-gauges": 0.1.5
                                Adapter    "vis-colorpicker": 1.2.0
                                Adapter    "vis-fancyswitch": 1.1.0
                                Adapter    "vis-google-fonts": 0.1.0
                                Adapter    "vis-history"   : 1.0.0
                                Adapter    "vis-hqwidgets" : 1.1.4
                                Adapter    "vis-inventwo"  : 1.3.3
                                Adapter    "vis-jqui-mfd"  : 1.0.12
                                Adapter    "vis-justgage"  : 1.0.2
                                Adapter    "vis-keyboard"  : 0.0.2
                                Adapter    "vis-lcars"     : 1.0.4
                                Adapter    "vis-map"       : 1.0.4
                                Adapter    "vis-material"  : 0.1.3
                                Adapter    "vis-material-webfont": 0.0.3
                                Adapter    "vis-materialdesign": 0.3.6
                                Adapter    "vis-metro"     : 1.1.2
                                Adapter    "vis-players"   : 0.1.6
                                Adapter    "vis-plumb"     : 1.0.2
                                Adapter    "vis-rgraph"    : 0.0.2
                                Adapter    "vis-timeandweather": 1.1.7
                                Adapter    "vis-weather"   : 2.5.2
                                Adapter    "vodafone-speedtest": 0.0.4
                                Adapter    "volvo"         : 0.0.2
                                Adapter    "vr200"         : 1.0.0
                                Adapter    "vw-connect"    : 0.0.11
                                Adapter    "weatherunderground": 3.2.1
                                Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                                Adapter    "web-speedy"    : 0.2.0
                                Adapter    "weishaupt-wem" : 0.0.8
                                Adapter    "wiffi-wz"      : 2.2.0
                                Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                                Adapter    "windows-control": 0.1.3
                                Adapter    "wlanthermo-nano": 0.1.1
                                Adapter    "wled"          : 0.5.0
                                Adapter    "wm-bus"        : 0.3.1
                                Adapter    "wolf"          : 1.2.0
                                Adapter    "worx"          : 1.0.2
                                Adapter    "xbox"          : 0.6.3
                                Adapter    "xs1"           : 1.0.2
                                Adapter    "yahka"         : 0.11.0
                                Adapter    "yamaha"        : 0.3.19
                                Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                                Adapter    "youtube"       : 0.0.8
                                Adapter    "yr"            : 2.0.3
                                Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                                Adapter    "zoneminder"    : 0.3.3
                                Adapter    "zont"          : 0.5.4
                                Adapter    "zwave"         : 2.0.1
                                Adapter    "zwave2"        : 0.11.7
                                pi@iobroker:/opt/iobroker $ iobroker upgrade
                                Adapter "accuweather"    is not installed.
                                Update admin from @4.0.9 to @4.1.1
                                host.iobroker Adapter "system.adapter.admin.0" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.admin@4.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                Package pixman-1 was not found in the pkg-config search path.
                                Perhaps you should add the directory containing `pixman-1.pc'
                                to the PKG_CONFIG_PATH environment variable
                                No package 'pixman-1' found
                                gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                gyp ERR! configure error
                                gyp ERR! stack Error: `gyp` failed with exit code: 1
                                gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                                gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                gyp ERR! System Linux 4.19.97-v7l+
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                                gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                gyp ERR! node -v v12.16.3
                                gyp ERR! node-gyp -v v5.1.0
                                gyp ERR! not ok
                                node-pre-gyp ERR! build error
                                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                                node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                                node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                node-pre-gyp ERR! System Linux 4.19.97-v7l+
                                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                node-pre-gyp ERR! node -v v12.16.3
                                node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                node-pre-gyp ERR! not ok
                                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                                Update "system.adapter.admin.0"
                                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                Adapter "admin" updated
                                host.iobroker Adapter "system.adapter.admin.0" is started
                                Adapter "alarm"          is not installed.
                                Adapter "alexa2"         is not installed.
                                Adapter "alpha2"         is not installed.
                                Adapter "amazon-dash"    is not installed.
                                Adapter "artnet"         is not installed.
                                Adapter "asterisk"       is not installed.
                                Adapter "asuswrt"        is not installed.
                                Adapter "b-control-em"   is not installed.
                                Adapter "backitup"       is not installed.
                                Adapter "beckhoff"       is not installed.
                                Adapter "benq"           is not installed.
                                Adapter "binance"        is not installed.
                                Adapter "ble"            is not installed.
                                Adapter "blink4home"     is not installed.
                                Adapter "bmw"            is not installed.
                                Adapter "boblight"       is not installed.
                                Adapter "bosesoundtouch" is not installed.
                                Adapter "botvac"         is not installed.
                                Adapter "bring"          is not installed.
                                Adapter "broadlink2"     is not installed.
                                Adapter "bsblan"         is not installed.
                                Adapter "bshb"           is not installed.
                                Adapter "calendar"       is not installed.
                                Adapter "chromecast"     is up to date.
                                Adapter "cloud"          is up to date.
                                Adapter "comfoair"       is not installed.
                                Adapter "contact"        is not installed.
                                Adapter "contactid"      is not installed.
                                Adapter "coronavirus-statistics" is not installed.
                                Adapter "corrently"      is not installed.
                                Adapter "countdown"      is not installed.
                                Adapter "cul"            is not installed.
                                Adapter "daikin"         is not installed.
                                Adapter "daswetter"      is up to date.
                                Adapter "deconz"         is not installed.
                                Update denon from @1.7.4 to @1.7.7
                                NPM version: 6.14.4
                                npm install iobroker.denon@1.7.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                                Update "system.adapter.denon.0"
                                upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                                upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index.html index.html text/html
                                upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                                Adapter "denon" updated
                                Adapter "devices"        is not installed.
                                Adapter "digitalstrom"   is not installed.
                                Adapter "discovergy"     is not installed.
                                Update discovery from @2.2.2 to @2.3.5
                                NPM version: 6.14.4
                                npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
                                In file included from ../src/./serialport.h:6,
                                                 from ../src/serialport.cpp:1:
                                ../../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                ../../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                ../src/serialport.cpp: At global scope:
                                ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                In file included from ../../../../../nan/nan.h:54,
                                /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                       (node::addon_register_func) (regfunc),                          \
                                /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
                                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(serialport, init);
                                In file included from ../src/serialport.h:6,
                                                 from ../src/serialport_unix.cpp:2:
                                ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                In file included from ../src/poller.cpp:1:
                                gyp ERR! not ok
                                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                Update "system.adapter.discovery.0"
                                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                Adapter "discovery" updated
                                Adapter "doorbird"       is not installed.
                                Adapter "ds18b20"        is not installed.
                                Adapter "dwd"            is not installed.
                                Adapter "ebus"           is not installed.
