  4. Javascript Adapter rot (out of memory)
javascript
82 Beiträge 6 Kommentatoren 12.2k Aufrufe 5 Beobachtet
  • M maxpd
    @Thomas-Braun da waren wir gestern schonmal. Den Befehl gibt es nicht.
    pi@iobroker:/opt/iobroker $ rebuild iobroker.zigbee --install
    -bash: rebuild: Kommando nicht gefunden.
    pi@iobroker:/opt/iobroker $ iobroker rebuild iobroker.zigbee --install
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start
    iobroker stop
    iobroker start <adapter>
    iobroker stop <adapter>
    iobroker start all
    iobroker restart
    iobroker restart <adapter>
    iobroker info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter>
    iobroker url <url> [<name>]
    iobroker del <adapter>
    iobroker del <adapter>.<instance>
    iobroker update [repository url] [--updatable/--u] [--installed/--i]
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url]
    iobroker upgrade <adapter> [repository url]
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all
    iobroker upload <adapter>
    iobroker object get <id>
    iobroker object set <id> <json-value>
    iobroker object set <id> propertyname=value
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id>
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instanceid] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path>
    iobroker validate <backup name or path>
    iobroker <command> --timeout 5000
    iobroker status [all]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status
    iobroker compact <enable|on|disable|off>
    iobroker compact <adapter>.<instance> status
    iobroker compact <adapter>.<instance> group <group-id>
    iobroker compact <adapter>.<instance> <disable|off>
    iobroker compact <adapter>.<instance> <enable|on> [group-id]
    iobroker version [adapter]
    iobroker [adapter] -v
    Options:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    nach dem Binding rebuild habe ich weiterhin den gleichen Fehler.
    @maxpd
    Dann über npm.
    npm rebuild iobroker.zigbee
      @maxpd
      Dann über npm.
      maxpd
      @Thomas-Braun
      funktioniert auch nicht.
      pi@iobroker:/opt/iobroker $ npm rebuild iobroker.zigbee
      iobroker.zigbee@1.0.4 /opt/iobroker/node_modules/iobroker.zigbee
      anschließend auch bindings gesetzt. Fehler bleibt gleich 😵
      maxpd
      • M maxpd
        @Thomas-Braun
        #66
        @maxpd Mehr kommt da nicht an Ausgabe?
          maxpd
          #67
          @Thomas-Braun nein, das war alles
          maxpd
          • M maxpd
            #68
            @maxpd
            iobroker list instances
              @maxpd
              maxpd
              #69
              @Thomas-Braun
              pi@iobroker:/opt/iobroker $ iobroker list instances
              + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.chromecast.0            : chromecast            - disabled
              + system.adapter.cloud.0                 : cloud                 -  enabled
                system.adapter.daswetter.0             : daswetter             -  enabled
              + system.adapter.denon.0                 : denon                 -  enabled
              + system.adapter.discovery.0             : discovery             -  enabled
              + system.adapter.google-sharedlocations.0: google-sharedlocations -  enabled
                system.adapter.history.0               : history               - disabled
              + system.adapter.hm-rega.0               : hm-rega               -  enabled
              + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
              + system.adapter.info.0                  : info                  -  enabled
                system.adapter.iot.0                   : iot                   - disabled
              + system.adapter.javascript.0            : javascript            -  enabled
              + system.adapter.lgtv.0                  : lgtv                  -  enabled
              + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
                system.adapter.ping.0                  : ping                  - disabled
              + system.adapter.sayit.0                 : sayit                 -  enabled, port: 0
                system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.shuttercontrol.0        : shuttercontrol        -  enabled
              + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.1              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.telegram.2              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.text2command.0          : text2command          -  enabled
                system.adapter.tr-064.0                : tr-064                - disabled
              + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.wifilight.0             : wifilight             -  enabled
              + system.adapter.yeelight-2.0            : yeelight-2            -  enabled
                system.adapter.zigbee.0                : zigbee                -  enabled
              + instance is alive
              maxpd
              • M maxpd
                @Thomas-Braun
                + instance is alive
                #70
                @maxpd Keine Ahnung...
                Vielleicht ziehst du das gesamte System auf 'latest' und node12?
                  maxpd
                  #71
                  @Thomas-Braun Versuchen kann ichs. Mit welchen Befehlen?
                  maxpd
                  • M maxpd
                    #72
                    @maxpd
                    iobroker stop
                    iobroker fix
                    iobroker start
                    Dann im Admin beim 'Schraubenschlüssel' - 'Haupteinstellungen' auf 'latest' stellen.
                    iobroker update
                    iobroker upgrade
                    Dann in /opt/iobroker
                    npm rebuild
                    iobroker start
                    Das müsste es gewesen sein...
                    • Thomas BraunT Online
                      #73
                      Vorher vielleicht auch noch node12 installieren:
                      curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                      sudo apt update
                      sudo apt dist-upgrade
                        maxpd
                        schrieb am zuletzt editiert von maxpd
                        #74
                        puuuhhh durchsäht von fehlern
                        pi@iobroker:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_12.x | sud                                                             o -E bash -
                        ## Installing the NodeSource Node.js 12.x repo...
                        ## Populating apt-get cache...
                        + apt-get update
                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                        Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                        Holen:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,                                                             0 MB]
                        OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                        OK:5 https://www.pivccu.de/piVCCU stable InRelease
                        Es wurden 13,0 MB in 1 min 6 s geholt (198 kB/s).
                        ## Confirming "buster" is supported...
                        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Rele                                                             ase'
                        ## Adding the NodeSource signing key to your keyring...
                        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                        OK
                        ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                        + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources                                                             .list.d/nodesource.list
                        + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/so                                                             urces.list.d/nodesource.list
                        ## Running `apt-get update` for you...
                        + apt-get update
                        OK:1 https://deb.nodesource.com/node_12.x buster InRelease
                        OK:2 https://www.pivccu.de/piVCCU stable InRelease
                        OK:3 http://archive.raspberrypi.org/debian buster InRelease
                        OK:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                        ## You may also need development tools to build native addons:
                             sudo apt-get install gcc g++ make
                        ## To install the Yarn package manager, run:
                             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                             echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/s                                                             ources.list.d/yarn.list
                             sudo apt-get update && sudo apt-get install yarn
                        pi@iobroker:/opt/iobroker $ sudo apt update
                        OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                        Fehl:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut werden (2a00:1                                                             098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreichbar) Verbin                                                             dung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (93.93.128.19                                                             3), Zeitüberschreitung aufgetreten
                        Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u                                                             m sie anzuzeigen.
                        W: Fehlschlag beim Holen von http://raspbian.raspberrypi.org/raspbian/dists/bust                                                             er/InRelease Verbindung mit raspbian.raspberrypi.org:80 kann nicht aufgebaut wer                                                             den (2a00:1098:0:80:1000:75:0:3). - connect (101: Das Netzwerk ist nicht erreich                                                             bar) Verbindung mit raspbian.raspberrypi.org:80 konnte nicht aufgebaut werden (9                                                             3.93.128.193), Zeitüberschreitung aufgetreten
                        W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignorier                                                             t oder alte an ihrer Stelle benutzt.
                        Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                        pi@iobroker:/opt/iobroker $ apt dist-upgrade
                        E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                        E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                        pi@iobroker:/opt/iobroker $ sudo apt dist-upgrade
                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                          rpi.gpio-common
                        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                          libldap-2.4-2 libldap-common
                        2 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 288 kB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                        Möchten Sie fortfahren? [J/n] j
                        Holen:1 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u2 [89,8 kB]
                        Holen:2 http://archive-bm.raspbian.org/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u2 [198 kB]
                        Es wurden 288 kB in 60 s geholt (4.798 B/s).
                        Changelogs werden gelesen... Fertig
                        (Lese Datenbank ... 117901 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../libldap-common_2.4.47+dfsg-3+rpi1+deb10u2_all.deb ...
                        Entpacken von libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                        libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u2_armhf.deb ...
                        Entpacken von libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) über (2.4.47+dfsg-3+rpi1+deb10u1) ...
                        libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) wird eingerichtet ...
                        Trigger für man-db (2.8.5-2) werden verarbeitet ...
                        Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                        pi@iobroker:/opt/iobroker $ iobroker stop
                        pi@iobroker:/opt/iobroker $ iobroker fix
                        library: loaded
                        Library version=2020-04-12
                            Welcome to the ioBroker installation fixer!
                            Script version: 2020-04-12
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/3)
                        OK:1 https://www.pivccu.de/piVCCU stable InRelease
                        OK:2 http://archive.raspberrypi.org/debian buster InRelease
                        Installed gcc-c++
                        Installed python-dev
                            Checking ioBroker user and directory permissions (2/3)
                            Checking autostart (3/3)
                        Enabling autostart...
                        Autostart enabled!
                            Your installation was fixed successfully
                            Run iobroker start to start ioBroker again!
