  4. Test Adapter Gartenbewässerung v0.0.x
    apollon77A
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 220.0k Aufrufe 77 Beobachtet
  • JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    #481
    @tombox
    Auch wenn du den Adapter nicht weiter entwickelst, kannst du bitte die Fehlermeldung die der Adapter im Zusammenhang mit Admin 5.x.x ausgibt, ggf noch heilen?
    gartenbewaesserung.0	2021-05-10 06:55:28.555	info	(4324) State value to set for "gartenbewaesserung.0.status.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.fortschritt" has been written without ack-flag with value "100"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.restzeit_sek" has been written without ack-flag with value "10"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	warn	(4324) Read-only state "gartenbewaesserung.0.status.restzeit" has been written without ack-flag with value "00:10"
    gartenbewaesserung.0	2021-05-10 06:55:28.554	info	(4324) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-10 06:55:28.553	warn	(4324) Read-only state "gartenbewaesserung.0.status.ventil4.fortschritt" has been written without ack-flag with value "99"
    gartenbewaesserung.0	2021-05-10 06:55:28.553	info	(4324) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
    gartenbewaesserung.0	2021-05-10 06:55:28.553	warn	(4324) Read-only state "gartenbewaesserung.0.status.ventil4.restzeit_sek" has been written without ack-flag with value "10"
    • JB_SullivanJ JB_Sullivan
      @tombox
      T
      T
      tombox
      schrieb am zuletzt editiert von tombox
      #482
      @jb_sullivan habe mal blind ein update in github gemacht da müssten die fehler weg sein und habe nochmal 4 ventile hinzugefügt bitte mal testen ob noch alles geht
      AtomicIXA sigi234S 2 Antworten Letzte Antwort
      • T tombox
        AtomicIXA
        AtomicIXA
        AtomicIX
        #483
        @tombox dann gehen jetzt 10 Ventile? 😍
        Das für deine Mühe.
        • AtomicIXA AtomicIX
          Das für deine Mühe.
          T
          T
          tombox
          #484
          @atomicix rein theoretisch ja wenn ich nichts vergessen habe.. einfach testen
          AtomicIXA 1 Antwort Letzte Antwort
          • T tombox
            AtomicIXA
            AtomicIXA
            AtomicIX
            #485
            @tombox okay, ich habe das jetzt übers Handy / VPN auf meinem entfernen System probiert.
            Habe vorher nicht auf die Version geachtet. Jetzt ist die 0.0.7 installiert. Habe aber weiterhin nur 6 Ventile.
            Muss ich die Instanzen neu aufsetzen? Oder hat da einfach was nicht funktioniert?
            Muss ich sonnst morgen abend mal live vor Ort gucken.
              T
              T
              tombox
              #486
              @atomicix Es muss ein Upload durchgeführt werden was eigentlich nach neuinstallation und adaper neustart passiert
              • T tombox
                AtomicIXA
                AtomicIXA
                AtomicIX
                #487
                @tombox okay, habe das update/Installation über Git jetzt noch mal probiert. Jetzt hat es auch erheblich länger gedauert. Jetzt habe ich die 0.0.8 drauf und ohne Neuinstallation oder reboot werden mir die 10 möglichen Ventile angezeigt. Im Changelog steht noch 0.0.7, das hätte mich irritiert.
                Danke für die Änderung.
                Jetzt muss nur noch mal der Regen aufhören, das der Adapter auch einen Sinn macht.
                • T tombox
                  sigi234S
                  sigi234S
                  sigi234
                  #488
                  @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
                  artenbewaesserung.0
                  2021-05-13 23:38:54.772	warn	Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1620931019"
                  2021-05-13 23:38:54.748	info	State value to set for "gartenbewaesserung.0.status.ventil6.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.713	info	State value to set for "gartenbewaesserung.0.status.ventil5.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.712	info	State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.711	info	State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.711	info	State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.710	info	State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.709	info	State value to set for "gartenbewaesserung.0.status.ventil6.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.704	info	State value to set for "gartenbewaesserung.0.status.ventil5.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.703	info	State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.699	info	State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.699	info	State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.698	info	State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                  2021-05-13 23:38:54.665	info	Stop ventil6
                  2021-05-13 23:38:54.665	info	Stop ventil5
                  2021-05-13 23:38:54.665	info	Stop ventil4
                  2021-05-13 23:38:54.665	info	Stop ventil3
                  2021-05-13 23:38:54.665	info	Stop ventil2
                  2021-05-13 23:38:54.664	info	Stop ventil1
                  2021-05-13 23:38:54.664	info	Bewässerung stop
                  2021-05-13 23:38:54.664	info	Stop ventil6
                  2021-05-13 23:38:54.664	info	Stop ventil5
                  2021-05-13 23:38:54.664	info	Stop ventil4
                  2021-05-13 23:38:54.663	info	Stop ventil3
                  2021-05-13 23:38:54.663	info	Stop ventil2
                  2021-05-13 23:38:54.662	info	Stop ventil1
                  2021-05-13 23:38:54.587	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil10.dauer_in_state_mult"
                  2021-05-13 23:38:54.587	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil9.dauer_in_state_mult"
                  2021-05-13 23:38:54.586	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil8.dauer_in_state_mult"
                  2021-05-13 23:38:54.586	info	undefined is not a valid state value for id "gartenbewaesserung.0.config.ventil7.dauer_in_state_mult"
                  2021-05-13 23:38:54.569	warn	This object will not be created in future versions. Please report this to the developer.