                                Adapter "ecovacs-deebot" is not installed.
                                Adapter "egigeozone"     is not installed.
                                Adapter "ekey"           is not installed.
                                Adapter "email"          is not installed.
                                Adapter "emby"           is not installed.
                                Adapter "energymanager"  is not installed.
                                Adapter "enet"           is not installed.
                                Adapter "epson_stylus_px830" is not installed.
                                Adapter "exchangerates"  is not installed.
                                Adapter "fakeroku"       is not installed.
                                Adapter "fb-checkpresence" is not installed.
                                Adapter "feiertage"      is not installed.
                                Adapter "fhem"           is not installed.
                                Adapter "find-my-iphone" is not installed.
                                Adapter "firetv"         is not installed.
                                Adapter "fitbit-api"     is not installed.
                                Adapter "flot"           is not installed.
                                Adapter "foobar2000"     is not installed.
                                Adapter "fritzbox"       is not installed.
                                Adapter "fritzdect"      is not installed.
                                Adapter "fronius"        is not installed.
                                Adapter "fullcalendar"   is not installed.
                                Adapter "fullybrowser"   is not installed.
                                Adapter "g-homa"         is not installed.
                                Adapter "geofency"       is not installed.
                                Adapter "gruenbeck"      is not installed.
                                Adapter "habpanel"       is not installed.
                                Adapter "haier"          is not installed.
                                Adapter "ham"            is not installed.
                                Adapter "ham-wemo"       is not installed.
                                Adapter "harmony"        is not installed.
                                Adapter "hass-mqtt"      is not installed.
                                Adapter "heatingcontrol" is not installed.
                                Adapter "heytech"        is not installed.
                                Adapter "hid"            is not installed.
                                Adapter "hilink"         is not installed.
                                Update history from @1.8.7 to @1.9.6
                                NPM version: 6.14.4
                                npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/wordsCustom.js wordsCustom.js application/javascript
                                upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                Update "system.adapter.history.0"
                                upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                                upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                                upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                                upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                                Adapter "history" updated
                                Update hm-rega from @2.5.5 to @2.6.6
                                NPM version: 6.14.4
                                npm install iobroker.hm-rega@2.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                                Update "system.adapter.hm-rega.0"
                                upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                                upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                                upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                                Adapter "hm-rega" updated
                                Update hm-rpc from @1.12.10 to @1.14.2
                                NPM version: 6.14.4
                                npm install iobroker.hm-rpc@1.14.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                Update "system.adapter.hm-rpc.0"
                                upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/96_hm-tc-it-wm-w-eu_thumb.png icons/96_hm-tc-it-wm-w-eu_thumb.png image/png
                                upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/49_hm-sec-wds_thumb.png icons/49_hm-sec-wds_thumb.png image/png
                                upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                                upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                                upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                                upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                                upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                                upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                                upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                                upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                                upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                                upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                                upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                                upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                                upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                                upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                                upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                                upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                                upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                                upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                                upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                                upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                                upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                                upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                                upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                                upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                                upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                                upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                                upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                                upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                                upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                                Adapter "hm-rpc" updated
                                Adapter "hmip"           is not installed.
                                Adapter "hombot"         is not installed.
                                Adapter "homeconnect"    is not installed.
                                Adapter "homee"          is not installed.
                                Adapter "homepilot"      is not installed.
                                Adapter "hp-ilo"         is not installed.
                                Adapter "hs100"          is not installed.
                                Adapter "hue"            is not installed.
                                Adapter "hue-extended"   is not installed.
                                Adapter "hyperion"       is not installed.
                                Adapter "i2c"            is not installed.
                                Adapter "ical"           is not installed.
                                Adapter "icons-addictive-flavour-png" is not installed.
                                Adapter "icons-fatcow-hosting" is not installed.
                                Adapter "icons-icons8"   is not installed.
                                Adapter "icons-material-png" is not installed.
                                Adapter "icons-material-svg" is not installed.
                                Adapter "icons-mfd-png"  is not installed.
                                Adapter "icons-mfd-svg"  is not installed.
                                Adapter "icons-open-icon-library-png" is not installed.
                                Adapter "icons-ultimate-png" is not installed.
                                Adapter "influxdb"       is not installed.
                                Update info from @1.5.6 to @1.7.2
                                NPM version: 6.14.4
                                npm install iobroker.info@1.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                Update "system.adapter.info.0"
                                upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                Adapter "info" updated
                                Adapter "innogy-smarthome" is not installed.
                                Adapter "intesishome"    is not installed.
                                Adapter "iogo"           is not installed.
                                Adapter "iot"            is up to date.
                                Adapter "iqontrol"       is not installed.
                                Adapter "javascript"     is up to date.
                                Adapter "jeelink"        is not installed.
                                Adapter "js2fs"          is not installed.
                                Adapter "kecontact"      is not installed.
                                Adapter "klf200"         is not installed.
                                Adapter "km200"          is not installed.
                                Adapter "knmi-weather"   is not installed.
                                Adapter "knx"            is not installed.
                                Adapter "kodi"           is not installed.
                                Adapter "kress"          is not installed.
                                Adapter "lametric"       is not installed.
                                Adapter "landroid"       is not installed.
                                Adapter "lcn"            is not installed.
                                Adapter "letrika_comgw"  is not installed.
                                Adapter "lgtv"           is up to date.
                                Adapter "lgtv-rs"        is not installed.
                                Adapter "lgtv11"         is not installed.
                                Adapter "lifx"           is not installed.
                                Adapter "lightify"       is not installed.
                                Adapter "link"           is not installed.
                                Adapter "linkeddevices"  is not installed.
                                Adapter "lovelace"       is not installed.
                                Adapter "loxone"         is not installed.
                                Adapter "luftdaten"      is not installed.
                                Adapter "lupusec"        is not installed.
                                Adapter "luxtronik1"     is not installed.
                                Adapter "material"       is not installed.
                                Adapter "maxcube"        is not installed.
                                Adapter "maxcul"         is not installed.
                                Adapter "mbus"           is not installed.
                                Adapter "mclighting"     is not installed.
                                Adapter "megad"          is not installed.
                                Adapter "megadd"         is not installed.
                                Adapter "megaesp"        is not installed.
                                Adapter "mercedesme"     is not installed.
                                Adapter "mercury"        is not installed.
                                Adapter "meross"         is not installed.
                                Adapter "meteoalarm"     is not installed.
                                Adapter "miele"          is not installed.
                                Adapter "mielecloudservice" is not installed.
                                Adapter "mihome"         is not installed.
                                Adapter "mihome-airpurifier" is not installed.
                                Adapter "mihome-lamp"    is not installed.
                                Adapter "mihome-plug"    is not installed.
