  4. Javascript Adapter rot (out of memory)
javascript
82 Beiträge 6 Kommentatoren 12.2k Aufrufe 5 Beobachtet
  • M maxpd
    @Thomas-Braun will er nicht.
    pi@iobroker:/opt/iobroker $ iobroker rebuild iobroker.zigbee --install
    Commands:
    iobroker setup [--objects <host>] [--states <host>] [custom]
    iobroker start
    iobroker stop
    iobroker start <adapter>
    iobroker stop <adapter>
    iobroker start all
    iobroker restart
    iobroker restart <adapter>
    iobroker info
    iobroker logs [adapter] [--watch] [--lines=1000]
    iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
    iobroker install <adapter>
    iobroker url <url> [<name>]
    iobroker del <adapter>
    iobroker del <adapter>.<instance>
    iobroker update [repository url] [--updatable/--u] [--installed/--i]
    iobroker upgrade [repository url]
    iobroker upgrade self [repository url]
    iobroker upgrade <adapter> [repository url]
    iobroker upload <pathToLocalFile> <pathIniobroker>
    iobroker upload all
    iobroker upload <adapter>
    iobroker object get <id>
    iobroker object set <id> <json-value>
    iobroker object set <id> propertyname=value
    iobroker object del <id|pattern> [--yes]
    iobroker object chmod <object-mode> [state-mode] <id>
    iobroker object chown <user> <group> <id>
    iobroker object list <id>
    iobroker state get <id>
    iobroker state getplain <id> [--pretty]
    iobroker state getvalue <id>
    iobroker state set <id> <value> [ack]
    iobroker state del <id>
    iobroker message <adapter>[.instanceid] <command> [<message>]
    iobroker list <type> [filter]
    iobroker chmod <mode> <file>
    iobroker chown <user> <group> <file>
    iobroker touch <file>
    iobroker rm <file>
    iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
    iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
    iobroker file rm <iobroker-path-to-delete>
    iobroker file sync
    iobroker user add <user> [--ingroup group] [--password pass]
    iobroker user del <user>
    iobroker user passwd <user> [--password pass]
    iobroker user enable <user>
    iobroker user disable <user>
    iobroker user get <user>
    iobroker user check <user> [--password pass]
    iobroker group add <group>
    iobroker group del <group>
    iobroker group list <group>
    iobroker group enable <group>
    iobroker group disable <group>
    iobroker group get <group>
    iobroker group adduser <group> <user>
    iobroker group deluser <group> <user>
    iobroker host this
    iobroker host <hostname>
    iobroker host set <hostname>
    iobroker host remove <hostname>
    iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
    iobroker license <license.file or license.text>
    iobroker cert create
    iobroker cert view [<certificate name>]
    iobroker clean
    iobroker backup
    iobroker restore <backup name or path>
    iobroker validate <backup name or path>
    iobroker <command> --timeout 5000
    iobroker status [all]
    iobroker repo [name]
    iobroker repo add <name> <path or url>
    iobroker repo set <name>
    iobroker repo del <name>
    iobroker uuid
    iobroker unsetup
    iobroker fix
    iobroker multihost <enable|disable> [--secure true|false]
    iobroker multihost browse
    iobroker multihost connect
    iobroker compact status
    iobroker compact <enable|on|disable|off>
    iobroker compact <adapter>.<instance> status
    iobroker compact <adapter>.<instance> group <group-id>
    iobroker compact <adapter>.<instance> <disable|off>
    iobroker compact <adapter>.<instance> <enable|on> [group-id]
    iobroker version [adapter]
    iobroker [adapter] -v
    Options:
      --help     Hilfe anzeigen  [boolean]
      --version  Version anzeigen  [boolean]
    #41
    @maxpd
    iobroker version
      @maxpd
      iobroker version
      maxpd
      #42
      @Thomas-Braun 2.2.9
      maxpd
      Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
      • M maxpd
        @Thomas-Braun 2.2.9
        #43
        @maxpd
        Möglich das 2.2.9 das noch nicht kann. Bei mir gibt es 'rebuild' in 3.0.20.
        Dann
        npm rebuild iobroker.zigbee
          @maxpd
          Dann
          maxpd
          #44
          @Thomas-Braun
          Dabei hab ich das System neu aufgesetzt. Warum bin ich eine ganze Hauptversion hintendran?!
          Auch der rebuild lässt Zigbee nicht starten. Fehler bleibt der gleiche.
          maxpd
          • M maxpd
            @Thomas-Braun
            #45
            @maxpd
            npm rebuild bindings
            Bist du auf 'default'? V3 ist glaube ich erst in 'latest' drin.
            M 3 Antworten Letzte Antwort
              @maxpd
              maxpd
              #46
              @Thomas-Braun
              Habe das Image
              maxpd
              • M maxpd
                @Thomas-Braun
                Habe das Image
                #47
                @maxpd Das Image hat mit iobroker nichts direkt zu tun.
                  @maxpd
                  maxpd
                  #48
                  @Thomas-Braun ich vermute ^^
                  maxpd
                    @maxpd
                    maxpd
                    #49
                    @Thomas-Braun said in Javascript Adapter rot (out of memory):
                    @maxpd
                    ich vermute ^^
                    maxpd
                    • M maxpd
                      @maxpd
                      ich vermute ^^
                      #50
                      @maxpd
                      Schau mal unter dem 'Schraubenschlüssel' im Admin unter 'Verwahrungsort' nach. Dürfte aber 'default' sein.
                      Hast du die bindings neugebaut?
                        @maxpd
                        maxpd
                        #51
                        @maxpd
                        maxpd
                        • M maxpd
                          @maxpd
                          #52
                          @maxpd Auf dem ersten Reiter.