                  2021-05-13 23:38:54.569	warn	Object gartenbewaesserung.0.config.ventil10.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil9.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2021-05-13 23:38:54.568	warn	This object will not be created in future versions. Please report this to the developer.
                  2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil8.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2021-05-13 23:38:54.568	warn	Object gartenbewaesserung.0.config.ventil7.dauer_in_state_mult is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                  2021-05-13 23:38:54.567	info	State value to set for "gartenbewaesserung.0.config.updateinterval" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.565	info	State value to set for "gartenbewaesserung.0.config.pauseTime" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.510	info	State value to set for "gartenbewaesserung.0.config.raintresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.483	info	State value to set for "gartenbewaesserung.0.config.temptresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.476	info	State value to set for "gartenbewaesserung.0.config.ventil6.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil5.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil4.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.475	info	State value to set for "gartenbewaesserung.0.config.ventil3.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.474	info	State value to set for "gartenbewaesserung.0.config.ventil2.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.474	info	State value to set for "gartenbewaesserung.0.config.ventil1.feuchtigkeit_tresh" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.442	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.441	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.441	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.440	info	State value to set for "gartenbewaesserung.0.config.ventil3.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.440	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.439	info	State value to set for "gartenbewaesserung.0.config.ventil1.dauer_in_state_mult" has to be type "undefined" but received type "string"
                  2021-05-13 23:38:54.409	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.408	info	State value to set for "gartenbewaesserung.0.config.ventil3.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.407	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.407	info	State value to set for "gartenbewaesserung.0.config.ventil1.dauerstate_mult" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.401	info	State value to set for "gartenbewaesserung.0.config.ventil6.dauer" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.400	info	State value to set for "gartenbewaesserung.0.config.ventil5.dauer" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.399	info	State value to set for "gartenbewaesserung.0.config.ventil4.dauer" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.399	info	State value to set for "gartenbewaesserung.0.config.ventil2.dauer" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.383	info	State value to set for "gartenbewaesserung.0.config.minSonnenuntergang" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.373	info	State value to set for "gartenbewaesserung.0.config.minSonnenaufgang" has to be type "number" but received type "string"
                  2021-05-13 23:38:54.344	info	starting. Version 0.0.8 in C:/Program Files/iobroker/Home/node_modules/iobroker.gartenbewaesserung, node: v12.22.1, js-controller: 3.3.9
                  Plattform: Windows
                  RAM: 16 GB
                  Node.js: 12.22.1
                  NPM: 6.14.12
                  JS Controller: 3.3.9
                  Admin: 5.0.22
                  Web: 3.4.1
                  Socket.io: 3.1.4
                  Script Engine: 5.1.3
                  Immer Daten sichern!
                  • sigi234S sigi234
                    artenbewaesserung.0
                    Plattform: Windows
                    RAM: 16 GB
                    Node.js: 12.22.1
                    NPM: 6.14.12
                    Admin: 5.0.22
                    Web: 3.4.1
                    Socket.io: 3.1.4
                    T
                    T
                    tombox
                    #489
                    @sigi234 Jetzt müsste es passen, kann aber sein das man die werte in den optionen neu setzen muss damit sie den richtigen typ haben
                    G 1 Antwort Letzte Antwort
                    • T tombox
                      G
                      G
                      gender
                      #490
                      @tombox
                      Vielen Dank für das Update.
                      Mir ist aufgefallen, dass nun das Objekt "Restlaufzeit" für die Anzeige der Minuten stets auf "null" bleibt. Die verbleibenden Sekunden werden korrekt angezeigt.