                                Update mihome-vacuum from @1.1.5 to @2.0.7
                                NPM version: 6.14.4
                                npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the canvas@2.6.1 install script.
                                npm ERR!     /home/iobroker/.npm/_logs/2020-05-08T10_19_53_090Z-debug.log
                                host.iobroker Cannot install iobroker.mihome-vacuum@2.0.7: 1
                                pi@iobroker:/opt/iobroker $ iobroker upgrade self
                                Controller is running. Please stop ioBroker first.
                                ^[[A^[[Api@iobroker:/opt/iobroker $ iobroker upgrade self
                                Update js-controller from @2.2.9 to @3.0.20
                                NPM version: 6.14.4
                                npm install iobroker.js-controller@3.0.20 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                                gyp ERR! not ok
                                Starting node restart.js
                                > protobufjs@6.8.9 postinstall /opt/iobroker/node_modules/protobufjs
                                > node scripts/postinstall
                                > serialport@8.0.8 postinstall /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                                > node thank-you.js
                                Thank you for using serialport!
                                If you rely on this package, please consider supporting our open collective:
                                > https://opencollective.com/serialport/donate
                                > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                                > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                prebuild-install WARN install No prebuilt binaries found (target=12.16.3 runtime=node arch=arm libc= platform=linux)
                                gyp ERR! clean error
                                gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                                npm ERR!
                                npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
                                npm ERR!     /home/pi/.npm/_logs/2020-05-08T10_25_49_001Z-debug.log
                                Fehler bleibt bestehen.
                                Eine Idee wäre noch ein Downgrade von Node.js zurück auf die 10er zu machen und schauen ob es wirklich nur die Schleife im Blockly war, die den JS Adapter zum Absturz brachte.
                                maxpd
                                • M maxpd
                                  + apt-get update
                                  OK
                                  + apt-get update
                                    rpi.gpio-common
                                  library: loaded
                                  Installed gcc-c++
                                  Autostart enabled!
                                  update done
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  NPM version: 6.14.4
                                  gyp ERR! not ok
                                  > node thank-you.js
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  #75
                                  @maxpd
                                  sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                                  Und dann nochmal versuchen.
                                    @maxpd
                                    maxpd
                                    #76
                                    @Thomas-Braun said in Javascript Adapter rot (out of memory):
                                    nochmal alles komplett versuchen?
                                    vorher auf default zurückswitchen?
                                    maxpd
                                    • M maxpd
                                      #77
                                      @maxpd Bleib mal auf 'latest'
                                      Die Pakete von gerade eben einspielen und dann nochmal
                                      iobroker update
                                      iobroker upgrade
                                      npm rebuild
                                        iobroker update
                                        iobroker upgrade
                                        npm rebuild
                                        maxpd
                                        #78
                                        @Thomas-Braun hat jetzt schon wesentlich länger gedauert. Würde auch sagen sieht gut aus, mit Ausnahme npm rebuild.
                                        update done
                                        Adapter    "admin"         : 4.1.1    , installed 4.1.1
                                        Adapter    "denon"         : 1.7.7    , installed 1.7.7
                                        Adapter    "discovery"     : 2.3.5    , installed 2.3.5
                                        Adapter    "history"       : 1.9.6    , installed 1.9.6
                                        Adapter    "hm-rega"       : 2.6.6    , installed 2.6.6
                                        Adapter    "hm-rpc"        : 1.14.2   , installed 1.14.2
                                        Adapter    "info"          : 1.7.2    , installed 1.7.2
                                        Controller "js-controller" : 3.0.20   , installed 3.0.20
                                        Adapter "admin"          is up to date.
                                        Adapter "denon"          is up to date.
                                        Adapter "discovery"      is up to date.
                                        Adapter "history"        is up to date.
                                        Adapter "hm-rega"        is up to date.
                                        Adapter "hm-rpc"         is up to date.
                                        Adapter "info"           is up to date.
                                        NPM version: 6.14.4
                                        In file included from ../src/backend/Backend.h:6,
                                                         from ../src/backend/Backend.cc:1:
                                                         from ../src/backend/ImageBackend.h:3,
                                                         from ../src/backend/ImageBackend.cc:1:
                                                         from ../src/backend/PdfBackend.h:3,
                                                         from ../src/backend/PdfBackend.cc:1:
                                                         from ../src/backend/SvgBackend.h:3,
                                                         from ../src/backend/SvgBackend.cc:1:
                                        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                                        ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                                           E(ptr - data > imgdOffset, "image data overlaps with another structure");
                                        ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                         #define E(cond, msg) if(cond) return setErr(msg)
                                        ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                                           E(ptr - data + imgdSize > len, "not enough image data");
                                                         from ../src/Backends.h:3,
                                                         from ../src/Backends.cc:1:
                                                         from ../src/Canvas.h:5,
                                                         from ../src/Canvas.cc:3:
                                        ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
                                             if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                        ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                        ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                        In file included from ../src/CanvasGradient.h:5,
                                                         from ../src/CanvasGradient.cc:3:
                                        In file included from ../src/CanvasPattern.h:6,
                                                         from ../src/CanvasPattern.cc:3:
                                                         from ../src/CanvasRenderingContext2d.h:6,
                                                         from ../src/CanvasRenderingContext2d.cc:3:
                                                         from ../src/closure.h:5,
                                                         from ../src/closure.cc:1:
                                        In file included from ../src/Image.h:8,
                                                         from ../src/Image.cc:3:
                                        In file included from ../src/ImageData.h:5,
                                                         from ../src/ImageData.cc:3:
                                                         from ../src/init.cc:17:
                                        In file included from ../../nan/nan.h:54,
                                        ../src/init.cc: At global scope:
                                        ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
                                         NODE_MODULE(canvas, init);
                                        upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                        Update "system.adapter.mihome-vacuum.0"
                                        upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                                        upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                                        upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                                        upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                                        upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                                        upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                                        upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                                        upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                        upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                        upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                        upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                        Adapter "mihome-vacuum" updated
                                        Adapter "miio"           is not installed.
                                        Adapter "mikrotik"       is not installed.
                                        Adapter "milight"        is not installed.
                                        Adapter "milight-smart-light" is not installed.
                                        Adapter "mobile"         is not installed.
                                        Adapter "modbus"         is not installed.
                                        Adapter "moma"           is not installed.
                                        Adapter "mpd"            is not installed.
                                        Adapter "mqtt"           is not installed.
                                        Adapter "mqtt-client"    is not installed.
                                        Adapter "multicast"      is not installed.
                                        Adapter "musiccast"      is not installed.
                                        Adapter "mydlink"        is not installed.
                                        Adapter "myq"            is not installed.
                                        Adapter "mysensors"      is not installed.
                                        Adapter "myvbus"         is not installed.