                        pi@iobroker:/opt/iobroker $ iobroker start
                        pi@iobroker:/opt/iobroker $ iobroker update
                        Used repository: latest
                        hash unchanged, use cached sources
                        update done
                        Adapter    "accuweather"   : 1.1.3
                        Adapter    "admin"         : 4.1.1    , installed 4.0.9 [Updateable]
                        Adapter    "alarm"         : 0.3.0
                        Adapter    "alexa2"        : 3.1.2
                        Adapter    "alpha2"        : 1.0.0
                        Adapter    "amazon-dash"   : 1.1.0
                        Adapter    "artnet"        : 1.2.2
                        Adapter    "asterisk"      : 1.0.6
                        Adapter    "asuswrt"       : 1.0.1
                        Adapter    "b-control-em"  : 0.2.1
                        Adapter    "backitup"      : 1.5.6
                        Adapter    "beckhoff"      : 1.2.1
                        Adapter    "benq"          : 0.2.2
                        Adapter    "binance"       : 1.1.2
                        Adapter    "ble"           : 0.11.6
                        Adapter    "blink4home"    : 0.1.1
                        Adapter    "bmw"           : 1.4.0
                        Adapter    "boblight"      : 0.0.1
                        Adapter    "bosesoundtouch": 0.9.2
                        Adapter    "botvac"        : 1.0.0
                        Adapter    "bring"         : 1.7.2
                        Adapter    "broadlink2"    : 2.0.3
                        Adapter    "bsblan"        : 0.0.6
                        Adapter    "bshb"          : 0.1.10
                        Adapter    "calendar"      : 1.2.0
                        Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                        Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                        Adapter    "comfoair"      : 1.1.1
                        Adapter    "contact"       : 1.1.3
                        Adapter    "contactid"     : 1.0.0
                        Adapter    "coronavirus-statistics": 0.5.9
                        Adapter    "corrently"     : 0.0.2
                        Adapter    "countdown"     : 1.1.0
                        Adapter    "cul"           : 1.2.1
                        Adapter    "daikin"        : 1.0.5
                        Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                        Adapter    "deconz"        : 1.3.7
                        Adapter    "denon"         : 1.7.7    , installed 1.7.4 [Updateable]
                        Adapter    "devices"       : 0.3.6
                        Adapter    "digitalstrom"  : 2.0.5
                        Adapter    "discovergy"    : 0.5.4
                        Adapter    "discovery"     : 2.3.5    , installed 2.2.2 [Updateable]
                        Adapter    "doorbird"      : 0.1.5
                        Adapter    "ds18b20"       : 1.1.4
                        Adapter    "dwd"           : 2.4.8
                        Adapter    "ebus"          : 2.0.0
                        Adapter    "ecovacs-deebot": 0.5.8
                        Adapter    "egigeozone"    : 0.1.2
                        Adapter    "ekey"          : 1.1.0
                        Adapter    "email"         : 1.0.6
                        Adapter    "emby"          : 1.0.2
                        Adapter    "energymanager" : 1.2.2
                        Adapter    "enet"          : 1.0.1
                        Adapter    "epson_stylus_px830": 0.2.1
                        Adapter    "exchangerates" : 0.0.12
                        Adapter    "fakeroku"      : 0.2.1
                        Adapter    "fb-checkpresence": 1.0.1
                        Adapter    "feiertage"     : 1.0.19
                        Adapter    "fhem"          : 1.4.1
                        Adapter    "find-my-iphone": 0.2.17
                        Adapter    "firetv"        : 1.0.0
                        Adapter    "fitbit-api"    : 0.1.1
                        Adapter    "flot"          : 1.9.2
                        Adapter    "foobar2000"    : 1.0.0
                        Adapter    "fritzbox"      : 0.2.1
                        Adapter    "fritzdect"     : 0.3.2
                        Adapter    "fronius"       : 1.0.5
                        Adapter    "fullcalendar"  : 1.1.0
                        Adapter    "fullybrowser"  : 1.0.3
                        Adapter    "g-homa"        : 0.5.1
                        Adapter    "geofency"      : 0.3.2
                        Adapter    "gruenbeck"     : 0.0.18
                        Adapter    "habpanel"      : 0.4.1
                        Adapter    "haier"         : 1.0.3
                        Adapter    "ham"           : 1.1.2
                        Adapter    "ham-wemo"      : 1.0.1
                        Adapter    "harmony"       : 1.2.2
                        Adapter    "hass-mqtt"     : 0.0.7
                        Adapter    "heatingcontrol": 0.5.0
                        Adapter    "heytech"       : 0.2.0
                        Adapter    "hid"           : 0.1.17
                        Adapter    "hilink"        : 0.2.7
                        Adapter    "history"       : 1.9.6    , installed 1.8.7 [Updateable]
                        Adapter    "hm-rega"       : 2.6.6    , installed 2.5.5 [Updateable]
                        Adapter    "hm-rpc"        : 1.14.2   , installed 1.12.10 [Updateable]
                        Adapter    "hmip"          : 0.0.11
                        Adapter    "hombot"        : 0.1.3
                        Adapter    "homeconnect"   : 0.0.26
                        Adapter    "homee"         : 1.0.5
                        Adapter    "homepilot"     : 1.1.4
                        Adapter    "hp-ilo"        : 1.0.5
                        Adapter    "hs100"         : 1.1.2
                        Adapter    "hue"           : 3.2.8
                        Adapter    "hue-extended"  : 1.3.2
                        Adapter    "hyperion"      : 0.0.9
                        Adapter    "i2c"           : 0.0.6
                        Adapter    "ical"          : 1.7.0
                        Adapter    "icons-addictive-flavour-png": 0.1.0
                        Adapter    "icons-fatcow-hosting": 0.1.0
                        Adapter    "icons-icons8"  : 0.0.1
                        Adapter    "icons-material-png": 0.1.0
                        Adapter    "icons-material-svg": 0.1.0
                        Adapter    "icons-mfd-png" : 1.0.2
                        Adapter    "icons-mfd-svg" : 1.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.2
                        Adapter    "icons-ultimate-png": 1.0.1
                        Adapter    "influxdb"      : 1.8.4
                        Adapter    "info"          : 1.7.2    , installed 1.5.6 [Updateable]
                        Adapter    "innogy-smarthome": 0.3.4
                        Adapter    "intesishome"   : 0.1.2
                        Adapter    "iogo"          : 0.5.10
                        Adapter    "iot"           : 1.4.14   , installed 1.4.14
                        Adapter    "iqontrol"      : 0.3.7
                        Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                        Adapter    "jeelink"       : 0.1.3
                        Controller "js-controller" : 3.0.20   , installed 2.2.9 [Updateable]
                        Adapter    "js2fs"         : 0.1.5
                        Adapter    "kecontact"     : 0.1.0
                        Adapter    "klf200"        : 0.9.5
                        Adapter    "km200"         : 2.0.3
                        Adapter    "knmi-weather"  : 0.2.0
                        Adapter    "knx"           : 1.0.41
                        Adapter    "kodi"          : 2.0.2
                        Adapter    "kress"         : 2.5.5
                        Adapter    "lametric"      : 0.0.7
                        Adapter    "landroid"      : 1.0.3
                        Adapter    "lcn"           : 0.6.3
                        Adapter    "letrika_comgw" : 0.0.5
                        Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                        Adapter    "lgtv-rs"       : 0.1.0
                        Adapter    "lgtv11"        : 1.0.5
                        Adapter    "lifx"          : 0.1.1
                        Adapter    "lightify"      : 0.2.16
                        Adapter    "link"          : 0.5.9
                        Adapter    "linkeddevices" : 1.1.4
                        Adapter    "lovelace"      : 1.0.16
                        Adapter    "loxone"        : 1.0.0
                        Adapter    "luftdaten"     : 0.0.11
                        Adapter    "lupusec"       : 1.2.6
                        Adapter    "luxtronik1"    : 0.2.3
                        Adapter    "material"      : 0.13.8
                        Adapter    "maxcube"       : 0.1.2
                        Adapter    "maxcul"        : 1.1.2
                        Adapter    "mbus"          : 2.2.0
                        Adapter    "mclighting"    : 0.1.1
                        Adapter    "megad"         : 1.2.1
                        Adapter    "megadd"        : 0.2.0
                        Adapter    "megaesp"       : 0.1.0
                        Adapter    "mercedesme"    : 0.0.21
                        Adapter    "mercury"       : 0.1.1
                        Adapter    "meross"        : 1.3.13
                        Adapter    "meteoalarm"    : 1.1.0
                        Adapter    "miele"         : 0.1.5
                        Adapter    "mielecloudservice": 1.2.1
                        Adapter    "mihome"        : 1.3.0
                        Adapter    "mihome-airpurifier": 0.1.7
                        Adapter    "mihome-lamp"   : 1.1.0
                        Adapter    "mihome-plug"   : 0.2.1
                        Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                        Adapter    "miio"          : 0.0.13
                        Adapter    "mikrotik"      : 1.0.12
                        Adapter    "milight"       : 0.3.6
                        Adapter    "milight-smart-light": 0.4.1
                        Adapter    "mobile"        : 0.5.0
                        Adapter    "modbus"        : 3.0.0
                        Adapter    "moma"          : 1.2.6
                        Adapter    "mpd"           : 1.0.5
                        Adapter    "mqtt"          : 2.1.1
                        Adapter    "mqtt-client"   : 1.3.1
                        Adapter    "multicast"     : 0.1.5
                        Adapter    "musiccast"     : 0.1.3
                        Adapter    "mydlink"       : 1.0.9
                        Adapter    "myq"           : 0.1.1
                        Adapter    "mysensors"     : 2.0.0
                        Adapter    "myvbus"        : 0.0.4
                        Adapter    "nanoleaf-lightpanels": 0.8.2
                        Adapter    "nello"         : 2.0.8
                        Adapter    "netatmo"       : 1.3.1
                        Adapter    "nibeuplink"    : 0.3.0
                        Adapter    "nina"          : 0.0.23
                        Adapter    "node-red"      : 1.17.2
                        Adapter    "noolitef"      : 0.0.2
                        Adapter    "nuki"          : 1.2.3
                        Adapter    "nuki-extended" : 2.2.5
                        Adapter    "nut"           : 1.1.3
                        Adapter    "odl"           : 1.0.5
                        Adapter    "oilfox"        : 2.1.0
                        Adapter    "onkyo"         : 2.0.3
                        Adapter    "onvif"         : 0.4.2
                        Adapter    "openhab"       : 1.1.0
                        Adapter    "openligadb"    : 1.1.0
                        Adapter    "opentherm"     : 0.1.9
                        Adapter    "openweathermap": 0.1.0
                        Adapter    "opi"           : 0.1.1
                        Adapter    "oppoplayer"    : 0.2.1
                        Adapter    "owfs"          : 0.6.4
                        Adapter    "owntracks"     : 0.6.2
                        Adapter    "panasonic-viera": 1.0.2
                        Adapter    "parser"        : 1.0.7
                        Adapter    "paw"           : 0.3.2
                        Adapter    "phantomjs"     : 1.0.1
                        Adapter    "pi-hole"       : 1.2.3
                        Adapter    "piface"        : 1.0.0
                        Adapter    "pimatic"       : 0.2.1
                        Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                        Adapter    "places"        : 0.7.0
                        Adapter    "plenticore"    : 2.1.3
                        Adapter    "plex"          : 0.8.11
                        Adapter    "plexconnect"   : 0.0.7
                        Adapter    "pollenflug"    : 1.0.6
                        Adapter    "primelab"      : 1.0.2
                        Adapter    "proxmox"       : 1.0.2
                        Adapter    "proxy"         : 1.2.1
                        Adapter    "pushbullet"    : 0.0.11
                        Adapter    "pushover"      : 2.0.2