                      Ansonsten scheint alles weiter wie gewohnt zu laufen.
                      P.S.: Ich weiß, der Adapter wird nicht mehr weiterentwickelt, aber ich wollte zumindest mal nachfragen, falls ich nur eine Einstellung falsch gemacht habe: Sobald ich eine andere Ventilöffnungszeit bei einem Ventil im Objekt "ventilx.dauer" einstelle, startet der gesamte Adapter immer neu. Das ist unsofern umständlich, als das es natürlich ärgerlich ist, wenn gerade schon ein Ventil offen ist und hier die Zeit abläuft. Stellt man dann ein anderes Ventil auf (mit einer andereren als der zuvor eingestellten Zeit, ist natürlich das vorher geöffnete Ventil auch wieder zu.
                      Gibts da noch ne Möglichkeit der Veränderung?
                      • G gender
                        @tombox
                        T
                        T
                        tombox
                        #491
                        @gender Den Fehler habe ich gefixt. Leider ist der Adapter nicht ausgelegt das man während des Betriebs die Zeiten ändert
                        • S
                          S
                          Snapergy
                          #492
                          @tombox
                          Vielen Dank für das nochmalige Update. Du siehst, dass dein Adapter von den Usern ebenfalls als sehr gut eingeschätzt wird und auch wenn der andere Adapter aus deiner Sicht besser ist, die Nutzer sich in großer Zahl für deinen entscheiden. Da hast du wirklich klasse Arbeit geleistet! :)
                          • S Snapergy
                            @tombox
                            T
                            T
                            Tschaeens
                            #493
                            @snapergy sehe ich genauso!
                            Würde mir ebenfalls eine Weiterentwicklung wünschen!
                            • JB_SullivanJ
                              JB_SullivanJ
                              JB_Sullivan
                              #494
                              @tombox
                              Ich wollte gerade das Update auf die Version 0.0.8 machen, weil ich immer noch die folgenden Fehler angezeigt bekommen.
                              gartenbewaesserung.0	2021-05-26 10:05:05.700	warn	(248) Read-only state "gartenbewaesserung.0.status.startAbend" has been written without ack-flag with value "Wed May 26 2021 20:39:43 GMT+0200"
                              gartenbewaesserung.0	2021-05-26 10:05:05.699	warn	(248) Read-only state "gartenbewaesserung.0.status.startMorgen" has been written without ack-flag with value "Wed May 26 2021 05:40:21 GMT+0200"
                              gartenbewaesserung.0	2021-05-26 10:05:05.698	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenuntergang" has been written without ack-flag with value "21:24:43 GMT+0200 (Mitteleuropäische Sommerzeit)"
                              gartenbewaesserung.0	2021-05-26 10:05:05.697	warn	(248) Read-only state "gartenbewaesserung.0.status.sonnenaufgang" has been written without ack-flag with value "05:10:21 GMT+0200 (Mitteleuropäische Sommerzeit)"
                              gartenbewaesserung.0	2021-05-26 10:05:05.541	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.539	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.538	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.522	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.521	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.520	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.518	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.517	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.514	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.513	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.512	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.511	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.510	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.509	info	(248) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.508	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.507	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.506	info	(248) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.504	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.503	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.502	info	(248) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                              gartenbewaesserung.0	2021-05-26 10:05:05.501	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.restzeit_sek" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.500	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.fortschritt" has to be type "number" but received type "string"
                              gartenbewaesserung.0	2021-05-26 10:05:05.498	info	(248) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                              Seit der Admin Version 5.x.x funktioniert unter ioB / Windows aber das Adapter Update aus dem Admin heraus bei manchen Adapter nicht mehr. Es kommt dann ein sogenannter EBUSY Fehler. Leider gehört dein Adapter dazu.
                              Der Workaround ist das Update aus der Konsole heraus durchzuführen. Aber auch das funktioniert im Fall der Version 0.0.8 nicht.
                              Hast du eine Idee dazu?
                              C:\iobroker\GLT>npm install iobroker.gartenbewaesserung@0.0.8
                              npm ERR! code E404
                              npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.gartenbewaesserung - Not found
                              npm ERR! 404
                              npm ERR! 404  'iobroker.gartenbewaesserung@0.0.8' is not in the npm registry.
                              npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                              npm ERR! 404
                              npm ERR! 404 Note that you can also install from a
                              npm ERR! 404 tarball, folder, http url, or git url.