                                        Adapter "nanoleaf-lightpanels" is not installed.
                                        Adapter "nello"          is not installed.
                                        Adapter "netatmo"        is not installed.
                                        Adapter "nibeuplink"     is not installed.
                                        Adapter "nina"           is not installed.
                                        Adapter "node-red"       is not installed.
                                        Adapter "noolitef"       is not installed.
                                        Adapter "nuki"           is not installed.
                                        Adapter "nuki-extended"  is not installed.
                                        Adapter "nut"            is not installed.
                                        Adapter "odl"            is not installed.
                                        Adapter "oilfox"         is not installed.
                                        Adapter "onkyo"          is not installed.
                                        Adapter "onvif"          is not installed.
                                        Adapter "openhab"        is not installed.
                                        Adapter "openligadb"     is not installed.
                                        Adapter "opentherm"      is not installed.
                                        Adapter "openweathermap" is not installed.
                                        Adapter "opi"            is not installed.
                                        Adapter "oppoplayer"     is not installed.
                                        Adapter "owfs"           is not installed.
                                        Adapter "owntracks"      is not installed.
                                        Adapter "panasonic-viera" is not installed.
                                        Adapter "parser"         is not installed.
                                        Adapter "paw"            is not installed.
                                        Adapter "phantomjs"      is not installed.
                                        Adapter "pi-hole"        is not installed.
                                        Adapter "piface"         is not installed.
                                        Adapter "pimatic"        is not installed.
                                        Update ping from @1.3.2 to @1.4.7
                                        NPM version: 6.14.4
                                        npm install iobroker.ping@1.4.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                        Update "system.adapter.ping.0"
                                        upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                        upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html
                                        upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
                                        Adapter "ping" updated
                                        Adapter "places"         is not installed.
                                        Adapter "plenticore"     is not installed.
                                        Adapter "plex"           is not installed.
                                        Adapter "plexconnect"    is not installed.
                                        Adapter "pollenflug"     is not installed.
                                        Adapter "primelab"       is not installed.
                                        Adapter "proxmox"        is not installed.
                                        Adapter "proxy"          is not installed.
                                        Adapter "pushbullet"     is not installed.
                                        Adapter "pushover"       is not installed.
                                        Adapter "pushsafer"      is not installed.
                                        Adapter "radar2"         is not installed.
                                        Adapter "radiohead"      is not installed.
                                        Adapter "rainbird"       is not installed.
                                        Adapter "rflink"         is not installed.
                                        Adapter "rickshaw"       is not installed.
                                        Adapter "ring"           is not installed.
                                        Adapter "roadtraffic"    is not installed.
                                        Adapter "robonect"       is not installed.
                                        Adapter "roomba"         is not installed.
                                        Adapter "rpi2"           is not installed.
                                        Adapter "rssfeed"        is not installed.
                                        Adapter "s7"             is not installed.
                                        Adapter "samsung"        is not installed.
                                        Adapter "sanext"         is not installed.
                                        Adapter "sayit"          is up to date.
                                        Adapter "sbfspot"        is not installed.
                                        Adapter "scenes"         is not installed.
                                        Adapter "schoolfree"     is not installed.
                                        Adapter "senec"          is not installed.
                                        Update shelly from @3.1.6 to @3.2.7
                                        NPM version: 6.14.4
                                        npm install iobroker.shelly@3.2.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                                        Update "system.adapter.shelly.0"
                                        upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                                        upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                                        Adapter "shelly" updated
                                        Update shuttercontrol from @0.4.3 to @0.5.0
                                        host.iobroker Adapter "system.adapter.shuttercontrol.0" is stopped.
                                        NPM version: 6.14.4
                                        npm install iobroker.shuttercontrol@0.5.0 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                        Update "system.adapter.shuttercontrol.0"
                                        upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                        upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                        upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                        Adapter "shuttercontrol" updated
                                        host.iobroker Adapter "system.adapter.shuttercontrol.0" is started
                                        Adapter "sia"            is not installed.
                                        Adapter "siegenia"       is not installed.
                                        Adapter "simple-api"     is up to date.
                                        Adapter "sma-em"         is not installed.
                                        Adapter "smappee"        is not installed.
                                        Adapter "smartmeter"     is not installed.
                                        Adapter "snips"          is not installed.
                                        Adapter "snmp"           is not installed.
                                        Update socketio from @3.0.6 to @3.0.7
                                        NPM version: 6.14.4
                                        npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                                        upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                        upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                                        upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                                        Adapter "socketio" updated
                                        Adapter "solarlog"       is not installed.
                                        Adapter "solarviewdatareader" is not installed.
                                        Adapter "solarwetter"    is not installed.
                                        Adapter "sonnen"         is not installed.
                                        Adapter "sonoff"         is up to date.
                                        Adapter "sonos"          is not installed.
                                        Adapter "sonus"          is not installed.
                                        Adapter "sony-bravia"    is not installed.
                                        Adapter "sourceanalytix" is not installed.
                                        Adapter "spotify-premium" is not installed.
                                        Adapter "sql"            is not installed.
                                        Adapter "squeezebox"     is not installed.
                                        Adapter "squeezeboxrpc"  is not installed.
                                        Adapter "starline"       is not installed.
                                        Adapter "statistics"     is not installed.
                                        Adapter "stiebel-isg"    is not installed.
                                        Adapter "stockmarket"    is not installed.
                                        Adapter "sunnyportal"    is not installed.
                                        Adapter "swiss-weather-api" is not installed.
                                        Adapter "synology"       is not installed.
                                        Adapter "systeminfo"     is not installed.
                                        Adapter "tado"           is not installed.
                                        Adapter "tahoma"         is not installed.
                                        Adapter "tankerkoenig"   is not installed.
                                        Update telegram from @1.4.3 to @1.5.9
                                        host.iobroker Adapter "system.adapter.telegram.1" is stopped.
                                        host.iobroker Adapter "system.adapter.telegram.2" is stopped.
                                        NPM version: 6.14.4
                                        npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                        Update "system.adapter.telegram.0"
                                        Update "system.adapter.telegram.1"
                                        Update "system.adapter.telegram.2"
                                        upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                        upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                                        upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                                        upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                                        upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                        Adapter "telegram" updated
                                        host.iobroker Adapter "system.adapter.telegram.1" is started
                                        host.iobroker Adapter "system.adapter.telegram.2" is started
                                        Adapter "terminal"       is up to date.
                                        Adapter "tesla-motors"   is not installed.
                                        Adapter "text2command"   is up to date.
                                        Adapter "tileboard"      is not installed.
                                        Adapter "tinker"         is not installed.
                                        Adapter "tino"           is not installed.
                                        Adapter "tinyrx4"        is not installed.