                          2.2.9. ist in 'default', hab gerade schon geschaut. Lass das mal da stehen.
                          • M maxpd
                            @Thomas-Braun
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #53
                            @maxpd sagte in Javascript Adapter rot (out of memory):
                            auch der rebuild lässt Zigbee nicht starten. Fehler bleibt der gleiche.
                            Das ist Murks ... warum postet du hier nicht weiter !!!!
                            Link Text
                              maxpd
                              #54
                              Ist im Ordner /opt/iobroker eine Datei package-lock.json? -JA
                              Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @? -JA
                              Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
                              pi@iobroker:/opt/iobroker $ cat package.json
                                "name": "iobroker.inst",
                                "version": "2.0.3",
                                "private": true,
                                "description": "Automation platform in node.js",
                                "scripts": {
                                  "install": "node lib/checkVersions.js",
                                  "postinstall": "node lib/install.js",
                                  "test": "node node_modules/mocha/bin/mocha --exit"
                                "dependencies": {
                                  "colors": "^1.3.3",
                                  "fs-extra": "^7.0.1",
                                  "iobroker": "^2.0.3",
                                  "iobroker.admin": "^4.0.9",
                                  "iobroker.chromecast": "^2.3.1",
                                  "iobroker.cloud": "^3.0.3",
                                  "iobroker.daswetter": "^2.8.1",
                                  "iobroker.denon": "^1.7.4",
                                  "iobroker.discovery": "^2.2.2",
                                  "iobroker.google-sharedlocations": "https://github.com/t4qjXH8N/ioBroker.google-sharedlocations/tarball/ec1d15964dc6f3995f744d240d8b972bf25331fe",
                                  "iobroker.history": "^1.8.7",
                                  "iobroker.hm-rega": "^2.5.5",
                                  "iobroker.hm-rpc": "^1.12.10",
                                  "iobroker.info": "^1.5.6",
                                  "iobroker.iot": "^1.4.14",
                                  "iobroker.javascript": "^4.5.1",
                                  "iobroker.js-controller": "^2.2.9",
                                  "iobroker.lgtv": "^1.1.6",
                                  "iobroker.mihome-vacuum": "^1.1.5",
                                  "iobroker.ping": "^1.3.2",
                                  "iobroker.sayit": "^1.8.2",
                                  "iobroker.shelly": "^3.1.6",
                                  "iobroker.shuttercontrol": "^0.4.3",
                                  "iobroker.socketio": "^3.0.6",
                                  "iobroker.sonoff": "^2.3.3",
                                  "iobroker.telegram": "^1.4.3",
                                  "iobroker.terminal": "^0.1.2",
                                  "iobroker.text2command": "^1.3.0",
                                  "iobroker.tr-064": "^0.4.18",
                                  "iobroker.web": "^3.0.7",
                                  "iobroker.wifilight": "https://github.com/iobroker-community-adapters/ioBroker.wifilight/tarball/3b408fefaca79abe9bb404216791b5408d3d6d52",
                                  "iobroker.yeelight-2": "^1.0.3",
                                  "iobroker.zigbee": "^1.0.4",
                                  "semver": "^5.6.0",
                                  "yargs": "^7.0.2"
                              maxpd
                              • M maxpd
                                  "version": "2.0.3",
                                  "private": true,
                                  "scripts": {
                                  "dependencies": {
                                    "colors": "^1.3.3",
                                    "semver": "^5.6.0",
                                    "yargs": "^7.0.2"
                                #55
                                @maxpd
                                In den anderen Thread wurde dann deine Zeile 16 gelöscht und das Ding lief wieder. Kannst du auch mal probieren.
                                Ich übernehme aber keine Gewähr, das deine Kiste nicht explodiert und die Katze tötet.
                                GlasfaserG M 3 Antworten Letzte Antwort
                                  @maxpd
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #56
                                  @Thomas-Braun sagte in Javascript Adapter rot (out of memory):
                                  Der ist gut 👍
                                    @maxpd
                                    maxpd
                                    #57
                                    @Thomas-Braun ok, ich leg morgen erst mal ein backup an.
                                    maxpd
                                      @maxpd
                                      maxpd
                                      #58
                                      @Thomas-Braun Zeile 16 ist gelöscht. Jetzt wird davon gesprochen, dass man Adapter wieder installieren kann. Der Adapter ist per se ja noch da. Soll ich trotzdem ran mit
                                      maxpd
                                      • M maxpd
                                        #59
                                        @maxpd
                                        iobroker stop
                                        iobroker start
                                        Und dann schau nochmal, was das Adapter im log ausgibt, wenn der startet.
                                          @maxpd
                                          iobroker stop
                                          iobroker start
                                          maxpd
                                          #60
                                          @Thomas-Braun
                                          Bislang nur Zeile 16 gelöscht und iobroker neu gestartet.
                                          Fehler ist weiterhin der gleiche.
                                          host.iobroker	2020-05-08 10:57:34.353	info	Restart adapter system.adapter.zigbee.0 because enabled
                                          host.iobroker	2020-05-08 10:57:34.353	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                          host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                          host.iobroker	2020-05-08 10:57:34.353	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                          host.iobroker	2020-05-08 10:57:34.352	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: was compiled against a different Node.js version using
                                          host.iobroker	2020-05-08 10:57:34.351	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                                          host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: ^
                                          host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: throw e;
                                          host.iobroker	2020-05-08 10:57:34.350	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                                          host.iobroker	2020-05-08 10:57:33.963	info	instance system.adapter.zigbee.0 started with pid 7660
                                          maxpd