                              npm ERR!     C:\iobroker\GLT\env\npm-cache\_logs\2021-05-26T08_17_13_008Z-debug.log
                              C:\iobroker\GLT>
                                @tombox
                                npm ERR! code E404
                                npm ERR! 404
                                npm ERR! 404
                                C:\iobroker\GLT>
                                T
                                T
                                tombox
                                #495
                                @jb_sullivan Installation geht nur über GitHub Katze wie im ersten Beitrag beschrieben
                                JB_SullivanJ 1 Antwort Letzte Antwort
                                • T tombox
                                  JB_SullivanJ
                                  JB_SullivanJ
                                  JB_Sullivan
                                  #496
                                  @tombox
                                  Wie gesagt, GITHUB Katze geht derzeit unter Admin 5.x.x wegen EBUSY Fehler nicht.
                                  Ich habe es aber doch noch hin bekommen und habe jetzt die 0.0.8 drauf. Trotzdem tauchen im LOG immer noch ein paar Fehlermeldungen auf.
                                  gartenbewaesserung.0	2021-05-26 10:44:59.822	warn	(5768) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.811	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.809	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.802	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.801	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.799	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil4.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.798	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil3.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.797	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil2.active" has to be type "string" but received type "boolean"
                                  gartenbewaesserung.0	2021-05-26 10:44:59.795	info	(5768) State value to set for "gartenbewaesserung.0.status.ventil1.active" has to be type "string" but received type "boolean"
                                    @tombox
                                    T
                                    T
                                    tombox
                                    #497
                                    @jb_sullivan die objekte müssen vorher gelöscht werden damit sie korrekt neu erstellt werden
                                    • T tombox
                                      JB_SullivanJ
                                      JB_SullivanJ
                                      JB_Sullivan
                                      #498
                                      @tombox Habe ich gemacht, aber das ändert nichts.
                                      gartenbewaesserung.0	2021-05-26 19:31:28.417	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:28.415	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:28.414	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:28.412	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:28.393	info	(1988) Stop ventil4
                                      gartenbewaesserung.0	2021-05-26 19:31:28.388	info	(1988) Stop ventil3
                                      gartenbewaesserung.0	2021-05-26 19:31:28.383	info	(1988) Stop ventil2
                                      gartenbewaesserung.0	2021-05-26 19:31:28.378	info	(1988) Stop ventil1
                                      gartenbewaesserung.0	2021-05-26 19:31:28.377	info	(1988) Bewässerung stop
                                      gartenbewaesserung.0	2021-05-26 19:31:24.440	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:24.439	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052084"
                                      gartenbewaesserung.0	2021-05-26 19:31:24.438	warn	(1988) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:01:24 GMT+0200"
                                      gartenbewaesserung.0	2021-05-26 19:31:24.437	info	(1988) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                      gartenbewaesserung.0	2021-05-26 19:31:24.426	info	(1988) Start ventil1
                                      gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil4 in 5130sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Start ventil4 in 3630sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.408	info	(1988) Stop ventil3 in 3620sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Stop ventil2 in 3610sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.407	info	(1988) Start ventil2 in 1810sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Stop ventil1 in 1800sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.406	info	(1988) Start ventil1 in 0sek
                                      gartenbewaesserung.0	2021-05-26 19:31:24.377	info	(1988) Start pumpe
                                      gartenbewaesserung.0	2021-05-26 19:31:24.376	info	(1988) Start Bewaesserung
                                      gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil4
                                      gartenbewaesserung.0	2021-05-26 19:31:24.194	info	(1988) Stop ventil3
                                      gartenbewaesserung.0	2021-05-26 19:31:24.193	info	(1988) Stop ventil2
                                      gartenbewaesserung.0	2021-05-26 19:31:24.192	info	(1988) Stop ventil1
                                      gartenbewaesserung.0	2021-05-26 19:31:24.191	info	(1988) Bewässerung stop
                                      gartenbewaesserung.0	2021-05-26 19:30:51.762	warn	(1988) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                                        T
                                        T
                                        tombox
                                        #499
                                        @jb_sullivan Sollte so nicht passieren.. Alle objekte löschen. Per github installieren und instanz neustarten?
                                        • T tombox
                                          JB_SullivanJ
                                          JB_SullivanJ
                                          JB_Sullivan
                                          schrieb am zuletzt editiert von JB_Sullivan
                                          #500
                                          @tombox Genau so - habe ich alles genau so gemacht. Admin und js-controler ist latest letzter Stand.