                                        Update tr-064 from @0.4.18 to @4.0.1
                                        NPM version: 6.14.4
                                        npm install iobroker.tr-064@4.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                        Update "system.adapter.tr-064.0"
                                        upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                        upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                        Adapter "tr-064" updated
                                        Adapter "tradfri"        is not installed.
                                        Adapter "trashschedule"  is not installed.
                                        Adapter "tunnelbroker-endpoint-updater" is not installed.
                                        Adapter "tuya"           is not installed.
                                        Adapter "tvspielfilm"    is not installed.
                                        Adapter "unifi"          is not installed.
                                        Adapter "unifi-protect"  is not installed.
                                        Adapter "upnp"           is not installed.
                                        Adapter "vaillant"       is not installed.
                                        Adapter "valloxmv"       is not installed.
                                        Adapter "vcard"          is not installed.
                                        Adapter "vedirect"       is not installed.
                                        Adapter "velux"          is not installed.
                                        Adapter "viessmann"      is not installed.
                                        Adapter "viessmannapi"   is not installed.
                                        Adapter "virtualpowermeter" is not installed.
                                        Adapter "vis"            is not installed.
                                        Adapter "vis-bars"       is not installed.
                                        Adapter "vis-canvas-gauges" is not installed.
                                        Adapter "vis-colorpicker" is not installed.
                                        Adapter "vis-fancyswitch" is not installed.
                                        Adapter "vis-google-fonts" is not installed.
                                        Adapter "vis-history"    is not installed.
                                        Adapter "vis-hqwidgets"  is not installed.
                                        Adapter "vis-inventwo"   is not installed.
                                        Adapter "vis-jqui-mfd"   is not installed.
                                        Adapter "vis-justgage"   is not installed.
                                        Adapter "vis-keyboard"   is not installed.
                                        Adapter "vis-lcars"      is not installed.
                                        Adapter "vis-map"        is not installed.
                                        Adapter "vis-material"   is not installed.
                                        Adapter "vis-material-webfont" is not installed.
                                        Adapter "vis-materialdesign" is not installed.
                                        Adapter "vis-metro"      is not installed.
                                        Adapter "vis-players"    is not installed.
                                        Adapter "vis-plumb"      is not installed.
                                        Adapter "vis-rgraph"     is not installed.
                                        Adapter "vis-timeandweather" is not installed.
                                        Adapter "vis-weather"    is not installed.
                                        Adapter "vodafone-speedtest" is not installed.
                                        Adapter "volvo"          is not installed.
                                        Adapter "vr200"          is not installed.
                                        Adapter "vw-connect"     is not installed.
                                        Adapter "weatherunderground" is not installed.
                                        Update web from @3.0.7 to @3.0.8
                                        host.iobroker Adapter "system.adapter.web.0" is stopped.
                                        NPM version: 6.14.4
                                        npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                                        upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                                        upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                        upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                        upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                                        upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                                        upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                                        upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                                        upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                                        upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                                        upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                                        upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                                        upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                                        upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                                        upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                                        upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                                        upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                                        upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                                        upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                                        upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                                        upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                                        upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                        upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                        upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                        upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                        upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                        upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                        upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                        upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                        upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                        upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                        upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                        upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                        upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                        upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                        upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                        upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                        upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                        upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                        Update "system.adapter.web.0"
                                        Adapter "web" updated
                                        host.iobroker Adapter "system.adapter.web.0" is started
                                        Adapter "web-speedy"     is not installed.
                                        Adapter "weishaupt-wem"  is not installed.
                                        Adapter "wiffi-wz"       is not installed.
                                        Adapter "wifilight"      is up to date.
                                        Adapter "windows-control" is not installed.
                                        Adapter "wlanthermo-nano" is not installed.
                                        Adapter "wled"           is not installed.
                                        Adapter "wm-bus"         is not installed.
                                        Adapter "wolf"           is not installed.
                                        Adapter "worx"           is not installed.
                                        Adapter "xbox"           is not installed.
                                        Adapter "xs1"            is not installed.
                                        Adapter "yahka"          is not installed.
                                        Adapter "yamaha"         is not installed.
                                        Adapter "yeelight-2"     is up to date.
                                        Adapter "youtube"        is not installed.
                                        Adapter "yr"             is not installed.
                                        Update zigbee from @1.0.4 to @1.1.1
                                        host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
                                        NPM version: 6.14.4
                                        npm install iobroker.zigbee@1.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                        Update "system.adapter.zigbee.0"
                                        upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                        upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
                                        upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                                        upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/jiawen.png img/jiawen.png image/png
                                        upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/iluminize_511_040.png img/iluminize_511_040.png image/png
                                        upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
                                        upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
                                        upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
                                        upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_MS01.png img/ewelink_MS01.png image/png
                                        upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                                        upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                                        upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                                        upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
                                        upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                                        upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
                                        upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0218.png img/TS0218.png image/png
                                        upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0215.png img/TS0215.png image/png
                                        upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTW017.png img/LTW017.png image/png
                                        upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC015.png img/LTC015.png image/png
                                        upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC014.png img/LTC014.png image/png
                                        upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
                                        upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                                        upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                        upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                        upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                        upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                                        upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                                        upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                        upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                        upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                        upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                        Adapter "zigbee" updated
                                        host.iobroker Adapter "system.adapter.zigbee.0" is started
                                        Adapter "zoneminder"     is not installed.
                                        Adapter "zont"           is not installed.
                                        Adapter "zwave"          is not installed.
                                        Adapter "zwave2"         is not installed.
                                        Host    "iobroker"       is up to date.
                                        pi@iobroker:/opt/iobroker $ npm rebuild
                                        > node thank-you.js
                                        gyp ERR! not ok
                                        npm ERR! errno 1
                                        npm ERR!