                        Adapter    "pushsafer"     : 0.1.8
                        Adapter    "radar2"        : 1.2.5
                        Adapter    "radiohead"     : 1.0.5
                        Adapter    "rainbird"      : 0.2.2
                        Adapter    "rflink"        : 2.1.5
                        Adapter    "rickshaw"      : 1.0.0
                        Adapter    "ring"          : 1.1.2
                        Adapter    "roadtraffic"   : 0.2.0
                        Adapter    "robonect"      : 0.1.3
                        Adapter    "roomba"        : 1.1.1
                        Adapter    "rpi2"          : 1.2.0
                        Adapter    "rssfeed"       : 0.0.28
                        Adapter    "s7"            : 1.1.8
                        Adapter    "samsung"       : 0.2.9
                        Adapter    "sanext"        : 0.0.4
                        Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                        Adapter    "sbfspot"       : 3.0.0
                        Adapter    "scenes"        : 1.1.0
                        Adapter    "schoolfree"    : 0.6.0
                        Adapter    "senec"         : 1.0.8
                        Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                        Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                        Adapter    "sia"           : 1.0.4
                        Adapter    "siegenia"      : 1.0.0
                        Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                        Adapter    "sma-em"        : 0.5.7
                        Adapter    "smappee"       : 0.2.2
                        Adapter    "smartmeter"    : 3.1.2
                        Adapter    "snips"         : 1.5.0
                        Adapter    "snmp"          : 0.5.0
                        Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                        Adapter    "solarlog"      : 2.0.0
                        Adapter    "solarviewdatareader": 0.2.0
                        Adapter    "solarwetter"   : 1.0.0
                        Adapter    "sonnen"        : 1.5.0
                        Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                        Adapter    "sonos"         : 2.0.1
                        Adapter    "sonus"         : 0.1.1
                        Adapter    "sony-bravia"   : 1.0.1
                        Adapter    "sourceanalytix": 0.4.2
                        Adapter    "spotify-premium": 1.0.0
                        Adapter    "sql"           : 1.12.5
                        Adapter    "squeezebox"    : 1.0.0
                        Adapter    "squeezeboxrpc" : 1.0.1
                        Adapter    "starline"      : 1.0.0
                        Adapter    "statistics"    : 0.2.2
                        Adapter    "stiebel-isg"   : 1.4.11
                        Adapter    "stockmarket"   : 0.0.2
                        Adapter    "sunnyportal"   : 0.1.5
                        Adapter    "swiss-weather-api": 0.2.0
                        Adapter    "synology"      : 0.1.7
                        Adapter    "systeminfo"    : 0.3.1
                        Adapter    "tado"          : 0.1.9
                        Adapter    "tahoma"        : 0.3.3
                        Adapter    "tankerkoenig"  : 2.0.9
                        Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                        Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                        Adapter    "tesla-motors"  : 0.2.3
                        Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                        Adapter    "tileboard"     : 0.1.1
                        Adapter    "tinker"        : 1.1.0
                        Adapter    "tino"          : 0.1.3
                        Adapter    "tinyrx4"       : 0.1.5
                        Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                        Adapter    "tradfri"       : 2.6.2
                        Adapter    "trashschedule" : 0.0.5
                        Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                        Adapter    "tuya"          : 3.2.3
                        Adapter    "tvspielfilm"   : 2.0.1
                        Adapter    "unifi"         : 0.4.3
                        Adapter    "unifi-protect" : 0.0.11
                        Adapter    "upnp"          : 1.0.16
                        Adapter    "vaillant"      : 0.0.10
                        Adapter    "valloxmv"      : 1.0.3
                        Adapter    "vcard"         : 0.0.9
                        Adapter    "vedirect"      : 0.1.0
                        Adapter    "velux"         : 0.0.5
                        Adapter    "viessmann"     : 1.2.4
                        Adapter    "viessmannapi"  : 1.3.2
                        Adapter    "virtualpowermeter": 1.2.1
                        Adapter    "vis"           : 1.2.6
                        Adapter    "vis-bars"      : 0.1.4
                        Adapter    "vis-canvas-gauges": 0.1.5
                        Adapter    "vis-colorpicker": 1.2.0
                        Adapter    "vis-fancyswitch": 1.1.0
                        Adapter    "vis-google-fonts": 0.1.0
                        Adapter    "vis-history"   : 1.0.0
                        Adapter    "vis-hqwidgets" : 1.1.4
                        Adapter    "vis-inventwo"  : 1.3.3
                        Adapter    "vis-jqui-mfd"  : 1.0.12
                        Adapter    "vis-justgage"  : 1.0.2
                        Adapter    "vis-keyboard"  : 0.0.2
                        Adapter    "vis-lcars"     : 1.0.4
                        Adapter    "vis-map"       : 1.0.4
                        Adapter    "vis-material"  : 0.1.3
                        Adapter    "vis-material-webfont": 0.0.3
                        Adapter    "vis-materialdesign": 0.3.6
                        Adapter    "vis-metro"     : 1.1.2
                        Adapter    "vis-players"   : 0.1.6
                        Adapter    "vis-plumb"     : 1.0.2
                        Adapter    "vis-rgraph"    : 0.0.2
                        Adapter    "vis-timeandweather": 1.1.7
                        Adapter    "vis-weather"   : 2.5.2
                        Adapter    "vodafone-speedtest": 0.0.4
                        Adapter    "volvo"         : 0.0.2
                        Adapter    "vr200"         : 1.0.0
                        Adapter    "vw-connect"    : 0.0.11
                        Adapter    "weatherunderground": 3.2.1
                        Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                        Adapter    "web-speedy"    : 0.2.0
                        Adapter    "weishaupt-wem" : 0.0.8
                        Adapter    "wiffi-wz"      : 2.2.0
                        Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                        Adapter    "windows-control": 0.1.3
                        Adapter    "wlanthermo-nano": 0.1.1
                        Adapter    "wled"          : 0.5.0
                        Adapter    "wm-bus"        : 0.3.1
                        Adapter    "wolf"          : 1.2.0
                        Adapter    "worx"          : 1.0.2
                        Adapter    "xbox"          : 0.6.3
                        Adapter    "xs1"           : 1.0.2
                        Adapter    "yahka"         : 0.11.0
                        Adapter    "yamaha"        : 0.3.19
                        Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                        Adapter    "youtube"       : 0.0.8
                        Adapter    "yr"            : 2.0.3
                        Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                        Adapter    "zoneminder"    : 0.3.3
                        Adapter    "zont"          : 0.5.4
                        Adapter    "zwave"         : 2.0.1
                        Adapter    "zwave2"        : 0.11.7
                        pi@iobroker:/opt/iobroker $ iobroker upgrade
                        Adapter "accuweather"    is not installed.
                        Update admin from @4.0.9 to @4.1.1
                        host.iobroker Adapter "system.adapter.admin.0" is stopped.
                        NPM version: 6.14.4
                        npm install iobroker.admin@4.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                        Package pixman-1 was not found in the pkg-config search path.
                        Perhaps you should add the directory containing `pixman-1.pc'
                        to the PKG_CONFIG_PATH environment variable
                        No package 'pixman-1' found
                        gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                        gyp ERR! configure error
                        gyp ERR! stack Error: `gyp` failed with exit code: 1
                        gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                        gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                        gyp ERR! System Linux 4.19.97-v7l+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                        gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        gyp ERR! node -v v12.16.3
                        gyp ERR! node-gyp -v v5.1.0
                        gyp ERR! not ok
                        node-pre-gyp ERR! build error
                        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                        node-pre-gyp ERR! System Linux 4.19.97-v7l+
                        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                        node-pre-gyp ERR! node -v v12.16.3
                        node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                        node-pre-gyp ERR! not ok
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                        Update "system.adapter.admin.0"
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        Adapter "admin" updated
                        host.iobroker Adapter "system.adapter.admin.0" is started
                        Adapter "alarm"          is not installed.
                        Adapter "alexa2"         is not installed.
                        Adapter "alpha2"         is not installed.
                        Adapter "amazon-dash"    is not installed.
                        Adapter "artnet"         is not installed.
                        Adapter "asterisk"       is not installed.
                        Adapter "asuswrt"        is not installed.
                        Adapter "b-control-em"   is not installed.
                        Adapter "backitup"       is not installed.
                        Adapter "beckhoff"       is not installed.
                        Adapter "benq"           is not installed.
                        Adapter "binance"        is not installed.
                        Adapter "ble"            is not installed.
                        Adapter "blink4home"     is not installed.
                        Adapter "bmw"            is not installed.
                        Adapter "boblight"       is not installed.
                        Adapter "bosesoundtouch" is not installed.
                        Adapter "botvac"         is not installed.
                        Adapter "bring"          is not installed.
                        Adapter "broadlink2"     is not installed.
                        Adapter "bsblan"         is not installed.
                        Adapter "bshb"           is not installed.
                        Adapter "calendar"       is not installed.
                        Adapter "chromecast"     is up to date.
                        Adapter "cloud"          is up to date.
                        Adapter "comfoair"       is not installed.
                        Adapter "contact"        is not installed.
                        Adapter "contactid"      is not installed.
                        Adapter "coronavirus-statistics" is not installed.
                        Adapter "corrently"      is not installed.
                        Adapter "countdown"      is not installed.
                        Adapter "cul"            is not installed.
                        Adapter "daikin"         is not installed.
                        Adapter "daswetter"      is up to date.
                        Adapter "deconz"         is not installed.
                        Update denon from @1.7.4 to @1.7.7
                        NPM version: 6.14.4
                        npm install iobroker.denon@1.7.7 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        upload [3] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js words.js application/javascript
                        Update "system.adapter.denon.0"
                        upload [2] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.html index_m.html text/html
                        upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index.html index.html text/html
                        upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.png denon.png image/png
                        Adapter "denon" updated
                        Adapter "devices"        is not installed.
                        Adapter "digitalstrom"   is not installed.
                        Adapter "discovergy"     is not installed.