                                          Habe es nochmal auf DEBUG gestellt - aber da kommt auch nicht viel bei raus.
                                          gartenbewaesserung.0	2021-05-26 19:39:46.507	debug	(12300) system.adapter.admin.0: logging true
                                          gartenbewaesserung.0	2021-05-26 19:39:42.848	warn	(12300) Read-only state "gartenbewaesserung.0.status.startAbendTimestamp" has been written without ack-flag with value "1622054383"
                                          gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil4
                                          gartenbewaesserung.0	2021-05-26 19:39:42.738	info	(12300) Stop ventil3
                                          gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil2
                                          gartenbewaesserung.0	2021-05-26 19:39:42.737	info	(12300) Stop ventil1
                                          gartenbewaesserung.0	2021-05-26 19:39:42.736	info	(12300) Bewässerung stop
                                          gartenbewaesserung.0	2021-05-26 19:39:42.735	info	(12300) Stop ventil4
                                          gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil3
                                          gartenbewaesserung.0	2021-05-26 19:39:42.734	info	(12300) Stop ventil2
                                          gartenbewaesserung.0	2021-05-26 19:39:42.731	info	(12300) Stop ventil1
                                          gartenbewaesserung.0	2021-05-26 19:39:41.743	info	(12300) starting. Version 0.0.8 in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 3.3.11
                                          gartenbewaesserung.0	2021-05-26 19:39:41.325	debug	(12300) statesDB connected
                                          gartenbewaesserung.0	2021-05-26 19:39:41.324	debug	(12300) States connected to redis: 127.0.0.1:9000
                                          gartenbewaesserung.0	2021-05-26 19:39:41.310	debug	(12300) States create User PubSub Client
                                          gartenbewaesserung.0	2021-05-26 19:39:41.309	debug	(12300) States create System PubSub Client
                                          gartenbewaesserung.0	2021-05-26 19:39:41.296	debug	(12300) Redis States: Use Redis connection: 127.0.0.1:9000
                                          gartenbewaesserung.0	2021-05-26 19:39:41.294	debug	(12300) objectDB connected
                                          gartenbewaesserung.0	2021-05-26 19:39:41.284	debug	(12300) Objects connected to redis: 127.0.0.1:9001
                                          gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects client initialize lua scripts
                                          gartenbewaesserung.0	2021-05-26 19:39:41.263	debug	(12300) Objects create User PubSub Client
                                          gartenbewaesserung.0	2021-05-26 19:39:41.262	debug	(12300) Objects create System PubSub Client
                                          gartenbewaesserung.0	2021-05-26 19:39:41.259	debug	(12300) Objects client ready ... initialize now
                                          gartenbewaesserung.0	2021-05-26 19:39:41.215	debug	(12300) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          gartenbewaesserung.0	2021-05-26 19:42:42.836	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:42:32.839	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:42:22.834	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:42:12.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:42:02.837	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:41:52.833	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:41:46.796	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:41:46.795	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.endeTimestamp" has been written without ack-flag with value "1622052706"
                                          gartenbewaesserung.0	2021-05-26 19:41:46.794	warn	(12300) Read-only state "gartenbewaesserung.0.status.ventil1.ende" has been written without ack-flag with value "Wed May 26 2021 20:11:46 GMT+0200"
                                          gartenbewaesserung.0	2021-05-26 19:41:46.793	info	(12300) State value to set for "gartenbewaesserung.0.status.restzeit" has to be type "number" but received type "string"
                                          gartenbewaesserung.0	2021-05-26 19:41:46.779	info	(12300) Start ventil1
                                          gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Stop ventil4 in 5130sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.762	info	(12300) Start ventil4 in 3630sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil3 in 3620sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.761	info	(12300) Stop ventil2 in 3610sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Start ventil2 in 1810sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.760	info	(12300) Stop ventil1 in 1800sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.759	info	(12300) Start ventil1 in 0sek
                                          gartenbewaesserung.0	2021-05-26 19:41:46.739	info	(12300) Start pumpe
                                          gartenbewaesserung.0	2021-05-26 19:41:46.738	info	(12300) Start Bewaesserung
                                          gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil4
                                          gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil3
                                          gartenbewaesserung.0	2021-05-26 19:41:46.599	info	(12300) Stop ventil2
                                          gartenbewaesserung.0	2021-05-26 19:41:46.598	info	(12300) Stop ventil1
                                          gartenbewaesserung.0	2021-05-26 19:41:46.597	info	(12300) Bewässerung stop
                                          84.0k
                                          1.4m