                                        npm ERR!     /home/pi/.npm/_logs/2020-05-08T11_11_28_882Z-debug.log
                                        maxpd
                                        • M maxpd
                                          pi@iobroker:/opt/iobroker $ iobroker update
                                          Used repository: latest
                                          hash unchanged, use cached sources
                                          update done
                                          Adapter    "accuweather"   : 1.1.3
                                          Adapter    "alarm"         : 0.3.0
                                          Adapter    "alexa2"        : 3.1.2
                                          Adapter    "alpha2"        : 1.0.0
                                          Adapter    "amazon-dash"   : 1.1.0
                                          Adapter    "artnet"        : 1.2.2
                                          Adapter    "asterisk"      : 1.0.6
                                          Adapter    "asuswrt"       : 1.0.1
                                          Adapter    "b-control-em"  : 0.2.1
                                          Adapter    "backitup"      : 1.5.6
                                          Adapter    "beckhoff"      : 1.2.1
                                          Adapter    "benq"          : 0.2.2
                                          Adapter    "binance"       : 1.1.2
                                          Adapter    "ble"           : 0.11.6
                                          Adapter    "blink4home"    : 0.1.1
                                          Adapter    "bmw"           : 1.4.0
                                          Adapter    "boblight"      : 0.0.1
                                          Adapter    "bosesoundtouch": 0.9.2
                                          Adapter    "botvac"        : 1.0.0
                                          Adapter    "bring"         : 1.7.2
                                          Adapter    "broadlink2"    : 2.0.3
                                          Adapter    "bsblan"        : 0.0.6
                                          Adapter    "bshb"          : 0.1.10
                                          Adapter    "calendar"      : 1.2.0
                                          Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                                          Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                                          Adapter    "comfoair"      : 1.1.1
                                          Adapter    "contact"       : 1.1.3
                                          Adapter    "contactid"     : 1.0.0
                                          Adapter    "coronavirus-statistics": 0.5.9
                                          Adapter    "corrently"     : 0.0.2
                                          Adapter    "countdown"     : 1.1.0
                                          Adapter    "cul"           : 1.2.1
                                          Adapter    "daikin"        : 1.0.5
                                          Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                                          Adapter    "deconz"        : 1.3.7
                                          Adapter    "devices"       : 0.3.6
                                          Adapter    "digitalstrom"  : 2.0.5
                                          Adapter    "discovergy"    : 0.5.4
                                          Adapter    "doorbird"      : 0.1.5
                                          Adapter    "ds18b20"       : 1.1.4
                                          Adapter    "dwd"           : 2.4.8
                                          Adapter    "ebus"          : 2.0.0
                                          Adapter    "ecovacs-deebot": 0.5.8
                                          Adapter    "egigeozone"    : 0.1.2
                                          Adapter    "ekey"          : 1.1.0
                                          Adapter    "email"         : 1.0.6
                                          Adapter    "emby"          : 1.0.2
                                          Adapter    "energymanager" : 1.2.2
                                          Adapter    "enet"          : 1.0.1
                                          Adapter    "epson_stylus_px830": 0.2.1
                                          Adapter    "exchangerates" : 0.0.12
                                          Adapter    "fakeroku"      : 0.2.1
                                          Adapter    "fb-checkpresence": 1.0.1
                                          Adapter    "feiertage"     : 1.0.19
                                          Adapter    "fhem"          : 1.4.1
                                          Adapter    "find-my-iphone": 0.2.17
                                          Adapter    "firetv"        : 1.0.0
                                          Adapter    "fitbit-api"    : 0.1.1
                                          Adapter    "flot"          : 1.9.2
                                          Adapter    "foobar2000"    : 1.0.0
                                          Adapter    "fritzbox"      : 0.2.1
                                          Adapter    "fritzdect"     : 0.3.2
                                          Adapter    "fronius"       : 1.0.5
                                          Adapter    "fullcalendar"  : 1.1.0
                                          Adapter    "fullybrowser"  : 1.0.3
                                          Adapter    "g-homa"        : 0.5.1
                                          Adapter    "geofency"      : 0.3.2
                                          Adapter    "gruenbeck"     : 0.0.18
                                          Adapter    "habpanel"      : 0.4.1
                                          Adapter    "haier"         : 1.0.3
                                          Adapter    "ham"           : 1.1.2
                                          Adapter    "ham-wemo"      : 1.0.1
                                          Adapter    "harmony"       : 1.2.2
                                          Adapter    "hass-mqtt"     : 0.0.7
                                          Adapter    "heatingcontrol": 0.5.0
                                          Adapter    "heytech"       : 0.2.0
                                          Adapter    "hid"           : 0.1.17
                                          Adapter    "hilink"        : 0.2.7
                                          Adapter    "hmip"          : 0.0.11
                                          Adapter    "hombot"        : 0.1.3
                                          Adapter    "homeconnect"   : 0.0.26
                                          Adapter    "homee"         : 1.0.5
                                          Adapter    "homepilot"     : 1.1.4
                                          Adapter    "hp-ilo"        : 1.0.5
                                          Adapter    "hs100"         : 1.1.2
                                          Adapter    "hue"           : 3.2.8
                                          Adapter    "hue-extended"  : 1.3.2
                                          Adapter    "hyperion"      : 0.0.9
                                          Adapter    "i2c"           : 0.0.6
                                          Adapter    "ical"          : 1.7.0
                                          Adapter    "icons-addictive-flavour-png": 0.1.0
                                          Adapter    "icons-fatcow-hosting": 0.1.0
                                          Adapter    "icons-icons8"  : 0.0.1
                                          Adapter    "icons-material-png": 0.1.0
                                          Adapter    "icons-material-svg": 0.1.0
                                          Adapter    "icons-mfd-png" : 1.0.2
                                          Adapter    "icons-mfd-svg" : 1.0.2
                                          Adapter    "icons-open-icon-library-png": 0.1.2
                                          Adapter    "icons-ultimate-png": 1.0.1
                                          Adapter    "influxdb"      : 1.8.4
                                          Adapter    "innogy-smarthome": 0.3.4
                                          Adapter    "intesishome"   : 0.1.2
                                          Adapter    "iogo"          : 0.5.10
                                          Adapter    "iot"           : 1.4.14   , installed 1.4.14
                                          Adapter    "iqontrol"      : 0.3.7
                                          Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                                          Adapter    "jeelink"       : 0.1.3
                                          Adapter    "js2fs"         : 0.1.5
                                          Adapter    "kecontact"     : 0.1.0
                                          Adapter    "klf200"        : 0.9.5
                                          Adapter    "km200"         : 2.0.3
                                          Adapter    "knmi-weather"  : 0.2.0
                                          Adapter    "knx"           : 1.0.41
                                          Adapter    "kodi"          : 2.0.2
                                          Adapter    "kress"         : 2.5.5
                                          Adapter    "lametric"      : 0.0.7
                                          Adapter    "landroid"      : 1.0.3
                                          Adapter    "lcn"           : 0.6.3
                                          Adapter    "letrika_comgw" : 0.0.5
                                          Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                                          Adapter    "lgtv-rs"       : 0.1.0
                                          Adapter    "lgtv11"        : 1.0.5
                                          Adapter    "lifx"          : 0.1.1
                                          Adapter    "lightify"      : 0.2.16
                                          Adapter    "link"          : 0.5.9
                                          Adapter    "linkeddevices" : 1.1.4