                        Update discovery from @2.2.2 to @2.3.5
                        NPM version: 6.14.4
                        npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
                        In file included from ../src/./serialport.h:6,
                                         from ../src/serialport.cpp:1:
                        ../../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                        ../../../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                        ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                           uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                        ../src/serialport.cpp: At global scope:
                        ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                         SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                        ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                         SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                        In file included from ../../../../../nan/nan.h:54,
                        /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                               (node::addon_register_func) (regfunc),                          \
                        /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                        ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                         NODE_MODULE(serialport, init);
                        In file included from ../src/serialport.h:6,
                                         from ../src/serialport_unix.cpp:2:
                        ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                        ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                             snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                        ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                        ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                        ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                             snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                        ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                        In file included from ../src/poller.cpp:1:
                        gyp ERR! not ok
                        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        Update "system.adapter.discovery.0"
                        upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                        upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                        Adapter "discovery" updated
                        Adapter "doorbird"       is not installed.
                        Adapter "ds18b20"        is not installed.
                        Adapter "dwd"            is not installed.
                        Adapter "ebus"           is not installed.
                        Adapter "ecovacs-deebot" is not installed.
                        Adapter "egigeozone"     is not installed.
                        Adapter "ekey"           is not installed.
                        Adapter "email"          is not installed.
                        Adapter "emby"           is not installed.
                        Adapter "energymanager"  is not installed.
                        Adapter "enet"           is not installed.
                        Adapter "epson_stylus_px830" is not installed.
                        Adapter "exchangerates"  is not installed.
                        Adapter "fakeroku"       is not installed.
                        Adapter "fb-checkpresence" is not installed.
                        Adapter "feiertage"      is not installed.
                        Adapter "fhem"           is not installed.
                        Adapter "find-my-iphone" is not installed.
                        Adapter "firetv"         is not installed.
                        Adapter "fitbit-api"     is not installed.
                        Adapter "flot"           is not installed.
                        Adapter "foobar2000"     is not installed.
                        Adapter "fritzbox"       is not installed.
                        Adapter "fritzdect"      is not installed.
                        Adapter "fronius"        is not installed.
                        Adapter "fullcalendar"   is not installed.
                        Adapter "fullybrowser"   is not installed.
                        Adapter "g-homa"         is not installed.
                        Adapter "geofency"       is not installed.
                        Adapter "gruenbeck"      is not installed.
                        Adapter "habpanel"       is not installed.
                        Adapter "haier"          is not installed.
                        Adapter "ham"            is not installed.
                        Adapter "ham-wemo"       is not installed.
                        Adapter "harmony"        is not installed.
                        Adapter "hass-mqtt"      is not installed.
                        Adapter "heatingcontrol" is not installed.
                        Adapter "heytech"        is not installed.
                        Adapter "hid"            is not installed.
                        Adapter "hilink"         is not installed.
                        Update history from @1.8.7 to @1.9.6
                        NPM version: 6.14.4
                        npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/wordsCustom.js wordsCustom.js application/javascript
                        upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                        Update "system.adapter.history.0"
                        upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                        upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                        upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                        upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                        upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                        Adapter "history" updated
                        Update hm-rega from @2.5.5 to @2.6.6
                        NPM version: 6.14.4
                        npm install iobroker.hm-rega@2.6.6 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                        Update "system.adapter.hm-rega.0"
                        upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                        upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                        upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                        Adapter "hm-rega" updated
                        Update hm-rpc from @1.12.10 to @1.14.2
                        NPM version: 6.14.4
                        npm install iobroker.hm-rpc@1.14.2 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        Update "system.adapter.hm-rpc.0"
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/96_hm-tc-it-wm-w-eu_thumb.png icons/96_hm-tc-it-wm-w-eu_thumb.png image/png
                        upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/49_hm-sec-wds_thumb.png icons/49_hm-sec-wds_thumb.png image/png
                        upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/187_hmip-rcb1_thumb.png icons/187_hmip-rcb1_thumb.png image/png
                        upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/178_hmip-etrv-b1_thumb.png icons/178_hmip-etrv-b1_thumb.png image/png
                        upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/168_hmip-smi55_thumb.png icons/168_hmip-smi55_thumb.png image/png
                        upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                        upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
                        upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/140_alpha-ip-rgb_thumb.png icons/140_alpha-ip-rgb_thumb.png image/png
                        upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/132_hmip-smo_thumb.png icons/132_hmip-smo_thumb.png image/png
                        upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/121_hmip-wth_thumb.png icons/121_hmip-wth_thumb.png image/png
                        upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                        upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-uk_thumb.png icons/113_hmip-psm-uk_thumb.png image/png
                        upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-pe_thumb.png icons/113_hmip-psm-pe_thumb.png image/png
                        upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-it_thumb.png icons/113_hmip-psm-it_thumb.png image/png
                        upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm-ch_thumb.png icons/113_hmip-psm-ch_thumb.png image/png
                        upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/112_hmip-wrc2_thumb.png icons/112_hmip-wrc2_thumb.png image/png
                        upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/111_hm-lc-rgbw-wm_thumb.png icons/111_hm-lc-rgbw-wm_thumb.png image/png
                        upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/110_hm-es-pmsw1-dr_thump.png icons/110_hm-es-pmsw1-dr_thump.png image/png
                        upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/109_hm-lc-sw1-pl-ct_thump.png icons/109_hm-lc-sw1-pl-ct_thump.png image/png
                        upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/108_hm-rc-dis-h-x-eu_thump.png icons/108_hm-rc-dis-h-x-eu_thump.png image/png
                        upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R5_thumb.png icons/107_hm-es-pmsw1-pl-R5_thumb.png image/png
                        upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R4_thumb.png icons/107_hm-es-pmsw1-pl-R4_thumb.png image/png
                        upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R3_thumb.png icons/107_hm-es-pmsw1-pl-R3_thumb.png image/png
                        upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/107_hm-es-pmsw1-pl-R2_thumb.png icons/107_hm-es-pmsw1-pl-R2_thumb.png image/png
                        upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/105_hm-sec-sd-2-team_thumb.png icons/105_hm-sec-sd-2-team_thumb.png image/png
                        upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/104_hm-sec-sd-2_thumb.png icons/104_hm-sec-sd-2_thumb.png image/png
                        upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/103_hm-sen-mdir-wm55_thumb.png icons/103_hm-sen-mdir-wm55_thumb.png image/png
                        upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/102_hm-es-tx-wm_thumb.png icons/102_hm-es-tx-wm_thumb.png image/png
                        upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/101_hm-sen-db-pcb_thumb.png icons/101_hm-sen-db-pcb_thumb.png image/png
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        Adapter "hm-rpc" updated
                        Adapter "hmip"           is not installed.
                        Adapter "hombot"         is not installed.
                        Adapter "homeconnect"    is not installed.
                        Adapter "homee"          is not installed.
                        Adapter "homepilot"      is not installed.
                        Adapter "hp-ilo"         is not installed.
                        Adapter "hs100"          is not installed.
                        Adapter "hue"            is not installed.
                        Adapter "hue-extended"   is not installed.
                        Adapter "hyperion"       is not installed.
                        Adapter "i2c"            is not installed.
                        Adapter "ical"           is not installed.
                        Adapter "icons-addictive-flavour-png" is not installed.
                        Adapter "icons-fatcow-hosting" is not installed.
                        Adapter "icons-icons8"   is not installed.
                        Adapter "icons-material-png" is not installed.
                        Adapter "icons-material-svg" is not installed.
                        Adapter "icons-mfd-png"  is not installed.
                        Adapter "icons-mfd-svg"  is not installed.
                        Adapter "icons-open-icon-library-png" is not installed.
                        Adapter "icons-ultimate-png" is not installed.
                        Adapter "influxdb"       is not installed.
                        Update info from @1.5.6 to @1.7.2
                        NPM version: 6.14.4
                        npm install iobroker.info@1.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                        Update "system.adapter.info.0"
                        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                        upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                        Adapter "info" updated
                        Adapter "innogy-smarthome" is not installed.
                        Adapter "intesishome"    is not installed.
                        Adapter "iogo"           is not installed.
                        Adapter "iot"            is up to date.
                        Adapter "iqontrol"       is not installed.
                        Adapter "javascript"     is up to date.
                        Adapter "jeelink"        is not installed.
                        Adapter "js2fs"          is not installed.
                        Adapter "kecontact"      is not installed.
                        Adapter "klf200"         is not installed.
                        Adapter "km200"          is not installed.
                        Adapter "knmi-weather"   is not installed.
                        Adapter "knx"            is not installed.
                        Adapter "kodi"           is not installed.
                        Adapter "kress"          is not installed.
                        Adapter "lametric"       is not installed.
                        Adapter "landroid"       is not installed.
                        Adapter "lcn"            is not installed.
                        Adapter "letrika_comgw"  is not installed.
                        Adapter "lgtv"           is up to date.
                        Adapter "lgtv-rs"        is not installed.
                        Adapter "lgtv11"         is not installed.
                        Adapter "lifx"           is not installed.
                        Adapter "lightify"       is not installed.
                        Adapter "link"           is not installed.
                        Adapter "linkeddevices"  is not installed.
                        Adapter "lovelace"       is not installed.
                        Adapter "loxone"         is not installed.
                        Adapter "luftdaten"      is not installed.
                        Adapter "lupusec"        is not installed.
                        Adapter "luxtronik1"     is not installed.
                        Adapter "material"       is not installed.
                        Adapter "maxcube"        is not installed.
                        Adapter "maxcul"         is not installed.
                        Adapter "mbus"           is not installed.
                        Adapter "mclighting"     is not installed.
                        Adapter "megad"          is not installed.
                        Adapter "megadd"         is not installed.
                        Adapter "megaesp"        is not installed.
                        Adapter "mercedesme"     is not installed.
                        Adapter "mercury"        is not installed.
                        Adapter "meross"         is not installed.
                        Adapter "meteoalarm"     is not installed.
                        Adapter "miele"          is not installed.
                        Adapter "mielecloudservice" is not installed.
                        Adapter "mihome"         is not installed.
                        Adapter "mihome-airpurifier" is not installed.
                        Adapter "mihome-lamp"    is not installed.
                        Adapter "mihome-plug"    is not installed.
                        Update mihome-vacuum from @1.1.5 to @2.0.7
                        NPM version: 6.14.4
                        npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the canvas@2.6.1 install script.
                        npm ERR!     /home/iobroker/.npm/_logs/2020-05-08T10_19_53_090Z-debug.log
                        host.iobroker Cannot install iobroker.mihome-vacuum@2.0.7: 1
                        pi@iobroker:/opt/iobroker $ iobroker upgrade self
                        Controller is running. Please stop ioBroker first.
                        ^[[A^[[Api@iobroker:/opt/iobroker $ iobroker upgrade self
                        Update js-controller from @2.2.9 to @3.0.20
                        NPM version: 6.14.4
                        npm install iobroker.js-controller@3.0.20 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                        gyp ERR! not ok
                        Starting node restart.js
                        > protobufjs@6.8.9 postinstall /opt/iobroker/node_modules/protobufjs
                        > node scripts/postinstall
                        > serialport@8.0.8 postinstall /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                        > node thank-you.js
                        Thank you for using serialport!
                        If you rely on this package, please consider supporting our open collective:
                        > https://opencollective.com/serialport/donate
                        > @serialport/bindings@8.0.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                        > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                        prebuild-install WARN install No prebuilt binaries found (target=12.16.3 runtime=node arch=arm libc= platform=linux)
                        gyp ERR! clean error
                        gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings
                        gyp ERR! not ok
                        npm ERR! errno 1
                        npm ERR! @serialport/bindings@8.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
                        npm ERR!
                        npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
                        npm ERR!     /home/pi/.npm/_logs/2020-05-08T10_25_49_001Z-debug.log
                        Fehler bleibt bestehen.
                        Eine Idee wäre noch ein Downgrade von Node.js zurück auf die 10er zu machen und schauen ob es wirklich nur die Schleife im Blockly war, die den JS Adapter zum Absturz brachte.
                        maxpd
                        • M maxpd
                          + apt-get update
                          OK
                          + apt-get update
                            rpi.gpio-common
                          library: loaded
                          Installed gcc-c++
                          Autostart enabled!
                          update done
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          NPM version: 6.14.4
                          gyp ERR! not ok
                          > node thank-you.js
                          gyp ERR! not ok
                          npm ERR! errno 1
                          npm ERR!
                          #75
                          @maxpd
                          sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-0
                          Und dann nochmal versuchen.
                            @maxpd
                            maxpd
                            #76
                            @Thomas-Braun said in Javascript Adapter rot (out of memory):
                            nochmal alles komplett versuchen?
                            vorher auf default zurückswitchen?
                            maxpd
                            • M maxpd
                              #77
                              @maxpd Bleib mal auf 'latest'
                              Die Pakete von gerade eben einspielen und dann nochmal
                              iobroker update
                              iobroker upgrade
                              npm rebuild
                                iobroker update
                                iobroker upgrade
                                npm rebuild
                                maxpd
                                #78
                                @Thomas-Braun hat jetzt schon wesentlich länger gedauert. Würde auch sagen sieht gut aus, mit Ausnahme npm rebuild.
                                update done
                                Adapter    "admin"         : 4.1.1    , installed 4.1.1
                                Adapter    "denon"         : 1.7.7    , installed 1.7.7
                                Adapter    "discovery"     : 2.3.5    , installed 2.3.5
                                Adapter    "history"       : 1.9.6    , installed 1.9.6
                                Adapter    "hm-rega"       : 2.6.6    , installed 2.6.6
                                Adapter    "hm-rpc"        : 1.14.2   , installed 1.14.2
                                Adapter    "info"          : 1.7.2    , installed 1.7.2
                                Controller "js-controller" : 3.0.20   , installed 3.0.20
                                Adapter "admin"          is up to date.
                                Adapter "denon"          is up to date.
                                Adapter "discovery"      is up to date.
                                Adapter "history"        is up to date.
                                Adapter "hm-rega"        is up to date.
                                Adapter "hm-rpc"         is up to date.
                                Adapter "info"           is up to date.
                                NPM version: 6.14.4
                                In file included from ../src/backend/Backend.h:6,
                                                 from ../src/backend/Backend.cc:1:
                                                 from ../src/backend/ImageBackend.h:3,
                                                 from ../src/backend/ImageBackend.cc:1:
                                                 from ../src/backend/PdfBackend.h:3,
                                                 from ../src/backend/PdfBackend.cc:1:
                                                 from ../src/backend/SvgBackend.h:3,
                                                 from ../src/backend/SvgBackend.cc:1:
                                ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                                ../src/bmp/BMPParser.cc:189:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                                   E(ptr - data > imgdOffset, "image data overlaps with another structure");
                                ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                                 #define E(cond, msg) if(cond) return setErr(msg)
                                ../src/bmp/BMPParser.cc:204:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                                   E(ptr - data + imgdSize > len, "not enough image data");
                                                 from ../src/Backends.h:3,
                                                 from ../src/Backends.cc:1:
                                                 from ../src/Canvas.h:5,
                                                 from ../src/Canvas.cc:3:
                                ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/Canvas.cc:415:26: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
                                     if (canvas->nBytes() > node::Buffer::kMaxLength) {
                                ../src/Canvas.cc:479:79: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                     uv_queue_work(uv_default_loop(), req, ToPngBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                ../src/Canvas.cc:520:80: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                     uv_queue_work(uv_default_loop(), req, ToJpegBufferAsync, (uv_after_work_cb)ToBufferAsyncAfter);
                                In file included from ../src/CanvasGradient.h:5,
                                                 from ../src/CanvasGradient.cc:3:
                                In file included from ../src/CanvasPattern.h:6,
                                                 from ../src/CanvasPattern.cc:3:
                                                 from ../src/CanvasRenderingContext2d.h:6,
                                                 from ../src/CanvasRenderingContext2d.cc:3:
                                                 from ../src/closure.h:5,
                                                 from ../src/closure.cc:1:
                                In file included from ../src/Image.h:8,
                                                 from ../src/Image.cc:3:
                                In file included from ../src/ImageData.h:5,
                                                 from ../src/ImageData.cc:3:
                                                 from ../src/init.cc:17:
                                In file included from ../../nan/nan.h:54,
                                ../src/init.cc: At global scope:
                                ../src/init.cc:88:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(canvas, init);
                                upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                Update "system.adapter.mihome-vacuum.0"
                                upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
                                upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
                                upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
                                upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
                                upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
                                upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
                                upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
                                upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                Adapter "mihome-vacuum" updated
                                Adapter "miio"           is not installed.
                                Adapter "mikrotik"       is not installed.
                                Adapter "milight"        is not installed.
                                Adapter "milight-smart-light" is not installed.
                                Adapter "mobile"         is not installed.
                                Adapter "modbus"         is not installed.
                                Adapter "moma"           is not installed.
                                Adapter "mpd"            is not installed.
                                Adapter "mqtt"           is not installed.
                                Adapter "mqtt-client"    is not installed.
                                Adapter "multicast"      is not installed.
                                Adapter "musiccast"      is not installed.
                                Adapter "mydlink"        is not installed.
                                Adapter "myq"            is not installed.
                                Adapter "mysensors"      is not installed.
                                Adapter "myvbus"         is not installed.
                                Adapter "nanoleaf-lightpanels" is not installed.
                                Adapter "nello"          is not installed.
                                Adapter "netatmo"        is not installed.
                                Adapter "nibeuplink"     is not installed.
                                Adapter "nina"           is not installed.
                                Adapter "node-red"       is not installed.
                                Adapter "noolitef"       is not installed.
                                Adapter "nuki"           is not installed.
                                Adapter "nuki-extended"  is not installed.
                                Adapter "nut"            is not installed.
                                Adapter "odl"            is not installed.
                                Adapter "oilfox"         is not installed.
                                Adapter "onkyo"          is not installed.
                                Adapter "onvif"          is not installed.
                                Adapter "openhab"        is not installed.
                                Adapter "openligadb"     is not installed.
                                Adapter "opentherm"      is not installed.
                                Adapter "openweathermap" is not installed.
                                Adapter "opi"            is not installed.
                                Adapter "oppoplayer"     is not installed.
                                Adapter "owfs"           is not installed.
                                Adapter "owntracks"      is not installed.
                                Adapter "panasonic-viera" is not installed.
                                Adapter "parser"         is not installed.
                                Adapter "paw"            is not installed.
                                Adapter "phantomjs"      is not installed.
                                Adapter "pi-hole"        is not installed.
                                Adapter "piface"         is not installed.
                                Adapter "pimatic"        is not installed.
                                Update ping from @1.3.2 to @1.4.7
                                NPM version: 6.14.4
                                npm install iobroker.ping@1.4.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                Update "system.adapter.ping.0"
                                upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html
                                upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
                                Adapter "ping" updated
                                Adapter "places"         is not installed.
                                Adapter "plenticore"     is not installed.
                                Adapter "plex"           is not installed.
                                Adapter "plexconnect"    is not installed.
                                Adapter "pollenflug"     is not installed.
                                Adapter "primelab"       is not installed.
                                Adapter "proxmox"        is not installed.
                                Adapter "proxy"          is not installed.
                                Adapter "pushbullet"     is not installed.
                                Adapter "pushover"       is not installed.
                                Adapter "pushsafer"      is not installed.
                                Adapter "radar2"         is not installed.
                                Adapter "radiohead"      is not installed.
                                Adapter "rainbird"       is not installed.
                                Adapter "rflink"         is not installed.
                                Adapter "rickshaw"       is not installed.
                                Adapter "ring"           is not installed.
                                Adapter "roadtraffic"    is not installed.
                                Adapter "robonect"       is not installed.
                                Adapter "roomba"         is not installed.
                                Adapter "rpi2"           is not installed.
                                Adapter "rssfeed"        is not installed.
                                Adapter "s7"             is not installed.
                                Adapter "samsung"        is not installed.
                                Adapter "sanext"         is not installed.
                                Adapter "sayit"          is up to date.
                                Adapter "sbfspot"        is not installed.
                                Adapter "scenes"         is not installed.
                                Adapter "schoolfree"     is not installed.
                                Adapter "senec"          is not installed.
                                Update shelly from @3.1.6 to @3.2.7
                                NPM version: 6.14.4
                                npm install iobroker.shelly@3.2.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                                Update "system.adapter.shelly.0"
                                upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                                upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                                Adapter "shelly" updated
                                Update shuttercontrol from @0.4.3 to @0.5.0
                                host.iobroker Adapter "system.adapter.shuttercontrol.0" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.shuttercontrol@0.5.0 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
                                Update "system.adapter.shuttercontrol.0"
                                upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
                                upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
                                upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
                                Adapter "shuttercontrol" updated
                                host.iobroker Adapter "system.adapter.shuttercontrol.0" is started
                                Adapter "sia"            is not installed.