                                          Adapter    "lovelace"      : 1.0.16
                                          Adapter    "loxone"        : 1.0.0
                                          Adapter    "luftdaten"     : 0.0.11
                                          Adapter    "lupusec"       : 1.2.6
                                          Adapter    "luxtronik1"    : 0.2.3
                                          Adapter    "material"      : 0.13.8
                                          Adapter    "maxcube"       : 0.1.2
                                          Adapter    "maxcul"        : 1.1.2
                                          Adapter    "mbus"          : 2.2.0
                                          Adapter    "mclighting"    : 0.1.1
                                          Adapter    "megad"         : 1.2.1
                                          Adapter    "megadd"        : 0.2.0
                                          Adapter    "megaesp"       : 0.1.0
                                          Adapter    "mercedesme"    : 0.0.21
                                          Adapter    "mercury"       : 0.1.1
                                          Adapter    "meross"        : 1.3.13
                                          Adapter    "meteoalarm"    : 1.1.0
                                          Adapter    "miele"         : 0.1.5
                                          Adapter    "mielecloudservice": 1.2.1
                                          Adapter    "mihome"        : 1.3.0
                                          Adapter    "mihome-airpurifier": 0.1.7
                                          Adapter    "mihome-lamp"   : 1.1.0
                                          Adapter    "mihome-plug"   : 0.2.1
                                          Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                                          Adapter    "miio"          : 0.0.13
                                          Adapter    "mikrotik"      : 1.0.12
                                          Adapter    "milight"       : 0.3.6
                                          Adapter    "milight-smart-light": 0.4.1
                                          Adapter    "mobile"        : 0.5.0
                                          Adapter    "modbus"        : 3.0.0
                                          Adapter    "moma"          : 1.2.6
                                          Adapter    "mpd"           : 1.0.5
                                          Adapter    "mqtt"          : 2.1.1
                                          Adapter    "mqtt-client"   : 1.3.1
                                          Adapter    "multicast"     : 0.1.5
                                          Adapter    "musiccast"     : 0.1.3
                                          Adapter    "mydlink"       : 1.0.9
                                          Adapter    "myq"           : 0.1.1
                                          Adapter    "mysensors"     : 2.0.0
                                          Adapter    "myvbus"        : 0.0.4
                                          Adapter    "nanoleaf-lightpanels": 0.8.2
                                          Adapter    "nello"         : 2.0.8
                                          Adapter    "netatmo"       : 1.3.1
                                          Adapter    "nibeuplink"    : 0.3.0
                                          Adapter    "nina"          : 0.0.23
                                          Adapter    "node-red"      : 1.17.2
                                          Adapter    "noolitef"      : 0.0.2
                                          Adapter    "nuki"          : 1.2.3
                                          Adapter    "nuki-extended" : 2.2.5
                                          Adapter    "nut"           : 1.1.3
                                          Adapter    "odl"           : 1.0.5
                                          Adapter    "oilfox"        : 2.1.0
                                          Adapter    "onkyo"         : 2.0.3
                                          Adapter    "onvif"         : 0.4.2
                                          Adapter    "openhab"       : 1.1.0
                                          Adapter    "openligadb"    : 1.1.0
                                          Adapter    "opentherm"     : 0.1.9
                                          Adapter    "openweathermap": 0.1.0
                                          Adapter    "opi"           : 0.1.1
                                          Adapter    "oppoplayer"    : 0.2.1
                                          Adapter    "owfs"          : 0.6.4
                                          Adapter    "owntracks"     : 0.6.2
                                          Adapter    "panasonic-viera": 1.0.2
                                          Adapter    "parser"        : 1.0.7
                                          Adapter    "paw"           : 0.3.2
                                          Adapter    "phantomjs"     : 1.0.1
                                          Adapter    "pi-hole"       : 1.2.3
                                          Adapter    "piface"        : 1.0.0
                                          Adapter    "pimatic"       : 0.2.1
                                          Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                                          Adapter    "places"        : 0.7.0
                                          Adapter    "plenticore"    : 2.1.3
                                          Adapter    "plex"          : 0.8.11
                                          Adapter    "plexconnect"   : 0.0.7
                                          Adapter    "pollenflug"    : 1.0.6
                                          Adapter    "primelab"      : 1.0.2
                                          Adapter    "proxmox"       : 1.0.2
                                          Adapter    "proxy"         : 1.2.1
                                          Adapter    "pushbullet"    : 0.0.11
                                          Adapter    "pushover"      : 2.0.2
                                          Adapter    "pushsafer"     : 0.1.8
                                          Adapter    "radar2"        : 1.2.5
                                          Adapter    "radiohead"     : 1.0.5
                                          Adapter    "rainbird"      : 0.2.2
                                          Adapter    "rflink"        : 2.1.5
                                          Adapter    "rickshaw"      : 1.0.0
                                          Adapter    "ring"          : 1.1.2
                                          Adapter    "roadtraffic"   : 0.2.0
                                          Adapter    "robonect"      : 0.1.3
                                          Adapter    "roomba"        : 1.1.1
                                          Adapter    "rpi2"          : 1.2.0
                                          Adapter    "rssfeed"       : 0.0.28
                                          Adapter    "s7"            : 1.1.8
                                          Adapter    "samsung"       : 0.2.9
                                          Adapter    "sanext"        : 0.0.4
                                          Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                                          Adapter    "sbfspot"       : 3.0.0
                                          Adapter    "scenes"        : 1.1.0
                                          Adapter    "schoolfree"    : 0.6.0
                                          Adapter    "senec"         : 1.0.8
                                          Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                                          Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                                          Adapter    "sia"           : 1.0.4
                                          Adapter    "siegenia"      : 1.0.0
                                          Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                                          Adapter    "sma-em"        : 0.5.7
                                          Adapter    "smappee"       : 0.2.2
                                          Adapter    "smartmeter"    : 3.1.2
                                          Adapter    "snips"         : 1.5.0
                                          Adapter    "snmp"          : 0.5.0
                                          Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                                          Adapter    "solarlog"      : 2.0.0
                                          Adapter    "solarviewdatareader": 0.2.0
                                          Adapter    "solarwetter"   : 1.0.0
                                          Adapter    "sonnen"        : 1.5.0
                                          Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                                          Adapter    "sonos"         : 2.0.1
                                          Adapter    "sonus"         : 0.1.1
                                          Adapter    "sony-bravia"   : 1.0.1
                                          Adapter    "sourceanalytix": 0.4.2
                                          Adapter    "spotify-premium": 1.0.0
                                          Adapter    "sql"           : 1.12.5
                                          Adapter    "squeezebox"    : 1.0.0
                                          Adapter    "squeezeboxrpc" : 1.0.1
                                          Adapter    "starline"      : 1.0.0
                                          Adapter    "statistics"    : 0.2.2
                                          Adapter    "stiebel-isg"   : 1.4.11
                                          Adapter    "stockmarket"   : 0.0.2
                                          Adapter    "sunnyportal"   : 0.1.5
                                          Adapter    "swiss-weather-api": 0.2.0
                                          Adapter    "synology"      : 0.1.7
                                          Adapter    "systeminfo"    : 0.3.1