                                Adapter "siegenia"       is not installed.
                                Adapter "simple-api"     is up to date.
                                Adapter "sma-em"         is not installed.
                                Adapter "smappee"        is not installed.
                                Adapter "smartmeter"     is not installed.
                                Adapter "snips"          is not installed.
                                Adapter "snmp"           is not installed.
                                Update socketio from @3.0.6 to @3.0.7
                                NPM version: 6.14.4
                                npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
                                upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
                                upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
                                Adapter "socketio" updated
                                Adapter "solarlog"       is not installed.
                                Adapter "solarviewdatareader" is not installed.
                                Adapter "solarwetter"    is not installed.
                                Adapter "sonnen"         is not installed.
                                Adapter "sonoff"         is up to date.
                                Adapter "sonos"          is not installed.
                                Adapter "sonus"          is not installed.
                                Adapter "sony-bravia"    is not installed.
                                Adapter "sourceanalytix" is not installed.
                                Adapter "spotify-premium" is not installed.
                                Adapter "sql"            is not installed.
                                Adapter "squeezebox"     is not installed.
                                Adapter "squeezeboxrpc"  is not installed.
                                Adapter "starline"       is not installed.
                                Adapter "statistics"     is not installed.
                                Adapter "stiebel-isg"    is not installed.
                                Adapter "stockmarket"    is not installed.
                                Adapter "sunnyportal"    is not installed.
                                Adapter "swiss-weather-api" is not installed.
                                Adapter "synology"       is not installed.
                                Adapter "systeminfo"     is not installed.
                                Adapter "tado"           is not installed.
                                Adapter "tahoma"         is not installed.
                                Adapter "tankerkoenig"   is not installed.
                                Update telegram from @1.4.3 to @1.5.9
                                host.iobroker Adapter "system.adapter.telegram.1" is stopped.
                                host.iobroker Adapter "system.adapter.telegram.2" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                Update "system.adapter.telegram.0"
                                Update "system.adapter.telegram.1"
                                Update "system.adapter.telegram.2"
                                upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                                upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                                upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                                upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                Adapter "telegram" updated
                                host.iobroker Adapter "system.adapter.telegram.1" is started
                                host.iobroker Adapter "system.adapter.telegram.2" is started
                                Adapter "terminal"       is up to date.
                                Adapter "tesla-motors"   is not installed.
                                Adapter "text2command"   is up to date.
                                Adapter "tileboard"      is not installed.
                                Adapter "tinker"         is not installed.
                                Adapter "tino"           is not installed.
                                Adapter "tinyrx4"        is not installed.
                                Update tr-064 from @0.4.18 to @4.0.1
                                NPM version: 6.14.4
                                npm install iobroker.tr-064@4.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                Update "system.adapter.tr-064.0"
                                upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                Adapter "tr-064" updated
                                Adapter "tradfri"        is not installed.
                                Adapter "trashschedule"  is not installed.
                                Adapter "tunnelbroker-endpoint-updater" is not installed.
                                Adapter "tuya"           is not installed.
                                Adapter "tvspielfilm"    is not installed.
                                Adapter "unifi"          is not installed.
                                Adapter "unifi-protect"  is not installed.
                                Adapter "upnp"           is not installed.
                                Adapter "vaillant"       is not installed.
                                Adapter "valloxmv"       is not installed.
                                Adapter "vcard"          is not installed.
                                Adapter "vedirect"       is not installed.
                                Adapter "velux"          is not installed.
                                Adapter "viessmann"      is not installed.
                                Adapter "viessmannapi"   is not installed.
                                Adapter "virtualpowermeter" is not installed.
                                Adapter "vis"            is not installed.
                                Adapter "vis-bars"       is not installed.
                                Adapter "vis-canvas-gauges" is not installed.
                                Adapter "vis-colorpicker" is not installed.
                                Adapter "vis-fancyswitch" is not installed.
                                Adapter "vis-google-fonts" is not installed.
                                Adapter "vis-history"    is not installed.
                                Adapter "vis-hqwidgets"  is not installed.
                                Adapter "vis-inventwo"   is not installed.
                                Adapter "vis-jqui-mfd"   is not installed.
                                Adapter "vis-justgage"   is not installed.
                                Adapter "vis-keyboard"   is not installed.
                                Adapter "vis-lcars"      is not installed.
                                Adapter "vis-map"        is not installed.
                                Adapter "vis-material"   is not installed.
                                Adapter "vis-material-webfont" is not installed.
                                Adapter "vis-materialdesign" is not installed.
                                Adapter "vis-metro"      is not installed.
                                Adapter "vis-players"    is not installed.
                                Adapter "vis-plumb"      is not installed.
                                Adapter "vis-rgraph"     is not installed.
                                Adapter "vis-timeandweather" is not installed.
                                Adapter "vis-weather"    is not installed.
                                Adapter "vodafone-speedtest" is not installed.
                                Adapter "volvo"          is not installed.
                                Adapter "vr200"          is not installed.
                                Adapter "vw-connect"     is not installed.
                                Adapter "weatherunderground" is not installed.
                                Update web from @3.0.7 to @3.0.8
                                host.iobroker Adapter "system.adapter.web.0" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
                                upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
                                upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
                                upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
                                upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
                                upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
                                upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
                                upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
                                upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
                                upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
                                upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
                                upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
                                upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
                                upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
                                upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
                                upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
                                upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
                                upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
                                upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
                                upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
                                upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
                                upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
                                upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
                                upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
                                upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
                                upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
                                upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
                                upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
                                upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
                                upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
                                upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
                                upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
                                upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
                                upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
                                upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
                                upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                Update "system.adapter.web.0"
                                Adapter "web" updated
                                host.iobroker Adapter "system.adapter.web.0" is started
                                Adapter "web-speedy"     is not installed.
                                Adapter "weishaupt-wem"  is not installed.
                                Adapter "wiffi-wz"       is not installed.
                                Adapter "wifilight"      is up to date.
                                Adapter "windows-control" is not installed.
                                Adapter "wlanthermo-nano" is not installed.
                                Adapter "wled"           is not installed.
                                Adapter "wm-bus"         is not installed.
                                Adapter "wolf"           is not installed.
                                Adapter "worx"           is not installed.
                                Adapter "xbox"           is not installed.
                                Adapter "xs1"            is not installed.
                                Adapter "yahka"          is not installed.
                                Adapter "yamaha"         is not installed.
                                Adapter "yeelight-2"     is up to date.
                                Adapter "youtube"        is not installed.
                                Adapter "yr"             is not installed.
                                Update zigbee from @1.0.4 to @1.1.1
                                host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
                                NPM version: 6.14.4
                                npm install iobroker.zigbee@1.1.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                Update "system.adapter.zigbee.0"
                                upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                                upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
                                upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                                upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/jiawen.png img/jiawen.png image/png
                                upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/iluminize_511_040.png img/iluminize_511_040.png image/png
                                upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_led1837r5.PNG img/ikea_led1837r5.PNG image/png
                                upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
                                upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
                                upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_MS01.png img/ewelink_MS01.png image/png
                                upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                                upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                                upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                                upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
                                upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                                upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZWLD-100.png img/ZWLD-100.png image/png
                                upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0218.png img/TS0218.png image/png
                                upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS0215.png img/TS0215.png image/png
                                upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTW017.png img/LTW017.png image/png
                                upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC015.png img/LTC015.png image/png
                                upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LTC014.png img/LTC014.png image/png
                                upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
                                upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                                upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                                upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                                upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                Adapter "zigbee" updated
                                host.iobroker Adapter "system.adapter.zigbee.0" is started
                                Adapter "zoneminder"     is not installed.
                                Adapter "zont"           is not installed.
                                Adapter "zwave"          is not installed.
                                Adapter "zwave2"         is not installed.
                                Host    "iobroker"       is up to date.
                                pi@iobroker:/opt/iobroker $ npm rebuild
                                > node thank-you.js
                                gyp ERR! not ok
                                npm ERR! errno 1
                                npm ERR!
                                npm ERR!     /home/pi/.npm/_logs/2020-05-08T11_11_28_882Z-debug.log
                                maxpd
                                • M maxpd
                                  pi@iobroker:/opt/iobroker $ iobroker update
                                  Used repository: latest
                                  hash unchanged, use cached sources
                                  update done
                                  Adapter    "accuweather"   : 1.1.3
                                  Adapter    "alarm"         : 0.3.0
                                  Adapter    "alexa2"        : 3.1.2
                                  Adapter    "alpha2"        : 1.0.0
                                  Adapter    "amazon-dash"   : 1.1.0
                                  Adapter    "artnet"        : 1.2.2
                                  Adapter    "asterisk"      : 1.0.6
                                  Adapter    "asuswrt"       : 1.0.1
                                  Adapter    "b-control-em"  : 0.2.1
                                  Adapter    "backitup"      : 1.5.6
                                  Adapter    "beckhoff"      : 1.2.1
                                  Adapter    "benq"          : 0.2.2
                                  Adapter    "binance"       : 1.1.2
                                  Adapter    "ble"           : 0.11.6
                                  Adapter    "blink4home"    : 0.1.1
                                  Adapter    "bmw"           : 1.4.0
                                  Adapter    "boblight"      : 0.0.1
                                  Adapter    "bosesoundtouch": 0.9.2
                                  Adapter    "botvac"        : 1.0.0
                                  Adapter    "bring"         : 1.7.2
                                  Adapter    "broadlink2"    : 2.0.3
                                  Adapter    "bsblan"        : 0.0.6
                                  Adapter    "bshb"          : 0.1.10
                                  Adapter    "calendar"      : 1.2.0
                                  Adapter    "chromecast"    : 2.3.1    , installed 2.3.1
                                  Adapter    "cloud"         : 3.0.3    , installed 3.0.3
                                  Adapter    "comfoair"      : 1.1.1
                                  Adapter    "contact"       : 1.1.3
                                  Adapter    "contactid"     : 1.0.0
                                  Adapter    "coronavirus-statistics": 0.5.9
                                  Adapter    "corrently"     : 0.0.2
                                  Adapter    "countdown"     : 1.1.0
                                  Adapter    "cul"           : 1.2.1
                                  Adapter    "daikin"        : 1.0.5
                                  Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                                  Adapter    "deconz"        : 1.3.7
                                  Adapter    "devices"       : 0.3.6
                                  Adapter    "digitalstrom"  : 2.0.5
                                  Adapter    "discovergy"    : 0.5.4
                                  Adapter    "doorbird"      : 0.1.5
                                  Adapter    "ds18b20"       : 1.1.4
                                  Adapter    "dwd"           : 2.4.8
                                  Adapter    "ebus"          : 2.0.0
                                  Adapter    "ecovacs-deebot": 0.5.8
                                  Adapter    "egigeozone"    : 0.1.2
                                  Adapter    "ekey"          : 1.1.0
                                  Adapter    "email"         : 1.0.6
                                  Adapter    "emby"          : 1.0.2
                                  Adapter    "energymanager" : 1.2.2
                                  Adapter    "enet"          : 1.0.1
                                  Adapter    "epson_stylus_px830": 0.2.1
                                  Adapter    "exchangerates" : 0.0.12
                                  Adapter    "fakeroku"      : 0.2.1
                                  Adapter    "fb-checkpresence": 1.0.1
                                  Adapter    "feiertage"     : 1.0.19
                                  Adapter    "fhem"          : 1.4.1
                                  Adapter    "find-my-iphone": 0.2.17
                                  Adapter    "firetv"        : 1.0.0
                                  Adapter    "fitbit-api"    : 0.1.1
                                  Adapter    "flot"          : 1.9.2
                                  Adapter    "foobar2000"    : 1.0.0
                                  Adapter    "fritzbox"      : 0.2.1
                                  Adapter    "fritzdect"     : 0.3.2
                                  Adapter    "fronius"       : 1.0.5
                                  Adapter    "fullcalendar"  : 1.1.0
                                  Adapter    "fullybrowser"  : 1.0.3
                                  Adapter    "g-homa"        : 0.5.1
                                  Adapter    "geofency"      : 0.3.2
                                  Adapter    "gruenbeck"     : 0.0.18
                                  Adapter    "habpanel"      : 0.4.1
                                  Adapter    "haier"         : 1.0.3
                                  Adapter    "ham"           : 1.1.2
                                  Adapter    "ham-wemo"      : 1.0.1
                                  Adapter    "harmony"       : 1.2.2
                                  Adapter    "hass-mqtt"     : 0.0.7
                                  Adapter    "heatingcontrol": 0.5.0
                                  Adapter    "heytech"       : 0.2.0
                                  Adapter    "hid"           : 0.1.17
                                  Adapter    "hilink"        : 0.2.7
                                  Adapter    "hmip"          : 0.0.11
                                  Adapter    "hombot"        : 0.1.3
                                  Adapter    "homeconnect"   : 0.0.26
                                  Adapter    "homee"         : 1.0.5
                                  Adapter    "homepilot"     : 1.1.4
                                  Adapter    "hp-ilo"        : 1.0.5
                                  Adapter    "hs100"         : 1.1.2
                                  Adapter    "hue"           : 3.2.8
                                  Adapter    "hue-extended"  : 1.3.2
                                  Adapter    "hyperion"      : 0.0.9
                                  Adapter    "i2c"           : 0.0.6
                                  Adapter    "ical"          : 1.7.0
                                  Adapter    "icons-addictive-flavour-png": 0.1.0
                                  Adapter    "icons-fatcow-hosting": 0.1.0
                                  Adapter    "icons-icons8"  : 0.0.1
                                  Adapter    "icons-material-png": 0.1.0
                                  Adapter    "icons-material-svg": 0.1.0
                                  Adapter    "icons-mfd-png" : 1.0.2
                                  Adapter    "icons-mfd-svg" : 1.0.2
                                  Adapter    "icons-open-icon-library-png": 0.1.2
                                  Adapter    "icons-ultimate-png": 1.0.1
                                  Adapter    "influxdb"      : 1.8.4
                                  Adapter    "innogy-smarthome": 0.3.4
                                  Adapter    "intesishome"   : 0.1.2
                                  Adapter    "iogo"          : 0.5.10
                                  Adapter    "iot"           : 1.4.14   , installed 1.4.14
                                  Adapter    "iqontrol"      : 0.3.7
                                  Adapter    "javascript"    : 4.5.1    , installed 4.5.1
                                  Adapter    "jeelink"       : 0.1.3
                                  Adapter    "js2fs"         : 0.1.5
                                  Adapter    "kecontact"     : 0.1.0
                                  Adapter    "klf200"        : 0.9.5
                                  Adapter    "km200"         : 2.0.3
                                  Adapter    "knmi-weather"  : 0.2.0
                                  Adapter    "knx"           : 1.0.41
                                  Adapter    "kodi"          : 2.0.2
                                  Adapter    "kress"         : 2.5.5
                                  Adapter    "lametric"      : 0.0.7
                                  Adapter    "landroid"      : 1.0.3
                                  Adapter    "lcn"           : 0.6.3
                                  Adapter    "letrika_comgw" : 0.0.5
                                  Adapter    "lgtv"          : 1.1.6    , installed 1.1.6
                                  Adapter    "lgtv-rs"       : 0.1.0
                                  Adapter    "lgtv11"        : 1.0.5
                                  Adapter    "lifx"          : 0.1.1
                                  Adapter    "lightify"      : 0.2.16
                                  Adapter    "link"          : 0.5.9
                                  Adapter    "linkeddevices" : 1.1.4
                                  Adapter    "lovelace"      : 1.0.16
                                  Adapter    "loxone"        : 1.0.0
                                  Adapter    "luftdaten"     : 0.0.11
                                  Adapter    "lupusec"       : 1.2.6
                                  Adapter    "luxtronik1"    : 0.2.3
                                  Adapter    "material"      : 0.13.8
                                  Adapter    "maxcube"       : 0.1.2
                                  Adapter    "maxcul"        : 1.1.2
                                  Adapter    "mbus"          : 2.2.0
                                  Adapter    "mclighting"    : 0.1.1
                                  Adapter    "megad"         : 1.2.1
                                  Adapter    "megadd"        : 0.2.0
                                  Adapter    "megaesp"       : 0.1.0
                                  Adapter    "mercedesme"    : 0.0.21
                                  Adapter    "mercury"       : 0.1.1
                                  Adapter    "meross"        : 1.3.13
                                  Adapter    "meteoalarm"    : 1.1.0
                                  Adapter    "miele"         : 0.1.5
                                  Adapter    "mielecloudservice": 1.2.1
                                  Adapter    "mihome"        : 1.3.0
                                  Adapter    "mihome-airpurifier": 0.1.7
                                  Adapter    "mihome-lamp"   : 1.1.0
                                  Adapter    "mihome-plug"   : 0.2.1
                                  Adapter    "mihome-vacuum" : 2.0.7    , installed 1.1.5 [Updateable]
                                  Adapter    "miio"          : 0.0.13
                                  Adapter    "mikrotik"      : 1.0.12
                                  Adapter    "milight"       : 0.3.6
                                  Adapter    "milight-smart-light": 0.4.1
                                  Adapter    "mobile"        : 0.5.0
                                  Adapter    "modbus"        : 3.0.0
                                  Adapter    "moma"          : 1.2.6
                                  Adapter    "mpd"           : 1.0.5
                                  Adapter    "mqtt"          : 2.1.1
                                  Adapter    "mqtt-client"   : 1.3.1
                                  Adapter    "multicast"     : 0.1.5
                                  Adapter    "musiccast"     : 0.1.3
                                  Adapter    "mydlink"       : 1.0.9
                                  Adapter    "myq"           : 0.1.1
                                  Adapter    "mysensors"     : 2.0.0
                                  Adapter    "myvbus"        : 0.0.4
                                  Adapter    "nanoleaf-lightpanels": 0.8.2
                                  Adapter    "nello"         : 2.0.8
                                  Adapter    "netatmo"       : 1.3.1
                                  Adapter    "nibeuplink"    : 0.3.0
                                  Adapter    "nina"          : 0.0.23
                                  Adapter    "node-red"      : 1.17.2
                                  Adapter    "noolitef"      : 0.0.2
                                  Adapter    "nuki"          : 1.2.3
                                  Adapter    "nuki-extended" : 2.2.5
                                  Adapter    "nut"           : 1.1.3
                                  Adapter    "odl"           : 1.0.5
                                  Adapter    "oilfox"        : 2.1.0
                                  Adapter    "onkyo"         : 2.0.3
                                  Adapter    "onvif"         : 0.4.2
                                  Adapter    "openhab"       : 1.1.0
                                  Adapter    "openligadb"    : 1.1.0
                                  Adapter    "opentherm"     : 0.1.9
                                  Adapter    "openweathermap": 0.1.0
                                  Adapter    "opi"           : 0.1.1
                                  Adapter    "oppoplayer"    : 0.2.1
                                  Adapter    "owfs"          : 0.6.4
                                  Adapter    "owntracks"     : 0.6.2
                                  Adapter    "panasonic-viera": 1.0.2
                                  Adapter    "parser"        : 1.0.7
                                  Adapter    "paw"           : 0.3.2
                                  Adapter    "phantomjs"     : 1.0.1
                                  Adapter    "pi-hole"       : 1.2.3
                                  Adapter    "piface"        : 1.0.0
                                  Adapter    "pimatic"       : 0.2.1
                                  Adapter    "ping"          : 1.4.7    , installed 1.3.2 [Updateable]
                                  Adapter    "places"        : 0.7.0
                                  Adapter    "plenticore"    : 2.1.3
                                  Adapter    "plex"          : 0.8.11