                                          Adapter    "tado"          : 0.1.9
                                          Adapter    "tahoma"        : 0.3.3
                                          Adapter    "tankerkoenig"  : 2.0.9
                                          Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                                          Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                          Adapter    "tesla-motors"  : 0.2.3
                                          Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                                          Adapter    "tileboard"     : 0.1.1
                                          Adapter    "tinker"        : 1.1.0
                                          Adapter    "tino"          : 0.1.3
                                          Adapter    "tinyrx4"       : 0.1.5
                                          Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                                          Adapter    "tradfri"       : 2.6.2
                                          Adapter    "trashschedule" : 0.0.5
                                          Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                          Adapter    "tuya"          : 3.2.3
                                          Adapter    "tvspielfilm"   : 2.0.1
                                          Adapter    "unifi"         : 0.4.3
                                          Adapter    "unifi-protect" : 0.0.11
                                          Adapter    "upnp"          : 1.0.16
                                          Adapter    "vaillant"      : 0.0.10
                                          Adapter    "valloxmv"      : 1.0.3
                                          Adapter    "vcard"         : 0.0.9
                                          Adapter    "vedirect"      : 0.1.0
                                          Adapter    "velux"         : 0.0.5
                                          Adapter    "viessmann"     : 1.2.4
                                          Adapter    "viessmannapi"  : 1.3.2
                                          Adapter    "virtualpowermeter": 1.2.1
                                          Adapter    "vis"           : 1.2.6
                                          Adapter    "vis-bars"      : 0.1.4
                                          Adapter    "vis-canvas-gauges": 0.1.5
                                          Adapter    "vis-colorpicker": 1.2.0
                                          Adapter    "vis-fancyswitch": 1.1.0
                                          Adapter    "vis-google-fonts": 0.1.0
                                          Adapter    "vis-history"   : 1.0.0
                                          Adapter    "vis-hqwidgets" : 1.1.4
                                          Adapter    "vis-inventwo"  : 1.3.3
                                          Adapter    "vis-jqui-mfd"  : 1.0.12
                                          Adapter    "vis-justgage"  : 1.0.2
                                          Adapter    "vis-keyboard"  : 0.0.2
                                          Adapter    "vis-lcars"     : 1.0.4
                                          Adapter    "vis-map"       : 1.0.4
                                          Adapter    "vis-material"  : 0.1.3
                                          Adapter    "vis-material-webfont": 0.0.3
                                          Adapter    "vis-materialdesign": 0.3.6
                                          Adapter    "vis-metro"     : 1.1.2
                                          Adapter    "vis-players"   : 0.1.6
                                          Adapter    "vis-plumb"     : 1.0.2
                                          Adapter    "vis-rgraph"    : 0.0.2
                                          Adapter    "vis-timeandweather": 1.1.7
                                          Adapter    "vis-weather"   : 2.5.2
                                          Adapter    "vodafone-speedtest": 0.0.4
                                          Adapter    "volvo"         : 0.0.2
                                          Adapter    "vr200"         : 1.0.0
                                          Adapter    "vw-connect"    : 0.0.11
                                          Adapter    "weatherunderground": 3.2.1
                                          Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                                          Adapter    "web-speedy"    : 0.2.0
                                          Adapter    "weishaupt-wem" : 0.0.8
                                          Adapter    "wiffi-wz"      : 2.2.0
                                          Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                                          Adapter    "windows-control": 0.1.3
                                          Adapter    "wlanthermo-nano": 0.1.1
                                          Adapter    "wled"          : 0.5.0
                                          Adapter    "wm-bus"        : 0.3.1
                                          Adapter    "wolf"          : 1.2.0
                                          Adapter    "worx"          : 1.0.2
                                          Adapter    "xbox"          : 0.6.3
                                          Adapter    "xs1"           : 1.0.2
                                          Adapter    "yahka"         : 0.11.0
                                          Adapter    "yamaha"        : 0.3.19
                                          Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                                          Adapter    "youtube"       : 0.0.8
                                          Adapter    "yr"            : 2.0.3
                                          Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                                          Adapter    "zoneminder"    : 0.3.3
                                          Adapter    "zont"          : 0.5.4
                                          Adapter    "zwave"         : 2.0.1
                                          Adapter    "zwave2"        : 0.11.7
                                          Adapter "accuweather"    is not installed.
                                          Adapter "alarm"          is not installed.
                                          Adapter "alexa2"         is not installed.
                                          Adapter "alpha2"         is not installed.
                                          Adapter "amazon-dash"    is not installed.
                                          Adapter "artnet"         is not installed.
                                          Adapter "asterisk"       is not installed.
                                          Adapter "asuswrt"        is not installed.
                                          Adapter "b-control-em"   is not installed.
                                          Adapter "backitup"       is not installed.
                                          Adapter "beckhoff"       is not installed.
                                          Adapter "benq"           is not installed.
                                          Adapter "binance"        is not installed.
                                          Adapter "ble"            is not installed.
                                          Adapter "blink4home"     is not installed.
                                          Adapter "bmw"            is not installed.
                                          Adapter "boblight"       is not installed.
                                          Adapter "bosesoundtouch" is not installed.
                                          Adapter "botvac"         is not installed.
                                          Adapter "bring"          is not installed.
                                          Adapter "broadlink2"     is not installed.
                                          Adapter "bsblan"         is not installed.
                                          Adapter "bshb"           is not installed.
                                          Adapter "calendar"       is not installed.
                                          Adapter "chromecast"     is up to date.
                                          Adapter "cloud"          is up to date.
                                          Adapter "comfoair"       is not installed.
                                          Adapter "contact"        is not installed.
                                          Adapter "contactid"      is not installed.
                                          Adapter "coronavirus-statistics" is not installed.
                                          Adapter "corrently"      is not installed.
                                          Adapter "countdown"      is not installed.
                                          Adapter "cul"            is not installed.
                                          Adapter "daikin"         is not installed.
                                          Adapter "daswetter"      is up to date.
                                          Adapter "deconz"         is not installed.
                                          Adapter "devices"        is not installed.
                                          Adapter "digitalstrom"   is not installed.
                                          Adapter "discovergy"     is not installed.
                                          NPM version: 6.14.4
                                          ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                          ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          NPM version: 6.14.4
                                          > node thank-you.js
                                          gyp ERR! System Linux 4.19.97-v7l+
                                          gyp ERR! node -v v12.16.3
                                          gyp ERR! node-gyp -v v5.1.0
                                          gyp ERR! not ok
                                          npm ERR! errno 1
                                          npm ERR!
                                          #79
                                          @maxpd
                                          Und? Läuft zigbee nun?