                                  Adapter    "plexconnect"   : 0.0.7
                                  Adapter    "pollenflug"    : 1.0.6
                                  Adapter    "primelab"      : 1.0.2
                                  Adapter    "proxmox"       : 1.0.2
                                  Adapter    "proxy"         : 1.2.1
                                  Adapter    "pushbullet"    : 0.0.11
                                  Adapter    "pushover"      : 2.0.2
                                  Adapter    "pushsafer"     : 0.1.8
                                  Adapter    "radar2"        : 1.2.5
                                  Adapter    "radiohead"     : 1.0.5
                                  Adapter    "rainbird"      : 0.2.2
                                  Adapter    "rflink"        : 2.1.5
                                  Adapter    "rickshaw"      : 1.0.0
                                  Adapter    "ring"          : 1.1.2
                                  Adapter    "roadtraffic"   : 0.2.0
                                  Adapter    "robonect"      : 0.1.3
                                  Adapter    "roomba"        : 1.1.1
                                  Adapter    "rpi2"          : 1.2.0
                                  Adapter    "rssfeed"       : 0.0.28
                                  Adapter    "s7"            : 1.1.8
                                  Adapter    "samsung"       : 0.2.9
                                  Adapter    "sanext"        : 0.0.4
                                  Adapter    "sayit"         : 1.8.2    , installed 1.8.2
                                  Adapter    "sbfspot"       : 3.0.0
                                  Adapter    "scenes"        : 1.1.0
                                  Adapter    "schoolfree"    : 0.6.0
                                  Adapter    "senec"         : 1.0.8
                                  Adapter    "shelly"        : 3.2.7    , installed 3.1.6 [Updateable]
                                  Adapter    "shuttercontrol": 0.5.0    , installed 0.4.3 [Updateable]
                                  Adapter    "sia"           : 1.0.4
                                  Adapter    "siegenia"      : 1.0.0
                                  Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
                                  Adapter    "sma-em"        : 0.5.7
                                  Adapter    "smappee"       : 0.2.2
                                  Adapter    "smartmeter"    : 3.1.2
                                  Adapter    "snips"         : 1.5.0
                                  Adapter    "snmp"          : 0.5.0
                                  Adapter    "socketio"      : 3.0.7    , installed 3.0.6 [Updateable]
                                  Adapter    "solarlog"      : 2.0.0
                                  Adapter    "solarviewdatareader": 0.2.0
                                  Adapter    "solarwetter"   : 1.0.0
                                  Adapter    "sonnen"        : 1.5.0
                                  Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                                  Adapter    "sonos"         : 2.0.1
                                  Adapter    "sonus"         : 0.1.1
                                  Adapter    "sony-bravia"   : 1.0.1
                                  Adapter    "sourceanalytix": 0.4.2
                                  Adapter    "spotify-premium": 1.0.0
                                  Adapter    "sql"           : 1.12.5
                                  Adapter    "squeezebox"    : 1.0.0
                                  Adapter    "squeezeboxrpc" : 1.0.1
                                  Adapter    "starline"      : 1.0.0
                                  Adapter    "statistics"    : 0.2.2
                                  Adapter    "stiebel-isg"   : 1.4.11
                                  Adapter    "stockmarket"   : 0.0.2
                                  Adapter    "sunnyportal"   : 0.1.5
                                  Adapter    "swiss-weather-api": 0.2.0
                                  Adapter    "synology"      : 0.1.7
                                  Adapter    "systeminfo"    : 0.3.1
                                  Adapter    "tado"          : 0.1.9
                                  Adapter    "tahoma"        : 0.3.3
                                  Adapter    "tankerkoenig"  : 2.0.9
                                  Adapter    "telegram"      : 1.5.9    , installed 1.4.3 [Updateable]
                                  Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                  Adapter    "tesla-motors"  : 0.2.3
                                  Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                                  Adapter    "tileboard"     : 0.1.1
                                  Adapter    "tinker"        : 1.1.0
                                  Adapter    "tino"          : 0.1.3
                                  Adapter    "tinyrx4"       : 0.1.5
                                  Adapter    "tr-064"        : 4.0.1    , installed 0.4.18 [Updateable]
                                  Adapter    "tradfri"       : 2.6.2
                                  Adapter    "trashschedule" : 0.0.5
                                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                  Adapter    "tuya"          : 3.2.3
                                  Adapter    "tvspielfilm"   : 2.0.1
                                  Adapter    "unifi"         : 0.4.3
                                  Adapter    "unifi-protect" : 0.0.11
                                  Adapter    "upnp"          : 1.0.16
                                  Adapter    "vaillant"      : 0.0.10
                                  Adapter    "valloxmv"      : 1.0.3
                                  Adapter    "vcard"         : 0.0.9
                                  Adapter    "vedirect"      : 0.1.0
                                  Adapter    "velux"         : 0.0.5
                                  Adapter    "viessmann"     : 1.2.4
                                  Adapter    "viessmannapi"  : 1.3.2
                                  Adapter    "virtualpowermeter": 1.2.1
                                  Adapter    "vis"           : 1.2.6
                                  Adapter    "vis-bars"      : 0.1.4
                                  Adapter    "vis-canvas-gauges": 0.1.5
                                  Adapter    "vis-colorpicker": 1.2.0
                                  Adapter    "vis-fancyswitch": 1.1.0
                                  Adapter    "vis-google-fonts": 0.1.0
                                  Adapter    "vis-history"   : 1.0.0
                                  Adapter    "vis-hqwidgets" : 1.1.4
                                  Adapter    "vis-inventwo"  : 1.3.3
                                  Adapter    "vis-jqui-mfd"  : 1.0.12
                                  Adapter    "vis-justgage"  : 1.0.2
                                  Adapter    "vis-keyboard"  : 0.0.2
                                  Adapter    "vis-lcars"     : 1.0.4
                                  Adapter    "vis-map"       : 1.0.4
                                  Adapter    "vis-material"  : 0.1.3
                                  Adapter    "vis-material-webfont": 0.0.3
                                  Adapter    "vis-materialdesign": 0.3.6
                                  Adapter    "vis-metro"     : 1.1.2
                                  Adapter    "vis-players"   : 0.1.6
                                  Adapter    "vis-plumb"     : 1.0.2
                                  Adapter    "vis-rgraph"    : 0.0.2
                                  Adapter    "vis-timeandweather": 1.1.7
                                  Adapter    "vis-weather"   : 2.5.2
                                  Adapter    "vodafone-speedtest": 0.0.4
                                  Adapter    "volvo"         : 0.0.2
                                  Adapter    "vr200"         : 1.0.0
                                  Adapter    "vw-connect"    : 0.0.11
                                  Adapter    "weatherunderground": 3.2.1
                                  Adapter    "web"           : 3.0.8    , installed 3.0.7 [Updateable]
                                  Adapter    "web-speedy"    : 0.2.0
                                  Adapter    "weishaupt-wem" : 0.0.8
                                  Adapter    "wiffi-wz"      : 2.2.0
                                  Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
                                  Adapter    "windows-control": 0.1.3
                                  Adapter    "wlanthermo-nano": 0.1.1
                                  Adapter    "wled"          : 0.5.0
                                  Adapter    "wm-bus"        : 0.3.1
                                  Adapter    "wolf"          : 1.2.0
                                  Adapter    "worx"          : 1.0.2
                                  Adapter    "xbox"          : 0.6.3
                                  Adapter    "xs1"           : 1.0.2
                                  Adapter    "yahka"         : 0.11.0
                                  Adapter    "yamaha"        : 0.3.19
                                  Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                                  Adapter    "youtube"       : 0.0.8
                                  Adapter    "yr"            : 2.0.3
                                  Adapter    "zigbee"        : 1.1.1    , installed 1.0.4 [Updateable]
                                  Adapter    "zoneminder"    : 0.3.3
                                  Adapter    "zont"          : 0.5.4
                                  Adapter    "zwave"         : 2.0.1
                                  Adapter    "zwave2"        : 0.11.7
                                  Adapter "accuweather"    is not installed.
                                  Adapter "alarm"          is not installed.
                                  Adapter "alexa2"         is not installed.
                                  Adapter "alpha2"         is not installed.
                                  Adapter "amazon-dash"    is not installed.
                                  Adapter "artnet"         is not installed.
                                  Adapter "asterisk"       is not installed.
                                  Adapter "asuswrt"        is not installed.
                                  Adapter "b-control-em"   is not installed.
                                  Adapter "backitup"       is not installed.
                                  Adapter "beckhoff"       is not installed.
                                  Adapter "benq"           is not installed.
                                  Adapter "binance"        is not installed.
                                  Adapter "ble"            is not installed.
                                  Adapter "blink4home"     is not installed.
                                  Adapter "bmw"            is not installed.
                                  Adapter "boblight"       is not installed.
                                  Adapter "bosesoundtouch" is not installed.
                                  Adapter "botvac"         is not installed.
                                  Adapter "bring"          is not installed.
                                  Adapter "broadlink2"     is not installed.
                                  Adapter "bsblan"         is not installed.
                                  Adapter "bshb"           is not installed.
                                  Adapter "calendar"       is not installed.
                                  Adapter "chromecast"     is up to date.
                                  Adapter "cloud"          is up to date.
                                  Adapter "comfoair"       is not installed.
                                  Adapter "contact"        is not installed.
                                  Adapter "contactid"      is not installed.
                                  Adapter "coronavirus-statistics" is not installed.
                                  Adapter "corrently"      is not installed.
                                  Adapter "countdown"      is not installed.
                                  Adapter "cul"            is not installed.
                                  Adapter "daikin"         is not installed.
                                  Adapter "daswetter"      is up to date.
                                  Adapter "deconz"         is not installed.
                                  Adapter "devices"        is not installed.
                                  Adapter "digitalstrom"   is not installed.
                                  Adapter "discovergy"     is not installed.
                                  NPM version: 6.14.4
                                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                  ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  NPM version: 6.14.4
                                  > node thank-you.js
                                  gyp ERR! System Linux 4.19.97-v7l+
                                  gyp ERR! node -v v12.16.3
                                  gyp ERR! node-gyp -v v5.1.0
                                  gyp ERR! not ok
                                  npm ERR! errno 1
                                  npm ERR!
                                  #79
                                  @maxpd
                                  Und? Läuft zigbee nun?
                                    @maxpd
                                    maxpd
                                    #80
                                    @Thomas-Braun AAABBBBERRR Zigbeeeee läuft!!!!!!!!!!!!
                                    maxpd
                                    • Thomas BraunT Online
                                      #81
                                      Schön! Dann kannst du ja jetzt dein skript korrigieren. ;-)
                                      • M maxpd
                                        #82
                                        @maxpd Und stell vielleicht den Verwahrungsor mal wieder auf 'default' zurück. Dann hast du mit upgrade erst wieder zu tun, wenn deine Module in höherer Version da irgendwann auftauchen.
